Skip to main content
Version: 7.26
PCQ example
Per Connection Queue (PCQ) is a queuing discipline that can be used to dynamically equalize or shape traffic for multiple users, using little administration. It is possible to divide PCQ scenarios into three major groups: equal bandwidth for a number of users, certain bandwidth equal distribution between users, and unknown bandwidth equal distribution between users.
Equal Bandwidth for a Number of Users​
PCQ type can be used through the Queue Tree and Simple Queues to equalize the bandwidth [and set max limit] for a number of users. We will set the 64kbps download and 32kbps upload limits.
Step 1: add PCQ in Queue Types​
Add two new entries - one for download and one for upload. dst-address is a classifier for the user's download traffic, and src-address for upload traffic:
/queue/type/add name="PCQ_download" kind=pcq pcq-rate=64000 pcq-classifier=dst-address
/queue/type/add name="PCQ_upload" kind=pcq pcq-rate=32000 pcq-classifier=src-address
Step 2: deploy the PCQ​
Queue Tree option​
Mark all packets with packet-marks upload/download: (let's consider that ether1-WAN is the public interface to the Internet and ether2-LAN is a local interface where clients are connected):
/ip/firewall/mangle/add chain=prerouting action=mark-packet \
in-interface=ether2-LAN new-packet-mark=client_upload
in-interface=ether1-WAN new-packet-mark=client_download
Then, two queue rules are required, one for download and one for upload:
/queue/tree/add parent=global queue=PCQ_download packet-mark=client_download
/queue/tree/add parent=global queue=PCQ_upload packet-mark=client_upload
Simple Queues option​
Alternatively you can do it with one command like so:
/queue/simple/add target=192.168.0.0/24 queue=PCQ_upload/PCQ_download
