Quick Guide - FTC21
This guide can be downloaded as a PDF file.
EN - English - Quick Guide
This device needs to be upgraded to SwOS v2.18 release to ensure compliance with local authority regulations! It is the end users' responsibility to follow local country regulations. All MikroTik devices must be professionally installed.
This Quick Guide covers the model: FTC21.
This is a network device. You can find the product model name on the case label (ID). |
First steps:
- Unscrew the central screw and remove the plastic cover;
- Locate the Ethernet and SFP ports;
- Set your IP for PC to 192.168.88.2/24;
- Connect the device and power it on: Using PoE-in (802.3af/at 24-57 V): Connect the device to the included PoE injector with an Ethernet cable to the data+power end;
- Connect the data end of the PoE injector to the computer;
- Connect the power adapter to the PoE injector;
- Using DC Jack (24-57 V): Use the included power adapter to power up the device with the DC jack;
- Open https://192.168.88.1 in a web browser. Use admin as the username (no password by default);
- Download the latest SwOS Lite from mikrotik.com/download. Upload it in the Upgrade tab, then let the device reboot;
- Set a password to secure the device;
- If needed, the device can be mounted on a pole or on a wall;
- The screws with dowels are included in the package.
Safety Information:
- Before you work on any MikroTik equipment, be aware of the hazards involved with electrical circuitry, and be familiar with standard practices for preventing accidents. The installer should be familiar with network structures, terms, and concepts.
- Use only accessories approved by the manufacturer, and which can be found in the original packaging of this product.
- This equipment is to be installed by trained and qualified personnel, as per these installation instructions. The installer is responsible for making sure, that the installation of the equipment is compliant with local and national electrical codes. Do not attempt to disassemble, repair, or modify the device.
- This product can be used both indoors and outdoors. Please read the mounting instructions carefully before beginning installation. Failure to use the correct hardware and configuration or to follow the correct procedures could result in a hazardous situation for people and damage to the system.
- We cannot guarantee that no accidents or damage will occur due to the improper use of the device. Please use this product with care and operate at your own risk!
- We highly recommend to use AC/DC power supply only for indoor use cases.
- The socket-outlet shall be installed near the equipment and shall be easily accessible.
- In the case of device failure, please disconnect it from power. The fastest way to do so is by unplugging the power adapter from the power outlet. Manufacturer: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
BG - Български. Бързо ръководство
Това устройство трябва да бъде надстроено до версията на SwOS v2.18, за да се осигури съответствие с разпоредбите на местните власти! Отговорността на крайните потребители е да спазват местните държавни разпоредби. Всички устройства MikroTik трябва да бъдат инсталирани професионално.
Този документ обхваща модела: FTC21.
Това е мрежово устройство. Можете да намерите името на модела на продукта на етикета на регистъра (ID). |
Първи стъпки:
- Развийте централния винт и премахнете пластмасовия капак;
- Намерете Ethernet и SFP портовете;
- Настройте вашия IP на компютъра на 192.168.88.2/24;
- Свържете устройството и го включете: Използвайки PoE-in (802.3af/at 24-57 V): Свържете устройството към включения PoE инжектор с Ethernet кабел към порта за данни и захранване;
- Свържете порта за данни на PoE инжектора към компютъра;
- Свържете захранващия адаптер към PoE инжектора;
- Използвайки DC Jack (24-57 V): Използвайте включения захранващ адаптер, за да захраните устройството чрез DC вход;
- Отворете https://192.168.88.1 в уеб браузър. Използвайте admin като потребителско име (без парола по подразбиране);
- Изтеглете последната версия на SwOS Lite от mikrotik.com/download. Качете я в раздела Upgrade и оставете устройството да се рестартира;
- Задайте парола, за да защитите устройството;
- Ако е необходимо, устройството може да се монтира на стена или стълб;
- Винтовете с дюбели са включени в комплекта.
Информация за безопасност:
- Преди да работите с което и да е оборудване на MikroTik, имайте предвид опасностите, свързани с електрическата верига, и се запознайте със стандартните практики за предотвратяване на злополуки. Инсталаторът трябва да е запознат с мрежовите структури, термини и понятия.
- Използвайте само захранването и аксесоарите, одобрени от производителя, и които можете да намерите в оригиналната опаковка на този продукт.
- Това оборудване трябва да се монтира от обучен и квалифициран персонал съгласно тези инструкции за монтаж. Инсталаторът отговаря за това, че инсталирането на оборудването е в съответствие с местните и националните електрически кодове. Не се опитвайте да разглобявате, ремонтирате или модифицирате устройството.
- Този продукт може да се използва както на закрито, така и на открито. Моля, прочетете внимателно инструкциите за монтаж, преди да започнете инсталацията. Неизползването на правилния хардуер и конфигурация или спазването на правилните процедури може да доведе до опасна ситуация за хората и повреда на системата.
- Силно препоръчваме да използвате AC/DC захранване само за случаи на употреба на закрито.
- Контактът трябва да бъде монтиран близо до оборудването и да бъде лесно достъпен.
- Не можем да гарантираме, че няма злополуки или повреди поради неправилна употреба на устройството. Моля, използвайте внимателно този продукт и работете на свой риск!
- В случай на повреда на устройството, моля, изключете го от захранването. Най-бързият начин да направите това е чрез изключване на захранващия адаптер от контакта. Производител: Mikrotikls SIA, Unijas iela 2, Рига, Латвия, LV1039.
CS - Česko. Rychlý průvodce
Toto zařízení je třeba upgradovat na verzi SwOS v2.18, aby bylo zajištěno dodržování předpisů místních úřadů! Je odpovědností koncových uživatelů dodržovat místní předpisy. Všechna zařízení MikroTik musí být profesionálně nainstalována.
Tento Stručný průvodce se týká modelu: FTC21.
Toto je síťové zařízení. Název modelu produktu najdete na štítku případu (ID). |
První kroky:
- Odšroubujte centrální šroub a sejměte plastový kryt;
- Najděte Ethernetové a SFP porty;
- Nastavte IP vašeho počítače na 192.168.88.2/24;
- Připojte zařízení a zapněte jej: Použití PoE-in (802.3af/at 24-57 V): Připojte zařízení k přiloženému PoE injektoru pomocí Ethernetového kabelu na data+napájení;
- Připojte datový konec PoE injektoru k počítači;
- Připojte napájecí adaptér k PoE injektoru;
- Použití DC Jack (24-57 V): Použijte přiložený napájecí adaptér k napájení zařízení přes DC jack;
- Otevřete https://192.168.88.1 v prohlížeči. Použijte admin jako uživatelské jméno (bez výchozího hesla);
- Stáhněte nejnovější verzi SwOS Lite z mikrotik.com/download. Nahrajte ji na záložku Upgrade a nechte zařízení restartovat;
- Nastavte heslo pro zabezpečení zařízení;
- Pokud je potřeba, zařízení může být namontováno na sloup nebo na stěnu;
- Šrouby s hmoždinkami jsou součástí balení.
Bezpečná informace:
- Než začnete pracovat na jakémkoli zařízení MikroTik, uvědomte si rizika spojená s elektrickými obvody a seznamte se se standardními postupy pro prevenci nehod. Instalátor by měl být obeznámen se síťovými strukturami, termíny a koncepty.
- Používejte pouze napájecí zdroj a příslušenství schválené výrobcem, které najdete v originálním balení tohoto produktu.
- Toto zařízení musí instalovat vyškolený a kvalifikovaný personál podle těchto pokynů k instalaci. Instalátor odpovídá za to, že instalace zařízení je v souladu s místními a národními elektrickými předpisy. Nepokoušejte se zařízení rozebírat, opravovat ani upravovat.
- Tento produkt lze použít uvnitř i venku. Před zahájením instalace si prosím pečlivě přečtěte montážní pokyny. Pokud nebudete používat správný hardware a konfiguraci nebo nedodržíte správné postupy, může to mít za následek nebezpečnou situaci pro lidi a poškození systému.
- Důrazně doporučujeme používat AC/DC napájecí zdroj pouze pro vnitřní použití.
- Zásuvka musí být instalována v blízkosti zařízení a musí být snadno dostupná.
- Nemůžeme zaručit, že v důsledku nesprávného používání zařízení nedojde k nehodám nebo poškození. Tento produkt používejte opatrně a používejte jej na vlastní nebezpečí!
- V případě poruchy zařízení jej prosím odpojte od napájení. Nejrychlejším způsobem je odpojení napájecího adaptéru ze zásuvky. Výrobce: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
DA - Dansk. Hurtig guide
Denne enhed skal opgraderes til SwOS v2.18-udgivelsen for at sikre overholdelse af lokale myndigheders regler! Det er slutbrugerens ansvar at følge lokale landes regler. Alle MikroTik-enheder skal være professionelt installeret.
Dette dokument dækker modellen: FTC21.
Dette er netværksenhed. Du kan finde produktmodelnavnet på sagetiketten (ID). |
Første trin:
- Skru den centrale skrue af, og fjern plastikdækslet;
- Find Ethernet- og SFP-porte;
- Indstil din pc’s IP-adresse til 192.168.88.2/24;
- Tilslut enheden og tænd for den: Ved hjælp af PoE-in (802.3af/at 24-57 V): Tilslut enheden til den medfølgende PoE-injektor med et Ethernet-kabel til data+strøm;
- Tilslut dataenden af PoE-injektoren til computeren;
- Tilslut strømforsyningen til PoE-injektoren;
- Ved hjælp af DC Jack (24-57 V): Brug den medfølgende strømforsyning til at tænde enheden via DC jack;
- Åbn https://192.168.88.1 i en webbrowser. Brug admin som brugernavn (ingen adgangskode som standard);
- Download den nyeste version af SwOS Lite fra mikrotik.com/download. Upload den på fanen Upgrade, og lad enheden genstarte;
- Indstil en adgangskode for at sikre enheden;
- Hvis nødvendigt kan enheden monteres på en stolpe eller en væg;
- Skruer med dyvler er inkluderet i pakken.
Sikkerhedsoplysninger:
- Inden du arbejder med MikroTik-udstyr, skal du være opmærksom på farerne i forbindelse med elektriske kredsløb og kende almindelig praksis til forebyggelse af ulykker. Installationsprogrammet skal være bekendt med netværksstrukturer, vilkår og koncepter.
- Brug kun strømforsyningen og det tilbehør, der er godkendt af producenten, og som findes i den originale emballage til dette produkt.
- Dette udstyr skal installeres af uddannet og kvalificeret personale i henhold til disse installationsinstruktioner. Installatøren er ansvarlig for at sikre, at installationen af udstyret er i overensstemmelse med lokale og nationale elektriske koder. Forsøg ikke at adskille, reparere eller ændre enheden.
- Dette produkt kan bruges både indendørs og udendørs. Læs monteringsvejledningen grundigt inden installationen påbegyndes. Manglende brug af den korrekte hardware og konfiguration eller de korrekte procedurer kan resultere i en farlig situation for mennesker og skader på systemet.
- Vi anbefaler stærkt kun at bruge AC/DC strømforsyning til indendørs brug.
- Stikkontakten skal installeres i nærheden af udstyret og skal være let tilgængelig.
- Vi kan ikke garantere, at der ikke vil ske ulykker eller skader på grund af forkert brug af enheden. Brug dette produkt med omhu og betjen det på egen risiko!
- I tilfælde af fejl på enheden skal du frakoble det fra strømmen. Den hurtigste måde at gøre det er ved at tage stikket ud af stikkontakten. Producent: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
DE - Deutsche. Kurzanleitung
Dieses Gerät muss auf die Version SwOS v2.18 aktualisiert werden, um die Einhaltung der örtlichen behördlichen Vorschriften sicherzustellen! Es liegt in der Verantwortung des Endbenutzers, die örtlichen Vorschriften zu befolgen. Alle MikroTik-Geräte müssen professionell installiert werden.
Diese Kurzanleitung behandelt das Modell: FTC21.
Dies ist das Netzwerkgerät. Den Produktmodellnamen finden Sie auf dem Gehäuseaufkleber (ID). |
Erste Schritte:
- Entfernen Sie die zentrale Schraube und den Kunststoffdeckel;
- Finden Sie die Ethernet- und SFP-Ports;
- Stellen Sie die IP Ihres PCs auf 192.168.88.2/24 ein;
- Schließen Sie das Gerät an und schalten Sie es ein: Verwenden Sie PoE-in (802.3af/at 24-57 V): Verbinden Sie das Gerät mit dem mitgelieferten PoE-Injektor über ein Ethernet-Kabel für Daten+Strom;
- Verbinden Sie das Datenende des PoE-Injektors mit dem Computer;
- Schließen Sie den Netzadapter an den PoE-Injektor an;
- Verwenden Sie DC Jack (24-57 V): Verwenden Sie den mitgelieferten Netzadapter, um das Gerät über den DC-Eingang mit Strom zu versorgen;
- Öffnen Sie https://192.168.88.1 in einem Webbrowser. Verwenden Sie admin als Benutzernamen (kein Standardpasswort);
- Laden Sie die neueste Version von SwOS Lite von mikrotik.com/download herunter. Laden Sie diese auf die Upgrade-Registerkarte hoch und lassen Sie das Gerät neu starten;
- Legen Sie ein Passwort fest, um das Gerät zu sichern;
- Wenn nötig, kann das Gerät an einem Mast oder an der Wand montiert werden;
- Schrauben und Dübel sind im Lieferumfang enthalten.
Sicherheitsinformation:
- Bevor Sie an MikroTik-Geräten arbeiten, sollten Sie sich der Gefahren bewusst sein, die mit elektrischen Schaltkreisen verbunden sind, und sich mit den Standardverfahren zur Verhinderung von Unfällen vertraut machen. Das Installationsprogramm sollte mit Netzwerkstrukturen, Begriffen und Konzepten vertraut sein.
- Verwenden Sie nur das vom Hersteller zugelassene Netzteil und Zubehör, das in der Originalverpackung dieses Produkts enthalten ist.
- Dieses Gerät muss von geschultem und qualifiziertem Personal gemäß diesen Installationsanweisungen installiert werden. Der Installateur ist dafür verantwortlich, dass die Installation des Geräts den örtlichen und nationalen elektrischen Vorschriften entspricht. Versuchen Sie nicht, das Gerät zu zerlegen, zu reparieren oder zu modifizieren.
- Dieses Produkt kann sowohl im Innen- als auch im Außenbereich verwendet werden. Bitte lesen Sie die Montageanleitung sorgfältig durch, bevor Sie mit der Installation beginnen. Wenn Sie die richtige Hardware und Konfiguration nicht verwenden oder die korrekten Verfahren nicht befolgen, kann dies zu einer Gefahrensituation für Personen und Schäden am System führen.
- Wir empfehlen dringend, die AC/DC-Stromversorgung nur für Anwendungsfälle in Innenräumen zu verwenden.
- Die Steckdose muss in der Nähe des Geräts installiert und leicht zugänglich sein.
- Wir können nicht garantieren, dass durch unsachgemäße Verwendung des Geräts keine Unfälle oder Schäden auftreten. Bitte verwenden Sie dieses Produkt mit Vorsicht und arbeiten Sie auf eigenes Risiko!
- Trennen Sie das Gerät bei einem Stromausfall vom Stromnetz. Der schnellste Weg, dies zu tun, besteht darin, das Netzteil aus der Steckdose zu ziehen. Hersteller: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
EL - Ελληνικά. Γρήγορος οδηγός
Αυτή η συσκευή πρέπει να αναβαθμιστεί στην έκδοση SwOS v2.18 για να διασφαλιστεί η συμμόρφωση με τους κανονισμούς των τοπικών αρχών! Είναι ευθύνη των τελικών χρηστών να ακολουθούν τους τοπικούς κανονισμούς των χωρών. Όλες οι συσκευές MikroTik πρέπει να εγκατασταθούν επαγγελματικά.
Αυτός ο γρήγορος οδηγός καλύπτει το μοντέλο: FTC21.
Αυτή είναι η συσκευή δικτύου. Μπορείτε να βρείτε το όνομα του μοντέλου προϊόντος στην ετικέτα της θήκης (ID). |
Πρώτα βήματα:
- Ξεβιδώστε την κεντρική βίδα και αφαιρέστε το πλαστικό κάλυμμα;
- Βρείτε τις θύρες Ethernet και SFP;
- Ρυθμίστε την IP του υπολογιστή σας σε 192.168.88.2/24;
- Συνδέστε τη συσκευή και ενεργοποιήστε την: Χρησιμοποιώντας PoE-in (802.3af/at 24-57 V): Συνδέστε τη συσκευή με τον παρεχόμενο PoE injector χρησιμοποιώντας καλώδιο Ethernet για δεδομένα+ρεύμα;
- Συνδέστε το άκρο δεδομένων του PoE injector στον υπολογιστή;
- Συνδέστε τον τροφοδοτικό στον PoE injector;
- Χρησιμοποιώντας DC Jack (24-57 V): Χρησιμοποιήστε τον παρεχόμενο τροφοδοτικό για να ενεργοποιήσετε τη συσκευή μέσω DC jack;
- Ανοίξτε το https://192.168.88.1 σε ένα πρόγραμμα περιήγησης. Χρησιμοποιήστε admin ως όνομα χρήστη (χωρίς προεπιλεγμένο κωδικό πρόσβασης);
- Κατεβάστε την τελευταία έκδοση του SwOS Lite από το mikrotik.com/download. Ανεβάστε το στην καρτέλα Αναβάθμιση και αφήστε τη συσκευή να επανεκκινήσει;
- Ορίστε έναν κωδικό πρόσβασης για την ασφάλεια της συσκευής;
- Εάν χρειάζεται, η συσκευή μπορεί να τοποθετηθεί σε ιστό ή στον τοίχο;
- Οι βίδες με ούπα περιλαμβάνονται στη συσκευασία.
Οδηγίες ασφαλείας:
- Πριν να εργαστείτε σε οποιοδήποτε εξοπλισμό MikroTik, να είστε ενήμεροι για τους κινδύνους που σχετίζονται με τα ηλεκτρικά κυκλώματα και να είστε εξοικειωμένοι με τις συνήθεις πρακτικές για την πρόληψη ατυχημάτων. Ο εγκαταστάτης πρέπει να είναι εξοικειωμένος με τις δομές, τους όρους και τις έννοιες του δικτύου.
- Χρησιμοποιήστε μόνο την τροφοδοσία ρεύματος και τα εξαρτήματα που έχει εγκριθεί από τον κατασκευαστή και τα οποία μπορείτε να βρείτε στην αρχική συσκευασία αυτού του προϊόντος.
- Αυτός ο εξοπλισμός πρέπει να εγκατασταθεί από εκπαιδευμένο και ειδικευμένο προσωπικό, σύμφωνα με αυτές τις οδηγίες εγκατάστασης. Ο εγκαταστάτης είναι υπεύθυνος για τη διασφάλιση της συμμόρφωσης της εγκατάστασης του εξοπλισμού με τους τοπικούς και εθνικούς ηλεκτρικούς κώδικες. Μην επιχειρήσετε να αποσυναρμολογήσετε, να επιδιορθώσετε ή να τροποποιήσετε τη συσκευή.
- Αυτό το προϊόν μπορεί να χρησιμοποιηθεί τόσο σε εσωτερικούς όσο και σε εξωτερικούς χώρους. Διαβάστε προσεκτικά τις οδηγίες τοποθέτησης πριν ξεκινήσετε την εγκατάσταση. Η μη χρήση του σωστού υλικού και της διαμόρφωσης ή η τήρηση των σωστών διαδικασιών μπορεί να οδηγήσει σε επικίνδυνη κατάσταση για τους ανθρώπους και ζημιά στο σύστημα.
- Συνιστούμε ανεπιφύλακτα να χρησιμοποιείτε τροφοδοτικό AC/DC μόνο για θήκες εσωτερικής χρήσης.
- Η πρίζα πρέπει να είναι εγκατεστημένη κοντά στον εξοπλισμό και να είναι εύκολα προσβάσιμη.
- Δεν μπορούμε να εγγυηθούμε ότι δεν θα προκύψουν ατυχήματα ή ζημιές εξαιτίας της ακατάλληλης χρήσης της συσκευής. Χρησιμοποιείτε αυτό το προϊόν με προσοχή και λειτουργείτε με δική σας ευθύνη!
- Σε περίπτωση βλάβης της συσκευής, αποσυνδέστε την από την τροφοδοσία. Ο ταχύτερος τρόπος είναι να αποσυνδέσετε το τροφοδοτικό από την πρίζα. Κατασκευαστής: Mikrotikls SIA, Unijas iela 2, Ρίγα, Λετονία, LV1039.
ES - Español. Guía rápida
¡Este dispositivo debe actualizarse a la versión SwOS v2.18 para garantizar el cumplimiento de las regulaciones de las autoridades locales! Es responsabilidad del usuario final seguir las regulaciones locales del país. Todos los dispositivos MikroTik deben instalarse profesionalmente.
Esta guía rápida cubre el modelo: FTC21.
Este es un dispositivo de red. Puede encontrar el nombre del modelo del producto en la etiqueta del caso (ID). |
Primeros pasos:
- Desatornille el tornillo central y retire la cubierta de plástico;
- Ubique los puertos Ethernet y SFP;
- Configure la IP de su PC a 192.168.88.2/24;
- Conecte el dispositivo y enciéndalo: Usando PoE-in (802.3af/at 24-57 V): Conecte el dispositivo al inyector PoE incluido utilizando un cable Ethernet para datos+energía;
- Conecte el extremo de datos del inyector PoE a la computadora;
- Conecte el adaptador de corriente al inyector PoE;
- Usando un conector DC Jack (24-57 V): Use el adaptador de corriente incluido para alimentar el dispositivo a través del DC jack;
- Abra https://192.168.88.1 en un navegador web. Use admin como nombre de usuario (sin contraseña por defecto);
- Descargue la última versión de SwOS Lite desde mikrotik.com/download. Cárguela en la pestaña Upgrade y permita que el dispositivo se reinicie;
- Configure una contraseña para proteger el dispositivo;
- Si es necesario, el dispositivo puede montarse en un poste o en la pared;
- Los tornillos con tacos están incluidos en el paquete.
Información de seguridad:
- Antes de trabajar en cualquier equipo MikroTik, tenga en cuenta los riesgos relacionados con los circuitos eléctricos y familiarícese con las prácticas estándar para prevenir accidentes. El instalador debe estar familiarizado con las estructuras de red, los términos y los conceptos.
- Utilice solo la fuente de alimentación y los accesorios aprobados por el fabricante, y que se pueden encontrar en el embalaje original de este producto.
- Este equipo debe ser instalado por personal capacitado y calificado, según estas instrucciones de instalación. El instalador es responsable de asegurarse de que la instalación del equipo cumpla con los códigos eléctricos locales y nacionales. No intente desmontar, reparar o modificar el dispositivo.
- Este producto se puede utilizar tanto en interiores como en exteriores. Lea atentamente las instrucciones de montaje antes de comenzar la instalación. No utilizar el hardware y la configuración correctos o no seguir los procedimientos correctos podría resultar en una situación peligrosa para las personas y daños en el sistema.
- Recomendamos encarecidamente utilizar una fuente de alimentación de CA/CC solo para casos de uso en interiores.
- El tomacorriente se instalará cerca del equipo y será de fácil acceso.
- No podemos garantizar que no ocurran accidentes o daños debido al uso incorrecto del dispositivo. ¡Utilice este producto con cuidado y opere bajo su propio riesgo!
- En caso de falla del dispositivo, desconéctelo de la alimentación. La forma más rápida de hacerlo es desconectando el adaptador de alimentación de la toma de corriente. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
Información México:
La operacion de este equipo esta sujeta a las siguientes dos condiciones:
- Es posible que este equipo o dispositivo no cause interferencia perjudicial y.
- Este equipo debe aceptar cualquier interferencia, incluyendo la que pueda causar su operacion no deseada. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, LV-1039, Latvia.
País De Origen: Letonia; Lituania; China (Republica Popular); Estados Unidos De America; Mexico.
Por favor contacte a su distribuidor local para preguntas regionales específicas. La lista de importadores se puede encontrar en nuestra página de inicio – https://mikrotik.com/buy/latinamerica/mexico.
ET - Eestlane. Kiirjuhend
See seade tuleb üle viia versioonile SwOS v2.18, et tagada vastavus kohalike omavalitsuste eeskirjadele! Lõppkasutajate kohustus on järgida kohaliku riigi seadusi. Kõik MikroTik seadmed peavad olema professionaalselt installitud.
See kiirjuhend hõlmab mudelit: FTC21.
See on võrguseade. Toote mudeli nime leiate kohvri sildilt (ID). |
Esimesed sammud:
- Keerake lahti keskne kruvi ja eemaldage plastikkate;
- Leidke Etherneti ja SFP-pordid;
- Seadke oma arvuti IP-aadressiks 192.168.88.2/24;
- Ühendage seade ja lülitage see sisse: Kasutades PoE-in (802.3af/at 24-57 V): Ühendage seade kaasasoleva PoE-injektoriga, kasutades Etherneti kaablit andmete+toite jaoks;
- Ühendage PoE-injektori andmete ots arvutiga;
- Ühendage toiteadapter PoE-injektoriga;
- Kasutades DC Jacki (24-57 V): Kasutage kaasasolevat toiteadapterit, et toita seade läbi DC jacki;
- Avage veebibrauseris https://192.168.88.1. Kasutage kasutajanimeks admin (parool puudub vaikimisi);
- Laadige alla uusim SwOS Lite versioon mikrotik.com/download. Laadige see üles Upgrade vahekaardile ja laske seadmel taaskäivitada;
- Määrake seadme turvamiseks parool;
- Vajadusel saab seadme paigaldada postile või seinale;
- Kruvid koos tüüblitega on pakendis kaasas.
Ohutusteave:
- Enne kui töötate mõne MikroTiku seadmega, tutvuge elektriskeemidega kaasnevate ohtudega ja tutvuge õnnetuste vältimise tavapraktikaga. Installer peaks tundma võrgustruktuure, termineid ja kontseptsioone.
- Kasutage ainult tootja poolt heaks kiidetud toiteallikat ja tarvikuid, mis on selle toote originaalpakendis.
- Need seadmed peavad paigaldama väljaõppinud ja kvalifitseeritud töötajad vastavalt käesolevatele paigaldusjuhistele. Paigaldaja vastutab selle eest, et seadmed paigaldataks vastavalt kohalikele ja riiklikele elektriseadustele. Ärge üritage seadet lahti võtta, remontida ega modifitseerida.
- Seda toodet saab kasutada nii toas kui ka väljas. Enne paigaldamise alustamist lugege hoolikalt paigaldusjuhiseid. Õige riistvara ja konfiguratsiooni kasutamata jätmine või õigete protseduuride järgimata jätmine võib põhjustada inimeste ohtlikku olukorda ja süsteemi kahjustada.
- Soovitame tungivalt kasutada AC/DC toiteallikat ainult siseruumides kasutamiseks.
- Pistikupesa paigaldatakse seadme lähedusse ja see peab olema kergesti ligipääsetav.
- Me ei saa garanteerida, et seadme ebaõige kasutamise tõttu ei juhtu õnnetusi ega kahjustusi. Kasutage seda toodet ettevaatlikult ja tegutsege omal vastutusel!
- Seadme rikke korral eraldage see vooluvõrgust. Kiireim viis selleks on toiteadapteri pistikupesast lahti ühendamine. Tootja: Mikrotikls SIA, Unijas iela 2, Riia, Läti, LV1039.
FI - Suomalainen. Pikaopas
Tämä laite on päivitettävä SwOS v2.18 -julkaisuun, jotta varmistetaan paikallisten viranomaisten määräysten mukainen! Loppukäyttäjien vastuulla on noudattaa paikallisia maalakeja. Kaikki MikroTik-laitteet on asennettava ammattimaisesti.
Tämä pikaopas kattaa mallin: FTC21.
Tämä on verkkolaite. Tuotemallin nimi löytyy kotelon etiketistä (ID). |
Ensiaskeleet:
- Irrota keskimmäinen ruuvi ja poista muovikansi;
- Löydä Ethernet- ja SFP-portit;
- Aseta tietokoneesi IP-osoitteeksi 192.168.88.2/24;
- Yhdistä laite ja käynnistä se: Käyttämällä PoE-in (802.3af/at 24-57 V): Yhdistä laite mukana toimitettuun PoE-injektoriin Ethernet-kaapelilla data+virta;
- Yhdistä PoE-injektorin data-osa tietokoneeseen;
- Kytke virtalähde PoE-injektoriin;
- Käyttämällä DC Jack (24-57 V): Käytä mukana toimitettua virtalähdettä laitteen virran kytkemiseksi DC jackin kautta;
- Avaa https://192.168.88.1 verkkoselaimessa. Käytä käyttäjänimenä admin (ei oletussalasanaa);
- Lataa uusin SwOS Lite -versio osoitteesta mikrotik.com/download. Lataa se Päivitys-välilehdelle ja anna laitteen käynnistyä uudelleen;
- Aseta salasana laitteen suojaamiseksi;
- Tarvittaessa laite voidaan kiinnittää pylvääseen tai seinään;
- Pakettiin sisältyy ruuvit ja tulpat.
Turvallisuustieto:
- Ennen kuin työskentelet MikroTik-laitteiden kanssa, ole tietoinen sähköpiiriin liittyvistä vaaroista ja perehdy vakiomuotoisiin käytäntöihin onnettomuuksien estämiseksi. Asentajan tulee tuntea verkkorakenteet, termit ja käsitteet.
- Käytä vain valmistajan hyväksymää virtalähdettä ja lisävarusteita, jotka löytyvät tämän tuotteen alkuperäispakkauksesta.
- Tämän laitteen saa asentaa koulutettu ja pätevä henkilöstö näiden asennusohjeiden mukaisesti. Asentajan on varmistettava, että laitteen asennus on paikallisten ja kansallisten sähkömääräysten mukainen. Älä yritä purkaa, korjata tai muokata laitetta.
- Tätä tuotetta voidaan käyttää sekä sisällä että ulkona. Lue asennusohjeet huolellisesti ennen asennuksen aloittamista. Oikean laitteiston ja kokoonpanon käyttämättä jättäminen tai oikeiden menettelytapojen noudattamatta jättäminen voi aiheuttaa ihmisille vaarallisen tilanteen ja vahingoittaa järjestelmää.
- Suosittelemme käyttämään AC/DC-virtalähdettä vain sisäkäyttöön.
- Pistorasia on asennettava laitteen lähelle ja siihen on oltava helposti saatavilla.
- Emme voi taata, että laitteen väärinkäytöstä ei aiheudu onnettomuuksia tai vaurioita. Käytä tätä tuotetta huolellisesti ja käytä omalla vastuulla!
- Irrota laite sähkövirrasta, jos laite vioittuu. Nopein tapa tehdä tämä on irrottaa virtalähde pistorasiasta. Valmistaja: Mikrotikls SIA, Unijas iela 2, Riika, Latvia, LV1039.
FR - Français. Guide rapide
Cet appareil doit être mis à niveau vers la version SwOS v2.18 pour garantir la conformité avec les réglementations des autorités locales! Il est de la responsabilité des utilisateurs finaux de suivre les réglementations locales du pays. Tous les appareils MikroTik doivent être installés par des professionnels.
Ce document couvre le modèle: FTC21.
Ceci est un périphérique réseau. Vous pouvez trouver le nom du modèle du produit sur l'étiquette du boîtier (ID). |
Premiers pas:
- Dévissez la vis centrale et retirez le couvercle en plastique;
- Localisez les ports Ethernet et SFP;
- Configurez l'IP de votre PC à 192.168.88.2/24;
- Connectez l'appareil et allumez-le: En utilisant PoE-in (802.3af/at 24-57 V): Connectez l'appareil à l'injecteur PoE fourni à l'aide d'un câble Ethernet pour les données et l'alimentation;
- Connectez l'extrémité des données de l'injecteur PoE à l'ordinateur;
- Branchez l'adaptateur secteur à l'injecteur PoE;
- En utilisant un connecteur DC Jack (24-57 V): Utilisez l'adaptateur secteur fourni pour alimenter l'appareil via le connecteur DC jack;
- Ouvrez https://192.168.88.1 dans votre navigateur. Utilisez admin comme nom d'utilisateur (pas de mot de passe par défaut);
- Téléchargez la dernière version de SwOS Lite depuis mikrotik.com/download. Téléchargez-la dans l'onglet Upgrade et laissez l'appareil redémarrer;
- Définissez un mot de passe pour sécuriser l'appareil;
- Si nécessaire, l'appareil peut être monté sur un poteau ou au mur;
- Les vis avec chevilles sont incluses dans l'emballage.
Information sur la sécurité:
- Avant de travailler sur un équipement MikroTik, soyez conscient des dangers liés aux circuits électriques et familiarisez-vous avec les pratiques standard de prévention des accidents. Le programme d'installation doit être familiarisé avec les structures, les termes et les concepts du réseau.
- Utilisez uniquement l'alimentation et les accessoires approuvés par le fabricant et qui se trouvent dans l'emballage d'origine de ce produit.
- Cet équipement doit être installé par du personnel formé et qualifié, conformément à ces instructions d'installation. L'installateur est responsable de s'assurer que l'installation de l'équipement est conforme aux codes électriques locaux et nationaux. N'essayez pas de démonter, réparer ou modifier l'appareil.
- Ce produit peut être utilisé aussi bien à l'intérieur qu'à l'extérieur. Veuillez lire attentivement les instructions de montage avant de commencer l'installation. Le fait de ne pas utiliser le matériel et la configuration corrects ou de suivre les procédures correctes peut entraîner une situation dangereuse pour les personnes et endommager le système.
- Nous vous recommandons fortement d'utiliser l'alimentation AC/DC uniquement pour les cas d'utilisation en intérieur.
- La prise de courant doit être installée à proximité de l'équipement et doit être facilement accessible.
- Nous ne pouvons garantir qu'aucun accident ou dommage ne se produira en raison d'une mauvaise utilisation de l'appareil. Veuillez utiliser ce produit avec soin et l'utiliser à vos propres risques!
- En cas de panne de l'appareil, veuillez le déconnecter de l'alimentation. La façon la plus rapide de le faire est de débrancher l'adaptateur secteur de la prise de courant. Fabricant: Mikrotikls SIA, Unijas iela 2, Riga, Lettonie, LV1039.
HR - Hrvatski. Brzi vodič
Ovaj uređaj treba nadograditi na izdanje SwOS v2.18 kako bi se osigurala usklađenost s propisima lokalnih vlasti! Odgovornost krajnjih korisnika je da slijede lokalne propise. Svi MikroTik uređaji moraju biti profesionalno instalirani.
Ovaj brzi vodič pokriva model: FTC21.
Ovo je mrežni uređaj. Naziv modela proizvoda možete pronaći na naljepnici kućišta (ID). |
Prvi koraci:
- Odvrnite središnju vijku i uklonite plastičnu zaštitu;
- Pronađite Ethernet i SFP portove;
- Postavite IP adresu za svoj PC na 192.168.88.2/24;
- Povežite uređaj i uključite ga: Koristeći PoE-in (802.3af/at 24-57 V): Povežite uređaj s uključenim PoE injektorom koristeći Ethernet kabel za podatke + napajanje;
- Povežite krajnji dio podataka PoE injektora s računalom;
- Spojite adapter za napajanje na PoE injektor;
- Koristeći DC Jack (24-57 V): Koristite uključeni adapter za napajanje kako biste napajali uređaj preko DC jack-a;
- Otvorite https://192.168.88.1 u svom pregledniku. Koristite "admin" kao korisničko ime (bez lozinke prema zadanim postavkama);
- Preuzmite najnoviju verziju SwOS Lite s mikrotik.com/download. Prenesite je na karticu Upgrade i dopustite da se uređaj ponovno pokrene;
- Postavite lozinku za zaštitu uređaja;
- Ako je potrebno, uređaj se može montirati na stup ili na zid;
- U paketu su uključeni vijci s tiplama.
Sigurnosne informacije:
- Prije nego što radite na bilo kojoj MikroTik opremi, budite svjesni opasnosti koje uključuju električni krug i upoznajte se sa standardnim postupcima za sprečavanje nezgoda. Instalacijski program trebao bi biti upoznat s mrežnim strukturama, pojmovima i konceptima.
- Koristite samo napajanje i pribor odobrene od proizvođača koji se mogu naći u originalnom pakiranju ovog proizvoda.
- Ovu opremu treba ugraditi obučeno i kvalificirano osoblje prema ovim uputama za ugradnju. Instalater je odgovoran za provjeru da je instalacija opreme u skladu s lokalnim i nacionalnim električnim propisima. Ne pokušavajte rastavljati, popravljati ili modificirati uređaj.
- Ovaj se proizvod može koristiti i u zatvorenom i na otvorenom. Molimo pažljivo pročitajte upute za montažu prije početka instalacije. Ako ne upotrijebite ispravan hardver i konfiguraciju ili ne slijedite ispravne postupke, moglo bi doći do opasne situacije za ljude i oštećenja sustava.
- Toplo preporučamo korištenje AC/DC napajanja samo za unutarnje slučajeve.
- Utičnica mora biti instalirana u blizini opreme i mora biti lako dostupna.
- Ne možemo jamčiti da neće doći do nezgoda ili oštećenja uslijed nepravilne uporabe uređaja. Molimo koristite ovaj proizvod s pažnjom i radite na vlastiti rizik!
- U slučaju kvara uređaja, isključite ga iz napajanja. Najbrži način za to je isključivanjem mrežnog adaptera iz utičnice. Proizvođač: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
HU - Magyar. Gyors útmutató
Ezt az eszközt frissíteni kell a SwOS v2.18 kiadásra, hogy megfeleljen a helyi hatóságok előírásainak! A végfelhasználók felelőssége a helyi országos előírások betartása. Az összes MikroTik eszközt szakszerűen telepíteni kell.
Ez a gyors útmutató a modellre vonatkozik: FTC21.
Ez hálózati eszköz. A terméktípus nevét a tok címkéjén (ID) találhatja meg. |
Első lépések:
- Oldja fel a középső csavart és távolítsa el a műanyag fedelet;
- Helyezze el az Ethernet és SFP portokat;
- Állítsa be a számítógépe IP-jét 192.168.88.2/24;
- Csatlakoztassa az eszközt és kapcsolja be: PoE-in használatával (802.3af/at 24-57 V): Csatlakoztassa az eszközt a mellékelt PoE injektorhoz Ethernet kábellel adat+energia számára;
- Csatlakoztassa a PoE injektor adatportját a számítógéphez;
- Csatlakoztassa az adaptert a PoE injektorhoz;
- DC Jack használatával (24-57 V): Használja a mellékelt tápegységet az eszköz táplálásához DC jack-en keresztül;
- Nyissa meg a https://192.168.88.1 oldalt a böngészőjében. Használja az admin felhasználónevet (alapértelmezett jelszó nélkül);
- Töltse le a legújabb SwOS Lite verziót a mikrotik.com/download oldalról. Töltse fel az Upgrade fülre, majd hagyja, hogy az eszköz újrainduljon;
- Állítson be jelszót az eszköz biztonságához;
- Ha szükséges, az eszközt rögzítheti oszlopra vagy falra;
- A csavarok és dübelek a csomagban találhatók.
Biztonsági információk:
- Mielőtt bármilyen MikroTik berendezésen dolgozik, tisztában kell lennie az elektromos áramkörökkel kapcsolatos veszélyekkel, és ismernie kell a balesetek megelőzésére szolgáló szokásos gyakorlatokat. A telepítőnek ismeri a hálózati struktúrákat, a fogalmakat és a fogalmakat.
- Csak a gyártó által jóváhagyott tápegységet és tartozékokat használjon, amelyek a termék eredeti csomagolásában találhatók.
- Ezt a felszerelést képzett és képesített személyzetnek kell telepítenie, a jelen telepítési útmutató szerint. A telepítő felel annak biztosításáért, hogy a berendezés telepítése megfeleljen a helyi és az országos elektromos szabályoknak. Ne kísérelje meg szétszerelni, megjavítani vagy átalakítani a készüléket.
- Ez a termék beltéren és kültéren egyaránt használható. A telepítés megkezdése előtt figyelmesen olvassa el a szerelési útmutatót. Ha nem használja a megfelelő hardvert és konfigurációt, vagy nem tartja be a megfelelő eljárásokat, az veszélyes helyzetet okozhat az emberek számára, és károsíthatja a rendszert.
- Erősen javasoljuk az AC/DC tápegység használatát csak beltéri használatra.
- Az aljzatot a berendezés közelében kell elhelyezni, és könnyen hozzáférhetőnek kell lennie.
- Nem garantálhatjuk, hogy a készülék nem megfelelő használata miatt balesetek vagy károk nem következhetnek be. Kérjük, használja ezt a terméket körültekintően és működtesse a saját felelősségét!
- Eszköz meghibásodása esetén kérjük, húzza ki a tápkábelt. A leggyorsabb módszer erre az, ha a hálózati adaptert kihúzza a konnektorból. Gyártó: Mikrotikls SIA, Unijas iela 2, Riga, Lettország, LV1039.
ID - Bahasa Indonesia. Panduan cepat
Perangkat ini perlu ditingkatkan ke rilis SwOS v2.18 untuk memastikan kepatuhan dengan peraturan otoritas lokal! Pengguna akhir bertanggung jawab untuk mengikuti peraturan negara setempat. Semua perangkat MikroTik harus diinstal secara profesional.
Panduan Cepat ini mencakup model: FTC21.
Ini adalah perangkat jaringan. Anda dapat menemukan nama model produk pada label casing (ID).
Kunjungi halaman panduan pengguna di https://mt.lv/um untuk mendapatkan panduan pengguna terbaru dan lengkap. Atau pindai kode QR dengan ponsel Anda. |
Langkah pertama:
- Lepaskan sekrup tengah dan lepaskan penutup plastik;
- Temukan port Ethernet dan SFP;
- Atur IP PC Anda ke 192.168.88.2/24;
- Sambungkan perangkat dan nyalakan: Menggunakan PoE-in (802.3af/at 24-57 V): Sambungkan perangkat ke injector PoE yang disertakan menggunakan kabel Ethernet untuk data dan daya;
- Sambungkan ujung data injector PoE ke komputer;
- Sambungkan adaptor daya ke injector PoE;
- Menggunakan DC Jack (24-57 V): Gunakan adaptor daya yang disertakan untuk memberi daya perangkat melalui jack DC;
- Buka https://192.168.88.1 di browser Anda. Gunakan admin sebagai nama pengguna (tidak ada kata sandi secara default);
- Unduh versi terbaru SwOS Lite dari mikrotik.com/download. Unggah di tab Upgrade dan biarkan perangkat reboot;
- Setel kata sandi untuk mengamankan perangkat;
- Jika perlu, perangkat dapat dipasang di tiang atau di dinding;
- Sekrup dengan dowel disertakan dalam paket.
Informasi keselamatan:
- Sebelum Anda mengerjakan peralatan MikroTik apa pun, waspadai bahaya yang terkait dengan sirkuit listrik, dan pahami praktik standar untuk mencegah kecelakaan. Pemasang harus memahami struktur, istilah, dan konsep jaringan.
- Gunakan hanya aksesori yang disetujui oleh produsen, dan dapat ditemukan dalam kemasan asli produk ini.
- Peralatan ini harus dipasang oleh personel yang terlatih dan berkualifikasi, sesuai petunjuk pemasangan ini. Pemasang bertanggung jawab untuk memastikan bahwa Pemasangan peralatan mematuhi peraturan kelistrikan lokal dan nasional. Jangan mencoba membongkar, memperbaiki, atau memodifikasi perangkat.
- Produk ini dapat digunakan baik di dalam maupun di luar ruangan. Sebelum memulai instalasi, bacalah petunjuk instalasi dengan seksama. Kegagalan dalam menggunakan perangkat keras dan konfigurasi yang benar atau mengikuti prosedur yang benar dapat menimbulkan situasi berbahaya bagi manusia dan merusak sistem.
- Sangat disarankan untuk menggunakan daya AC/DC hanya untuk penggunaan di dalam ruangan.
- Stop Kontak harus dipasang di dekat peralatan dan harus mudah diakses.
- Kami tidak dapat menjamin bahwa tidak akan terjadi kecelakaan atau kerusakan akibat penggunaan perangkat yang tidak tepat. Harap gunakan produk ini dengan hati-hati dan pengoperasian dengan risiko Anda sendiri!
- Jika terjadi kegagalan perangkat, harap putuskan sambungannya dari listrik. Cara tercepat untuk melakukannya adalah dengan mencabut adaptor daya dari stopkontak. Pabrikan: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
IT - Italiano. Guida veloce
Questo dispositivo deve essere aggiornato alla versione SwOS v2.18 per garantire la conformità con le normative delle autorità locali! È responsabilità dell'utente finale seguire le normative locali locali. Tutti i dispositivi MikroTik devono essere installati in modo professionale.
Questa guida rapida copre il modello: FTC21.
Questo è il dispositivo di rete. È possibile trovare il nome del modello del prodotto sull'etichetta della custodia (ID). |
Primi passi:
- Svitare la vite centrale e rimuovere la copertura in plastica;
- Trova le porte Ethernet e SFP;
- Imposta l'IP del PC su 192.168.88.2/24;
- Collega il dispositivo e accendilo: Utilizzando PoE-in (802.3af/at 24-57 V): Collega il dispositivo all'iniettore PoE fornito utilizzando un cavo Ethernet per i dati e l'alimentazione;
- Collega l'estremità dati dell'iniettore PoE al computer;
- Collega l'adattatore di alimentazione all'iniettore PoE;
- Utilizzando il Jack DC (24-57 V): Usa l'adattatore di alimentazione fornito per alimentare il dispositivo tramite il Jack DC;
- Apri https://192.168.88.1 nel tuo browser. Usa "admin" come nome utente (nessuna password di default);
- Scarica l'ultima versione di SwOS Lite da mikrotik.com/download. Caricalo nella scheda Upgrade e lascia che il dispositivo si riavvii;
- Imposta una password per proteggere il dispositivo;
- Se necessario, il dispositivo può essere montato su un palo o su una parete;
- Le viti con tasselli sono incluse nella confezione.
Informazioni sulla sicurezza:
- Prima di lavorare su qualsiasi apparecchiatura MikroTik, prestare attenzione ai pericoli connessi con i circuiti elettrici e conoscere le pratiche standard per la prevenzione degli incidenti. Il programma di installazione dovrebbe avere familiarità con le strutture, i termini e i concetti della rete.
- Utilizzare solo l'alimentatore e gli accessori approvati dal produttore e che si trovano nella confezione originale di questo prodotto.
- Questa apparecchiatura deve essere installata da personale addestrato e qualificato, secondo queste istruzioni di installazione. L'installatore è responsabile di assicurarsi che l'installazione dell'apparecchiatura sia conforme ai codici elettrici locali e nazionali. Non tentare di smontare, riparare o modificare il dispositivo.
- Questo prodotto può essere utilizzato sia all'interno che all'esterno. Si prega di leggere attentamente le istruzioni di montaggio prima di iniziare l'installazione. Il mancato utilizzo dell'hardware e della configurazione corretti o il mancato rispetto delle procedure corrette potrebbe comportare una situazione pericolosa per le persone e danni al sistema.
- Si consiglia vivamente di utilizzare l'alimentazione AC/DC solo per casi di utilizzo in interni.
- La presa di corrente deve essere installata vicino all'apparecchiatura e deve essere facilmente accessibile.
- Non possiamo garantire che non si verifichino incidenti o danni dovuti all'uso improprio del dispositivo. Utilizzare questo prodotto con cura e operare a proprio rischio!
- In caso di guasto del dispositivo, scollegarlo dall'alimentazione. Il modo più rapido per farlo è scollegare l'alimentatore dalla presa di corrente. Produttore: Mikrotikls SIA, Unijas iela 2, Riga, Lettonia, LV1039.
IS - Íslensku. Fljótur leiðarvísir
Þetta tæki þarf að uppfæra í SwOS v2.18 útgáfuna til að tryggja samræmi við reglugerðir sveitarfélaga! Það er ábyrgð notendanna að fylgja reglugerðum á staðnum. Öll MikroTik tæki verða að vera sett upp á fagmennsku.
Þessi snögga leiðbeining nær yfir líkanið: FTC21.
Þetta er net tæki. Þú getur fundið heiti vörulíkansins á merkimiðanum (ID). |
Fyrstu skrefin:
- Fjarstýra miðju skrúfunni og fjarlægja plastlokið;
- Finndu Ethernet og SFP portana;
- Settu IP fyrir tölvuna þína á 192.168.88.2/24;
- Tengdu tækið og kveiktu á því: Með PoE-in (802.3af/at 24-57 V): Tengdu tækið við PoE inndælingu sem fylgir með með Ethernet snúru fyrir gögn og afl;
- Tengdu gögn endann PoE inndælingar við tölvuna;
- Tengdu straumbreytir við PoE inndælinguna;
- Með DC Jack (24-57 V): Notaðu meðfylgjandi straumbreytir til að veita aflgjafa á tækið með DC jack;
- Opnaðu https://192.168.88.1 í vafrara. Notaðu admin sem notendanafn (enginn lykilorð af sjálfgefinni stillingu);
- Hlaða niður nýjustu útgáfu af SwOS Lite frá mikrotik.com/download. Hladdu því upp á uppfærslu flipanum og leyfðu tækinu að endurræsa sig;
- Stilltu lykilorð til að tryggja tækið;
- Ef þarf, má setja tækið á stöng eða á vegg;
- Skrúfur með plötum fylgja pakkanum.
Öryggisupplýsingar:
- Áður en þú vinnur að einhverjum MikroTik búnaði, vertu meðvitaður um hættuna sem fylgir rafrásum og kynntu þér hefðbundnar venjur til að koma í veg fyrir slys. Uppsetningarforritið ætti að vera kunnugt um netkerfi, hugtök og hugtök.
- Notaðu aðeins aflgjafa og fylgihluti sem framleiðandi hefur samþykkt og er að finna í upprunalegum umbúðum þessarar vöru.
- Þessum búnaði skal setja upp af þjálfuðu og hæfu starfsfólki samkvæmt þessum uppsetningarleiðbeiningum. Uppsetningaraðilinn ber ábyrgð á því að uppsetning búnaðarins sé í samræmi við staðbundin og innlend rafmagnsnúmer. Ekki reyna að taka tækið í sundur, gera við eða breyta því.
- Þessa vöru er hægt að nota bæði inni og úti. Vinsamlegast lestu leiðbeiningar um uppsetningu vandlega áður en byrjað er að setja upp. Ef ekki er notaður réttur vélbúnaður og stillingar eða farið eftir réttum aðferðum gæti það valdið hættulegum aðstæðum fyrir fólk og skemmdum á kerfinu.
- Við mælum eindregið með því að nota AC/DC aflgjafa eingöngu til notkunar innanhúss.
- Innstungan skal vera nálægt búnaðinum og vera aðgengileg.
- Við getum ekki ábyrgst að engin slys eða skemmdir muni verða vegna óviðeigandi notkunar tækisins. Vinsamlegast notaðu þessa vöru með varúð og starfaðu á eigin ábyrgð!
- Ef bilun í tæki, vinsamlegast aftengdu það frá rafmagni. Skjótasta leiðin til þess er með því að taka rafmagnstengið úr sambandi. Framleiðandi: Mikrotikls SIA, Unijas iela 2, Riga, Lettlandi, LV1039.
NO - Norsk. Hurtiginnføring
Denne enheten må oppgraderes til SwOS v2.18-versjonen for å sikre samsvar med lokale myndigheters forskrifter! Det er sluttbrukernes ansvar å følge lokale lands forskrifter. Alle MikroTik-enheter må være profesjonelt installert.
Denne hurtigveiledningen dekker modellen: FTC21.
Dette er nettverksenhet. Du kan finne produktmodellnavnet på etiketten (ID). |
Første steg:
- Skru løs midtskrue og fjern plastdekselet;
- Finn Ethernet og SFP-portene;
- Sett IP-en for PC-en til 192.168.88.2/24;
- Koble til enheten og slå den på: Bruke PoE-in (802.3af/at 24-57 V): Koble enheten til den medfølgende PoE-injektoren ved hjelp av en Ethernet-kabel for data og strøm;
- Koble dataportenden av PoE-injektoren til datamaskinen;
- Koble strømforsyningen til PoE-injektoren;
- Bruke DC Jack (24-57 V): Bruk den medfølgende strømforsyningen for å gi strøm til enheten via DC jack;
- Åpne https://192.168.88.1 i nettleseren din. Bruk "admin" som brukernavn (ingen passord som standard);
- Last ned den nyeste versjonen av SwOS Lite fra mikrotik.com/download. Last det opp i oppgraderingsfanen, og la enheten starte på nytt;
- Sett et passord for å beskytte enheten;
- Hvis nødvendig, kan enheten monteres på en stang eller på en vegg;
- Skruer med dowels er inkludert i pakken.
Sikkerhetsinformasjon:
- Før du jobber med MikroTik-utstyr, må du være oppmerksom på farene som er forbundet med elektriske kretsløp, og kjenne til standard praksis for å forhindre ulykker. Installasjonsprogrammet skal være kjent med nettverksstrukturer, vilkår og konsepter.
- Bruk bare strømforsyningen og tilbehøret som er godkjent av produsenten, og som finnes i originalemballasjen til dette produktet.
- Dette utstyret skal installeres av trent og kvalifisert personell i henhold til denne installasjonsinstruksen. Installatøren er ansvarlig for at installasjonen av utstyret er i samsvar med lokale og nasjonale elektriske koder. Ikke prøv å demontere, reparere eller endre enheten.
- Dette produktet kan brukes både innendørs og utendørs. Les monteringsinstruksjonene nøye før du begynner å installere. Unnlatelse av å bruke riktig maskinvare og konfigurasjon eller å følge de riktige prosedyrene kan føre til en farlig situasjon for mennesker og skade på systemet.
- Vi anbefaler på det sterkeste å bruke AC/DC strømforsyning kun for innendørs bruk.
- Stikkontakten skal installeres i nærheten av utstyret og skal være lett tilgjengelig.
- Vi kan ikke garantere at ingen ulykker eller skader vil oppstå på grunn av feil bruk av enheten. Bruk dette produktet med forsiktighet og bruk det på egen risiko!
- Ved feil på enheten må du koble den fra strømmen. Den raskeste måten å gjøre det på er ved å trekke ut strømadapteren fra stikkontakten. Produsent: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
LT - Lietuvių. Trumpas vadovas
Šis įrenginys turi būti atnaujintas į SwOS v2.18 leidimą, kad būtų laikomasi vietos valdžios taisyklių! Galutiniai vartotojai yra atsakingi už vietinių šalies įstatymų laikymąsi. Visi „MikroTik“ įrenginiai turi būti profesionaliai įdiegti.
Šis trumpasis vadovas apima modelį: FTC21.
Tai yra tinklo įrenginys. Produkto modelio pavadinimą galite rasti dėklo etiketėje (ID). |
Pirmieji žingsniai:
- Atsukite centrinį varžtą ir nuimkite plastikinį dangtį;
- Suraskite Ethernet ir SFP jungtis;
- Nustatykite kompiuterio IP adresą į 192.168.88.2/24;
- Prijunkite įrenginį ir įjunkite: Naudojant PoE-in (802.3af/at 24-57 V): Prijunkite įrenginį prie suteikto PoE injektoriaus naudojant Ethernet kabelį duomenims ir energijai;
- Prijunkite duomenų pabaigą prie kompiuterio;
- Prijunkite maitinimo adapterį prie PoE injektoriaus;
- Naudojant DC Jack (24-57 V): Naudokite suteiktą maitinimo adapterį įrenginio maitinimui per DC jack;
- Atidarykite https://192.168.88.1 savo naršyklėje. Naudokite „admin“ kaip vartotojo vardą (numatytasis slaptažodis nėra nustatytas);
- Atsisiųskite naujausią SwOS Lite versiją iš mikrotik.com/download. Įkelkite ją į naujinimo skirtuką ir leiskite įrenginiui paleisti iš naujo;
- Nustatykite slaptažodį, kad apsaugotumėte įrenginį;
- Jei reikia, įrenginį galima montuoti ant stulpo arba sienos;
- Varžtai su kaiščiais yra įtraukti į pakuotę.
Saugumo informacija:
- Prieš pradėdami dirbti su bet kuria „MikroTik“ įranga, žinokite apie pavojus, susijusius su elektros grandinėmis, ir susipažinkite su standartine avarijų prevencijos praktika. Montuotojas turėtų būti susipažinęs su tinklo struktūromis, terminais ir sąvokomis.
- Naudokite tik gamintojo patvirtintus maitinimo šaltinius ir priedus, kuriuos galite rasti originalioje šio gaminio pakuotėje.
- Šią įrangą turi montuoti apmokyti ir kvalifikuoti darbuotojai, kaip numatyta šiose montavimo instrukcijose. Montuotojas yra atsakingas už tai, kad įranga būtų montuojama laikantis vietinių ir nacionalinių elektros taisyklių. Nemėginkite išardyti, taisyti ar modifikuoti įrenginio.
- Šis produktas gali būti naudojamas tiek viduje, tiek lauke. Prieš pradėdami diegimą, atidžiai perskaitykite montavimo instrukcijas. Jei nenaudosite tinkamos aparatūros ir konfigūracijos arba nesilaikysite teisingų procedūrų, žmonėms gali kilti pavojinga situacija ir sugadinti sistemą.
- Primygtinai rekomenduojame naudoti AC/DC maitinimo šaltinį tik patalpose.
- Kištukinis lizdas turi būti įrengtas šalia įrangos ir turi būti lengvai pasiekiamas.
- Mes negalime garantuoti, kad dėl netinkamo prietaiso naudojimo nebus jokių avarijų ar žalos. Naudokite šį gaminį atsargiai ir dirbkite savo rizika!
- Sugedus įrenginiui, atjunkite jį nuo maitinimo. Greičiausias būdas tai padaryti yra atjungus maitinimo adapterį nuo maitinimo lizdo. Gamintojas: Mikrotikls SIA, Unijas iela 2, Ryga, Latvija, LV1039.
LV - Latviešu. Īsa rokasgrāmata
Šī ierīce ir jāatjaunina uz SwOS v2.18 versiju, lai nodrošinātu atbilstību vietējo varas iestāžu noteikumiem! Gala lietotāju pienākums ir ievērot vietējos valsts normatīvus. Visām MikroTik ierīcēm jābūt profesionāli uzstādītām.
Šī īsā rokasgrāmata attiecas uz modeli: FTC21.
Šī ir tīkla ierīce. Produkta modeļa nosaukumu varat atrast uz produkta iepakojuma (ID). |
Pirmie soļi:
- Atskrūvējiet vidējo skrūvi un noņemiet plastmasas vāciņu;
- Atradiet Ethernet un SFP portus;
- Iestatiet datora IP adresi uz 192.168.88.2/24;
- Pievienojiet ierīci un ieslēdziet to: Izmantojot PoE-in (802.3af/at 24-57 V): Pievienojiet ierīci piegādātajam PoE injektoram, izmantojot Ethernet kabeli datiem un barošanai;
- Pievienojiet datu galu pie datora;
- Pievienojiet strāvas adapteri PoE injektoram;
- Izmantojot DC Jack (24-57 V): Izmantojiet piegādāto strāvas adapteri, lai piegādātu barošanu ierīcei, izmantojot DC jack;
- Atveriet https://192.168.88.1 pārlūkā. Izmantojiet “admin” kā lietotājvārdu (noklusējuma parole nav iestatīta);
- Lejupielādējiet jaunāko SwOS Lite versiju no mikrotik.com/download. Augšupielādējiet to atjaunināšanas cilnē un ļaujiet ierīcei restartēties;
- Iestatiet paroli, lai aizsargātu ierīci;
- Ja nepieciešams, ierīci var uzstādīt uz staba vai pie sienas;
- Skrūves ar dowelēm ir iekļautas iepakojumā.
Drošības informācija:
- Pirms sākat strādāt ar jebkuru MikroTik aprīkojumu, iepazīstieties ar briesmām, kas saistītas ar elektriskajām shēmām, un iepazīstieties ar standarta praksi negadījumu novēršanā. Instalētājam jāzina tīkla struktūras, termini un koncepcijas.
- Izmantojiet tikai ražotāja apstiprinātu barošanas avotu un piederumus, kas atrodami šī produkta oriģinālajā iepakojumā.
- Saskaņā ar šīm uzstādīšanas instrukcijām šo aprīkojumu jāuzstāda apmācītam un kvalificētam personālam. Uzstādītāja pienākums ir pārliecināties, ka aprīkojuma uzstādīšana atbilst vietējiem un nacionālajiem elektrības noteikumiem. Nemēģiniet ierīci izjaukt, labot vai pārveidot.
- Šo produktu var izmantot gan telpās, gan ārpus tām. Pirms uzstādīšanas, lūdzu, uzmanīgi izlasiet montāžas instrukciju. Pareizas aparatūras un konfigurācijas neizmantošana vai pareizu procedūru neievērošana var izraisīt cilvēkiem bīstamu situāciju un sistēmas bojājumus.
- Stingri rekomendējam izmantot AC/DC barošanas avotu tikai iekštelpās.
- Kontaktligzdai jābūt uzstādītai netālu no iekārtas un tai jābūt viegli pieejamai.
- Mēs nevaram garantēt, ka ierīces nepareizas lietošanas dēļ negadījumi vai bojājumi nenotiks. Lūdzu, izmantojiet šo produktu uzmanīgi un rīkojieties atbildīgi!
- Ierīces kļūmes gadījumā, lūdzu, atvienojiet to no strāvas. Ātrākais veids, kā to izdarīt, ir, atvienojot strāvas adapteri no kontaktligzdas. Ražotājs: Mikrotikls SIA, Unijas iela 2, Rīga, Latvija, LV1039.
MT - Malti. Gwida Quick
Dan l-apparat jeħtieġ li jiġi aġġornat għar-rilaxx SwOS v2.18 biex tiġi żgurata l-konformità mar-regolamenti tal-awtorità lokali! Hija r-responsabbiltà tal-utenti finali li jsegwu r-regolamenti lokali tal-pajjiż. L-apparati kollha MikroTik għandhom ikunu installati professjonalment.
Din il-Gwida Quick tkopri l-mudell: FTC21.
Dan huwa apparat tan-netwerk. Tista 'ssib l-isem tal-mudell tal-prodott fuq it-tikketta tal-każ (ID). |
L-ewwel passi:
- Istrina s-screw ċentrali u neħħi l-kopertura tal-plastik;
- Sib il-portijiet Ethernet u SFP;
- Stabbilixxi l-IP tiegħek għall-PC għa 192.168.88.2/24;
- Ikonnettja d-devices u qabbad: Uża PoE-in (802.3af/at 24-57 V): Ikonnettja d-device mal-PoE injector li jingħata b'kable Ethernet għal data u enerġija;
- Ikonnettja l-ends tad-data tal-PoE injector mal-kompjuter;
- Ikonnettja l-adapter tal-enerġija mal-PoE injector;
- Uża DC Jack (24-57 V): Uża l-adapter tal-enerġija mogħti biex tagħti enerġija lid-device permezz ta’ DC jack;
- Erġa' pprova l-https://192.168.88.1 fil-browser tiegħek. Uża admin bħala l-username (m'hemm l-ebda password b'definizzjoni);
- Niżżel l-aħħar verżjoni ta' SwOS Lite minn mikrotik.com/download. Tella' dan fil-tab ta' Upgrade u ħalli li l-apparat ir-ristartja;
- Stabbilixxi password biex tipproteġi d-device;
- Jekk meħtieġ, il-device jista' jintlaħaq fuq pjanċa jew fuq il-ħajt;
- L-iskruċetti ma’ dowels huma inklużi fil-pakkett.
Informazzjoni dwar is-Sikurezza:
- Qabel ma taħdem fuq kwalunkwe tagħmir MikroTik, kun konxju tal-perikli involuti fiċ-ċirkwiti elettriċi u kun familjari mal-prattiki standard għall-prevenzjoni ta 'inċidenti. L-installatur għandu jkun familjari mal-istrutturi, termini u kunċetti tan-netwerk.
- Uża biss il-provvista tal-enerġija u l-aċċessorji approvati mill-manifattur, u li tista 'tinstab fl-imballaġġ oriġinali ta' dan il-prodott.
- Dan it-tagħmir għandu jkun installat minn persunal imħarreġ u kwalifikat, skont dawn l-istruzzjonijiet ta 'installazzjoni. L-installatur huwa responsabbli li jiżgura li l-Installazzjoni tat-tagħmir hija konformi mal-kodiċijiet elettriċi lokali u nazzjonali. Tippruvax tiżżarma, tissewwa jew timmodifika l-apparat.
- Dan il-prodott jista 'jintuża kemm ġewwa kif ukoll barra. Jekk jogħġbok aqra sew l-istruzzjonijiet tal-immuntar qabel tibda l-installazzjoni. Nuqqas li tuża l-hardware u l-konfigurazzjoni korretti jew li ssegwi l-proċeduri korretti jista 'jirriżulta f'sitwazzjoni perikoluża għan-nies u ħsara lis-sistema.
- Nirrakkomandaw ħafna li tuża provvista ta 'enerġija AC/DC biss għal każijiet ta' użu fuq ġewwa.
- Is-socket-outlet għandu jkun installat ħdejn it-tagħmir u għandu jkun faċilment aċċessibbli.
- Ma nistgħux niggarantixxu li ma jseħħ l-ebda inċident jew ħsara minħabba l-użu mhux xieraq tal-apparat. Jekk jogħġbok uża dan il-prodott b'attenzjoni u tħaddem għar-riskju tiegħek!
- Fil-każ ta 'ħsara fl-apparat, jekk jogħġbok aqla' mill-enerġija. L-iktar mod mgħaġġel biex tagħmel dan huwa billi tiftaħ l-adapter tal-enerġija mill-iżbokk tad-dawl. Manifattur: Mikrotikls SIA, Unijas iela 2, Riga, il-Latvja, LV1039.
NL - Nederlands. Snelgids
Dit apparaat moet worden geüpgraded naar de SwOS v2.18-release om ervoor te zorgen dat het voldoet aan de lokale overheidsvoorschriften! Het is de verantwoordelijkheid van de eindgebruiker om de lokale landelijke voorschriften. Alle MikroTik-apparaten moeten professioneel worden geïnstalleerd.
Deze beknopte handleiding behandelt het model: FTC21.
Dit is een netwerkapparaat. U kunt de naam van het productmodel vinden op het etiket van de behuizing (ID). |
Eerste stappen:
- Draai de centrale schroef los en verwijder de plastic cover;
- Zoek de Ethernet- en SFP-poorten;
- Stel het IP-adres van uw pc in op 192.168.88.2/24;
- Verbind het apparaat en zet het aan: Gebruik PoE-in (802.3af/at 24-57 V): Verbind het apparaat met de meegeleverde PoE-injector via een Ethernetkabel voor data en stroom;
- Verbind het datakabeltje van de PoE-injector met de computer;
- Sluit de voeding aan op de PoE-injector;
- Gebruik DC Jack (24-57 V): Gebruik de meegeleverde voedingsadapter om het apparaat van stroom te voorzien via de DC-jack;
- Open https://192.168.88.1 in uw webbrowser. Gebruik "admin" als gebruikersnaam (geen wachtwoord ingesteld);
- Download de laatste SwOS Lite-versie van mikrotik.com/download. Upload deze in het tabblad Upgrade en laat het apparaat opnieuw opstarten;
- Stel een wachtwoord in om het apparaat te beveiligen;
- Indien nodig kan het apparaat op een paal of muur worden gemonteerd;
- De schroeven met pluggen zijn bij de verpakking inbegrepen.
Veiligheidsinformatie:
- Voordat u aan een MikroTik-apparaat gaat werken, moet u zich bewust zijn van de gevaren van elektrische circuits en bekend zijn met de standaardpraktijken om ongevallen te voorkomen. Het installatieprogramma moet bekend zijn met netwerkstructuren, termen en concepten.
- Gebruik alleen de voeding en accessoires die zijn goedgekeurd door de fabrikant en die u kunt vinden in de originele verpakking van dit product.
- Deze apparatuur moet worden geïnstalleerd door opgeleid en gekwalificeerd personeel, volgens deze installatie-instructies. De installateur is ervoor verantwoordelijk dat de installatie van de apparatuur voldoet aan de lokale en nationale elektrische voorschriften. Probeer het apparaat niet uit elkaar te halen, te repareren of aan te passen.
- Dit product kan zowel binnen als buiten worden gebruikt. Lees de montage-instructies zorgvuldig door voordat u met de installatie begint. Het niet gebruiken van de juiste hardware en configuratie of het niet volgen van de juiste procedures kan leiden tot een gevaarlijke situatie voor mensen en schade aan het systeem.
- We raden ten zeerste aan om AC/DC-voeding alleen te gebruiken voor gebruik binnenshuis.
- Het stopcontact moet in de buurt van de apparatuur worden geïnstalleerd en gemakkelijk toegankelijk zijn.
- We kunnen niet garanderen dat er geen ongelukken of schade zullen optreden als gevolg van oneigenlijk gebruik van het apparaat. Gebruik dit product met zorg en werk op eigen risico!
- Koppel het apparaat los van de stroom als het defect is. De snelste manier om dit te doen is door de stroomadapter uit het stopcontact te halen. Fabrikant: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
PL - Polskie. Szybka porada
To urządzenie wymaga uaktualnienia do wersji SwOS v2.18, aby zapewnić zgodność z przepisami władz lokalnych! Użytkownicy końcowi są zobowiązani do przestrzegania lokalnych przepisów krajowych. Wszystkie urządzenia MikroTik muszą być profesjonalnie zainstalowane.
Niniejszy Krótki przewodnik obejmuje model: FTC21.
To jest urządzenie sieciowe. Nazwę modelu produktu można znaleźć na etykiecie skrzynki (ID). |
Pierwsze kroki:
- Odkręć centralną śrubę i zdejmij plastikową pokrywę;
- Znajdź porty Ethernet i SFP;
- Ustaw adres IP dla PC na 192.168.88.2/24;
- Podłącz urządzenie i włącz je: Użyj PoE-in (802.3af/at 24-57 V): Podłącz urządzenie do dostarczonego injektora PoE za pomocą kabla Ethernet do danych i zasilania;
- Podłącz koniec danych injektora PoE do komputera;
- Podłącz zasilacz do injektora PoE;
- Użyj DC Jack (24-57 V): Użyj dostarczonego zasilacza, aby zasilić urządzenie przez złącze DC jack;
- Otwórz https://192.168.88.1 w przeglądarce. Użyj "admin" jako nazwę użytkownika (domyślnie brak hasła);
- Pobierz najnowszą wersję SwOS Lite z mikrotik.com/download. Prześlij ją w zakładce Upgrade, a następnie pozwól urządzeniu zrestartować się;
- Ustaw hasło w celu zabezpieczenia urządzenia;
- Jeśli to konieczne, urządzenie można zamontować na słupie lub na ścianie;
- W zestawie znajdują się wkręty z kołkami.
Informacje dotyczące bezpieczeństwa:
- Przed rozpoczęciem pracy z jakimkolwiek sprzętem MikroTik należy pamiętać o zagrożeniach związanych z obwodami elektrycznymi i zapoznać się ze standardowymi praktykami zapobiegania wypadkom. Instalator powinien zapoznać się ze strukturami sieci, terminami i koncepcjami.
- Używaj wyłącznie zasilacza i akcesoriów zatwierdzonych przez producenta, które znajdują się w oryginalnym opakowaniu tego produktu.
- To urządzenie powinno być zainstalowane przez przeszkolony i wykwalifikowany personel zgodnie z niniejszą instrukcją instalacji. Instalator jest odpowiedzialny za upewnienie się, że instalacja urządzenia jest zgodna z lokalnymi i krajowymi przepisami elektrycznymi. Nie należy podejmować prób demontażu, naprawy ani modyfikacji urządzenia.
- Ten produkt może być używany zarówno wewnątrz, jak i na zewnątrz. Przed rozpoczęciem instalacji prosimy o dokładne zapoznanie się z instrukcją montażu. Niezastosowanie prawidłowego sprzętu i konfiguracji lub nieprzestrzeganie prawidłowych procedur może skutkować niebezpieczną sytuacją dla ludzi i uszkodzeniem systemu.
- Zdecydowanie zalecamy używanie zasilacza AC/DC tylko do zastosowań wewnętrznych.
- Gniazdko powinno być zainstalowane w pobliżu urządzenia i powinno być łatwo dostępne.
- Nie możemy zagwarantować, że nie dojdzie do wypadków ani szkód spowodowanych niewłaściwym użytkowaniem urządzenia. Proszę używać tego produktu ostrożnie i działać na własne ryzyko!
- W przypadku awarii urządzenia odłącz je od zasilania. Najszybszym sposobem jest odłączenie zasilacza od gniazdka elektrycznego. Producent: Mikrotikls SIA, Unijas iela 2, Riga, Łotwa, LV1039.
PT - Português. Guia rápido
Este dispositivo precisa ser atualizado para a versão SwOS v2.18 para garantir a conformidade com os regulamentos das autoridades locais! É responsabilidade do usuário final seguir as regulamentações locais do país. Todos os dispositivos MikroTik devem ser instalados profissionalmente.
Este Guia Rápido cobre o modelo: FTC21.
Este é o dispositivo de rede. Você pode encontrar o nome do modelo do produto no rótulo da caixa (ID). |
Primeiros passos:
- Retire o parafuso central e remova a capa plástica;
- Localize as portas Ethernet e SFP;
- Defina o IP do seu PC para 192.168.88.2/24;
- Conecte o dispositivo e ligue-o: Usando PoE-in (802.3af/at 24-57 V): Conecte o dispositivo ao PoE injector fornecido com um cabo Ethernet para dados e energia;
- Conecte a extremidade de dados do PoE injector ao computador;
- Conecte o adaptador de energia ao PoE injector;
- Usando DC Jack (24-57 V): Use o adaptador de energia fornecido para alimentar o dispositivo via DC jack;
- Abra https://192.168.88.1 no seu navegador. Use "admin" como nome de usuário (sem senha definida por padrão);
- Baixe a versão mais recente do SwOS Lite de mikrotik.com/download. Carregue-a na aba de Upgrade e permita que o dispositivo reinicie;
- Defina uma senha para proteger o dispositivo;
- Se necessário, o dispositivo pode ser montado em um poste ou parede;
- Os parafusos com buchas estão incluídos no pacote.
Informação de Segurança:
- Antes de trabalhar em qualquer equipamento MikroTik, esteja ciente dos riscos envolvidos nos circuitos elétricos e esteja familiarizado com as práticas padrão para prevenção de acidentes. O instalador deve estar familiarizado com estruturas, termos e conceitos de rede.
- Use apenas a fonte de alimentação e os acessórios aprovados pelo fabricante e que podem ser encontrados na embalagem original deste produto.
- Este equipamento deve ser instalado por pessoal treinado e qualificado, de acordo com estas instruções de instalação. O instalador é responsável por garantir que a instalação do equipamento esteja em conformidade com os códigos elétricos locais e nacionais. Não tente desmontar, reparar ou modificar o dispositivo.
- Este produto pode ser usado tanto em ambientes internos quanto externos. Leia as instruções de montagem cuidadosamente antes de iniciar a instalação. A falha em usar o hardware e a configuração corretos ou em seguir os procedimentos corretos pode resultar em uma situação perigosa para as pessoas e danos ao sistema.
- É altamente recomendável usar a fonte de alimentação CA/CC apenas para casos de uso interno.
- A tomada deve ser instalada próxima ao equipamento e deve ser de fácil acesso.
- Não podemos garantir que nenhum acidente ou dano ocorra devido ao uso inadequado do dispositivo. Por favor, use este produto com cuidado e opere por sua conta e risco!
- No caso de falha do dispositivo, desconecte-o da energia. A maneira mais rápida de fazer isso é desconectando o adaptador de energia da tomada. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letônia, LV1039.
RO - Română. Ghid rapid
Acest dispozitiv trebuie să fie actualizat la versiunea SwOS v2.18 pentru a asigura conformitatea cu reglementările autorităților locale! Este responsabilitatea utilizatorilor finali să urmeze reglementările locale ale țării. Toate dispozitivele MikroTik trebuie instalate profesional.
Acest Ghid rapid acoperă modelul: FTC21.
Acesta este dispozitivul de rețea. Puteți găsi numele modelului produsului pe eticheta carcasei (ID). |
Primii pasi:
- Deșurubați șurubul central și îndepărtați capacul din plastic;
- Localizați porturile Ethernet și SFP;
- Setează adresa IP a PC-ului la 192.168.88.2/24;
- Conectați dispozitivul și porniți-l: Folosind PoE-in (802.3af/at 24-57 V): Conectați dispozitivul la injectorul PoE furnizat cu un cablu Ethernet pentru date și alimentare;
- Conectați capătul de date al injectorului PoE la computer;
- Conectați adaptorul de alimentare la injectorul PoE;
- Folosind DC Jack (24-57 V): Folosiți adaptorul de alimentare furnizat pentru a alimenta dispozitivul prin DC jack;
- Deschideți https://192.168.88.1 în browserul dumneavoastră. Folosiți „admin” ca nume de utilizator (nu este setată nicio parolă implicită);
- Descărcați cea mai recentă versiune SwOS Lite de pe mikrotik.com/download. Încărcați-o în tab-ul de Upgrade și lăsați dispozitivul să se repornească;
- Setați o parolă pentru a securiza dispozitivul;
- Dacă este necesar, dispozitivul poate fi montat pe un stâlp sau pe perete;
- Șuruburile cu dibluri sunt incluse în pachet.
Informații de siguranță:
- Înainte de a lucra la orice echipament MikroTik, fiți conștienți de pericolele implicate de circuitele electrice și cunoașteți practicile standard pentru prevenirea accidentelor. Programul de instalare ar trebui să fie familiarizat cu structurile, termenii și conceptele rețelei.
- Folosiți numai sursa de alimentare și accesoriile aprobate de producător și care pot fi găsite în ambalajul original al acestui produs.
- Acest echipament va fi instalat de personal instruit și calificat, conform acestor instrucțiuni de instalare. Instalatorul este responsabil să se asigure că Instalarea echipamentului respectă codurile electrice locale și naționale. Nu încercați să dezasamblați, reparați sau modificați dispozitivul.
- Acest produs poate fi utilizat atât în interior, cât și în exterior. Vă rugăm să citiți cu atenție instrucțiunile de montare înainte de a începe instalarea. Neutilizarea hardware-ului și a configurației corecte sau a respectării procedurilor corecte ar putea duce la o situație periculoasă pentru oameni și la deteriorarea sistemului.
- Vă recomandăm să utilizați sursa de alimentare AC/DC numai pentru cazuri de utilizare în interior.
- Priza trebuie instalată în apropierea echipamentului și trebuie să fie ușor accesibilă.
- Nu putem garanta că nu se vor produce accidente sau daune din cauza utilizării necorespunzătoare a dispozitivului. Vă rugăm să utilizați acest produs cu grijă și să operați pe riscul dvs.!
- În cazul unei defecțiuni a dispozitivului, vă rugăm să îl deconectați de la alimentare. Cel mai rapid mod de a face acest lucru este prin a deconecta adaptorul de alimentare de la priza electrică. Producător: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
SK - Slovenský. Stručný návod
Toto zariadenie je potrebné inovovať na vydanie SwOS v2.18, aby sa zabezpečil súlad s predpismi miestnych úradov! Je na koncových užívateľoch, aby dodržiavali miestne predpisy krajiny. Všetky zariadenia MikroTik musia byť profesionálne nainštalované.
Táto Stručná príručka sa týka modelu: FTC21.
Toto je sieťové zariadenie. Názov modelu produktu nájdete na štítku prípadu (ID). |
Prvé kroky:
- Odstráňte centrálny skrutku a vyberte plastový kryt;
- Nájdite Ethernet a SFP porty;
- Nastavte IP pre PC na 192.168.88.2/24;
- Pripojte zariadenie a zapnite ho: Použite PoE-in (802.3af/at 24-57 V): Pripojte zariadenie k dodanému PoE injektoru cez Ethernetový kábel pre dáta a napájanie;
- Pripojte koniec dátového kábla PoE injektora k počítaču;
- Pripojte napájací adaptér k PoE injektoru;
- Použite DC Jack (24-57 V): Použite dodaný napájací adaptér na napájanie zariadenia cez DC jack;
- Otvorte https://192.168.88.1 vo vašom prehliadači. Použite "admin" ako meno používateľa (predvolene bez hesla);
- Stiahnite najnovšiu verziu SwOS Lite z mikrotik.com/download. Nahrajte ju v sekcii Upgrade a nechajte zariadenie reštartovať;
- Nastavte heslo na zabezpečenie zariadenia;
- Ak je to potrebné, zariadenie môžete namontovať na stĺp alebo na stenu;
- Skrutky s hmoždinkami sú súčasťou balenia.
Bezpečnostné informácie:
- Predtým, ako začnete pracovať na akomkoľvek zariadení MikroTik, uvedomte si riziká spojené s elektrickými obvodmi a zoznámte sa so štandardnými postupmi prevencie nehôd. Inštalátor by mal byť oboznámený so sieťovými štruktúrami, pojmami a konceptmi.
- Používajte iba napájací zdroj a príslušenstvo schválené výrobcom, ktoré nájdete v pôvodnom obale tohto produktu.
- Toto zariadenie musí inštalovať školený a kvalifikovaný personál podľa týchto pokynov na inštaláciu. Inštalatér je zodpovedný za zabezpečenie toho, aby inštalácia zariadenia bola v súlade s miestnymi a národnými elektrickými predpismi. Nepokúšajte sa zariadenie rozoberať, opravovať alebo upravovať.
- Tento výrobok je možné používať v interiéroch aj exteriéroch. Pred začatím inštalácie si pozorne prečítajte montážne pokyny. Ak nepoužijete správny hardvér a konfiguráciu alebo nedodržíte správne postupy, môže to viesť k nebezpečnej situácii pre ľudí a poškodeniu systému.
- Dôrazne odporúčame používať AC/DC napájací zdroj len pre vnútorné použitie.
- Zásuvka musí byť inštalovaná v blízkosti zariadenia a musí byť ľahko dostupná.
- Nemôžeme zaručiť, že v dôsledku nesprávneho použitia zariadenia nedôjde k žiadnym nehodám alebo škodám. Tento výrobok používajte opatrne a pracujte na svoje vlastné riziko!
- V prípade poruchy zariadenia ho prosím odpojte od napájania. Najrýchlejším spôsobom je odpojenie sieťového adaptéra zo sieťovej zásuvky. Výrobca: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
SL - Slovenščina. Hitri vodnik
To napravo je treba nadgraditi na izdajo SwOS v2.18, da se zagotovi skladnost s predpisi lokalnih oblasti! Končni uporabniki so odgovorni za sledenje lokalnim predpisom. Vse naprave MikroTik morajo biti profesionalno nameščene.
Ta hitri vodnik zajema model: FTC21.
To je omrežna naprava. Ime modela izdelka najdete na nalepki (ID). |
Prvi koraki:
- Odvijte osrednjo vijak in odstranite plastični pokrov;
- Poiščite Ethernet in SFP porte;
- Nastavite IP za PC na 192.168.88.2/24;
- Povežite napravo in jo vklopite: Uporabite PoE-in (802.3af/at 24-57 V): Povežite napravo z vključenim PoE injektorjem preko Ethernet kabla za podatke in napajanje;
- Povežite konec podatkovnega kabla PoE injektorja s računalnikom;
- Priključite napajalnik na PoE injektor;
- Uporabite DC Jack (24-57 V): Uporabite priložen napajalnik za napajanje naprave preko DC jack;
- Odprite https://192.168.88.1 v svojem brskalniku. Uporabite "admin" kot uporabniško ime (privzeto brez gesla);
- Prenesite najnovejšo različico SwOS Lite z mikrotik.com/download. Naložite jo v zavihek Upgrade in pustite napravi, da se ponovno zažene;
- Nastavite geslo za zaščito naprave;
- Če je potrebno, lahko napravo namestite na drog ali steno;
- Vijaki z vložki so vključeni v paket.
Varnostne informacije:
- Pred delom na kateri koli opremi MikroTik bodite pozorni na nevarnosti, povezane z električnim vezjem, in se seznanite s standardnimi praksami za preprečevanje nesreč. Namestitveni program mora biti seznanjen z omrežnimi strukturami, izrazi in koncepti.
- Uporabljajte samo napajalnik in dodatke, ki jih je odobril proizvajalec in ki jih najdete v originalni embalaži tega izdelka.
- To opremo mora vgraditi usposobljeno in usposobljeno osebje v skladu s temi navodili za namestitev. Monter je odgovoren za to, da je namestitev opreme skladna z lokalnimi in državnimi električnimi kodeksi. Naprave ne poskušajte razstaviti, popraviti ali spremeniti.
- Ta izdelek lahko uporabljate tako v zaprtih prostorih kot na prostem. Pred začetkom namestitve natančno preberite navodila za montažo. Če ne uporabite pravilne strojne opreme in konfiguracije ali ne upoštevate pravilnih postopkov, lahko pride do nevarnih razmer za ljudi in poškodbe sistema.
- Močno priporočamo, da napajalnik AC/DC uporabljate le za uporabo v zaprtih prostorih.
- Vtičnica mora biti nameščena v bližini opreme in mora biti lahko dostopna.
- Ne moremo zagotoviti, da se zaradi nepravilne uporabe naprave ne bo zgodilo nobena nesreča ali škoda. Uporabljajte ta izdelek previdno in delujte na lastno odgovornost!
- V primeru okvare naprave jo izklopite iz napajanja. Najhitreje to storite tako, da napajalnik odklopite iz vtičnice. Proizvajalec: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
SV - Svenska. Snabb guide
Den här enheten måste uppgraderas till SwOS v2.18-versionen för att säkerställa efterlevnad av lokala myndigheters föreskrifter! Det är slutanvändarnas ansvar att följa lokala landsregler. Alla MikroTik-enheter måste vara professionellt installerade.
Detta dokument täcker modellen: FTC21.
Det här är nätverksenhet. Du hittar produktmodellnamnet på etiketten (ID). |
Første steg:
- Skruva loss den centrala skruven och ta bort plastlocket;
- Lokalisera Ethernet- och SFP-portarna;
- Ställ in IP för PC till 192.168.88.2/24;
- Anslut enheten och slå på den: Använd PoE-in (802.3af/at 24-57 V): Anslut enheten till den medföljande PoE-injektorn via en Ethernet-kabel för data och ström;
- Anslut datakabeln från PoE-injektorn till datorn;
- Anslut strömadaptern till PoE-injektorn;
- Använd DC Jack (24-57 V): Använd den medföljande strömadaptern för att strömförsörja enheten via DC jack;
- Öppna https://192.168.88.1 i din webbläsare. Använd "admin" som användarnamn (utan lösenord som standard);
- Ladda ner den senaste versionen av SwOS Lite från mikrotik.com/download. Ladda upp den i fliken Upgrade och låt enheten starta om;
- Ställ in ett lösenord för att säkra enheten;
- Vid behov kan enheten monteras på en stolpe eller vägg;
- Skruvar med pluggar ingår i paketet.
Säkerhetsinformation:
- Innan du arbetar med någon MikroTik-utrustning ska du vara medveten om farorna med elektriska kretsar och känna till vanliga metoder för att förebygga olyckor. Installatören bör känna till nätverksstrukturer, termer och koncept.
- Använd endast den strömförsörjning och tillbehör som godkänts av tillverkaren och som finns i originalförpackningen för denna produkt.
- Denna utrustning ska installeras av utbildad och kvalificerad personal enligt dessa installationsinstruktioner. Installatören ansvarar för att installationen av utrustningen överensstämmer med lokala och nationella elektriska koder. Försök inte ta isär, reparera eller modifiera enheten.
- Denna produkt kan användas både inomhus och utomhus. Läs monteringsanvisningarna noga innan installationen påbörjas. Underlåtenhet att använda rätt maskinvara och konfiguration eller att följa rätt procedurer kan leda till en farlig situation för människor och skador på systemet.
- Vi rekommenderar starkt att endast använda AC/DC-strömförsörjning för inomhusbruk.
- Uttaget ska installeras nära utrustningen och ska vara lättillgängligt.
- Vi kan inte garantera att inga olyckor eller skador kommer att inträffa på grund av felaktig användning av enheten. Använd denna produkt med försiktighet och använd den på egen risk!
- Vid fel på enheten, koppla bort den från strömmen. Det snabbaste sättet är att koppla ur nätadaptern från eluttaget. Tillverkare: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
PRC - 中文. 快速指南
此设备需要升级到 SwOS v2.18 版本以确保符合当地政府法规! 最终用户有责任遵守当地的法规。所有MikroTik设备都必须经过专业安装。
本快速指南介绍了以下型号:FTC21.
这是网络设备。 您可以在包装箱标签(ID)上找到产品型号名称。 |
第一步:
- 拧开中央螺丝并移除塑料盖;
- 定位以太网端口和SFP端口;
- 将计算机的IP设置为192.168.88.2/24;
- 连接设备并开启:使用PoE-in(802.3af/at 24-57 V):将设备通过以太网线连接到提供的PoE注入器(数据和电力);
- 将PoE注入器的数据端连接到计算机;
- 将电源适配器连接到PoE注入器;
- 使用DC Jack(24-57 V):使用提供的电源适配器通过DC Jack为设备供电;
- 在浏览器中打开 https://192.168.88.1。使用 "admin" 作为用户名(默认无密码);
- 从 mikrotik.com/download 下载最新的SwOS Lite。通过升级选项上传文件,并让设备重启;
- 设置密码以保护设备;
- 如有需要,设备可安装在柱子或墙壁上;
- 包装中包括螺钉和膨胀螺栓。
安全信息:
- 在使用任何MikroTik设备之前,请注意电路所涉及的危险,并熟悉防止事故的标准做法。 安装程序应熟悉网络结构,术语和概念。
- 仅使用制造商认可的电源和附件,这些电源和附件可在该产品的原始包装中找到。
- 根据这些安装说明,应由经过培训的合格人员来安装本设备。 安装程序负责确保设备的安装符合当地和国家的电气法规。 请勿尝试拆卸,修理或改装设备。
- 本产品可在室内和室外使用。 请在开始安装前仔细阅读安装说明。 不使用正确的硬件和配置或不遵循正确的程序可能会导致人员危险和系统损坏。
- 我们强烈建议仅将 AC/DC 电源用于室内用例。
- 插座应安装在设备附近且易于插拔的位置。
- 由于设备使用不当,我们不能保证不会发生任何事故或损坏。 请谨慎使用本产品,风险自负!
- 如果设备发生故障,请断开电源。 最快的方法是从电源插座上拔下电源适配器。 制造商:Mikrotikls SIA,拉脱维亚Unijas iela 2, Riga,LV1039。
RU - Русский. Краткое пособие. Евразийский экономический союз информация
Это устройство необходимо обновить до версии SwOS v2.18, чтобы обеспечить соответствие требованиям местных властей! Конечные пользователи обязаны соблюдать местные правила страны. Все устройства MikroTik должны быть профессионально установлены.
Это краткое руководство охватывает модели: FTC21.
Это сетевое устройство. Вы можете найти название модели продукта на ярлыке кейса (ID). |
Первые шаги:
- Открутите центральный винт и снимите пластиковую крышку;
- Найдите порты Ethernet и SFP;
- Установите IP для ПК: 192.168.88.2/24;
- Подключите устройство и включите его: Используя PoE-in (802.3af/at 24-57 V): Подключите устройство к поставляемому PoE инжектору с помощью Ethernet кабеля для передачи данных и питания;
- Подключите данные PoE инжектора к компьютеру;
- Подключите адаптер питания к PoE инжектору;
- Используя DC Jack (24-57 V): Используйте поставляемый адаптер питания для питания устройства через DC jack;
- Откройте https://192.168.88.1 в браузере. Используйте "admin" в качестве имени пользователя (по умолчанию без пароля);
- Скачайте последнюю версию SwOS Lite с mikrotik.com/download. Загрузите её во вкладке Upgrade и дайте устройству перезагрузиться;
- Установите пароль для защиты устройства;
- Если необходимо, устройство можно установить на столб или на стену;
- В комплект входят винты с дюбелями.
Информация по технике безопасности:
- Перед началом работы на любом оборудовании MikroTik ознакомьтесь с опасностями, связанными с электрическими цепями, и ознакомьтесь со стандартными методами предотвращения несчастных случаев. Установщик должен быть знаком с сетевыми структурами, терминами и концепциями.
- Используйте только те источники питания и аксессуары, которые утверждены производителем и находятся в оригинальной упаковке этого продукта.
- Это оборудование должно быть установлено обученным и квалифицированным персоналом согласно этим инструкциям по установке. Установщик несет ответственность за то, чтобы установка оборудования соответствовала местным и национальным электротехническим нормам и правилам. Не пытайтесь разбирать, ремонтировать или модифицировать устройство.
- Этот продукт можно использовать как в помещении, так и на открытом воздухе. Перед началом установки внимательно прочтите инструкции по монтажу. Неспособность использовать правильное оборудование и конфигурацию или следовать правильным процедурам может привести к опасной ситуации для людей и повреждению системы.
- Мы настоятельно рекомендуем использовать источник питания AC/DC тока только для использования внутри помещений.
- Розетка должна быть установлена рядом с оборудованием и должна быть легко доступна.
- Мы не можем гарантировать, что в результате неправильного использования устройства не произойдет несчастных случаев или повреждений. Пожалуйста, используйте этот продукт с осторожностью и действуйте на свой страх и риск!
- В случае сбоя устройства отключите его от питания. Самый быстрый способ сделать это - отсоединить адаптер питания от электрической розетки.
Запрещается:
- Эксплуатация роутера (точки доступа) и её комплектующих с повреждёнными шнурами электропитания;
- Подключение роутера (точки доступа) и её комплектующих к сети электропитания при открытых корпусах;
- Открыватькорпус изделия, разбирать, извлекать электронные модули и проводить какие-либо ремонтные работы вне условий ремонтной организации.
Техническое обслуживание:
- Роутер (точка доступа) не требует проведения профилактических работ и постоянного присутствия эксплуатационного персонала.
- Чистка корпуса от пыли и загрязнений выполняется бумажными безворсовыми салфетками.
- Не брызгайте водой в щели и контакты корпуса изделия.
- Плохо выводящиеся следы и пятна удаляйте изопропиловым спиртом.
Текущий ремонт:
- Все виды ремонта изделия допускается выполнять только аттестованным персоналом в сервисном центре предприятия-изготовителя или в другой уполномоченной изготовителем организации.
- Замена вышедших из строя технических средств (ТС) изделия должна осуществляться на соответствующие ТС, прошедшие специальные исследования и специальную проверку.
Хранение:
- Изделия, упакованные в ящик, следует хранить в складских помещениях при относительная влажность воздуха не более 85%, наличие в воздухе паров кислот, щелочей и прочих агрессивных примесей не допускается.
Транспортирование:
- Транспортируют изделия всеми видами транспорта в крытых транспортных средствах в соответствии с правилами перевозки грузов, действующих на данном виде транспорта.
- Транспортирование и хранение должны осуществляться в упаковке фирмы-изготовителя с соблюдением указаний по ориентации, защите, укладке и других, нанесенных на упаковку указаний обозначений.
- В помещениях и транспортных средствах не должно быть паров или аэрозолей агрессивных или вызывающих коррозию веществ.
- Упакованные изделия должны быть закреплены для предотвращения случайных неконтролируемых перемещений.
- Транспортирование, хранение и эксплуатация не допустимы в условиях конденсации влаги без защиты от атмосферных осадков и прямых солнечных лучей.
Гарантийные обязательства:
- Гарантийный срок эксплуатации − не более 14 суток со дня реализации потребителю.
- Гарантийный срок хранения изделий − 12 месяцев со дня изготовления.
- Некачественные изделия продавец обязан заменить в сроки, согласованные с потребителем.
- В случае спора о причинах возникновения недостатков товара продавец (изготовитель), уполномоченная организация или уполномоченный индивидуальный предприниматель, импортер обязаны провести экспертизу товара за свой счет.
- Срок устранения недостатков товара не может превышать сорок пять дней.
- Действие гарантийных обязательств прекращается: - при нарушении потребителем правил эксплуатации, транспортирования и хранения;- при обнаружении механических повреждений, следов вскрытия, попыток неквалифицированного ремонта;- при обнаружении признаков небрежного обращения, преднамеренного повреждения оборудования;- при попадании внутрь оборудования посторонних предметов, жидкостей и насекомых;- при обнаружении признаков воздействия непреодолимых сил, приведших к выходу из строя роутера (точки доступа).
Утилизация:
- Во избежание загрязнения окружающей среды необходимо отделить устройство от бытовых отходов и утилизировать его безопасным способом, например в специально отведенных местах. Ознакомьтесь с процедурами надлежащей транспортировки оборудования к специальным местам утилизации в вашем регионе. Информация о дате изготовления устройства указана в конце серийного номера на его наклейке через дробь. Первая цифра означает номер года (последняя цифра года), две последующие означают номер недели.
Изготовитель: SIA Mikrotikls, Aizkraukles iela 23, Riga, LV-1006, Латвия, support@mikrotik.com. Сделано в Китае, Латвии или Литве. Cм. на упаковке.
Продукты MikroTik, которые поставляются в Евразийский таможенный союз, оцениваются с учетом соответствующих требований и помечены знаком EAC, как показано ниже:
UA - Українська. Короткий посібник
Цей пристрій потрібно оновити до випуску SwOS v2.18, щоб забезпечити відповідність нормам місцевої влади! Кінцеві користувачі несуть відповідальність за дотримання місцевих правил. Всі пристрої MikroTik повинні бути встановлені відповідно до інструкцій.
Цей короткий посібник стосується моделей: FTC21.
Це мережевий пристрій. Ви можете знайти назву моделі продукту на етикетці корпусу (ID). |
Перші кроки:
- Відкрутіть центральний гвинт і зніміть пластикову кришку;
- Знайдіть порти Ethernet і SFP;
- Встановіть IP для ПК на 192.168.88.2/24;
- Підключіть пристрій і увімкніть його: Використовуючи PoE-in (802.3af/at 24-57 V): Підключіть пристрій до наданого PoE інжектора через Ethernet кабель для передачі даних та живлення;
- Підключіть кінець PoE інжектора до комп'ютера;
- Підключіть адаптер живлення до PoE інжектора;
- Використовуючи DC Jack (24-57 V): Використовуйте наданий адаптер живлення для підключення до DC jack;
- Відкрийте https://192.168.88.1 у веб-браузері. Використовуйте "admin" як ім'я користувача (без пароля за замовчуванням);
- Завантажте останню версію SwOS Lite з mikrotik.com/download. Завантажте її у вкладку Upgrade та дозвольте пристрою перезавантажитись;
- Встановіть пароль для захисту пристрою;
- Якщо потрібно, пристрій можна встановити на стовп або стіну;
- В упаковці є гвинти з дюбелями.
Інформація про безпеку:
- Перш ніж працювати з будь-яким обладнанням MikroTik, усвідомте небезпеку, пов’язану з електричними схемами, і ознайомтеся зі стандартними методами запобігання нещасним випадкам. Особа, що виконує роботи зі встановлення устаткування мусить бути ознайомлена із правилами роботи з мережевими системами, термінами та концепціями.
- Використовуйте тільки адаптер електроживлення та аксесуари, затверджені виробником, і які можна знайти в оригінальній упаковці цього виробу.
- Це обладнання має встановлювати навчений та кваліфікований персонал відповідно до цих інструкцій зі встановлення. Особа, що виконує роботи зі встановлення устаткування несе відповідальність за те, щоб встановлення обладнання відповідало місцевим і національним електричним нормам. Не намагайтеся розібрати, відремонтувати чи модифікувати пристрій.
- Цей продукт можна використовувати як у приміщенні, так і на відкритому повітрі. Будь ласка, уважно прочитайте інструкції з монтажу перед початком установки. Невикористання належного обладнання та конфігурації або дотримання правильних процедур може призвести до небезпечної ситуації для людей та пошкодження системи.
- Ми наполегливо рекомендуємо використовувати джерело живлення AC/DC струму лише для використання в приміщенні.
- Розетка має бути встановлена поблизу обладнання та бути легко доступною.
- Ми не можемо гарантувати відсутність нещасних випадків або пошкоджень через неправильне використання пристрою. Використовуйте цей продукт обережно та на свій страх і ризик!
- У разі несправності пристрою відключіть його від електроживлення. Найшвидший спосіб це зробити — від’єднати адаптер електроживлення від розетки. Виробник: Mikrotikls SIA, Unijas iela 2, Рига, Латвія, LV1039.
Federal Communication Commission Interference Statement
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation.
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
- Reorient or relocate the receiving antenna.
- Increase the separation between the equipment and receiver.
- Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
- Consult the dealer or an experienced radio/TV technician for help. FCC Caution: Any changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Note: This unit was tested with shielded cables on the peripheral devices. Shielded cables must be used with the unit to ensure compliance.
Innovation, Science, and Economic Development Canada
This device contains license-exempt transmitter(s)/receiver(s) that comply with Innovation, Science, and Economic Development Canada’s license-exempt RSS(s). Operation is subject to the following two conditions: (1) This device may not cause interference. (2) This device must accept any interference, including interference that may cause undesired operation of the device.
L’émetteur/récepteur exempt de licence contenu dans le présent appareil est conforme aux CNR d’Innovation, Sciences et Développement économique Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisée aux deux conditions suivantes: 1) L’appareil ne doit pas produire de brouillage; 2) L’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
This Class B digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe [B] est conforme à la norme NMB-003 du Canada.
CAN ICES-003 (B) / NMB-003 (B)
UKCA marking
| (EN) Technical Specifications / (DE) Technische Spezifikationen / (FR) Spécifications techniques / (IT) Specifiche tecniche / (ES) Especificaciones técnicas / (RU) Технические характеристики: | ||||
| (EN) Product Power Input Options (DE) Produkt Stromquellen Optionen (FR) Options d'entrée d'alimentation du produit (IT) Opzioni di ingresso alimentazione del prodotto (ES) Opciones de entrada de energía del producto (RU) Параметры входной мощности продукта | (EN) DC Adapter Output Specification (DE) Ausgangsspezifikationen des Gleichstromadapters (FR) Spécifications de sortie de l'adaptateur de courant continu (IT) Specifiche di uscita dell'adattatore di corrente continua (ES) Especificaciones de salida del adaptador de corriente continua (RU) Выходные характеристики адаптера постоянного тока | (EN) IP class of the enclosure (DE) IP-Klasse des Gehäuses (FR) Classe IP du boîtier (IT) Classe IP della custodia (ES) Clase de IP del recinto (RU) Класс защиты корпуса IP | (EN) Operating Temperature (DE) Betriebstemperatur (FR) température de fonctionnement (IT) temperatura di esercizio (ES) Temperatura de funcionamiento (RU) Рабочая Температура | |
| Voltage, V | Current, A | |||
| DC Jack (24-57 V DC) PoE In Ethernet (24-57 V DC) | 48 | 0.95 | IP55 | -33°..+60°C |
#76959
