Skip to main content
Version: 7.26
Configuring EasyMesh
Package: wifi-qcom, wifi-qcom-ac
warning
EasyMesh is available in CLI (no GUI support yet).
At this moment, it works on wifi-qcom and wifi-qcom-ac only.
EasyMesh is a Wi-Fi Alliance standard for multi-AP Wi-Fi networks. One device acts as the controller and manages one or more agents. The controller distributes the Wi-Fi configuration to the agents, so all access points broadcast the same networks and use coordinated settings. For the complete list of settings, see the EasyMesh CLI reference.
CAPsMAN provides similar centralized management for MikroTik devices, but it is primarily intended for access points connected to the network with Ethernet. It does not provide the standardized wireless backhaul and WPS onboarding. EasyMesh is a vendor-neutral standard, so a certified controller can manage certified agents from different vendors. Interoperability still depends on the devices, so test the controller and agent combination before deployment.
Topology​
An EasyMesh network has one controller and one or more agents. The controller and agents must be in the same Layer 2 network. Agents connect to the controller over a wired Ethernet connection or a wireless backhaul link. The backhaul (wired and wireless) carries EasyMesh management traffic and the client traffic of each agent.
A device performs one of three EasyMesh roles:
  • controller - manages the EasyMesh network. It provides the fronthaul and backhaul configurations and coordinates the agents. Use it on a device that only performs controller duties.
  • agent - joins the EasyMesh network and receives its configuration from the controller. It broadcasts the configured fronthaul networks and connects to the controller over a wireless backhaul link or a wired Ethernet connection. Use it on additional access points.
  • controller-and-agent - performs both roles on the same device. A single Wi-Fi device can manage the EasyMesh network and also serve clients as an agent. Use it on the main router or access point with Wi-Fi radios.
Only the controller manages the network. An agent receives and applies configuration (it does not manage other agents, but it can relay controller traffic over the backhaul).
In most setups, the main router uses controller-and-agent and additional access points use agent.
The radios on these devices can perform the following roles:
  • Fronthaul AP - broadcasts the client networks. Client devices connect to these BSSes.
  • Backhaul AP - broadcasts the backhaul network. Agents use it to connect to the controller. Client devices do not use this network.
  • Backhaul station - connects an agent to the controller's backhaul AP. It is used only for a wireless backhaul.
The same radio can provide both fronthaul and backhaul BSSes. Fronthaul interfaces stay dedicated to clients and are bridged to the backhaul.
The controller and agents exchange EasyMesh control messages with the IEEE 1905.1 standard (EtherType 0x893A). It carries Wi-Fi Alliance Multi-AP Control Message Data Units (CMDUs) and TLVs over the Layer 2 backhaul. WPS onboarding uses 802.11/EAP-WSC.
Controller configuration​
Set the radio manager​
Set the EasyMesh manager on every radio that EasyMesh should control:
/interface/wifi
set [find default-name=wifi1] configuration.manager=easymesh
set [find default-name=wifi2] configuration.manager=easymesh
Adjust the interface names to match your device.
Create the Wi-Fi configurations​
Create a fronthaul configuration for clients and a backhaul configuration for wireless agents:
/interface/wifi/configuration
add name=em_fh ssid=em_fh security.authentication-types=wpa2-psk security.passphrase=fronthaul-password
add name=em_bh ssid=em_bh security.authentication-types=wpa2-psk security.passphrase=backhaul-password
  • em_fh is the client network, broadcast by agents for client devices.
  • em_bh is the backhaul network, broadcast by agents for other agents to connect to. Use a separate SSID and password from the client network.
Enable the controller​
/interface/wifi/easymesh
set enabled=yes role=controller-and-agent bridge=bridge bhaul-configuration=em_bh fhaul-configurations=em_fh dpp-onboarding=no
  • role=controller-and-agent makes the device manage the network and provide Wi-Fi. Use role=controller if the device only manages the network.
  • bridge=bridge is the bridge that connects the controller to the agents. Use the existing LAN bridge.
  • bhaul-configuration=em_bh selects the backhaul configuration.
  • fhaul-configurations=em_fh selects the client network. Add more configuration names to broadcast more networks.
The backhaul SSID and security come from the em_bh configuration. Wireless agents receive these credentials during onboarding.
Agent configuration​
Prepare the access point​
Configure the agent as a bridged access point. Set the EasyMesh manager on every radio:
/interface/wifi
Configure the bridge and the management IP address as described in Configuring standalone access point. The bridge must include the Ethernet port used for a wired backhaul.
Enable the agent​
set enabled=yes role=agent bridge=bridge dpp-onboarding=no
EasyMesh adds its Wi-Fi interfaces to the bridge specified in the bridge setting. Do not set bhaul-configuration or fhaul-configurations on the agent. The controller provides them during onboarding.
Onboarding​
Wired backhaul​
Connect an agent Ethernet port to the controller's LAN. WPS is not required. When the agent is in the same Layer 2 network, the controller discovers it and applies the configuration automatically.
Wireless backhaul​
A wireless backhaul is used when an agent has no Ethernet connection to the controller. The controller provides a backhaul network through its bhaul-configuration. A backhaul AP broadcasts it, and the agent's backhaul station connects to it using the credentials received during onboarding.
Onboard the agent with WPS push-button:
/interface/wifi/easymesh/wps-push-button
Run the command on the controller first, then on the agent. The agent connects to the controller's backhaul network and receives the backhaul and fronthaul configuration.
After onboarding, agent-state will change to wifi-backhaul-connected:
[admin@hAP] > /interface/wifi/easymesh/print
enabled: yes
role: agent
bridge: bridge
bhaul-ssid: em_bh
bhaul-passphrase: backhaul-password
bhaul-authentication-types: wpa2-psk
bhaul-encryption: ccmp
gcmp
dpp-onboarding: no
agent-state: wifi-backhaul-connected
tip
Keep the agent close to the controller during onboarding. Move it to its final location after the backhaul link is established.
Verify the setup​
Run the following commands to see the EasyMesh state:
/interface/wifi/easymesh/topology/print
/interface/wifi/easymesh/bss/print
/interface/wifi/easymesh/sta/print
  • print shows the global EasyMesh settings, the agent state, and the topology tree with the controller, agents, radios, and BSSes.
  • topology/print lists connected agents by their AL MAC addresses.
  • bss/print lists all BSSes with their fronthaul/backhaul role, channel, utilization, and client count.
  • sta/print lists connected clients and backhaul stations.
info
The AL MAC is the IEEE 1905.1 abstraction layer MAC address. EasyMesh uses it as the device identity in control messages and topology, independent of the interface that carries the traffic.
The print output shows the global settings, the agent state, and the topology tree:
[admin@cAP] > /interface/wifi/easymesh/print
enabled: yes
role: controller-and-agent
bridge: bridge
bhaul-configuration: em_bh
fhaul-configurations: em_fh
dpp-onboarding: no
agent-state: wired-backhaul-connected
network: CONTROLLER: AL-MAC: 48:XX:XX:XX:XX:74
ETHERNET: mac: 48:XX:XX:XX:XX:74
AGENT: AL-MAC: D0:XX:XX:XX:XX:D3 via mac: D0:XX:XX:XX:XX:D3
ETHERNET: mac: D0:XX:XX:XX:XX:D3
ETHERNET: mac: D0:XX:XX:XX:XX:D4
ETHERNET: mac: D0:XX:XX:XX:XX:D5
ETHERNET: mac: D0:XX:XX:XX:XX:D6
ETHERNET: mac: D0:XX:XX:XX:XX:D7
RADIO: mac: D0:XX:XX:XX:XX:D9
bVAP[0]: bssid: D0:XX:XX:XX:XX:D9, ssid: em_bh, bw: 160 MHz, ccfi1: 50
fVAP[1]: bssid: D2:XX:XX:XX:XX:DA, ssid: em_fh, bw: 160 MHz, ccfi1: 50
RADIO: mac: D0:XX:XX:XX:XX:D8
bVAP[0]: bssid: D2:XX:XX:XX:XX:D8, ssid: em_bh, bw: 40 MHz, ccfi1: 11
fVAP[1]: bssid: D2:XX:XX:XX:XX:D9, ssid: em_fh, bw: 40 MHz, ccfi1: 11
ETHERNET: mac: 48:XX:XX:XX:XX:75
RADIO: mac: 48:XX:XX:XX:XX:77
bVAP[0]: bssid: 48:XX:XX:XX:XX:77, ssid: em_bh, bw: 40 MHz, ccfi1: 5
fVAP[1]: bssid: 4A:XX:XX:XX:XX:77, ssid: em_fh, bw: 40 MHz, ccfi1: 5
RADIO: mac: 48:XX:XX:XX:XX:76
bVAP[0]: bssid: 48:XX:XX:XX:XX:76, ssid: em_bh, bw: 80 MHz, ccfi1: 58
fVAP[1]: bssid: 4A:XX:XX:XX:XX:76, ssid: em_fh, bw: 80 MHz, ccfi1: 58
The topology table lists connected agents:
[admin@cAP] > /interface/wifi/easymesh/topology/print
Columns: ALMAC
# ALMAC
0 D0:XX:XX:XX:XX:D3
The BSS table lists the fronthaul and backhaul BSSes on the controller and the agent:
[admin@cAP] > /interface/wifi/easymesh/bss/print
Flags: A - ACTIVE
Columns: ALMAC, RADIO-MAC, BSSID, SSID, FRONTHAUL, BACKHAUL, UTILIZATION, BRANCH-UTILIZATION, STA-COUNT, OPCLASS, PRIMARY-CHAN, IEEE-CHAN
# ALMAC RADIO-MAC BSSID SSID FRONTHAUL BACKHAUL UTI BRA S OPCLASS PRI IEEE-CHAN
0 A 48:XX:XX:XX:XX:74 48:XX:XX:XX:XX:76 48:XX:XX:XX:XX:76 em_bh no yes 0% 0% 0 128 136 138
1 A 48:XX:XX:XX:XX:74 48:XX:XX:XX:XX:77 48:XX:XX:XX:XX:77 em_bh no yes 33% 33% 1 84 5 5
2 A 48:XX:XX:XX:XX:74 48:XX:XX:XX:XX:76 4A:XX:XX:XX:XX:76 em_fh yes no 0% 0% 1 128 136 138
3 A 48:XX:XX:XX:XX:74 48:XX:XX:XX:XX:77 4A:XX:XX:XX:XX:77 em_fh yes no 33% 33% 0 84 5 5
4 A D0:XX:XX:XX:XX:D3 D0:XX:XX:XX:XX:D9 D0:XX:XX:XX:XX:D9 em_bh no yes 0% 33% 0 129 64 50
5 A D0:XX:XX:XX:XX:D3 D0:XX:XX:XX:XX:D8 D2:XX:XX:XX:XX:D8 em_bh no yes 0% 33% 0 84 5 5
6 A D0:XX:XX:XX:XX:D3 D0:XX:XX:XX:XX:D8 D2:XX:XX:XX:XX:D9 em_fh yes no 0% 33% 0 84 5 5
7 A D0:XX:XX:XX:XX:D3 D0:XX:XX:XX:XX:D9 D2:XX:XX:XX:XX:DA em_fh yes no 0% 33% 0 129 64 50
The STA table lists connected clients and backhaul stations:
[admin@cAP] > /interface/wifi/easymesh/sta/print
Columns: BSSID, SSID, ALMAC, MAC-ADDRESS, UPTIME, LAST-ACTIVITY, SIGNAL, BACKHAUL
# BSSID SSID ALMAC MAC-ADDRESS UPTIME LAST-ACTIVITY SIGNAL BACKHAUL
0 4A:XX:XX:XX:XX:76 em_fh 48:XX:XX:XX:XX:74 3C:XX:XX:XX:XX:AD 6s 1s510ms -32 no
1 48:XX:XX:XX:XX:77 em_bh 48:XX:XX:XX:XX:74 D0:XX:XX:XX:XX:D8 16s 1s820ms -22 yes
Troubleshooting​
  • If the agent does not appear in topology, check that both devices are in the same Layer 2 network, that the agent's bridge includes the correct ports, and that enabled=yes, role=agent, and configuration.manager=easymesh are set.
  • If the wireless backhaul does not come up, run the WPS push-button command on both devices again. Start with the controller.
  • If clients do not see the network, check that the controller has the correct fhaul-configurations value and that the agent has completed onboarding.
  • A radio can use only one manager. Do not combine EasyMesh and CAPsMAN on the same interface.
Notes​
note
  • Use one controller per EasyMesh network.
  • All controllers and agents must be in the same Layer 2 network.
  • Cross-vendor interoperability requires certified EasyMesh devices. Test the specific controller and agent combination before deployment.
