Skip to main content
Version: 7.26
GPS-tracking using HTTP POST
The following article explains how to create a simple vehicle tracking system using the RouterOS GPS function and scripting.
Method​
This approach uses HTTP POST capability of the RouterOS Fetch tool. It allows you to POST any kind of data to a webserver, right from the RouterOS command line. Of course, you can use scripting to fill the POST data with variables. The posted data will be written to an SQLITE3 database (file is created, if it doesn't exist) and then read from the database and fed into a Leaflet.js Polyline array. This is a proof of concept example; there is no authentication, security, or error handling.
Requirements​
  • Web server of your choice.
  • PHP.
  • SQLite3 module for PHP.
  • RouterOS device with a working GPS module.
  • RouterOS.
  • Set GPS format in RouterOS to dd.
RouterOS script​
You can run this script in the Scheduler tool, with an interval of 1s, to have your coordinates sent every 1 second.
:global lat
:global lon
/system/gps/monitor once do={
:set $lat $("latitude")
:set $lon $("longitude")
/tool/fetch mode=http url="https://YOURSERVER.com/index.php" port=80 http-method=post http-data=("{\"lat\":\"" . $lat . "\",\"lon\":\"" . $lon . "\"}") http-header-field="Content-Type: application/json"
:put ("{\"lat\":\"" . $lat . "\",\"lon\":\"" . $lon . "\"}")
index.php file​
Create an empty directory called sqlite_db next to the index.php file. Make sure that the directory and files are writable by the group with chmod -R a+w sqlite_db/
<?php
$loc = dirname(__FILE__).'/sqlite_db/coord.db';
$db = new SQLite3($loc,SQLITE3_OPEN_READWRITE | SQLITE3_OPEN_CREATE);
$raw = file_get_contents('php://input');
$raw = preg_replace('/\\x00/','',$raw);
$data = json_decode($raw);
if (!empty($data) && is_object($data) && property_exists($data,'lat') && property_exists($data,'lon')){
if(file_exists($loc)) echo 'exists!'.chr(0xa);
$src = 'SELECT name FROM sqlite_master WHERE type=\'table\' AND name=\'coordinates\'';
$res = $db->querySingle($src);
if ($res === false){
$db->exec('CREATE TABLE coordinates (latitude TEXT, longitude TEXT, time TIMESTAMP DEFAULT CURRENT_TIMESTAMP, added TIMESTAMP DEFAULT CURRENT_TIMESTAMP ) ');
$regex = '/^(|\-)([0-9]{2,3}\.[0-9]{0,8})$/';
if (preg_match($regex,$data->lat) && preg_match($regex,$data->lon) )
$lat = $data->lat;
$lon = $data->lon;
$ins = 'INSERT INTO coordinates (latitude,longitude) VALUES (\''.SQLite3::escapeString($lat).'\',\''.SQLite3::escapeString($lon).'\')';
$db->exec($ins);
die();
<!DOCTYPE html>
<html>
<head>
<link rel="stylesheet" href="https://unpkg.com/leaflet@1.3.1/dist/leaflet.css" integrity="sha512-Rksm5RenBEKSKFjgI3a41vrjkw4EVPlJ3+OiI65vTjIdo9brlAacEuKOiQ5OFh7cOI1bkDwLqdLw3Zg0cRJAAQ==" crossorigin=""/>
<script src="https://unpkg.com/leaflet@1.3.1/dist/leaflet.js" integrity="sha512-/Nsx9X4HebavoBvEBuyp3I7od5tA0UzAxs+j83KgC8PU0kgB4XiK4Lfe4y4cgBtaRJQEIFCW+oC506aPT2L1zw==" crossorigin=""></script>
</head>
<body>
<div id="map" style={{width: '800px', height: '600px'}}></div>
<script>
var map = L.map('map').setView([0,0], 4);
L.tileLayer('http://{s}.tile.osm.org/{z}/{x}/{y}.png', {attribution: '<a href="https://osm.org/copyright">OSM</a>'}).addTo(map);
<?php
if($result = $db->query('SELECT latitude,longitude FROM coordinates')){
echo ' var latlngs = [ ';
while($obj = $result->fetchArray()){
if (!is_array($obj) || !isset($obj['latitude']) || !isset($obj['longitude']) || empty($obj['latitude']) || empty($obj['longitude'])) continue;
echo '["'. $obj['latitude'].'","'.$obj['longitude'].'"],';
echo ']; ';
} else
echo('//'.$db->lastErrorMsg().chr(0xa));
var polyline = L.polyline(latlngs, {color: 'red'}).addTo(map);
map.fitBounds(polyline.getBounds());
</script>
</body>
</html>
Result​
