Skip to main content
SXTsq Embedded LTE4 Global
SXTsq Embedded LTE4 Global (EG25-G&SXTsq)​
A cost-effective outdoor LTE device with an integrated 2×2 MIMO directional antenna, Cat4 LTE modem and RouterOS v7, designed for reliable remote connectivity. Available in EU (EC25-EU) and Global (EG25-G) versions with eSIM support, PoE in (12–28 V), and a rugged IP-rated SXTsq outdoor enclosure, it delivers stable LTE connectivity with only 5 W max power consumption. This is the global version with extra USA/non-EMEA LTE bands. AT&T, T-Mobile certified. See the SXTsq Embedded LTE4 Global product page for full specifications and brochures.
Safety Warnings​
  • Before you work on any MikroTik equipment, be aware of the hazards involved with electrical circuitry, and be familiar with standard practices for preventing accidents. The installer should be familiar with network structures, terms, and concepts.
  • Use only the power supply and accessories approved by the manufacturer, and which can be found in the original packaging of this product.
  • This equipment is to be installed by trained and qualified personnel, as per these installation instructions. The installer is responsible for making sure, that the Installation of the equipment is compliant with local and national electrical codes.
  • Do not attempt to disassemble, repair, or modify the device. If service is needed, contact MikroTik support.
  • This product is intended to be mounted outdoors on a pole. Read the mounting instructions carefully before beginning installation. Failure to use the correct hardware and configuration or to follow the correct procedures could result in a hazardous situation for people and damage to the system.
  • We cannot guarantee that no accidents or damage will occur due to the improper use of the device. Use this product with care and operate at your own risk!
  • The socket-outlet shall be installed near the equipment and shall be easily accessible.
  • In the case of device failure, disconnect it from power. The fastest way to do so is by unplugging the power adapter from the power outlet.
  • This is a Class A product. In a domestic environment, this product might cause radio interference in which case the user might be required to take adequate measures.
  • To avoid contamination of the environment, separate the device from household waste and dispose of it in a safe manner, for example, in designated areas. Become familiar with procedures for properly transporting the equipment to designated collection points in your area.
Quickstart​
  • Insert the Nano SIM card into the slot according to the indications;
  • Connect the device to the included power adapter;
  • Connect the device to the computer using Ethernet cable;
  • Configure your device using a web browser through WebFig or the WinBox tool at https://mt.lv/winbox. Multiple configuration methods are available to ensure accessibility;
  • Access WebFig by opening https://192.168.188.1, and for WinBox, download the tool, navigate to the Neighbors tab, and select the MAC address. The username is "admin" with no password (or, for some models, check user and wireless passwords on the sticker);
  • Enter the PIN code, if required by your mobile network operator;
  • Select the "Check for updates" button and update RouterOS to the latest version. A valid SIM card must be inserted or an eSIM must be set up, and an active Internet connection is required;
  • For a manual update of the device, visit mikrotik.com, select your model, and locate the required packages in the "Downloads" section;
  • Set up your router password.
MikroTik mobile app​
Use the MikroTik smartphone app to configure your router in the field, or to apply the most basic initial settings for your MikroTik home access point.
  • Scan QR code and choose your preferred OS.
  • Install and open application.
  • By default, the IP address and user name will be already entered.
  • Select Connect to establish a connection to your device through a wireless network.
  • Choose Quick setup and application will guide you through all basic configuration settings in a couple of easy steps.
  • An advanced menu is available to fully configure all necessary settings.
Configuration​
Configuration can be done using a web browser via WebFig, the WinBox tool https://mt.lv/winbox methods are available to ensure accessibility.
  • To access WebFig, open https://192.168.188.1 in your browser.
  • For WinBox, download the tool, go to the Neighbors tab, and select the MAC address. The default username is "admin", find the password on the device sticker. You should check for updates frequently to ensure your RouterOS software remains up to date for the best performance and stability. Select the "Check for updates" button in WinBox or WebFig to update to the latest version.
A valid SIM card must be inserted or an eSIM set up, along with an active Internet connection, for updates to work.
RouterOS provides a wide range of configuration options beyond what's described in this document. We suggest visiting https://mt.lv/help explore these features.
For recovery purposes, it is possible to boot the device for reinstallation, see section .
Mounting​
The IP rating scale for this device is IP67. When mounting outdoors, ensure that any cable openings are directed downwards. You should use POE injector and proper grounding. When using and installing this device pay attention to Maximum Permissible Exposure (MPE) safety distance with a minimum of 20 cm between the radiator and your body.
The device comes bundled with a metal mounting ring, which can be used on the mounting slot on the backside of the device.
  • Use a Phillips screwdriver to loosen the metal ring.
  • Slide one end of it through the most convenient of the three mounting slots.
  • Position the device on the pole where it will be mounted.
  • Slide the loose end of the mounting ring back to its closing latch and use the screwdriver to tighten it.
  • The included ring mount allows for mounting on 3-7 cm diameter poles. It's recommended to secure Ethernet cable to the pole using zip ties. With the distance from the device approximately 30 cm.
Specifications​
ParametersDescription
Product CodeEG25-G&SXTsq
ArchitectureARM 32bit
CPUCortex A7
CPU Core Count1
CPU Nominal Frequency800 MHz
RouterOS LicenseLevel 3
Operating SystemRouterOS v7
RAM256 MB
Storage256 MB NAND
MTBFApproximately 100'000 hours at 25°C
Operating Temperature-40°C to +70°C
Max Power Consumption5 W
PowerPoE-IN (Passive), 12–28 V
CoolingPassive
Ethernet1 × 10/100/1000 Mbps
SIM1 Modem (Nano SIM)
Mobile: 2GClass 33
2G Bands2 (1900 MHz), 3 (1800 MHz), 5 (850 MHz), 8 (900 MHz)
Mobile: 3GCategory R8 (DL 42.2 Mbps / UL 5.76 Mbps)
3G Bands1 (2100 MHz), 2 (1900 MHz), 4 (1700 MHz), 5 (850 MHz), 6 (850 MHz), 8 (900 MHz), 19 (800 MHz)
Mobile: LTECategory 4 (DL 150 Mbps / UL 50 Mbps)
MIMODL 2×2, UL 1×1
LTE FDD Bands1 (2100 MHz), 2 (1900 MHz), 3 (1800 MHz), 4 (1700 MHz), 5 (850 MHz), 7 (2600 MHz), 8 (900 MHz), 12 (700 MHz), 13 (700 MHz), 18 (800 MHz), 19 (800 MHz), 20 (800 MHz), 25 (1900 MHz), 26 (850 MHz), 28 (700 MHz)
LTE TDD Bands38 (2600 MHz), 39 (1900 MHz), 40 (2300 MHz), 41 (2500 MHz)
TAC01678800
MonitoringCPU temperature monitor
eSIMYes
CertificationsCE, EAC, ROHS
IP RatingIP67
Powering​
The device accepts 12–28 V DC ⎓ via PoE 802.3af/at. A power supply and PoE injector are included.
To connect power:
  • Connect the Ethernet cable from the device to the PoE+DATA port of the PoE injector.
  • Connect your LAN cable to the injector.
  • Connect the power supply and plug it into an outlet.
eSIM settings​
By default the device is configured to use the SIM slot. To use the on-board eSIM, switch the slot by using the following command: /interface/lte/settings/set sim-slot=esim
A single eSIM chip can store multiple eSIM profiles, the maximum profile count depends on the eSIM chip used.
See the LTE eSIM page for details.
Reset button​
The reset button has three functions:
  • Hold this button during boot time until the green LED light starts flashing, release the button to reset RouterOS configuration (total 5 seconds).
  • Keep holding for 5 more seconds, LED turns solid, release now to turn on CAP mode. The device will now look for a CAPsMAN server (total of 10 seconds).
  • Reinstall RouterOS using Netinstall. To reinstall RouterOS using the Netinstall utility, enter the device into BOOTP mode. There are two types of booters available: the regular booter and the backup booter.Regular booter - Power on the device, wait 1-2 seconds, then press and hold the Reset button. Wait until the "USR" LED is blinking, then turns solid "On". When the "USR" LED turns "Off", release the Reset button - the device will enter BOOTP mode.
  • Backup booter – Power off the device, press and hold the Reset button, then power it on. Wait until the "USR" LED is blinking, then turns solid "On". When the "USR" LED turns "Off", release the Reset button - the device will enter BOOTP mode using the backup booter. Regardless of the above option used, the system will load the backup RouterBOOT loader if the button is pressed before power is applied to the device. Useful for RouterBOOT debugging and recovery.
NetinstallWhen performing Netinstall, make sure to use the latest v7 version of both ROS files and the Netinstall software.
Grounding​
The device includes a grounding connection (marked ⏚) which you should connect to the grounding installation of the tower or building where the device will be used. This is to substantially reduce the risk of ESD and lightning damage.
Accessories​
Package includes the following accessories that come with the device:
  • EU/US Switching Power Supply 24V DC ⎓, 0.38 A, 9 W
  • POE Injector with shielded connector/Gigabit POE injector.
  • Hose Clamp SUS304 (Phillips type; clamping diameter range 30-70 mm).
Operating system support​
