Skip to main content
Version: 7.26
Policy Routing
Policy routing steers traffic that matches criteria to a specific gateway. Use it to force selected customers or protocols, such as HTTP traffic, to always use a particular gateway. It can also route local and overseas traffic through different gateways.
RouterOS provides these components for policy routing:
  • Routing tables.
  • Routing rules.
  • Firewall mangle marking.
Routing Tables​
A router can have multiple routing tables, each with its own routes for the same destination and different gateways.
See and configure tables from the /routing/table menu.
By default, RouterOS has only the main routing table:
[admin@rack1_b33_CCR1036] /routing/table> print
Flags: D - dynamic; X - disabled, I - invalid; U - used
0 D name="main" fib
Define a custom routing table in this menu before using it elsewhere in the configuration.
Consider a basic example with two gateways, 172.16.1.1 and 172.16.2.1, and a route for 8.8.8.8 in the routing table named myTable that uses gateway 172.16.2.1:
/routing/table/add name=myTable fib
/ip/route/add dst-address=8.8.8.8 gateway=172.16.1.1
/ip/route/add dst-address=8.8.8.8 gateway=172.16.2.1@main routing-table=myTable
tip
For a user-created table to be able to resolve the destination, the main routing table should be able to resolve the destination too.
In this example, the main routing table should also include a route to 8.8.8.8 or at least a default route. Because DHCP dynamically adds the default route for safety, add 8.8.8.8 explicitly to the main table.
[admin@rack1_b33_CCR1036] /ip/route> print detail Flags: D - dynamic; X - disabled, I - inactive, A - active;
c - connect, s - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem, y - cop
y;
H - hw-offloaded; + - ecmp
DAd dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=172.16.1.1
immediate-gw=172.16.1.1%ether8 distance=1 scope=30 target-scope=10
vrf-interface=ether8 suppress-hw-offload=no
0 As dst-address=8.8.8.8/32 routing-table=main pref-src="" gateway=172.16.1.1
immediate-gw=172.16.1.1%ether8 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
DAc dst-address=172.16.1.0/24 routing-table=main gateway=ether8 immediate-gw=ether8
distance=0 scope=10 suppress-hw-offload=no local-address=172.16.1.2%ether8
DAc dst-address=172.16.2.0/24 routing-table=main gateway=ether7 immediate-gw=ether7
distance=0 scope=10 suppress-hw-offload=no local-address=172.16.2.2%ether7
1 As dst-address=8.8.8.8/32 routing-table=myTable pref-src="" gateway=172.16.2.1
immediate-gw=172.16.2.1%ether7 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
The configuration above is not enough. You need a way to force traffic to use the new table. RouterOS provides two options:
  • firewall mangle - gives more control over the criteria used to steer traffic, such as per connection or per packet balancing. For examples, see Firewall Marking.
  • routing rules - a basic set of parameters for quickly steering traffic. This example uses routing rules.
Do not use both methods at the same time unless necessary. If mangle and routing rules are used together, mangle by default has higher priority. If mangle-marked traffic can be resolved in the table, routing rules never see that traffic. The order of execution can be changed.
warning
Routing table count is limited to 4096 unique tables.
Routing Rules​
Routing rules steer traffic based on basic parameters such as source address, destination address, in-interface, and others.
In this example, select traffic destined for 8.8.8.8 and prevent fallback to the main table:
/routing/rule/add dst-address=8.8.8.8 action=lookup-only-in-table table=myTable
If a customer is connected to ether4 and only that customer should route 8.8.8.8 to a specific gateway, use this rule:
/routing/rule/add dst-address=8.8.8.8 action=lookup-only-in-table table=myTable interface=ether4
If the gateway used in the table goes down, the lookup fails and the destination becomes unreachable. In active-backup setups, allow traffic to fall back to the main table by changing the action from lookup-only-in-table to lookup.
Routing rules can also act as a basic firewall. For example, to block a customer on ether4 from accessing 192.168.1.0/24:
/routing/rule/add dst-address=192.168.1.0/24 interface=ether4 action=drop
