# Device mode
> Device-mode restricts RouterOS features to protect the router from misuse; changing it requires physical confirmation. Covers the modes, per-feature switches, allowed versions and the flagged state.
# Device mode
The **device-mode** limits access to specific configuration options. It protects the router and the network from attackers who gain unauthorized access and use the device as a gateway to attack other networks.
The available modes are `advanced`, `home`, `basic` and `rose`. New devices come with a mode configured at the factory: `advanced` (previously `enterprise`) on CCR and 1100 series devices, `home` on home routers and `basic` on other devices. Devices from before the factory modes were introduced use `advanced`, and upgrading RouterOS keeps it.
Check the current settings in the [`/system/device-mode`](../cli-reference/system/device-mode) menu.
```ros
[admin@MikroTik] > /system/device-mode/print
                 mode: advanced
     allowed-versions: 7.13+,6.49.8+
              flagged: no
     flagging-enabled: yes
            scheduler: yes
                socks: yes
                fetch: yes
                 pptp: yes
                 l2tp: yes
       bandwidth-test: yes
          traffic-gen: no
              sniffer: yes
                ipsec: yes
                romon: yes
                proxy: yes
              hotspot: yes
                  smb: yes
                email: yes
             zerotier: yes
            container: no
  install-any-version: no
           partitions: no
          routerboard: no
        attempt-count: 0
An authorized user can change the device-mode parameters, but physical access is required to approve the change. Confirm it with the reset or mode button on the device, or with a "cold reboot" — unplug the power. A regular reboot does not confirm the change; it cancels it. After confirmation, regardless of the method, the **device reboots**.
## Check device mode in WinBox
Open **System > Device Mode** to inspect the restrictions:
1. **Mode** and **Allowed Versions** identify the configured mode and permitted RouterOS versions.
2. The per-tool fields show which operations are allowed. For example, check **Scheduler**, **Fetch**, or **Email** when one of those tools reports a device-mode restriction.
![WinBox Device Mode overview with the current mode and per-tool restrictions](./img/device-mode-winbox.webp)
The screenshot shows a router with an existing `rose` configuration; it is not a factory default. The overview is read-only. The **Update** action starts a mode change, which requires physical confirmation and reboots the device (see the next section).
## Change device-mode
Change the mode or individual features with the [`update`](../cli-reference/system/device-mode/update) command.
Change the mode to `home`:
```ros
[admin@MikroTik] > /system/device-mode/update mode=home
  update: turn off power or reboot by pressing reset or mode button in 5m to activate changes
If the update is not confirmed in time, the mode change is canceled. To cancel a pending update yourself, run `/system/device-mode/update` without parameters; it reports `canceled previous update`. An `update` with parameters while another update is pending cancels the pending one and is not applied itself; run it again to start a new update.
:::note
Some EOL products confirm mode changes only with a power cycle, not with a button press.
An attacker with access can prepare a device-mode change and leave it pending. The change activates on the next button press or power cycle, even when the administrator does not know what it is. To limit that risk, only three update attempts are allowed without a reset. Every `update` request with parameters increments the **attempt-count** counter, including refused ones; a request that cancels a pending update does not. When the counter reaches 3, further requests are refused and a reset window equal to the `activation-timeout` of that request opens. The counter resets after a confirmed update, or after a button press or power cycle inside the reset window. An expired request and a plain reboot do not reset it.
```ros
[admin@MikroTik] > /system/device-mode/update container=yes
  update: too many unsuccessful attempts, turn off power or reboot by pressing reset or mode button in 5m to reset attempt-count
A command that specifies `mode` replaces the entire device-mode configuration: all per-feature settings are lost except those given in the same command. The `print config` output shows only the settings that differ from the mode defaults.
```ros
[admin@MikroTik] > /system/device-mode/update mode=home email=yes fetch=yes
-- reboot --
[admin@MikroTik] > /system/device-mode/print config
              mode: home
             fetch: yes
             email: yes
[admin@MikroTik] > /system/device-mode/update mode=advanced sniffer=no
-- reboot --
              mode: advanced
           sniffer: no
The `fetch` and `email` overrides are gone, because the second mode change replaced them. A command that specifies only per-feature settings changes only those:
```ros
[admin@MikroTik] > /system/device-mode/update hotspot=no
-- reboot --
              mode: advanced
           sniffer: no
           hotspot: no
A disabled feature rejects interactive commands:
```ros
              mode: advanced
           sniffer: no
           hotspot: no
[admin@MikroTik] > /tool/sniffer/quick
failure: not allowed by device-mode
Configuration for a disabled feature can still be added; the entry is created disabled, with a comment that the device-mode does not allow it:
```ros
[admin@MikroTik] > /ip/hotspot/add interface=ether1
[admin@MikroTik] > /ip/hotspot/print
Flags: X - DISABLED
Columns: NAME, INTERFACE, PROFILE, IDLE-TIMEOUT
#   NAME      INTERFACE  PROFILE  IDLE-TIMEOUT
;;; inactivated, not allowed by device-mode
0 X hotspot1  ether1     default  5m
## Configure device-mode with Netinstall or FlashFig
Netinstall and FlashFig can set **device-mode**, **protected-routerboot** and other settings when they provision a device.
See the [Netinstall](../getting-started/installation-and-upgrade/netinstall/) and [FlashFig](../management-tools/flashfig) documentation for details.
## Available device-mode modes
Four modes are available (`advanced` is the default); each disables a subset of features. No mode has all features enabled — some features must be enabled explicitly even in `advanced` mode. `rose` is similar to `advanced`, intended for RDS and similar devices with broad disk use and factory container support. The table lists what each feature controls. **traffic-gen**, **container**, **partitions** and **routerboard** are disabled in every mode unless enabled explicitly.
| Feature / Property | Actions/unavailable menus | Home | Basic | Advanced | ROSE |
| [**Bandwidth Test**](../diagnostics-monitoring-and-troubleshooting/bandwidth-test.md) | `/tool/bandwidth-test`, `/tool/bandwidth-server`, `/tool/speed-test` | No | No | Yes | Yes |
| [**Containers**](../containers/index.md) | All container functionality. | No | No | No | Yes |
| [**Email**](./e-mail.md) | `/tool/e-mail` | No | Yes | Yes | Yes |
| [**Fetch**](./fetch.md) | `/tool/fetch` | No | Yes | Yes | Yes |
| [**Hotspot**](../authentication-authorization-accounting/hotspot-captive-portal/index.md) | `/ip/hotspot` | No | No | Yes | Yes |
| **Install Any Version** | RouterOS will no longer allow installation of versions outside the **allowed-versions** list. | No | No | No | No |
| [**IPsec**](../virtual-private-networks/ipsec/index.md) | `/ip/ipsec` | Yes | Yes | Yes | Yes |
| [**L2TP**](../virtual-private-networks/l2tp/index.md) | `/interface/l2tp-server`, `/interface/l2tp-client` | Yes | Yes | Yes | Yes |
| [**Partitions**](./partitions.md) | `/partitions` — does not allow changing the count of partitions. If your router is unable to boot, it will still be able to boot into your other partitions. No restriction for crash recovery. | No | No | No | No |
| [**PPTP**](../virtual-private-networks/pptp.md) | `/interface/pptp-server`, `/interface/pptp-client` | Yes | Yes | Yes | Yes |
| [**Proxy**](../network-management/proxy/web-proxy) | `/ip/proxy` | No | No | Yes | Yes |
| [**RoMon**](../management-tools/romon.md) | `/tool/romon` | No | Yes | Yes | Yes |
| [**Routerboard Settings**](../hardware/routerboard.md) | `/system/routerboard/settings` (except auto-upgrade option) | No | No | No | No |
| [**Scheduler**](./scheduler.md) | `/system/scheduler` | No | Yes | Yes | Yes |
| [**SMB**](../storage/smb.md) | `/ip/smb` | Yes | Yes | Yes | Yes |
| [**Sniffer**](../diagnostics-monitoring-and-troubleshooting/packet-sniffer.md) | `/tool/sniffer` | No | Yes | Yes | Yes |
| [**SOCKS Proxy**](../network-management/socks/index.md) | `/ip/socks` | No | No | Yes | Yes |
| [**Traffic Generator**](../diagnostics-monitoring-and-troubleshooting/traffic-generator.md) | `/tool/traffic-generator`, `/tool/flood-ping`, `/tool/ping-speed` | No | No | No | No |
| [**ZeroTier**](../virtual-private-networks/zerotier.md) | `/zerotier` | No | No | Yes | Yes |
Each feature controlled by device-mode can be enabled or disabled individually.
For example, with **scheduler** disabled, `/system/scheduler` cannot perform any action. If the device runs in `home` mode but your setup needs `zerotier`, run `/system/device-mode/update zerotier=yes` and confirm it with physical access to the device. On dual-boot devices, device-mode restricts the SwOS/RouterOS transition; enable it with `/system/device-mode/update routerboard=yes`.
## Allowed versions
The **allowed-versions** parameter lists the RouterOS versions MikroTik considers secure, without serious vulnerabilities that an attacker could exploit.
The list works as a separate protection layer, independent of the installed version, to prevent an attacker from downgrading step by step to a known vulnerable release. An upgrade to a release with a newer **allowed-versions** list overwrites the old one; a downgrade leaves the list unchanged. The list is ignored when **install-any-version** is enabled.
## Flagged status
RouterOS analyzes the whole configuration at startup for signs of unauthorized access. If it finds suspicious configuration, the device disables it and sets **flagged** to *yes*, which enforces additional limitations.
```ros
     mode: advanced
  flagged: yes
In the flagged state, the current configuration keeps working, but these actions are not possible:
- bandwidth-test, traffic-generator and sniffer
- configuration actions that enable or create entries (disabling or deleting them still works) in system scheduler, SOCKS proxy, PPTP, L2TP, IPsec, proxy and SMB.
Attempting them returns an error:
```ros
failure: configuration flagged, check all router configuration for unauthorized changes and update device-mode
[admin@MikroTik] > /interface/l2tp-client/add connect-to=192.0.2.1 user=user1
To exit the flagged state, run `/system/device-mode/update flagged=no` and confirm it with a button press or a power cycle: cut the power, or do a hard reboot of the virtual machine.
:::danger
Although the system has disabled any malicious-looking rules that triggered the flagged state, inspect
all of your configuration for other unknown entries before exiting the flagged state. If your system
has been flagged, assume that it has been compromised and audit all settings before re-enabling it for
use. After the audit, change all system passwords and upgrade to the latest RouterOS version.
