Quick Guide - Cube 60Pro Series
This guide can be downloaded as a PDF file.
EN - English - Quick Guide
This device needs to be upgraded to RouterOS v7.13 or the latest version to ensure compliance with local authority regulations! It is the end users' responsibility to follow local country regulations, including operation within legal frequency channels, output power, cabling requirements, and Dynamic Frequency Selection (DFS) requirements. All MikroTik radio devices must be installed according to instructions.
This "Cube 60Pro" series Quick Guide covers models: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
This is a wireless network device. You can find the product model name on the case label (ID). |
First steps:
- Connect the device to the included PoE injector with Ethernet cable;
- Connect the PoE injector into the PC or to the network switch;
- Connect the power adapter to the PoE injector;
- Configuration should be made using a web browser WebFig or the WinBox configuration tool https://mt.lv/winbox; multiple configuration methods are available to ensure accessibility;
- Default IP: 192.168.88.1, user name: admin, for the paired models IP: 192.168.88.2/192.168.88.3, please find the password on the sticker;
- Click the "Check for updates" button and update RouterOS to the latest version;
- For a manual update of the device, visit mikrotik.com, select your model, and locate the required packages in the "Downloads" section;
- Upload downloaded packages to the WebFig or WinBox "Files" menu and reboot the device;
- By upgrading your RouterOS software to the latest version, you can ensure optimal performance, stability, and security updates;
- In the "QuickSet" menu set up the following: Choose your country, to apply country regulation settings;
- Set up your wireless network password in the left field;
- Set up your router password in the bottom field.
Safety Information:
- Before you work on any MikroTik equipment, be aware of the hazards involved with electrical circuitry, and be familiar with standard practices for preventing accidents. The installer should be familiar with network structures, terms, and concepts.
- Use only the power supply and accessories approved by the manufacturer, which can be found in the original packaging of this product.
- This equipment is to be installed by trained and qualified personnel, as per these installation instructions. The installer is responsible for making sure, that the Installation of the equipment is compliant with local and national electrical codes. Do not attempt to disassemble, repair, or modify the device.
- This product is intended to be mounted outdoors on a pole but can also be installed indoors. Please read the mounting instructions carefully before beginning installation. Failure to use the correct hardware and configuration or to follow the correct procedures could result in a hazardous situation for people and damage to the system.
- We cannot guarantee that no accidents or damage will occur due to the improper use of the device. Please use this product with care and operate at your own risk!
- In the case of device failure, please disconnect it from power. The fastest way to do so is by unplugging the power adapter from the power outlet.
- This is a Class A product. In a domestic environment, this product might cause radio interference in which case the user might be required to take adequate measures!
Exposure to Radio Frequency Radiation: This MikroTik equipment complies with the European Union radiation exposure limits set forth for an uncontrolled environment. This MikroTik device should be installed and operated more than 20 cm away from your body, occupational user, or the general public.
Manufacturer: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
BG - Български. Бързо ръководство
Това устройство трябва да бъде надстроено до RouterOS v7.13 или най-новата версия, за да се гарантира спазването на местните регулаторни разпоредби. Крайните потребители са отговорни за спазването на местните разпоредби, включително работата в рамките на законни честотни канали, извеждане на продукция изисквания за захранване, окабеляване и изисквания за динамичен избор на честота (DFS). Всички радиоустройства на MikroTik трябва да бъдат професионално инсталиран.
Този документ обхваща модела: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Това е устройство за безжична мрежа. Можете да намерите името на модела на продукта на етикета на регистъра (ID). |
Първи стъпки:
- Свържете устройството към включения PoE инжектор с Ethernet кабел;
- Свържете PoE инжектора към компютъра или към мрежовия превключвател;
- Свържете захранващия адаптер към PoE инжектора;
- Конфигурацията трябва да се извършва с помощта на уеб браузър WebFig или инструмента за конфигурация WinBox https://mt.lv/winbox; налични са множество методи за конфигуриране, за да се осигури достъпност;
- IP по подразбиране: 192.168.88.1, потребителско име: admin, за сдвоените модели IP: 192.168.88.2/192.168.88.3, моля, намерете паролата на стикера;
- Щракнете върху бутона "Check for updates" и актуализирайте RouterOS до най-новата версия;
- За ръчно обновяване на устройството посетете mikrotik.com, изберете модела си и намерете необходимите пакети в секцията "Downloads";
- Качете изтеглените пакети в менюто WebFig или WinBox"Files" и рестартирайте устройството;
- Чрез актуализиране на софтуера на вашия RouterOS до последната версия, можете да гарантирате оптимална производителност, стабилност и актуализации за сигурност;
- В менюто "QuickSet" настройте следното: Изберете вашата държава, за да приложите настройките за страната;
- Настройте паролата на вашата безжична мрежа в лявото поле;
- Настройте паролата на вашия рутер в долното поле.
Информация за безопасност:
- Преди да работите с всяко оборудване на MikroTik, имайте предвид опасностите, свързани с електрическата верига, и се запознайте със стандартните практики за предотвратяване на злополуки. Инсталаторът трябва да е запознат с мрежовите структури, термини и понятия.
- Използвайте само захранването и аксесоарите, одобрени от производителя, и които можете да намерите в оригиналната опаковка на този продукт.
- Това оборудване трябва да се монтира от обучен и квалифициран персонал съгласно тези инструкции за монтаж. Инсталаторът отговаря за това, че инсталирането на оборудването е в съответствие с местните и националните електрически кодове. Не се опитвайте да разглобявате, ремонтирате или модифицирате устройството.
- Този продукт е предназначен за монтиране на открито върху стълб, но може да се монтира и на закрито. Моля, прочетете внимателно инструкциите за монтаж преди да започнете инсталирането. Ако не използвате подходящия хардуер и конфигурация или не спазвате правилните процедури, това може да доведе до опасна ситуация за хората и да повреди системата на системата.
- Не можем да гарантираме, че няма злополуки или повреди поради неправилна употреба на устройството. Моля, използвайте внимателно този продукт и работете на свой риск!
- В случай на повреда на устройството, моля, изключете го от захранването. Най-бързият начин да направите това е чрез изключване на захранващия адаптер от контакта.
- Това е продукт от клас А. В домашна среда този продукт може да причини радиосмущения, като в този случай от потребителя може да се наложи да предприеме адекватни мерки!
Излагане на радиочестотно излъчване: Това оборудване MikroTik отговаря на ограниченията за радиация на радиационната радиация Европейския съюз, определени за неконтролирана среда. Това устройство MikroTik трябва да се инсталира и използва на повече от 20 см от тялото ви, от професионален потребител или от широката общественост.
Производител: Mikrotikls SIA, Unijas iela 2, Рига, Латвия, LV1039.
CS - Česko. Rychlý průvodce
Toto zařízení musí být upgradováno na RouterOS v7.13 nebo na nejnovější verzi, aby bylo zajištěno dodržování předpisů místních úřadů. Je odpovědností koncových uživatelů dodržovat místní předpisy, včetně provozu v rámci legálních frekvenčních kanálů, výstupů požadavky na napájení, kabeláž a dynamický výběr frekvence (DFS). Všechna rádiová zařízení MikroTik musí být profesionálně nainstalován.
Tato rychlá příručka „Cube 60Pro“ zahrnuje modely: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Toto je bezdrátové síťové zařízení. Název modelu produktu najdete na štítku případu (ID). |
První kroky:
- Připojte zařízení k dodávanému PoE injektoru pomocí ethernetového kabelu;
- Připojte injektor PoE k počítači nebo k síťovému přepínači;
- Připojte napájecí adaptér k injektoru PoE;
- Konfigurace by měla být provedena pomocí webového prohlížeče WebFig nebo nástroje pro konfiguraci WinBox https://mt.lv/winbox; je k dispozici více konfiguračních metod k zajištění přístupnosti;
- Výchozí IP: 192.168.88.1, uživatelské jméno: admin, u spárovaných modelů IP: 192.168.88.2/192.168.88.3 najdete heslo na nálepce;
- Klikněte na tlačítko "Check for updates" a aktualizujte RouterOS na nejnovější verzi;
- Pro manuální aktualizaci zařízení navštivte mikrotik.com, vyberte svůj model a najděte požadované balíčky v sekci "Downloads";
- Nahrajte stažené balíčky do nabídky WebFig nebo WinBox"Files" a restartujte zařízení;
- Aktualizací softwaru RouterOS na nejnovější verzi zajistíte optimální výkon, stabilitu a aktualizace zabezpečení;
- V nabídce "QuickSet" proveďte následující nastavení: Vyberte svou zemi, abyste aplikovali nastavení pro regulaci země;
- Nastavte heslo k bezdrátové síti v levém poli;
- Nastavte heslo k vašemu routeru v dolním poli.
Bezpečná informace:
- Než začnete pracovat na jakémkoli zařízení MikroTik, uvědomte si rizika spojená s elektrickými obvody a seznamte se se standardními postupy pro předcházení nehodám. Instalátor by měl být obeznámen se síťovými strukturami, termíny a koncepty.
- Používejte pouze napájecí zdroj a příslušenství schválené výrobcem, které najdete v originálním balení tohoto produktu.
- Toto zařízení musí instalovat vyškolený a kvalifikovaný personál podle těchto pokynů k instalaci. Instalátor odpovídá za to, že instalace zařízení je v souladu s místními a národními elektrickými předpisy. Nepokoušejte se zařízení rozebírat, opravovat ani upravovat.
- Tento produkt je určen k montáži venku na sloup, ale lze jej instalovat i uvnitř. Před zahájením instalace si pozorně přečtěte montážní pokyny. Pokud nepoužijete odpovídající hardware a konfiguraci nebo nebudete dodržovat správné postupy, může to mít za následek nebezpečnou situaci pro lidi a poškození systému.
- Nemůžeme zaručit, že v důsledku nesprávného používání zařízení nedojde k nehodám nebo poškození. Tento produkt používejte opatrně a používejte jej na vlastní nebezpečí!
- V případě poruchy zařízení jej prosím odpojte od napájení. Nejrychlejším způsobem je odpojení napájecího adaptéru ze zásuvky.
- Toto je produkt třídy A. V domácím prostředí může tento produkt způsobovat rádiové rušení. V takovém případě může být uživatel požádán, aby přijal odpovídající opatření!
Vystavení vysokofrekvenčnímu záření: Toto zařízení MikroTik splňuje limity pro ozáření Evropské unie stanovené pro nekontrolované prostředí. Toto zařízení MikroTik by mělo být instalováno a provozováno ve vzdálenosti větší než 20 cm od vašeho těla, od uživatele v zaměstnání nebo od široké veřejnosti.
Výrobce: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
DA - Dansk. Hurtig guide
Denne enhed skal opgraderes til RouterOS v7.13 eller den nyeste version for at sikre overholdelse af lokale myndigheders regler. Det er slutbrugerens ansvar at følge lokale landes regler, herunder drift inden for lovlige frekvenskanaler, output strøm, kablingskrav og DFS-krav (Dynamic Frequency Selection). Alle MikroTik-radioenheder skal være professionelt installeret.
Dette dokument dækker modellen: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Dette er trådløs netværksenhed. Du kan finde produktmodelnavnet på sagetiketten (ID). |
Første trin:
- Tilslut enheden til den inkluderede PoE-injektor med Ethernet-kabel;
- Tilslut PoE-injektoren til pc'en eller til netværksafbryderen;
- Tilslut strømadapteren til PoE-injektoren;
- Konfigurationen skal foretages ved hjælp af webbrowseren WebFig eller konfigurationsværktøjet WinBox https://mt.lv/winbox; flere konfigurationsmetoder er tilgængelige for at sikre tilgængelighed;
- Standard IP: 192.168.88.1, brugernavn: admin, for de parrede modeller IP: 192.168.88.2/192.168.88.3 skal du finde adgangskoden på klistermærket;
- Klik på knappen "Check for updates", og opdater RouterOS til den nyeste version;
- For manuel opdatering af enheden, besøg mikrotik.com, vælg din model og find de nødvendige pakker i sektionen "Downloads";
- Upload downloadede pakker til menuen WebFig eller WinBox"Files" og genstart enheden;
- Ved at opgradere din RouterOS-software til den nyeste version sikrer du optimal ydeevne, stabilitet og sikkerhedsopdateringer;
- I menuen "QuickSet" konfigurer følgende: Vælg dit land for at anvende landsreguleringsindstillinger;
- Indstil dit trådløse netværkspassword i det venstre felt;
- Indstil dit routerpassword i bundfeltet.
Sikkerhedsoplysninger:
- Inden du arbejder med MikroTik-udstyr, skal du være opmærksom på farerne i forbindelse med elektriske kredsløb og kende almindelig praksis til forebyggelse af ulykker. Installationsprogrammet skal være bekendt med netværksstrukturer, vilkår og koncepter.
- Brug kun strømforsyningen og det tilbehør, der er godkendt af producenten, og som findes i den originale emballage til dette produkt.
- Dette udstyr skal installeres af uddannet og kvalificeret personale i henhold til disse installationsinstruktioner. Installatøren er ansvarlig for at sikre, at installationen af udstyret er i overensstemmelse med lokale og nationale elektriske koder. Forsøg ikke at adskille, reparere eller ændre enheden.
- Dette produkt er beregnet til at blive monteret udendørs på en stang, men kan også installeres indendørs. Læs monteringsvejledningen omhyggeligt, inden installationen påbegyndes. Undladelse af at bruge den korrekte hardware og konfiguration eller at følge de korrekte procedurer kan resultere i en farlig situation for mennesker og skade på syste m.
- Vi kan ikke garantere, at der ikke vil ske ulykker eller skader på grund af forkert brug af enheden. Brug dette produkt med omhu og betjen det på egen risiko!
- I tilfælde af fejl på enheden skal du frakoble det fra strømmen. Den hurtigste måde at gøre det er ved at tage stikket ud af stikkontakten.
- Dette er et klasse A-produkt. I et hjemligt miljø kan dette produkt forårsage radiointerferens, i hvilket tilfælde brugeren muligvis skal træffe passende foranstaltninger!
Eksponering for radiofrekvensstråling: Dette MikroTik-udstyr overholder EU's strålingseksponeringsgrænser, der er fastsat for et ukontrolleret miljø. Denne MikroTik-enhed skal installeres og betjenes mere end 20 cm væk fra din krop, en erhvervsmæssig bruger eller offentligheden.
Producent: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
DE - Deutsche. Kurzanleitung
Dieses Gerät muss auf RouterOS v7.13 oder die neueste Version aktualisiert werden, um die Einhaltung der örtlichen behördlichen Vorschriften zu gewährleisten. Es liegt in der Verantwortung des Endbenutzers, die örtlichen Vorschriften zu befolgen, einschließlich des Betriebs innerhalb der gesetzlichen Frequenzkanäle und der Ausgabe Anforderungen an Stromversorgung, Verkabelung und dynamische Frequenzauswahl (Dynamic Frequency Selection, DFS). Alle MikroTik Funkgeräte müssen professionell installiert.
Diese Kurzanleitung behandelt das Modell: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Dies ist ein drahtloses Netzwerkgerät. Den Produktmodellnamen finden Sie auf dem Gehäuseaufkleber (ID). |
Erste Schritte
- Schließen Sie das Gerät mit einem Ethernet-Kabel an den mitgelieferten PoE-Injektor an.
- Schließen Sie den PoE-Injektor an den PC oder an den Netzwerk-Switch an.
- Schließen Sie das Netzteil an den PoE-Injektor an.
- Die Konfiguration sollte mit dem Webbrowser WebFig oder dem WinBox-Konfigurationstool https://mt.lv/winbox durchgeführt werden; mehrere Konfigurationsmethoden stehen zur Verfügung, um die Barrierefreiheit sicherzustellen;
- Standard-IP: 192.168.88.1, Benutzername: admin. Für die gekoppelten Modelle IP: 192.168.88.2/192.168.88.3 finden Sie das Passwort auf dem Aufkleber.
- Klicken Sie auf die Schaltfläche "Check for updates" und aktualisieren Sie RouterOS auf die neueste Version;
- Für ein manuelles Update des Geräts besuchen Sie mikrotik.com, wählen Ihr Modell aus und finden die erforderlichen Pakete im Abschnitt "Downloads";
- Laden Sie heruntergeladene Pakete in das Menü WebFig oder WinBox"Files" hoch und starten Sie das Gerät neu;
- Durch das Aktualisieren Ihrer RouterOS-Software auf die neueste Version können Sie eine optimale Leistung, Stabilität und Sicherheitsupdates gewährleisten;
- Konfigurieren Sie im Menü "QuickSet" folgendes: Wählen Sie Ihr Land aus, um länderspezifische Einstellungen anzuwenden;
- Legen Sie Ihr drahtloses Netzwerkkennwort im linken Feld fest;
- Legen Sie Ihr Routerkennwort im unteren Feld fest.
Sicherheitsinformation:
- Bevor Sie an MikroTik-Geräten arbeiten, sollten Sie sich der Gefahren bewusst sein, die mit elektrischen Schaltkreisen verbunden sind, und sich mit den Standardverfahren zur Verhinderung von Unfällen vertraut machen. Das Installationsprogramm sollte mit Netzwerkstrukturen, Begriffen und Konzepten vertraut sein.
- Verwenden Sie nur das vom Hersteller zugelassene Netzteil und Zubehör, das in der Originalverpackung dieses Produkts enthalten ist.
- Dieses Gerät muss von geschultem und qualifiziertem Personal gemäß diesen Installationsanweisungen installiert werden. Der Installateur ist dafür verantwortlich, dass die Installation des Geräts den örtlichen und nationalen elektrischen Vorschriften entspricht. Versuchen Sie nicht, das Gerät zu zerlegen, zu reparieren oder zu modifizieren.
- Dieses Produkt ist für die Montage im Freien an einer Stange vorgesehen, kann aber auch im Innenbereich installiert werden. Bitte lesen Sie die Montageanleitung sorgfältig durch, bevor Sie mit der Installation beginnen. Wenn Sie die richtige Hardware und Konfiguration nicht verwenden oder die richtigen Verfahren nicht befolgen, kann dies zu einer gefährlichen Situation für Personen und zu Schäden am System führen.
- Wir können nicht garantieren, dass durch unsachgemäße Verwendung des Geräts keine Unfälle oder Schäden auftreten. Bitte verwenden Sie dieses Produkt mit Vorsicht und arbeiten Sie auf eigenes Risiko!
- Trennen Sie das Gerät bei einem Stromausfall vom Stromnetz. Der schnellste Weg, dies zu tun, besteht darin, das Netzteil aus der Steckdose zu ziehen.
- Dies ist ein Produkt der Klasse A. In einer häuslichen Umgebung kann dieses Produkt Funkstörungen verursachen. In diesem Fall muss der Benutzer möglicherweise angemessene Maßnahmen ergreifen!
Exposition gegenüber hochfrequenter Strahlung: Dieses MikroTik-Gerät entspricht den EU-Grenzwerten für die Strahlenexposition in unkontrollierten Umgebungen. Dieses MikroTik-Gerät sollte in einem Abstand von mehr als 20 cm zu Ihrem Körper, dem Benutzer im Beruf oder der Öffentlichkeit installiert und betrieben werden.
Hersteller: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
EL - Ελληνικά. Γρήγορος οδηγός
Αυτή η συσκευή πρέπει να αναβαθμιστεί στο RouterOS v7.13 ή την τελευταία έκδοση για να διασφαλιστεί η συμμόρφωση με τους κανονισμούς της τοπικής αυτοδιοίκησης. Είναι ευθύνη των τελικών χρηστών να ακολουθούν τους τοπικούς κανονισμούς των χωρών, συμπεριλαμβανομένης της λειτουργίας εντός των νόμιμων καναλιών συχνότητας, της παραγωγής ισχύ, απαιτήσεις καλωδίωσης και απαιτήσεις δυναμικής επιλογής συχνότητας (DFS). Όλες οι ασύρματες συσκευές MikroTik πρέπει να είναι επαγγελματικά εγκατεστημένο.
Αυτός ο γρήγορος οδηγός της σειράς "Cube 60Pro" καλύπτει τα μοντέλα: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Αυτή είναι η ασύρματη συσκευή δικτύου. Μπορείτε να βρείτε το όνομα του μοντέλου προϊόντος στην ετικέτα της θήκης (ID). |
Πρώτα βήματα:
- Συνδέστε τη συσκευή στον ενσωματωμένο εγχυτήρα PoE με καλώδιο Ethernet.
- Συνδέστε τον εγχυτήρα PoE στον υπολογιστή ή στο διακόπτη δικτύου.
- Συνδέστε το τροφοδοτικό στο PoE εγχυτήρα.
- Η ρύθμιση πρέπει να γίνει χρησιμοποιώντας τον περιηγητή WebFig ή το εργαλείο ρύθμισης WinBox https://mt.lv/winbox; διατίθενται πολλαπλές μέθοδοι ρύθμισης για να διασφαλιστεί η προσβασιμότητα;
- Προεπιλεγμένη διεύθυνση IP: 192.168.88.1, όνομα admin:, για τα ζευγαρωμένα μοντέλα IP: 192.168.88.2/192.168.88.3, βρείτε τον κωδικό πρόσβασης στο αυτοκόλλητο.
- Κάντε κλικ στο κουμπί "Check for updates" και ενημερώστε το RouterOS στην πιο πρόσφατη έκδοση.
- Για χειροκίνητη ενημέρωση της συσκευής, επισκεφθείτε το mikrotik.com, επιλέξτε το μοντέλο σας και εντοπίστε τα απαιτούμενα πακέτα στην ενότητα "Downloads";
- Μεταφορτώστε τα ληφθέντα πακέτα στο μενού WebFig ή WinBox"Files" και επανεκκινήστε τη συσκευή.
- Αναβαθμίζοντας το λογισμικό του RouterOS στην πιο πρόσφατη έκδοση, μπορείτε να εξασφαλίσετε βέλτιστη απόδοση, σταθερότητα και ενημερώσεις ασφαλείας;
- Στο μενού "QuickSet" ρυθμίστε τα εξής: Επιλέξτε τη χώρα σας, για να εφαρμόσετε ρυθμίσεις κανονισμού για τη χώρα;
- Ρυθμίστε τον κωδικό πρόσβασης του ασύρματου δικτύου σας στο αριστερό πεδίο;
- Ρυθμίστε τον κωδικό πρόσβασης του δρομολογητή σας στο κάτω πεδίο.
Πληροφορίες για την ασφάλεια:
- Πριν να εργαστείτε σε οποιοδήποτε εξοπλισμό MikroTik, να είστε ενήμεροι για τους κινδύνους που σχετίζονται με τα ηλεκτρικά κυκλώματα και να είστε εξοικειωμένοι με τις συνήθεις πρακτικές για την πρόληψη ατυχημάτων. Ο εγκαταστάτης πρέπει να είναι εξοικειωμένος με τις δομές, τους όρους και τις έννοιες του δικτύου.
- Χρησιμοποιήστε μόνο την τροφοδοσία ρεύματος και τα εξαρτήματα που έχει εγκριθεί από τον κατασκευαστή και τα οποία μπορείτε να βρείτε στην αρχική συσκευασία αυτού του προϊόντος.
- Αυτός ο εξοπλισμός πρέπει να εγκατασταθεί από εκπαιδευμένο και ειδικευμένο προσωπικό, σύμφωνα με αυτές τις οδηγίες εγκατάστασης. Ο εγκαταστάτης είναι υπεύθυνος για τη διασφάλιση της συμμόρφωσης της εγκατάστασης του εξοπλισμού με τους τοπικούς και εθνικούς ηλεκτρικούς κώδικες. Μην επιχειρήσετε να αποσυναρμολογήσετε, να επιδιορθώσετε ή να τροποποιήσετε τη συσκευή.
- Το προϊόν αυτό προορίζεται για εξωτερική τοποθέτηση σε πόλο, αλλά μπορεί επίσης να εγκατασταθεί σε εσωτερικό χώρο. Παρακαλούμε διαβάστε προσεκτικά τις οδηγίες εγκατάστασης πριν ξεκινήσετε την εγκατάσταση. Η αδυναμία χρήσης του υλικού και των ρυθμίσεων διόρθωσης ή η τήρηση των σωστών διαδικασιών μπορεί να οδηγήσει σε επικίνδυνη κατάσταση για τους ανθρώπους και βλάβες στο σύστημα.
- Δεν μπορούμε να εγγυηθούμε ότι δεν θα προκύψουν ατυχήματα ή ζημιές εξαιτίας της ακατάλληλης χρήσης της συσκευής. Χρησιμοποιείτε αυτό το προϊόν με προσοχή και λειτουργείτε με δική σας ευθύνη!
- Σε περίπτωση βλάβης της συσκευής, αποσυνδέστε την από την τροφοδοσία. Ο ταχύτερος τρόπος είναι να αποσυνδέσετε το τροφοδοτικό από την πρίζα.
- Πρόκειται για προϊόν κλάσης Α. Σε οικιακό περιβάλλον, αυτό το προϊόν μπορεί να προκαλέσει ραδιοπαρεμβολές, οπότε ο χρήστης ενδέχεται να χρειαστεί να λάβει τα κατάλληλα μέτρα!
Έκθεση σε ακτινοβολία ραδιοσυχνοτήτων: Αυτός ο εξοπλισμός MikroTik συμμορφώνεται με τα όρια έκθεσης ακτινοβολίας Ευρωπαϊκής Ένωσης που καθορίζονται για ανεξέλεγκτο περιβάλλον. Αυτή η συσκευή MikroTik πρέπει να εγκατασταθεί και να λειτουργήσει σε απόσταση μεγαλύτερη απο 20 εκατοστά από το σώμα σας, το επαγγελματικό χρήστη ή το ευρύ κοινό.
Κατασκευαστής: Mikrotikls SIA, Unijas iela 2, Ρίγα, Λετονία, LV1039.
ES - Español. Guía rápida
Este dispositivo debe actualizarse a RouterOS v7.13 o la última versión para garantizar el cumplimiento de las regulaciones de las autoridades locales. Es responsabilidad del usuario final seguir las regulaciones locales del país, incluida la operación dentro de los canales legales de frecuencia, salida alimentación, requisitos de cableado y requisitos de selección de frecuencia dinámica (DFS). Todos los dispositivos de radio MikroTik deben ser instalado profesionalmente
Esta guía rápida cubre el modelo: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Este es un dispositivo de red inalámbrica. Puede encontrar el nombre del modelo del producto en la etiqueta del caso (ID). |
Primeros pasos:
- Conecte el dispositivo al inyector PoE incluido con el cable Ethernet;
- Conecte el inyector PoE a la PC o al conmutador de red;
- Conecte el adaptador de corriente al inyector PoE;
- La configuración debe realizarse con el navegador web WebFig o la herramienta de configuración WinBox https://mt.lv/winbox; hay varios métodos de configuración disponibles para garantizar la accesibilidad;
- IP predeterminada: 192.168.88.1, nombre de usuario: admin, para los modelos emparejados IP: 192.168.88.2/192.168.88.3, busque la contraseña en la etiqueta;
- Haga clic en el botón "Check for updates" y actualice RouterOS a la última versión;
- Para actualizar manualmente el dispositivo, visite mikrotik.com, seleccione su modelo y localice los paquetes requeridos en la sección "Downloads";
- Cargue los paquetes descargados en el menú WebFig o WinBox"Files" y reinicie el dispositivo;
- Al actualizar el software RouterOS a la última versión, puede garantizar un rendimiento, estabilidad y actualizaciones de seguridad óptimos;
- En el menú "QuickSet" configure lo siguiente: Elija su país para aplicar configuraciones de regulación del país;
- Configure la contraseña de su red inalámbrica en el campo izquierdo;
- Configure la contraseña de su router en el campo inferior.
Información de seguridad:
- Antes de trabajar en cualquier equipo MikroTik, tenga en cuenta los riesgos relacionados con los circuitos eléctricos y familiarícese con las prácticas estándar para prevenir accidentes. El instalador debe estar familiarizado con las estructuras de red, los términos y los conceptos.
- Utilice solo la fuente de alimentación y los accesorios aprobados por el fabricante, y que se pueden encontrar en el embalaje original de este producto.
- Este equipo debe ser instalado por personal capacitado y calificado, según estas instrucciones de instalación. El instalador es responsable de asegurarse de que la instalación del equipo cumpla con los códigos eléctricos locales y nacionales. No intente desmontar, reparar o modificar el dispositivo.
- Este producto está diseñado para montarse en exteriores en un poste, pero también puede instalarse en interiores. Lea atentamente las instrucciones de montaje antes de comenzar la instalación. Si no se utiliza el hardware y la configuración correctos o no se siguen los procedimientos correctos, se podrían producir situaciones peligrosas para las personas y daños en el sistema.
- No podemos garantizar que no ocurran accidentes o daños debido al uso incorrecto del dispositivo. ¡Utilice este producto con cuidado y opere bajo su propio riesgo!
- En caso de falla del dispositivo, desconéctelo de la alimentación. La forma más rápida de hacerlo es desconectando el adaptador de alimentación de la toma de corriente.
- Este es un producto de clase A. ¡En un entorno doméstico, este producto puede causar interferencias de radio, en cuyo caso el usuario deberá tomar las medidas adecuadas!
Exposición a la radiación de radiofrecuencia: este equipo MikroTik cumple con los límites de exposición a la radiación de la Unión Europea establecidos para un entorno no controlado. Este dispositivo MikroTik debe instalarse y utilizarse a más de 20 cm de distancia de su cuerpo, del usuario profesional o del público en general.
Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
Información México:
Módulo inalámbrico integrado que funciona a 5 GHz, protocolo 802.11a / n / ac con antena PCB incorporada, ganancia máxima 11.5 dBi.
Módulo WiGig integrado que funciona en la banda de 60 GHz, protocolo 802.11ay con antena direccional incorporada, ganancia máxima de 30 dBi.
Canales operacionales de WIGig 58.32 GHz, 60.48 GHz, 62.64 GHz. Rango de frecuencia (potencia de salida máxima): 5725-5850 MHz (30 dBm)
Los canales de frecuencia disponibles pueden variar según el modelo y la certificación del producto.
Número de Certificado de Homologación (IFT): Ver la etiqueta del producto.
La operacion de este equipo esta sujeta a las siguientes dos condiciones:
- Es posible que este equipo o dispositivo no cause interferencia perjudicial y.
- Este equipo debe aceptar cualquier interferencia, incluyendo la que pueda causar su operacion no deseada. Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, LV-1039, Latvia.
País De Origen: Letonia; Lituania; China (Republica Popular); Estados Unidos De America; Mexico.
Por favor contacte a su distribuidor local para preguntas regionales específicas. La lista de importadores se puede encontrar en nuestra página de inicio – https://mikrotik.com/buy/latinamerica/mexico.
ET - Eestlane. Kiirjuhend
Kohaliku omavalitsuse eeskirjade järgimise tagamiseks tuleb see seade uuendada versioonile RouterOS v7.13 või uusimale versioonile. Lõppkasutajate kohustus on järgida kohaliku riigi seadusi, sealhulgas toimimist seaduslikes sageduskanalites, väljund võimsus, kaabeldusnõuded ja dünaamilise sageduse valiku (DFS) nõuded. Kõik MikroTiku raadioseadmed peavad olema professionaalselt paigaldatud.
See "Cube 60Pro" seeria lühijuhend hõlmab mudeleid: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
See on traadita võrguseade. Toote mudeli nime leiate kohvri sildilt (ID). |
Esimesed sammud:
- Ühendage seade kaasasoleva PoE-injektoriga Etherneti kaabli abil;
- Ühendage PoE-injektor arvutiga või võrgulülitiga;
- Ühendage toiteadapter PoE-injektoriga;
- Konfigureerimine tuleb teha veebibrauseri WebFig või WinBox konfigureerimisriista https://mt.lv/winbox abil; ligipääsetavuse tagamiseks on saadaval mitu seadistamismeetodit;
- Vaikimisi IP: 192.168.88.1, kasutajanimi: admin, paaritud mudelite IP: 192.168.88.2/192.168.88.3 jaoks leidke parool kleebiselt;
- Klõpsake nuppu "Check for updates" ja värskendage RouterOS uusimale versioonile;
- Seadme käsitsi uuendamiseks külastage mikrotik.com, valige oma mudel ja leidke vajalikud paketid jaotises "Downloads";
- Laadige allalaaditud paketid üles menüüsse WebFig või WinBox"Files" ja taaskäivitage seade;
- Uuendades RouterOS tarkvara viimasele versioonile, saate tagada optimaalse jõudluse, stabiilsuse ja turvavärskendused;
- Menüüs "QuickSet" konfigureerige järgmist: Valige oma riik, et rakendada riigipõhiseid seadeid;
- Seadke traadita võrgu parool vasakusse välja;
- Seadke ruuteri parool alumisse välja.
Ohutusteave:
- Enne kui töötate mõne MikroTiku seadmega, tutvuge elektriskeemidega kaasnevate ohtudega ja tutvuge õnnetuste vältimise tavapraktikaga. Installer peaks tundma võrgustruktuure, termineid ja kontseptsioone.
- Kasutage ainult tootja poolt heaks kiidetud toiteallikat ja tarvikuid, mis on selle toote originaalpakendis.
- Need seadmed peavad paigaldama väljaõppinud ja kvalifitseeritud töötajad vastavalt käesolevatele paigaldusjuhistele. Paigaldaja vastutab selle eest, et seadmed paigaldataks vastavalt kohalikele ja riiklikele elektriseadustele. Ärge üritage seadet lahti võtta, remontida ega modifitseerida.
- See toode on ette nähtud monteerimiseks välistingimustes, kuid seda saab paigaldada ka siseruumides. Enne paigaldamise alustamist lugege hoolikalt paigaldusjuhendit. Parandatud riistvara ja konfiguratsiooni kasutamata jätmine või õigete toimingute järgimata jätmine võib põhjustada inimestele ohtliku olukorra ja süsteemi kahjustada.
- Me ei saa garanteerida, et seadme ebaõige kasutamise tõttu ei juhtu õnnetusi ega kahjustusi. Kasutage seda toodet ettevaatlikult ja tegutsege omal vastutusel!
- Seadme rikke korral eraldage see vooluvõrgust. Kiireim viis selleks on toiteadapteri pistikupesast lahti ühendamine.
- See on A-klassi toode. Koduses keskkonnas võib see toode põhjustada raadiohäireid - sel juhul võidakse kasutajalt nõuda asjakohaste meetmete võtmist!
Raadiosagedusliku kiirgusega kokkupuude: see MikroTik seade vastab Euroopa Liidu kiirguskontrolli piirnormidele, mis on kehtestatud kontrollimatu keskkonna jaoks. See MikroTiku seade tuleks paigaldada ja seda tuleks kasutada rohkem kui 20 cm kaugusel teie kehast, tööalaselt kasutajalt või üldsusest.
Tootja: Mikrotikls SIA, Unijas iela 2, Riia, Läti, LV1039.
FI - Suomalainen. Pikaopas
Tämä laite on päivitettävä RouterOS v7.13 -versioon tai uusimpaan versioon, jotta varmistetaan paikallisviranomaisten määräysten noudattaminen. Loppukäyttäjien vastuulla on noudattaa paikallisia maalakeja, mukaan lukien toiminta laillisilla taajuuskanavilla, lähtö teho, kaapelointivaatimukset ja dynaamisen taajuuden valinnan (DFS) vaatimukset. Kaikkien MikroTik-radiolaitteiden on oltava ammattimaisesti asennettu.
Tämä "Cube 60Pro" -sarjan pikaopas kattaa mallit: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Tämä on langaton verkkolaite. Tuotemallin nimi löytyy kotelon etiketistä (ID). |
Ensiaskeleet:
- Kytke laite mukana toimitettuun PoE-injektoriin Ethernet-kaapelilla;
- Kytke PoE-injektori tietokoneeseen tai verkkokytkimeen;
- Kytke verkkolaite PoE-injektoriin;
- Kokoonpano tulee tehdä käyttäen verkkoselainta WebFig tai konfiguraatiotyökalua WinBox https://mt.lv/winbox; useita määritysmenetelmiä on saatavilla saavutettavuuden varmistamiseksi;
- Oletus-IP: 192.168.88.1, käyttäjänimi: admin. Paritut mallit IP: 192.168.88.2/192.168.88.3 löytyvät tarrasta;
- Napsauta "Check for updates"- painiketta ja päivitä RouterOS uusimpaan versioon;
- Laitteen manuaalista päivitystä varten siirry osoitteeseen mikrotik.com, valitse mallisi ja etsi tarvittavat paketit osiossa "Downloads";
- Lataa ladatut paketit valikkoon WebFig tai WinBox"Files" ja käynnistä laite uudelleen;
- Päivittämällä RouterOS-ohjelmiston uusimpaan versioon voit varmistaa optimaalisen suorituskyvyn, vakauden ja turvapäivitykset;
- "QuickSet"-valikossa aseta seuraavat: Valitse maasi, jotta voit soveltaa maasääntelyasetuksia;
- Aseta langattoman verkkosi salasana vasempaan kenttään;
- Aseta reitittimesi salasana alaosaan.
Turvallisuustieto:
- Ennen kuin työskentelet MikroTik-laitteiden kanssa, ole tietoinen sähköpiiriin liittyvistä vaaroista ja perehdy vakiintuneisiin käytäntöihin onnettomuuksien estämiseksi. Asentajan tulee tuntea verkkorakenteet, termit ja käsitteet.
- Käytä vain valmistajan hyväksymää virtalähdettä ja lisävarusteita, jotka löytyvät tämän tuotteen alkuperäispakkauksesta.
- Tämän laitteen saa asentaa koulutettu ja pätevä henkilöstö näiden asennusohjeiden mukaisesti. Asentajan on varmistettava, että laitteen asennus on paikallisten ja kansallisten sähkömääräysten mukainen. Älä yritä purkaa, korjata tai muokata laitetta.
- Tämä tuote on tarkoitettu asennettavaksi ulkona pylvääseen, mutta voidaan myös asentaa sisätiloihin. Lue asennusohjeet huolellisesti ennen asennuksen aloittamista. Oikeiden laitteistojen ja kokoonpanojen käyttämättä jättäminen tai oikeiden menettelytapojen noudattamatta jättäminen voi aiheuttaa vaarallisen tilanteen ihmisille ja vaurioittaa järjestelmää.
- Emme voi taata, että laitteen väärinkäytöstä ei aiheudu onnettomuuksia tai vaurioita. Käytä tätä tuotetta huolellisesti ja käytä omalla vastuulla!
- Irrota laite sähkövirrasta, jos laite vioittuu. Nopein tapa tehdä tämä on irrottaa virtalähde pistorasiasta.
- Tämä on luokan A tuote. Kotitalousympäristössä tämä tuote voi aiheuttaa radiohäiriöitä, jolloin käyttäjää saatetaan joutua toteuttamaan riittävät toimenpiteet!
Radiotaajuussäteilyaltistus: Tämä MikroTik-laite on Euroopan unionin säteilyaltistusrajojen mukainen, jotka on asetettu hallitsemattomalle ympäristölle. Tämä MikroTik-laite tulee asentaa ja sitä tulee käyttää yli 20 cm:n etäisyydellä kehostasi, ammattikäyttäjästä tai suuresta yleisöstä.
Valmistaja: Mikrotikls SIA, Unijas iela 2, Riika, Latvia, LV1039.
FR - Français. Guide rapide
Cet appareil doit être mis à niveau vers RouterOS v7.13 ou la dernière version pour garantir la conformité aux réglementations des autorités locales. Il est de la responsabilité des utilisateurs finaux de suivre les réglementations locales du pays, y compris le fonctionnement dans les canaux de fréquence légaux, la sortie les exigences d'alimentation, de câblage et de sélection dynamique de fréquence (DFS). Tous les appareils radio MikroTik doivent être installé professionnellement.
Ce document couvre le modèle: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Il s'agit d'un périphérique réseau sans fil. Vous pouvez trouver le nom du modèle du produit sur l'étiquette du boîtier (ID). |
Premiers pas:
- Connectez l'appareil à l'injecteur PoE fourni avec un câble Ethernet;
- Connectez l'injecteur PoE au PC ou au commutateur réseau;
- Connectez l'adaptateur d'alimentation à l'injecteur PoE;
- La configuration doit être effectuée à l'aide du navigateur WebFig ou de l'outil de configuration WinBox https://mt.lv/winbox; plusieurs méthodes de configuration sont disponibles pour garantir l’accessibilité;
- IP par défaut: 192.168.88.1, nom d'utilisateur: admin, pour les modèles jumelés IP: 192.168.88.2/192.168.88.3, veuillez trouver le mot de passe sur l'autocollant;
- Cliquez sur le bouton "Check for updates" et mettez à jour RouterOS vers la dernière version;
- Pour une mise à jour manuelle de l'appareil, rendez-vous sur mikrotik.com, sélectionnez votre modèle et localisez les paquets requis dans la section "Downloads";
- Téléchargez les packages téléchargés dans le menu WebFig ou WinBox"Files" et redémarrez l'appareil;
- En mettant à jour votre logiciel RouterOS vers la dernière version, vous pouvez garantir des performances optimales, une stabilité et des mises à jour de sécurité;
- Dans le menu "QuickSet", configurez ce qui suit: Choisissez votre pays pour appliquer les paramètres de régulation du pays;
- Configurez le mot de passe de votre réseau sans fil dans le champ de gauche;
- Configurez le mot de passe de votre routeur dans le champ inférieur.
Information sur la sécurité:
- Avant de travailler sur un équipement MikroTik, soyez conscient des dangers liés aux circuits électriques et familiarisez-vous avec les pratiques standard de prévention des accidents. Le programme d'installation doit être familiarisé avec les structures, les termes et les concepts du réseau.
- Utilisez uniquement l'alimentation et les accessoires approuvés par le fabricant et qui se trouvent dans l'emballage d'origine de ce produit.
- Cet équipement doit être installé par du personnel formé et qualifié, conformément à ces instructions d'installation. L'installateur est responsable de s'assurer que l'installation de l'équipement est conforme aux codes électriques locaux et nationaux. N'essayez pas de démonter, réparer ou modifier l'appareil.
- Ce produit est destiné à être monté à l'extérieur sur un poteau, mais peut également être installé à l'intérieur. Veuillez lire attentivement les instructions de montage avant de commencer l'installation. Le fait de ne pas utiliser le matériel et la configuration corrects ou de ne pas suivre les procédures correctes peut entraîner une situation dangereuse pour les personnes et endommager le système.
- Nous ne pouvons garantir qu'aucun accident ou dommage ne se produira en raison d'une mauvaise utilisation de l'appareil. Veuillez utiliser ce produit avec soin et l'utiliser à vos propres risques!
- En cas de panne de l'appareil, veuillez le déconnecter de l'alimentation. La façon la plus rapide de le faire est de débrancher l'adaptateur secteur de la prise de courant.
- Ceci est un produit de classe A. Dans un environnement domestique, ce produit peut provoquer des interférences radio, auquel cas l'utilisateur peut être amené à prendre les mesures adéquates!
Exposition aux rayonnements radiofréquences: cet équipement MikroTik est conforme aux limites d'exposition aux rayonnements Union européenne établies pour un environnement non contrôlé. Cet appareil MikroTik doit être installé et utilisé à plus de 20 cm de votre corps, de l'utilisateur professionnel ou du grand public.
Fabricant: Mikrotikls SIA, Unijas iela 2, Riga, Lettonie, LV1039.
HR - Hrvatski. Brzi vodič
Ovaj je uređaj potrebno nadograditi na RouterOS v7.13 ili najnoviju verziju kako bi se osigurala sukladnost s lokalnim propisima. Odgovornost krajnjih korisnika je da slijede lokalne propise, uključujući rad unutar legalnih frekvencijskih kanala zahtjevi za napajanje, kabliranje i zahtjevi za dinamički odabir frekvencije (DFS). Svi MikroTik radijski uređaji moraju biti profesionalno instaliran.
Ovaj "Cube 60Pro" serija Brzi vodič obuhvaća modele: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Ovo je bežični mrežni uređaj. Naziv modela proizvoda možete pronaći na naljepnici kućišta (ID). |
Prvi koraci:
- Spojite uređaj na uključeni PoE injektor pomoću Ethernet kabela;
- PoE priključite injektor na računalo ili na mrežni prekidač;
- Priključite ispravljač na PoE injektor;
- Konfiguracija se mora obaviti pomoću web preglednika WebFig ili alata za konfiguraciju WinBox https://mt.lv/winbox; dostupne su različite metode konfiguracije kako bi se osigurala pristupačnost;
- Zadani IP: 192.168.88.1, korisničko ime: admin, za uparene modele IP: 192.168.88.2/192.168.88.3, lozinku potražite na naljepnici;
- Pritisnite gumb "Check for updates" i ažurirajte RouterOS na najnoviju verziju;
- Za ručnu nadogradnju uređaja posjetite mikrotik.com, odaberite svoj model i pronađite potrebne pakete u odjeljku "Downloads";
- Učitajte preuzete pakete u izbornik WebFig ili WinBox"Files" i ponovno pokrenite uređaj;
- Ažuriranjem RouterOS softvera na najnoviju verziju možete osigurati optimalne performanse, stabilnost i sigurnosna ažuriranja;
- U "QuickSet" izborniku postavite sljedeće: Odaberite svoju zemlju da biste primijenili postavke regulacije za tu zemlju;
- Postavite lozinku za svoju bežičnu mrežu u lijevo polje;
- Postavite lozinku za svoj usmjerivač u donje polje.
Sigurnosne informacije:
- Prije nego što radite na bilo kojoj MikroTik opremi, budite svjesni opasnosti koje uključuju električni krug i upoznajte se sa standardnim postupcima za sprečavanje nezgoda. Instalacijski program trebao bi biti upoznat s mrežnim strukturama, pojmovima i konceptima.
- Koristite samo napajanje i pribor odobrene od proizvođača koji se mogu naći u originalnom pakiranju ovog proizvoda.
- Ovu opremu treba ugraditi obučeno i kvalificirano osoblje prema ovim uputama za ugradnju. Instalater je odgovoran za provjeru da je instalacija opreme u skladu s lokalnim i nacionalnim električnim propisima. Ne pokušavajte rastavljati, popravljati ili modificirati uređaj.
- Ovaj je proizvod namijenjen postavljanju vani na stup, ali može se ugraditi i u zatvorenom prostoru. Prije početka instalacije pažljivo pročitajte upute za ugradnju. Ako ne koristite ispravni hardver i konfiguraciju ili ne slijedite ispravne postupke, može doći do opasne situacije za ljude i oštećenja sustava.
- Ne možemo jamčiti da neće doći do nezgoda ili oštećenja uslijed nepravilne uporabe uređaja. Molimo koristite ovaj proizvod s pažnjom i radite na vlastiti rizik!
- U slučaju kvara uređaja, isključite ga iz napajanja. Najbrži način za to je isključivanjem mrežnog adaptera iz utičnice.
- Ovo je proizvod klase A. U domaćem okruženju, ovaj proizvod može prouzročiti radio smetnje. U tom slučaju se od korisnika može tražiti da poduzme odgovarajuće mjere!
Izloženost radiofrekvencijskom zračenju: Ova oprema MikroTik udovoljava ograničenjima izloženosti zračenju Europske unije utvrđenim za nekontrolirano okruženje. Ovaj MikroTik uređaj treba instalirati i koristiti na udaljenosti većoj od 20 cm od vašeg tijela, profesionalnog korisnika ili šire javnosti.
Proizvođač: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
HU - Magyar. Gyors útmutató
Ezt az eszközt frissíteni kell a RouterOS v7.13-ra vagy a legújabb verzióra, hogy biztosítsák a helyi hatóságok előírásainak való megfelelést. A végfelhasználók felelőssége a helyi országos előírások betartása, ideértve a törvényes frekvenciacsatornákon keresztüli működést is teljesítményre, kábelezésre és dinamikus frekvenciaválasztásra (DFS) vonatkozó követelmények. Az összes MikroTik rádiókészüléknek lennie kell szakszerűen telepítve.
Ez a "Cube 60Pro" sorozat Gyors útmutató modellekre vonatkozik: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Ez a vezeték nélküli hálózati eszköz. A terméktípus nevét a tok címkéjén (ID) találhatja meg. |
Első lépések:
- Csatlakoztassa a készüléket a mellékelt PoE injektorhoz Ethernet kábellel;
- Csatlakoztassa a PoE injektort a számítógéphez vagy a hálózati kapcsolóhoz;
- Csatlakoztassa a hálózati adaptert a PoE injektorhoz;
- A konfigurációt a WebFig webböngésző vagy a WinBox konfigurációs eszköz használatával kell elvégezni https://mt.lv/winbox; számos konfigurációs módszer áll rendelkezésre az akadálymentesség biztosításához;
- Alapértelmezett IP: 192.168.88.1, felhasználói név: admin, a párosított modellekhez kérjük IP: 192.168.88.2/192.168.88.3, keresse meg a jelszót a matricán;
- Kattintson a "Check for updates" gombra, és frissítse a RouterOS-t a legújabb verzióra;
- Az eszköz kézi frissítéséhez látogasson el a mikrotik.com oldalra, válassza ki a modelljét, és találja meg a szükséges csomagokat a "Downloads" részben;
- Töltse fel a letöltött csomagokat a WebFig vagy WinBox"Files" menübe, és indítsa újra az eszközt;
- A RouterOS szoftver frissítésével a legújabb verzióra optimális teljesítményt, stabilitást és biztonsági frissítéseket biztosíthat;
- A "QuickSet" menüben állítsa be a következőket: Válassza ki az országát a szabályozási beállítások alkalmazásához;
- Állítsa be a vezeték nélküli hálózati jelszavát a bal oldali mezőben;
- Állítsa be a router jelszavát az alsó mezőben.
Biztonsági információk:
- Mielőtt bármilyen MikroTik berendezésen dolgozik, tisztában kell lennie az elektromos áramkörökkel kapcsolatos veszélyekkel, és ismernie kell a balesetek megelőzésére szolgáló szokásos gyakorlatokat. A telepítőnek ismeri a hálózati struktúrákat, a fogalmakat és a fogalmakat.
- Csak a gyártó által jóváhagyott tápegységet és tartozékokat használjon, amelyek a termék eredeti csomagolásában találhatók.
- Ezt a felszerelést képzett és képesített személyzetnek kell telepítenie, a jelen telepítési útmutató szerint. A telepítő felel annak biztosításáért, hogy a berendezés telepítése megfeleljen a helyi és az országos elektromos szabályoknak. Ne kísérelje meg szétszerelni, megjavítani vagy átalakítani a készüléket.
- Ezt a terméket szabadon, rúdra történő felszerelésre tervezték, de beltérben is fel lehet szerelni. A telepítés megkezdése előtt olvassa el figyelmesen a szerelési útmutatót. A helyes hardver és konfiguráció használata vagy a helyes eljárások be nem tartása az emberek számára veszélyes helyzetet és a rendszer károsodását eredményezheti.
- Nem garantálhatjuk, hogy a készülék nem megfelelő használata miatt balesetek vagy károk nem következhetnek be. Kérjük, használja ezt a terméket körültekintően és működtesse a saját felelősségét!
- Eszköz meghibásodása esetén kérjük, húzza ki a tápkábelt. A leggyorsabb módszer erre az, ha a hálózati adaptert kihúzza a konnektorból.
- Ez egy A osztályú termék. Háztartási környezetben ez a termék rádióinterferenciát okozhat, ebben az esetben a felhasználót szükség lehet megfelelő intézkedések megtételére!
Rádiófrekvencia-sugárzás: Ez a MikroTik berendezés megfelel az Európai Unió sugárterhelési határértékeinek, amelyeket egy ellenőrizetlen környezetre vonatkoznak. Ezt a MikroTik eszközt legalább 20 cm távolságra kell telepíteni és üzemeltetni a testétől, a foglalkozásszerű felhasználótól vagy a nyilvánosságtól.
Gyártó: Mikrotikls SIA, Unijas iela 2, Riga, Lettország, LV1039.
ID - Bahasa Indonesia. Panduan Cepat
Perangkat ini perlu ditingkatkan ke RouterOS v7.13 atau versi terbaru untuk memastikan kepatuhan terhadap peraturan otoritas setempat! Pengguna akhir bertanggung jawab untuk mengikuti peraturan negara setempat, termasuk pengoperasian dalam saluran frekuensi resmi, daya keluaran, persyaratan perkabelan, dan persyaratan Pemilihan Frekuensi Dinamis (DFS). Semua perangkat radio MikroTik harus diinstal sesuai petunjuk.
Panduan Cepat seri "Cube 60Pro" ini mencakup model: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Ini adalah perangkat jaringan nirkabel. Anda dapat menemukan nama model produk pada label casing (ID).
Kunjungi halaman panduan pengguna di https://mt.lv/um untuk mendapatkan panduan pengguna terbaru dan lengkap. Atau pindai kode QR dengan ponsel Anda. |
Langkah pertama:
- Hubungkan perangkat ke injektor PoE yang disertakan dengan kabel Ethernet;
- Hubungkan injektor PoE ke PC atau ke sakelar jaringan;
- Hubungkan adaptor daya ke injektor PoE;
- Konfigurasi harus dilakukan menggunakan peramban web WebFig atau alat konfigurasi WinBox https://mt.lv/winbox; berbagai metode konfigurasi tersedia untuk memastikan aksesibilitas;
- IP default: 192.168.88.1, nama pengguna: admin, untuk model berpasangan IP: 192.168.88.2/192.168.88.3, temukan sandi pada stiker;
- Klik tombol "Check for updates" dan perbarui RouterOS ke versi terbaru;
- Untuk pembaruan manual perangkat, kunjungi mikrotik.com, pilih model Anda, dan temukan paket yang diperlukan di bagian "Downloads";
- Unggah paket yang diunduh ke menu WebFig atau WinBox"Files" dan reboot perangkat;
- Dengan mengupgrade perangkat lunak RouterOS Anda ke versi terbaru, Anda dapat memastikan kinerja, stabilitas, dan pembaruan keamanan yang optimal;
- Dalam menu "QuickSet" atur yang berikut ini: Pilih negara Anda, untuk menerapkan pengaturan peraturan negara;
- Atur kata sandi jaringan nirkabel Anda di kolom kiri;
- Siapkan kata sandi router Anda di kolom bawah.
Informasi keselamatan:
- Sebelum Anda mengerjakan peralatan MikroTik apa pun, waspadai bahaya yang terkait dengan sirkuit listrik, dan pahami praktik standar untuk mencegah kecelakaan. Pemasang harus memahami struktur, istilah, dan konsep jaringan.
- Gunakan hanya catu daya dan aksesori yang disetujui oleh produsen, yang dapat ditemukan dalam kemasan asli produk ini.
- Peralatan ini harus dipasang oleh personel yang terlatih dan berkualifikasi, sesuai petunjuk pemasangan ini. Pemasang bertanggung jawab untuk memastikan bahwa Pemasangan peralatan mematuhi peraturan kelistrikan lokal dan nasional. Jangan mencoba membongkar, memperbaiki, atau memodifikasi perangkat.
- Produk ini dimaksudkan untuk dipasang di luar ruangan pada tiang tetapi juga dapat dipasang di dalam ruangan. Harap baca petunjuk pemasangan dengan cermat sebelum memulai pemasangan. Kegagalan dalam menggunakan perangkat keras dan konfigurasi yang benar atau mengikuti prosedur yang benar dapat mengakibatkan situasi berbahaya bagi manusia dan kerusakan pada sistem.
- Kami tidak dapat menjamin bahwa tidak akan terjadi kecelakaan atau kerusakan akibat penggunaan perangkat yang tidak tepat. Harap gunakan produk ini dengan hati-hati dan pengoperasian dengan risiko Anda sendiri!
- Jika terjadi kegagalan perangkat, harap putuskan sambungannya dari listrik. Cara tercepat untuk melakukannya adalah dengan mencabut adaptor daya dari stopkontak.
- Ini adalah produk Kelas A. Di lingkungan rumah tangga, produk ini dapat menyebabkan interferensi radio sehingga pengguna mungkin perlu mengambil tindakan yang memadai!
Paparan Radiasi Frekuensi Radio: Peralatan MikroTik ini mematuhi batas paparan radiasi Uni Eropa yang ditetapkan untuk lingkungan yang tidak terkendali. Perangkat MikroTik ini harus dipasang dan dioperasikan lebih dari 20 cm dari tubuh Anda, pengguna profesional, atau masyarakat umum.
Pabrikan: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
IT - Italiano. Guida veloce
Questo dispositivo deve essere aggiornato a RouterOS v7.13 o alla versione più recente per garantire la conformità alle normative delle autorità locali. È responsabilità dell'utente finale seguire le normative locali locali, incluso il funzionamento nei canali di frequenza legali, in uscita requisiti di alimentazione, cablaggio e selezione della frequenza dinamica (DFS). Tutti i dispositivi radio MikroTik devono essere installato professionalmente.
Questa guida rapida copre il modello: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Questo è un dispositivo di rete wireless. È possibile trovare il nome del modello del prodotto sull'etichetta della custodia (ID). |
Primi passi:
- Collegare il dispositivo all'iniettore PoE incluso con cavo Ethernet;
- Collegare l'iniettore PoE al PC o allo switch di rete;
- Collegare l'alimentatore all'iniettore PoE;
- La configurazione deve essere effettuata utilizzando il browser WebFig o lo strumento di configurazione WinBox https://mt.lv/winbox; sono disponibili diversi metodi di configurazione per garantire l’accessibilità;
- IP predefinito: 192.168.88.1, nome utente: admin, per i modelli accoppiati IP: 192.168.88.2/192.168.88.3, trovare la password sull'adesivo;
- Fare clic sul pulsante "Check for updates" e aggiornare RouterOS all'ultima versione;
- Per aggiornare manualmente il dispositivo, visitare mikrotik.com, selezionare il modello e individuare i pacchetti necessari nella sezione "Downloads";
- Carica i pacchetti scaricati nel menu WebFig o WinBox"Files" e riavvia il dispositivo;
- Aggiornando il software RouterOS alla versione più recente, puoi garantire prestazioni ottimali, stabilità e aggiornamenti di sicurezza;
- Nel menu "QuickSet" imposta quanto segue: Scegli il tuo paese per applicare le impostazioni di regolamentazione nazionale;
- Imposta la password della tua rete wireless nel campo sinistro;
- Imposta la password del tuo router nel campo inferiore.
Informazioni sulla sicurezza:
- Prima di lavorare su qualsiasi apparecchiatura MikroTik, prestare attenzione ai pericoli connessi con i circuiti elettrici e conoscere le pratiche standard per la prevenzione degli incidenti. Il programma di installazione dovrebbe avere familiarità con le strutture, i termini e i concetti della rete.
- Utilizzare solo l'alimentatore e gli accessori approvati dal produttore e che si trovano nella confezione originale di questo prodotto.
- Questa apparecchiatura deve essere installata da personale addestrato e qualificato, secondo queste istruzioni di installazione. L'installatore è responsabile di assicurarsi che l'installazione dell'apparecchiatura sia conforme ai codici elettrici locali e nazionali. Non tentare di smontare, riparare o modificare il dispositivo.
- Questo prodotto è progettato per essere montato all'esterno su un palo ma può anche essere installato all'interno. Leggere attentamente le istruzioni di montaggio prima di iniziare l'installazione. Il mancato utilizzo dell'hardware e della configurazione corretti o il rispetto delle procedure corrette potrebbe comportare una situazione pericolosa per le persone e danni al sistema.
- Non possiamo garantire che non si verifichino incidenti o danni dovuti all'uso improprio del dispositivo. Utilizzare questo prodotto con cura e operare a proprio rischio!
- In caso di guasto del dispositivo, scollegarlo dall'alimentazione. Il modo più rapido per farlo è scollegare l'alimentatore dalla presa di corrente.
- Questo è un prodotto di classe A. In un ambiente domestico, questo prodotto potrebbe causare interferenze radio, nel qual caso all'utente potrebbe essere richiesto di adottare misure adeguate!
Esposizione alle radiazioni di radiofrequenza: questa apparecchiatura MikroTik è conforme ai limiti di esposizione alle radiazioni dell'Unione Europea stabiliti per un ambiente non controllato. Questo dispositivo MikroTik deve essere installato e utilizzato a una distanza di almeno 20 cm dal corpo dell'utente, dell'operatore o del pubblico in generale.
Produttore: Mikrotikls SIA, Unijas iela 2, Riga, Lettonia, LV1039.
IS - Íslensku. Fljótur leiðarvísir
Það þarf að uppfæra þetta tæki í RouterOS v7.13 eða nýjustu útgáfuna til að tryggja samræmi við reglugerðir sveitarfélaga. Það er ábyrgð notendanna að fylgja reglugerðum á staðnum, þar með talið rekstri innan löglegra tíðnisviða, framleiðsla afl, kaðall kröfur og Dynamic Frequency Val (DFS) kröfur. Öll MikroTik útvarpstæki verða að vera faglega sett upp.
Þessi „Cube 60Pro“ röð flýtileiðbeiningar ná yfir gerðir: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Þetta er þráðlaust net tæki. Þú getur fundið heiti vörulíkansins á merkimiðanum (ID). |
Fyrstu skrefin:
- Tengdu tækið við meðfylgjandi inndælingartæki með PoE með Ethernet snúru;
- Tengdu PoE inndælingartækið við tölvuna eða við netrofinn;
- Tengdu rafmagnsinnstunguna við PoE inndælingartækið;
- Stillingin þarf að vera framkvæmd með WebFig eða WinBox stillingartólun https://mt.lv/winbox; margar stillingaraðferðir eru í boði til að tryggja aðgengi;
- Sjálfgefið IP: 192.168.88.1, notandanafn: admin, fyrir pöruð módel IP: 192.168.88.2/192.168.88.3, vinsamlegast finndu lykilorðið á límmiðanum;
- Smelltu á "Check for updates" hnappinn og uppfærðu RouterOS í nýjustu útgáfuna;
- Til að uppfæra tækið handvirkt, farðu á mikrotik.com, veldu módelið þitt og finndu nauðsynlegu pakkana í kaflanum "Downloads";
- Hladdu niður niðurhaluðum pakka í WebFig eða WinBox"Files" valmyndina og endurræstu tækið;
- Með því að uppfæra RouterOS hugbúnaðinn á nýjustu útgáfu getur þú tryggt besta árangur, stöðugleika og öryggisuppfærslur;
- Í "QuickSet" valmyndinni stilltu eftirfarandi: Veldu landið þitt til að nota landsreglugerðarstillingar;
- Stilltu lykilorðið fyrir þitt þráðlausa net í vinstra reitnum;
- Stilltu lykilorðið fyrir routerinn þinn í neðra reitnum.
Öryggisupplýsingar:
- Áður en þú vinnur að einhverjum MikroTik búnaði, vertu meðvituð um hættuna sem fylgir rafrásum og kynntu þér venjur til að koma í veg fyrir slys. Uppsetningarforritið ætti að vera kunnugt um netkerfi, hugtök og hugtök.
- Notaðu aðeins aflgjafa og fylgihluti sem framleiðandi hefur samþykkt og er að finna í upprunalegum umbúðum þessarar vöru.
- Þessum búnaði skal setja upp af þjálfuðu og hæfu starfsfólki samkvæmt þessum uppsetningarleiðbeiningum. Uppsetningaraðilinn ber ábyrgð á því að uppsetning búnaðarins sé í samræmi við staðbundin og innlend rafmagnsnúmer. Ekki reyna að taka tækið í sundur, gera við eða breyta því.
- Þessari vöru er ætlað að vera úti á stöng en einnig er hægt að setja hana innandyra. Vinsamlegast lestu festingarleiðbeiningarnar vandlega áður en þú byrjar að setja upp. Bilun í að nota leiðréttan vélbúnað og stillingar eða fylgja réttum aðferðum gæti leitt til hættulegra aðstæðna fyrir fólki og skemmdum á kerfinu.
- Við getum ekki ábyrgst að engin slys eða skemmdir muni verða vegna óviðeigandi notkunar tækisins. Vinsamlegast notaðu þessa vöru með varúð og starfaðu á eigin ábyrgð!
- Ef bilun í tæki, vinsamlegast aftengdu það frá rafmagni. Skjótasta leiðin til þess er með því að taka rafmagnstengið úr sambandi.
- Þetta er A-vara. Í innlendu umhverfi gæti þessi vara valdið truflunum á útvarpi og þá gæti verið krafist þess að notandinn geri fullnægjandi ráðstafanir!
Útsetning fyrir útvarpsbylgjugeislun: Þessi MikroTik búnaður er í samræmi við geislunarmörk Evrópusambandsins sem sett eru fyrir stjórnlaust umhverfi. Þetta MikroTik tæki ætti að vera sett upp og notað í meira en 20 cm fjarlægð frá líkama þínum, notanda í vinnu eða almenningi.
Framleiðandi: Mikrotikls SIA, Unijas iela 2, Riga, Lettlandi, LV1039.
NO - Norsk. Hurtiginnføring
Denne enheten må oppgraderes til RouterOS v7.13 eller den nyeste versjonen for å sikre samsvar med lokale myndighetsbestemmelser. Det er sluttbrukernes ansvar å følge lokale lands forskrifter, inkludert drift innen lovlige frekvenskanaler, output strøm, kabling og krav til dynamisk frekvensvalg (DFS). Alle MikroTik-radioenheter må være profesjonelt installert.
Denne hurtigveiledningen dekker modellen: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Dette er trådløs nettverksenhet. Du kan finne produktmodellnavnet på etiketten (ID). |
Første steg:
- Koble enheten til den medfølgende PoE-injektoren med Ethernet-kabel;
- Koble PoE-injektoren til PCen eller til nettverksbryteren;
- Koble strømadapteren til PoE-injektoren;
- Konfigurasjonen må gjøres ved hjelp av nettleseren WebFig eller konfigurasjonsverktøyet WinBox https://mt.lv/winbox; flere konfigurasjonsmetoder er tilgjengelige for å sikre tilgjengelighet;
- Standard IP: 192.168.88.1, brukernavn: admin. For de sammenkoblede modellene IP: 192.168.88.2/192.168.88.3, vennligst finn passordet på klistremerket;
- Klikk på "Check for updates"- knappen og oppdater RouterOS til den nyeste versjonen;
- For manuell oppdatering av enheten, gå til mikrotik.com, velg modellen din og finn de nødvendige pakkene i seksjonen "Downloads";
- Last ned nedlastede pakker til WebFig eller WinBox"Files"- menyen og start enheten på nytt;
- Ved å oppgradere RouterOS-programvaren til den nyeste versjonen, kan du sikre optimal ytelse, stabilitet og sikkerhetsoppdateringer;
- I "QuickSet" -menyen setter du opp følgende: Velg landet ditt for å bruke landsreguleringsinnstillinger;
- Sett opp passordet for det trådløse nettverket ditt i det venstre feltet;
- Sett opp passordet for ruteren din i det nedre feltet.
Sikkerhetsinformasjon:
- Før du jobber med MikroTik-utstyr, må du være oppmerksom på farene som er forbundet med elektriske kretsløp, og kjenne til standard praksis for å forhindre ulykker. Installasjonsprogrammet skal være kjent med nettverksstrukturer, vilkår og konsepter.
- Bruk bare strømforsyningen og tilbehøret som er godkjent av produsenten, og som finnes i originalemballasjen til dette produktet.
- Dette utstyret skal installeres av trent og kvalifisert personell i henhold til denne installasjonsinstruksen. Installatøren er ansvarlig for at installasjonen av utstyret er i samsvar med lokale og nasjonale elektriske koder. Ikke prøv å demontere, reparere eller endre enheten.
- Dette produktet er ment å være montert utendørs på en stolpe, men kan også installeres innendørs. Les monteringsanvisningene nøye før du begynner installasjonen. Unnlatelse av å bruke den rette maskinvaren og konfigurasjonen eller å følge de riktige prosedyrene kan føre til en farlig situasjon for mennesker og skade på syste m.
- Vi kan ikke garantere at ingen ulykker eller skader vil oppstå på grunn av feil bruk av enheten. Bruk dette produktet med forsiktighet og bruk det på egen risiko!
- Ved feil på enheten må du koble den fra strømmen. Den raskeste måten å gjøre det på er ved å trekke ut strømadapteren fra stikkontakten.
- Dette er et produkt i klasse A. I hjemlige omgivelser kan dette produktet forårsake radioforstyrrelser, i hvilket tilfelle brukeren kan bli pålagt å treffe tilstrekkelige tiltak!
Eksponering for radiofrekvensstråling: Dette MikroTik-utstyret er i samsvar med EUs strålingseksponeringsgrenser som er angitt for et ukontrollert miljø. Denne MikroTik-enheten skal installeres og brukes mer enn 20 cm fra kroppen din, en yrkesmessig bruker eller allmennheten.
Produsent: Mikrotikls SIA, Unijas iela 2, Riga, Latvia, LV1039.
LT - Lietuvių. Trumpas vadovas
Šį įrenginį reikia atnaujinti į „RouterOS v7.13“ arba naujausią versiją, kad būtų užtikrinta atitiktis vietinės valdžios nuostatoms. Galutiniai vartotojai yra atsakingi už vietinių šalies įstatymų laikymąsi, įskaitant veikimą legaliais dažnių kanalais galios, kabelių ir dinaminio dažnio pasirinkimo (DFS) reikalavimai. Visi „MikroTik“ radijo prietaisai turi būti profesionaliai sumontuota.
Šis „Cube 60Pro“ serijos trumpasis vadovas apima modelius: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Tai yra belaidžio tinklo įrenginys. Produkto modelio pavadinimą galite rasti dėklo etiketėje (ID). |
Pirmieji žingsniai:
- Prijunkite įrenginį prie pridedamo „PoE“ purkštuvo Ethernet laidu;
- Prijunkite „PoE“ purkštuvą prie kompiuterio arba prie tinklo jungiklio;
- Prijunkite maitinimo adapterį prie „PoE“ purkštuko;
- Konfigūracija turi būti atlikta naudojant naršyklę WebFig arba konfigūravimo įrankį WinBox https://mt.lv/winbox; galimi keli konfigūravimo metodai prieinamumui užtikrinti;
- Numatytasis IP: 192.168.88.1, vartotojo vardas: admin, suporuotų modelių IP: 192.168.88.2/192.168.88.3 slaptažodį rasite ant lipduko;
- Spustelėkite mygtuką "Check for updates" ir atnaujinkite RouterOS į naujausią versiją;
- Norėdami rankiniu būdu atnaujinti įrenginį, eikite į mikrotik.com, pasirinkite savo modelį ir raskite reikalingus paketus skiltyje "Downloads";
- Įkelkite atsisiųstus paketus į WebFig arba WinBox"Files" meniu ir perkraukite įrenginį;
- Atnaujindami RouterOS programinę įrangą iki naujausios versijos, galite užtikrinti optimalų našumą, stabilumą ir saugumo atnaujinimus;
- Meniu "QuickSet" nustatykite šiuos parametrus: Pasirinkite savo šalį, kad galėtumėte taikyti šalies reguliavimo nustatymus;
- Nustatykite belaidžio tinklo slaptažodį kairėje srityje;
- Nustatykite maršruto slaptažodį apačioje esančioje srityje.
Saugumo informacija:
- Prieš pradėdami dirbti su bet kuria „MikroTik“ įranga, žinokite apie pavojus, susijusius su elektros grandinėmis, ir susipažinkite su standartine avarijų prevencijos praktika. Montuotojas turėtų būti susipažinęs su tinklo struktūromis, terminais ir sąvokomis.
- Naudokite tik gamintojo patvirtintus maitinimo šaltinius ir priedus, kuriuos galite rasti originalioje šio gaminio pakuotėje.
- Šią įrangą turi montuoti apmokyti ir kvalifikuoti darbuotojai, kaip numatyta šiose montavimo instrukcijose. Montuotojas yra atsakingas už tai, kad įranga būtų montuojama laikantis vietinių ir nacionalinių elektros taisyklių. Nemėginkite išardyti, taisyti ar modifikuoti įrenginio.
- Šis produktas yra skirtas montuoti lauke ant stulpo, bet taip pat gali būti montuojamas viduje. Prieš pradėdami diegimą, atidžiai perskaitykite montavimo instrukcijas. Jei nenaudosite pataisytos aparatūros ir konfigūracijos arba nesiimsite teisingų procedūrų, galite sukelti pavojingą situaciją žmonėms ir sugadinti sistemą.
- Mes negalime garantuoti, kad dėl netinkamo prietaiso naudojimo nebus jokių avarijų ar žalos. Naudokite šį gaminį atsargiai ir dirbkite savo rizika!
- Sugedus įrenginiui, atjunkite jį nuo maitinimo. Greičiausias būdas tai padaryti yra atjungus maitinimo adapterį nuo maitinimo lizdo.
- Tai yra A klasės produktas. Buitinėje aplinkoje šis produktas gali sukelti radijo trikdžius; tokiu atveju gali reikėti vartotojo imtis tinkamų priemonių!
Radijo dažnio spinduliuotės poveikis: Ši „MikroTik“ įranga atitinka Europos Sąjungos radiacijos poveikio ribas, nustatytas nekontroliuojamai aplinkai. Šis „MikroTik“ įrenginys turėtų būti montuojamas ir naudojamas daugiau nei 20 cm atstumu nuo jūsų kūno, profesinio naudotojo ar plačiosios visuomenės.
Gamintojas: Mikrotikls SIA, Unijas iela 2, Ryga, Latvija, LV1039.
LV - Latviešu. Īsa rokasgrāmata
Šīs ierīces programmatūra ir jāatjaunina uz RouterOS v7.13 vai jaunāku versiju, lai nodrošinātu atbilstību vietējās valsts noteikumiem. Gala lietotāju pienākums ir ievērot vietējos valsts normatīvus, ieskaitot darbību likumīgos frekvences kanālos, jaudas izvadi, kabeļu prasības un dinamiskās frekvences izvēles (DFS) prasības. Visām MikroTik radio ierīcēm jābūt uzstādītām atbilstoši instrukcijai.
Šī "Cube 60Pro" sērijas īsā rokasgrāmata aptver modeļus: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Šī ir bezvadu tīkla ierīce. Produkta modeļa nosaukumu varat atrast uz produkta iepakojuma (ID). |
Pirmie soļi:
- Savienojiet iekārtu ar PoE inžektoru, izmantojot Ethernet kabeli;
- Pievienojiet PoE inžektoru datoram vai citai tīkla iekārtai;
- Pievienojiet strāvas adapteri PoE inžektoram;
- Konfigurāciju ir jāveic, izmantojot WebFig pārlūku vai WinBox konfigurācijas rīku https://mt.lv/winbox; vairāki konfigurēšanas veidi ir pieejami piekļūstamības nodrošināšanai;
- Noklusējuma IP: 192.168.88.1, lietotājvārds: admin, modeļi, kuri tirgojās pāros IP: 192.168.88.2/192.168.88.3, lūdzu, meklējiet paroli uz uzlīmes;
- Noklikšķiniet uz pogas Check for updates un atjauniniet savu RouterOS programmatūru uz jaunāko versiju;
- Lai manuāli atjauninātu ierīci, apmeklējiet mikrotik.com, izvēlieties savu modeli un atrodiet nepieciešamos pakotnes sadaļā "Downloads";
- Augšupielādējiet lejupielādētās pakas izvēlnē WebFig vai WinBox "Files" un restartējiet ierīci;
- Atjauninot savu RouterOS programmatūru līdz jaunākajai versijai, varat nodrošināt optimālu veiktspēju, stabilitāti un drošības atjauninājumus;
- Sadaļā "QuickSet" iestatiet šādi: Izvēlieties savu valsti, lai piemērotu valsts regulējuma iestatījumus;
- Iestatiet savu bezvadu tīkla paroli kreisajā laukumā;
- Iestatiet savas maršruta paroli apakšējā laukumā.
Drošības informācija:
- Pirms sākat strādāt ar jebkuru MikroTik aprīkojumu, iepazīstieties ar briesmām, kas saistītas ar elektriskajām shēmām, un iepazīstieties ar standarta praksi negadījumu novēršanā. Instalētājam jāzina tīkla struktūras, termini un koncepcijas.
- Izmantojiet tikai ražotāja apstiprinātu barošanas avotu un piederumus, kas atrodami šī produkta oriģinālajā iepakojumā.
- Saskaņā ar šīm uzstādīšanas instrukcijām šo aprīkojumu jāuzstāda apmācītam un kvalificētam personālam. Uzstādītāja pienākums ir pārliecināties, ka aprīkojuma uzstādīšana atbilst vietējiem un nacionālajiem elektrības noteikumiem. Nemēģiniet ierīci izjaukt, labot vai pārveidot.
- Šis produkts ir paredzēts uzstādīšanai ārā uz staba, bet to var uzstādīt arī telpās. Pirms instalēšanas, lūdzu, uzmanīgi izlasiet montāžas instrukcijas. Nepareizas aparatūras un konfigurācijas nelietošana vai pareizu procedūru neievērošana var izraisīt bīstamu situāciju cilvēkiem un sabojāt sistēmu.
- Mēs nevaram garantēt, ka ierīces nepareizas lietošanas dēļ negadījumi vai bojājumi nenotiks. Lūdzu, izmantojiet šo produktu uzmanīgi un rīkojieties uz savu risku!
- Ierīces kļūmes gadījumā, lūdzu, atvienojiet to no strāvas. Ātrākais veids, kā to izdarīt, ir, atvienojot strāvas adapteri no kontaktligzdas.
- Šis ir A klases produkts. Sadzīves apstākļos šis izstrādājums var izraisīt radio traucējumus, un tādā gadījumā lietotājam var būt jāveic atbilstoši pasākumi!
Radiofrekvences starojuma iedarbība: Šī MikroTik iekārta atbilst Eiropas Savienības radiācijas iedarbības ierobežojumiem, kas noteikti nekontrolētai videi. Šī MikroTik ierīce jāuzstāda un jādarbina vairāk nekā 20 centimetru attālumā no ķermeņa, profesionāla lietotāja vai plašas sabiedrības.
Ražotājs: Mikrotikls SIA, Ūnijas iela 2, Rīga, Latvija, LV1039.
MT - Malti. Gwida Quick
Dan l-apparat jeħtieġ li jiġi aġġornat għal RouterOS v7.13 jew l-aħħar verżjoni biex tkun assigurata l-konformità mar-regolamenti tal-awtorità lokali. Hija r-responsabbiltà tal-utenti finali li jsegwu r-regolamenti lokali tal-pajjiż, inkluż l-operazzjoni fil-kanali tal-frekwenza legali, tal-ħruġ qawwa, ħtiġiet ta 'kejbils, u Reklamar ta' Frekwenza Dinamika (DFS). L-apparati kollha tar-radju MikroTik għandhom ikunu installat professjonalment.
Din is-serje "Cube 60Pro" Gwida ta 'malajr tkopri mudelli: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Dan huwa Apparat tan-Netwerk Wireless. Tista 'ssib l-isem tal-mudell tal-prodott fuq it-tikketta tal-każ (ID). |
L-ewwel passi:
- Qabbad it-tagħmir mal-injettur PoE inkluż mal-kejbil Ethernet;
- Qabbad l-injettur PoE fil-PC jew mal-iswiċċ tan-netwerk;
- Qabbad l-adapter tal-qawwa mal-injettur PoE;
- Il-konfigurazzjoni għandha tkun mfassla bl-użu ta 'WebFig jew l-għodda tal-konfigurazzjoni WinBox https://mt.lv/winbox; metodi multipli ta’ konfigurazzjoni huma disponibbli biex tiġi żgurata l-aċċessibbiltà;
- IP Default: 192.168.88.1, isem tal-utent: admin, għall-mudelli paired IP: 192.168.88.2/192.168.88.3, jekk jogħġbok sib il-password fuq l-istiker;
- Ikklikkja l -buttuna "Check for updates" u aġġorna RouterOS għall-aħħar verżjoni;
- Għal aġġornament manwali tal-apparat, żur mikrotik.com, agħżel il-mudell tiegħek u sib il-pakketti meħtieġa fis-sezzjoni "Downloads";
- Tella' pakketti mniżżla fil- menu WebFig jew WinBox"Files" u reboot l-apparat;
- Billi taġġorna l-software RouterOS għall-aħħar verżjoni, tista 'tiżgura prestazzjoni, stabbiltà u aġġornamenti ta' sikurezza ottimali;
- Fl-menù "QuickSet" iwaqqaf l-iskont segwenti: Agħżel pajjiżek biex tapplika settings tar-regolazzjoni tal-pajjiż;
- Isetta il-password tal-netwerk tal-wi-fi tiegħek fis-suq;
- Isetta il-password tar-router tiegħek fis-suq.
Informazzjoni dwar is-Sikurezza:
- Qabel ma taħdem fuq kwalunkwe tagħmir MikroTik, kun konxju tal-perikli involuti fiċ-ċirkwiti elettriċi u kun familjari mal-prattiki standard għall-prevenzjoni ta 'inċidenti. L-installatur għandu jkun familjari mal-istrutturi, termini u kunċetti tan-netwerk.
- Uża biss il-provvista tal-enerġija u l-aċċessorji approvati mill-manifattur, u li tista 'tinstab fl-imballaġġ oriġinali ta' dan il-prodott.
- Dan it-tagħmir għandu jkun installat minn persunal imħarreġ u kwalifikat, skont dawn l-istruzzjonijiet ta 'installazzjoni. L-installatur huwa responsabbli li jiżgura li l-Installazzjoni tat-tagħmir hija konformi mal-kodiċijiet elettriċi lokali u nazzjonali. Tippruvax tiżżarma, tissewwa jew timmodifika l-apparat.
- Dan il-prodott huwa maħsub biex jiġi mmuntat fuq barra fuq arblu iżda jista 'jiġi installat ukoll ġewwa. Jekk jogħġbok aqra l-istruzzjonijiet tal-immuntar b’attenzjoni qabel tibda l-installazzjoni. Jekk tonqos milli tuża l- hardware u l-konfigurazzjoni korretta jew issegwi l-proċeduri t-tajba tista 'tirriżulta f'sitwazzjoni perikoluża għan-nies u tagħmel ħsara lis-sistema.
- Ma nistgħux niggarantixxu li ma jseħħ l-ebda inċident jew ħsara minħabba l-użu mhux xieraq tal-apparat. Jekk jogħġbok uża dan il-prodott b'attenzjoni u tħaddem għar-riskju tiegħek!
- Fil-każ ta 'ħsara fl-apparat, jekk jogħġbok aqla' mill-enerġija. L-iktar mod mgħaġġel biex tagħmel dan huwa billi tiftaħ l-adapter tal-enerġija mill-iżbokk tad-dawl.
- Dan huwa prodott tal-Klassi A. F'ambjent domestiku, dan il-prodott jista 'jikkawża interferenza bir-radju f'liema każ l-utent jista' jkun meħtieġ li jieħu miżuri adegwati!
Esponiment għal Radjazzjoni ta 'Frekwenza tar-Radju: Dan it-tagħmir MikroTik jikkonforma mal-limiti ta' esponiment ta l-Unjoni Ewropea għar-radjazzjoni stabbiliti għal ambjent mhux kontrollat. Dan l-apparat MikroTik għandu jiġi installat u mħaddem aktar minn 20 ċentimetru 'l bogħod minn ġismek, mill-utent okkupazzjonali, jew mill-pubbliku ġenerali.
Manifattur: Mikrotikls SIA, Unijas iela 2, Riga, il-Latvja, LV1039.
NL - Nederlands. Snelgids
Dit apparaat moet worden geüpgraded naar RouterOS v7.13 of de nieuwste versie om te voldoen aan de voorschriften van de lokale autoriteiten. Het is de verantwoordelijkheid van de eindgebruiker om de lokale landelijke voorschriften, inclusief werking binnen wettelijke frequentiekanalen, te volgen vermogen, bekabelingseisen en Dynamic Frequency Selection (DFS) -vereisten. Alle MikroTik-radioapparatuur moet zijn professioneel geïnstalleerd.
Deze beknopte handleiding behandelt het model: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Dit is een draadloos netwerkapparaat. U kunt de naam van het productmodel vinden op het etiket van de behuizing (ID). |
Eerste stappen:
- Sluit het apparaat aan op de meegeleverde PoE-injector met Ethernet-kabel;
- Sluit de PoE-injector aan op de pc of op de netwerkswitch;
- Sluit de voedingsadapter aan op de PoE-injector;
- Configuratie moet worden gedaan met behulp van de WebFig-webbrowser of het WinBox-configuratiehulpprogramma https://mt.lv/winbox; er zijn meerdere configuratiemethoden beschikbaar om toegankelijkheid te waarborgen;
- Standaard IP: 192.168.88.1, gebruikersnaam: admin, voor de gekoppelde modellen IP: 192.168.88.2/192.168.88.3 vindt u het wachtwoord op de sticker;
- Klik op de knop "Check for updates" en update RouterOS naar de nieuwste versie;
- Voor een handmatige update van het apparaat, ga naar mikrotik.com, selecteer uw model en vind de benodigde pakketten in de sectie "Downloads";
- Upload gedownloade pakketten naar het menu WebFig of WinBox"Files" en start het apparaat opnieuw op;
- Door uw RouterOS-software bij te werken naar de nieuwste versie, kunt u optimale prestaties, stabiliteit en beveiligingsupdates garanderen;
- In het "QuickSet"-menu stelt u het volgende in: Kies uw land om landreguleringsinstellingen toe te passen;
- Stel uw draadloze netwerkwachtwoord in het linker veld in;
- Stel uw routerwachtwoord in het onderste veld in.
Veiligheidsinformatie:
- Voordat u aan een MikroTik-apparaat gaat werken, moet u zich bewust zijn van de gevaren van elektrische circuits en bekend zijn met de standaardpraktijken om ongevallen te voorkomen. Het installatieprogramma moet bekend zijn met netwerkstructuren, termen en concepten.
- Gebruik alleen de voeding en accessoires die zijn goedgekeurd door de fabrikant en die u kunt vinden in de originele verpakking van dit product.
- Deze apparatuur moet worden geïnstalleerd door opgeleid en gekwalificeerd personeel, volgens deze installatie-instructies. De installateur is ervoor verantwoordelijk dat de installatie van de apparatuur voldoet aan de lokale en nationale elektrische voorschriften. Probeer het apparaat niet uit elkaar te halen, te repareren of aan te passen.
- Dit product is bedoeld om buiten op een paal te worden gemonteerd, maar kan ook binnenshuis worden geïnstalleerd. Lees de montage-instructies zorgvuldig door voordat u met de installatie begint. Het niet gebruiken van de juiste hardware en configuratie of het volgen van de juiste procedures kan leiden tot een gevaarlijke situatie voor mensen en schade aan het systeem.
- We kunnen niet garanderen dat er geen ongelukken of schade zullen optreden als gevolg van oneigenlijk gebruik van het apparaat. Gebruik dit product met zorg en werk op eigen risico!
- Koppel het apparaat los van de stroom als het defect is. De snelste manier om dit te doen is door de stroomadapter uit het stopcontact te halen.
- Dit is een Klasse A-product. In een huiselijke omgeving kan dit product radio-interferentie veroorzaken, in welk geval de gebruiker mogelijk passende maatregelen moet nemen!
Blootstelling aan radiofrequente straling: deze MikroTik-apparatuur voldoet aan de EU-limieten voor blootstelling aan straling die zijn vastgelegd voor een ongecontroleerde omgeving. Dit MikroTik-apparaat moet worden geïnstalleerd en bediend op niet meer dan 20 centimeter van uw lichaam, beroepsgebruiker of het grote publiek.
Fabrikant: Mikrotikls SIA, Unijas iela 2, Riga, Letland, LV1039.
PL - Polskie. Szybka porada
To urządzenie musi zostać zaktualizowane do wersji RouterOS v7.13 lub najnowszej wersji, aby zapewnić zgodność z przepisami władz lokalnych. Użytkownicy końcowi są zobowiązani do przestrzegania lokalnych przepisów krajowych, w tym działania w ramach legalnych kanałów częstotliwości wymagania dotyczące zasilania, okablowania i dynamicznego wyboru częstotliwości (DFS). Wszystkie urządzenia radiowe MikroTik muszą być profesjonalnie zainstalowany.
Niniejsza skrócona instrukcja „Cube 60Pro” obejmuje modele: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
To jest urządzenie sieci bezprzewodowej. Nazwę modelu produktu można znaleźć na etykiecie skrzynki (ID). |
Pierwsze kroki:
- Podłącz urządzenie do dołączonego wtryskiwacza PoE za pomocą kabla Ethernet;
- Podłącz wtryskiwacz PoE do komputera lub przełącznika sieciowego;
- Podłącz zasilacz do wtryskiwacza PoE;
- Konfiguracja powinna być dokonywana za pomocą przeglądarki internetowej WebFig lub narzędzia konfiguracyjnego WinBox https://mt.lv/winbox; dostępnych jest wiele metod konfiguracji w celu zapewnienia dostępności;
- Domyślny adres IP: 192.168.88.1, nazwa użytkownika: admin, w przypadku sparowanych modeli IP: 192.168.88.2/192.168.88.3 hasło należy znaleźć na naklejce;
- Kliknij przycisk "Check for updates" i zaktualizuj RouterOS do najnowszej wersji;
- Aby ręcznie zaktualizować urządzenie, odwiedź mikrotik.com, wybierz swój model i znajdź wymagane pakiety w sekcji "Downloads";
- Prześlij pobrane pakiety do menu WebFig lub WinBox"Files" i zrestartuj urządzenie;
- Aktualizując oprogramowanie RouterOS do najnowszej wersji, zapewnisz optymalną wydajność, stabilność i aktualizacje zabezpieczeń;
- W menu "QuickSet" skonfiguruj następujące: Wybierz swój kraj, aby zastosować ustawienia regulacji krajowej;
- Skonfiguruj hasło do swojej sieci bezprzewodowej w lewym polu;
- Skonfiguruj hasło do routera w dolnym polu.
Informacje dotyczące bezpieczeństwa:
- Przed rozpoczęciem pracy z jakimkolwiek sprzętem MikroTik należy pamiętać o zagrożeniach związanych z obwodami elektrycznymi i zapoznać się ze standardowymi praktykami zapobiegania wypadkom. Instalator powinien zapoznać się ze strukturami sieci, terminami i koncepcjami.
- Używaj wyłącznie zasilacza i akcesoriów zatwierdzonych przez producenta, które znajdują się w oryginalnym opakowaniu tego produktu.
- To urządzenie powinno być zainstalowane przez przeszkolony i wykwalifikowany personel zgodnie z niniejszą instrukcją instalacji. Instalator jest odpowiedzialny za upewnienie się, że instalacja urządzenia jest zgodna z lokalnymi i krajowymi przepisami elektrycznymi. Nie należy podejmować prób demontażu, naprawy ani modyfikacji urządzenia.
- Ten produkt jest przeznaczony do montażu na zewnątrz na słupie, ale może być również instalowany wewnątrz. Proszę uważnie przeczytać instrukcję montażu przed rozpoczęciem instalacji. Niezastosowanie odpowiedniego sprzętu i konfiguracji lub nieprzestrzeganie prawidłowych procedur może spowodować zagrożenie dla ludzi i uszkodzenie systemu.
- Nie możemy zagwarantować, że nie dojdzie do wypadków ani szkód spowodowanych niewłaściwym użytkowaniem urządzenia. Proszę używać tego produktu ostrożnie i działać na własne ryzyko!
- W przypadku awarii urządzenia odłącz je od zasilania. Najszybszym sposobem jest odłączenie zasilacza od gniazdka elektrycznego.
- To jest produkt klasy A. W środowisku domowym ten produkt może powodować zakłócenia radiowe, w takim przypadku użytkownik może być zobowiązany do podjęcia odpowiednich kroków!
Ekspozycja na promieniowanie o częstotliwości radiowej: To urządzenie MikroTik jest zgodne z limitami ekspozycji na promieniowanie Unii Europejskiej określonymi dla niekontrolowanego środowiska. Urządzenie MikroTik należy instalować i obsługiwać w odległości co najmniej 20 centymetrów od ciała użytkownika zawodowego lub ogółu społeczeństwa.
Producent: Mikrotikls SIA, Unijas iela 2, Riga, Łotwa, LV1039.
PT - Português. Guia rápido
Este dispositivo precisa ser atualizado para o RouterOS v7.13 ou a versão mais recente para garantir a conformidade com os regulamentos das autoridades locais. É responsabilidade do usuário final seguir as regulamentações locais do país, incluindo a operação dentro dos canais de frequência legal, saída requisitos de alimentação, cabeamento e Seleção Dinâmica de Frequência (DFS). Todos os dispositivos de rádio MikroTik devem ser instalado profissionalmente.
Este Guia Rápido da série "Cube 60Pro" abrange os modelos: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Este é o dispositivo de rede sem fio. Você pode encontrar o nome do modelo do produto no rótulo da caixa (ID). |
Primeiros passos:
- Conecte o dispositivo ao injetor PoE incluído com cabo Ethernet;
- Conecte o injetor PoE ao PC ou ao comutador de rede;
- Conecte o adaptador de energia ao injetor PoE;
- A configuração deve ser feita usando o navegador da Web WebFig ou a ferramenta de configuração WinBox https://mt.lv/winbox; estão disponíveis vários métodos de configuração para garantir a acessibilidade;
- IP padrão: 192.168.88.1, nome de usuário: admin, para os modelos emparelhados IP: 192.168.88.2/192.168.88.3, localize a senha no adesivo;
- Clique no botão "Check for updates" e atualize o RouterOS para a versão mais recente;
- Para atualizar manualmente o dispositivo, visite mikrotik.com, selecione o seu modelo e localize os pacotes necessários na seção "Downloads";
- Carregue os pacotes baixados no menu WebFig ou WinBox"Files" e reinicie o dispositivo;
- Ao atualizar seu software RouterOS para a versão mais recente, você pode garantir desempenho, estabilidade e atualizações de segurança ideais;
- No menu "QuickSet", configure o seguinte: Escolha o seu país para aplicar as configurações de regulamentação do país;
- Configure a senha da sua rede sem fio no campo esquerdo;
- Configure a senha do seu roteador no campo inferior.
Informação de Segurança:
- Antes de trabalhar em qualquer equipamento MikroTik, esteja ciente dos riscos envolvidos nos circuitos elétricos e esteja familiarizado com as práticas padrão para prevenção de acidentes. O instalador deve estar familiarizado com estruturas, termos e conceitos de rede.
- Use apenas a fonte de alimentação e os acessórios aprovados pelo fabricante e que podem ser encontrados na embalagem original deste produto.
- Este equipamento deve ser instalado por pessoal treinado e qualificado, de acordo com estas instruções de instalação. O instalador é responsável por garantir que a instalação do equipamento esteja em conformidade com os códigos elétricos locais e nacionais. Não tente desmontar, reparar ou modificar o dispositivo.
- Este produto deve ser montado ao ar livre em um poste, mas também pode ser instalado em ambientes fechados. Leia atentamente as instruções de montagem antes de iniciar a instalação. A não utilização do hardware e configuração corretos ou do não cumprimento dos procedimentos corretos pode resultar em uma situação perigosa para as pessoas e danificar o sistema.
- Não podemos garantir que nenhum acidente ou dano ocorra devido ao uso inadequado do dispositivo. Por favor, use este produto com cuidado e opere por sua conta e risco!
- No caso de falha do dispositivo, desconecte-o da energia. A maneira mais rápida de fazer isso é desconectando o adaptador de energia da tomada.
- Este é um produto de classe A. Em um ambiente doméstico, este produto pode causar interferência de rádio. Nesse caso, pode ser necessário que o usuário tome as medidas adequadas!
Exposição à radiação de radiofrequência: Este equipamento MikroTik está em conformidade com os limites de exposição à radiação da União Europeia estabelecidos para um ambiente não controlado. Este dispositivo MikroTik deve ser instalado e operado a uma distância superior a 20 centímetros do corpo do utilizador, do utilizador profissional ou do público em geral.
Fabricante: Mikrotikls SIA, Unijas iela 2, Riga, Letônia, LV1039.
RO - Română. Ghid rapid
Acest dispozitiv trebuie actualizat la RouterOS v7.13 sau cea mai recentă versiune pentru a asigura respectarea reglementărilor autorității locale. Este responsabilitatea utilizatorilor finali să urmeze reglementările locale ale țării, inclusiv operarea în cadrul canalelor de frecvență legale cerințe de alimentare, cabluri și cerințe de selecție a frecvenței dinamice (DFS). Toate dispozitivele radio MikroTik trebuie să fie instalat profesional.
Acest Ghid rapid seria „Cube 60Pro” acoperă modele: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Acesta este dispozitivul de rețea wireless. Puteți găsi numele modelului produsului pe eticheta carcasei (ID). |
Primii pasi:
- Conectați dispozitivul la injectorul PoE inclus cu cablu Ethernet;
- Conectați injectorul PoE la PC sau la comutatorul de rețea;
- Conectați adaptorul de alimentare la injectorul PoE;
- Configurarea trebuie efectuată cu ajutorul browserului web WebFig sau a instrumentului de configurare WinBox https://mt.lv/winbox; sunt disponibile mai multe metode de configurare pentru a asigura accesibilitatea;
- IP implicit: 192.168.88.1, nume utilizator: admin, pentru modelele împerecheate IP: 192.168.88.2/192.168.88.3, vă rugăm să găsiți parola pe autocolant;
- Faceți clic pe butonul "Check for updates" și actualizați RouterOS la cea mai recentă versiune;
- Pentru actualizarea manuală a dispozitivului, accesați mikrotik.com, selectați modelul dvs. și găsiți pachetele necesare în secțiunea "Downloads";
- Încărcați pachetele descărcate în meniul WebFig sau WinBox"Files" și reporniți dispozitivul;
- Prin actualizarea software-ului RouterOS la cea mai recentă versiune, puteți asigura performanțe, stabilitate și actualizări de securitate optime;
- În meniul "QuickSet" configurați următoarele: Alegeți țara pentru a aplica setările de reglementare ale țării;
- Configurați parola rețelei wireless în câmpul din stânga;
- Configurați parola routerului în câmpul de jos.
Informații de siguranță:
- Înainte de a lucra la orice echipament MikroTik, fiți conștienți de pericolele implicate de circuitele electrice și cunoașteți practicile standard pentru prevenirea accidentelor. Programul de instalare ar trebui să fie familiarizat cu structurile, termenii și conceptele rețelei.
- Folosiți numai sursa de alimentare și accesoriile aprobate de producător și care pot fi găsite în ambalajul original al acestui produs.
- Acest echipament va fi instalat de personal instruit și calificat, conform acestor instrucțiuni de instalare. Instalatorul este responsabil să se asigure că Instalarea echipamentului respectă codurile electrice locale și naționale. Nu încercați să dezasamblați, reparați sau modificați dispozitivul.
- Acest produs este destinat să fie montat în aer liber pe un stâlp, dar poate fi instalat și în interior. Citiți cu atenție instrucțiunile de montare înainte de a începe instalarea. Nefolosirea hardware-ului și configurației corecte sau respectarea procedurilor corecte poate duce la o situație periculoasă pentru oameni și deteriorarea sistemului m.
- Nu putem garanta că nu se vor produce accidente sau daune din cauza utilizării necorespunzătoare a dispozitivului. Vă rugăm să utilizați acest produs cu grijă și să operați pe riscul dvs.!
- În cazul unei defecțiuni a dispozitivului, vă rugăm să îl deconectați de la alimentare. Cel mai rapid mod de a face acest lucru este prin a deconecta adaptorul de alimentare de la priza electrică.
- Acesta este un produs de clasa A. Într-un mediu intern, acest produs poate provoca interferențe radio, caz în care utilizatorul ar putea fi obligat să ia măsuri adecvate!
Expunerea la radiații de frecvență radio: Acest echipament MikroTik respectă limitele de expunere la radiații Uniunea Europeană stabilite pentru un mediu necontrolat. Acest dispozitiv MikroTik trebuie instalat și utilizat la o distanță mai mare de 20 de centimetri față de corp, utilizatorul ocupațional sau publicul larg.
Producător: Mikrotikls SIA, Unijas iela 2, Riga, Letonia, LV1039.
SK - Slovenský. Stručný návod
Toto zariadenie musí byť aktualizované na RouterOS v7.13 alebo na najnovšiu verziu, aby sa zabezpečilo dodržiavanie predpisov miestnych úradov. Je na koncových užívateľoch, aby dodržiavali miestne predpisy krajiny, vrátane prevádzky v rámci legálnych frekvenčných kanálov a výstupov požiadavky na energiu, kabeláž a dynamický výber frekvencie (DFS). Všetky rádiové zariadenia MikroTik musia byť profesionálne nainštalovaný.
Tento rýchly sprievodca „Cube 60Pro“ sa týka modelov: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Toto je bezdrôtové sieťové zariadenie. Názov modelu produktu nájdete na štítku prípadu (ID). |
Prvé kroky:
- Pripojte zariadenie k dodávanému injektoru PoE pomocou kábla Ethernet;
- Pripojte injektor PoE k počítaču alebo k sieťovému prepínaču;
- Pripojte napájací adaptér k injektoru PoE;
- Konfiguráciu treba vykonať pomocou webového prehliadača WebFig alebo nástroja na konfiguráciu WinBox https://mt.lv/winbox; na zabezpečenie prístupnosti sú k dispozícii viaceré metódy konfigurácie;
- Predvolená IP: 192.168.88.1, meno používateľa: admin, pre spárované modely IP: 192.168.88.2/192.168.88.3, nájdete heslo na nálepke;
- Kliknite na tlačidlo "Check for updates" a aktualizujte RouterOS na najnovšiu verziu;
- Na manuálnu aktualizáciu zariadenia navštívte mikrotik.com, vyberte svoj model a nájdite požadované balíčky v sekcii "Downloads";
- Nahrajte stiahnuté balíčky do ponuky WebFig alebo WinBox"Files" a reštartujte zariadenie;
- Aktualizáciou softvéru RouterOS na najnovšiu verziu môžete zabezpečiť optimálny výkon, stabilitu a bezpečnostné aktualizácie;
- V menu "QuickSet" nastavte nasledujúce: Vyberte svoju krajinu, aby ste aplikovali nastavenia regulácie krajiny;
- Nastavte heslo k vašej bezdrôtovej sieti v ľavom poli;
- Nastavte heslo k vášmu routeru v dolnom poli.
Bezpečnostné informácie:
- Predtým, ako začnete pracovať na akomkoľvek zariadení MikroTik, uvedomte si riziká spojené s elektrickými obvodmi a zoznámte sa so štandardnými postupmi prevencie nehôd. Inštalátor by mal byť oboznámený so sieťovými štruktúrami, pojmami a konceptmi.
- Používajte iba napájací zdroj a príslušenstvo schválené výrobcom, ktoré nájdete v pôvodnom obale tohto produktu.
- Toto zariadenie musí inštalovať školený a kvalifikovaný personál podľa týchto pokynov na inštaláciu. Inštalatér je zodpovedný za zabezpečenie toho, aby inštalácia zariadenia bola v súlade s miestnymi a národnými elektrickými predpismi. Nepokúšajte sa zariadenie rozoberať, opravovať alebo upravovať.
- Tento výrobok je určený na montáž vonku na stožiar, ale môže byť nainštalovaný aj vo vnútri. Pred začatím inštalácie si pozorne prečítajte montážne pokyny. Ak nebudete používať správny hardvér a konfiguráciu alebo nebudete postupovať správne, môže to mať za následok nebezpečnú situáciu pre ľudí a poškodenie systému.
- Nemôžeme zaručiť, že v dôsledku nesprávneho použitia zariadenia nedôjde k žiadnym nehodám alebo škodám. Tento výrobok používajte opatrne a pracujte na svoje vlastné riziko!
- V prípade poruchy zariadenia ho prosím odpojte od napájania. Najrýchlejším spôsobom je odpojenie sieťového adaptéra zo sieťovej zásuvky.
- Toto je produkt triedy A. V domácom prostredí môže tento produkt spôsobovať rádiové rušenie. V takom prípade môže byť od používateľa požadované, aby prijal primerané opatrenia!
Vystavenie vysokofrekvenčnému žiareniu: Toto zariadenie MikroTik spĺňa limity vystavenia žiareniu Európskej únie stanovené pre nekontrolované prostredie. Toto zariadenie MikroTik by malo byť nainštalované a prevádzkované vo vzdialenosti viac ako 20 centimetrov od vášho tela, od používateľa v práci alebo od širokej verejnosti.
Výrobca: Mikrotikls SIA, Unijas iela 2, Riga, Lotyšsko, LV1039.
SL - Slovenščina. Hitri vodnik
To napravo je treba nadgraditi na RouterOS v7.13 ali najnovejšo različico, da se zagotovi skladnost z lokalnimi predpisi. Končni uporabniki so odgovorni za sledenje lokalnim predpisom, vključno z delovanjem v legalnih frekvenčnih kanalih, za doseganje rezultatov napajanje, zahteve za kabliranje in zahteve za dinamično izbiro frekvence (DFS). Vse radijske naprave MikroTik morajo biti strokovno nameščen.
Ta hitri vodnik serije "Cube 60Pro" zajema modele: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
To je brezžična omrežna naprava. Ime modela izdelka najdete na nalepki (ID). |
Prvi koraki:
- Napravo priključite na priložen PoE injektor s kablom Ethernet;
- PoE injektor priključite v računalnik ali na omrežno stikalo;
- Napajalnik priključite na PoE injektor;
- Konfiguracijo je treba izvesti s pomočjo spletnega brskalnika WebFig ali orodja za konfiguracijo WinBox https://mt.lv/winbox; na voljo je več metod konfiguracije za zagotovitev dostopnosti;
- Privzeti IP: 192.168.88.1, uporabniško ime: admin, za seznanjene modele IP: 192.168.88.2/192.168.88.3, poiščite geslo na nalepki;
- Kliknite gumb "Check for updates" in posodobite RouterOS na najnovejšo različico;
- Za ročno posodobitev naprave obiščite mikrotik.com, izberite svoj model in poiščite potrebne pakete v razdelku "Downloads";
- Prenesene pakete naložite v meni WebFig ali WinBox"Files" in znova zaženite napravo;
- Z nadgradnjo programske opreme RouterOS na najnovejšo različico lahko zagotovite optimalno delovanje, stabilnost in posodobitve varnosti;
- V meniju "QuickSet" nastavite naslednje: Izberite svojo državo, da uporabite nastavitve regulacije države;
- Nastavite geslo za svoje brezžično omrežje v levem polju;
- Nastavite geslo za svoj usmerjevalnik v spodnjem polju.
Varnostne informacije:
- Pred delom na kateri koli opremi MikroTik bodite pozorni na nevarnosti, povezane z električnim vezjem, in se seznanite s standardnimi praksami za preprečevanje nesreč. Namestitveni program mora biti seznanjen z omrežnimi strukturami, izrazi in koncepti.
- Uporabljajte samo napajalnik in dodatke, ki jih je odobril proizvajalec in ki jih najdete v originalni embalaži tega izdelka.
- To opremo mora vgraditi usposobljeno in usposobljeno osebje v skladu s temi navodili za namestitev. Monter je odgovoren za to, da je namestitev opreme skladna z lokalnimi in državnimi električnimi kodeksi. Naprave ne poskušajte razstaviti, popraviti ali spremeniti.
- Ta izdelek je namenjen za namestitev na prostem na drog, vendar ga je mogoče namestiti tudi v zaprtih prostorih. Pred začetkom namestitve natančno preberite navodila za montažo. Neuporaba ustrezne strojne opreme in konfiguracije ali upoštevanje pravilnih postopkov lahko povzroči nevarne razmere za ljudi in poškoduje sistem.
- Ne moremo zagotoviti, da se zaradi nepravilne uporabe naprave ne bo zgodilo nobena nesreča ali škoda. Uporabljajte ta izdelek previdno in delujte na lastno odgovornost!
- V primeru okvare naprave jo izklopite iz napajanja. Najhitreje to storite tako, da napajalnik odklopite iz vtičnice.
- To je izdelek razreda A. V domačem okolju lahko ta izdelek povzroči radijske motnje; v tem primeru se od uporabnika zahteva, da sprejme ustrezne ukrepe!
Izpostavljenost radiofrekvenčnim sevanjem: Ta oprema MikroTik ustreza mejam izpostavljenosti sevanju Evropske unije, določenim za nenadzorovano okolje. To napravo MikroTik je treba namestiti in uporabljati več kot 20 centimetrov stran od telesa, poklicnega uporabnika ali širše javnosti.
Proizvajalec: Mikrotikls SIA, Unijas iela 2, Riga, Latvija, LV1039.
SV - Svenska. Snabb guide
Den här enheten måste uppgraderas till RouterOS v7.13 eller den senaste versionen för att säkerställa överensstämmelse med lokala myndighetsbestämmelser. Det är slutanvändarnas ansvar att följa lokala landsregler, inklusive drift inom lagliga frekvenskanaler, output kraft, kablingskrav och DFS-krav (Dynamic Frequency Selection). Alla MikroTik-radioenheter måste vara professionellt installerat.
Detta dokument täcker modellen: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Det här är trådlöst nätverksenhet. Du hittar produktmodellnamnet på etiketten (ID). |
Första stegen:
- Anslut enheten till den medföljande PoE-injektorn med Ethernet-kabel;
- Anslut PoE-injektorn till PC: n eller till nätverksomkopplaren;
- Anslut nätadaptern till PoE-injektorn;
- Konfigurationen bör göras med hjälp av webbläsaren WebFig eller konfigurationsverktyget WinBox https://mt.lv/winbox; flera konfigurationsmetoder är tillgängliga för att säkerställa tillgänglighet;
- Standard IP: 192.168.88.1, användarnamn: admin, för de parade modellerna, IP: 192.168.88.2/192.168.88.3 vänligen hitta lösenordet på klistermärket;
- Klicka på knappen "Check for updates" och uppdatera RouterOS till den senaste versionen;
- För manuell uppdatering av enheten, gå till mikrotik.com, välj din modell och hitta de nödvändiga paketen i avsnittet "Downloads";
- Ladda ner nedladdade paket till menyn WebFig eller WinBox"Files" och starta om enheten;
- Genom att uppgradera din RouterOS-programvara till den senaste versionen kan du säkerställa optimal prestanda, stabilitet och säkerhetsuppdateringar;
- I menyn "QuickSet" konfigurerar du följande: Välj ditt land för att tillämpa landsregleringsinställningar;
- Ställ in ditt trådlösa nätverkslösenord i det vänstra fältet;
- Ställ in ditt routerlösenord i det nedre fältet.
Säkerhetsinformation:
- Innan du arbetar med någon MikroTik-utrustning ska du vara medveten om farorna med elektriska kretsar och känna till vanliga metoder för att förebygga olyckor. Installatören bör känna till nätverksstrukturer, termer och koncept.
- Använd endast den strömförsörjning och tillbehör som godkänts av tillverkaren och som finns i originalförpackningen för denna produkt.
- Denna utrustning ska installeras av utbildad och kvalificerad personal enligt dessa installationsinstruktioner. Installatören ansvarar för att installationen av utrustningen överensstämmer med lokala och nationella elektriska koder. Försök inte ta isär, reparera eller modifiera enheten.
- Denna produkt är avsedd att monteras utomhus på en stolpe men kan också installeras inomhus. Läs monteringsanvisningarna noggrant innan installationen påbörjas. Underlåtenhet att använda rätt maskinvara och konfiguration eller att följa korrekta procedurer kan leda till en farlig situation för människor och skada på syste m.
- Vi kan inte garantera att inga olyckor eller skador kommer att inträffa på grund av felaktig användning av enheten. Använd denna produkt med försiktighet och använd den på egen risk!
- Vid fel på enheten, koppla bort den från strömmen. Det snabbaste sättet är att koppla ur nätadaptern från eluttaget.
- Detta är en klass A-produkt. I en hemmamiljö kan denna produkt orsaka radiostörningar, i vilket fall användaren kan behöva vidta lämpliga åtgärder!
Exponering för radiofrekvensstrålning: Denna MikroTik-utrustning överensstämmer med Europeiska unionens strålningsexponeringsgränser som anges för en okontrollerad miljö. Denna MikroTik-enhet bör installeras och användas mer än 20 centimeter från din kropp, yrkesmässigt ansvariga användare eller allmänheten.
Tillverkare: Mikrotikls SIA, Unijas iela 2, Riga, Lettland, LV1039.
PRC - 中文. 快速指南
该设备需要升级到RouterOS v7.13或最新版本,以确保符合地方当局法规。 最终用户有责任遵守当地的法规,包括在合法频道内操作,输出 电源,布线要求和动态频率选择(DFS)要求。 所有MikroTik无线电设备必须 专业安装。
此“ Cube 60Pro”系列快速指南涵盖以下型号:CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
这是无线网络设备。 您可以在包装箱标签(ID)上找到产品型号名称。 |
第一步:
- 用以太网电缆将设备连接到随附的PoE注入器;
- 将PoE注入器连接到PC或网络交换机;
- 将电源适配器连接到PoE注入器;
- 配置应使用WebFig浏览器或WinBox配置工具https://mt.lv/winbox 完成; 提供多种配置方法以确保可访问性;
- 默认IP:192.168.88.1,用户名:admin,对于配对的机型 IP: 192.168.88.2/192.168.88.3,请在贴纸上找到密码;
- 点击 "Check for updates" 按钮,将RouterOS更新到最新版本;
- 要手动更新设备,请访问 mikrotik.com,选择您的型号,并在"Downloads"部分找到所需的软件包;
- 将下载的包上传到 WebFig 或 WinBox"Files" 菜单并重启设备;
- 通过将RouterOS软件升级到最新版本,可以确保最佳性能、稳定性和安全更新;
- 在"QuickSet"菜单中设置以下内容: 选择您的国家以应用国家法规设置;
- 在左侧字段中设置您的无线网络密码;
- 在底部字段中设置您的路由器密码。
安全信息:
- 在使用任何MikroTik设备之前,请注意电路所涉及的危险,并熟悉防止事故的标准做法。 安装程序应熟悉网络结构,术语和概念。
- 仅使用制造商认可的电源和附件,这些电源和附件可在该产品的原始包装中找到。
- 根据这些安装说明,应由经过培训的合格人员来安装本设备。 安装程序负责确保设备的安装符合当地和国家的电气法规。 请勿尝试拆卸,修理或改装设备。
- 该产品旨在安装在室外的杆子上,也可以安装在室内。 在开始安装之前,请仔细阅读安装说明。 不使用 正确的硬件和配置或未遵循正确的程序可能会导致人员受伤和系统损坏 。
- 由于设备使用不当,我们不能保证不会发生任何事故或损坏。 请谨慎使用本产品,风险自负!
- 如果设备发生故障,请断开电源。 最快的方法是从电源插座上拔下电源适配器。
- 这是A类产品。 在家庭环境中,此产品可能会造成无线电干扰,在这种情况下,可能要求用户采取适当的措施! 射频辐射暴露:该 MikroTik 设备符合针对不受控制的环境规定的欧盟辐射暴露限制。 这款 MikroTik 设备应安装在距离您的身体、职业用户或公众 20 厘米以上的位置,并可进行操作。
制造商:Mikrotikls SIA,拉脱维亚Unijas iela 2, Riga,LV1039。
RU - Русский. Краткое пособие. Евразийский экономический союз информация
Это устройство должно быть обновлено до RouterOS v7.13 или до последней версии, чтобы обеспечить соответствие требованиям местных органов власти. Конечные пользователи несут ответственность за соблюдение местных нормативов, в том числе за работу в пределах допустимых частотных каналов, вывод требования к питанию, кабелям и динамическому выбору частоты (DFS). Все радиоустройства MikroTik должны быть профессионально установлены.
Краткое руководство по этой серии "Cube 60Pro" охватывает модели: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Это беспроводное сетевое устройство. Вы можете найти название модели продукта на ярлыке кейса (ID). |
Первые шаги:
- Подключите устройство к входящему в комплект инжектору PoE с помощью кабеля Ethernet;
- Подключите инжектор PoE к ПК или к сетевому коммутатору;
- Подключите адаптер питания к инжектору PoE;
- Конфигурация должна выполняться с использованием веб-браузера WebFig или инструмента конфигурации WinBox https://mt.lv/winbox; существует несколько методов настройки для обеспечения доступности;
- IP-адрес по умолчанию: 192.168.88.1, имя пользователя: admin, для парных моделей IP: 192.168.88.2/192.168.88.3, найдите пароль на наклейке;
- Нажмите кнопку "Check for updates" и обновите RouterOS до последней версии;
- Для ручного обновления устройства зайдите на mikrotik.com, выберите свою модель и найдите необходимые пакеты в разделе "Downloads";
- Загрузите скачанные пакеты в меню WebFig или WinBox"Files" и перезагрузите устройство;
- Обновив программное обеспечение RouterOS до последней версии, вы можете обеспечить оптимальную производительность, стабильность и обновления безопасности;
- В меню "QuickSet" настройте следующее: выберите свою страну, чтобы применить настройки регулирования страны;
- Установите пароль для вашей беспроводной сети в левом поле;
- Установите пароль для вашего роутера в нижнем поле.
Информация по технике безопасности:
- Перед началом работы на любом оборудовании MikroTik ознакомьтесь с опасностями, связанными с электрическими цепями, и ознакомьтесь со стандартными методами предотвращения несчастных случаев. Установщик должен быть знаком с сетевыми структурами, терминами и концепциями.
- Используйте только те источники питания и аксессуары, которые утверждены производителем и находятся в оригинальной упаковке этого продукта.
- Это оборудование должно быть установлено обученным и квалифицированным персоналом согласно этим инструкциям по установке. Установщик несет ответственность за то, чтобы установка оборудования соответствовала местным и национальным электротехническим нормам и правилам. Не пытайтесь разбирать, ремонтировать или модифицировать устройство.
- Этот продукт можно использовать как в помещении, так и на открытом воздухе. Перед началом установки внимательно прочтите инструкции по монтажу. Неспособность использовать правильное оборудование и конфигурацию или следовать правильным процедурам может привести к опасной ситуации для людей и повреждению системы.
- Мы не можем гарантировать, что в результате неправильного использования устройства не произойдет несчастных случаев или повреждений. Пожалуйста, используйте этот продукт с осторожностью и действуйте на свой страх и риск!
- В случае сбоя устройства отключите его от питания. Самый быстрый способ сделать это - вынуть вилку из розетки.
- Это продукт класса А. В домашних условиях этот продукт может вызывать радиопомехи, и в этом случае пользователю может потребоваться принять адекватные меры.
Запрещается:
- Эксплуатация роутера (точки доступа) и её комплектующих с повреждёнными шнурами электропитания;
- Подключение роутера (точки доступа) и её комплектующих к сети электропитания при открытых корпусах;
- Открыватькорпус изделия, разбирать, извлекать электронные модули и проводить какие-либо ремонтные работы вне условий ремонтной организации.
Техническое обслуживание:
- Роутер (точка доступа) не требует проведения профилактических работ и постоянного присутствия эксплуатационного персонала.
- Чистка корпуса от пыли и загрязнений выполняется бумажными безворсовыми салфетками.
- Не брызгайте водой в щели и контакты корпуса изделия.
- Плохо выводящиеся следы и пятна удаляйте изопропиловым спиртом.
Текущий ремонт:
- Все виды ремонта изделия допускается выполнять только аттестованным персоналом в сервисном центре предприятия-изготовителя или в другой уполномоченной изготовителем организации.
- Замена вышедших из строя технических средств (ТС) изделия должна осуществляться на соответствующие ТС, прошедшие специальные исследования и специальную проверку.
Хранение:
- Изделия, упакованные в ящик, следует хранить в складских помещениях при относительная влажность воздуха не более 85%, наличие в воздухе паров кислот, щелочей и прочих агрессивных примесей не допускается.
Транспортирование:
- Транспортируют изделия всеми видами транспорта в крытых транспортных средствах в соответствии с правилами перевозки грузов, действующих на данном виде транспорта.
- Транспортирование и хранение должны осуществляться в упаковке фирмы-изготовителя с соблюдением указаний по ориентации, защите, укладке и других, нанесенных на упаковку указаний обозначений.
- В помещениях и транспортных средствах не должно быть паров или аэрозолей агрессивных или вызывающих коррозию веществ.
- Упакованные изделия должны быть закреплены для предотвращения случайных неконтролируемых перемещений.
- Транспортирование, хранение и эксплуатация не допустимы в условиях конденсации влаги без защиты от атмосферных осадков и прямых солнечных лучей.
Гарантийные обязательства:
- Гарантийный срок эксплуатации − не более 14 суток со дня реализации потребителю.
- Гарантийный срок хранения изделий − 12 месяцев со дня изготовления.
- Некачественные изделия продавец обязан заменить в сроки, согласованные с потребителем.
- В случае спора о причинах возникновения недостатков товара продавец (изготовитель), уполномоченная организация или уполномоченный индивидуальный предприниматель, импортер обязаны провести экспертизу товара за свой счет.
- Срок устранения недостатков товара не может превышать сорок пять дней.
- Действие гарантийных обязательств прекращается:- при нарушении потребителем правил эксплуатации, транспортирования и хранения;- при обнаружении механических повреждений, следов вскрытия, попыток неквалифицированного ремонта;- при обнаружении признаков небрежного обращения, преднамеренного повреждения оборудования;- при попадании внутрь оборудования посторонних предметов, жидкостей и насекомых;- при обнаружении признаков воздействия непреодолимых сил, приведших к выходу из строя роутера (точки доступа).
Утилизация:
- Во избежание загрязнения окружающей среды необходимо отделить устройство от бытовых отходов и утилизировать его безопасным способом, например в специально отведенных местах. Ознакомьтесь с процедурами надлежащей транспортировки оборудования к специальным местам утилизации в вашем регионе.
Воздействие радиочастотного излучения. Это устройство MikroTik должно быть установлено и эксплуатироваться не ближе 20 сантиметров от вашего тела, профессионального пользователя или широкой публики.
Производитель: Mikrotikls SIA, улица Унияс 2, Рига, Латвия, LV1039.
Рабочие каналы WIGig 58,32 ГГц, 60,48 ГГц, 62,64 ГГц. Доступные частотные каналы могут различаться в зависимости от модели и сертификации продукта.
Частотный диапазон: 5150-5350 МГц, 5850-6100 МГц. Доступные частотные каналы могут различаться в зависимости от модели продукта и сертификации.
Информация о дате изготовления устройства указана в конце серийного номера на его наклейке через дробь. Первая цифра означает номер года (последняя цифра года), две последующие означают номер недели.
Изготовитель: SIA Mikrotikls, Aizkraukles iela 23, Riga, LV-1006, Латвия, support@mikrotik.com. Сделано в Китае, Латвии или Литве
Продукты MikroTik, которые поставляются в Евразийский таможенный союз, оцениваются с учетом соответствующих требований и помечены знаком EAC, как показано ниже:
UA - Українська. Короткий посібник
Цей пристрій потрібно оновити до RouterOS v7.13 або останньої версії, щоб забезпечити відповідність місцевим нормам влади! Кінцеві користувачі несуть відповідальність за дотримання місцевих правил, включаючи функціонування в межах законних частотних каналів, вихідну потужність, вимоги до кабелів та вимоги щодо вибору динамічної частоти (DFS). Всі радіопристрої MikroTik повинні бути встановлені відповідно до інструкцій.
Цей короткий посібник серії Cube 60Pro охоплює моделі: CubeG-5ac60ay (Cube 60Pro ac), CubeG-5ac60ay-SA (CubeSA 60Pro ac), CubeG-5ac60aypair (Wireless Wire Cube Pro).
Це пристрій бездротової мережі. Ви можете знайти назву моделі продукту на етикетці корпусу (ID). |
Перші кроки:
- Підключіть пристрій до включеного інжектора PoE за допомогою кабелю Ethernet;
- Підключіть інжектор PoE до ПК або до мережевого комутатора;
- Підключіть адаптер живлення до інжектора PoE;
- Конфігурацію слід виконувати за допомогою веб-браузера WebFig або інструменту конфігурації WinBox https://mt.lv/winbox; існує декілька методів налаштування для забезпечення доступності;
- IP за замовчуванням: 192.168.88.1, ім'я користувача: admin, для парних моделей IP: 192.168.88.2/192.168.88.3, знайдіть пароль на наклейці;
- Натисніть кнопку "Check for updates" і оновіть RouterOS до останньої версії;
- Щоб оновити пристрій вручну, відвідайте сторінку продуктів за адресою mikrotik.com, виберіть свою модель і знайдіть потрібні пакети в розділі "Downloads";
- Завантажте завантажені пакети в меню WebFig або WinBox"Files" і перезавантажте пристрій;
- Оновивши програмне забезпечення RouterOS до останньої версії, ви можете забезпечити оптимальну продуктивність, стабільність та оновлення безпеки;
- У меню "QuickSet" встановіть наступне: виберіть свою країну, щоб застосувати налаштування регулювання країни;
- Налаштуйте пароль для вашої бездротової мережі в лівому полі;
- Налаштуйте пароль для вашого маршрутизатора в нижньому полі.
Інформація про безпеку:
- Перш ніж працювати з будь-яким обладнанням MikroTik, усвідомте небезпеку, пов’язану з електричними схемами, і ознайомтеся зі стандартними методами запобігання нещасним випадкам. Особа, що виконує роботи зі встановлення устаткування мусить бути ознайомлена із правилами роботи з мережевими системами, термінами та концепціями
- Використовуйте тільки адаптер електроживлення та аксесуари, затверджені виробником, і які можна знайти в оригінальній упаковці цього виробу.
- Це обладнання має встановлювати навчений та кваліфікований персонал відповідно до цих інструкцій зі встановлення. Особа, що виконує роботи зі встановлення устаткування несе відповідальність за те, щоб встановлення обладнання відповідало місцевим і національним електричним нормам. Не намагайтеся розібрати, відремонтувати чи модифікувати пристрій.
- Цей виріб призначений для встановлення на вулиці на стовпі, але також може встановлюватися в приміщенні. Будь ласка, уважно прочитайте інструкції з монтажу перед початком установки. Якщо не використовувати правильне обладнання та конфігурацію або дотримуватися правильних процедур, це може призвести до небезпечної ситуації для людей та пошкодження системи.
- Ми не можемо гарантувати відсутність нещасних випадків або пошкоджень через неправильне використання пристрою. Використовуйте цей продукт обережно та на свій страх і ризик!
- У разі відмови пристрою, відключіть його від живлення. Найшвидший спосіб зробити це - від'єднавши адаптер живлення від розетки.
- Це продукт класу А. У побутових умовах цей продукт може спричинити радіоперешкоди, і в цьому випадку від користувача може знадобитися вжити належних заходів!
Вплив радіочастотного випромінювання: Це обладнання MikroTik відповідає нормам радіаційного опромінення Європейського Союзу, встановленим для неконтрольованого середовища. Цей пристрій MikroTik слід встановлювати та експлуатувати не ближче 20 сантиметрів від вашого тіла, професіонала чи широкого загалу.
Виробник: Mikrotikls SIA, Unijas iela 2, Рига, Латвія, LV1039.
Робоча частота (Максимальна вихідна потужність): 5150-5250 МГц (23 дБм), 5250-5350 МГц (20 дБм), 5470-5725 МГц (27 дБм), 58.32 ГГц (<40 дБм), 60.48 ГГц (<40 дБм), 62.64 ГГц (<40 дБм).
Federal Communication Commission Interference Statement
FCC ID: TV7CB5A60Y
This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a commercial installation.
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his own expense.
FCC Caution: Any changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
This device is not to be operated on aircraft except for the conditions listed on FCC CFR §15.255 (b)
IMPORTANT NOTE: FCC Radiation Exposure Statement: This equipment complies with FCC radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with a minimum distance of 20cm between the radiator & your body. All cables used to connect peripherals must be shielded and grounded. Operation with cables connected to peripherals that are not shielded and grounded may result in interference to radio and television reception.
Innovation, Science and Economic Development Canada
IC: 7442A-CB5A60Y
This device contains license-exempt transmitter(s)/receiver(s) that comply with Innovation, Science, and Economic Development Canada’s license-exempt RSS(s). Operation is subject to the following two conditions: (1) This device may not cause interference. (2) This device must accept any interference, including interference that may cause undesired operation of the device.
L’émetteur/récepteur exempt de licence contenu dans le présent appareil est conforme aux CNR d’Innovation, Sciences et Développement économique Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisée aux deux conditions suivantes: 1) L’appareil ne doit pas produire de brouillage; 2) L’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
This Class A digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe [A] est conforme à la norme NMB-003 du Canada.
CAN ICES-003 (A) / NMB-003 (A)
The device for operation in the band 5150–5250 MHz is only for indoor use to reduce the potential for harmful interference to co-channel mobile satellite systems.
Les dispositifs fonctionnant dans la bande de 5 150 à 5 250 MHz sont réservés uniquement pour une utilisation à l'intérieur afin de réduire les risques de brouillage préjudiciable aux systèmes de satellites mobiles utilisant les mêmes canaux.
This device is not to be operated on aircraft except for the conditions listed on ISED RSS-210 Annex J.1.
Cet appareil ne doit pas être utilisé sur un avion, sauf dans les conditions énumérées ISED RSS-210 Annex J.1.
IMPORTANT NOTE: IC Radiation Exposure Statement: This equipment complies with IC RSS-102 radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with a minimum distance of 20cm between the radiator & your body. Cet équipement est conforme aux limites d'exposition aux rayonnements IC établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 20cm de distance entre la source de rayonnement et votre corps.
UKCA marking
CE Declaration of Conformity
| BG | С настоящото Mikrotīkls SIA декларира, че този тип радиосъоръжение CubeG-5ac60ay, CubeG-5ac60ay-SA е в съответствие с Директива 2014/53/ЕС. Цялостният текст на ЕС декларацията за съответствие може да се намери на следния интернет адрес: https://mikrotik.com/products |
| CS | Tímto Mikrotīkls SIA prohlašuje, že typ rádiového zařízení CubeG-5ac60ay, CubeG-5ac60ay-SA je v souladu se směrnicí 2014/53/EU. Úplné znění EU prohlášení o shodě je k dispozici na této internetové adrese: https://mikrotik.com/products |
| DA | Hermed erklærer Mikrotīkls SIA, at radioudstyrstypen CubeG-5ac60ay, CubeG-5ac60ay-SA er i overensstemmelse med direktiv 2014/53/EU. EU-overensstemmelseserklæringens fulde tekst kan findes på følgende internetadresse: https://mikrotik.com/products |
| DE | Hiermit erklärt Mikrotīkls SIA, dass der Funkanlagentyp CubeG-5ac60ay, CubeG-5ac60ay-SA der Richtlinie 2014/53/EU entspricht. Der vollständige Text der EU-Konformitätserklärung ist unter der folgenden Internetadresse verfügbar: https://mikrotik.com/products |
| EL | Με την παρούσα ο/η Mikrotīkls SIA, δηλώνει ότι ο ραδιοεξοπλισμός CubeG-5ac60ay, CubeG-5ac60ay-SA πληροί την οδηγία 2014/53/ΕΕ. Το πλήρες κείμενο της δήλωσης συμμόρφωσης ΕΕ διατίθεται στην ακόλουθη ιστοσελίδα στο διαδίκτυο: https://mikrotik.com/products |
| EN | Hereby, Mikrotīkls SIA declares that the radio equipment type CubeG-5ac60ay, CubeG-5ac60ay-SA is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://mikrotik.com/products |
| ES | Por la presente, Mikrotīkls SIA declara que el tipo de equipo radioeléctrico CubeG-5ac60ay, CubeG-5ac60ay-SA es conforme con la Directiva 2014/53/UE. El texto completo de la declaración UE de conformidad está disponible en la dirección Internet siguiente: https://mikrotik.com/products |
| ET | Käesolevaga deklareerib Mikrotīkls SIA, et käesolev raadioseadme tüüp CubeG-5ac60ay, CubeG-5ac60ay-SA vastab direktiivi 2014/53/EL nõuetele. ELi vastavusdeklaratsiooni täielik tekst on kättesaadav järgmisel internetiaadressil: https://mikrotik.com/products |
| FI | Mikrotīkls SIA vakuuttaa, että radiolaitetyyppi CubeG-5ac60ay, CubeG-5ac60ay-SA on direktiivin 2014/53/EU mukainen. EU-vaatimustenmukaisuusvakuutuksen täysimittainen teksti on saatavilla seuraavassa internetosoitteessa: https://mikrotik.com/products |
| FR | Le soussigné, Mikrotīkls SIA, déclare que l'équipement radioélectrique du type CubeG-5ac60ay, CubeG-5ac60ay-SA est conforme à la directive 2014/53/UE. Le texte complet de la déclaration UE de conformité est disponible à l'adresse internet suivante: https://mikrotik.com/products |
| HR | Mikrotīkls SIA ovime izjavljuje da je radijska oprema tipa CubeG-5ac60ay, CubeG-5ac60ay-SA u skladu s Direktivom 2014/53/EU. Cjeloviti tekst EU izjave o sukladnosti dostupan je na sljedećoj internetskoj adresi: https://mikrotik.com/products |
| HU | Mikrotīkls SIA igazolja, hogy a CubeG-5ac60ay, CubeG-5ac60ay-SA típusú rádióberendezés megfelel a 2014/53/EU irányelvnek. Az EU-megfelelőségi nyilatkozat teljes szövege elérhető a következő internetes címen: https://mikrotik.com/products |
| IT | Il fabbricante, Mikrotīkls SIA, dichiara che il tipo di apparecchiatura radio CubeG-5ac60ay, CubeG-5ac60ay-SA è conforme alla direttiva 2014/53/UE. Il testo completo della dichiarazione di conformità UE è disponibile al seguente indirizzo Internet: https://mikrotik.com/products |
| IS | Hér með lýsir Mikrotīkls SIA því yfir að CubeG-5ac60ay, CubeG-5ac60ay-SA er í samræmi við grunnkröfur og aðrar kröfur, sem gerðar eru í tilskipun 2014/53/EU. Fullur texti ESB samræmisyfirlýsingar er að finna á eftirfarandi veffangi: https://mikrotik.com/products |
| LT | Aš, Mikrotīkls SIA, patvirtinu, kad radijo įrenginių tipas CubeG-5ac60ay, CubeG-5ac60ay-SA atitinka Direktyvą 2014/53/ES. Visas ES atitikties deklaracijos tekstas prieinamas šiuo interneto adresu: https://mikrotik.com/products |
| LV | Ar šo Mikrotīkls SIA deklarē, ka radioiekārta CubeG-5ac60ay, CubeG-5ac60ay-SA atbilst Direktīvai 2014/53/ES. Pilns ES atbilstības deklarācijas teksts ir pieejams šādā interneta vietnē: https://mikrotik.com/products |
| MT | B'dan, Mikrotīkls SIA, niddikjara li dan it-tip ta' tagħmir tar-radju CubeG-5ac60ay, CubeG-5ac60ay-SA huwa konformi mad-Direttiva 2014/53/UE. It-test kollu tad-dikjarazzjoni ta' konformità tal-UE huwa disponibbli f'dan l-indirizz tal-Internet li ġej: https://mikrotik.com/products |
| NL | Hierbij verklaar ik, Mikrotīkls SIA, dat het type radioapparatuur CubeG-5ac60ay, CubeG-5ac60ay-SA conform is met Richtlijn 2014/53/EU. De volledige tekst van de EU-conformiteitsverklaring kan worden geraadpleegd op het volgende internetadres: https://mikrotik.com/products |
| NO | Mikrotīkls SIA erklærer herved at utstyret CubeG-5ac60ay, CubeG-5ac60ay-SA er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 2014/53/EU. Den fulle teksten til EU-samsvarserklæringen er tilgjengelig på følgende internettadresse: https://mikrotik.com/products |
| PL | Mikrotīkls SIA niniejszym oświadcza, że typ urządzenia radiowego CubeG-5ac60ay, CubeG-5ac60ay-SA jest zgodny z dyrektywą 2014/53/UE. Pełny tekst deklaracji zgodności UE jest dostępny pod następującym adresem internetowym: https://mikrotik.com/products |
| PT | O(a) abaixo assinado(a) Mikrotīkls SIA declara que o presente tipo de equipamento de rádio CubeG-5ac60ay, CubeG-5ac60ay-SA está em conformidade com a Diretiva 2014/53/UE. O texto integral da declaração de conformidade está disponível no seguinte endereço de Internet: https://mikrotik.com/products |
| RO | Prin prezenta, Mikrotīkls SIA declară că tipul de echipamente radio CubeG-5ac60ay, CubeG-5ac60ay-SA este în conformitate cu Directiva 2014/53/UE. Textul integral al declarației UE de conformitate este disponibil la următoarea adresă internet: https://mikrotik.com/products |
| SK | Mikrotīkls SIA týmto vyhlasuje, že rádiové zariadenie typu CubeG-5ac60ay, CubeG-5ac60ay-SA je v súlade so smernicou 2014/53/EÚ. Úplné EÚ vyhlásenie o zhode je k dispozícii na tejto internetovej adrese: https://mikrotik.com/products |
| SL | Mikrotīkls SIA potrjuje, da je tip radijske opreme CubeG-5ac60ay, CubeG-5ac60ay-SA skladen z Direktivo 2014/53/EU. Celotno besedilo izjave EU o skladnosti je na voljo na naslednjem spletnem naslovu: https://mikrotik.com/products |
| SV | Härmed försäkrar Mikrotīkls SIA att denna typ av radioutrustning CubeG-5ac60ay, CubeG-5ac60ay-SA överensstämmer med direktiv 2014/53/EU. Den fullständiga texten till EU-försäkran om överensstämmelse finns på följande webbadress: https://mikrotik.com/products |
This device meets the Maximum TX power limit per ETSI regulations. The frequency is 5470-5725MHz and the maximum transmitted power is less than 27dBm. The frequency and the maximum transmitted power in the EU are listed below: 57 - 66 GHz: 34.02 dBm. An Operational mode in the 60 GHz band: 58.32 GHz, 60.48 GHz, 62.64 GHz. This device is certified for outdoor use in Point to Multipoint applications. In the following countries this device cannot be used in Fixed Point-to-Point applications:
WiGig
| Operational channels / Maximum output power Betriebskanäle / maximale Ausgangsleistung Canaux opérationnels / puissance de sortie maximale Canali operativi / massima potenza di uscita Canales operacionales / potencia de salida máxima Операционные каналы / максимальная выходная мощность | 58.32 GHz / <40 dBm |
| 60.48 GHz / <40 dBm | |
| 62.64 GHz / <40 dBm |
WLAN
Operating Frequency / Maximum output power | 5470-5725 MHz / 27 dBm |
| (EN) Technical Specifications / (DE) Technische Spezifikationen / (FR) Spécifications techniques / (IT) Specifiche tecniche / (ES) Especificaciones técnicas / (RU) Технические характеристики: | ||||
| (EN) Product Power Input Options (DE) Produkt Stromquellen Optionen (FR) Options d'entrée d'alimentation du produit (IT) Opzioni di ingresso alimentazione del prodotto (ES) Opciones de entrada de energía del producto (RU) Параметры входной мощности продукта | (EN) DC Adapter Output Specification (DE) Ausgangsspezifikationen des Gleichstromadapters (FR) Spécifications de sortie de l'adaptateur de courant continu (IT) Specifiche di uscita dell'adattatore di corrente continua (ES) Especificaciones de salida del adaptador de corriente continua (RU) Выходные характеристики адаптера постоянного тока | (EN) IP class of the enclosure (DE) IP-Klasse des Gehäuses (FR) Classe IP du boîtier (IT) Classe IP della custodia (ES) Clase de IP del recinto (RU) Класс защиты корпуса IP | (EN) Operating Temperature (DE) Betriebstemperatur (FR) température de fonctionnement (IT) temperatura di esercizio (ES) Temperatura de funcionamiento (RU) Рабочая Температура | |
| Voltage, V | Current, A | |||
| PoE In Ethernet Port (18 - 48 V DC) | 24 | 0.8 | IP66 | -33°..+70°C |
#75933
