Skip to main content
TG-LR82 / TG-LR92 User Manual
Quickstart Guide​
  • Register device on LoRaWAN network server. Use tg-lrx2-2.0-ul-dec.js payload decoder script if device model not supported.
  • Activate the device: new devices start in SHUTDOWN. Hold the magnet near the switch for about 1.5 s to enter digit 2, then remove it. The device confirms the command with short LED blinks and restarts in RUN mode.
  • Wait for network join. Default profile 0 sends current-state and device-orientation every 5 minutes. The first uplink after join can also contain version, serial-number, cfg-state, and dev-health frames.
  • Decode the first uplink to verify temperature, humidity, orientation, battery, and device identity data. See Magnet Switch for command input details.
Functionality​
note
New device is in SHUTDOWN mode. To activate use magnet switch commands.
Models
ModelDescriptionSensors
TG-LR82LoRaWAN 1.0.4 Class A, B, 863.0 - 869.0 MHz band.TMP116N, HDC2010, LIS2DW12
TG-LR92LoRaWAN 1.0.4 Class A, B, 900.0 - 928.0 MHz band.TMP116N, HDC2010, LIS2DW12
note
For safety warnings, hardware specifications, installation, and regulatory information, see the TG-LR82 hardware page and TG-LR92 hardware page.
Bands
Numeric codeNameDescription
1BAND_1GHzSub-GHz operating band. Frequency range is based on device Model.
2BAND_2GHz2.4GHz ISM band. Supported by both models; uses the LoRaWAN ISM2400 region automatically when active.
Operating modes
Numeric codeModeDescription
0SHUTDOWNDevice in low power mode. Network and data services are stopped, but all magnet switch commands remain available. Settings can be changed in this mode and the device activated afterwards.
1RUNDevice joins network and sends uplinks based on current profile and configuration.
Supported regions
X-Y CodedownlinkCommon NameTG-LR82TG-LR92
1-11EU868Yes
2-12AS923_GRP1Yes
3-13US915Yes
4-14AU915Yes
ISM2400YesYes
6-17AS923_GRP2Yes
7-18AS923_GRP3Yes
8-19IN865Yes
9-110KR920Yes
The X-Y code is the magnet switch sequence. The numeric downlink value is used by lora set-region.
ISM2400 is the LoRaWAN 2.4 GHz region. It is supported by both models and is used automatically whenever BAND_2GHz is active. BAND_2GHz can be the primary or secondary band (lora primary-band, lora second-band).
lora set-region configures only the sub-GHz region. It cannot select ISM2400, and ISM2400 is not available while only BAND_1GHz is active. There is currently no independent ISM2400 region selection or runtime region switch; change the active band to use it.
LoRaWAN​
Device supports Class A and B, and can operate in two frequency bands: BAND_1GHz and BAND_2GHz. User can configure periodic link check, MAC time synchronization (DeviceTimeReq) and network ADR.
Join Procedure​
Once activated (RUN) device will attempt to join network. Device sends Join-Request on primary band and if Join-Accept is not received it will wait back-off interval and send next Join-Request on secondary band if enabled, otherwise primary-band again.
note
Join attempt interval depends on time on air for last Join-Request and total join time. See 1 section 7. If last join request used slower data rate - expect longer interval.
Join configuration commands: lora primary-band, lora second-band, lora join-cfg. See Command Encoding on how to convert text commands to binary encoding for downlink.
Link check lets the end device verify that the network is still reachable. Most uplinks can be non-confirmed, so they do not prove that the network received them. Use periodic link check or confirmed uplinks when the device must detect a lost network.
Link check can be configured specifically for each band using lora link-chk. If link check fails, the device leaves the network and restarts the join procedure. A failed confirmed uplink has the same effect.
note
Any network downlink will restart link check timer to prevent unnecessary LinkCheckReq.
Time Synchronization​
Time synchronization gives stored events absolute timestamps instead of device uptime. Events and telemetry can be stored locally and sent later, so absolute time lets the application know when an event actually occurred. This is useful when the device is outside network coverage and reports the collected data after it returns to coverage.
Device supports optional time synchronization using DeviceTimeReq MAC command. See command lora clk-sync for configuration parameters or to request immediate synchronization.
Class B​
Device supports Class B operation. Class B operation can be either manually requested using lora class or device can be configured to automatically switch to class B on network join using lora cfg-class-b.
ADR Configuration​
It is possible to disable network ADR and set fixed data rate using lora adr-cfg.
warning
In FW 2.0.1, ADR changes made while the device is joined may not take effect until the device rejoins or restarts (LORA-281). With network ADR disabled, only DR0 works as a fixed data rate (LORA-282). Reset the device after changing ADR; when network ADR is disabled, use DR0.
Leaving Network​
In case of Link Check or confirmed uplink failure device leaves network and restarts join procedure.
Credentials​
Device has factory configured default credentials that come with each device: DevEUI, JoinEUI, AppKey.
DevEUI and JoinEUI are IEEE 64-bit EUI (2) written MSB first. On air byte order is LSB first. See 1 section 6.2.5.
AppKey is 16 byte AES128 encryption key and is written as stored in device memory. AppKey must be kept secret!
To change JoinEUI and AppKey use commands: lora join-eui, lora net-key and lora cred. Commands lora join-eui and lora net-key can be issued in any order and multiple times to write new pending join credentials.
Once new pending credentials are written “lora cred 600,1” or “app reset 0” can be executed to attempt join with new credentials. If new credentials are not confirmed by join accept device will revert to previous. See LORA-275, LORA-276 for known issues!
Example sequence where JoinEUI and AppKey are written and join is attempted:
lora join-eui 87904163,0x00,0x16,0xC0,0x01,0xFF,0xFE,0x00,0x00
lora net-key 87904163,0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F
lora cred 600
app reset 0
// device reboots and attempts join using new credentials with 600s timeout
JoinEUI from previous example can be copy/pasted as is 00 16 C0 01 FF FE 00 00 to register new device. lora join-eui parameters are MSB first.
warning
Executing lora cred <confirm-timeout-s>,87904163 will force confirm credentials without verification join attempt! You may lose access to device!
Each LoRaWAN uplink can carry one or more pending Data Frames. Frames are added in ascending frame-ID order. The first frame-type delta is encoded in the FPort field; additional type deltas are encoded at the start of FRMPayload, followed by the frame contents. The FPort value therefore depends on the first frame type and is not a fixed application port.
The device packs only frames that fit in the current payload. Frames that do not fit remain pending for the next uplink. If any packed frame is configured as confirmed, the whole uplink is sent as confirmed. A failed confirmed uplink causes the device to leave the network and restart the join procedure.
note
See tg-lrx2-2.0-ul-dec.js script for frame encoding details. This script can be used as is in application server payload decoders.
Telemetry​
Device Profiles​
Device has 6 configurable profiles. Each profile stores independent sensor and uplink send configuration. This allows device to quickly change operating characteristics without requiring costly downlink configuration messages. Profile can be switched using Device Commands, magnet or even based on evaluated Data Rules. For instance switching between periodic keepalive mode with uplinks few times per day to more rapid telemetry every few minutes.
note
MikroTik can support your specific use case, new devices with custom default configuration are available.
Devices come preconfigured with evaluation configuration to showcase some of possible use case:
Default profile configuration
Profile NumberNameDescription
0Sensor TelemetrySend current-state, device-orientation every 5 minutes. Send remaining telemetry every 60 minutes.
1Activity MonitorSend activity, full-activity, current-state every 60 min and generate activity_state events on LOW and IDLE state changes.
2Magnet SwitchSend mag-switch, current-state, device-events every 60 minutes and generate a mag_sw_cnt event when the magnet has been removed for at least 20 seconds. Save up to 10 events.
3OrientationSend current-state, device-events, device-orientation every 60 minutes. Generate a device-orientation frame when the rotation angle exceeds 30 degrees. Generate angle_1 and meta_rule_id events when the device is close to reference vector V=(0,1,1). Save up to 3 events.
4Asset MonitorSend dev-health, device-orientation, histograms, ema-temp, ema-humid, motion-events, impact-count, and device-events every 3 hours. Additional frames and events are generated by the factory rules for orientation, impact, free fall, temperature, humidity, and magnet removal. Save up to 10 events.
5Empty
See default-cfg.txt for exact factory default configuration commands.
Configuring Sensors​
Sampling Intervals​
Periodic temperature, humidity and battery voltage sampling can be configured for specific use cases using data poll-cfg command. Device can sample data at a higher rate than uplink frames are sent. This gives opportunity to send average values or to perform rule based decisions. Since sampling interval influences device power consumption this can be leveraged to improve lifetime.
Averaging​
Device also tracks average of sampled values in: temperature_ema, humidity_ema, battery_mv_ema, angle_ema. Command data ema-cfg configures exponential moving average (EMA) period and optionally can send EMA values in current-state, dev-health, device-orientation if send-ema-* is enabled.
Count parameters temp-cnt, humid-cnt, bat-cnt, orient-cnt in data ema-cfg determine coefficient a used for moving average calculation. Moving EMA is calculated based on previous value ema and new value sample as:
ema(t) = sample(t) * a + ema(t-1) * (1 - a)
To get approximate time constant t of EMA you need to use sampling intervals configured by data poll-cfg and data orient-cfg (interval) and respective count parameter (N):
t ~ (N + 1) * interval / 2
To get required count parameter value for data ema-cfg:
N ~ 2 * t / interval - 1
Example:
Temperature sampling interval th-poll-int is configured to 30s using data poll-cfg. To configure EMA with time constant t ~ 60 minutes:
temp-cnt = 2 * 3600 / 30 - 1 = 239
Assuming profile #0 is used and we don’t want to change other parameters we need to send command:
data ema-cfg 1,239
Histogram​
All periodic samples are added to temperature and humidity histograms. Histograms can be used in addition to regular telemetry or simply stand alone to monitor temperature and humidity distribution. Configure bins and epoch intervals using data temp-histo-cfg, data humid-histo-cfg commands and/or enable temp-histogram, humid-histogram frames. All histogram frames contain epoch number to detect histogram counter reset. Since frame size is limited to 1B per bin, if internal bin counter value is above 255 histogram will be normalized (probability type) for uplink.
Example configuration:
data temp-histo-cfg 1,86400,0,0,1,1,-10,0,10,15,17.5,20,22.5,25.0,30
data humid-histo-cfg 1,86400,0,0,1,1,10,20,30,40,50,60,70,80,90
Orientation​
Device accelerometer axis.
Periodic device 3D orientation sampling relative to Earth can be configured using command: data orient-cfg. In addition 3 user orientation vectors ref-1, ref-2, ref-3 can be configured to detect specific device orientations. User variables angle_1, angle_2, angle_3 contain current angle between device last sampled orientation and user defined vector. These variables can be used in Data Rules to trigger on specific orientation. angle_ema is angle between last sampled device orientation and EMA value of samples. In addition coarse orientation is also available with major_axis_orientation variable.
major_axis_orientation description
ValueNumeric codeDescription
XH0X up
HL1X down
YH2Y up
YL3Y down
ZH4Z up
ZL5Z down
DISABLED7sensor disabled
Coarse orientation has advantage that it is sent in current-state frame.
Activity Monitor​
Device has activity monitoring service based on accelerometer. This service will automatically manage simple state machine that determines movement/activity. activity_s, high_activity_s, total_activity_s count accumulated time in each state activity_state, activity_state_etm hold state information.
Command data activity-cfg can be used to configure mode and thresholds for activity monitoring. data activity-cal can be used to automatically perform calibration for specific mode.
level1-th and level2-th units are 1/64 * 2G irrespective of other accelerometer settings (like in data acc-cfg). level2-cnt is internally computed and not user configurable. level2-cnt is always in range 7..15 and calculated as:
level2-cnt = 7 + round((1 - ((level2-th - level1-th - 1) / 61)) * 8)
activity_state description
Numeric codeValue
0IDLE
1LOW
2HIGH
3DISABLED
Single Mode​
Mode in data activity-cfg is set to single.
  • If accelerometer sample value in any axis is above level1-th device transitions from IDLE to LOW state.
  • If all samples for at least 1.3s are below level1-th device transitions from LOW to IDLE state.
note
The 1.3 s LOW-to-IDLE timing applies to single-level mode. In dual mode the accelerometer and state machine use different timing; use the 5 s transitions in the Dual Mode table only for dual mode.
Example to set profile #0 single mode with threshold 0.25G:
data activity-cfg 1,1,8,63
Dual Mode​
Mode in data activity-cfg is set to dual.
In dual mode LOW state has two sub states: LOW1 and LOW2 that both represent LOW. Device will report LOW state during both of these and actvity counter values are incremented as if in LOW state. Only difference is transition logic between these states.
activity_state dual mode state transitions
CurrentNextCondition
IDLELOW2sample > level1-th
LOW2LOW1sample < level2-th at least 5s
LOW1LOW2sample > level1-th
LOW2HIGHsample > level2-th at least level2-cnt times
LOW1IDLEsample < level1-th at least 5s
HIGHLOW1sample < level2-th at least 5s
Example to set profile #0 dual mode with thresholds 0.25G and 0.5G:
data activity-cfg 1,2,8,16
Calibration​
In addition to manually configuring level1-th and level2-th there is activity calibration functionality. Executing command data activity-cal will perform auto calibration of cal-level. level-one will calibrate level1-th and level-two will calibrate level2-th for all profiles selected in profile-mask. For dual mode you can run level-one and level-two in sequence. Calibration time is 15s. This functionality is mostly suited for periodic motion/vibration.
note
It may be useful to enable LED during calibration procedure or activity monitor testing to ensure correct operation.
Example to calibrate profile #0 with single level activity monitor:
warning
Activity calibration with orientation enabled causes fault and device reboot. Disable using data orient-cfg before calibration and re-enable after finished. See LORA-279.
  1. Place device in environment with periodic motion/activity to calibrate.
  2. Send commands:
    data activity-cfg 1,1,,,1
    data activity-cal 1,1,1
  3. Observe LED periodic blink 2x/1.5s for ~ 15s.
  4. Test motion detection. During LOW activity device will blink LED 3x/1s.
  5. If calibration results are acceptable send command to disable LED:
    data activity-cfg 1,,,,0
Example to calibrate profile #0 with dual level activity monitor:
  1. Place device in environment with periodic motion/activity for level 1 calibration.
  2. Send commands:
    data activity-cfg 1,2,,,1
  4. Place device in environment for level 2 calibration.
  5. Send commands to calibrate level 2:
    data activity-cal 1,2,1
  6. Observe LED periodic blink 2x/1.5s for ~ 15s.
  7. Test motion detection. During HIGH activity device will blink LED 6x/1s.
  8. If calibration results are acceptable send command to disable LED:
note
After calibration level1-th and level2-th can be manually changed using command data activity-cfg.
Impact and Free fall​
Command data acc-cfg can be used to configure device accelerometer for basic impact and free-fall detection. Frames: motion-events, impact-count contain relevant data fields. current-state contains impact_evnt, free_fall_evnt flags that indicate new event. These can be used if explicit read is preferred.
Variables impact_cnt, impact_cnt_x, impact_cnt_y, impact_cnt_z, impact_etm, free_fall_cnt, free_fall_etm allow rule based logic.
warning
If Activity Monitor is enabled impact and free fall detection can’t be used and will be ignored.
Data Rules​
Up to 32 user rules can be stored using data set-rule and data del-rule. A rule contains a test expression, optional input expressions, and optional actions. If <rule-num> is omitted, the first free rule slot is used. data del-rule without a rule number deletes all rules; with a rule number it deletes one rule. Rule configuration persists across reboots; rule evaluation state is reset on reboot.
Command syntax to add or override rules:
data set-rule [<rule-num>],<test-expr>,[<input-expr>],[<switch-profile>],[<make-event-0>],[<make-event-1>], [<make-event-2>],[<make-event-3>],[<send-frame-0>],[<send-frame-1>],[<send-frame-2>],[<send-frame-3>],[<clr-timer-mask>]
Rule Model​
The test expression is evaluated against one value from User Variables and produces the rule local state. The local state combined with optional input rules produces the rule combined state.
An action is executed only when combined state changes from false to true. While it remains true, actions are not repeated. When it changes back to false, no action is executed.
Rules are evaluated in dependency order. Rules without inputs are evaluated first, then rules whose input rules have already been evaluated. Rule numbers identify rules and input references; they do not define evaluation order. A rule that depends on itself directly or through other rules is not evaluated.
Test Expression​
<test-expr>: [^] <variable-type> <operator> <argument>
ElementDescription
[^]use the absolute value of the variable in the expression
variable-typevariable name or numeric ID from User Variables
<operator>>, >=, <, <=, ==, !=, %
<argument>numeric value
The % operator is true when the integer part of abs(variable) % abs(argument) is zero. <argument> must not be zero.
Fractional arguments are supported and use fixed-point encoding. Prefer integer arguments where possible because fractional values increase rule encoding size. Use == and != only for exact-value variables; for measured analog values, prefer threshold comparisons.
Time values such as mag_sw_etm, impact_etm, timer_1, profile_etm, and activity_state_etm are in seconds. daytime_tm and unix_time are only useful after Time Synchronization.
Example:
data set-rule 0,profile == 0
data set-rule 1,^temperature > 30.55
data set-rule 2,impact_etm < 60
Use variable names in rule commands. The tg-lrx2-encode utility converts variable and frame names to numeric IDs and encodes the commands into the compact binary downlink format.
Input Expression​
Input expression is used if a rule needs to depend on the result of other rules. This allows constructing logic based on multiple test expressions.
<input-expr>: [&][|][!]<input-rule>[<]...
TermDescription
[&]AND input with the current combined value
[|]OR input with the current combined value
[!]invert the input value
<input-rule>rule number whose state is used
[<]use the input rule combined state, otherwise its local state.
The first input term is combined with the rule local state. Each additional term is applied to the result. There are no parentheses and no operator precedence.
warning
Terms are applied in ascending input-rule number order, regardless of the order written in the command. This is easy to miss when composing expressions.
Following configuration will send current-state data frame if magnet switch changed state less than 15s ago and temperature or humidity are out of range (-5..55 and 10..90%):
data del-rule
data set-rule 0,temperature < -5
data set-rule 1,temperature > 55
data set-rule 2,humidity < 10
data set-rule 3,humidity > 90,|0|1|2
data set-rule 4,mag_sw_etm < 15,&3<,,,,,,current-state
Rule 3 combines its own result with rules 0, 1, and 2 using OR. Rule 4 combines its own result with the combined state of rule 3 using AND. The action of rule 4 therefore runs when the magnet switch changed recently and any temperature or humidity threshold is true.
warning
Rule numbers are not evaluation order. Rules are evaluated in dependency order. Avoid circular dependencies: rules in a cycle are not evaluated. Input rules must be enabled; disabled input rules are not part of the evaluation order.
Actions​
If combined state changes to true, actions are executed once for that transition. Actions execute in this order: generate events, schedule frames, reset user timers. The optional profile switch is applied after all rules in the current evaluation pass. Rules in the same pass therefore still see the previous profile; the new profile is used from the next evaluation pass.
If <switch-profile> parameter is given, the active profile is changed. The value range is 0..5. This does not make the profile the default; use app profile with make-default or a magnet profile command to persist it. For example if temperature drops below 15 C device will switch to profile 5 (Device Profiles):
data set-rule 1,temperature < 15,,5
Up to 4 different Data Frames can be scheduled per rule. Scheduled frames are sent as soon as the network stack has air time; they do not wait for the configured periodic uplink interval:
data set-rule 0,impact_cnt % 10,,,,,,,current-state,device-orientation,dev-health,ema-temp
note
Rule chaining can be used if more than 4 frames should be sent.
Up to 4 different events can be generated per rule. Events are captured when the action executes and are described in Events:
data set-rule 0,impact_cnt % 10,,,temperature_ema,humidity_ema,activity_state,timer_1
The optional <clr-timer-mask> resets user timers when the action executes. See Timers and Rule ID Events.
Events​
Actions can optionally generate events. Events are stored in device memory and sent in the device-events frame. Event storage is configured per profile using data event-cfg:
OptionDescription
max-countMaximum stored events (0 disables event storage, range 1..100).
send-thSchedule device-events when the pending count is at least this value. 0 schedules a frame after every new event.
discardSelect oldest or newest event when storage is full.
send-allAfter a device-events frame is sent, schedule another frame while events remain.
Events are sent when the device-events frame is scheduled periodically using frame set-cfg, immediately using frame send, by a rule send-frame action, or automatically by the send-th threshold. Use data erase-events to erase all events or a selected number of oldest events.
Each event record in the device-events frame contains:
  • a length byte; bit 7 set means more records follow;
  • a 4-byte timestamp;
  • a 1-byte event code;
  • an optional value.
The timestamp is UNIX time after Time Synchronization, otherwise device uptime. Event codes 0..99 are user-variable events and carry the variable value. Event codes 100..229 are reserved for rule events; meta_rule_id uses code 100 + rule-number and carries no value. The supplied payload decoder interprets these records.
Example commands:
data event-cfg 1,50,10,0,1
data erase-events
data erase-events 10
The first command configures profile 0 to store at most 50 events, schedule device-events when at least 10 events are pending, discard the oldest event when full, and keep sending while events remain. The second command erases all events; the third erases the 10 oldest events.
Timers and Rule ID Events​
timer_1, timer_2, timer_3, and timer_4 are free-running user timers. They count seconds from the last reset and are reset on device reboot.
data timer sets the elapsed value of selected timers. Omitted parameters are left unchanged:
data timer 0
data timer ,0
data timer ,,,0
The first command resets timer_1, the second resets timer_2, and the third resets timer_4.
The <clr-timer-mask> action parameter is a 4-bit mask: bit 0 resets timer_1, bit 1 resets timer_2, bit 2 resets timer_3, and bit 3 resets timer_4.
meta_rule_id is a special event-action value. It cannot be used as a normal test variable. When an action generates an event for meta_rule_id, the event code is 100 + rule-number and the event has no value. The decoder reports this event as data_rule. This identifies which rule fired when several rules send the same frame. For example:
data set-rule 0,temperature > 30,,,temperature,meta_rule_id,,,current-state
data set-rule 1,humidity > 90,,,humidity,meta_rule_id,,,current-state
When either rule fires, current-state is scheduled and the event identifies the rule that triggered it.
Magnet Switch​
Device has magnet switch that can be used for command input or as magnetic field sensor. If unused, command input can be completely disabled or PIN protected using mag svc command.
note
Unique PIN code comes with each device.
Command Input​
User must apply command sequence of 1 to 4 digits. Each digit is entered consecutively. After 2.5s idle, valid input command is executed and device indicates result using LED. Successfully executed command is indicated with 3x 0.2s LED blinks and failure is 1s long LED pulse. Invalid commands are ignored.
When magnetic field is applied to device, LED starts blinking with interval 500ms ON, 500ms OFF (or according to mag cfg configured blink-mode). When LED is switched on, internal counter is incremented starting from 0. When magnetic field is removed counter value is latched as user input digit. If magnetic field is applied again, next digit in input sequence is started. If interval after applying digit is larger than 2.5s, sequence is evaluated.
note
When applying input code based on time, ensure to follow this equation: T = N - 0.5, where N is input digit from 1 to 9 and T is time in seconds to apply magnetic field. The interval between digits must be less than 2.5s, but more than 200ms.
Some commands require PIN mode to be entered and some can be optionally protected by PIN mode. See table Magnet switch commands. To enter PIN mode, user must apply sequence of PIN digits provided with the device. Once PIN mode is entered it will expire after configurable time and device will return back to normal mode.
warning
It is also possible to completely disable magnet commands. Only way to re-enable is using LoRaWAN downlink command. This can be useful if magnet sensor is used only for detecting external signals and no user commands are expected or allowed.
SequencePIN modeCommand description
2optionalActivate - enable RUN mode.
3-1optionalTrigger current-state frame uplink.
4-1-XoptionalSwitch device profile, where X is Profile Number + 1 [1..6].
4-2-1optionalSet primary band to BAND_1GHz.
4-2-2optionalSet primary band to BAND_2GHz.
4-3-1optionalEnable secondary band.
4-3-9optionalDisable secondary band.
6-1optionalDevice restart.
6-2-9optionalDeactivate device - SHUTDOWN mode.
9-X-YoptionalSet region for sub GHz band as per Supported regions.
6-9-9mandatoryDevice factory reset.
3-1-5mandatoryExit PIN mode.
A-B-C-D–Enter PIN mode. A-B-C-D are digits of device factory PIN code.
5-3-1optionalReserved.
note
LED indications during digit input can be changed based on device configuration. It is possible to change or completely disable LED indications using mag cfg.
Magnet Sensor​
Magnetic sensor is always operational (even when commands are applied). This sensor can be utilized to detect switching events mag_sw_flag or to count number of these events mag_sw_cnt. Device can report current switch state, number of state changes and last time stamp (UNIX/uptime) mag_switch_ts. Additionally you can create rules based on these attributes.
Command Encoding​
Device commands are binary encoded to reduce downlink message size. We provide Python utilities to verify, encode and publish commands as LoRaWAN binary downlink messages.
Install from PyPI with pip install tg-lrx2-utils.
PortPurpose
2Binary command message. After the commands are processed, the device schedules a cfg-state uplink with the current configuration checksums.
3Binary command message.
tg-lrx2-encode places all encoded messages on the command port except the last message, which is placed on the configuration port to trigger the cfg-state response. Send all generated messages in file order. If –max-len splits a script into several messages, the order is required.
Example configuration to set current-state and activity frame uplink every 600 seconds and mag-switch every 43200 seconds as confirmed message:
# lora-script.txt
frame set-cfg 1,601,0,0,current-state,activity
frame set-cfg 1,43200,1,0,mag-switch
We can use tg-lrx2-encode to convert text commands to binary messages for downlink:
tg-lrx2-encode --script ./lora-script.txt --max-len=50 --out ./lora-pub.yml
note
tg-lrx2-utils includes a device descriptor and uses it by default. Pass –dev-desc only when you need to override it, for example to use the 2.0 descriptor supplied with this manual. Make sure the descriptor matches the device and FW version.
lora-pub.yml will contain serialized binary payloads to use for downlink. You can either manually schedule them using available web tools or use tg-lrx2-pub to schedule them on The Things Network:
tg-lrx2-pub --host ./ttn-app.yml --dl-msg ./lora-pub.yml device-id
Example TTN credential file:
# ttn-app.yml
app-id: "ttn-tag-demo@ttn"
host: "eu1.cloud.thethings.industries"
port: 1883
user: "ttn-tag-demo@ttn"
password: "NNSXS.5G..."
warning
ttn-app.yml contains an access key. Keep it out of source control and do not publish it.
tg-lrx2-encode accepts command strings on CLI as well. This can be used for single or few lines of commands:
tg-lrx2-encode --cmd $'frame send device-orientation\napp profile 1,0' --max-len=50 --out ./lora-pub.yml
Device Commands​
All device commands consist of group-name and cmd-name. Optional parameters are given in square brackets. Parameters must be comma separated for tg-lrx2-encode script. group-name and cmd-name can also be comma separated but spaces are also accepted.
Example:
app factory-reset <key>,[<fw-def>],<delay-ms>
Parameters <key> and <delay-ms> are mandatory, but <fw-def> is optional and can be omitted:
app factory-reset 984651411,,2500
Each parameter has a valid input range and format. Some parameters allow only a specific choice between values or a choice between ranges.
Most parameters accept integer values. %f indicates that parameter accepts fractional value. Use of these values results in larger downlink payload so if possible integer values should be preferred. variable-type indicates that parameter accepts either user variable name or respective integer ID. frame-type indicates that parameter accepts either data frame name or integer ID. tg-lrx2-encode automatically converts these names to numeric ID.
The reference includes advanced manual commands such as data sample and data next-epoch. See Advanced Operations.
app set-mode​
Set device operating mode
Syntax
app set-mode <mode>
ParameterRangeDescription
mode0SHUTDOWN
1RUN
app profile​
Switch active profile and optionally make default
Syntax
app profile <profile-num>,<make-default>
profile-num0..5
make-default0no
1yes
app reset​
System reset
Syntax
app reset <type>
type0board
1app only
app factory-reset​
Reboot device, clear saved configuration and set to defaults (optional)
Syntax
key984651411
fw-def784565141don’t apply default configuration
delay-ms0..65535
app led​
Configure application LED signals
Syntax
app led [<enable>]
enable0no
1yes
app set-time​
Set UNIX time relative to device uptime
Syntax
app set-time [<unix-time-s>],<uptime-s>
unix-time-s0..4294967295
uptime-s0..4294967295
lora set-region​
Set LoRaWAN region for sub GHz band
Syntax
lora set-region <region-code>
region-code1EU868
2AS923-1
3US915
4AU915
7AS923-2
8AS923-3
9IN865
10KR920
lora primary-band​
Select primary band
Syntax
lora primary-band <band>
band1<1GHz
22.45GHz
lora second-band​
Enable or disable secondary band
Syntax
lora second-band <mode>
mode0off
1on
lora join-cfg​
Configure join duty cycle for band
Syntax
lora join-cfg <band>,<duty>
band1<1GHz
22.45GHz
duty00.1%
1..254
2551%
Set band specific link check interval and timeout
Syntax
lora link-chk <band>,<int-minutes>
band1<1GHz
22.45GHz
int-minutes0off
5..500000
lora adr-cfg​
Enable network ADR or configure fixed data rate
Syntax
lora adr-cfg <en-netw-adr>,[<fixed-data-rate>]
en-netw-adr0off
1on
fixed-data-rate0..6
lora clk-sync​
Absolute time synchronization
Syntax
lora clk-sync [<int-minutes>],[<leap-sec>],<sync-now>,[<retry-s>],[<retry-cnt>]
int-minutes0off
1..65535
leap-sec-128..127
sync-now0no
1yes
retry-s0..255
retry-cnt0..255
lora cfg-class-b​
Configure LoRaWAN Class B
Syntax
lora cfg-class-b [<auto-en>],[<ping-slot-int-s>]
auto-en0off
1on
ping-slot-int-s1
2
4
8
16
32
64
128
lora class​
Switch LoRaWAN class
Syntax
lora class <class>
class0A
1B
lora join-eui​
Override network JoinEUI
Syntax
lora join-eui <cred-ch-key>,<eui-0>,<eui-1>,<eui-2>,<eui-3>,<eui-4>,<eui-5>,<eui-6>,<eui-7>
cred-ch-key87904163
eui-00..255
eui-10..255
eui-20..255
eui-30..255
eui-40..255
eui-50..255
eui-60..255
eui-70..255
lora net-key​
Override network AppKey
Syntax
lora net-key <cred-ch-key>,<key-0>,<key-1>,<key-2>,<key-3>,<key-4>,<key-5>,<key-6>,<key-7>,<key-8>,<key-9>,<key-10>,<key-11>,<key-12>,<key-13>,<key-14>,<key-15>
cred-ch-key87904163
key-00..255
key-10..255
key-20..255
key-30..255
key-40..255
key-50..255
key-60..255
key-70..255
key-80..255
key-90..255
key-100..255
key-110..255
key-120..255
key-130..255
key-140..255
key-150..255
lora cred​
User network credential management
Syntax
lora cred [<confirm-timeout-s>],[<action>]
confirm-timeout-s60..65535revert if not joined
action0clear pending
1try now
87904163force confirm
frame send​
Schedule uplink frames
Syntax
frame send <frame-id>,...
frame-idframe-type
frame set-cfg​
Set uplink frame configuration
Syntax
frame set-cfg <profile-mask>,[<ul-period-s>],[<confirmed>],[<on-join>],<frame-id>,...
profile-mask1..63bitfield
ul-period-s0off
1..65535
confirmed0no
1yes
on-join0no
1yes
frame-idframe-type
frame clear-cfg​
Clear all frame config for specified profiles (as if ‘set-cfg profile-mask,0,0,0,…’)
Syntax
frame clear-cfg <profile-mask>
mag cfg​
Set configuration
Syntax
mag cfg [<pin-timeout>],[<pin-protect>],[<blink-mode>]
pin-timeout0..65535
pin-protect0off
1on
blink-mode0half duty
1pulse
2off
mag svc​
Enable or disable magnet command interface
Syntax
mag svc <new-state>,<key>
new-state0off
1on
key649864801
data sample​
Force sensor polling
Syntax
data sample
data next-epoch​
Manually start next histogram epoch
Syntax
data next-epoch <type>
typeall
temp
humid
data poll-cfg​
Set data polling configuration
Syntax
data poll-cfg <profile-mask>,[<th-poll-int>],[<sync-period>],[<on-mag-switch>],[<on-activity-change>],[<on-impact>],[<on-free-fall>],[<on-ul-stale>],[<bat-poll-int>]
th-poll-int1..4294967295temperature and humidity
sync-period0no
1yes
on-mag-switch0no
1yes
on-activity-change0no
1yes
on-impact0no
1yes
on-free-fall0no
1yes
on-ul-stale0no
1yes
bat-poll-int1..4294967295battery voltage
data temp-histo-cfg​
Set temperature histogram configuration
Syntax
data temp-histo-cfg <profile-mask>,[<epoch-interval-s>],[<epoch-interval-cnt>],[<epoch-max-bin-cnt>],[<frame-on-new-epoch>],[<lim-divider>],[<bin-limit-0>],[<bin-limit-1>],[<bin-limit-2>],[<bin-limit-3>],[<bin-limit-4>],[<bin-limit-5>],[<bin-limit-6>],[<bin-limit-7>],[<bin-limit-8>]
epoch-interval-s0off
1..4294967295
epoch-interval-cnt0off
1..4294967295
epoch-max-bin-cnt0off
1..4294967295
frame-on-new-epoch0no
1yes
lim-divider1..4294967295
bin-limit-0-128..127°C
%f
bin-limit-1-128..127°C
%f
bin-limit-2-128..127°C
%f
bin-limit-3-128..127°C
%f
bin-limit-4-128..127°C
%f
bin-limit-5-128..127°C
%f
bin-limit-6-128..127°C
%f
bin-limit-7-128..127°C
%f
bin-limit-8-128..127°C
%f
data humid-histo-cfg​
Set humidity histogram configuration
Syntax
data humid-histo-cfg <profile-mask>,[<epoch-interval-s>],[<epoch-interval-cnt>],[<epoch-max-bin-cnt>],[<frame-on-new-epoch>],[<lim-divider>],[<bin-limit-0>],[<bin-limit-1>],[<bin-limit-2>],[<bin-limit-3>],[<bin-limit-4>],[<bin-limit-5>],[<bin-limit-6>],[<bin-limit-7>],[<bin-limit-8>]
1..4294967295
1..4294967295
1..4294967295
1yes
bin-limit-00..99RH%
%f
bin-limit-10..99RH%
%f
bin-limit-20..99RH%
%f
bin-limit-30..99RH%
%f
bin-limit-40..99RH%
%f
bin-limit-50..99RH%
%f
bin-limit-60..99RH%
%f
bin-limit-70..99RH%
%f
bin-limit-80..99RH%
%f
data ema-cfg​
Set exponential moving average (EMA) configuration
Syntax
data ema-cfg <profile-mask>,[<temp-cnt>],[<humid-cnt>],[<bat-cnt>],[<orient-cnt>],[<send-ema-temp>],[<send-ema-humid>],[<send-ema-bat>],[<send-ema-orient>]
temp-cnt1..32766a = 2 / (temp-cnt + 1)
humid-cnt1..32766a = 2 / (humid-cnt + 1)
bat-cnt1..32766a = 2 / (bat-cnt + 1)
orient-cnt1..32766a = 2 / (orient-cnt + 1)
send-ema-temp0no
1yes
send-ema-humid0no
1yes
send-ema-bat0no
1yes
send-ema-orient0no
1yes
data activity-cfg​
Set activity monitor configuration
Syntax
data activity-cfg <profile-mask>,[<mode>],[<level1-th>],[<level2-th>],[<en-led>]
mode0off
1single
2dual
level1-th1..63
level2-th1..63
en-led0off
1on
data acc-cfg​
Set accelerometer configuration
Syntax
data acc-cfg <profile-mask>,[<full-scale>],[<en-impact-x>],[<en-impact-y>],[<en-impact-z>],[<impact-th>],[<impact-dur>],[<en-ff>],[<ff-th>],[<ff-dur>],[<data-rate>],[<filter>],[<lp-mode>],[<low-noise>]
full-scale02G
14G
28G
316G
en-impact-x0off
1on
en-impact-y0off
1on
en-impact-z0off
1on
impact-th1..63impact-th * full-scale / 64
impact-dur0..3
en-ff0off
1on
ff-th0..7
ff-dur0..63
data-rate2Hz
13
25
50
100
200
filter2cutoff = data-rate/filter
4
10
20
lp-mode0..3
low-noise0no
1yes
data orient-cfg​
Set orientation sense configuration
Syntax
data orient-cfg <profile-mask>,[<enable>],[<max-1G-offset>],[<poll-interval-s>],[<ref-1-x>],[<ref-1-y>],[<ref-1-z>],[<ref-2-x>],[<ref-2-y>],[<ref-2-z>],[<ref-3-x>],[<ref-3-y>],[<ref-3-z>]
enable0off
1on
max-1G-offset1..20
poll-interval-s1..4294967295
ref-1-x-32768..32767
ref-1-y-32768..32767
ref-1-z-32768..32767
ref-2-x-32768..32767
ref-2-y-32768..32767
ref-2-z-32768..32767
ref-3-x-32768..32767
ref-3-y-32768..32767
ref-3-z-32768..32767
data event-cfg​
Set event storage configuration
Syntax
data event-cfg <profile-mask>,[<max-count>],[<send-th>],[<discard>],[<send-all>]
max-count0disabled
1..100
send-th0..65535if count >= send-th: send(device-events); 0 sends on every event
discard0oldest (if no free space)
1newest
send-all0off (send remaining events after device-events frame)
1on
data erase-events​
Erase <num-oldest> events if provided, otherwise all
Syntax
data erase-events [<num-oldest>]
num-oldest0..65535
data del-rule​
Delete <rule-num> rules if provided, otherwise delete all
Syntax
data del-rule [<rule-num>]
rule-num0..31
data set-rule​
Set data rule <rule-num>
Syntax
data set-rule [<rule-num>],<test-expr>,[<input-expr>],[<switch-profile>],[<make-event-0>],[<make-event-1>],[<make-event-2>],[<make-event-3>],[<send-frame-0>],[<send-frame-1>],[<send-frame-2>],[<send-frame-3>],[<clr-timer-mask>]
rule-num0..31
test-exprtest expression
input-exprinput expression
switch-profile0..5
make-event-0variable-type
make-event-1variable-type
make-event-2variable-type
make-event-3variable-type
send-frame-0frame-type
send-frame-1frame-type
send-frame-2frame-type
send-frame-3frame-type
clr-timer-mask0..15bit0=timer_1 bit1=timer_2 bit2=timer_3 bit3=timer_4
data timer​
Set user timer value
Syntax
data timer [<timer_1>],[<timer_2>],[<timer_3>],[<timer_4>]
timer_10..4294967295timer_1
timer_20..4294967295timer_2
timer_30..4294967295timer_3
timer_40..4294967295timer_4
data activity-cal​
Run activity monitor calibration and apply result to profiles
Syntax
data activity-cal <profile-mask>,<cal-level>,<cal-led>
cal-level1level-one
2level-two
cal-led0no
1yes
Data Frames​
Frames are packed into LoRaWAN uplinks as described in Uplink Messages. Configuration export frames 25-30 are described in Advanced Operations.
IDSize [B]NameData Fields
15current-statetemperature, humidity, mag_sw_cnt_u8, major_axis_orientation, activity_state, free_fall_evnt, impact_evnt, pending_evnt
2variabledevice-eventsevent-list
311temp-histogramtemp_histo_epoch, temp_histo_bin[10]
411humid-histogramhumid_histo_epoch, humid_histo_bin[10]
53device-orientationorientation_x, orientation_y, orientation_z
69full-activityactivity_state, activity_s, high_activity_s
78motion-eventsimpact_cnt, free_fall_cnt
88mag-switchmag_sw_cnt, mag_switch_ts
98impact-countimpact_cnt_u16, impact_cnt_x_u16, impact_cnt_y_u16, impact_cnt_z_u16
102last-temptemperature
112ema-temptemperature_ema
121last-humidhumidity
131ema-humidhumidity_ema
145activityactivity_state, total_activity_s
208dev-timeuptime_s, unix_time
212dev-healthbattery_mv
2211versionversion_pid, version_maj, version_min, version_rev, version_hash[6]
2311serial-numberserial_number[11]
2410cfg-statecfg_app_crc, cfg_net_crc, cfg_frames_crc, cfg_data_crc, cfg_rules_crc
25variablefull-cfgcontent-offset, content-final, content-len, content-binary-blob
26variableapp-cfgcontent-offset, content-final, content-len, content-binary-blob
27variablenet-cfgcontent-offset, content-final, content-len, content-binary-blob
28variableframe-cfgcontent-offset, content-final, content-len, content-binary-blob
29variabledata-cfgcontent-offset, content-final, content-len, content-binary-blob
30variablerules-cfgcontent-offset, content-final, content-len, content-binary-blob
User Variables​
IDSize [B]EncodingNameDescription
01u8profilecurrent data profile (0..5)
14u32profile_etmelapsed time [s] since last profile switch
24u32daytime_tmseconds since midnight 00:00 GMT or 0 if unknown
34u32unix_timecurrent UNIX time or device uptime if unknown
44u32net_frame_etmelapsed time since last network uplink
51boolnet_joined_flagnetwork join state
61u8net_classcurrently selected LoRaWAN class
71u8net_regioncurrently used LoRaWAN region code
82f8.8temperaturelast measured temperature
92f8.8temperature_emaEMA of measured temperature
101u8humiditylast measured humidity
111u8humidity_emaEMA of measured humidity
124u32mag_sw_cntmagnetic switch state change counter
134u32mag_sw_etmelapsed time since last magnetic switch change [s]
141boolmag_sw_flagcurrent state of magnetic switch
151activityactivity_statecurrent device activity state
164u32activity_slow activity (level 1) state counter [s]
174u32high_activity_shigh activity (level 2) state counter [s]
181orientmajor_axis_orientationcoarse device orientation
194u32impact_cnt_xX axis impact event counter
204u32impact_cnt_yY axis impact event counter
214u32impact_cnt_zZ axis impact event counter
224u32impact_cntimpact event counter
231boolimpact_evntimpact event flag, cleared by current-state, motion-events, impact-count frames
244u32impact_etmelapsed time since last impact event [s]
254u32free_fall_cntfree-fall event counter
261boolfree_fall_evntfree-fall event flag, cleared by current-state, motion-events frames
274u32free_fall_etmelapsed time since last free-fall event [s]
281u8angle_1angle between current orientation and user ref-1 vector, see data orient-cfg
291u8angle_2angle between current orientation and user ref-2 vector, see data orient-cfg
301u8angle_3angle between current orientation and user ref-3 vector, see data orient-cfg
311u8angle_emaangle between current orientation and EMA of device orientation
322u16battery_mvlast measured battery voltage [mV]
332u16battery_mv_emaEMA of battery voltage [mV]
342u16meta_rule_idspecial event action value: emits rule number as event code 100 + rule ID
354u32timer_1user timer elapsed time [s], reset by rule action or data timer
364u32timer_2user timer elapsed time [s], reset by rule action or data timer
374u32timer_3user timer elapsed time [s], reset by rule action or data timer
384u32timer_4user timer elapsed time [s], reset by rule action or data timer
394u32activity_state_etmtime since activity_state state change [s]
Frame Data Fields​
1u8mag_sw_cnt_u8LSB of internal magnet switch counter mag_sw_cnt
1/8boolpending_evntindicates device has stored events
0event-listvariable length list of: event time stamp, code and optional value
1u8temp_histo_epochtemperature histogram epoch number
10u8[10]temp_histo_bin[10]temperature histogram bin counter values
1u8humid_histo_epochhumidity histogram epoch number
10u8[10]humid_histo_bin[10]humidity histogram bin counter values
1i8orientation_xdevice orientation normal vector X axis
1i8orientation_ydevice orientation normal vector Y axis
1i8orientation_zdevice orientation normal vector Z axis
4u32mag_switch_tstime stamp of last time magnetic switch state change
2u16impact_cnt_u16impact event counter
2u16impact_cnt_x_u16X axis impact event counter
2u16impact_cnt_y_u16Y axis impact event counter
2u16impact_cnt_z_u16Z axis impact event counter
4u32total_activity_stotal activity state time (level 1 + level 2)
4u32uptime_sdevice FW uptime
2u16version_pidTG-LR82:0x0000, TG-LR92:0x0001
1u8version_majFW version major number
1u8version_minFW version minor number
1u8version_revFW version patch number
6u8[6]version_hash[6]FW version hash
11u8[11]serial_number[11]last 11 characters of device serial number
2u16cfg_app_crcapp & mag configuration group 16 bit checksum
2u16cfg_net_crcnet configuration group 16 bit checksum
2u16cfg_frames_crcframe configuration group 16 bit checksum
2u16cfg_data_crcdata configuration group 16 bit checksum
2u16cfg_rules_crcdata rule configuration 16 bit checksum
1/8boolcontent-finalflag indicating last chunk of content
15/8u15content-offsetbyte offset of content data
1u8content-lenlength of content
0content-binary-blobbinary data of content chunk
Example Configurations​
The examples below are downlink configuration scripts and assume the device is joined. Most examples use profile 5, which is empty by default, so existing profile settings remain unchanged.
Temperature and Humidity Reporting​
Configure profile 5 to report temperature and humidity every 15 minutes and battery voltage every 6 hours:
data poll-cfg 32,900,0,0,0,0,0,0,21600
frame set-cfg 32,900,0,0,current-state
frame set-cfg 32,21600,0,0,dev-health
app profile 5,1
The current-state frame carries temperature, humidity, and the remaining device state fields. Battery voltage is sent in the dev-health frame. Profile 5 is empty by default, so orientation and activity monitoring are not needed.
Door/Window Switch​
Use profile 5. The device sends current-state every 6 hours and reports immediately when the magnet switch changes state:
mag cfg 600,1,1
frame set-cfg 32,21600,0,0,current-state
data del-rule
data set-rule 0,mag_sw_etm < 2,,,,,,,current-state,mag-switch
app profile 5,1
mag cfg 600,1,1 enables PIN protection for normal magnet commands with a 600-second PIN-mode timeout and selects pulse LED blink mode. Magnet switch events continue to work normally; the PIN is supplied with the device.
The rule uses the elapsed time since the last magnet switch change, so either opening or closing triggers current-state and mag-switch. The latter contains the full counter and last-change timestamp. Bit 0 of mag_sw_cnt_u8 is the current switch state.
Threshold Alarm With Cooldown​
Use profile 5. Rule 0 is a five-minute cooldown gate. Rule 1 sends an alarm and resets the gate when temperature exceeds 30 C. The event contains both the temperature value and the rule ID:
data poll-cfg 32,30
data event-cfg 32,20,0,0,1
data timer 300
data del-rule
data set-rule 0,timer_1 >= 300
data set-rule 1,temperature > 30,&0,,temperature,meta_rule_id,,,current-state,,,,1
app profile 5,1
The timer is preset so the first alarm can trigger immediately. After each alarm, timer_1 is reset and the gate closes for five minutes. The expected uplink is current-state plus a device-events frame containing the temperature and data_rule 1.
Impact and Free Fall Profile Switch​
Use profile 5 and configure impact and free-fall detection for it. The app profile 5,1 command at the end activates profile 5 and makes it the default:
data acc-cfg 32,0,1,1,1,8,0,1,7,0,13,2,0,1
data del-rule
data set-rule 0,impact_etm < 20,,,meta_rule_id,,,,impact-count
data set-rule 1,free_fall_etm < 15,,,meta_rule_id,,,,motion-events
app profile 5,1
The expected uplink is impact-count or motion-events plus a device-events frame that identifies rule 0 or 1.
warning
Impact and free-fall detection cannot be used while Activity Monitor is enabled.
Orientation Change Event​
Use the last profile, profile 5, and orientation EMA; no reference vectors are needed. A change of at least 20 degrees relative to the orientation EMA generates an event:
data orient-cfg 32,1,2,3
data ema-cfg 32,6,6,6,20
data del-rule
data set-rule 0,angle_ema >= 20,,,angle_ema,meta_rule_id,,,device-orientation
app profile 5,1
The expected uplink is device-orientation plus a device-events frame with the measured angle_ema and data_rule 1. orient-cnt 20 sets the EMA time constant to approximately 30 seconds at the 3-second orientation polling interval. The example makes profile 5 the default.
Magnet-Only Setup​
Use case: prepare a TG-LR device for a door/window installation without any downlinks. The device starts in SHUTDOWN, so the settings are applied first and the device is activated last.
Magnet-only setup for profile 2
StepSequenceAction
14-3-9Disable the secondary band (2.4 GHz). The device will use the 1 GHz band only.
24-1-3Switch to profile 2 (Magnet Switch) and make it the default.
32Activate the device and start it in RUN mode. The device restarts and joins the network.
After the device joins, it uses profile 2 by default and sends current-state, mag-switch, and device-events every 60 minutes. A mag_sw_cnt event is generated when the magnet has been removed for at least 20 seconds. The secondary band remains disabled and profile 2 remains the default after reboot.
Known Issues​
Issue IDs are internal support references. The description and workaround are the user-facing contract.
IDFWDescription
LORA-2752.0.0No timeout changing credentials with secondary band disabled.
LORA-2762.0.0Incorrect credential change command timeout.
LORA-2792.0.0Activity calibration with orientation enabled causes fault.
LORA-2812.0.0 - 2.0.1New ADR configuration is not applied until device rejoins or restarts.
LORA-2822.0.0 - 2.0.1Only DR0 works as a configured fixed data rate.
LORA-275​
Description: If credential changes are initiated with secondary band disabled - device will not timeout join. Device will be stuck attempting join until either it succeeds or is restarted.
Workaround: If new credentials are invalid restart device physically with magnet switch command.
LORA-276​
Description: When lora cred is executed device will timeout join procedure on next join attempt based on total uptime instead of command execution time. If uptime is longer than confirm-timeout-s parameter device will timeout exactly after single failed join attempt.
Workaround: Issue device reset command app reset before attempting to change credentials. Or manually retry credential change multiple times.
LORA-279​
Description: If activity calibration is performed while orientation detection is enabled device may fault and restart.
Workaround: Disable orientation detection with data orient-cfg before performing activity calibration and re-enable after.
LORA-281​
Description: Changing the ADR setting with lora adr-cfg while the device is joined may not take effect until the device rejoins or restarts. Uplinks may continue using the previous ADR mode and data rate.
Workaround: Reset the device with app reset after changing the ADR setting.
LORA-282​
Description: When network ADR is disabled, only DR0 works as a configured fixed data rate. Configuring any other fixed data rate may not take effect.
Workaround: Enable network ADR with lora adr-cfg.
NoName
1TS001-1.0.4 LoRaWAN® L2 1.0.4 Specification
2Guidelines for 64-bit Global Identifier (EUI-64)
Advanced Operations​
The operations below are public but not required for normal end-device operation.
Manual Sampling​
data sample forces one temperature, humidity, battery, and orientation sampling cycle. Forced samples update the last measured values and event flags, but do not update EMA or histogram counters except for the first sample. Use it for diagnostics or to refresh data before a manual read.
Manual Histogram Epoch​
data next-epoch immediately starts a new temperature and humidity histogram epoch. Use data next-epoch temp or data next-epoch humid to reset only one histogram. The next histogram frame reports the new epoch number.
Configuration Export Frames​
Frames full-cfg, app-cfg, net-cfg, frame-cfg, data-cfg, and rules-cfg carry fragmented configuration data. They are intended for configuration backup and verification tooling, not for normal telemetry. The cfg-state frame is the normal automatic checksum response after a configuration downlink.
Optional Evaluation Stack​
telemetry_hub.zip contains optional Grafana and Influx docker services for device capability evaluation. It is not required for device operation. Follow the instructions included in the archive.
