# MikroTik mobile app
> The MikroTik mobile app provides both basic and advanced configuration options for MikroTik routers on Android and iOS, offering a user-friendly setup interface with QR code download links and quick configuration steps.
## Summary
The application is available for both Android and iOS operating systems. It is a good way to configure a new device, as it provides a simple and user-friendly setup screen for the most basic settings of your new router. It also features an advanced menu, for the more experienced user.
## Downloading app
MikroTik application is available to download on the App Store and Google Play, please see our web [page Software section](https://mikrotik.com/mobile_app) for direct download links or scan the QR code.
| ![](./img/mikrotik-mobile-app-01.webp) |
Use the MikroTik smartphone app to configure your router in the field, or to apply the most basic initial settings for your MikroTik home access point.
## Quick start with the application
- Scan QR code and choose your preferred OS.
- Install and connect to your wireless network.
- Open the application. By default, the IP address and username will be already entered.
- Click Connect to establish a connection.
- Choose Quick setup, and the application will guide you through all basic configuration settings in a couple of easy steps.
