Quick Guide - CRS106-1C-5S
This guide can be downloaded as a PDF file.
EN - English - Quick Guide
This device needs to be upgraded to RouterOS v7.13.1 or the latest version to ensure compliance with local authority regulations! It is the end users' responsibility to follow local country regulations. All MikroTik devices must be professionally installed.
This Quick Guide covers the model: CRS106-1C-5S.
This is a Network Device. You can find the product model name on the case label (ID). |
First steps:
- Connect with your PC to any Ethernet port;
- Connect the device to a power source;
- Configure the IP settings of your network card to 192.168.88.2/24;
- Use WebFig in a web browser or the "WinBox" configuration tool https://mt.lv/winbox; multiple configuration methods are available to ensure accessibility;
- Open https://192.168.88.1 in a web browser to start setup. If the IP address is unavailable, use WinBox and choose the "Neighbors" tab to find the device. Proceed to connect using the MAC address. The username is "admin", and there is no password (or, for some models, check user and wireless passwords on the sticker);
- Click the "Check for updates" button and update RouterOS to the latest version;
- For a manual update of the device, visit mikrotik.com, select your model, and locate the required packages in the "Downloads" section;
- Upload downloaded packages to the WebFig or WinBox "Files" menu and reboot the device;
- By upgrading your RouterOS software to the latest version, you can ensure optimal performance, stability, and security updates;
- Set up your router password.
Safety Information:
- Before you work on any MikroTik equipment, be aware of the hazards involved with electrical circuitry, and be familiar with standard practices for preventing accidents. The installer should be familiar with network structures, terms, and concepts.
- Use only the power supply and accessories approved by the manufacturer, and which can be found in the original packaging of this product.
- This equipment is to be installed by trained and qualified personnel, as per these installation instructions. The installer is responsible for making sure, that the Installation of the equipment is compliant with local and national electrical codes. Do not attempt to disassemble, repair, or modify the device.
- This product is intended to be installed indoors. Keep this product away from water, fire, humidity, or hot environments.
- We cannot guarantee that no accidents or damage will occur due to the improper use of the device. Please use this product with care and operate at your own risk!
- In the case of device failure, please disconnect it from power. The fastest way to do so is by unplugging the power plug from the power outlet.
- The socket-outlet shall be installed near the equipment and shall be easily accessible.
- This is a Class A product. In a domestic environment, this product might cause radio interference in which case the user might be required to take adequate measures.
- To avoid contamination of the environment, separate the device from household waste and dispose of it in a safe manner, for example, in designated areas. Become familiar with procedures for properly transporting the equipment to designated collection points in your area. Manufacturer: Mikrotikls SIA, Unijas 2, Riga, Latvia, LV1039.
BG - Български. Бързо ръководство
Това устройство трябва да бъде надстроено до RouterOS v7.13.1 или най-новата версия, за да се гарантира спазването на местните регулаторни разпоредби. Крайните потребители са отговорни за спазването на местните разпоредби. Всички устройства на MikroTik трябва да бъдат професионално инсталиран.
Този документ обхваща модела: CRS106-1C-5S.
Това е мрежово устройство. Можете да намерите името на модела на продукта на етикета на регистъра (ID). |
Първи стъпки:
- Cвържете се с вашия компютър към всеки Ethernet порт;
- Свържете устройството към източник на захранване;
- Конфигурирайте IP настройките на мрежовата ви карта на 192.168.88.2/24;
- Използвайте WebFig в уеб браузър или конфигурационния инструмент "WinBox" https://mt.lv/winbox; налични са множество методи за конфигуриране, за да се осигури достъпност;
- Отворете https://192.168.88.1 в уеб браузъра, за да стартирате настройката. Ако IP адресът не е достъпен, използвайте WinBox и изберете раздел "Neighbors", за да намерите устройството. Свържете се чрез MAC адреса. Потребителското име е "admin", а паролата липсва (или, за някои модели, проверете потребителските и безжичните пароли на стикера);
- Кликнете на бутона "Check for updates" и актуализирайте RouterOS до последната версия;
- За ръчно обновяване на устройството посетете mikrotik.com, изберете модела си и намерете необходимите пакети в секцията "Downloads";
- Качете изтеглените пакети в менюто "Files" на WebFig или WinBox и рестартирайте устройството;
- Чрез актуализиране на софтуера на вашия RouterOS до последната версия, можете да гарантирате оптимална производителност, стабилност и актуализации за сигурност;
- Задайте паролата на вашия рутер.
Информация за безопасност:
- Преди да работите с каквото и да е оборудване на MikroTik, бъдете наясно с опасностите, свързани с електрическата верига, и се запознайте със стандартните практики за предотвратяване на злополуки. Инсталаторът трябва да е запознат с мрежовите структури, термини и концепции.
- Използвайте само захранването и аксесоарите, одобрени от производителя и които могат да бъдат намерени в оригиналната опаковка на този продукт.
- Това оборудване трябва да бъде инсталирано от обучен и квалифициран персонал, съгласно тези инструкции за монтаж. Инсталаторът е отговорен да гарантира, че инсталирането на оборудването е в съответствие с местните и националните електрически кодекси. Не се опитвайте да разглобявате, поправяте или модифицирате устройството.
- Този продукт е предназначен за инсталиране на закрито. Пазете този продукт далеч от вода, огън, влажност или гореща среда.
- Не можем да гарантираме, че няма да възникнат инциденти или щети поради неправилна употреба на устройството. Моля, използвайте този продукт внимателно и работете на свой собствен риск!
- В случай на повреда на устройството, моля, изключете го от захранването. Най -бързият начин да направите това е като извадите щепсела от контакта.
- Контактът трябва да бъде монтиран близо до оборудването и да бъде лесно достъпен.
- Това е продукт от клас А. В домашна среда този продукт може да причини радиосмущения, в този случай от потребителя може да се наложи да предприеме адекватни мерки.
- За да избегнете замърсяване на околната среда, отделете устройството от битовите отпадъци и го изхвърлете по безопасен начин, например на определени места. Запознайте се с процедурите за правилно транспортиране на оборудването до определените пунктове за събиране във вашия район. Производител: Mikrotikls SIA, Unijas 2, Рига, Латвия, LV1039.
CS - Česko. Rychlý průvodce
Toto zařízení musí být upgradováno na RouterOS v7.13.1 nebo na nejnovější verzi, aby bylo zajištěno dodržování předpisů místních úřadů. Je odpovědností koncových uživatelů dodržovat místní předpisy. Všechna zařízení MikroTik musí být profesionálně nainstalován.
Tento Stručný průvodce se týká modelu: CRS106-1C-5S.
Toto je síťové zařízení. Název modelu produktu najdete na štítku případu (ID). |
První kroky:
- Připojte počítač k libovolnému portu Ethernet;
- Připojte zařízení ke zdroji napájení;
- Nakonfigurujte IP nastavení vaší síťové karty na 192.168.88.2/24;
- Použijte WebFig v webovém prohlížeči nebo konfigurační nástroj "WinBox“ https://mt.lv/winbox; je k dispozici více konfiguračních metod k zajištění přístupnosti;
- Otevřete https://192.168.88.1 ve webovém prohlížeči pro spuštění nastavení. Pokud není IP adresa k dispozici, použijte WinBox a vyberte záložku "Neighbors" k nalezení zařízení. Pokračujte v připojení pomocí MAC adresy. Uživatelské jméno je "admin", a není žádné heslo (nebo, pro některé modely, zkontrolujte uživatelská a bezdrátová hesla na štítku);
- Klepněte na tlačítko "Check for updates" a aktualizujte RouterOS na nejnovější verzi;
- Pro manuální aktualizaci zařízení navštivte mikrotik.com, vyberte svůj model a najděte požadované balíčky v sekci "Downloads";
- Nahrajte stažené balíčky do menu "Files" ve WebFig nebo WinBox a restartujte zařízení;
- Aktualizací softwaru RouterOS na nejnovější verzi zajistíte optimální výkon, stabilitu a bezpečnostní aktualizace;
- Nastavte heslo pro váš router.
Bezpečná informace:
- Než začnete pracovat na jakémkoli zařízení MikroTik, uvědomte si rizika spojená s elektrickými obvody a seznamte se se standardními postupy pro předcházení nehodám. Instalační technik by měl znát síťové struktury, termíny a koncepty.
- Používejte pouze napájecí zdroj a příslušenství schválené výrobcem, které lze nalézt v originálním balení tohoto produktu.
- Toto zařízení má být instalováno vyškoleným a kvalifikovaným personálem podle těchto instalačních pokynů. Instalační technik odpovídá za to, že instalace zařízení je v souladu s místními a národními elektrickými předpisy. Nepokoušejte se zařízení rozebírat, opravovat nebo upravovat.
- Tento výrobek je určen k instalaci uvnitř. Chraňte tento produkt před vodou, ohněm, vlhkostí nebo horkým prostředím.
- Nemůžeme zaručit, že v důsledku nesprávného používání zařízení nedojde k nehodám nebo škodám. Používejte prosím tento produkt opatrně a provozujte na vlastní nebezpečí!
- V případě poruchy zařízení jej odpojte od napájení. Nejrychlejším způsobem je vytáhnout zástrčku ze zásuvky.
- Zásuvka musí být instalována v blízkosti zařízení a musí být snadno dostupná.
- Toto je výrobek třídy A. V domácím prostředí může tento výrobek způsobovat rušení rádiových vln. V takovém případě může být uživatel povinen přijmout odpovídající opatření.
- Abyste zabránili znečištění životního prostředí, oddělte zařízení od domácího odpadu a zlikvidujte jej bezpečným způsobem, například na určených místech. Seznamte se s postupy správné přepravy zařízení na určená sběrná místa ve vaší oblasti. Výrobce: Mikrotikls SIA, Unijas 2, Riga, Lotyšsko, LV1039.
DA - Dansk. Hurtig guide
Denne enhed skal opgraderes til RouterOS v7.13.1 eller den nyeste version for at sikre overholdelse af lokale myndigheders regler. Det er slutbrugerens ansvar at følge lokale landes regler. Alle MikroTik-enheder skal være professionelt installeret.
Dette dokument dækker modellen: CRS106-1C-5S.
Dette er netværksenhed. Du kan finde produktmodelnavnet på sagetiketten (ID). |
Første trin:
- Skal du oprette forbindelse til din pc til en hvilken som helst Ethernet-port;
- Tilslut enheden til en strømkilde;
- Konfigurér IP-indstillingerne på dit netværkskort til 192.168.88.2/24;
- Brug WebFig i en webbrowser eller konfigurationsværktøjet "WinBox" https://mt.lv/winbox; flere konfigurationsmetoder er tilgængelige for at sikre tilgængelighed;
- Åbn https://192.168.88.1 i en webbrowser for at starte opsætningen. Hvis IP-adressen ikke er tilgængelig, skal du bruge WinBox og forbinde ved hjælp af MAC-adressen. Brugernavnet er "admin", og der er ingen adgangskode (eller, for nogle modeller, tjek bruger- og trådløse adgangskoder på klistermærket);
- Klik på knappen "Check for updates" og opdater RouterOS til den nyeste version;
- For manuel opdatering af enheden, besøg mikrotik.com, vælg din model og find de nødvendige pakker i sektionen "Downloads";
- Upload downloadede pakker til WebFig eller WinBox "Files" menu og genstart enheden;
- Ved at opgradere din RouterOS-software til den nyeste version kan du sikre optimal ydeevne, stabilitet og sikkerhedsopdateringer;
- Indstil din routeradgangskode.
Sikkerhedsoplysninger:
- Inden du arbejder med MikroTik-udstyr, skal du være opmærksom på farerne i forbindelse med elektriske kredsløb og kende almindelig praksis til forebyggelse af ulykker. Installationsprogrammet skal være bekendt med netværksstrukturer, vilkår og koncepter.
- Brug kun strømforsyningen og det tilbehør, der er godkendt af producenten, og som findes i den originale emballage til dette produkt.
- Dette udstyr skal installeres af uddannet og kvalificeret personale i henhold til disse installationsinstruktioner. Installatøren er ansvarlig for at sikre, at installationen af udstyret er i overensstemmelse med lokale og nationale elektriske koder. Forsøg ikke at adskille, reparere eller ændre enheden.
- Dette produkt er beregnet til at blive installeret indendørs. Hold dette produkt væk fra vand, ild, fugtighed eller varme omgivelser.
- Vi kan ikke garantere, at der ikke vil ske ulykker eller skader på grund af forkert brug af enheden. Brug dette produkt med omhu og betjen det på egen risiko!
- I tilfælde af fejl på enheden skal du frakoble det fra strømmen. Den hurtigste måde at gøre det er ved at tage stikket ud af stikkontakten.
- Stikkontakten skal installeres i nærheden af udstyret og skal være let tilgængelig.
- Dette er et klasse A-produkt. I et hjemligt miljø kan dette produkt forårsage radiointerferens, i hvilket tilfælde brugeren muligvis skal træffe passende foranstaltninger.
- For at undgå forurening af miljøet skal du adskille apparatet fra husholdningsaffald og bortskaffe det på en sikker måde, f.eks. i afmærkede områder. Bliv fortrolig med procedurer for korrekt transport af udstyret til udpegede indsamlingssteder i dit område. Producent: Mikrotikls SIA, Unijas 2, Riga, Letland, LV1039.
DE - Deutsche. Kurzanleitung
Dieses Gerät muss auf RouterOS v7.13.1 oder die neueste Version aktualisiert werden, um die Einhaltung der örtlichen behördlichen Vorschriften zu gewährleisten. Es liegt in der Verantwortung des Endbenutzers, die örtlichen Landesvorschriften einzuhalten. Alle MikroTik-Geräte müssen professionell installiert werden.
Diese Kurzanleitung behandelt das Modell: CRS106-1C-5S.
Dies ist das Netzwerkgerät. Den Produktmodellnamen finden Sie auf dem Gehäuseaufkleber (ID). |
Erste Schritte:
- Ihren PC mit einem beliebigen Ethernet-Port;
- Schließen Sie das Gerät an eine Stromquelle an;
- Konfigurieren Sie die IP-Einstellungen Ihrer Netzwerkkarte auf 192.168.88.2/24;
- Verwenden Sie WebFig in einem Webbrowser oder das Konfigurationstool "WinBox“ https://mt.lv/winbox; mehrere Konfigurationsmethoden stehen zur Verfügung, um die Barrierefreiheit sicherzustellen;
- Öffnen Sie https://192.168.88.1 in einem Webbrowser, um das Setup zu starten. Wenn die IP-Adresse nicht verfügbar ist, verwenden Sie WinBox und stellen Sie über die Registerkarte "Neighbors" eine Verbindung zum Gerät her. Fahren Sie mit der Verbindung über die MAC-Adresse fort. Der Benutzername lautet "admin", und es gibt kein Passwort (oder, für einige Modelle, überprüfen Sie Benutzer- und drahtlose Passwörter auf dem Aufkleber);
- Klicken Sie auf die Schaltfläche "Check for updates" und aktualisieren Sie RouterOS auf die neueste Version;
- Für ein manuelles Update des Geräts besuchen Sie mikrotik.com, wählen Ihr Modell aus und finden die erforderlichen Pakete im Abschnitt "Downloads";
- Laden Sie die heruntergeladenen Pakete in das WebFig- oder WinBox-Menü "Files" hoch und starten Sie das Gerät neu;
- Durch Aktualisieren Ihrer RouterOS-Software auf die neueste Version können Sie eine optimale Leistung, Stabilität und Sicherheitsupdates gewährleisten;
- Legen Sie Ihr Routerpasswort fest.
Sicherheitsinformation:
- Bevor Sie an MikroTik-Geräten arbeiten, seien Sie sich der Gefahren im Zusammenhang mit elektrischen Schaltkreisen bewusst und machen Sie sich mit den Standardverfahren zur Unfallverhütung vertraut. Der Installateur sollte mit Netzwerkstrukturen, Begriffen und Konzepten vertraut sein.
- Verwenden Sie nur vom Hersteller zugelassene Netzteile und Zubehörteile, die sich in der Originalverpackung dieses Produkts befinden.
- Dieses Gerät muss von geschultem und qualifiziertem Personal gemäß dieser Installationsanleitung installiert werden. Der Installateur ist dafür verantwortlich sicherzustellen, dass die Installation des Geräts den lokalen und nationalen Elektrovorschriften entspricht. Versuchen Sie nicht, das Gerät zu zerlegen, zu reparieren oder zu modifizieren.
- Dieses Produkt ist für die Installation in Innenräumen vorgesehen. Halten Sie dieses Produkt von Wasser, Feuer, Feuchtigkeit oder heißen Umgebungen fern.
- Wir können nicht garantieren, dass durch unsachgemäßen Gebrauch des Gerätes keine Unfälle oder Schäden entstehen. Bitte verwenden Sie dieses Produkt mit Sorgfalt und auf eigene Gefahr!
- Bei einem Geräteausfall trennen Sie es bitte vom Strom. Am schnellsten geht das, indem Sie den Netzstecker aus der Steckdose ziehen.
- Die Steckdose muss in der Nähe des Geräts installiert und leicht zugänglich sein.
- Dies ist ein Produkt der Klasse A. In einer häuslichen Umgebung kann dieses Produkt Funkstörungen verursachen. In diesem Fall muss der Benutzer möglicherweise angemessene Maßnahmen ergreifen.
- For at undgå forurening af miljøet skal apparatet adskilles fra husholdningsaffald og bortskaffes på en sikker måde, f.eks. I bestemte områder. Bliv fortrolig med procedurer til korrekt transport af udstyr til udpegede indsamlingssteder i dit område. Hersteller: Mikrotikls SIA, Unijas 2, Riga, Lettland, LV1039.
EL - Ελληνικά. Γρήγορος οδηγός
Αυτή η συσκευή πρέπει να αναβαθμιστεί στο RouterOS v7.13.1 ή την τελευταία έκδοση για να διασφαλιστεί η συμμόρφωση με τους κανονισμούς της τοπικής αυτοδιοίκησης. Είναι ευθύνη των τελικών χρηστών να ακολουθούν τους τοπικούς κανονισμούς της χώρας. Όλες οι συσκευές MikroTik πρέπει να εγκατασταθούν επαγγελματικά.
Αυτός ο γρήγορος οδηγός καλύπτει το μοντέλο: CRS106-1C-5S.
Αυτή είναι η συσκευή δικτύου. Μπορείτε να βρείτε το όνομα του μοντέλου προϊόντος στην ετικέτα της θήκης (ID). |
Πρώτα βήματα:
- Συνδεθείτε με τον υπολογιστή σας σε οποιαδήποτε θύρα Ethernet.
- Συνδέστε τη συσκευή σε πηγή ενέργειας;
- Διαμορφώστε τις ρυθμίσεις IP της κάρτας δικτύου σας σε 192.168.88.2/24;
- Χρησιμοποιήστε το WebFig σε ένα πρόγραμμα περιήγησης ή το εργαλείο ρύθμισης ”WinBox” https://mt.lv/winbox; διατίθενται πολλαπλές μέθοδοι ρύθμισης για να διασφαλιστεί η προσβασιμότητα;
- Ανοίξτε το https://192.168.88.1 σε έναν πρόγραμμα περιήγησης στο διαδίκτυο για να ξεκινήσετε τη ρύθμιση. Εάν η διεύθυνση IP δεν είναι διαθέσιμη, χρησιμοποιήστε το WinBox και επιλέξτε την καρτέλα "Neighbors" για να βρείτε τη συσκευή. Συνεχίστε συνδέοντας χρησιμοποιώντας τη διεύθυνση MAC. Το όνομα χρήστη είναι "admin", και δεν υπάρχει κωδικός πρόσβασης (ή, για ορισμένα μοντέλα, ελέγξτε τους κωδικούς χρήστη και ασύρματους κωδικούς στο αυτοκόλλητο);
- Κάντε κλικ στο κουμπί "Check for updates" και ενημερώστε το RouterOS στην τελευταία έκδοση;
- Για χειροκίνητη ενημέρωση της συσκευής, επισκεφθείτε το mikrotik.com, επιλέξτε το μοντέλο σας και εντοπίστε τα απαιτούμενα πακέτα στην ενότητα "Downloads";
- Μεταφορτώστε τα κατεβασμένα πακέτα στο μενού "Files" του WebFig ή του WinBox και επανεκκινήστε τη συσκευή;
- Αναβαθμίζοντας το λογισμικό του RouterOS στην πιο πρόσφατη έκδοση, μπορείτε να διασφαλίσετε βέλτιστη απόδοση, σταθερότητα και ενημερώσεις ασφαλείας;
- Ορίστε τον κωδικό πρόσβασης του δρομολογητή σας.
Οδηγίες ασφαλείας:
- Πριν εργαστείτε σε οποιοδήποτε εξοπλισμό MikroTik, λάβετε υπόψη τους κινδύνους που συνδέονται με τα ηλεκτρικά κυκλώματα και εξοικειωθείτε με τις τυπικές πρακτικές για την πρόληψη ατυχημάτων. Ο εγκαταστάτης πρέπει να είναι εξοικειωμένος με τις δομές, τους όρους και τις έννοιες του δικτύου.
- Χρησιμοποιείτε μόνο το τροφοδοτικό και τα αξεσουάρ που έχουν εγκριθεί από τον κατασκευαστή και τα οποία βρίσκονται στην αρχική συσκευασία αυτού του προϊόντος.
- Αυτός ο εξοπλισμός πρέπει να εγκατασταθεί από εκπαιδευμένο και εξειδικευμένο προσωπικό, σύμφωνα με αυτές τις οδηγίες εγκατάστασης. Ο εγκαταστάτης είναι υπεύθυνος για να βεβαιωθεί ότι η εγκατάσταση του εξοπλισμού συμμορφώνεται με τους τοπικούς και εθνικούς ηλεκτρικούς κωδικούς. Μην επιχειρήσετε να αποσυναρμολογήσετε, επισκευάσετε ή τροποποιήσετε τη συσκευή.
- Αυτό το προϊόν προορίζεται για εγκατάσταση σε εσωτερικούς χώρους. Κρατήστε αυτό το προϊόν μακριά από νερό, φωτιά, υγρασία ή ζεστό περιβάλλον.
- Δεν μπορούμε να εγγυηθούμε ότι δεν θα προκύψουν ατυχήματα ή ζημιές λόγω ακατάλληλης χρήσης της συσκευής. Χρησιμοποιήστε αυτό το προϊόν με προσοχή και λειτουργήστε με δική σας ευθύνη!
- Σε περίπτωση βλάβης της συσκευής, αποσυνδέστε την από το ρεύμα. Ο γρηγορότερος τρόπος για να γίνει αυτό είναι να αποσυνδέσετε το φις από την πρίζα.
- Η πρίζα πρέπει να είναι εγκατεστημένη κοντά στον εξοπλισμό και να είναι εύκολα προσβάσιμη.
- Αυτό είναι ένα προϊόν κατηγορίας Α. Σε οικιακό περιβάλλον, αυτό το προϊόν ενδέχεται να προκαλέσει ραδιοφωνικές παρεμβολές, οπότε ενδέχεται να απαιτείται από τον χρήστη να λάβει τα κατάλληλα μέτρα.
- Για να αποφύγετε τη μόλυνση του περιβάλλοντος, διαχωρίστε τη συσκευή από οικιακά απορρίμματα και απορρίψτε την με ασφαλή τρόπο, για παράδειγμα, σε καθορισμένες περιοχές. Εξοικειωθείτε με τις διαδικασίες για τη σωστή μεταφορά του εξοπλισμού σε καθορισμένα σημεία συλλογής στην περιοχή σας. Κατασκευαστής: Mikrotikls SIA, Unijas 2, Ρίγα, Λετονία, LV1039.
ES - Español. Guía rápida
Este dispositivo debe actualizarse a RouterOS v7.13.1 o la última versión para garantizar el cumplimiento de las regulaciones de las autoridades locales. Es responsabilidad del usuario final seguir las regulaciones locales del país. Todos los dispositivos de MikroTik deben ser instalado profesionalmente
Esta guía rápida cubre el modelo: CRS106-1C-5S.
Este es un dispositivo de red. Puede encontrar el nombre del modelo del producto en la etiqueta del caso (ID). |
Primeros pasos:
- Conéctese con su PC a cualquier puerto Ethernet;
- Conecte el dispositivo a una fuente de alimentación;
- Configura las opciones IP de tu tarjeta de red a 192.168.88.2/24;
- Utilice WebFig en un navegador web o la herramienta de configuración "WinBox" https://mt.lv/winbox; hay varios métodos de configuración disponibles para garantizar la accesibilidad;
- Abre https://192.168.88.1 en un navegador web para comenzar la configuración. Si la dirección IP no está disponible, utiliza WinBox y selecciona la pestaña "Neighbors" para encontrar el dispositivo. Procede a conectar usando la dirección MAC. El nombre de usuario es "admin", y no hay contraseña (o, para algunos modelos, verifica los usuarios y contraseñas inalámbricas en la etiqueta);
- Haga clic en el botón "Check for updates" y actualice RouterOS a la última versión;
- Para actualizar manualmente el dispositivo, visite mikrotik.com, seleccione su modelo y localice los paquetes requeridos en la sección "Downloads";
- Sube los paquetes descargados al menú "Files" de WebFig o WinBox y reinicia el dispositivo;
- Al actualizar el software de tu RouterOS a la última versión, puedes asegurar un rendimiento óptimo, estabilidad y actualizaciones de seguridad;
- Configura la contraseña de tu enrutador.
Información de seguridad:
- Antes de trabajar en cualquier equipo MikroTik, tenga en cuenta los peligros relacionados con los circuitos eléctricos y familiarícese con las prácticas estándar para prevenir accidentes. El instalador debe estar familiarizado con las estructuras, los términos y los conceptos de la red.
- Utilice únicamente la fuente de alimentación y los accesorios aprobados por el fabricante y que se pueden encontrar en el embalaje original de este producto.
- Este equipo debe ser instalado por personal capacitado y calificado, de acuerdo con estas instrucciones de instalación. El instalador es responsable de asegurarse de que la instalación del equipo cumpla con los códigos eléctricos locales y nacionales. No intente desmontar, reparar o modificar el dispositivo.
- Este producto está diseñado para ser instalado en interiores. Mantenga este producto alejado del agua, el fuego, la humedad o los entornos calientes.
- No podemos garantizar que no ocurran accidentes o daños debido al uso inadecuado del dispositivo. ¡Utilice este producto con cuidado y opere bajo su propio riesgo!
- En caso de falla del dispositivo, desconéctelo de la alimentación. La forma más rápida de hacerlo es desconectando el enchufe de la toma de corriente.
- El tomacorriente se instalará cerca del equipo y será de fácil acceso.
- Este es un producto de Clase A. En un entorno doméstico, este producto puede causar interferencias de radio, en cuyo caso es posible que el usuario deba tomar las medidas adecuadas.
- Para evitar la contaminación del medio ambiente, separe el dispositivo de la basura doméstica y deséchelo de manera segura, por ejemplo, en las áreas designadas. Familiarícese con los procedimientos para transportar correctamente el equipo a los puntos de recolección designados en su área.
Peligro de descarga eléctrica. Este equipo debe ser reparado solo por personal capacitado
Fabricante: Mikrotikls SIA, Unijas 2, Riga, Letonia, LV1039.
Información México:
La operacion de este equipo esta sujeta a las siguientes dos condiciones:
- Es posible que este equipo o dispositivo no cause interferencia perjudicial y.
- Este equipo debe aceptar cualquier interferencia, incluyendo la que pueda causar su operacion no deseada. Fabricante: Mikrotikls SIA, Unijas 2, Riga, LV-1039, Latvia.
País De Origen: Letonia; Lituania; China (Republica Popular); Estados Unidos De America; Mexico.
Por favor contacte a su distribuidor local para preguntas regionales específicas. La lista de importadores se puede encontrar en nuestra página de inicio – https://mikrotik.com/buy/latinamerica/mexico.
ET - Eestlane. Kiirjuhend
Kohaliku omavalitsuse eeskirjade järgimise tagamiseks tuleb see seade uuendada versioonile RouterOS v7.13.1 või uusimale versioonile. Lõppkasutajad vastutavad kohalike riigieeskirjade järgimise eest. Kõik MikroTik seadmed peavad olema professionaalselt paigaldatud.
See kiirjuhend hõlmab mudelit: CRS106-1C-5S.
See on võrguseade. Toote mudeli nime leiate kohvri sildilt (ID). |
Esimesed sammud:
- Ühendage arvutiga mis tahes Etherneti porti;
- Ühendage seade toiteallikaga;
- Konfigureeri oma võrgukaardi IP-seaded 192.168.88.2/24;
- Kasutage WebFigi veebibrauseris või seadistustööriista "WinBox“ https://mt.lv/winbox; ligipääsetavuse tagamiseks on saadaval mitu seadistamismeetodit;
- Ava https://192.168.88.1 veebibrauseris seadistamise alustamiseks. Kui IP-aadress pole kättesaadav, kasuta WinBoxi ja vali seade leidmiseks "Neighbors" vahekaart. Jätka ühendamist MAC-aadressi kasutades. Kasutajanimi on "admin" ja parooli pole (või mõne mudeli puhul kontrollige kasutaja- ja traadita paroole kleebisel);
- Klõpsake nupul "Check for updates" ja ajakohastage RouterOS viimasele versioonile;
- Seadme käsitsi uuendamiseks külastage mikrotik.com, valige oma mudel ja leidke vajalikud paketid jaotises "Downloads";
- Lae allalaaditud paketid üles veebibrauseri WebFig või WinBox "Files" menüüsse ja taaskäivita seade;
- Värskendades RouterOS tarkvara viimasele versioonile, tagad optimaalse jõudluse, stabiilsuse ja turvavärskendused;
- Seadista ruuteri parool.
Ohutusteave:
- Enne mis tahes MikroTik seadmetega töötamist olge teadlik elektriskeemidega seotud ohtudest ja tutvuge õnnetuste vältimise tavapraktikaga. Paigaldaja peaks olema kursis võrgustruktuuride, terminite ja kontseptsioonidega.
- Kasutage ainult tootja poolt heaks kiidetud toiteallikat ja tarvikuid, mis on selle toote originaalpakendis.
- Seda seadet peavad paigaldama väljaõppinud ja kvalifitseeritud töötajad vastavalt käesolevale paigaldusjuhendile. Paigaldaja vastutab selle eest, et seadme paigaldamine vastaks kohalikele ja riiklikele elektrikoodeksitele. Ärge proovige seadet lahti võtta, parandada ega muuta.
- See toode on ette nähtud paigaldamiseks siseruumidesse. Hoidke seda toodet eemal veest, tulest, niiskusest või kuumast keskkonnast.
- Me ei saa garanteerida, et seadme ebaõige kasutamise tõttu ei juhtu õnnetusi ega kahjustusi. Palun kasutage seda toodet ettevaatlikult ja tegutsege omal vastutusel!
- Seadme rikke korral ühendage see vooluvõrgust lahti. Kiireim viis selleks on toitepistik pistikupesast välja tõmmata.
- Pistikupesa paigaldatakse seadme lähedusse ja see peab olema kergesti ligipääsetav.
- See on A -klassi toode. Koduses keskkonnas võib see toode põhjustada raadiohäireid, mille korral võib kasutaja nõuda piisavate meetmete võtmist.
- Keskkonna saastumise vältimiseks eraldage seade olmejäätmetest ja utiliseerige see ohutult, näiteks selleks ettenähtud kohtades. Tutvuge seadmete nõuetekohase transportimise protseduuridega teie piirkonnas asuvatesse kogumispunktidesse. Tootja: Mikrotikls SIA, Unijas 2, Riia, Läti, LV1039.
FI - Suomalainen. Pikaopas
Tämä laite on päivitettävä RouterOS v7.13.1 -versioon tai uusimpaan versioon, jotta varmistetaan paikallisviranomaisten määräysten noudattaminen. Loppukäyttäjien vastuulla on noudattaa paikallisia maakohtaisia määräyksiä. Kaikki MikroTik-laitteet on asennettava ammattimaisesti.
Tämä pikaopas kattaa mallin: CRS106-1C-5S.
Tämä on verkkolaite. Tuotemallin nimi löytyy kotelon etiketistä (ID). |
Ensiaskeleet:
- Yhdistä tietokoneesi mihin tahansa Ethernet-porttiin;
- Kytke laite virtalähteeseen;
- Määritä verkkokorttisi IP-asetukset 192.168.88.2/24;
- Käytä WebFigiä web-selaimessa tai konfigurointityökalua "WinBox" https://mt.lv/winbox; useita määritysmenetelmiä on saatavilla saavutettavuuden varmistamiseksi;
- Avaa https://192.168.88.1 verkkoselaimeen aloittaaksesi asennuksen. Jos IP-osoite ei ole käytettävissä, käytä WinBoxia ja valitse "Neighbors" -välilehti laitteen löytämiseksi. Jatka yhdistämistä MAC-osoitteen avulla. Käyttäjänimi on "admin", eikä salasanaa ole (tai joissakin malleissa tarkista käyttäjä- ja langattomat salasanat tarrasta);
- Napsauta "Check for updates" -painiketta ja päivitä RouterOS uusimpaan versioon;
- Laitteen manuaalista päivitystä varten siirry osoitteeseen mikrotik.com, valitse mallisi ja etsi tarvittavat paketit osiossa "Downloads";
- Lataa ladatut paketit WebFigin tai WinBoxin "Files" -valikkoon ja käynnistä laite uudelleen;
- Päivittämällä RouterOS-ohjelmistosi uusimpaan versioon voit varmistaa optimaalisen suorituskyvyn, vakauden ja turvallisuuspäivitykset;
- Aseta reitittimesi salasana.
Turvallisuustieto:
- Ennen kuin työskentelet MikroTik -laitteiden parissa, ole tietoinen sähköpiiriin liittyvistä vaaroista ja tutustu tavanomaisiin käytäntöihin onnettomuuksien ehkäisemiseksi. Asentajan tulee tuntea verkkorakenteet, termit ja käsitteet.
- Käytä vain valmistajan hyväksymää virtalähdettä ja lisävarusteita, jotka löytyvät tämän tuotteen alkuperäisestä pakkauksesta.
- Tämän laitteen saa asentaa koulutettu ja pätevä henkilökunta näiden asennusohjeiden mukaisesti. Asentaja on vastuussa siitä, että laitteen asennus on paikallisten ja kansallisten sähkökoodien mukainen. Älä yritä purkaa, korjata tai muuttaa laitetta.
- Tämä tuote on tarkoitettu asennettavaksi sisätiloihin. Pidä tämä tuote poissa vedestä, tulesta, kosteudesta tai kuumasta ympäristöstä.
- Emme voi taata, että laitteen väärinkäytöstä ei aiheudu onnettomuuksia tai vaurioita. Käytä tätä tuotetta varoen ja toimi omalla vastuullasi!
- Jos laite vioittuu, irrota se virtalähteestä. Nopein tapa tehdä se on irrottaa pistoke pistorasiasta.
- Pistorasia on asennettava laitteen lähelle ja siihen on oltava helposti saatavilla.
- Tämä on luokan A tuote. Kotitalousympäristössä tämä tuote voi aiheuttaa radiohäiriöitä, jolloin käyttäjää voidaan joutua ryhtymään tarvittaviin toimenpiteisiin.
- Ympäristön saastumisen välttämiseksi erota laite kotitalousjätteestä ja hävitä se turvallisella tavalla esimerkiksi määrätyillä alueilla. Tutustu toimenpiteisiin, joilla laite kuljetetaan asianmukaisesti alueellesi määritettyihin keräyspisteisiin. Valmistaja: Mikrotikls SIA, Unijas 2, Riika, Latvia, LV1039.
FR - Français. Guide rapide
Cet appareil doit être mis à niveau vers RouterOS v7.13.1 ou la dernière version pour garantir la conformité aux réglementations des autorités locales. Il est de la responsabilité des utilisateurs finaux de suivre les réglementations locales du pays. Tous les appareils MikroTik doivent être installé professionnellement.
Ce document couvre le modèle: CRS106-1C-5S.
Ceci est un périphérique réseau. Vous pouvez trouver le nom du modèle du produit sur l'étiquette du boîtier (ID). |
Premiers pas:
- Connectez-vous avec votre PC à n'importe quel port Ethernet;
- Connectez l'appareil à une source d'alimentation;
- Configurez les paramètres IP de votre carte réseau à 192.168.88.2/24;
- Utilisez WebFig dans un navigateur web ou l’outil de configuration "WinBox" https://mt.lv/winbox; plusieurs méthodes de configuration sont disponibles pour garantir l’accessibilité;
- Ouvrez https://192.168.88.1 dans un navigateur Web pour démarrer la configuration. Si l'adresse IP n'est pas disponible, utilisez WinBox et sélectionnez l'onglet "Neighbors" pour trouver le périphérique. Procédez à la connexion en utilisant l'adresse MAC. Le nom d'utilisateur est "admin", et il n'y a pas de mot de passe (ou, pour certains modèles, vérifiez les mots de passe utilisateur et sans fil sur l'autocollant);
- Cliquez sur le bouton "Check for updates" et mettez à jour RouterOS vers la dernière version;
- Pour une mise à jour manuelle de l'appareil, rendez-vous sur mikrotik.com, sélectionnez votre modèle et localisez les paquets requis dans la section "Downloads";
- Téléchargez les packages téléchargés dans le menu "Files" de WebFig ou WinBox et redémarrez l'appareil;
- En mettant à jour votre logiciel RouterOS à la dernière version, vous pouvez assurer des performances optimales, la stabilité et des mises à jour de sécurité;
- Configurez le mot de passe de votre routeur.
Information sur la sécurité:
- Avant de travailler sur un équipement MikroTik, soyez conscient des dangers liés aux circuits électriques et familiarisez-vous avec les pratiques standard pour prévenir les accidents. L'installateur doit être familiarisé avec les structures, les termes et les concepts du réseau.
- Utilisez uniquement le bloc d'alimentation et les accessoires approuvés par le fabricant et qui se trouvent dans l'emballage d'origine de ce produit.
- Cet équipement doit être installé par du personnel formé et qualifié, conformément à ces instructions d'installation. L'installateur est responsable de s'assurer que l'installation de l'équipement est conforme aux codes électriques locaux et nationaux. N'essayez pas de démonter, réparer ou modifier l'appareil.
- Ce produit est destiné à être installé à l'intérieur. Gardez ce produit loin de l'eau, du feu, de l'humidité ou des environnements chauds.
- Nous ne pouvons garantir qu'aucun accident ou dommage ne se produira en raison d'une mauvaise utilisation de l'appareil. Veuillez utiliser ce produit avec précaution et opérer à vos risques et périls!
- En cas de panne de l'appareil, veuillez le débrancher de l'alimentation. Le moyen le plus rapide de le faire est de débrancher la fiche d'alimentation de la prise de courant.
- La prise de courant doit être installée à proximité de l'équipement et doit être facilement accessible.
- Il s'agit d'un produit de classe A. Dans un environnement domestique, ce produit peut provoquer des interférences radio, auquel cas l'utilisateur peut être amené à prendre des mesures adéquates.
- Pour éviter la contamination de l'environnement, séparez l'appareil des déchets ménagers et éliminez-le de manière sûre, par exemple dans des zones désignées. Familiarisez-vous avec les procédures pour transporter correctement l'équipement vers les points de collecte désignés dans votre région. Fabricant: Mikrotikls SIA, Unijas 2, Riga, Lettonie, LV1039.
HR - Hrvatski. Brzi vodič
Ovaj je uređaj potrebno nadograditi na RouterOS v7.13.1 ili najnoviju verziju kako bi se osigurala sukladnost s lokalnim propisima. Odgovornost je krajnjih korisnika da se pridržavaju lokalnih propisa zemlje. Svi MikroTik uređaji moraju biti profesionalno instalirani.
Ovaj brzi vodič pokriva model: CRS106-1C-5S.
Ovo je mrežni uređaj. Naziv modela proizvoda možete pronaći na naljepnici kućišta (ID). |
Prvi koraci:
- Povežite se s računalom na bilo koji Ethernet priključak;
- Priključite uređaj na izvor napajanja;
- Konfigurirajte IP postavke svoje mrežne kartice na 192.168.88.2/24;
- Koristite WebFig u web-pregledniku ili konfiguracijski alat "WinBox“ https://mt.lv/winbox; dostupne su različite metode konfiguracije kako bi se osigurala pristupačnost;
- Otvorite https://192.168.88.1 u web pregledniku kako biste započeli postavljanje. Ako IP adresa nije dostupna, koristite WinBox i odaberite karticu "Neighbors" da biste pronašli uređaj. Nastavite s povezivanjem putem MAC adrese. Korisničko ime je "admin", a nema lozinke (ili, za neke modele, provjerite korisničke i bežične lozinke na naljepnici);
- Kliknite na gumb "Check for updates" i ažurirajte RouterOS na najnoviju verziju;
- Za ručnu nadogradnju uređaja posjetite mikrotik.com, odaberite svoj model i pronađite potrebne pakete u odjeljku "Downloads";
- Prenesite preuzete pakete u WebFig ili WinBox "Files" izbornik i ponovno pokrenite uređaj;
- Ažuriranjem softvera RouterOS na najnoviju verziju možete osigurati optimalne performanse, stabilnost i sigurnosna ažuriranja;
- Postavite lozinku za svoj usmjerivač.
Sigurnosne informacije:
- Prije rada na bilo kojoj MikroTik opremi, budite svjesni opasnosti povezanih s električnim krugovima i upoznajte se sa standardnom praksom za sprječavanje nesreća. Instalacijski program trebao bi poznavati mrežne strukture, pojmove i koncepte.
- Koristite samo izvor napajanja i dodatnu opremu odobrene od proizvođača, koji se mogu pronaći u originalnom pakiranju ovog proizvoda.
- Ovu opremu mora instalirati obučeno i kvalificirano osoblje, u skladu s ovim uputama za ugradnju. Instalater je odgovoran za to da instalacija opreme bude u skladu s lokalnim i nacionalnim električnim kodovima. Ne pokušavajte rastaviti, popraviti ili preinačiti uređaj.
- Ovaj je proizvod namijenjen za ugradnju u zatvorene prostore. Držite ovaj proizvod dalje od vode, vatre, vlage ili vrućeg okruženja.
- Ne možemo jamčiti da neće doći do nesreća ili oštećenja zbog nepravilne uporabe uređaja. Pažljivo koristite ovaj proizvod i radite na vlastitu odgovornost!
- U slučaju kvara uređaja, isključite ga iz napajanja. Najbrži način za to je isključivanje utikača iz utičnice.
- Utičnica mora biti instalirana u blizini opreme i mora biti lako dostupna.
- Ovo je proizvod klase A. U kućnom okruženju ovaj proizvod može uzrokovati radio smetnje, u tom slučaju od korisnika se može zahtijevati da poduzme odgovarajuće mjere.
- Da biste izbjegli onečišćenje okoliša, odvojite uređaj od kućnog otpada i odložite ga na siguran način, na primjer, na za to predviđena mjesta. Upoznajte se s postupcima pravilnog transporta opreme do određenih sabirnih mjesta u vašem području. Proizvođač: Mikrotikls SIA, Unijas 2, Riga, Latvija, LV1039.
HU - Magyar. Gyors útmutató
Ezt az eszközt frissíteni kell a RouterOS v7.13.1-ra vagy a legújabb verzióra, hogy biztosítsák a helyi hatóságok előírásainak való megfelelést. A végfelhasználók felelőssége a helyi országos előírások betartása. Az összes MikroTik készüléknek lennie kell szakszerűen telepítve.
Ez a gyors útmutató a következőre vonatkozik: CRS106-1C-5S.
Ez hálózati eszköz. A terméktípus nevét a tok címkéjén (ID) találhatja meg. |
Első lépések:
- Csatlakoztassa a számítógépet bármelyik Ethernet porthoz;
- Csatlakoztassa a készüléket az áramforráshoz;
- Konfigurálja hálózati kártyája IP beállításait 192.168.88.2/24-re;
- Használja a WebFig-et webböngészőben vagy a "WinBox” konfigurációs eszközt https://mt.lv/winbox; számos konfigurációs módszer áll rendelkezésre az akadálymentesség biztosításához;
- Nyissa meg a https://192.168.88.1 címet egy webböngészőben a beállítás elindításához. Ha az IP cím nem elérhető, használja a WinBoxot, és válassza ki a "Neighbors" fület az eszköz megtalálásához. Folytassa a csatlakozást a MAC cím használatával. A felhasználónév "admin", és nincs jelszó (vagy, néhány modell esetén, ellenőrizze a felhasználói és vezeték nélküli jelszavakat a matricán);
- Kattintson az "Check for updates" gombra, és frissítse a RouterOS-t a legújabb verzióra;
- Az eszköz kézi frissítéséhez látogasson el a mikrotik.com oldalra, válassza ki a modelljét, és találja meg a szükséges csomagokat a "Downloads" részben;
- Töltse fel a letöltött csomagokat a WebFig vagy WinBox "Files" menübe, majd indítsa újra az eszközt;
- Az RouterOS szoftver frissítésével a legújabb verzióra biztosíthatja az optimális teljesítményt, stabilitást és biztonsági frissítéseket;
- Állítsa be a router jelszavát.
Biztonsági információk:
- Mielőtt bármilyen MikroTik berendezésen dolgozna, legyen tisztában az elektromos áramkörökkel kapcsolatos veszélyekkel, és ismerje meg a balesetek megelőzésének szokásos gyakorlatát. A telepítőnek ismernie kell a hálózati struktúrákat, kifejezéseket és fogalmakat.
- Csak a gyártó által jóváhagyott tápegységet és tartozékokat használja, amelyek a termék eredeti csomagolásában találhatók.
- Ezt a berendezést képzett és szakképzett személyzet telepítse, a jelen szerelési utasítás szerint. A szerelő felelős azért, hogy megbizonyosodjon arról, hogy a berendezés telepítése megfelel a helyi és országos elektromos előírásoknak. Ne kísérelje meg szétszerelni, javítani vagy módosítani a készüléket.
- Ezt a terméket beltéri használatra tervezték. Tartsa távol a terméket víztől, tűztől, páratartalomtól vagy forró környezettől.
- Nem tudjuk garantálni, hogy a készülék nem rendeltetésszerű használata miatt baleset vagy sérülés nem következik be. Kérjük, óvatosan használja ezt a terméket, és saját felelősségére használja!
- A készülék meghibásodása esetén válassza le az áramellátást. Ennek leggyorsabb módja, ha kihúzza a hálózati csatlakozót a konnektorból.
- Az aljzatot a berendezés közelében kell elhelyezni, és könnyen hozzáférhetőnek kell lennie.
- Ez egy A osztályú termék. Háztartási környezetben ez a termék rádióinterferenciát okozhat, ebben az esetben a felhasználónak meg kell tennie a megfelelő intézkedéseket.
- A környezet szennyeződésének elkerülése érdekében különítse el a készüléket a háztartási hulladéktól, és biztonságos módon dobja el, például a kijelölt területekre. Ismerje meg a berendezés megfelelő szállítási eljárásait a környéken található gyűjtőhelyekre. Gyártó: Mikrotikls SIA, Unijas 2, Riga, Lettország, LV1039.
ID - Bahasa Indonesia. Panduan Cepat
Perangkat ini perlu ditingkatkan ke RouterOS v7.13.1 atau versi terbaru untuk memastikan kepatuhan terhadap peraturan otoritas setempat! Merupakan tanggung jawab pengguna akhir untuk mengikuti peraturan negara setempat. Semua perangkat MikroTik harus diinstal secara profesional.
Panduan Cepat ini mencakup model: CRS106-1C-5S.
Ini adalah Perangkat Jaringan. Anda dapat menemukan nama model produk pada label casing (ID).
Kunjungi halaman panduan pengguna di https://mt.lv/um untuk mendapatkan panduan pengguna terbaru dan lengkap. Atau pindai kode QR dengan ponsel Anda. |
Langkah pertama:
- Terhubung dengan PC Anda ke port Ethernet apa pun;
- Hubungkan perangkat ke sumber listrik;
- Konfigurasikan pengaturan IP kartu jaringan Anda ke 192.168.88.2/24;
- Gunakan WebFig di peramban web atau alat konfigurasi "WinBox" https://mt.lv/winbox; berbagai metode konfigurasi tersedia untuk memastikan aksesibilitas;
- Buka https://192.168.88.1 di browser web untuk memulai pengaturan. Jika alamat IP tidak tersedia, gunakan WinBox dan pilih tab "Neighbors" untuk menemukan perangkat. Lanjutkan untuk terhubung menggunakan alamat MAC. Nama penggunanya adalah "admin", dan tidak ada kata sandi (atau, untuk beberapa model, periksa kata sandi pengguna dan nirkabel pada stiker);
- Klik tombol "Check for updates" dan perbarui RouterOS ke versi terbaru;
- Untuk pembaruan manual perangkat, kunjungi mikrotik.com, pilih model Anda, dan temukan paket yang diperlukan di bagian "Downloads";
- Unggah paket yang diunduh ke menu "File" WebFig atau WinBox dan reboot perangkat;
- Dengan mengupgrade perangkat lunak RouterOS Anda ke versi terbaru, Anda dapat memastikan kinerja, stabilitas, dan pembaruan keamanan yang optimal;
- Siapkan kata sandi router Anda.
Informasi keselamatan:
- Sebelum Anda mengerjakan peralatan MikroTik apa pun, waspadai bahaya yang terkait dengan sirkuit listrik, dan pahami praktik standar untuk mencegah kecelakaan. Pemasang harus memahami struktur, istilah, dan konsep jaringan.
- Gunakan hanya catu daya dan aksesori yang disetujui oleh produsen, dan dapat ditemukan dalam kemasan asli produk ini.
- Peralatan ini harus dipasang oleh personel yang terlatih dan berkualifikasi, sesuai petunjuk pemasangan ini. Pemasang bertanggung jawab untuk memastikan bahwa Pemasangan peralatan mematuhi peraturan kelistrikan lokal dan nasional. Jangan mencoba membongkar, memperbaiki, atau memodifikasi perangkat.
- Produk ini dimaksudkan untuk dipasang di dalam ruangan. Jauhkan produk ini dari air, api, kelembapan, atau lingkungan panas.
- Kami tidak dapat menjamin bahwa tidak akan terjadi kecelakaan atau kerusakan akibat penggunaan perangkat yang tidak tepat. Harap gunakan produk ini dengan hati-hati dan pengoperasian dengan risiko Anda sendiri!
- Jika terjadi kegagalan perangkat, harap putuskan sambungannya dari listrik. Cara tercepat untuk melakukannya adalah dengan mencabut steker listrik dari stopkontak.
- Stopkontak harus dipasang di dekat peralatan dan harus mudah dijangkau.
- Ini adalah produk Kelas A. Di lingkungan rumah tangga, produk ini dapat menyebabkan interferensi radio sehingga pengguna mungkin perlu mengambil tindakan yang memadai.
- Untuk menghindari kontaminasi terhadap lingkungan, pisahkan perangkat dari limbah rumah tangga dan buang dengan cara yang aman, misalnya di tempat yang telah ditentukan. Pahami prosedur pengangkutan peralatan dengan benar ke tempat pengumpulan yang ditentukan di wilayah Anda. Pabrikan: Mikrotikls SIA, Unijas 2, Riga, Latvia, LV1039.
IT - Italiano. Guida veloce
Questo dispositivo deve essere aggiornato a RouterOS v7.13.1 o alla versione più recente per garantire la conformità alle normative delle autorità locali. È responsabilità dell'utente finale seguire le normative locali. Tutti i dispositivi MikroTik devono essere installato professionalmente.
Questa guida rapida copre il modello: CRS106-1C-5S.
Questo è il dispositivo di rete. È possibile trovare il nome del modello del prodotto sull'etichetta della custodia (ID). |
Primi passi:
- Connettersi con il PC a qualsiasi porta Ethernet;
- Collegare il dispositivo a una fonte di alimentazione;
- Configura le impostazioni IP della tua scheda di rete a 192.168.88.2/24;
- Utilizzare WebFig in un browser web oppure lo strumento di configurazione "WinBox" https://mt.lv/winbox; sono disponibili diversi metodi di configurazione per garantire l’accessibilità;
- Apri https://192.168.88.1 in un browser web per avviare la configurazione. Se l'indirizzo IP non è disponibile, utilizza WinBox e scegli la scheda "Neighbors" per trovare il dispositivo. Prosegui con la connessione utilizzando l'indirizzo MAC. Il nome utente è "admin", e non c'è una password (o, per alcuni modelli, controlla gli utenti e le password wireless sull'etichetta);
- Fai clic sul pulsante "Check for updates" e aggiorna RouterOS all'ultima versione;
- Per aggiornare manualmente il dispositivo, visitare mikrotik.com, selezionare il modello e individuare i pacchetti necessari nella sezione "Downloads";
- Carica i pacchetti scaricati nel menu "Files" di WebFig o WinBox e riavvia il dispositivo;
- Aggiornando il software RouterOS alla versione più recente, puoi garantire prestazioni ottimali, stabilità e aggiornamenti di sicurezza;
- Imposta la password del tuo router.
Informazioni sulla sicurezza:
- Prima di lavorare su qualsiasi apparecchiatura MikroTik, sii consapevole dei rischi legati ai circuiti elettrici e acquisisci familiarità con le pratiche standard per prevenire gli incidenti. L'installatore deve avere familiarità con le strutture, i termini e i concetti di rete.
- Utilizzare solo l'alimentatore e gli accessori approvati dal produttore e che si trovano nella confezione originale di questo prodotto.
- Questa apparecchiatura deve essere installata da personale addestrato e qualificato, secondo queste istruzioni di installazione. L'installatore è responsabile di assicurarsi che l'installazione dell'apparecchiatura sia conforme alle normative elettriche locali e nazionali. Non tentare di smontare, riparare o modificare il dispositivo.
- Questo prodotto è destinato all'installazione in interni. Tenere questo prodotto lontano da acqua, fuoco, umidità o ambienti caldi.
- Non possiamo garantire che non si verifichino incidenti o danni dovuti all'uso improprio del dispositivo. Si prega di utilizzare questo prodotto con cura e operare a proprio rischio!
- In caso di guasto del dispositivo, scollegarlo dall'alimentazione. Il modo più veloce per farlo è scollegare la spina di alimentazione dalla presa di corrente.
- La presa deve essere installata vicino all'apparecchiatura e deve essere facilmente accessibile.
- Questo è un prodotto di classe A. In un ambiente domestico, questo prodotto potrebbe causare interferenze radio, nel qual caso l'utente potrebbe essere tenuto ad adottare misure adeguate.
- Per evitare la contaminazione dell'ambiente, separare il dispositivo dai rifiuti domestici e smaltirlo in modo sicuro, ad esempio, in aree designate. Acquisire familiarità con le procedure per trasportare correttamente l'attrezzatura ai punti di raccolta designati nella propria zona. Produttore: Mikrotikls SIA, Unijas 2, Riga, Lettonia, LV1039.
IS - Íslensku. Fljótur leiðarvísir
Það þarf að uppfæra þetta tæki í RouterOS v7.13.1 eða nýjustu útgáfuna til að tryggja samræmi við reglugerðir sveitarfélaga. Það er á ábyrgð endanlegra notenda að fylgja landsbundnum reglum. Öll MikroTik tæki verða að vera fagmannlega sett upp.
Þessi snögga leiðbeining nær yfir gerðina: CRS106-1C-5S.
Þetta er net tæki. Þú getur fundið heiti vörulíkansins á merkimiðanum (ID). |
Fyrstu skrefin:
- Tengstu við tölvuna þína við hvaða Ethernet tengi sem er;
- Tengdu tækið við aflgjafa;
- Stilla IP stillingar netkortsins þíns á 192.168.88.2/24;
- Notið WebFig í vefvafra eða uppsetningartól "WinBox“ https://mt.lv/winbox; margar stillingaraðferðir eru í boði til að tryggja aðgengi;
- Opnaðu https://192.168.88.1 í vefskoðara til að byrja uppsetningu. Ef IP heimilið er ekki tiltækt, notaðu WinBox og veljaðu "Neighbors" flipann til að finna tækið. Halda áfram með að tengjast með MAC heimilisfangi. Notandanafnið er "admin", og engin lykilorð er (eða, fyrir sumar módel, athugaðu notandanöfn og þráðlausa lykilorð á merki);
- Smelltu á "Check for updates" hnappinn og uppfærðu RouterOS á nýjustu útgáfu;
- Til að uppfæra tækið handvirkt, farðu á mikrotik.com, veldu módelið þitt og finndu nauðsynlegu pakkana í kaflanum "Downloads";
- Hlaða niður pökkum á WebFig eða WinBox "Files" valmynd og endurræsa tækið;
- Með því að uppfæra RouterOS hugbúnaðinn þinn í nýjustu útgáfu getur þú tryggjað bestu árangur, stöðugleika og öryggisuppfærslur;
- Stilla lykilorðið á routerinum þínu.
Öryggisupplýsingar:
- Áður en þú vinnur að einhverjum MikroTik búnaði skaltu vera meðvitaður um hættuna sem fylgir rafrásum og þekkja staðlaða vinnubrögð við að koma í veg fyrir slys. Uppsetningarforritið ætti að þekkja netkerfi, hugtök og hugtök.
- Notaðu aðeins aflgjafa og fylgihluti sem framleiðandi hefur samþykkt og finnast í upprunalegum umbúðum þessarar vöru.
- Þessi búnaður á að setja upp af þjálfuðu og hæfu starfsfólki samkvæmt þessum uppsetningarleiðbeiningum. Uppsetningaraðili ber ábyrgð á því að uppsetning búnaðarins sé í samræmi við staðbundna og innlenda rafmagnsreglur. Ekki reyna að taka í sundur, gera við eða breyta tækinu.
- Þessari vöru er ætlað að setja upp innandyra. Hafðu þessa vöru fjarri vatni, eldi, raka eða heitu umhverfi.
- Við getum ekki ábyrgst að engin slys eða skemmdir verða vegna rangrar notkunar tækisins. Vinsamlegast notaðu þessa vöru með varúð og farðu á eigin ábyrgð!
- Ef tækið bilar skaltu aftengja það frá rafmagni. Fljótlegasta leiðin til að gera það er með því að taka rafmagnstengið úr sambandi við rafmagnsinnstunguna.
- Innstungan skal vera nálægt búnaðinum og vera aðgengileg.
- Þetta er vara í flokki A. Í heimalandi umhverfi gæti þessi vara valdið truflunum á útvarpi, en þá gæti þurft að gera notandann viðeigandi ráðstafanir.
- Til að koma í veg fyrir mengun umhverfisins skaltu aðskilja tækið frá heimilissorpi og farga því á öruggan hátt, til dæmis á afmörkuðum svæðum. Kynntu þér verklagsreglur til að flytja búnaðinn rétt til tilnefndra söfnunarstaða á þínu svæði. Framleiðandi: Mikrotikls SIA, Unijas 2, Riga, Lettlandi, LV1039.
NO - Norsk. Hurtiginnføring
Denne enheten må oppgraderes til RouterOS v7.13.1 eller den nyeste versjonen for å sikre samsvar med lokale myndighetsbestemmelser. Det er sluttbrukernes ansvar å følge lokale lands forskrifter. Alle MikroTik-enheter må være profesjonelt installert.
Denne hurtigveiledningen dekker modellen: CRS106-1C-5S.
Dette er nettverksenhet. Du kan finne produktmodellnavnet på etiketten (ID). |
Første steg:
- Kobler du til PC-en til hvilken som helst Ethernet-port;
- Koble enheten til en strømkilde;
- Konfigurer IP-innstillingene på nettverkskortet ditt til 192.168.88.2/24;
- Bruk WebFig i en nettleser eller konfigurasjonsverktøyet "WinBox" https://mt.lv/winbox; flere konfigurasjonsmetoder er tilgjengelige for å sikre tilgjengelighet;
- Åpne https://192.168.88.1 i en nettleser for å starte oppsettet. Hvis IP-adressen ikke er tilgjengelig, bruk WinBox og velg "Neighbors"-fanen for å finne enheten. Fortsett å koble til ved hjelp av MAC-adressen. Brukernavnet er "admin", og det er ingen passord (eller, for noen modeller, sjekk bruker- og trådløse passord på etiketten);
- Klikk på knappen "Check for updates" og oppdater RouterOS til den nyeste versjonen;
- For manuell oppdatering av enheten, gå til mikrotik.com, velg modellen din og finn de nødvendige pakkene i seksjonen "Downloads";
- Last opp nedlastede pakker til WebFig eller WinBox "Files"-menyen og start enheten på nytt;
- Ved å oppgradere RouterOS-programvaren til den nyeste versjonen, kan du sikre optimal ytelse, stabilitet og sikkerhetsoppdateringer;
- Sett opp passordet for ruteren din.
Sikkerhetsinformasjon:
- Før du arbeider med noe MikroTik -utstyr, må du være oppmerksom på farene forbundet med elektriske kretser, og være kjent med standard praksis for å forhindre ulykker. Installatøren bør være kjent med nettverksstrukturer, begreper og begreper.
- Bruk bare strømforsyningen og tilbehøret som er godkjent av produsenten, og som finnes i originalemballasjen til dette produktet.
- Dette utstyret skal installeres av opplært og kvalifisert personell i henhold til denne installasjonsinstruksjonene. Installatøren er ansvarlig for at installasjonen av utstyret er i samsvar med lokale og nasjonale elektriske forskrifter. Ikke forsøk å demontere, reparere eller endre enheten.
- Dette produktet er ment å installeres innendørs. Hold dette produktet borte fra vann, brann, fuktighet eller varme omgivelser.
- Vi kan ikke garantere at det ikke vil oppstå ulykker eller skader på grunn av feil bruk av enheten. Bruk dette produktet med forsiktighet og bruk på egen risiko!
- I tilfelle feil på enheten, må du koble den fra strømmen. Den raskeste måten å gjøre det på er ved å trekke støpselet ut av stikkontakten.
- Stikkontakten skal installeres i nærheten av utstyret og skal være lett tilgjengelig.
- Dette er et klasse A -produkt. I et hjemmemiljø kan dette produktet forårsake radioforstyrrelser. I så fall kan det være nødvendig at brukeren tar nødvendige tiltak.
- For å unngå forurensning av miljøet, må du skille enheten fra husholdningsavfall og kaste den på en sikker måte, for eksempel i bestemte områder. Bli kjent med prosedyrer for riktig transport av utstyret til utpekte innsamlingssteder i ditt område. Produsent: Mikrotikls SIA, Unijas 2, Riga, Latvia, LV1039.
LT - Lietuvių. Trumpas vadovas
Šį įrenginį reikia atnaujinti į „RouterOS v7.13.1“ arba naujausią versiją, kad būtų užtikrinta atitiktis vietinės valdžios nuostatoms. Galutiniai vartotojai yra atsakingi už vietinių šalies įstatymų laikymąsi. Visi „MikroTik“ prietaisai turi būti profesionaliai sumontuota.
Šis trumpasis vadovas apima modelį: CRS106-1C-5S.
Tai yra tinklo įrenginys. Produkto modelio pavadinimą galite rasti dėklo etiketėje (ID). |
Pirmieji žingsniai:
- Prijunkite savo kompiuterį prie bet kurio Ethernet prievado;
- Prijunkite įrenginį prie maitinimo šaltinio;
- Sukonfigūruokite savo tinklo plokštės IP nustatymus į 192.168.88.2/24;
- Naudokite WebFig naršyklėje arba konfigūravimo įrankį "WinBox“ https://mt.lv/winbox; galimi keli konfigūravimo metodai prieinamumui užtikrinti;
- Atidarykite https://192.168.88.1 naršyklėje, norėdami pradėti sąranką. Jei IP adresas nepasiekiamas, naudokite WinBox ir pasirinkite "Neighbors" skirtuką, kad rastumėte įrenginį. Tęskite prisijungdami naudodami MAC adresą. Vartotojo vardas yra "admin", o slaptažodžio nėra (arba, kai kuriems modeliams, patikrinkite vartotojo ir belaidžio slaptažodžius ant lipduko);
- Spustelėkite "Check for updates" mygtuką ir atnaujinkite RouterOS į naujausią versiją;
- Norėdami rankiniu būdu atnaujinti įrenginį, eikite į mikrotik.com, pasirinkite savo modelį ir raskite reikalingus paketus skiltyje "Downloads";
- Įkraukite atsisiųstus paketus į WebFig arba WinBox "Files" meniu ir paleiskite įrenginį iš naujo;
- Atnaujindami savo RouterOS programinę įrangą iki naujausios versijos, galite užtikrinti optimalų našumą, stabilumą ir saugumo atnaujinimus;
- Nustatykite savo maršrutizatoriaus slaptažodį.
Saugumo informacija:
- Prieš pradėdami dirbti su bet kokia „MikroTik“ įranga, žinokite apie pavojus, susijusius su elektros grandinėmis, ir susipažinkite su standartine nelaimingų atsitikimų prevencijos praktika. Montuotojas turi būti susipažinęs su tinklo struktūromis, terminais ir sąvokomis.
- Naudokite tik gamintojo patvirtintą maitinimo šaltinį ir priedus, kuriuos rasite originalioje šio gaminio pakuotėje.
- Šią įrangą turi montuoti apmokytas ir kvalifikuotas personalas pagal šias montavimo instrukcijas. Montuotojas yra atsakingas už tai, kad įrenginio montavimas atitiktų vietinius ir nacionalinius elektros kodeksus. Nemėginkite išardyti, taisyti ar keisti prietaiso.
- Šis gaminys skirtas montuoti patalpose. Laikykite šį gaminį atokiau nuo vandens, ugnies, drėgmės ar karštos aplinkos.
- Mes negalime garantuoti, kad dėl netinkamo prietaiso naudojimo neįvyks nelaimingų atsitikimų ar žalos. Prašome naudoti šį gaminį atsargiai ir veikti savo rizika!
- Įrenginio gedimo atveju atjunkite jį nuo maitinimo šaltinio. Greičiausias būdas tai padaryti yra ištraukti maitinimo kištuką iš elektros lizdo.
- Kištukinis lizdas turi būti įrengtas šalia įrangos ir turi būti lengvai pasiekiamas.
- Tai yra A klasės produktas. Buitinėje aplinkoje šis gaminys gali sukelti radijo trukdžius, todėl vartotojas gali imtis atitinkamų priemonių.
- Kad išvengtumėte aplinkos užteršimo, atskirkite prietaisą nuo buitinių atliekų ir saugiai išmeskite, pavyzdžiui, tam skirtose vietose. Susipažinkite su procedūromis, kaip tinkamai transportuoti įrangą į paskirtus surinkimo punktus jūsų vietovėje. Gamintojas: Mikrotikls SIA, Unijas 2, Ryga, Latvija, LV1039.
LV - Latviešu. Īsa rokasgrāmata
Šīs ierīces programmatūra ir jāatjaunina uz RouterOS v7.13.1 vai jaunāku versiju, lai nodrošinātu atbilstību vietējās likumdošanas noteikumiem. Gala lietotāju pienākums ir ievērot vietējos valsts normatīvus. Visām MikroTik ierīcēm jābūt profesionāli uzstādītām.
Šī īsā rokasgrāmata attiecas uz modeli: CRS106-1C-5S.
Šī ir tīkla ierīce. Produkta modeļa nosaukumu varat atrast uz produkta iepakojuma (ID). |
Pirmie soļi:
- Pievienojiet savu datoru jebkuram Ethernet portam;
- Pievienojiet ierīci strāvas avotam;
- Konfigurējiet savas tīkla kartes IP iestatījumus uz 192.168.88.2/24;
- Izmantojiet WebFig tīmekļa pārlūkā vai konfigurācijas rīku "WinBox“ https://mt.lv/winbox; vairāki konfigurēšanas veidi ir pieejami piekļūstamības nodrošināšanai;
- Atveriet https://192.168.88.1 tīmekļa pārlūkprogrammā, lai sāktu iestatīšanu. Ja IP adrese nav pieejama, izmantojiet WinBox un atlasiet cilni "Neighbors", lai atrastu ierīci. Turpiniet savienojumu, izmantojot MAC adresi. Lietotājvārds ir "admin", un nav parole (vai, dažiem modeļiem, pārbaudiet lietotāja un bezvadu paroles uz līmplēves);
- Noklikšķiniet uz pogas "Check for updates" un atjaunojiet RouterOS līdz jaunākajai versijai;
- Lai manuāli atjauninātu ierīci, apmeklējiet mikrotik.com, izvēlieties savu modeli un atrodiet nepieciešamos pakotnes sadaļā "Downloads";
- Augšupielādējiet lejupielādētās pakotnes uz WebFig vai WinBox "Files" izvēlni un pārstartējiet ierīci;
- Jauninot savu RouterOS programmatūru līdz jaunākajai versijai, varat nodrošināt optimālu veiktspēju, stabilitāti un drošības atjauninājumus;
- Iestatiet sava maršrutētāja paroli.
Drošības informācija:
- Pirms strādājat ar jebkuru MikroTik aprīkojumu, apzinieties ar elektriskās ķēdes radīto apdraudējumu un iepazīstieties ar standarta praksi nelaimes gadījumu novēršanai. Instalētājam jāzina tīkla struktūras, termini un jēdzieni.
- Izmantojiet tikai ražotāja apstiprinātu barošanas avotu un piederumus, kas atrodami šī produkta oriģinālajā iepakojumā.
- Šo aprīkojumu drīkst uzstādīt apmācīts un kvalificēts personāls saskaņā ar šīm uzstādīšanas instrukcijām. Uzstādītājs ir atbildīgs par to, lai iekārtas uzstādīšana atbilstu vietējiem un valsts elektriskajiem noteikumiem. Nemēģiniet izjaukt, labot vai pārveidot ierīci.
- Šis produkts ir paredzēts uzstādīšanai telpās. Sargājiet šo produktu no ūdens, uguns, mitruma vai karstas vides.
- Mēs nevaram garantēt, ka ierīces nepareizas lietošanas dēļ nenotiks negadījumi vai bojājumi. Lūdzu, izmantojiet šo produktu piesardzīgi un darbojieties uz savu risku!
- Ierīces bojājuma gadījumā, lūdzu, atvienojiet to no strāvas. Ātrākais veids, kā to izdarīt, ir atvienot strāvas kontaktdakšu no kontaktligzdas.
- Kontaktligzdai jābūt uzstādītai netālu no iekārtas un tai jābūt viegli pieejamai.
- Šis ir A klases produkts. Sadzīves vidē šis produkts var izraisīt radio traucējumus, tādā gadījumā lietotājam var būt jāveic atbilstoši pasākumi.
- Lai izvairītos no vides piesārņošanas, atdaliet ierīci no sadzīves atkritumiem un atbrīvojieties no tās drošā un paredzētā veidā, piemēram, noteiktās vietās. Iepazīstieties ar kārtību, kā pareizi transportēt aprīkojumu uz noteiktajiem savākšanas punktiem jūsu apkārtnē. Ražotājs: Mikrotikls SIA, Ūnijas 2, Rīga, Latvija, LV1039.
MT - Malti. Gwida Quick
Dan l-apparat jeħtieġ li jiġi aġġornat għal RouterOS v7.13.1 jew l-aħħar verżjoni biex tkun assigurata l-konformità mar-regolamenti tal-awtorità lokali. Hija r-responsabbiltà tal-utenti finali li jsegwu r-regolamenti lokali tal-pajjiż. L-apparati kollha MikroTik iridu jkunu installati professjonalment.
Din il-Gwida Quick tkopri l-mudell: CRS106-1C-5S.
Dan huwa apparat tan-netwerk. Tista 'ssib l-isem tal-mudell tal-prodott fuq it-tikketta tal-każ (ID). |
L-ewwel passi:
- Waħħal mal-PC tiegħek ma 'kwalunkwe port Ethernet;
- Qabbad l-apparat ma 'sors ta' enerġija;
- Ikkonfigurat is-settings IP tal-karta tan-netwerk tiegħek għal 192.168.88.2/24;
- Uża WebFig f’web browser jew l-għodda ta’ konfigurazzjoni “WinBox” https://mt.lv/winbox; metodi multipli ta’ konfigurazzjoni huma disponibbli biex tiġi żgurata l-aċċessibbiltà;
- Agħlaq https://192.168.88.1 f'browser web biex tibda l-setup. Jekk l-indirizz IP mhux disponibbli, uża l-WinBox u għażel it-tab "Neighbors" biex tiskopri d-dispositiv. Kompli b'konnessjoni bl-użu tal-MAC address. Il-username huwa "admin", u m'hemmx password ( jew, għal xi mudelli, iċċekkja passwords tal-utent u tal-wi-fi fuq l-isticker);
- Ikklikkja fuq il-buttuna "Check for updates" u aġġorna l-RouterOS għall-aħħar verżjoni;
- Għal aġġornament manwali tal-apparat, żur mikrotik.com, agħżel il-mudell tiegħek u sib il-pakketti meħtieġa fis-sezzjoni "Downloads";
- Uploadja tal-pakketti miżjuda fil-menu "Files" ta' WebFig jew WinBox u rerew boot l-apparat;
- Billi tnaqqas il-software RouterOS tiegħek għall-aħħar verżjoni, tista' tażżura prestazzjoni ottimale, stabbiltà u aġġornamenti ta' sikurezza;
- Iffurmat il-password tar-router tiegħek.
Informazzjoni dwar is-Sikurezza:
- Qabel ma taħdem fuq kwalunkwe tagħmir MikroTik, kun konxju tal-perikli involuti fiċ-ċirkwiti elettriċi, u kun familjari mal-prattiki standard għall-prevenzjoni ta 'inċidenti. L-installatur għandu jkun familjari mal-istrutturi tan-netwerk, it-termini u l-kunċetti.
- Uża biss il-provvista tal-enerġija u l-aċċessorji approvati mill-manifattur, u li jistgħu jinstabu fl-imballaġġ oriġinali ta 'dan il-prodott.
- Dan it-tagħmir għandu jiġi installat minn persunal imħarreġ u kwalifikat, skont dawn l-istruzzjonijiet tal-installazzjoni. L-installatur huwa responsabbli biex jiżgura li l-Installazzjoni tat-tagħmir tkun konformi mal-kodiċi elettriċi lokali u nazzjonali. Tippruvax iżżarma, tissewwa jew timmodifika l-apparat.
- Dan il-prodott huwa maħsub biex jiġi installat ġewwa. Żomm dan il-prodott 'il bogħod mill-ilma, nar, umdità, jew ambjenti sħan.
- Ma nistgħux niggarantixxu li ma jiġru l-ebda inċidenti jew ħsara minħabba l-użu mhux xieraq tal-apparat. Jekk jogħġbok uża dan il-prodott b'attenzjoni u topera għar-riskju tiegħek!
- Fil-każ ta 'ħsara fl-apparat, jekk jogħġbok skonnettjaha mill-enerġija. L-iktar mod mgħaġġel biex tagħmel dan huwa billi tiskonnettja l-plagg tal-enerġija mill-iżbokk tal-elettriku.
- Is-socket-outlet għandu jkun installat ħdejn it-tagħmir u għandu jkun faċilment aċċessibbli.
- Dan huwa prodott tal-Klassi A. F'ambjent domestiku, dan il-prodott jista 'jikkawża interferenza tar-radju f'liema każ l-utent jista' jkun meħtieġ li jieħu miżuri adegwati.
- Biex tevita l-kontaminazzjoni ta 'l-ambjent, issepara l-apparat mill-iskart domestiku u armih b'mod sigur, per eżempju, f'żoni magħżula. Sir familjari mal-proċeduri biex it-tagħmir jiġi ttrasportat sewwa għal punti magħżula tal-ġbir fl-inħawi tiegħek. Manifattur: Mikrotikls SIA, Unijas 2, Riga, il-Latvja, LV1039.
NL - Nederlands. Snelgids
Dit apparaat moet worden geüpgraded naar RouterOS v7.13.1 of de nieuwste versie om te voldoen aan de voorschriften van de lokale autoriteiten. Het is de verantwoordelijkheid van de eindgebruiker om de lokale landelijke voorschriften. Alle MikroTik-apparatuur moet zijn professioneel geïnstalleerd.
Deze beknopte handleiding behandelt het model: CRS106-1C-5S.
Dit is een netwerkapparaat. U kunt de naam van het productmodel vinden op het etiket van de behuizing (ID). |
Eerste stappen:
- Verbindt u uw pc met elke Ethernet-poort;
- Sluit het apparaat aan op een stroombron;
- Configureer de IP-instellingen van uw netwerkkaart naar 192.168.88.2/24;
- Gebruik WebFig in een webbrowser of de configuratietool "WinBox" https://mt.lv/winbox; er zijn meerdere configuratiemethoden beschikbaar om toegankelijkheid te waarborgen;
- Open https://192.168.88.1 in een webbrowser om de installatie te starten. Als het IP-adres niet beschikbaar is, gebruik dan WinBox en kies het tabblad "Neighbors" om het apparaat te vinden. Ga verder met verbinden via het MAC-adres. De gebruikersnaam is "admin" en er is geen wachtwoord (of, voor sommige modellen, controleer gebruikers- en draadloze wachtwoorden op de sticker);
- Klik op de knop "Check for updates" en update RouterOS naar de nieuwste versie;
- Voor een handmatige update van het apparaat, ga naar mikrotik.com, selecteer uw model en vind de benodigde pakketten in de sectie "Downloads";
- Upload gedownloade pakketten naar het WebFig- of WinBox-"Files"-menu en herstart het apparaat;
- Door uw RouterOS-software bij te werken naar de nieuwste versie, kunt u optimale prestaties, stabiliteit en beveiligingsupdates garanderen;
- Stel het wachtwoord van uw router in.
Veiligheidsinformatie:
- Voordat u aan MikroTik-apparatuur gaat werken, moet u zich bewust zijn van de gevaren die verbonden zijn aan elektrische circuits en vertrouwd zijn met de standaardpraktijken om ongevallen te voorkomen. Het installatieprogramma moet bekend zijn met netwerkstructuren, termen en concepten.
- Gebruik alleen de voeding en accessoires die zijn goedgekeurd door de fabrikant en die zich in de originele verpakking van dit product bevinden.
- Deze apparatuur moet worden geïnstalleerd door opgeleid en gekwalificeerd personeel, volgens deze installatie-instructies. De installateur is ervoor verantwoordelijk dat de installatie van de apparatuur in overeenstemming is met de lokale en nationale elektrische voorschriften. Probeer het apparaat niet uit elkaar te halen, te repareren of aan te passen.
- Dit product is bedoeld om binnenshuis te worden geïnstalleerd. Houd dit product uit de buurt van water, vuur, vochtigheid of hete omgevingen.
- We kunnen niet garanderen dat er geen ongelukken of schade zullen optreden als gevolg van oneigenlijk gebruik van het apparaat. Gebruik dit product met zorg en gebruik het op eigen risico!
- In het geval van een apparaatstoring, koppel het dan los van de stroom. De snelste manier om dit te doen is door de stekker uit het stopcontact te halen.
- Het stopcontact moet in de buurt van de apparatuur worden geïnstalleerd en moet gemakkelijk toegankelijk zijn.
- Dit is een klasse A-product. In een huiselijke omgeving kan dit product radiostoring veroorzaken, in welk geval de gebruiker mogelijk passende maatregelen moet nemen.
- Om milieuverontreiniging te voorkomen, dient u het apparaat van het huisvuil te scheiden en op een veilige manier af te voeren, bijvoorbeeld in daarvoor bestemde ruimtes. Zorg dat u vertrouwd raakt met de procedures voor het correct vervoeren van de apparatuur naar aangewezen inzamelpunten in uw omgeving. Fabrikant: Mikrotikls SIA, Unijas 2, Riga, Letland, LV1039.
PL - Polskie. Szybka porada
To urządzenie musi zostać zaktualizowane do wersji RouterOS v7.13.1 lub najnowszej wersji, aby zapewnić zgodność z przepisami władz lokalnych. Użytkownicy końcowi są zobowiązani do przestrzegania lokalnych przepisów krajowych. Wszystkie urządzenia MikroTik muszą być profesjonalnie zainstalowany.
Niniejszy Krótki przewodnik obejmuje model: CRS106-1C-5S.
To jest urządzenie sieciowe. Nazwę modelu produktu można znaleźć na etykiecie skrzynki (ID). |
Pierwsze kroki:
- Podłącz komputer do dowolnego portu Ethernet;
- Podłącz urządzenie do źródła zasilania;
- Skonfiguruj ustawienia IP karty sieciowej na 192.168.88.2/24;
- Użyj WebFig w przeglądarce internetowej lub narzędzia konfiguracyjnego "WinBox” https://mt.lv/winbox; dostępnych jest wiele metod konfiguracji w celu zapewnienia dostępności;
- Otwórz https://192.168.88.1 w przeglądarce internetowej, aby rozpocząć konfigurację. Jeśli adres IP jest niedostępny, użyj WinBox i wybierz zakładkę "Neighbors", aby znaleźć urządzenie. Kontynuuj łączenie za pomocą adresu MAC. Nazwa użytkownika to "admin", a hasła nie ma (lub, dla niektórych modeli, sprawdź nazwy użytkowników i hasła bezprzewodowe na naklejce);
- Kliknij przycisk "Check for updates" i zaktualizuj RouterOS do najnowszej wersji;
- Aby ręcznie zaktualizować urządzenie, odwiedź mikrotik.com, wybierz swój model i znajdź wymagane pakiety w sekcji "Downloads";
- Prześlij pobrane paczki do menu "Files" WebFig lub WinBox i zrestartuj urządzenie;
- Aktualizując oprogramowanie RouterOS do najnowszej wersji, zapewnisz optymalną wydajność, stabilność i aktualizacje zabezpieczeń;
- Skonfiguruj hasło do routera.
Informacje dotyczące bezpieczeństwa:
- Zanim zaczniesz pracować na jakimkolwiek sprzęcie MikroTik, bądź świadomy zagrożeń związanych z obwodami elektrycznymi i zapoznaj się ze standardowymi praktykami zapobiegania wypadkom. Instalator powinien znać struktury, terminy i koncepcje sieci.
- Używaj wyłącznie zasilacza i akcesoriów zatwierdzonych przez producenta i znajdujących się w oryginalnym opakowaniu tego produktu.
- To urządzenie ma być instalowane przez przeszkolony i wykwalifikowany personel, zgodnie z niniejszą instrukcją instalacji. Instalator jest odpowiedzialny za upewnienie się, że instalacja urządzenia jest zgodna z lokalnymi i krajowymi przepisami elektrycznymi. Nie próbuj demontować, naprawiać ani modyfikować urządzenia.
- Ten produkt jest przeznaczony do instalacji w pomieszczeniach. Trzymaj ten produkt z dala od wody, ognia, wilgoci lub gorących środowisk.
- Nie możemy zagwarantować, że z powodu niewłaściwego użytkowania urządzenia nie nastąpią żadne wypadki lub uszkodzenia. Proszę używać tego produktu ostrożnie i działać na własne ryzyko!
- W przypadku awarii urządzenia należy odłączyć je od zasilania. Najszybszym sposobem na to jest wyjęcie wtyczki z gniazdka.
- Gniazdko powinno być zainstalowane w pobliżu urządzenia i powinno być łatwo dostępne.
- To jest produkt klasy A. W środowisku domowym ten produkt może powodować zakłócenia radiowe, w którym to przypadku użytkownik może być zobowiązany do podjęcia odpowiednich środków.
- Aby uniknąć zanieczyszczenia środowiska, oddziel urządzenie od odpadów domowych i utylizuj je w bezpieczny sposób, na przykład w wyznaczonych miejscach. Zapoznaj się z procedurami prawidłowego transportu sprzętu do wyznaczonych punktów zbiórki w Twojej okolicy. Producent: Mikrotikls SIA, Unijas 2, Riga, Łotwa, LV1039.
PT - Português. Guia rápido
Este dispositivo precisa ser atualizado para o RouterOS v7.13.1 ou a versão mais recente para garantir a conformidade com os regulamentos das autoridades locais. É responsabilidade do usuário final seguir as regulamentações locais do país. Todos os dispositivos de MikroTik devem ser instalado profissionalmente.
Este Guia Rápido cobre o modelo: CRS106-1C-5S.
Este é o dispositivo de rede. Você pode encontrar o nome do modelo do produto no rótulo da caixa (ID). |
Primeiros passos:
- Conecte com o seu PC a qualquer porta Ethernet;
- Conecte o dispositivo a uma fonte de energia;
- Configure as definições de IP do seu cartão de rede para 192.168.88.2/24;
- Use o WebFig num navegador ou a ferramenta de configuração "WinBox" https://mt.lv/winbox; estão disponíveis vários métodos de configuração para garantir a acessibilidade;
- Abra https://192.168.88.1 num navegador web para iniciar a configuração. Se o endereço IP não estiver disponível, utilize o WinBox e escolha a aba "Neighbors" para encontrar o dispositivo. Prossiga para conectar usando o endereço MAC. O nome de usuário é "admin", e não há senha (ou, para alguns modelos, verifique os nomes de usuário e senhas sem fio no adesivo);
- Clique no botão "Check for updates" e atualize o RouterOS para a versão mais recente;
- Para atualizar manualmente o dispositivo, visite mikrotik.com, selecione o seu modelo e localize os pacotes necessários na seção "Downloads";
- Faça o upload dos pacotes baixados para o menu "Files" do WebFig ou WinBox e reinicie o dispositivo;
- Ao atualizar o software do RouterOS para a versão mais recente, você pode garantir um desempenho, estabilidade e atualizações de segurança ótimos;
- Configure a senha do seu roteador.
Informação de Segurança:
- Antes de trabalhar em qualquer equipamento MikroTik, esteja ciente dos perigos envolvidos com os circuitos elétricos e esteja familiarizado com as práticas padrão para prevenção de acidentes. O instalador deve estar familiarizado com as estruturas, termos e conceitos de rede.
- Use apenas fonte de alimentação e acessórios aprovados pelo fabricante e que podem ser encontrados na embalagem original deste produto.
- Este equipamento deve ser instalado por pessoal treinado e qualificado, de acordo com estas instruções de instalação. O instalador é responsável por garantir que a instalação do equipamento esteja em conformidade com os códigos elétricos locais e nacionais. Não tente desmontar, reparar ou modificar o dispositivo.
- Este produto deve ser instalado em ambientes internos. Mantenha este produto longe de água, fogo, umidade ou ambientes quentes.
- Não podemos garantir que nenhum acidente ou dano ocorrerá devido ao uso impróprio do dispositivo. Use este produto com cuidado e opere por sua própria conta e risco!
- No caso de falha do dispositivo, desconecte-o da energia. A maneira mais rápida de fazer isso é desconectando o plugue de alimentação da tomada.
- A tomada deve ser instalada próxima ao equipamento e deve ser de fácil acesso.
- Este é um produto de Classe A. Em um ambiente doméstico, este produto pode causar interferência de rádio, caso em que o usuário pode ser obrigado a tomar as medidas adequadas.
- Para evitar a contaminação do meio ambiente, separe o dispositivo do lixo doméstico e descarte-o de maneira segura, por exemplo, em áreas designadas. Familiarize-se com os procedimentos para o transporte adequado do equipamento aos pontos de coleta designados em sua área. Fabricante: Mikrotikls SIA, Unijas 2, Riga, Letônia, LV1039.
RO - Română. Ghid rapid
Acest dispozitiv trebuie actualizat la RouterOS v7.13.1 sau cea mai recentă versiune pentru a asigura respectarea reglementărilor autorității locale. Este responsabilitatea utilizatorilor finali să urmeze reglementările locale ale țării. Toate dispozitivele MikroTik trebuie să fie instalat profesional.
Acest Ghid rapid acoperă modelul: CRS106-1C-5S.
Acesta este dispozitivul de rețea. Puteți găsi numele modelului produsului pe eticheta carcasei (ID). |
Primii pasi:
- Conectați-vă cu computerul la orice port Ethernet;
- Conectați dispozitivul la o sursă de alimentare;
- Configurați setările IP ale plăcii de rețea la 192.168.88.2/24;
- Utilizați WebFig într-un browser web sau instrumentul de configurare "WinBox” https://mt.lv/winbox; sunt disponibile mai multe metode de configurare pentru a asigura accesibilitatea;
- Deschideți https://192.168.88.1 într-un browser web pentru a începe configurarea. Dacă adresa IP nu este disponibilă, utilizați WinBox și alegeți fila "Neighbors" pentru a găsi dispozitivul. Continuați conectarea folosind adresa MAC. Numele de utilizator este "admin", și nu există parolă (sau, pentru unele modele, verificați utilizatori și parole wireless pe autocolant);
- Faceți clic pe butonul "Check for updates" și actualizați RouterOS la cea mai recentă versiune;
- Pentru actualizarea manuală a dispozitivului, accesați mikrotik.com, selectați modelul dvs. și găsiți pachetele necesare în secțiunea "Downloads";
- Încărcați pachetele descărcate în meniul "Files" al WebFig sau WinBox și reporniți dispozitivul;
- Prin actualizarea software-ului RouterOS la cea mai recentă versiune, puteți asigura performanță optimă, stabilitate și actualizări de securitate;
- Setați parola routerului.
Informații de siguranță:
- Înainte de a lucra la orice echipament MikroTik, fiți conștienți de pericolele implicate de circuitele electrice și cunoașteți practicile standard pentru prevenirea accidentelor. Instalatorul ar trebui să fie familiarizat cu structurile de rețea, termenii și conceptele.
- Utilizați numai sursa de alimentare și accesoriile aprobate de producător și care pot fi găsite în ambalajul original al acestui produs.
- Acest echipament trebuie instalat de personal instruit și calificat, conform acestor instrucțiuni de instalare. Instalatorul este responsabil pentru asigurarea faptului că instalarea echipamentului este conformă cu codurile electrice locale și naționale. Nu încercați să dezasamblați, să reparați sau să modificați dispozitivul.
- Acest produs este destinat instalării în interior. Păstrați acest produs departe de apă, foc, umiditate sau medii fierbinți.
- Nu putem garanta că nu vor apărea accidente sau daune din cauza utilizării necorespunzătoare a dispozitivului. Vă rugăm să utilizați acest produs cu grijă și să operați pe propriul risc!
- În caz de defecțiune a dispozitivului, vă rugăm să îl deconectați de la alimentare. Cea mai rapidă modalitate de a face acest lucru este deconectând ștecherul de la priză.
- Priza trebuie instalată în apropierea echipamentului și trebuie să fie ușor accesibilă.
- Acesta este un produs de clasa A. Într-un mediu casnic, acest produs ar putea provoca interferențe radio, caz în care utilizatorul ar putea fi obligat să ia măsuri adecvate.
- Pentru a evita contaminarea mediului, separați dispozitivul de deșeurile menajere și aruncați-le într-un mod sigur, de exemplu, în zonele desemnate. Familiarizați-vă cu procedurile pentru transportul corespunzător al echipamentelor la punctele de colectare desemnate din zona dumneavoastră. Producător: Mikrotikls SIA, Unijas 2, Riga, Letonia, LV1039.
SK - Slovenský. Stručný návod
Toto zariadenie musí byť aktualizované na RouterOS v7.13.1 alebo na najnovšiu verziu, aby sa zabezpečilo dodržiavanie predpisov miestnych úradov. Je na koncových užívateľoch, aby dodržiavali miestne predpisy krajiny. Všetky zariadenia MikroTik musia byť profesionálne nainštalovaný.
Táto Stručná príručka sa týka modelu: CRS106-1C-5S.
Toto je sieťové zariadenie. Názov modelu produktu nájdete na štítku prípadu (ID). |
Prvé kroky:
- Pripojte svoj počítač k akémukoľvek portu Ethernet;
- Pripojte zariadenie k zdroju napájania;
- Nakonfigurujte IP nastavenia vašej sieťovej karty na 192.168.88.2/24;
- Použite WebFig v webovom prehliadači alebo konfiguračný nástroj "WinBox“ https://mt.lv/winbox; na zabezpečenie prístupnosti sú k dispozícii viaceré metódy konfigurácie;
- Otvorte https://192.168.88.1 vo webovom prehliadači pre začiatok nastavenia. Ak nie je k dispozícii IP adresa, použite WinBox a vyberte kartu "Neighbors" na nájdenie zariadenia. Pokračujte v pripájaní pomocou MAC adresy. Užívateľské meno je "admin", a nie je heslo (alebo, pre niektoré modely, skontrolujte užívateľské a heslá pre bezdrôtové pripojenie na štítku);
- Kliknite na tlačidlo "Check for updates" a aktualizujte RouterOS na najnovšiu verziu;
- Na manuálnu aktualizáciu zariadenia navštívte mikrotik.com, vyberte svoj model a nájdite požadované balíčky v sekcii "Downloads";
- Nahrajte stiahnuté balíky do menu "Files" vo WebFig alebo WinBox a reštartujte zariadenie;
- Aktualizáciou softvéru RouterOS na najnovšiu verziu môžete zabezpečiť optimálnu výkon, stabilitu a bezpečnostné aktualizácie;
- Nastavte heslo pre váš router.
Bezpečnostné informácie:
- Pred prácou na akomkoľvek zariadení MikroTik si uvedomte riziká spojené s elektrickým obvodom a oboznámte sa so štandardnými postupmi prevencie nehôd. Inštalátor by mal byť oboznámený so sieťovými štruktúrami, termínmi a konceptmi.
- Používajte iba napájací zdroj a príslušenstvo schválené výrobcom, ktoré sa nachádzajú v pôvodnom obale tohto produktu.
- Toto zariadenie má byť inštalované vyškoleným a kvalifikovaným personálom podľa týchto inštalačných pokynov. Inštalatér zodpovedá za to, že inštalácia zariadenia je v súlade s miestnymi a národnými elektrickými predpismi. Nepokúšajte sa zariadenie rozoberať, opravovať alebo upravovať.
- Tento výrobok je určený na inštaláciu v interiéri. Uchovávajte tento výrobok mimo vody, ohňa, vlhkosti alebo horúceho prostredia.
- Nemôžeme zaručiť, že v dôsledku nesprávneho použitia zariadenia nedôjde k žiadnym nehodám alebo škodám. Používajte tento výrobok opatrne a pracujte na vlastné riziko!
- V prípade poruchy zariadenia ho odpojte od napájania. Najrýchlejší spôsob, ako to urobiť, je vytiahnuť sieťovú zástrčku zo zásuvky.
- Zásuvka musí byť inštalovaná v blízkosti zariadenia a musí byť ľahko dostupná.
- Toto je výrobok triedy A. V domácom prostredí môže tento výrobok spôsobovať rádiové rušenie. V takom prípade môže byť od používateľa vyžadované prijatie primeraných opatrení.
- Aby ste zabránili kontaminácii životného prostredia, odpojte prístroj od domáceho odpadu a zneškodnite ho bezpečným spôsobom, napríklad na určených miestach. Oboznámte sa s postupmi správnej prepravy zariadenia na určené zberné miesta vo vašej oblasti. Výrobca: Mikrotikls SIA, Unijas 2, Riga, Lotyšsko, LV1039.
SL - Slovenščina. Hitri vodnik
To napravo je treba nadgraditi na RouterOS v7.13.1 ali najnovejšo različico, da se zagotovi skladnost z lokalnimi predpisi. Končni uporabniki so odgovorni za sledenje lokalnim predpisom. Vse naprave MikroTik morajo biti strokovno nameščen.
Ta hitri vodnik zajema model: CRS106-1C-5S.
To je omrežna naprava. Ime modela izdelka najdete na nalepki (ID). |
Prvi koraki:
- Povežite se z računalnikom na katera koli vrata Ethernet;
- Napravo priključite na vir napajanja;
- Nastavite IP nastavitve svoje omrežne kartice na 192.168.88.2/24;
- Uporabite WebFig v spletni brskalniku ali konfiguracijsko orodje "WinBox“ https://mt.lv/winbox; na voljo je več metod konfiguracije za zagotovitev dostopnosti;
- Odpri https://192.168.88.1 v spletnem brskalniku, da začneš nastavljanje. Če IP naslov ni na voljo, uporabi WinBox in izberi zavihek "Neighbors" za iskanje naprave. Nadaljuj s povezovanjem prek MAC naslova. Uporabniško ime je "admin", in ni gesla (ali, za nekatere modele, preveri uporabniška imena in gesla brezžične povezave na nalepki);
- Kliknite na gumb "Check for updates" in posodobite RouterOS na najnovejšo različico;
- Za ročno posodobitev naprave obiščite mikrotik.com, izberite svoj model in poiščite potrebne pakete v razdelku "Downloads";
- Naložite prenesene pakete v meni "Files" WebFig ali WinBox in znova zaženite napravo;
- Z nadgradnjo programske opreme RouterOS na najnovejšo različico zagotovite optimalno delovanje, stabilnost in varnostne posodobitve;
- Nastavite geslo za svoj usmerjevalnik.
Varnostne informacije:
- Preden delate na kateri koli MikroTik opremi, se zavedajte nevarnosti, povezanih z električnimi vezji, in se seznanite s standardnimi praksami za preprečevanje nesreč. Namestitveni program mora poznati omrežne strukture, izraze in koncepte.
- Uporabljajte samo napajalnik in dodatno opremo, ki jih je odobril proizvajalec in jih najdete v originalni embalaži tega izdelka.
- To opremo mora namestiti usposobljeno in usposobljeno osebje v skladu s temi navodili za namestitev. Monter je odgovoren za to, da je namestitev opreme skladna z lokalnimi in državnimi električnimi kodeksi. Naprave ne poskušajte razstavljati, popravljati ali spreminjati.
- Ta izdelek je namenjen za vgradnjo v zaprtih prostorih. Izdelek hranite ločeno od vode, ognja, vlage ali vročih okolij.
- Ne moremo jamčiti, da zaradi nepravilne uporabe naprave ne bo prišlo do nesreč ali poškodb. Prosimo, da ta izdelek uporabljate previdno in delate na lastno odgovornost!
- V primeru okvare naprave odklopite napajanje. Najhitreje to storite tako, da izvlečete vtič iz vtičnice.
- Vtičnica mora biti nameščena v bližini opreme in mora biti lahko dostopna.
- To je izdelek razreda A. V domačem okolju lahko ta izdelek povzroči radijske motnje, v tem primeru bo uporabnik morda moral sprejeti ustrezne ukrepe.
- Da se izognete onesnaženju okolja, napravo ločite od gospodinjskih odpadkov in jo varno odvrzite, na primer na določena mesta. Spoznajte postopke za pravilen prevoz opreme do določenih zbirnih mest na vašem območju. Proizvajalec: Mikrotikls SIA, Unijas 2, Riga, Latvija, LV1039.
SV - Svenska. Snabb guide
Den här enheten måste uppgraderas till RouterOS v7.13.1 eller den senaste versionen för att säkerställa överensstämmelse med lokala myndighetsbestämmelser. Det är slutanvändarnas ansvar att följa lokala landsregler. Alla MikroTik-enheter måste vara professionellt installerat.
Detta dokument täcker modellen: CRS106-1C-5S.
Det här är nätverksenhet. Du hittar produktmodellnamnet på etiketten (ID). |
Första stegen:
- Anslut med din dator till vilken Ethernet-port som helst;
- Anslut enheten till en strömkälla;
- Konfigurera IP-inställningarna för ditt nätverkskort till 192.168.88.2/24;
- Använd WebFig i en webbläsare eller konfigurationsverktyget "WinBox" https://mt.lv/winbox; flera konfigurationsmetoder är tillgängliga för att säkerställa tillgänglighet;
- Öppna https://192.168.88.1 i en webbläsare för att starta inställningen. Om IP-adressen inte är tillgänglig, använd WinBox och välj fliken "Neighbors" för att hitta enheten. Fortsätt att ansluta med MAC-adressen. Användarnamnet är "admin", och det finns inget lösenord (eller, för vissa modeller, kontrollera användar- och trådlösa lösenord på klistermärket);
- Klicka på knappen "Check for updates" och uppdatera RouterOS till den senaste versionen;
- För manuell uppdatering av enheten, gå till mikrotik.com, välj din modell och hitta de nödvändiga paketen i avsnittet "Downloads";
- Ladda upp nedladdade paket till WebFig eller WinBox "Files" -menyn och starta om enheten;
- Genom att uppgradera din RouterOS-programvara till den senaste versionen kan du säkerställa optimal prestanda, stabilitet och säkerhetsuppdateringar;
- Ställ in lösenordet för din router.
Säkerhetsinformation:
- Innan du arbetar med någon MikroTik -utrustning, var medveten om riskerna med elektriska kretsar och bekanta dig med standardmetoder för att förebygga olyckor. Installatören bör känna till nätverksstrukturer, termer och koncept.
- Använd endast strömförsörjning och tillbehör som godkänts av tillverkaren och som finns i originalförpackningen till denna produkt.
- Denna utrustning ska installeras av utbildad och kvalificerad personal enligt denna installationsanvisning. Installatören ansvarar för att installationen av utrustningen överensstämmer med lokala och nationella elektriska föreskrifter. Försök inte demontera, reparera eller modifiera enheten.
- Denna produkt är avsedd att installeras inomhus. Håll denna produkt borta från vatten, eld, fukt eller varma miljöer.
- Vi kan inte garantera att inga olyckor eller skador uppstår på grund av felaktig användning av enheten. Använd denna produkt med omsorg och kör på egen risk!
- Vid enhetsfel, koppla bort den från strömmen. Det snabbaste sättet att göra det är att dra ut kontakten ur vägguttaget.
- Uttaget ska installeras nära utrustningen och ska vara lättillgängligt.
- Detta är en klass A -produkt. I hemmet kan denna produkt orsaka radiostörningar, i vilket fall användaren kan behöva vidta lämpliga åtgärder.
- För att undvika förorening av miljön, separera enheten från hushållsavfall och kassera den på ett säkert sätt, till exempel i avsedda områden. Bli bekant med procedurer för korrekt transport av utrustningen till utsedda uppsamlingsställen i ditt område. Tillverkare: Mikrotikls SIA, Unijas 2, Riga, Lettland, LV1039.
PRC - 中文. 快速指南
该设备需要升级到RouterOS v7.13.1或最新版本,以确保符合地方当局法规。 最终用户有责任遵守当地国家法规。所有 MikroTik 设备都必须经过专业安装。
本快速指南介绍了以下型号:CRS106-1C-5S。
这是网络设备。 您可以在包装箱标签(ID)上找到产品型号名称。 |
第一步:
- 将您的 PC 连接到任何以太网端口;
- 将设备连接到电源。
- 配置您网络卡的IP设置为192.168.88.2/24;
- 在网络浏览器中使用 WebFig 或使用“WinBox”配置工具 https://mt.lv/winbox 提供多种配置方法以确保可访问性;
- 在Web浏览器中打开https://192.168.88.1 以开始设置。如果IP地址不可用,请使用WinBox并选择“Neighbors”选项卡查找设备。通过MAC地址继续连接。用户名是“admin”,没有密码(或者对于某些型号,请检查贴纸上的用户和无线密码);
- 单击"Check for updates"按钮并将RouterOS更新到最新版本;
- 要手动更新设备,请访问 mikrotik.com,选择您的型号,并在"Downloads"部分找到所需的软件包;
- 将下载的软件包上传到WebFig或WinBox的“Files”菜单,并重新启动设备;
- 通过将RouterOS软件升级到最新版本,您可以确保最佳性能、稳定性和安全更新;
- 设置您的路由器密码。
安全信息:
- 在您使用任何 MikroTik 设备之前,请注意与电路相关的危险,并熟悉预防事故的标准做法。安装人员应熟悉网络结构、术语和概念。
- 只能使用制造商认可的电源和附件,这些附件可以在本产品的原始包装中找到。
- 该设备应由经过培训的合格人员按照这些安装说明进行安装。安装人员负责确保设备的安装符合当地和国家电气规范。请勿尝试拆卸、修理或改装设备。
- 本产品旨在安装在室内。使本产品远离水、火、湿气或高温环境。
- 我们不能保证不会因设备使用不当而发生事故或损坏。请谨慎使用本产品,操作风险自负!
- 如果设备出现故障,请断开电源。最快的方法是从电源插座上拔下电源插头。
- 插座應安裝在設備附近,並應易於取用。
- 这是A类产品。在家庭环境中,本产品可能会造成无线电干扰,在这种情况下,用户可能需要采取足够的措施.
- 为避免污染环境,请将设备与生活垃圾分开,并以安全的方式进行处置,例如在指定区域。熟悉将设备正确运输到您所在地区指定收集点的过程。 制造商:Mikrotikls SIA,拉脱维亚Unijas 2, Riga,LV1039。
RU - Русский. Краткое пособие. Евразийский экономический союз информация
Это устройство должно быть обновлено до RouterOS v7.13.1 или до последней версии, чтобы обеспечить соответствие требованиям местных органов власти. Конечные пользователи несут ответственность за соблюдение местных нормативов. Все устройства MikroTik должны быть профессионально установлены.
Это краткое руководство охватывает модель: CRS106-1C-5S.
Это сетевое устройство. Вы можете найти название модели продукта на ярлыке кейса (ID). |
Первые шаги:
- Подключитесь к ПК к любому порту Ethernet;
- Подключите устройство к источнику питания;
- Настройте IP-адрес вашей сетевой карты на 192.168.88.2/24;
- Используйте WebFig в веб-браузере или инструмент настройки ”WinBox” https://mt.lv/winbox; существует несколько методов настройки для обеспечения доступности;
- Откройте https://192.168.88.1 в веб-браузере, чтобы начать установку. Если IP-адрес недоступен, используйте WinBox и выберите вкладку "Neighbors", чтобы найти устройство. Продолжите подключение, используя MAC-адрес. Имя пользователя - "admin", и пароля нет (или, для некоторых моделей, проверьте имена пользователей и пароли Wi-Fi на наклейке);
- Нажмите кнопку "Check for updates" и обновите RouterOS до последней версии;
- Для ручного обновления устройства зайдите на mikrotik.com, выберите свою модель и найдите необходимые пакеты в разделе "Downloads";
- Загрузите скачанные пакеты в меню "Files" WebFig или WinBox и перезагрузите устройство;
- Обновив программное обеспечение RouterOS до последней версии, вы можете обеспечить оптимальную производительность, стабильность и обновления безопасности;
- Установите пароль для вашего маршрутизатора.
Информация по технике безопасности:
- Перед началом работы на любом оборудовании MikroTik ознакомьтесь с опасностями, связанными с электрическими цепями, и ознакомьтесь со стандартными методами предотвращения несчастных случаев. Установщик должен быть знаком с сетевыми структурами, терминами и концепциями.
- Используйте только те источники питания и аксессуары, которые утверждены производителем и находятся в оригинальной упаковке этого продукта.
- Это оборудование должно быть установлено обученным и квалифицированным персоналом согласно этим инструкциям по установке. Установщик несет ответственность за то, чтобы установка оборудования соответствовала местным и национальным электротехническим нормам и правилам. Не пытайтесь разбирать, ремонтировать или модифицировать устройство.
- Изделие предназначено для установки в помещении. Держите изделие вдали от воды, огня, влаги или горячих сред.
- Мы не можем гарантировать, что в результате неправильного использования устройства не произойдет несчастных случаев или повреждений. Пожалуйста, используйте этот продукт с осторожностью и действуйте на свой страх и риск!
- В случае сбоя устройства отключите его от питания. Самый быстрый способ сделать это - вынуть вилку из розетки.
- Розетка должна быть установлена рядом с оборудованием и должна быть легко доступна.
- Это продукт класса А. В домашних условиях этот продукт может вызывать радиопомехи, и в этом случае пользователю может потребоваться принять адекватные меры.
Запрещается:
- Эксплуатация роутера (точки доступа) и её комплектующих с повреждёнными шнурами электропитания;
- Подключение роутера (точки доступа) и её комплектующих к сети электропитания при открытых корпусах;
- Открыватькорпус изделия, разбирать, извлекать электронные модули и проводить какие-либо ремонтные работы вне условий ремонтной организации.
Техническое обслуживание:
- Роутер (точка доступа) не требует проведения профилактических работ и постоянного присутствия эксплуатационного персонала.
- Чистка корпуса от пыли и загрязнений выполняется бумажными безворсовыми салфетками.
- Не брызгайте водой в щели и контакты корпуса изделия.
- Плохо выводящиеся следы и пятна удаляйте изопропиловым спиртом.
Текущий ремонт:
- Все виды ремонта изделия допускается выполнять только аттестованным персоналом в сервисном центре предприятия-изготовителя или в другой уполномоченной изготовителем организации.
- Замена вышедших из строя технических средств (ТС) изделия должна осуществляться на соответствующие ТС, прошедшие специальные исследования и специальную проверку.
Хранение:
- Изделия, упакованные в ящик, следует хранить в складских помещениях при относительная влажность воздуха не более 85%, наличие в воздухе паров кислот, щелочей и прочих агрессивных примесей не допускается.
Транспортирование:
- Транспортируют изделия всеми видами транспорта в крытых транспортных средствах в соответствии с правилами перевозки грузов, действующих на данном виде транспорта.
- Транспортирование и хранение должны осуществляться в упаковке фирмы-изготовителя с соблюдением указаний по ориентации, защите, укладке и других, нанесенных на упаковку указаний обозначений.
- В помещениях и транспортных средствах не должно быть паров или аэрозолей агрессивных или вызывающих коррозию веществ.
- Упакованные изделия должны быть закреплены для предотвращения случайных неконтролируемых перемещений.
- Транспортирование, хранение и эксплуатация не допустимы в условиях конденсации влаги без защиты от атмосферных осадков и прямых солнечных лучей.
Гарантийные обязательства:
- Гарантийный срок эксплуатации − не более 14 суток со дня реализации потребителю.
- Гарантийный срок хранения изделий − 12 месяцев со дня изготовления.
- Некачественные изделия продавец обязан заменить в сроки, согласованные с потребителем.
- В случае спора о причинах возникновения недостатков товара продавец (изготовитель), уполномоченная организация или уполномоченный индивидуальный предприниматель, импортер обязаны провести экспертизу товара за свой счет.
- Срок устранения недостатков товара не может превышать сорок пять дней.
- Действие гарантийных обязательств прекращается:- при нарушении потребителем правил эксплуатации, транспортирования и хранения;- при обнаружении механических повреждений, следов вскрытия, попыток неквалифицированного ремонта;- при обнаружении признаков небрежного обращения, преднамеренного повреждения оборудования;- при попадании внутрь оборудования посторонних предметов, жидкостей и насекомых;- при обнаружении признаков воздействия непреодолимых сил, приведших к выходу из строя роутера (точки доступа).
Утилизация:
- Во избежание загрязнения окружающей среды необходимо отделить устройство от бытовых отходов и утилизировать его безопасным способом, например в специально отведенных местах. Ознакомьтесь с процедурами надлежащей транспортировки оборудования к специальным местам утилизации в вашем регионе. Информация о дате изготовления устройства указана в конце серийного номера на его наклейке через дробь. Первая цифра означает номер года (последняя цифра года), две последующие означают номер недели.
Изготовитель: SIA Mikrotikls, Aizkraukles iela 23, Riga, LV-1006, Латвия, support@mikrotik.com. Сделано в Китае, Латвии или Литве. Cм. на упаковке.
Для получения подробных сведений о гарантийном обслуживании обратитесь к продавцу.
Продукты MikroTik, которые поставляются в Евразийский таможенный союз, оцениваются с учетом соответствующих требований и помечены знаком EAC, как показано ниже:
UA - Українська. Короткий посібник
Цей пристрій потрібно оновити до RouterOS v7.13.1 або останньої версії, щоб забезпечити відповідність місцевим нормам влади! Кінцеві користувачі несуть відповідальність за дотримання місцевих правил. Всі радіопристрої MikroTik повинні бути встановлені відповідно до інструкцій.
Цей короткий посібник стосується моделі: CRS106-1C-5S.
Це пристрій бездротової мережі. Ви можете знайти назву моделі продукту на етикетці корпусу (ID). |
Перші кроки:
- Підключіться до ПК через будь-який порт Ethernet;
- Підключіть пристрій до адаптеру електроживлення;
- Налаштуйте IP-адресу вашої мережевої карти на 192.168.88.2/24;
- Використовуйте WebFig у веб-браузері або інструмент конфігурації ”WinBox” https://mt.lv/winbox; існує декілька методів налаштування для забезпечення доступності;
- Відкрийте веб-браузер і перейдіть за адресою https://192.168.88.1 для початку налаштувань. У випадку відсутності IP-адреси скористайтеся WinBox та оберіть вкладку "Neighbors", щоб знайти пристрій. Продовжте підключення за допомогою MAC-адреси. Ім'я користувача - "admin", і відсутній пароль (або, для деяких моделей, перевірте імена користувачів та паролі Wi-Fi на наклейці);
- Натисніть кнопку "Check for updates" і оновіть RouterOS до останньої версії;
- Щоб оновити пристрій вручну, відвідайте сторінку продуктів за адресою mikrotik.com, виберіть свою модель і знайдіть потрібні пакети в розділі "Downloads";
- Завантажте завантажені пакети в меню "Files" WebFig або WinBox та перезавантажте пристрій;
- Оновивши програмне забезпечення RouterOS до останньої версії, ви можете забезпечити оптимальну продуктивність, стабільність та оновлення безпеки;
- Встановіть пароль для вашого маршрутизатора.
Інформація про безпеку:
- Перш ніж працювати з будь-яким обладнанням MikroTik, усвідомте небезпеку, пов’язану з електричними схемами, і ознайомтеся зі стандартними методами запобігання нещасним випадкам. Особа, що виконує роботи зі встановлення устаткування мусить бути ознайомлена із правилами роботи з мережевими системами, термінами та концепціями.
- Використовуйте тільки адаптер електроживлення та аксесуари, затверджені виробником, і які можна знайти в оригінальній упаковці цього виробу.
- Це обладнання має встановлювати навчений та кваліфікований персонал відповідно до цих інструкцій зі встановлення. Особа, що виконує роботи зі встановлення устаткування несе відповідальність за те, щоб встановлення обладнання відповідало місцевим і національним електричним нормам. Не намагайтеся розібрати, відремонтувати чи модифікувати пристрій.
- Це обладнання призначене для встановлення в приміщенні. Тримайте це обладнання подалі від води, вогню, вологи, або гарячого середовища.
- Ми не можемо гарантувати відсутність нещасних випадків або пошкоджень через неправильне використання пристрою. Використовуйте цей продукт обережно та на свій страх і ризик.
- У разі несправності пристрою відключіть його від електроживлення. Найшвидший спосіб це зробити — від’єднати адаптер електроживлення від розетки.
- Розетка має бути встановлена поблизу обладнання та бути легко доступною.
- Це продукт класу А. У побутових умовах цей виріб може викликати радіоперешкоди, і в цьому випадку від користувача може знадобитися вжити відповідних заходів.
- Щоб уникнути забруднення навколишнього середовища, відокремте пристрій від побутових відходів та утилізуйте його безпечним способом, наприклад, у відведених місцях. Ознайомтесь із процедурами належного транспортування обладнання до визначених пунктів збору у вашому районі. Виробник: Mikrotikls SIA, Unijas 2, Рига, Латвія, LV1039.
Federal Communication Commission Interference Statement
This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a commercial installation.
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his own expense
FCC Caution: Any changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate this equipment.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Note: This unit was tested with shielded cables on the peripheral devices. Shielded cables must be used with the unit to ensure compliance.
Innovation, Science and Economic Development Canada
This device contains license-exempt transmitter(s)/receiver(s) that comply with Innovation, Science, and Economic Development Canada’s license-exempt RSS(s). Operation is subject to the following two conditions: (1) This device may not cause interference. (2) This device must accept any interference, including interference that may cause undesired operation of the device.
L’émetteur/récepteur exempt de licence contenu dans le présent appareil est conforme aux CNR d’Innovation, Sciences et Développement économique Canada applicables aux appareils radio exempts de licence. L’exploitation est autorisée aux deux conditions suivantes: 1) L’appareil ne doit pas produire de brouillage; 2) L’appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d’en compromettre le fonctionnement.
This Class A digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe [A] est conforme à la norme NMB-003 du Canada.
CAN ICES-003 (A) / NMB-003 (A)
UKCA marking
| (EN) Technical Specifications / (DE) Technische Spezifikationen / (FR) Spécifications techniques / (IT) Specifiche tecniche / (ES) Especificaciones técnicas / (RU) Технические характеристики: | ||||
| (EN) Product Power Input Options (DE) Produkt Stromquellen Optionen (FR) Options d'entrée d'alimentation du produit (IT) Opzioni di ingresso alimentazione del prodotto (ES) Opciones de entrada de energía del producto (RU) Параметры входной мощности продукта | (EN) DC Adapter Output Specification (DE) Ausgangsspezifikationen des Gleichstromadapters (FR) Spécifications de sortie de l'adaptateur de courant continu (IT) Specifiche di uscita dell'adattatore di corrente continua (ES) Especificaciones de salida del adaptador de corriente continua (RU) Выходные характеристики адаптера постоянного тока | (EN) IP class of the enclosure (DE) IP-Klasse des Gehäuses (FR) Classe IP du boîtier (IT) Classe IP della custodia (ES) Clase de IP del recinto (RU) Класс защиты корпуса IP | (EN) Operating Temperature (DE) Betriebstemperatur (FR) température de fonctionnement (IT) temperatura di esercizio (ES) Temperatura de funcionamiento (RU) Рабочая Температура | |
| Voltage, V | Current, A | |||
| DC Jack (11-30 V DC) PoE In Ethernet Port (11-30 V DC) | 24 V | 0.8A | IP20 | ±0°..+70°C |
#76921
