# PWR Line
> The PWR-Line page describes MikroTik RouterOS devices that enable Ethernet-like connectivity over power lines using the HomePlug AV standard, detailing interface properties like ARP modes and bandwidth limits, along...
# PWR Line
The PWR-Line series devices allow Ethernet-like connectivity between supported devices over regular power lines. When plugged into the same electrical circuit, the PWR-Line devices will establish connectivity by using the HomePlug AV standard.
## Properties
| **arp** (*disabled \| enabled \| proxy-arp \| reply-only*; Default: **enabled**) | Address Resolution Protocol mode:disabled - the interface will not use ARPenabled - the interface will use ARPproxy-arp - the interface will use the ARP proxy featurereply-only - the interface will only reply to requests originating from matching IP address/MAC address combinations which are entered as static entries in the `/ip/arp` table. No dynamic entries will be automatically stored in the ARP table. Therefore, for communications to be successful, a valid static entry must already exist. |
| **bandwidth** (*integer/integer*; Default: **unlimited/unlimited**) | Sets the max rx/tx bandwidth in kbps that will be handled by an interface. TX limit is supported on all Atheros [switch-chip](../bridging-and-switching/switch-chip-features.md) ports. RX limit is supported only on Atheros8327/QCA8337 switch-chip ports. |
| **comment** (*string*; Default: ) | Descriptive name of an item |
| **l2mtu** (*integer [0..65536]*; Default: ) | Layer2 Maximum transmission unit. [MTU in RouterOS](../hardware/mtu-in-routeros.md) |
| **mac-address** (*MAC*; Default: ) | Media Access Control number of an interface. |
| **mtu** (*integer [0..65536]*; Default: **1500**) | Layer3 Maximum transmission unit |
| **name** (*string*; Default: ) | Name of an interface |
| **orig-mac-address** (*MAC*; Default: ) |  |
| **rx-flow-control** (*on \| off \| auto*; Default: **off**) | When set to on, the port will process received pause frames and suspend transmission if required. **auto** is the same as **on** except when auto-negotiation=yes, flow control status is resolved by taking into account what the other end advertises. The feature is supported on AR724x, AR9xxx, and QCA9xxx CPU ports, all CCR ports, and all Atheros switch chip ports. |
| **tx-flow-control** (*on \| off \| auto*; Default: **off**) | When set to on, the port will send pause frames when specific buffer usage thresholds are met. **auto** is the same as **on** except when auto-negotiation=yes, flow control status is resolved by taking into account what the other end advertises. The feature is supported on AR724x, AR9xxx, and QCA9xxx CPU ports, all CCR ports, and all Atheros switch chip ports. |
## Menu specific commands
| Property | Description |
| **configure** () | The command configures the attached PWR-Line device's network-key, network-password, plc-cco-selection-mode. |
| **join** () | Initiates the pairing sequence which will look for other PWR-Line devices in the same electrical circuit that are also in the pairing mode. This mode lasts for 120 seconds. |
| **leave** () | Initiates the leaving sequence which essentially randomizes the device's network-key. |
| **monitor** () | Outputs PWR-Line-related statuses in real-time. |
| **upgrade-firmware** () | Upgrades the PWR-Line device with specified firmware-file and pib-file files. |
## Configuration example
For two or more devices to be able to connect with each other, they must share the same network-key value. The currently configured network-key can be seen using the monitor command as plc-actual-network-key.
```ros
[admin@MikroTik] > /interface/pwr-line/monitor pwr-line1
connection-to-plc: ok
tx-flow-control: no
rx-flow-control: no
plc-actual-network-key: c973947c200e1540b0f84b571d92bebe
plc-hw-platform: QCA7420
plc-sw-platform: MAC
plc-fw-version: 1.4.0(24-20180515-CS)
plc-line-freq: 50Hz
plc-zero-crossing: detected
plc-mac: B8:69:F4:C4:34:68
### Method 1
There are two ways to set the same network-key on different devices. You can either use the network-key parameter which is a hashed version of the network-password parameter, or use the network-password parameter and let the router apply the hash on a human-readable string.
For example:
```ros
/interface/pwr-line/configure pwr-line1 network-password=mynetwork
is the same as:
```ros
/interface/pwr-line/configure pwr-line1 network-key=cb01fcc6167bf3d1edb1433c2ebde4b3
You must set the same key or password on all devices you wish to communicate with each other.
### Method 2
It is possible to use the join and leave commands and make the PWR-Line devices automatically synchronize the network-key value. It is advised to use the leave command before using the join command to make sure a new network-key is randomly generated and the device is not part of any old network.
```ros
/interface/pwr-line/leave pwr-line1
Then we can issue the join command. When doing so, the pairing sequence is enabled for 120 seconds, meaning you have to enable pairing mode on another device within 120 seconds for them to successfully pair.
```ros
/interface/pwr-line/join pwr-line1
### Method 3
It is also possible to set a specified role for the PWR-Line device (master or slave) with the plc-cco-selection-mode parameter.
| **plc-cco-selection-mode** (*auto \| always \| never*; Default: **auto**) | Sets the PWR-Line device mode:auto - PWR-Line will automatically decide what role to take depending on the situation upon joining a PWR-Line network.always - PWR-Line will always be forced to act as a "central-coordinator" or master device.never - PWR-Line will always be forced to act as a slave device. |
Example:
```ros
/interface/pwr-line/configure pwr-line1 plc-cco-selection-mode=auto
```ros
/interface/pwr-line/configure pwr-line1 plc-cco-selection-mode=always
```ros
/interface/pwr-line/configure pwr-line1 plc-cco-selection-mode=never
## Sync Button usage
- Hold 0.5 – 3 seconds to turn on sync mode. For 120 seconds it will try to communicate with another PWR-LINE device. A blinking orange LED light indicates that it is in search mode. You have to also do the same on the other PWR-LINE device, so they can synchronize. Press the button again to cancel the search. You can also manually set the security keys in RouterOS settings.
- Hold 5 – 8 seconds to generate a new security key. This is needed to remove a PWR-LINE device from an existing PWR-LINE network.
- Hold 10 – 15 seconds to reset all PWR-LINE related settings.
## Supported Hardware
The device is fully compatible with our PWR-LINE AP and the newest revisions of products that have a MicroUSB port, such as hAP lite, hAP lite tower, hAP mini, mAP, and mAP lite, have a pwr-line interface. A simple software upgrade to v6.44+ enables this feature (supported by the mentioned devices with serial numbers that end with /9xx). PWR-LINE functionality is also supported by some previously manufactured units - if you have a unit with a serial number that ends with /8xx, upgrade to 6.44+ and see if the pwr-line interface shows up.
