Skip to main content
Quick Guide - FTC11XG
This guide can be downloaded as a PDF file.
EN - English - Quick Guide​
warning
This device needs to be upgraded to SwOS v2.18 release to ensure compliance with local authority regulations! It is the end users' responsibility to follow local country regulations. All MikroTik devices must be professionally installed.
This Quick Guide covers the model: FTC11XG.
This is a network device. You can find the product model name on the case label (ID).
Please visit the user manual page on https://mt.lv/um for the full up-to-date user manual. Or scan the QR code with your mobile phone.
The most important technical specifications for this product can be found on the last page of this Quick Guide.
Technical specifications, brochures, and more info about products at https://mikrotik.com/products
Configuration manual for software in your language with additional information can be found at https://mt.lv/help
MikroTik devices are for professional use. If you do not have qualifications please seek a consultant https://mikrotik.com/consultants
First steps:
  • Use a screwdriver to unscrew the central screw and remove the plastic cover;
  • Under the cover there are Ethernet and SFP output ports;
  • Connect to your devices;
  • Connect the device to the power source, the power adapter is not included in the package;
  • Open https://192.168.88.1 in your web browser to start configuration, user name: admin and there is no password by default;
  • If needed, the device can be mounted on the wall;
  • The screws with dowels are included in the package.
Safety Information:
  • Before you work on any MikroTik equipment, be aware of the hazards involved with electrical circuitry, and be familiar with standard practices for preventing accidents. The installer should be familiar with network structures, terms, and concepts.
  • Use only accessories approved by the manufacturer, and which can be found in the original packaging of this product.
  • This equipment is to be installed by trained and qualified personnel, as per these installation instructions. The installer is responsible for making sure, that the installation of the equipment is compliant with local and national electrical codes. Do not attempt to disassemble, repair, or modify the device.
  • This product can be used both indoors and outdoors. Please read the mounting instructions carefully before beginning installation. Failure to use the correct hardware and configuration or to follow the correct procedures could result in a hazardous situation for people and damage to the system.
  • We highly recommend to use AC/DC power supply only for indoor use cases.
  • The socket-outlet shall be installed near the equipment and shall be easily accessible.
  • We cannot guarantee that no accidents or damage will occur due to the improper use of the device. Please use this product with care and operate at your own risk!
  • In the case of device failure, please disconnect it from power. The fastest way to do so is by unplugging the power adapter from the power outlet. Manufacturer: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
BG - Български. Бързо ръководство​
warning
Това устройство трябва да бъде надстроено до версията на SwOS v2.18, за да се осигури съответствие с разпоредбите на местните власти! Отговорност на крайните потребители е да спазват местните разпоредби в страната. Всички устройства MikroTik трябва да бъдат професионално инсталирани.
Този документ обхваща модела: FTC11XG.
Това е мрежово устройство. Можете да намерите името на модела на продукта на етикета на регистъра (ID).
Моля, посетете страницата с ръководството за потребителя на https://mt.lv/um-bg за пълното актуализирано ръководство за употреба. Или сканирайте QR кода с мобилния си телефон.
Най-важните технически спецификации за този продукт могат да бъдат намерени на последната страница на това Кратко ръководство.
Технически спецификации, брошури и повече информация за продуктите на https://mikrotik.com/products
Ръководство за конфигуриране на софтуер на вашия език с допълнителна информация можете да намерите на https://mt.lv/help-bg
Устройствата MikroTik са за професионална употреба. Ако нямате квалификация, моля, потърсете консултант https://mikrotik.com/consultants
Първи стъпки:
  • Използвайте отвертка, за да развиете централния винт и да премахнете пластмасовия капак;
  • Под капака има изходни портове Ethernet и SFP;
  • Свържете се с вашите устройства;
  • Свържете устройството към източника на захранване, захранващият адаптер не е включен в пакета;
  • Отворете https://192.168.88.1 във вашия уеб браузър, за да стартирате конфигурация, потребителско име: admin и по подразбиране няма парола;
  • Ако е необходимо, устройството може да бъде монтирано на стената;
  • Винтовете с дюбели са включени в пакета.
Информация за безопасност:
  • Преди да работите с което и да е оборудване на MikroTik, имайте предвид опасностите, свързани с електрическата верига, и се запознайте със стандартните практики за предотвратяване на злополуки. Инсталаторът трябва да е запознат с мрежовите структури, термини и понятия.
  • Използвайте само захранването и аксесоарите, одобрени от производителя, и които можете да намерите в оригиналната опаковка на този продукт.
  • Това оборудване трябва да се монтира от обучен и квалифициран персонал съгласно тези инструкции за монтаж. Инсталаторът отговаря за това, че инсталирането на оборудването е в съответствие с местните и националните електрически кодове. Не се опитвайте да разглобявате, ремонтирате или модифицирате устройството.
  • Този продукт може да се използва както на закрито, така и на открито. Моля, прочетете внимателно инструкциите за монтаж, преди да започнете инсталацията. Неизползването на правилния хардуер и конфигурация или спазването на правилните процедури може да доведе до опасна ситуация за хората и повреда на системата.
  • Силно препоръчваме да използвате AC/DC захранване само за случаи на употреба на закрито.
  • Контактът трябва да бъде монтиран близо до оборудването и да бъде лесно достъпен.
  • Не можем да гарантираме, че няма злополуки или повреди поради неправилна употреба на устройството. Моля, използвайте внимателно този продукт и работете на свой риск!
  • В случай на повреда на устройството, моля, изключете го от захранването. Най-бързият начин да направите това е чрез изключване на захранващия адаптер от контакта. Производител: Mikrotikls SIA, Unijas iela 2, Рига, Латвия, LV1039.
CS - Česko. Rychlý průvodce​
warning
Toto zařízení je třeba upgradovat na verzi SwOS v2.18, aby bylo zajištěno dodržování předpisů místních úřadů! Je odpovědností koncových uživatelů dodržovat místní předpisy dané země. Všechna zařízení MikroTik musí být odborně nainstalována.
Tento Stručný průvodce se týká modelu: FTC11XG.
Toto je síťové zařízení. Název modelu produktu najdete na štítku případu (ID).
Úplnou aktuální uživatelskou příručku naleznete na stránce uživatelské příručky na adrese https://mt.lv/um-cs. Nebo naskenujte QR kód pomocí mobilního telefonu.
Nejdůležitější technické specifikace tohoto produktu najdete na poslední stránce tohoto Stručného průvodce.
Technické specifikace, brožury a další informace o produktech na adrese https://mikrotik.com/products
Konfigurační příručku pro software ve vašem jazyce s dalšími informacemi naleznete na adrese https://mt.lv/help-cs
Zařízení MikroTik jsou určena pro profesionální použití. Pokud nemáte kvalifikaci, vyhledejte konzultanta https://mikrotik.com/consultants
První kroky:
  • Pomocí šroubováku odšroubujte střední šroub a sejměte plastový kryt;
  • Pod krytem jsou výstupní porty Ethernet a SFP;
  • Připojte se ke svým zařízením;
  • Připojte zařízení ke zdroji napájení, napájecí adaptér není součástí balení;
  • Otevřete ve svém webovém prohlížeči https://192.168.88.1 a spusťte konfiguraci, uživatelské jméno: admin a ve výchozím nastavení není žádné heslo;
  • V případě potřeby lze zařízení namontovat na zeď;
  • Šrouby s hmoždinkami jsou součástí balení.
Bezpečná informace:
  • Než začnete pracovat na jakémkoli zařízení MikroTik, uvědomte si rizika spojená s elektrickými obvody a seznamte se se standardními postupy pro prevenci nehod. Instalátor by měl být obeznámen se síťovými strukturami, termíny a koncepty.
  • Používejte pouze napájecí zdroj a příslušenství schválené výrobcem, které najdete v originálním balení tohoto produktu.
  • Toto zařízení musí instalovat vyškolený a kvalifikovaný personál podle těchto pokynů k instalaci. Instalátor odpovídá za to, že instalace zařízení je v souladu s místními a národními elektrickými předpisy. Nepokoušejte se zařízení rozebírat, opravovat ani upravovat.
  • Tento produkt lze použít uvnitř i venku. Před zahájením instalace si prosím pečlivě přečtěte montážní pokyny. Pokud nebudete používat správný hardware a konfiguraci nebo nedodržíte správné postupy, může to mít za následek nebezpečnou situaci pro lidi a poškození systému.
  • Důrazně doporučujeme používat AC/DC napájecí zdroj pouze pro vnitřní použití.
  • Zásuvka musí být instalována v blízkosti zařízení a musí být snadno dostupná.
  • Nemůžeme zaručit, že v důsledku nesprávného používání zařízení nedojde k nehodám nebo poškození. Tento produkt používejte opatrně a používejte jej na vlastní nebezpečí!
  • V případě poruchy zařízení jej prosím odpojte od napájení. Nejrychlejším způsobem je odpojení napájecího adaptéru ze zásuvky. Výrobce: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
DA - Dansk. Hurtig guide​
warning
Denne enhed skal opgraderes til SwOS v2.18-udgivelsen for at sikre overholdelse af lokale myndigheders regler! Det er slutbrugernes ansvar at følge lokale landebestemmelser. Alle MikroTik-enheder skal være professionelt installeret.
Dette dokument dækker modellen: FTC11XG.
Dette er netværksenhed. Du kan finde produktmodelnavnet på sagetiketten (ID).
Besøg siden med brugermanualen på https://mt.lv/um-da for den fulde ajourførte brugermanual. Eller skan QR-koden med din mobiltelefon.
De vigtigste tekniske specifikationer for dette produkt findes på den sidste side i denne hurtigvejledning.
Tekniske specifikationer, brochurer og mere info om produkter på https://mikrotik.com/products
Konfigurationsvejledning til software på dit sprog med yderligere oplysninger kan findes på https://mt.lv/help-da
MikroTik-enheder er til professionel brug. Hvis du ikke har kvalifikationer, bedes du kontakte en konsulent https://mikrotik.com/consultants
Første trin:
  • Brug en skruetrækker til at skrue ud den midterste skrue og fjerne plastikdækslet;
  • Under dækslet er der Ethernet- og SFP-outputporte;
  • Opret forbindelse til dine enheder;
  • Tilslut enheden til strømkilden, strømforsyningen er ikke inkluderet i pakken;
  • Åbn https://192.168.88.1 i din webbrowser for at starte konfiguration, brugernavn: admin, og der er som standard ingen adgangskode;
  • Om nødvendigt kan enheden monteres på væggen;
  • Skruerne med dybler er inkluderet i pakken.
Sikkerhedsoplysninger:
  • Inden du arbejder med MikroTik-udstyr, skal du være opmærksom på farerne i forbindelse med elektriske kredsløb og kende almindelig praksis til forebyggelse af ulykker. Installationsprogrammet skal være bekendt med netværksstrukturer, vilkår og koncepter.
  • Brug kun strømforsyningen og det tilbehør, der er godkendt af producenten, og som findes i den originale emballage til dette produkt.
  • Dette udstyr skal installeres af uddannet og kvalificeret personale i henhold til disse installationsinstruktioner. Installatøren er ansvarlig for at sikre, at installationen af ​​udstyret er i overensstemmelse med lokale og nationale elektriske koder. Forsøg ikke at adskille, reparere eller ændre enheden.
  • Dette produkt kan bruges både indendørs og udendørs. Læs monteringsvejledningen grundigt inden installationen påbegyndes. Manglende brug af den korrekte hardware og konfiguration eller de korrekte procedurer kan resultere i en farlig situation for mennesker og skader på systemet.
  • Vi anbefaler stærkt kun at bruge AC/DC strømforsyning til indendørs brug.
  • Stikkontakten skal installeres i nærheden af udstyret og skal være let tilgængelig.
  • Vi kan ikke garantere, at der ikke vil ske ulykker eller skader på grund af forkert brug af enheden. Brug dette produkt med omhu og betjen det på egen risiko!
  • I tilfælde af fejl på enheden skal du frakoble det fra strømmen. Den hurtigste måde at gøre det er ved at tage stikket ud af stikkontakten. Producent: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
DE - Deutsche. Kurzanleitung​
warning
Dieses Gerät muss auf die Version SwOS v2.18 aktualisiert werden, um die Einhaltung der örtlichen behördlichen Vorschriften sicherzustellen! Es liegt in der Verantwortung des Endbenutzers, die örtlichen Landesvorschriften einzuhalten. Alle MikroTik-Geräte müssen professionell installiert werden.
Diese Kurzanleitung behandelt das Modell: FTC11XG.
Dies ist das Netzwerkgerät. Den Produktmodellnamen finden Sie auf dem Gehäuseaufkleber (ID).
Bitte besuchen Sie die Seite mit dem Benutzerhandbuch unter https://mt.lv/um-de, um das vollständige und aktuelle Benutzerhandbuch zu erhalten. Oder scannen Sie den QR-Code mit Ihrem Handy.
Die wichtigsten technischen Daten für dieses Produkt finden Sie auf der letzten Seite dieser Kurzanleitung.
Technische Spezifikationen, Broschüren und weitere Informationen zu Produkten finden Sie unter https://mikrotik.com/products
Das Konfigurationshandbuch für Software in Ihrer Sprache mit zusätzlichen Informationen finden Sie unter https://mt.lv/help-de
MikroTik-Geräte sind für den professionellen Einsatz bestimmt. Wenn Sie keine Qualifikationen haben, suchen Sie bitte einen Berater https://mikrotik.com/consultants
Erste Schritte:
  • Lösen Sie die Zentralschraube mit einem Schraubendreher und entfernen Sie die Kunststoffabdeckung;
  • Unter der Abdeckung befinden sich Ethernet- und SFP-Ausgangsanschlüsse;
  • Stellen Sie eine Verbindung zu Ihren Geräten her;
  • Schließen Sie das Gerät an die Stromquelle an. Das Netzteil ist nicht im Lieferumfang enthalten;
  • Öffnen Sie https://192.168.88.1 in Ihrem Webbrowser, um die Konfiguration zu starten. Benutzername: admin und standardmäßig ist kein Kennwort vorhanden;
  • Bei Bedarf kann das Gerät an der Wand montiert werden;
  • Die Schrauben mit Dübeln sind im Lieferumfang enthalten.
Sicherheitsinformation:
  • Bevor Sie an MikroTik-Geräten arbeiten, sollten Sie sich der Gefahren bewusst sein, die mit elektrischen Schaltkreisen verbunden sind, und sich mit den Standardverfahren zur Verhinderung von Unfällen vertraut machen. Das Installationsprogramm sollte mit Netzwerkstrukturen, Begriffen und Konzepten vertraut sein.
  • Verwenden Sie nur das vom Hersteller zugelassene Netzteil und Zubehör, das in der Originalverpackung dieses Produkts enthalten ist.
  • Dieses Gerät muss von geschultem und qualifiziertem Personal gemäß diesen Installationsanweisungen installiert werden. Der Installateur ist dafür verantwortlich, dass die Installation des Geräts den örtlichen und nationalen elektrischen Vorschriften entspricht. Versuchen Sie nicht, das Gerät zu zerlegen, zu reparieren oder zu modifizieren.
  • Dieses Produkt kann sowohl im Innen- als auch im Außenbereich verwendet werden. Bitte lesen Sie die Montageanleitung sorgfältig durch, bevor Sie mit der Installation beginnen. Wenn Sie die richtige Hardware und Konfiguration nicht verwenden oder die korrekten Verfahren nicht befolgen, kann dies zu einer Gefahrensituation für Personen und Schäden am System führen.
  • Wir empfehlen dringend, die AC/DC-Stromversorgung nur für Anwendungsfälle in Innenräumen zu verwenden.
  • Die Steckdose muss in der Nähe des Geräts installiert und leicht zugänglich sein.
  • Wir können nicht garantieren, dass durch unsachgemäße Verwendung des Geräts keine Unfälle oder Schäden auftreten. Bitte verwenden Sie dieses Produkt mit Vorsicht und arbeiten Sie auf eigenes Risiko!
  • Trennen Sie das Gerät bei einem Stromausfall vom Stromnetz. Der schnellste Weg, dies zu tun, besteht darin, das Netzteil aus der Steckdose zu ziehen. Hersteller: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
EL - Ελληνικά. Γρήγορος οδηγός​
warning
Αυτή η συσκευή πρέπει να αναβαθμιστεί στην έκδοση SwOS v2.18 για να διασφαλιστεί η συμμόρφωση με τους κανονισμούς των τοπικών αρχών! Είναι ευθύνη των τελικών χρηστών να ακολουθούν τους τοπικούς κανονισμούς της χώρας. Όλες οι συσκευές MikroTik πρέπει να εγκατασταθούν επαγγελματικά.
Αυτός ο γρήγορος οδηγός καλύπτει το μοντέλο: FTC11XG.
Αυτή είναι η συσκευή δικτύου. Μπορείτε να βρείτε το όνομα του μοντέλου προϊόντος στην ετικέτα της θήκης (ID).
Επισκεφτείτε τη σελίδα του εγχειριδίου χρήστη στο https://mt.lv/um-el για το πλήρες ενημερωμένο εγχειρίδιο χρήσης. Ή να σαρώσετε τον κωδικό QR με το κινητό σας τηλέφωνο.
Οι πιο σημαντικές τεχνικές προδιαγραφές για αυτό το προϊόν βρίσκονται στην τελευταία σελίδα αυτού του γρήγορου οδηγού.
Τεχνικές προδιαγραφές, φυλλάδια και περισσότερες πληροφορίες για τα προϊόντα στη διεύθυνση https://mikrotik.com/products
Το εγχειρίδιο διαμόρφωσης για λογισμικό στη γλώσσα σας με πρόσθετες πληροφορίες βρίσκεται στη διεύθυνση https://mt.lv/help-el
Οι συσκευές MikroTik προορίζονται για επαγγελματική χρήση. Εάν δεν έχετε τα προσόντα παρακαλώ ζητήστε έναν σύμβουλο https://mikrotik.com/consultants
Πρώτα βήματα:
  • Χρησιμοποιήστε ένα κατσαβίδι για να ξεβιδώσετε την κεντρική βίδα και να αφαιρέσετε το πλαστικό κάλυμμα;
  • Κάτω από το κάλυμμα υπάρχουν θύρες εξόδου Ethernet και SFP;
  • Συνδεθείτε στις συσκευές σας;
  • Συνδέστε τη συσκευή στην πηγή τροφοδοσίας, ο προσαρμογέας ρεύματος δεν περιλαμβάνεται στη συσκευασία;
  • Ανοίξτε το https://192.168.88.1 στο πρόγραμμα περιήγησής σας για να ξεκινήσετε τη διαμόρφωση, όνομα χρήστη: admin και δεν υπάρχει κωδικός πρόσβασης από προεπιλογή;
  • Εάν χρειαστεί, η συσκευή μπορεί να τοποθετηθεί στον τοίχο;
  • Οι βίδες με πείρους περιλαμβάνονται στη συσκευασία.
Οδηγίες ασφαλείας:
  • Πριν να εργαστείτε σε οποιοδήποτε εξοπλισμό MikroTik, να είστε ενήμεροι για τους κινδύνους που σχετίζονται με τα ηλεκτρικά κυκλώματα και να είστε εξοικειωμένοι με τις συνήθεις πρακτικές για την πρόληψη ατυχημάτων. Ο εγκαταστάτης πρέπει να είναι εξοικειωμένος με τις δομές, τους όρους και τις έννοιες του δικτύου.
  • Χρησιμοποιήστε μόνο την τροφοδοσία ρεύματος και τα εξαρτήματα που έχει εγκριθεί από τον κατασκευαστή και τα οποία μπορείτε να βρείτε στην αρχική συσκευασία αυτού του προϊόντος.
  • Αυτός ο εξοπλισμός πρέπει να εγκατασταθεί από εκπαιδευμένο και ειδικευμένο προσωπικό, σύμφωνα με αυτές τις οδηγίες εγκατάστασης. Ο εγκαταστάτης είναι υπεύθυνος για τη διασφάλιση της συμμόρφωσης της εγκατάστασης του εξοπλισμού με τους τοπικούς και εθνικούς ηλεκτρικούς κώδικες. Μην επιχειρήσετε να αποσυναρμολογήσετε, να επιδιορθώσετε ή να τροποποιήσετε τη συσκευή.
  • Αυτό το προϊόν μπορεί να χρησιμοποιηθεί τόσο σε εσωτερικούς όσο και σε εξωτερικούς χώρους. Διαβάστε προσεκτικά τις οδηγίες τοποθέτησης πριν ξεκινήσετε την εγκατάσταση. Η μη χρήση του σωστού υλικού και της διαμόρφωσης ή η τήρηση των σωστών διαδικασιών μπορεί να οδηγήσει σε επικίνδυνη κατάσταση για τους ανθρώπους και ζημιά στο σύστημα.
  • Συνιστούμε ανεπιφύλακτα να χρησιμοποιείτε τροφοδοτικό AC/DC μόνο για θήκες εσωτερικής χρήσης.
  • Η πρίζα πρέπει να είναι εγκατεστημένη κοντά στον εξοπλισμό και να είναι εύκολα προσβάσιμη.
  • Δεν μπορούμε να εγγυηθούμε ότι δεν θα προκύψουν ατυχήματα ή ζημιές εξαιτίας της ακατάλληλης χρήσης της συσκευής. Χρησιμοποιείτε αυτό το προϊόν με προσοχή και λειτουργείτε με δική σας ευθύνη!
  • Σε περίπτωση βλάβης της συσκευής, αποσυνδέστε την από την τροφοδοσία. Ο ταχύτερος τρόπος είναι να αποσυνδέσετε το τροφοδοτικό από την πρίζα. Κατασκευαστής: Mikrotikls SIA, Unijas iela 2, Ρίγα, Λετονία, LV1039.
ES - Español. Guía rápida​
warning
¡Este dispositivo debe actualizarse a la versión SwOS v2.18 para garantizar el cumplimiento de las regulaciones de las autoridades locales! Es responsabilidad de los usuarios finales seguir las regulaciones locales del país. Todos los dispositivos MikroTik deben ser instalados por un profesional.
Esta guía rápida cubre el modelo: FTC11XG.
Este es un dispositivo de red. Puede encontrar el nombre del modelo del producto en la etiqueta del caso (ID).
Visite la página del manual del usuario en https://mt.lv/um-es para obtener el manual del usuario actualizado. O escanee el código QR con su teléfono móvil.
Las especificaciones técnicas más importantes de este producto se pueden encontrar en la última página de esta Guía rápida.
Especificaciones técnicas, folletos y más información sobre productos en https://mikrotik.com/products
Puede encontrar el manual de configuración del software en su idioma con información adicional en https://mt.lv/help-es
Los dispositivos MikroTik son para uso profesional. Si no tiene calificaciones, busque un consultor https://mikrotik.com/consultants
Primeros pasos:
  • Use un destornillador para desenroscar el tornillo central y retire la cubierta de plástico;
  • Debajo de la cubierta hay puertos de salida Ethernet y SFP;
  • Conéctese a sus dispositivos;
  • Conecte el dispositivo a la fuente de alimentación, el adaptador de corriente no está incluido en el paquete;
  • Abra https://192.168.88.1 en su navegador web para iniciar la configuración, nombre de usuario: admin y no hay contraseña por defecto;
  • Si es necesario, el dispositivo se puede montar en la pared;
  • Los tornillos con tacos están incluidos en el paquete.
Información de seguridad:
  • Antes de trabajar en cualquier equipo MikroTik, tenga en cuenta los riesgos relacionados con los circuitos eléctricos y familiarícese con las prácticas estándar para prevenir accidentes. El instalador debe estar familiarizado con las estructuras de red, los términos y los conceptos.
  • Utilice solo la fuente de alimentación y los accesorios aprobados por el fabricante, y que se pueden encontrar en el embalaje original de este producto.
  • Este equipo debe ser instalado por personal capacitado y calificado, según estas instrucciones de instalación. El instalador es responsable de asegurarse de que la instalación del equipo cumpla con los códigos eléctricos locales y nacionales. No intente desmontar, reparar o modificar el dispositivo.
  • Este producto se puede utilizar tanto en interiores como en exteriores. Lea atentamente las instrucciones de montaje antes de comenzar la instalación. No utilizar el hardware y la configuración correctos o no seguir los procedimientos correctos podría resultar en una situación peligrosa para las personas y daños en el sistema.
  • Recomendamos encarecidamente utilizar una fuente de alimentación de CA/CC solo para casos de uso en interiores.
  • El tomacorriente se instalará cerca del equipo y será de fácil acceso.
  • No podemos garantizar que no ocurran accidentes o daños debido al uso incorrecto del dispositivo. ¡Utilice este producto con cuidado y opere bajo su propio riesgo!
  • En caso de falla del dispositivo, desconéctelo de la alimentación. La forma más rápida de hacerlo es desconectando el adaptador de alimentación de la toma de corriente. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
Información México:
La operacion de este equipo esta sujeta a las siguientes dos condiciones:
  • Es posible que este equipo o dispositivo no cause interferencia perjudicial y.
  • Este equipo debe aceptar cualquier interferencia, incluyendo la que pueda causar su operacion no deseada. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, LV-1039, Latvia.
País De Origen: Letonia; Lituania; China (Republica Popular); Estados Unidos De America; Mexico.
Por favor contacte a su distribuidor local para preguntas regionales específicas. La lista de importadores se puede encontrar en nuestra página de inicio – https://mikrotik.com/buy/latinamerica/mexico.
ET - Eestlane. Kiirjuhend​
warning
See seade tuleb üle viia versioonile SwOS v2.18, et tagada vastavus kohalike omavalitsuste eeskirjadele! Lõppkasutajad vastutavad kohalike riigieeskirjade järgimise eest. Kõik MikroTik seadmed peavad olema professionaalselt paigaldatud.
See kiirjuhend hõlmab mudelit: FTC11XG.
See on võrguseade. Toote mudeli nime leiate kohvri sildilt (ID).
Täieliku ja värske kasutusjuhendi saamiseks külastage kasutusjuhendit lehel https://mt.lv/um-et. Või skannige oma mobiiltelefoniga QR-koodi.
Selle toote kõige olulisemad tehnilised andmed leiate selle kiirjuhendi viimaselt lehelt.
Tehnilised kirjeldused, brošüürid ja lisateave toodete kohta leiate aadressilt https://mikrotik.com/products
Teie keeles oleva tarkvara konfiguratsioonijuhend koos lisateabega leiate aadressilt https://mt.lv/help-et
MikroTik seadmed on mõeldud professionaalseks kasutamiseks. Kui teil pole kvalifikatsiooni, pöörduge konsultandi poole https://mikrotik.com/consultants
Esimesed sammud:
  • Kruvige kruvikeerajaga lahti keskkruvi ja eemaldage plastkate;
  • Katte all on Etherneti ja SFP väljundpordid;
  • Ühendage oma seadmetega;
  • Ühendage seade toiteallikaga, toiteadapterit ei ole pakendis;
  • Seadistamise alustamiseks avage veebibrauseris https://192.168.88.1, kasutajanimi: admin ja vaikimisi pole parooli;
  • Vajadusel saab seadme seinale kinnitada;
  • Tüüblitega kruvid sisalduvad pakendis.
Ohutusteave:
  • Enne kui töötate mõne MikroTiku seadmega, tutvuge elektriskeemidega kaasnevate ohtudega ja tutvuge õnnetuste vältimise tavapraktikaga. Installer peaks tundma võrgustruktuure, termineid ja kontseptsioone.
  • Kasutage ainult tootja poolt heaks kiidetud toiteallikat ja tarvikuid, mis on selle toote originaalpakendis.
  • Need seadmed peavad paigaldama väljaõppinud ja kvalifitseeritud töötajad vastavalt käesolevatele paigaldusjuhistele. Paigaldaja vastutab selle eest, et seadmed paigaldataks vastavalt kohalikele ja riiklikele elektriseadustele. Ärge üritage seadet lahti võtta, remontida ega modifitseerida.
  • Seda toodet saab kasutada nii toas kui ka väljas. Enne paigaldamise alustamist lugege hoolikalt paigaldusjuhiseid. Õige riistvara ja konfiguratsiooni kasutamata jätmine või õigete protseduuride järgimata jätmine võib põhjustada inimeste ohtlikku olukorda ja süsteemi kahjustada.
  • Soovitame tungivalt kasutada AC/DC toiteallikat ainult siseruumides kasutamiseks.
  • Pistikupesa paigaldatakse seadme lähedusse ja see peab olema kergesti ligipääsetav.
  • Me ei saa garanteerida, et seadme ebaõige kasutamise tõttu ei juhtu õnnetusi ega kahjustusi. Kasutage seda toodet ettevaatlikult ja tegutsege omal vastutusel!
  • Seadme rikke korral eraldage see vooluvõrgust. Kiireim viis selleks on toiteadapteri pistikupesast lahti ühendamine. Tootja: Mikrotikls SIA, Unijas iela 2, Riia, Läti, LV1039.
FI - Suomalainen. Pikaopas​
warning
Tämä laite on päivitettävä SwOS v2.18 -julkaisuun, jotta varmistetaan paikallisten viranomaisten määräysten mukainen! Loppukäyttäjien vastuulla on noudattaa paikallisia maakohtaisia ​​määräyksiä. Kaikki MikroTik-laitteet on asennettava ammattimaisesti.
Tämä pikaopas kattaa mallin: FTC11XG.
Tämä on verkkolaite. Tuotemallin nimi löytyy kotelon etiketistä (ID).
Katso täydelliset ja ajantasaiset käyttöohjeet sivulta https://mt.lv/um-fi. Tai skannaa QR-koodi matkapuhelimellasi.
Tämän tuotteen tärkeimmät tekniset tiedot ovat tämän pikaoppaan viimeisellä sivulla.
Tekniset tiedot, esitteet ja lisätietoja tuotteista osoitteessa https://mikrotik.com/products
Kielelläsi olevien ohjelmistojen määritysoppaat, joissa on lisätietoja, ovat osoitteessa https://mt.lv/help-fi
MikroTik-laitteet on tarkoitettu ammattikäyttöön. Jos sinulla ei ole pätevyyttä, ota yhteys konsulttiin https://mikrotik.com/consultants
Ensiaskeleet:
  • Kierrä keskusruuvi ruuvitaltalla ja poista muovikansi;
  • Kannen alla on Ethernet- ja SFP-lähtöportit;
  • Yhdistä laitteisiisi;
  • Liitä laite virtalähteeseen, virtalähde ei sisälly pakkaukseen;
  • Aloita määritys avaamalla selaimessasi https://192.168.88.1, käyttäjänimi: admin, eikä salasanaa ole oletusarvoisesti;
  • Laite voidaan tarvittaessa asentaa seinälle;
  • Tangilla varustetut ruuvit sisältyvät pakettiin.
Turvallisuustieto:
  • Ennen kuin työskentelet MikroTik-laitteiden kanssa, ole tietoinen sähköpiiriin liittyvistä vaaroista ja perehdy vakiomuotoisiin käytäntöihin onnettomuuksien estämiseksi. Asentajan tulee tuntea verkkorakenteet, termit ja käsitteet.
  • Käytä vain valmistajan hyväksymää virtalähdettä ja lisävarusteita, jotka löytyvät tämän tuotteen alkuperäispakkauksesta.
  • Tämän laitteen saa asentaa koulutettu ja pätevä henkilöstö näiden asennusohjeiden mukaisesti. Asentajan on varmistettava, että laitteen asennus on paikallisten ja kansallisten sähkömääräysten mukainen. Älä yritä purkaa, korjata tai muokata laitetta.
  • Tätä tuotetta voidaan käyttää sekä sisällä että ulkona. Lue asennusohjeet huolellisesti ennen asennuksen aloittamista. Oikean laitteiston ja kokoonpanon käyttämättä jättäminen tai oikeiden menettelytapojen noudattamatta jättäminen voi aiheuttaa ihmisille vaarallisen tilanteen ja vahingoittaa järjestelmää.
  • Suosittelemme käyttämään AC/DC-virtalähdettä vain sisäkäyttöön.
  • Pistorasia on asennettava laitteen lähelle ja siihen on oltava helposti saatavilla.
  • Emme voi taata, että laitteen väärinkäytöstä ei aiheudu onnettomuuksia tai vaurioita. Käytä tätä tuotetta huolellisesti ja käytä omalla vastuulla!
  • Irrota laite sähkövirrasta, jos laite vioittuu. Nopein tapa tehdä tämä on irrottaa virtalähde pistorasiasta. Valmistaja: Mikrotikls SIA, Unijas iela 2, Riika, Latvia, LV1039.
FR - Français. Guide rapide​
warning
Cet appareil doit être mis à niveau vers la version SwOS v2.18 pour garantir la conformité avec les réglementations des autorités locales! Il est de la responsabilité des utilisateurs finaux de suivre les réglementations locales du pays. Tous les appareils MikroTik doivent être installés par un professionnel.
Ce document couvre le modèle: FTC11XG.
Ceci est un périphérique réseau. Vous pouvez trouver le nom du modèle du produit sur l'étiquette du boîtier (ID).
Veuillez visiter la page du manuel d'utilisation sur https://mt.lv/um-fr pour le manuel d'utilisation complet et à jour. Ou scannez le code QR avec votre téléphone portable.
Les spécifications techniques les plus importantes de ce produit se trouvent sur la dernière page de ce guide rapide.
Spécifications techniques, brochures et plus d'informations sur les produits sur https://mikrotik.com/products
Vous trouverez le manuel de configuration du logiciel dans votre langue avec des informations supplémentaires sur https://mt.lv/help-fr
Les appareils MikroTik sont destinés à un usage professionnel. Si vous n'avez pas de qualifications, veuillez consulter un consultant https://mikrotik.com/consultants
Premiers pas:
  • Utilisez un tournevis pour dévisser la vis centrale et retirer le couvercle en plastique;
  • Sous le couvercle, il y a des ports de sortie Ethernet et SFP;
  • Connectez-vous à vos appareils;
  • Connectez l'appareil à la source d'alimentation, l'adaptateur secteur n'est pas inclus dans l'emballage;
  • Ouvrez https://192.168.88.1 dans votre navigateur Web pour démarrer la configuration, nom d'utilisateur: admin et il n'y a pas de mot de passe par défaut;
  • Si nécessaire, l'appareil peut être monté sur le mur;
  • Les vis avec chevilles sont incluses dans l'emballage.
Information sur la sécurité:
  • Avant de travailler sur un équipement MikroTik, soyez conscient des dangers liés aux circuits électriques et familiarisez-vous avec les pratiques standard de prévention des accidents. Le programme d'installation doit être familiarisé avec les structures, les termes et les concepts du réseau.
  • Utilisez uniquement l'alimentation et les accessoires approuvés par le fabricant et qui se trouvent dans l'emballage d'origine de ce produit.
  • Cet équipement doit être installé par du personnel formé et qualifié, conformément à ces instructions d'installation. L'installateur est responsable de s'assurer que l'installation de l'équipement est conforme aux codes électriques locaux et nationaux. N'essayez pas de démonter, réparer ou modifier l'appareil.
  • Ce produit peut être utilisé aussi bien à l'intérieur qu'à l'extérieur. Veuillez lire attentivement les instructions de montage avant de commencer l'installation. Le fait de ne pas utiliser le matériel et la configuration corrects ou de suivre les procédures correctes peut entraîner une situation dangereuse pour les personnes et endommager le système.
  • Nous vous recommandons fortement d'utiliser l'alimentation AC/DC uniquement pour les cas d'utilisation en intérieur.
  • La prise de courant doit être installée à proximité de l'équipement et doit être facilement accessible.
  • Nous ne pouvons garantir qu'aucun accident ou dommage ne se produira en raison d'une mauvaise utilisation de l'appareil. Veuillez utiliser ce produit avec soin et l'utiliser à vos propres risques!
  • En cas de panne de l'appareil, veuillez le déconnecter de l'alimentation. La façon la plus rapide de le faire est de débrancher l'adaptateur secteur de la prise de courant. Fabricant: Mikrotikls SIA, Unijas iela 2, Riga, Lettonie, LV1039.
HR - Hrvatski. Brzi vodič​
warning
Ovaj uređaj treba nadograditi na izdanje SwOS v2.18 kako bi se osigurala usklađenost s propisima lokalnih vlasti! Odgovornost je krajnjih korisnika da se pridržavaju lokalnih propisa zemlje. Svi MikroTik uređaji moraju biti profesionalno instalirani.
Ovaj brzi vodič pokriva model: FTC11XG.
Ovo je mrežni uređaj. Naziv modela proizvoda možete pronaći na naljepnici kućišta (ID).
Molimo posjetite stranicu s priručnikom na https://mt.lv/um-hr za cjeloviti ažurirani korisnički priručnik. Ili skenirajte QR kod sa svojim mobilnim telefonom.
Najvažnije tehničke specifikacije za ovaj proizvod mogu se naći na posljednjoj stranici ovog Kratkog vodiča.
Tehničke specifikacije, brošure i više informacija o proizvodima na https://mikrotik.com/products
Priručnik o konfiguraciji softvera na vašem jeziku s dodatnim informacijama potražite na https://mt.lv/help-hr
MikroTik uređaji su za profesionalnu upotrebu. Ako nemate kvalifikacije, potražite savjetnika https://mikrotik.com/consultants
Prvi koraci:
  • Odvijte središnji vijak i uklonite plastični poklopac;
  • Ispod poklopca nalaze se izlazni priključci Ethernet i SFP;
  • Povežite se sa svojim uređajima;
  • Spojite uređaj na izvor napajanja, adapter za napajanje nije uključen u paket;
  • Otvorite https://192.168.88.1 u svom web pregledniku da biste započeli konfiguraciju, korisničko ime: admin i prema zadanim postavkama nema lozinke;
  • Ako je potrebno, uređaj se može montirati na zid;
  • Vijci s mozgalicama su uključeni u paket.
Sigurnosne informacije:
  • Prije nego što radite na bilo kojoj MikroTik opremi, budite svjesni opasnosti koje uključuju električni krug i upoznajte se sa standardnim postupcima za sprečavanje nezgoda. Instalacijski program trebao bi biti upoznat s mrežnim strukturama, pojmovima i konceptima.
  • Koristite samo napajanje i pribor odobrene od proizvođača koji se mogu naći u originalnom pakiranju ovog proizvoda.
  • Ovu opremu treba ugraditi obučeno i kvalificirano osoblje prema ovim uputama za ugradnju. Instalater je odgovoran za provjeru da je instalacija opreme u skladu s lokalnim i nacionalnim električnim propisima. Ne pokušavajte rastavljati, popravljati ili modificirati uređaj.
  • Ovaj se proizvod može koristiti i u zatvorenom i na otvorenom. Molimo pažljivo pročitajte upute za montažu prije početka instalacije. Ako ne upotrijebite ispravan hardver i konfiguraciju ili ne slijedite ispravne postupke, moglo bi doći do opasne situacije za ljude i oštećenja sustava.
  • Toplo preporučamo korištenje AC/DC napajanja samo za unutarnje slučajeve.
  • Utičnica mora biti instalirana u blizini opreme i mora biti lako dostupna.
  • Ne možemo jamčiti da neće doći do nezgoda ili oštećenja uslijed nepravilne uporabe uređaja. Molimo koristite ovaj proizvod s pažnjom i radite na vlastiti rizik!
  • U slučaju kvara uređaja, isključite ga iz napajanja. Najbrži način za to je isključivanjem mrežnog adaptera iz utičnice. Proizvođač: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
HU - Magyar. Gyors útmutató​
warning
Ezt az eszközt frissíteni kell a SwOS v2.18 kiadásra, hogy megfeleljen a helyi hatóságok előírásainak! A végfelhasználók felelőssége, hogy betartsák az ország helyi előírásait. Minden MikroTik eszközt szakszerűen kell telepíteni.
Ez a gyors útmutató a modellre vonatkozik: FTC11XG.
Ez hálózati eszköz. A terméktípus nevét a tok címkéjén (ID) találhatja meg.
Kérjük, keresse fel a használati útmutatót a https://mt.lv/um-hu oldalon a teljes, legfrissebb használati útmutatóért. Vagy beolvashatja a QR-kódot mobiltelefonjával.
A termék legfontosabb műszaki specifikációi a Gyors útmutató utolsó oldalán találhatók.
Műszaki leírások, brosúrák és további információk a termékekről a https://mikrotik.com/products oldalon
Az Ön nyelvén található szoftver konfigurációs kézikönyve és további információk a következő webhelyen találhatók: https://mt.lv/help-hu
A MikroTik eszközök professzionális használatra készültek. Ha nem rendelkezik képesítéssel, kérjen tanácsadót https://mikrotik.com/consultants
Első lépések:
  • Csavarhúzóval csavarja le a központi csavart és távolítsa el a műanyag burkolatot;
  • A fedél alatt Ethernet és SFP kimeneti portok találhatók;
  • Csatlakozás az eszközökhöz;
  • Csatlakoztassa az eszközt az áramforráshoz, a hálózati adaptert nem tartalmazza a csomag;
  • Nyissa meg a https://192.168.88.1 böngészőjét a konfiguráció megkezdéséhez, felhasználói név: admin, és alapértelmezés szerint nincs jelszó;
  • Szükség esetén az eszköz a falra szerelhető;
  • A csavarok tiplikkel vannak a csomagban.
Biztonsági információk:
  • Mielőtt bármilyen MikroTik berendezésen dolgozik, tisztában kell lennie az elektromos áramkörökkel kapcsolatos veszélyekkel, és ismernie kell a balesetek megelőzésére szolgáló szokásos gyakorlatokat. A telepítőnek ismeri a hálózati struktúrákat, a fogalmakat és a fogalmakat.
  • Csak a gyártó által jóváhagyott tápegységet és tartozékokat használjon, amelyek a termék eredeti csomagolásában találhatók.
  • Ezt a felszerelést képzett és képesített személyzetnek kell telepítenie, a jelen telepítési útmutató szerint. A telepítő felel annak biztosításáért, hogy a berendezés telepítése megfeleljen a helyi és az országos elektromos szabályoknak. Ne kísérelje meg szétszerelni, megjavítani vagy átalakítani a készüléket.
  • Ez a termék beltéren és kültéren egyaránt használható. A telepítés megkezdése előtt figyelmesen olvassa el a szerelési útmutatót. Ha nem használja a megfelelő hardvert és konfigurációt, vagy nem tartja be a megfelelő eljárásokat, az veszélyes helyzetet okozhat az emberek számára, és károsíthatja a rendszert.
  • Erősen javasoljuk az AC/DC tápegység használatát csak beltéri használatra.
  • Az aljzatot a berendezés közelében kell elhelyezni, és könnyen hozzáférhetőnek kell lennie.
  • Nem garantálhatjuk, hogy a készülék nem megfelelő használata miatt balesetek vagy károk nem következhetnek be. Kérjük, használja ezt a terméket körültekintően és működtesse a saját felelősségét!
  • Eszköz meghibásodása esetén kérjük, húzza ki a tápkábelt. A leggyorsabb módszer erre az, ha a hálózati adaptert kihúzza a konnektorból. Gyártó: Mikrotikls SIA, Unijas iela 2, Riga, Lettország, LV1039.
ID - Bahasa Indonesia. Panduan cepat​
warning
Perangkat ini perlu ditingkatkan ke rilis SwOS v2.18 untuk memastikan kepatuhan dengan peraturan otoritas lokal! Pengguna akhir bertanggung jawab untuk mengikuti peraturan negara setempat. Semua perangkat MikroTik harus dipasang secara profesional.
Panduan memulai cepat ini mencakup model: FTC11XG.
Ini adalah perangkat jaringan. Anda dapat menemukan nama model produk pada label casing (ID). Kunjungi halaman panduan pengguna di https://mt.lv/um untuk panduan pengguna yang diperbarui sepenuhnya. Atau pindai kode QR dengan ponsel Anda.
Spesifikasi teknis terpenting untuk produk ini dapat ditemukan di halaman terakhir Panduan Memulai Cepat ini.
Spesifikasi teknis, brosur, dan informasi produk lainnya di https://mikrotik.com/products
Panduan konfigurasi software dalam bahasa Anda dengan informasi tambahan tersedia di https://mt.lv/help
Perangkat MikroTik untuk penggunaan profesional. Jika Anda tidak memiliki kualifikasi, konsultasikan dengan konsultan https://mikrotik.com/consultants
Langkah pertama:
  • Gunakan obeng untuk membuka sekrup tengah dan menghapus penutup plastik;
  • Di bawah penutup terdapat port keluar Ethernet dan SFP;
  • Sambungkan ke perangkat Anda;
  • Sambungkan perangkat ke sumber daya listrik, adaptor daya tidak termasuk dalam paket;
  • Buka https://192.168.88.1 di peramban web Anda untuk memulai konfigurasi, nama pengguna: admin dan secara default tidak ada kata sandi;
  • Jika diperlukan, perangkat dapat dipasang di dinding;
  • Sekrup dengan borgol disertakan dalam paket.
Informasi keselamatan:
  • Sebelum mengerjakan peralatan MikroTik apa pun, waspadai bahaya yang terkait dengan sirkuit listrik dan pahami praktik standar untuk pencegahan kecelakaan. Pemasang harus terbiasa dengan struktur, istilah, dan konsep jaringan.
  • Gunakan hanya catu daya dan aksesori yang disetujui oleh produsen dan terdapat dalam kemasan asli produk ini.
  • Peralatan ini harus dipasang oleh personel yang terlatih dan memenuhi syarat, sesuai dengan petunjuk pemasangan ini. Pemasang bertanggung jawab untuk memastikan bahwa pemasangan peralatan mematuhi peraturan kelistrikan lokal dan nasional. Jangan mencoba membongkar, memperbaiki, atau memodifikasi perangkat.
  • Produk ini dapat digunakan baik di dalam maupun di luar ruangan. Sebelum memulai instalasi, bacalah petunjuk instalasi dengan seksama. Kegagalan dalam menggunakan perangkat keras dan konfigurasi yang benar atau mengikuti prosedur yang benar dapat menimbulkan situasi berbahaya bagi manusia dan merusak sistem.
  • Sangat disarankan untuk menggunakan daya AC/DC hanya untuk penggunaan di dalam ruangan.
  • Stop Kontak harus dipasang di dekat peralatan dan harus mudah diakses.
  • Kami tidak dapat menjamin bahwa tidak ada kecelakaan atau kerusakan yang akan terjadi karena penggunaan perangkat yang tidak tepat. Gunakan produk ini dengan hati-hati dan operasikan dengan risiko Anda sendiri!
  • Jika terjadi kegagalan perangkat, lepaskan dari catu daya. Cara tercepat untuk melakukannya adalah mencabut adaptor daya dari stopkontak. Pabrikan: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
IT - Italiano. Guida veloce​
warning
Questo dispositivo deve essere aggiornato alla versione SwOS v2.18 per garantire la conformità con le normative delle autorità locali! È responsabilità dell'utente finale seguire le normative nazionali locali. Tutti i dispositivi MikroTik devono essere installati professionalmente.
Questa guida rapida copre il modello: FTC11XG.
Questo è il dispositivo di rete. È possibile trovare il nome del modello del prodotto sull'etichetta della custodia (ID).
Visitare la pagina del manuale dell'utente su https://mt.lv/um-it per il manuale utente completamente aggiornato. Oppure scansiona il codice QR con il tuo cellulare.
Le specifiche tecniche più importanti per questo prodotto si trovano nell'ultima pagina di questa Guida rapida.
Specifiche tecniche, brochure e maggiori informazioni sui prodotti su https://mikrotik.com/products
Il manuale di configurazione del software nella tua lingua con informazioni aggiuntive è disponibile all'indirizzo https://mt.lv/help-it
I dispositivi MikroTik sono per uso professionale. Se non si dispone di qualifiche, consultare un consulente https://mikrotik.com/consultants
Primi passi:
  • Utilizzare un cacciavite per svitare la vite centrale e rimuovere il coperchio di plastica;
  • Sotto il coperchio sono presenti porte di uscita Ethernet e SFP;
  • Collegati ai tuoi dispositivi;
  • Collegare il dispositivo alla fonte di alimentazione, l'alimentatore non è incluso nella confezione;
  • Apri https://192.168.88.1 nel tuo browser web per avviare la configurazione, nome utente: admin e non c'è una password predefinita;
  • Se necessario, il dispositivo può essere montato a parete;
  • Le viti con tasselli sono incluse nella confezione.
Informazioni sulla sicurezza:
  • Prima di lavorare su qualsiasi apparecchiatura MikroTik, prestare attenzione ai pericoli connessi con i circuiti elettrici e conoscere le pratiche standard per la prevenzione degli incidenti. Il programma di installazione dovrebbe avere familiarità con le strutture, i termini e i concetti della rete.
  • Utilizzare solo l'alimentatore e gli accessori approvati dal produttore e che si trovano nella confezione originale di questo prodotto.
  • Questa apparecchiatura deve essere installata da personale addestrato e qualificato, secondo queste istruzioni di installazione. L'installatore è responsabile di assicurarsi che l'installazione dell'apparecchiatura sia conforme ai codici elettrici locali e nazionali. Non tentare di smontare, riparare o modificare il dispositivo.
  • Questo prodotto può essere utilizzato sia all'interno che all'esterno. Si prega di leggere attentamente le istruzioni di montaggio prima di iniziare l'installazione. Il mancato utilizzo dell'hardware e della configurazione corretti o il mancato rispetto delle procedure corrette potrebbe comportare una situazione pericolosa per le persone e danni al sistema.
  • Si consiglia vivamente di utilizzare l'alimentazione AC/DC solo per casi di utilizzo in interni.
  • La presa di corrente deve essere installata vicino all'apparecchiatura e deve essere facilmente accessibile.
  • Non possiamo garantire che non si verifichino incidenti o danni dovuti all'uso improprio del dispositivo. Utilizzare questo prodotto con cura e operare a proprio rischio!
  • In caso di guasto del dispositivo, scollegarlo dall'alimentazione. Il modo più rapido per farlo è scollegare l'alimentatore dalla presa di corrente. Produttore: Mikrotikls SIA, Unijas iela 2, Riga, Lettonia, LV1039.
IS - Íslensku. Fljótur leiðarvísir​
warning
Þetta tæki þarf að uppfæra í SwOS v2.18 útgáfuna til að tryggja samræmi við reglugerðir sveitarfélaga! Það er á ábyrgð endanlegra notenda að fylgja landsbundnum reglum. Öll MikroTik tæki verða að vera fagmannlega sett upp.
Þessi snögga leiðbeining nær yfir líkanið: FTC11XG.
Þetta er net tæki. Þú getur fundið heiti vörulíkansins á merkimiðanum (ID).
Vinsamlegast farðu á notendahandbókarsíðuna á https://mt.lv/um-is fyrir allar uppfærðar notendahandbækur. Eða skannaðu QR kóða með farsímanum þínum.
Mikilvægustu tækniforskriftirnar fyrir þessa vöru er að finna á síðustu síðu þessarar hraðhandbókar.
Tæknilýsingar, bæklingar og frekari upplýsingar um vörur á https://mikrotik.com/products
Stillingarhandbók fyrir hugbúnað á þínu tungumáli með viðbótarupplýsingum er að finna á https://mt.lv/help-is
MikroTik tæki eru til atvinnu notkunar. Ef þú ert ekki með hæfi vinsamlegast leitaðu til ráðgjafa https://mikrotik.com/consultants
Fyrstu skrefin:
  • Notaðu skrúfjárn til að skrúfa miðskrúfuna af og fjarlægja plasthlífina;
  • Undir hlífinni er Ethernet og SFP framleiðsla höfn;
  • Tengdu við tækin þín;
  • Tengdu tækið við aflgjafa, straumbreytirinn er ekki með í pakkanum;
  • Opnaðu https://192.168.88.1 í vafranum þínum til að hefja stillingar, notandanafn: admin og það er ekkert lykilorð sjálfgefið;
  • Ef þess er þörf, er hægt að festa tækið á vegginn;
  • Skrúfurnar með hengjum fylgja í pakkningunni.
Öryggisupplýsingar:
  • Áður en þú vinnur að einhverjum MikroTik búnaði, vertu meðvitaður um hættuna sem fylgir rafrásum og kynntu þér hefðbundnar venjur til að koma í veg fyrir slys. Uppsetningarforritið ætti að vera kunnugt um netkerfi, hugtök og hugtök.
  • Notaðu aðeins aflgjafa og fylgihluti sem framleiðandi hefur samþykkt og er að finna í upprunalegum umbúðum þessarar vöru.
  • Þessum búnaði skal setja upp af þjálfuðu og hæfu starfsfólki samkvæmt þessum uppsetningarleiðbeiningum. Uppsetningaraðilinn ber ábyrgð á því að uppsetning búnaðarins sé í samræmi við staðbundin og innlend rafmagnsnúmer. Ekki reyna að taka tækið í sundur, gera við eða breyta því.
  • Þessa vöru er hægt að nota bæði inni og úti. Vinsamlegast lestu leiðbeiningar um uppsetningu vandlega áður en byrjað er að setja upp. Ef ekki er notaður réttur vélbúnaður og stillingar eða farið eftir réttum aðferðum gæti það valdið hættulegum aðstæðum fyrir fólk og skemmdum á kerfinu.
  • Við mælum eindregið með því að nota AC/DC aflgjafa eingöngu til notkunar innanhúss.
  • Innstungan skal vera nálægt búnaðinum og vera aðgengileg.
  • Við getum ekki ábyrgst að engin slys eða skemmdir muni verða vegna óviðeigandi notkunar tækisins. Vinsamlegast notaðu þessa vöru með varúð og starfaðu á eigin ábyrgð!
  • Ef bilun í tæki, vinsamlegast aftengdu það frá rafmagni. Skjótasta leiðin til þess er með því að taka rafmagnstengið úr sambandi. Framleiðandi: Mikrotikls SIA, Unijas iela 2, Riga, Lettlandi, LV1039.
NO - Norsk. Hurtiginnføring​
warning
Denne enheten må oppgraderes til SwOS v2.18-versjonen for å sikre samsvar med lokale myndigheters forskrifter! Det er sluttbrukernes ansvar å følge lokale lands forskrifter. Alle MikroTik-enheter må være profesjonelt installert.
Denne hurtigveiledningen dekker modellen: FTC11XG.
Dette er nettverksenhet. Du kan finne produktmodellnavnet på etiketten (ID).
Vennligst besøk bruksanvisningen på https://mt.lv/um-no for den fulle oppdaterte bruksanvisningen. Eller skann QR-koden med mobiltelefonen din.
De viktigste tekniske spesifikasjonene for dette produktet finner du på siste side i denne hurtigveiledningen.
Tekniske spesifikasjoner, brosjyrer og mer info om produkter på https://mikrotik.com/products
Konfigurasjonshåndbok for programvare på ditt språk med tilleggsinformasjon finner du på https://mt.lv/help-no
MikroTik-enheter er til profesjonell bruk. Hvis du ikke har kvalifikasjoner, kan du søke en konsulent https://mikrotik.com/consultants
Første steg:
  • Bruk en skrutrekker for å skru ut den sentrale skruen og fjerne plastdekselet.
  • Under dekselet er det Ethernet- og SFP-utgangsportene;
  • Koble til enhetene dine;
  • Koble enheten til strømkilden, strømadapteren er ikke inkludert i pakken;
  • Åpne https://192.168.88.1 i nettleseren din for å starte konfigurasjonen, brukernavn: admin og det er ikke noe passord som standard;
  • Om nødvendig kan enheten monteres på veggen;
  • Skruene med dybler følger med i pakken.
Sikkerhetsinformasjon:
  • Før du jobber med MikroTik-utstyr, må du være oppmerksom på farene som er forbundet med elektriske kretsløp, og kjenne til standard praksis for å forhindre ulykker. Installasjonsprogrammet skal være kjent med nettverksstrukturer, vilkår og konsepter.
  • Bruk bare strømforsyningen og tilbehøret som er godkjent av produsenten, og som finnes i originalemballasjen til dette produktet.
  • Dette utstyret skal installeres av trent og kvalifisert personell i henhold til denne installasjonsinstruksen. Installatøren er ansvarlig for at installasjonen av utstyret er i samsvar med lokale og nasjonale elektriske koder. Ikke prøv å demontere, reparere eller endre enheten.
  • Dette produktet kan brukes både innendørs og utendørs. Les monteringsinstruksjonene nøye før du begynner å installere. Unnlatelse av å bruke riktig maskinvare og konfigurasjon eller å følge de riktige prosedyrene kan føre til en farlig situasjon for mennesker og skade på systemet.
  • Vi anbefaler på det sterkeste å bruke AC/DC strømforsyning kun for innendørs bruk.
  • Stikkontakten skal installeres i nærheten av utstyret og skal være lett tilgjengelig.
  • Vi kan ikke garantere at ingen ulykker eller skader vil oppstå på grunn av feil bruk av enheten. Bruk dette produktet med forsiktighet og bruk det på egen risiko!
  • Ved feil på enheten må du koble den fra strømmen. Den raskeste måten å gjøre det på er ved å trekke ut strømadapteren fra stikkontakten. Produsent: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
LT - Lietuvių. Trumpas vadovas​
warning
Šis įrenginys turi būti atnaujintas į SwOS v2.18 leidimą, kad būtų laikomasi vietos valdžios taisyklių! Galutiniai vartotojai yra atsakingi už vietinių šalies taisyklių laikymąsi. Visi MikroTik įrenginiai turi būti profesionaliai sumontuoti.
Šis trumpasis vadovas apima modelį: FTC11XG.
Tai yra tinklo įrenginys. Produkto modelio pavadinimą galite rasti dėklo etiketėje (ID).
Norėdami gauti išsamesnį vartotojo vadovą, apsilankykite vartotojo vadovo puslapyje https://mt.lv/um-lt. Arba nuskaitykite QR kodą savo mobiliuoju telefonu.
Svarbiausias šio gaminio technines specifikacijas galite rasti paskutiniame šio greito vadovo puslapyje.
Techninės specifikacijos, brošiūros ir daugiau informacijos apie gaminius rasite https://mikrotik.com/products
Programinės įrangos jūsų kalba konfigūravimo vadovą su papildoma informacija galite rasti tinklalapyje https://mt.lv/help-lt
„MikroTik“ prietaisai yra skirti profesionaliam naudojimui. Jei neturite kvalifikacijos, kreipkitės į konsultantą https://mikrotik.com/consultants
Pirmieji žingsniai:
  • Atsuktuvu atsukite centrinį varžtą ir nuimkite plastikinį dangtelį;
  • Po dangteliu yra Ethernet ir SFP išvesties prievadai;
  • Prisijunkite prie savo prietaisų;
  • Prijunkite prietaisą prie maitinimo šaltinio, maitinimo adapteris nėra pakuotėje;
  • Atidarykite https://192.168.88.1 savo interneto naršyklėje, kad pradėtumėte konfigūraciją, vartotojo vardas: admin ir pagal nutylėjimą nėra slaptažodžio;
  • Jei reikia, prietaisą galima pritvirtinti prie sienos;
  • Varžtai su kaiščiais yra pakuotėje.
Saugumo informacija:
  • Prieš pradėdami dirbti su bet kuria „MikroTik“ įranga, žinokite apie pavojus, susijusius su elektros grandinėmis, ir susipažinkite su standartine avarijų prevencijos praktika. Montuotojas turėtų būti susipažinęs su tinklo struktūromis, terminais ir sąvokomis.
  • Naudokite tik gamintojo patvirtintus maitinimo šaltinius ir priedus, kuriuos galite rasti originalioje šio gaminio pakuotėje.
  • Šią įrangą turi montuoti apmokyti ir kvalifikuoti darbuotojai, kaip numatyta šiose montavimo instrukcijose. Montuotojas yra atsakingas už tai, kad įranga būtų montuojama laikantis vietinių ir nacionalinių elektros taisyklių. Nemėginkite išardyti, taisyti ar modifikuoti įrenginio.
  • Šis produktas gali būti naudojamas tiek viduje, tiek lauke. Prieš pradėdami diegimą, atidžiai perskaitykite montavimo instrukcijas. Jei nenaudosite tinkamos aparatūros ir konfigūracijos arba nesilaikysite teisingų procedūrų, žmonėms gali kilti pavojinga situacija ir sugadinti sistemą.
  • Primygtinai rekomenduojame naudoti AC/DC maitinimo šaltinį tik patalpose.
  • Kištukinis lizdas turi būti įrengtas šalia įrangos ir turi būti lengvai pasiekiamas.
  • Mes negalime garantuoti, kad dėl netinkamo prietaiso naudojimo nebus jokių avarijų ar žalos. Naudokite šį gaminį atsargiai ir dirbkite savo rizika!
  • Sugedus įrenginiui, atjunkite jį nuo maitinimo. Greičiausias būdas tai padaryti yra atjungus maitinimo adapterį nuo maitinimo lizdo. Gamintojas: Mikrotikls SIA, Unijas iela 2, Ryga, Latvija, LV1039.
LV - Latviešu. Īsa rokasgrāmata​
warning
Šī ierīce ir jāatjaunina uz SwOS v2.18 versiju, lai nodrošinātu atbilstību vietējo varas iestāžu noteikumiem! Gala lietotāju pienākums ir ievērot vietējos valsts normatīvus. Visām MikroTik ierīcēm jābūt profesionāli uzstādītām.
Šī īsā rokasgrāmata attiecas uz modeli: FTC11XG.
Šī ir tīkla ierīce. Produkta modeļa nosaukumu varat atrast uz produkta iepakojuma (ID).
Lūdzu, apmeklējiet lietotāja rokasgrāmatas lapu https://mt.lv/um-lv, lai iegūtu pilnīgu un atjauninātu lietotāja rokasgrāmatu. Vai arī skenējiet QR kodu ar savu mobilo tālruni.
Vissvarīgākās šī produkta tehniskās specifikācijas ir atrodamas šīs ātrās rokasgrāmatas pēdējā lappusē.
Tehniskās specifikācijas, brošūras un vairāk informācijas par produktiem vietnē https://mikrotik.com/products
Konfigurācijas rokasgrāmata programmatūrai jūsu valodā ar papildu informāciju atrodama vietnē https://mt.lv/help-lv
MikroTik ierīces ir paredzētas profesionālai lietošanai. Ja jums nav kvalifikācijas, lūdzu, meklējiet konsultanta palīdzību https://mikrotik.com/consultants
Pirmie soļi:
  • Izmantojiet skrūvgriezi, lai atskrūvētu centrālo skrūvi un noņemtu plastmasas vāku;
  • Zem vāka atrodas Ethernet un SFP izvades porti;
  • Savienojiet ierīces ar portiem, izmantojot Ethernet vai SFP kabeļus;
  • Pievienojiet ierīci strāvas avotam, strāvas adapteris nav iekļauts komplektācijā;
  • Atveriet vietni https://192.168.88.1 savā tīmekļa pārlūkprogrammā, lai sāktu konfigurēšanu, lietotāja vārds: admin un pēc noklusējuma parole nav uzstādīta;
  • Ja, nepieciešams, ierīci var piestiprināt pie sienas;
  • Skrūves ar dībeļiem ir iekļautas iepakojumā.
Drošības informācija:
  • Pirms sākat strādāt ar jebkuru MikroTik aprīkojumu, iepazīstieties ar briesmām, kas saistītas ar elektriskajām shēmām, un iepazīstieties ar standarta praksi negadījumu novēršanā. Instalētājam jāzina tīkla struktūras, termini un koncepcijas.
  • Izmantojiet tikai ražotāja apstiprinātu barošanas avotu un piederumus, kas atrodami šī produkta oriģinālajā iepakojumā.
  • Saskaņā ar šīm uzstādīšanas instrukcijām šo aprīkojumu jāuzstāda apmācītam un kvalificētam personālam. Uzstādītāja pienākums ir pārliecināties, ka aprīkojuma uzstādīšana atbilst vietējiem un nacionālajiem elektrības noteikumiem. Nemēģiniet ierīci izjaukt, labot vai pārveidot.
  • Šo produktu var izmantot gan telpās, gan ārpus tām. Pirms uzstādīšanas, lūdzu, uzmanīgi izlasiet montāžas instrukciju. Pareizas aparatūras un konfigurācijas neizmantošana vai pareizu procedūru neievērošana var izraisīt cilvēkiem bīstamu situāciju un sistēmas bojājumus.
  • Stingri rekomendējam izmantot AC/DC barošanas avotu tikai iekštelpās.
  • Kontaktligzdai jābūt uzstādītai netālu no iekārtas un tai jābūt viegli pieejamai.
  • Mēs nevaram garantēt, ka ierīces nepareizas lietošanas dēļ negadījumi vai bojājumi nenotiks. Lūdzu, izmantojiet šo produktu uzmanīgi un rīkojieties atbildīgi!
  • Ierīces kļūmes gadījumā, lūdzu, atvienojiet to no strāvas. Ātrākais veids, kā to izdarīt, ir, atvienojot strāvas adapteri no kontaktligzdas. Ražotājs: Mikrotikls SIA, Ūnijas iela 2, Rīga, Latvija, LV1039.
MT - Malti. Gwida Quick​
warning
Dan l-apparat jeħtieġ li jiġi aġġornat għar-rilaxx SwOS v2.18 biex tiġi żgurata l-konformità mar-regolamenti tal-awtorità lokali! Hija r-responsabbiltà tal-utenti finali li jsegwu r-regolamenti lokali tal-pajjiż. L-apparati kollha MikroTik iridu jkunu installati professjonalment.
Din il-Gwida Quick tkopri l-mudell: FTC11XG.
Dan huwa apparat tan-netwerk. Tista 'ssib l-isem tal-mudell tal-prodott fuq it-tikketta tal-każ (ID).
Jekk jogħġbok żur il-paġna manwal tal-utent fuq https://mt.lv/um-mt għall-manwal aġġornat tal-utent. Jew skennja l-kodiċi QR bit-telefon ċellulari tiegħek.
L-iktar speċifikazzjonijiet tekniċi importanti għal dan il-prodott jistgħu jinstabu fl-aħħar paġna ta 'din il-Gwida ta' Ħeffa.
Speċifikazzjonijiet tekniċi, fuljetti u aktar tagħrif dwar il-prodotti fuq https://mikrotik.com/products
Manwal ta 'konfigurazzjoni għas-softwer fil-lingwa tiegħek b'informazzjoni addizzjonali jista' jinstab fuq https://mt.lv/help-mt
L-apparat MikroTik huwa għal użu professjonali. Jekk m'għandekx kwalifiki jekk jogħġbok fittex konsulent https://mikrotik.com/consultants
L-ewwel passi:
  • Uża tornavit biex tħoll il-kamin ċentrali u neħħi l-għatu tal-plastik;
  • Taħt il-kopertura hemm portijiet tal-ħruġ Ethernet u SFP;
  • Qabbad mat-tagħmir tiegħek;
  • Qabbad l-apparat mas-sors tal-enerġija, l-adapter tal-enerġija mhuwiex inkluż fil-pakkett;
  • Iftaħ https://192.168.88.1 fil-web browser tiegħek biex tibda l-konfigurazzjoni, isem l-utent: admin u m'hemm l-ebda password awtomatikament;
  • Jekk meħtieġ, l-apparat jista 'jkun immuntat fuq il-ħajt;
  • Il-viti bid-dowels huma nklużi fil-pakkett.
Informazzjoni dwar is-Sikurezza:
  • Qabel ma taħdem fuq kwalunkwe tagħmir MikroTik, kun konxju tal-perikli involuti fiċ-ċirkwiti elettriċi u kun familjari mal-prattiki standard għall-prevenzjoni ta 'inċidenti. L-installatur għandu jkun familjari mal-istrutturi, termini u kunċetti tan-netwerk.
  • Uża biss il-provvista tal-enerġija u l-aċċessorji approvati mill-manifattur, u li tista 'tinstab fl-imballaġġ oriġinali ta' dan il-prodott.
  • Dan it-tagħmir għandu jkun installat minn persunal imħarreġ u kwalifikat, skont dawn l-istruzzjonijiet ta 'installazzjoni. L-installatur huwa responsabbli li jiżgura li l-Installazzjoni tat-tagħmir hija konformi mal-kodiċijiet elettriċi lokali u nazzjonali. Tippruvax tiżżarma, tissewwa jew timmodifika l-apparat.
  • Dan il-prodott jista 'jintuża kemm ġewwa kif ukoll barra. Jekk jogħġbok aqra sew l-istruzzjonijiet tal-immuntar qabel tibda l-installazzjoni. Nuqqas li tuża l-hardware u l-konfigurazzjoni korretti jew li ssegwi l-proċeduri korretti jista 'jirriżulta f'sitwazzjoni perikoluża għan-nies u ħsara lis-sistema.
  • Nirrakkomandaw ħafna li tuża provvista ta 'enerġija AC/DC biss għal każijiet ta' użu fuq ġewwa.
  • Is-socket-outlet għandu jkun installat ħdejn it-tagħmir u għandu jkun faċilment aċċessibbli.
  • Ma nistgħux niggarantixxu li ma jseħħ l-ebda inċident jew ħsara minħabba l-użu mhux xieraq tal-apparat. Jekk jogħġbok uża dan il-prodott b'attenzjoni u tħaddem għar-riskju tiegħek!
  • Fil-każ ta 'ħsara fl-apparat, jekk jogħġbok aqla' mill-enerġija. L-iktar mod mgħaġġel biex tagħmel dan huwa billi tiftaħ l-adapter tal-enerġija mill-iżbokk tad-dawl. Manifattur: Mikrotikls SIA, Unijas iela 2, i Riga, il-Latvja, LV1039.
NL - Nederlands. Snelgids​
warning
Dit apparaat moet worden geüpgraded naar de SwOS v2.18-release om ervoor te zorgen dat het voldoet aan de lokale overheidsvoorschriften! Het is de verantwoordelijkheid van de eindgebruikers om de lokale regelgeving te volgen. Alle MikroTik-apparaten moeten professioneel worden geïnstalleerd.
Deze beknopte handleiding behandelt het model: FTC11XG.
Dit is een netwerkapparaat. U kunt de naam van het productmodel vinden op het etiket van de behuizing (ID).
Ga naar de gebruikerspagina op https://mt.lv/um-nl voor de volledige bijgewerkte gebruikershandleiding. Of scan de QR-code met uw mobiele telefoon.
De belangrijkste technische specificaties van dit product vindt u op de laatste pagina van deze Quick Guide.
Technische specificaties, brochures en meer informatie over producten op https://mikrotik.com/products
Configuratiehandleiding voor software in uw taal met aanvullende informatie is te vinden op https://mt.lv/help-nl
MikroTik-apparaten zijn voor professioneel gebruik. Als u geen kwalificaties hebt, zoek dan een consultant https://mikrotik.com/consultants
Eerste stappen:
  • Gebruik een schroevendraaier om de centrale schroef los te draaien en verwijder de plastic kap;
  • Onder de kap bevinden zich Ethernet- en SFP-uitgangspoorten;
  • Maak verbinding met uw apparaten;
  • Sluit het apparaat aan op de stroombron, de stroomadapter is niet inbegrepen in het pakket;
  • Open https://192.168.88.1 in uw webbrowser om de configuratie te starten, gebruikersnaam: admin en er is standaard geen wachtwoord;
  • Indien nodig kan het apparaat aan de muur worden gemonteerd;
  • De schroeven met pluggen zitten in het pakket.
Veiligheidsinformatie:
  • Voordat u aan een MikroTik-apparaat gaat werken, moet u zich bewust zijn van de gevaren van elektrische circuits en bekend zijn met de standaardpraktijken om ongevallen te voorkomen. Het installatieprogramma moet bekend zijn met netwerkstructuren, termen en concepten.
  • Gebruik alleen de voeding en accessoires die zijn goedgekeurd door de fabrikant en die u kunt vinden in de originele verpakking van dit product.
  • Deze apparatuur moet worden geïnstalleerd door opgeleid en gekwalificeerd personeel, volgens deze installatie-instructies. De installateur is ervoor verantwoordelijk dat de installatie van de apparatuur voldoet aan de lokale en nationale elektrische voorschriften. Probeer het apparaat niet uit elkaar te halen, te repareren of aan te passen.
  • Dit product kan zowel binnen als buiten worden gebruikt. Lees de montage-instructies zorgvuldig door voordat u met de installatie begint. Het niet gebruiken van de juiste hardware en configuratie of het niet volgen van de juiste procedures kan leiden tot een gevaarlijke situatie voor mensen en schade aan het systeem.
  • We raden ten zeerste aan om AC/DC-voeding alleen te gebruiken voor gebruik binnenshuis.
  • Het stopcontact moet in de buurt van de apparatuur worden geïnstalleerd en gemakkelijk toegankelijk zijn.
  • We kunnen niet garanderen dat er geen ongelukken of schade zullen optreden als gevolg van oneigenlijk gebruik van het apparaat. Gebruik dit product met zorg en werk op eigen risico!
  • Koppel het apparaat los van de stroom als het defect is. De snelste manier om dit te doen is door de stroomadapter uit het stopcontact te halen. Fabrikant: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
PL - Polskie. Szybka porada​
warning
To urządzenie wymaga uaktualnienia do wersji SwOS v2.18, aby zapewnić zgodność z przepisami władz lokalnych! Obowiązkiem użytkowników końcowych jest przestrzeganie lokalnych przepisów krajowych. Wszystkie urządzenia MikroTik muszą być profesjonalnie zainstalowane.
Niniejszy Krótki przewodnik obejmuje model: FTC11XG.
To jest urządzenie sieciowe. Nazwę modelu produktu można znaleźć na etykiecie skrzynki (ID).
Odwiedź stronę instrukcji użytkownika na https://mt.lv/um-pl, aby uzyskać pełną aktualną instrukcję obsługi. Lub zeskanuj kod QR za pomocą telefonu komórkowego.
Najważniejsze dane techniczne tego produktu można znaleźć na ostatniej stronie tego skróconego przewodnika.
Dane techniczne, broszury i więcej informacji o produktach na stronie https://mikrotik.com/products
Podręcznik konfiguracji oprogramowania w Twoim języku z dodatkowymi informacjami można znaleźć na stronie https://mt.lv/help-pl
Urządzenia MikroTik są przeznaczone do użytku profesjonalnego. Jeśli nie masz kwalifikacji, poszukaj konsultanta https://mikrotik.com/consultants
Pierwsze kroki:
  • Za pomocą śrubokręta odkręć środkową śrubę i zdejmij plastikową osłonę;
  • Pod pokrywą znajdują się porty wyjściowe Ethernet i SFP;
  • Połącz się ze swoimi urządzeniami;
  • Podłącz urządzenie do źródła zasilania, zasilacz nie znajduje się w pakiecie;
  • Otwórz https://192.168.88.1 w przeglądarce internetowej, aby rozpocząć konfigurację, nazwa użytkownika: admin i domyślnie nie ma hasła;
  • W razie potrzeby urządzenie można zamontować na ścianie;
  • Śruby z kołkami są dołączone do opakowania.
Informacje dotyczące bezpieczeństwa:
  • Przed rozpoczęciem pracy z jakimkolwiek sprzętem MikroTik należy pamiętać o zagrożeniach związanych z obwodami elektrycznymi i zapoznać się ze standardowymi praktykami zapobiegania wypadkom. Instalator powinien zapoznać się ze strukturami sieci, terminami i koncepcjami.
  • Używaj wyłącznie zasilacza i akcesoriów zatwierdzonych przez producenta, które znajdują się w oryginalnym opakowaniu tego produktu.
  • To urządzenie powinno być zainstalowane przez przeszkolony i wykwalifikowany personel zgodnie z niniejszą instrukcją instalacji. Instalator jest odpowiedzialny za upewnienie się, że instalacja urządzenia jest zgodna z lokalnymi i krajowymi przepisami elektrycznymi. Nie należy podejmować prób demontażu, naprawy ani modyfikacji urządzenia.
  • Ten produkt może być używany zarówno wewnątrz, jak i na zewnątrz. Przed rozpoczęciem instalacji prosimy o dokładne zapoznanie się z instrukcją montażu. Niezastosowanie prawidłowego sprzętu i konfiguracji lub nieprzestrzeganie prawidłowych procedur może skutkować niebezpieczną sytuacją dla ludzi i uszkodzeniem systemu.
  • Zdecydowanie zalecamy używanie zasilacza AC/DC tylko do zastosowań wewnętrznych.
  • Gniazdko powinno być zainstalowane w pobliżu urządzenia i powinno być łatwo dostępne.
  • Nie możemy zagwarantować, że nie dojdzie do wypadków ani szkód spowodowanych niewłaściwym użytkowaniem urządzenia. Proszę używać tego produktu ostrożnie i działać na własne ryzyko!
  • W przypadku awarii urządzenia odłącz je od zasilania. Najszybszym sposobem jest odłączenie zasilacza od gniazdka elektrycznego. Producent: Mikrotikls SIA, Unijas iela 2, Riga, Łotwa, LV1039.
PT - Português. Guia rápido​
warning
Este dispositivo precisa ser atualizado para a versão SwOS v2.18 para garantir a conformidade com os regulamentos das autoridades locais! É responsabilidade dos usuários finais seguir os regulamentos locais do país. Todos os dispositivos MikroTik devem ser instalados profissionalmente.
Este Guia Rápido cobre o modelo: FTC11XG.
Este é o dispositivo de rede. Você pode encontrar o nome do modelo do produto no rótulo da caixa (ID).
Visite a página do manual do usuário em https://mt.lv/um-pt para obter o manual do usuário completo e atualizado. Ou digitalize o código QR com seu telefone celular.
As especificações técnicas mais importantes para este produto podem ser encontradas na última página deste Guia Rápido.
Especificações técnicas, brochuras e mais informações sobre produtos em https://mikrotik.com/products
O manual de configuração do software em seu idioma com informações adicionais pode ser encontrado em https://mt.lv/help-pt
Os dispositivos MikroTik são para uso profissional. Se você não possui qualificações, procure um consultor https://mikrotik.com/consultants
Primeiros passos:
  • Use uma chave de fenda para desaparafusar o parafuso central e remover a tampa plástica;
  • Sob a cobertura, há portas de saída Ethernet e SFP;
  • Conecte-se aos seus dispositivos;
  • Conecte o dispositivo à fonte de alimentação, o adaptador de alimentação não está incluído no pacote;
  • Abra https://192.168.88.1 em seu navegador para iniciar a configuração, nome de usuário: admin e não há senha por padrão;
  • Se necessário, o dispositivo pode ser montado na parede;
  • Os parafusos com buchas estão incluídos na embalagem.
Informação de Segurança:
  • Antes de trabalhar em qualquer equipamento MikroTik, esteja ciente dos riscos envolvidos nos circuitos elétricos e esteja familiarizado com as práticas padrão para prevenção de acidentes. O instalador deve estar familiarizado com estruturas, termos e conceitos de rede.
  • Use apenas a fonte de alimentação e os acessórios aprovados pelo fabricante e que podem ser encontrados na embalagem original deste produto.
  • Este equipamento deve ser instalado por pessoal treinado e qualificado, de acordo com estas instruções de instalação. O instalador é responsável por garantir que a instalação do equipamento esteja em conformidade com os códigos elétricos locais e nacionais. Não tente desmontar, reparar ou modificar o dispositivo.
  • Este produto pode ser usado tanto em ambientes internos quanto externos. Leia as instruções de montagem cuidadosamente antes de iniciar a instalação. A falha em usar o hardware e a configuração corretos ou em seguir os procedimentos corretos pode resultar em uma situação perigosa para as pessoas e danos ao sistema.
  • É altamente recomendável usar a fonte de alimentação CA/CC apenas para casos de uso interno.
  • A tomada deve ser instalada próxima ao equipamento e deve ser de fácil acesso.
  • Não podemos garantir que nenhum acidente ou dano ocorra devido ao uso inadequado do dispositivo. Por favor, use este produto com cuidado e opere por sua conta e risco!
  • No caso de falha do dispositivo, desconecte-o da energia. A maneira mais rápida de fazer isso é desconectando o adaptador de energia da tomada. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letônia, LV1039.
RO - Română. Ghid rapid​
warning
Acest dispozitiv trebuie să fie actualizat la versiunea SwOS v2.18 pentru a asigura conformitatea cu reglementările autorităților locale! Este responsabilitatea utilizatorilor finali să respecte reglementările locale ale țării. Toate dispozitivele MikroTik trebuie instalate profesional.
Acest Ghid rapid acoperă modelul: FTC11XG.
Acesta este dispozitivul de rețea. Puteți găsi numele modelului produsului pe eticheta carcasei (ID).
Vă rugăm să vizitați pagina manualului utilizatorului de pe https://mt.lv/um-ro pentru manualul complet actualizat. Sau scanează codul QR cu telefonul tău mobil.
Cele mai importante specificații tehnice pentru acest produs pot fi găsite pe ultima pagină a acestui Ghid rapid.
Specificații tehnice, broșuri și mai multe informații despre produse la https://mikrotik.com/products
Manualul de configurare pentru software-ul în limba dvs. cu informații suplimentare poate fi găsit la https://mt.lv/help-ro
Dispozitivele MikroTik sunt destinate utilizării profesionale. Dacă nu aveți calificări, vă rugăm să căutați un consultant https://mikrotik.com/consultants
Primii pasi:
  • Folosiți o șurubelniță pentru a deșuruba șurubul central și a scoate capacul din plastic;
  • Sub acoperire există porturi de ieșire Ethernet și SFP;
  • Conectați-vă la dispozitivele dvs;
  • Conectați dispozitivul la sursa de alimentare, adaptorul de alimentare nu este inclus în pachet;
  • Deschideți https://192.168.88.1 în browserul dvs. web pentru a începe configurarea, numele de utilizator: admin și nu există o parolă în mod implicit;
  • Dacă este necesar, dispozitivul poate fi montat pe perete;
  • Șuruburile cu dibluri sunt incluse în pachet.
Informații de siguranță:
  • Înainte de a lucra la orice echipament MikroTik, fiți conștienți de pericolele implicate de circuitele electrice și cunoașteți practicile standard pentru prevenirea accidentelor. Programul de instalare ar trebui să fie familiarizat cu structurile, termenii și conceptele rețelei.
  • Folosiți numai sursa de alimentare și accesoriile aprobate de producător și care pot fi găsite în ambalajul original al acestui produs.
  • Acest echipament va fi instalat de personal instruit și calificat, conform acestor instrucțiuni de instalare. Instalatorul este responsabil să se asigure că Instalarea echipamentului respectă codurile electrice locale și naționale. Nu încercați să dezasamblați, reparați sau modificați dispozitivul.
  • Acest produs poate fi utilizat atât în interior, cât și în exterior. Vă rugăm să citiți cu atenție instrucțiunile de montare înainte de a începe instalarea. Neutilizarea hardware-ului și a configurației corecte sau a respectării procedurilor corecte ar putea duce la o situație periculoasă pentru oameni și la deteriorarea sistemului.
  • Vă recomandăm să utilizați sursa de alimentare AC/DC numai pentru cazuri de utilizare în interior.
  • Priza trebuie instalată în apropierea echipamentului și trebuie să fie ușor accesibilă.
  • Nu putem garanta că nu se vor produce accidente sau daune din cauza utilizării necorespunzătoare a dispozitivului. Vă rugăm să utilizați acest produs cu grijă și să operați pe riscul dvs.!
  • În cazul unei defecțiuni a dispozitivului, vă rugăm să îl deconectați de la alimentare. Cel mai rapid mod de a face acest lucru este prin a deconecta adaptorul de alimentare de la priza electrică. Producător: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
SK - Slovenský. Stručný návod​
warning
Toto zariadenie je potrebné inovovať na vydanie SwOS v2.18, aby sa zabezpečil súlad s predpismi miestnych úradov! Je zodpovednosťou koncových používateľov dodržiavať miestne predpisy krajiny. Všetky zariadenia MikroTik musia byť profesionálne nainštalované.
Táto Stručná príručka sa týka modelu: FTC11XG.
Toto je sieťové zariadenie. Názov modelu produktu nájdete na štítku prípadu (ID).
Úplnú aktualizovanú používateľskú príručku nájdete na stránke používateľskej príručky na adrese https://mt.lv/um-sk. Alebo naskenujte QR kód pomocou mobilného telefónu.
Najdôležitejšie technické špecifikácie tohto produktu nájdete na poslednej stránke tohto stručného sprievodcu.
Technické špecifikácie, brožúry a ďalšie informácie o produktoch nájdete na adrese https://mikrotik.com/products
Konfiguračnú príručku pre softvér vo vašom jazyku s ďalšími informáciami nájdete na https://mt.lv/help-sk
Zariadenia MikroTik sú určené pre profesionálne použitie. Ak nemáte kvalifikáciu, obráťte sa na konzultanta https://mikrotik.com/consultants
Prvé kroky:
  • Pomocou skrutkovača odskrutkujte strednú skrutku a odstráňte plastový kryt;
  • Pod krytom sú výstupné porty Ethernet a SFP;
  • Pripojte sa k svojim zariadeniam;
  • Pripojte zariadenie k zdroju napájania, napájací adaptér nie je súčasťou balenia;
  • Otvorte vo svojom webovom prehliadači https://192.168.88.1 aby ste spustili konfiguráciu, meno používateľa: admin a v predvolenom nastavení nie je zadané heslo;
  • V prípade potreby je možné zariadenie namontovať na stenu;
  • Skrutky s hmoždinkami sú súčasťou balenia.
Bezpečnostné informácie:
  • Predtým, ako začnete pracovať na akomkoľvek zariadení MikroTik, uvedomte si riziká spojené s elektrickými obvodmi a zoznámte sa so štandardnými postupmi prevencie nehôd. Inštalátor by mal byť oboznámený so sieťovými štruktúrami, pojmami a konceptmi.
  • Používajte iba napájací zdroj a príslušenstvo schválené výrobcom, ktoré nájdete v pôvodnom obale tohto produktu.
  • Toto zariadenie musí inštalovať školený a kvalifikovaný personál podľa týchto pokynov na inštaláciu. Inštalatér je zodpovedný za zabezpečenie toho, aby inštalácia zariadenia bola v súlade s miestnymi a národnými elektrickými predpismi. Nepokúšajte sa zariadenie rozoberať, opravovať alebo upravovať.
  • Tento výrobok je možné používať v interiéroch aj exteriéroch. Pred začatím inštalácie si pozorne prečítajte montážne pokyny. Ak nepoužijete správny hardvér a konfiguráciu alebo nedodržíte správne postupy, môže to viesť k nebezpečnej situácii pre ľudí a poškodeniu systému.
  • Dôrazne odporúčame používať AC/DC napájací zdroj len pre vnútorné použitie.
  • Zásuvka musí byť inštalovaná v blízkosti zariadenia a musí byť ľahko dostupná.
  • Nemôžeme zaručiť, že v dôsledku nesprávneho použitia zariadenia nedôjde k žiadnym nehodám alebo škodám. Tento výrobok používajte opatrne a pracujte na svoje vlastné riziko!
  • V prípade poruchy zariadenia ho prosím odpojte od napájania. Najrýchlejším spôsobom je odpojenie sieťového adaptéra zo sieťovej zásuvky. Výrobca: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
SL - Slovenščina. Hitri vodnik​
warning
To napravo je treba nadgraditi na izdajo SwOS v2.18, da se zagotovi skladnost s predpisi lokalnih oblasti! Končni uporabniki so odgovorni za upoštevanje lokalnih državnih predpisov. Vse naprave MikroTik morajo biti strokovno nameščene.
Ta hitri vodnik zajema model: FTC11XG.
To je omrežna naprava. Ime modela izdelka najdete na nalepki (ID).
Za popoln posodobitev uporabniškega priročnika obiščite stran z navodili na strani https://mt.lv/um-sl. Ali pa skenirajte QR kodo s svojim mobilnim telefonom.
Najpomembnejše tehnične specifikacije za ta izdelek najdete na zadnji strani teh hitrih navodil.
Tehnične specifikacije, brošure in več informacij o izdelkih na https://mikrotik.com/products
Navodila za konfiguracijo programske opreme v vašem jeziku z dodatnimi informacijami najdete na naslovu https://mt.lv/help-sl
Naprave MikroTik so namenjene profesionalni uporabi. Če nimate kvalifikacij, poiščite svetovalca https://mikrotik.com/consultants
Prvi koraki:
  • Z izvijačem odvijte osrednji vijak in odstranite plastični pokrov;
  • Pod pokrovom so izhodna vrata Ethernet in SFP;
  • Povežite se s svojimi napravami;
  • Napravo priključite na vir napajanja, napajalnik ni vključen v paket;
  • V spletnem brskalniku odprite https://192.168.88.1 da zaženete konfiguracijo, uporabniško ime: admin in privzeto ni gesla;
  • Po potrebi se lahko naprava namesti na steno;
  • V paketu so vijaki z mozniki.
Varnostne informacije:
  • Pred delom na kateri koli opremi MikroTik bodite pozorni na nevarnosti, povezane z električnim vezjem, in se seznanite s standardnimi praksami za preprečevanje nesreč. Namestitveni program mora biti seznanjen z omrežnimi strukturami, izrazi in koncepti.
  • Uporabljajte samo napajalnik in dodatke, ki jih je odobril proizvajalec in ki jih najdete v originalni embalaži tega izdelka.
  • To opremo mora vgraditi usposobljeno in usposobljeno osebje v skladu s temi navodili za namestitev. Monter je odgovoren za to, da je namestitev opreme skladna z lokalnimi in državnimi električnimi kodeksi. Naprave ne poskušajte razstaviti, popraviti ali spremeniti.
  • Ta izdelek lahko uporabljate tako v zaprtih prostorih kot na prostem. Pred začetkom namestitve natančno preberite navodila za montažo. Če ne uporabite pravilne strojne opreme in konfiguracije ali ne upoštevate pravilnih postopkov, lahko pride do nevarnih razmer za ljudi in poškodbe sistema.
  • Močno priporočamo, da napajalnik AC/DC uporabljate le za uporabo v zaprtih prostorih.
  • Vtičnica mora biti nameščena v bližini opreme in mora biti lahko dostopna.
  • Ne moremo zagotoviti, da se zaradi nepravilne uporabe naprave ne bo zgodilo nobena nesreča ali škoda. Uporabljajte ta izdelek previdno in delujte na lastno odgovornost!
  • V primeru okvare naprave jo izklopite iz napajanja. Najhitreje to storite tako, da napajalnik odklopite iz vtičnice. Proizvajalec: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
SV - Svenska. Snabb guide​
warning
Den här enheten måste uppgraderas till SwOS v2.18-versionen för att säkerställa efterlevnad av lokala myndigheters föreskrifter! Det är slutanvändarnas ansvar att följa lokala landsbestämmelser. Alla MikroTik-enheter måste vara professionellt installerade.
Detta dokument täcker modellen: FTC11XG.
Det här är nätverksenhet. Du hittar produktmodellnamnet på etiketten (ID).
Besök användarmanualsidan på https://mt.lv/um-sv för en fullständig uppdaterad användarmanual. Eller skanna QR-koden med din mobiltelefon.
Tekniska specifikationer, broschyrer och mer information om produkter på https://mikrotik.com/products
De viktigaste tekniska specifikationerna för denna produkt finns på den sista sidan i denna snabbguide.
Konfigurationshandbok för programvara på ditt språk med ytterligare information kan hittas på https://mt.lv/help-sv
MikroTik-enheter är för professionellt bruk. Om du inte har behörighet, sök en konsult https://mikrotik.com/consultants
Første steg:
  • Använd en skruvmejsel för att skruva loss den centrala skruven och ta bort plasthöljet;
  • Under locket finns Ethernet- och SFP-utgångsportar;
  • Anslut till dina enheter;
  • Anslut enheten till strömkällan, nätadaptern ingår inte i paketet;
  • Öppna https://192.168.88.1 i din webbläsare för att starta konfigurationen, användarnamn: admin och det finns inget lösenord som standard;
  • Vid behov kan enheten monteras på väggen;
  • Skruvarna med stift ingår i paketet.
Säkerhetsinformation:
  • Innan du arbetar med någon MikroTik-utrustning ska du vara medveten om farorna med elektriska kretsar och känna till vanliga metoder för att förebygga olyckor. Installatören bör känna till nätverksstrukturer, termer och koncept.
  • Använd endast den strömförsörjning och tillbehör som godkänts av tillverkaren och som finns i originalförpackningen för denna produkt.
  • Denna utrustning ska installeras av utbildad och kvalificerad personal enligt dessa installationsinstruktioner. Installatören ansvarar för att installationen av utrustningen överensstämmer med lokala och nationella elektriska koder. Försök inte ta isär, reparera eller modifiera enheten.
  • Denna produkt kan användas både inomhus och utomhus. Läs monteringsanvisningarna noga innan installationen påbörjas. Underlåtenhet att använda rätt maskinvara och konfiguration eller att följa rätt procedurer kan leda till en farlig situation för människor och skador på systemet.
  • Vi rekommenderar starkt att endast använda AC/DC-strömförsörjning för inomhusbruk.
  • Uttaget ska installeras nära utrustningen och ska vara lättillgängligt.
  • Vi kan inte garantera att inga olyckor eller skador kommer att inträffa på grund av felaktig användning av enheten. Använd denna produkt med försiktighet och använd den på egen risk!
  • Vid fel på enheten, koppla bort den från strömmen. Det snabbaste sättet är att koppla ur nätadaptern från eluttaget. Tillverkare: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
PRC - 中文. 快速指南​
warning
此设备需要升级到 SwOS v2.18 版本以确保符合当地政府法规! 最终用户有责任遵守当地国家法规。所有 MikroTik 设备都必须经过专业安装。
本快速指南介绍了以下型号:FTC11XG.
这是网络设备。 您可以在包装箱标签(ID)上找到产品型号名称。
请访问https://mt.lv/um-zh 上的用户手册页面,以获取最新的用户手册。 或使用手机扫描QR码。
该产品最重要的技术规格可在本快速指南的最后一页找到。
有关产品的技术规格,手册和更多信息, 请访问https://mikrotik.com/products
可以在以下位置找到使用您的语言的软件配置手册以及更多信息 https://mt.lv/help-zh
MikroTik设备是专业用途。 如果您没有资格,请寻求顾问https://mikrotik.com/consultants
第一步:
  • 用螺絲刀擰開中心螺絲,然後取下塑料蓋;
  • 掩護下有以太網和SFP輸出端口;
  • 連接到您的設備;
  • 将设备连接到电源,包装中不包含电源适配器;
  • 在Web浏览器中打开 https://192.168.88.1
  • 如果需要,可以將設備安裝在牆上;
  • 包裝中包含帶定位銷的螺釘。
安全信息:
  • 在使用任何MikroTik设备之前,请注意电路所涉及的危险,并熟悉防止事故的标准做法。 安装程序应熟悉网络结构,术语和概念。
  • 仅使用制造商认可的电源和附件,这些电源和附件可在该产品的原始包装中找到。
  • 根据这些安装说明,应由经过培训的合格人员来安装本设备。 安装程序负责确保设备的安装符合当地和国家的电气法规。 请勿尝试拆卸,修理或改装设备。
  • 本产品可在室内和室外使用。 请在开始安装前仔细阅读安装说明。 不使用正确的硬件和配置或不遵循正确的程序可能会导致人员危险和系统损坏。
  • 我们强烈建议仅将 AC/DC 电源用于室内用例。
  • 插座应安装在设备附近且易于插拔的位置。
  • 由于设备使用不当,我们不能保证不会发生任何事故或损坏。 请谨慎使用本产品,风险自负!
  • 如果设备发生故障,请断开电源。 最快的方法是从电源插座上拔下电源适配器。 制造商:Mikrotikls SIA,拉脱维亚Unijas iela 2, Riga,LV1039。
RU - Русский. Краткое пособие. Евразийский экономический союз информация​
warning
Это устройство необходимо обновить до версии SwOS v2.18, чтобы обеспечить соответствие требованиям местных властей! Конечные пользователи несут ответственность за соблюдение местных правил страны. Все устройства MikroTik должны быть установлены профессионально.
Краткое руководство охватывает модель: FTC11XG.
Это беспроводное сетевое устройство. Вы можете найти название модели продукта на ярлыке кейса (ID).
Пожалуйста, посетите страницу руководства пользователя на https://mt.lv/um-ru, чтобы ознакомиться с полным актуальным руководством пользователя. Или отсканируйте QR-код с помощью мобильного телефона.
Наиболее важные технические характеристики этого продукта можно найти на последней странице этого Краткого руководства.
Технические характеристики, брошюры и дополнительная информация о продуктах на https://mikrotik.com/products
Руководство по настройке программного обеспечения на вашем языке с дополнительной информацией можно найти по адресу https://mt.lv/help-ru
Устройства MikroTik предназначены для профессионального использования. Если у вас нет квалификации, пожалуйста, обратитесь к консультанту https://mikrotik.com/consultants
Первые шаги:
  • С помощью отвертки открутите центральный винт и снимите пластиковую крышку;
  • Под крышкой расположены порты Ethernet и SFP;
  • Подключаться к вашим устройствам;
  • Подключите устройство к источнику питания, адаптер питания в комплект не входит;
  • Откройте https://192.168.88.1 в своем веб-браузере, чтобы начать настройку, имя пользователя: admin и пароль по умолчанию отсутствует;
  • При необходимости устройство можно закрепить на стене;
  • Шурупы с дюбелями входят в комплект.
Информация по технике безопасности:
  • Перед началом работы на любом оборудовании MikroTik ознакомьтесь с опасностями, связанными с электрическими цепями, и ознакомьтесь со стандартными методами предотвращения несчастных случаев. Установщик должен быть знаком с сетевыми структурами, терминами и концепциями.
  • Используйте только те источники питания и аксессуары, которые утверждены производителем и находятся в оригинальной упаковке этого продукта.
  • Это оборудование должно быть установлено обученным и квалифицированным персоналом согласно этим инструкциям по установке. Установщик несет ответственность за то, чтобы установка оборудования соответствовала местным и национальным электротехническим нормам и правилам. Не пытайтесь разбирать, ремонтировать или модифицировать устройство.
  • Этот продукт можно использовать как в помещении, так и на открытом воздухе. Перед началом установки внимательно прочтите инструкции по монтажу. Неспособность использовать правильное оборудование и конфигурацию или следовать правильным процедурам может привести к опасной ситуации для людей и повреждению системы.
  • Мы настоятельно рекомендуем использовать источник питания AC/DC тока только для использования внутри помещений.
  • Розетка должна быть установлена рядом с оборудованием и должна быть легко доступна.
  • Мы не можем гарантировать, что в результате неправильного использования устройства не произойдет несчастных случаев или повреждений. Пожалуйста, используйте этот продукт с осторожностью и действуйте на свой страх и риск!
  • В случае сбоя устройства отключите его от питания. Самый быстрый способ сделать это - отсоединить адаптер питания от электрической розетки.
Запрещается:
  • Эксплуатация роутера (точки доступа) и её комплектующих с повреждёнными шнурами электропитания;
  • Подключение роутера (точки доступа) и её комплектующих к сети электропитания при открытых корпусах;
  • Открывать корпус изделия, разбирать, извлекать электронные модули и проводить какие-либо ремонтные работы вне условий ремонтной организации.
Техническое обслуживание:
  • Роутер (точка доступа) не требует проведения профилактических работ и постоянного присутствия эксплуатационного персонала.
  • Чистка корпуса от пыли и загрязнений выполняется бумажными безворсовыми салфетками.
  • Не брызгайте водой в щели и контакты корпуса изделия.
  • Плохо выводящиеся следы и пятна удаляйте изопропиловым спиртом.
Текущий ремонт:
  • Все виды ремонта изделия допускается выполнять только аттестованным персоналом в сервисном центре предприятия-изготовителя или в другой уполномоченной изготовителем организации.
  • Замена вышедших из строя технических средств (ТС) изделия должна осуществляться на соответствующие ТС, прошедшие специальные исследования и специальную проверку.
Хранение:
  • Изделия, упакованные в ящик, следует хранить в складских помещениях при относительная влажность воздуха не более 85%, наличие в воздухе паров кислот, щелочей и прочих агрессивных примесей не допускается.
Транспортирование:
  • Транспортируют изделия всеми видами транспорта в крытых транспортных средствах в соответствии с правилами перевозки грузов, действующих на данном виде транспорта.
  • Транспортирование и хранение должны осуществляться в упаковке фирмы-изготовителя с соблюдением указаний по ориентации, защите, укладке и других, нанесенных на упаковку указаний обозначений.
  • В помещениях и транспортных средствах не должно быть паров или аэрозолей агрессивных или вызывающих коррозию веществ.
  • Упакованные изделия должны быть закреплены для предотвращения случайных неконтролируемых перемещений.
  • Транспортирование, хранение и эксплуатация не допустимы в условиях конденсации влаги без защиты от атмосферных осадков и прямых солнечных лучей.
Гарантийные обязательства:
  • Гарантийный срок эксплуатации − не более 14 суток со дня реализации потребителю.
  • Гарантийный срок хранения изделий − 12 месяцев со дня изготовления.
  • Некачественные изделия продавец обязан заменить в сроки, согласованные с потребителем.
  • В случае спора о причинах возникновения недостатков товара продавец (изготовитель), уполномоченная организация или уполномоченный индивидуальный предприниматель, импортер обязаны провести экспертизу товара за свой счет.
  • Срок устранения недостатков товара не может превышать сорок пять дней.
  • Действие гарантийных обязательств прекращается:- при нарушении потребителем правил эксплуатации, транспортирования и хранения;- при обнаружении механических повреждений, следов вскрытия, попыток неквалифицированного ремонта;- при обнаружении признаков небрежного обращения, преднамеренного повреждения оборудования;- при попадании внутрь оборудования посторонних предметов, жидкостей и насекомых;- при обнаружении признаков воздействия непреодолимых сил, приведших к выходу из строя роутера (точки доступа).
Утилизация:
  • Во избежание загрязнения окружающей среды необходимо отделить устройство от бытовых отходов и утилизировать его безопасным способом, например в специально отведенных местах. Ознакомьтесь с процедурами надлежащей транспортировки оборудования к специальным местам утилизации в вашем регионе. Информация о дате изготовления устройства указана в конце серийного номера на его наклейке через дробь. Первая цифра означает номер года (последняя цифра года), две последующие означают номер недели.
Изготовитель: SIA Mikrotikls, Aizkraukles iela 23, Riga, LV-1006, Латвия, support@mikrotik.com. Сделано в Китае, Латвии или Литве. Cм. на упаковке.
Для получения подробных сведений о гарантийном обслуживании обратитесь к продавцу.
Продукты MikroTik, которые поставляются в Евразийский таможенный союз, оцениваются с учетом соответствующих требований и помечены знаком EAC, как показано ниже:
UA - Українська. Короткий посібник​
warning
Цей пристрій потрібно оновити до випуску SwOS v2.18, щоб забезпечити відповідність нормам місцевої влади! Кінцеві користувачі несуть відповідальність за дотримання місцевих правил країни. Всі радіопристрої MikroTik повинні бути встановлені відповідно до інструкцій.
Цей короткий посібник стосується моделі: FTC11XG.
Це мережевий пристрій. Ви можете знайти назву моделі продукту на етикетці корпусу (ID).
Будь ласка, відвідайте сторінку посібника користувача на https://mt.lv/um-ua для повної оновленої версії посібника користувача. Або скануйте QR-код за допомогою мобільного телефону.
Технічні характеристики, брошури та додаткова інформація про продукцію на https://mikrotik.com/products
Найважливіші технічні характеристики цього виробу можна знайти на останній сторінці цього короткого посібника.
Посібник з налаштування програмного забезпечення вашою мовою з додатковою інформацією можна знайти за посиланням https://mt.lv/help
Пристрої MikroTik призначені для професійного використання. Якщо у вас немає кваліфікації, зверніться до консультанта https://mikrotik.com/consultants
Перші кроки:
  • За допомогою викрутки відкрутіть центральний гвинт і зніміть пластикову кришку;
  • Під кришкою є вихідні порти Ethernet та SFP;
  • Підключіться до своїх пристроїв;
  • Підключіть пристрій до джерела живлення, адаптер живлення не входить в комплект;
  • Відкрийте https://192.168.88.1 у своєму веб-браузері, щоб розпочати конфігурацію, ім'я користувача: admin, і за замовчуванням немає пароля;
  • При необхідності пристрій можна закріпити на стіні;
  • Гвинти з дюбелями входять в комплект.
Інформація про безпеку:
  • Перш ніж працювати з будь-яким обладнанням MikroTik, усвідомте небезпеку, пов’язану з електричними схемами, і ознайомтеся зі стандартними методами запобігання нещасним випадкам. Особа, що виконує роботи зі встановлення устаткування мусить бути ознайомлена із правилами роботи з мережевими системами, термінами та концепціями.
  • Використовуйте тільки адаптер електроживлення та аксесуари, затверджені виробником, і які можна знайти в оригінальній упаковці цього виробу.
  • Це обладнання має встановлювати навчений та кваліфікований персонал відповідно до цих інструкцій зі встановлення. Особа, що виконує роботи зі встановлення устаткування несе відповідальність за те, щоб встановлення обладнання відповідало місцевим і національним електричним нормам. Не намагайтеся розібрати, відремонтувати чи модифікувати пристрій.
  • Цей продукт можна використовувати як у приміщенні, так і на відкритому повітрі. Будь ласка, уважно прочитайте інструкції з монтажу перед початком установки. Невикористання належного обладнання та конфігурації або дотримання правильних процедур може призвести до небезпечної ситуації для людей та пошкодження системи.
  • Ми наполегливо рекомендуємо використовувати джерело живлення AC/DC струму лише для використання в приміщенні.
  • Розетка має бути встановлена поблизу обладнання та бути легко доступною.
  • Ми не можемо гарантувати відсутність нещасних випадків або пошкоджень через неправильне використання пристрою. Використовуйте цей продукт обережно та на свій страх і ризик!
  • У разі несправності пристрою відключіть його від електроживлення. Найшвидший спосіб це зробити — від’єднати адаптер електроживлення від розетки. Виробник: Mikrotikls SIA, Unijas iela 2, Рига, Латвія, LV1039.
Federal Communication Commission Interference Statement​
This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation.
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the equipment and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the dealer or an experienced radio/TV technician for help. FCC Caution: Any changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Note: This unit was tested with shielded cables on the peripheral devices. Shielded cables must be used with the unit to ensure compliance.
Innovation, Science and Economic Development Canada​
This device contains license-exempt transmitter(s)/receiver(s) that comply with Innovation, Science, and Economic Development Canada’s license-exempt RSS(s). Operation is subject to the following two conditions: (1) This device may not cause interference. (2) This device must accept any interference, including interference that may cause undesired operation of the device.
L’émetteur/récepteur exempt de licence contenu dans le présent appareil est conforme aux CNR d’Innovation, Sciences et Développement économique Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisée aux deux conditions suivantes: 1) L’appareil ne doit pas produire de brouillage; 2) L’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
This Class B digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe [B] est conforme à la norme NMB-003 du Canada.
CAN ICES-003 (B) / NMB-003 (B)
UKCA marking​
(EN) Technical Specifications / (DE) Technische Spezifikationen / (FR) Spécifications techniques / (IT) Specifiche tecniche / (ES) Especificaciones técnicas / (RU) Технические характеристики:
(EN) Product Power Input Options
(DE) Produkt Stromquellen Optionen
(FR) Options d'entrée d'alimentation du produit
(IT) Opzioni di ingresso alimentazione del prodotto
(ES) Opciones de entrada de energía del producto
(RU) Параметры входной мощности продукта
(EN) DC Adapter Output Specification, (V / A)
(DE) Ausgangsspezifikationen des Gleichstromadapters, (V / A)
(FR) Spécifications de sortie de l'adaptateur de courant continu, (V / A)
(IT) Specifiche di uscita dell'adattatore di corrente continua, (V / A)
(ES) Especificaciones de salida del adaptador de corriente continua, (V / A)
(RU) Выходные характеристики адаптера постоянного тока, (В / А)
(EN) IP class of the enclosure
(DE) IP-Klasse des Gehäuses
(FR) Classe IP du boîtier
(IT) Classe IP della custodia
(ES) Clase de IP del recinto
(RU) Класс защиты корпуса IP
(EN) Operating Temperature
(DE) Betriebstemperatur
(FR) température de fonctionnement
(IT) temperatura di esercizio
(ES) Temperatura de funcionamiento
(RU) Рабочая Температура
DC Jack (18-57 V DC) PoE In Ethernet port (43-57 V DC)48 / 0.95IP55-33°..+60°C
#65845
