# Kid Control
> Kid Control is a RouterOS feature allowing parental control over LAN devices by setting daily internet access schedules, bandwidth limits, and device-specific restrictions through profiles and firewall rules.
# Kid Control
**Sub-menu:** `/ip/kid-control`
"Kid control" is a parental control feature to limit internet connectivity for LAN devices.
## Property Description
In this menu, it is possible to create a profile for each kid and restrict internet accessibility.
| Property | Description |
| **name** (*string*) | Name of the Kid's profile |
| **mon,tue,wed,thu,fri,sat,sun** (*time*) | Each day of the week. Time of day when internet access should be allowed |
| **disabled** (*yes \| no*) | Whether the profile is disabled |
| **rate-limit** (*string*) | The maximum available data rate for flow |
| **tur-mon,tur-tue,tur-wed,tur-thu,tur-fri,tur-sat,tur-sun** (*time*) | Time unlimited rate. Time of day when internet access should be unlimited |
Time-unlimited rate parameters have higher priority than rate-limit parameter.
## Devices
**Sub-menu:** `/ip/kid-control/device`
This sub-menu contains information about whether there are multiple devices connected to the internet (phone, tablet, gaming console, tv etc.). The device is identified by the MAC address that is retrieved from the ARP table. The appropriate IP address is taken from there.
| **name** (*string*) | Name of the device |
| **mac-address** (*string*) | Device's mac-address |
| **user** (*string*) | Profile to append the device to |
| **reset-counters** (*[id, name]*) | Reset bytes-up and bytes-down counters. |
## Application example
With the following example we will restrict access for Peter's mobile phone:
- Disables internet access on Monday, Wednesday and Friday
- Allows unlimited internet access on:
  - Tuesday
  - Thursday from 11:00-22:00
  - Sunday 15:00-21:00
- Limits bandwidth to 3Mbps for Peter's mobile phone on Saturday from 18:30-22:00
```ros
[admin@MikroTik] > /ip/kid-control/add name=Peter mon="" tur-tue="00:00-24h" wed="" tur-thu="11:00-22:00" fri="" sat="18:30-22:00" tur-sun="15h-21h" rate-limit=3M
[admin@MikroTik] > /ip/kid-control/device/add name=Mobile-phone user=Peter mac-address=FF:FF:FF:ED:83:63
Internet access limitation is implemented by adding dynamic firewall filter rules or simple queue rules. Here are example firewall filter rules:
```ros
[admin@MikroTik] > /ip/firewall/filter/print
1  D ;;; Mobile-phone, kid-control
      chain=forward action=reject src-address=192.168.88.254
2  D ;;; Mobile-phone, kid-control
      chain=forward action=reject dst-address=192.168.88.254
Dynamically created simple queue:
```ros
[admin@MikroTik] > /queue/simple/print
      name="queue1" target=192.168.88.254/32 parent=none packet-marks="" priority=8/8 queue=default-small/default-small limit-at=3M/3M max-limit=3M/3M burst-limit=0/0
      burst-threshold=0/0 burst-time=0s/0s bucket-size=0.1/0.1
It is possible to monitor how much data is used by the specific device:
```ros
[admin@MikroTik] > /ip/kid-control/device/print stats
Flags: X - disabled, D - dynamic, B - blocked, L - limited, I - inactive
 #    NAME        IDLE-TIME    RATE-DOWN   RATE-UP   BYTES-DOWN     BYTES-UP
 1 BI Mobile-phone        30s         0bps      0bps    3438.1KiB       8.9KiB
It is also possible to **pause** Internet access for the created kids; it will restrict all access until **resume** is used, which will continue with configured settings:
```ros
[admin@MikroTik] > /ip/kid-control/pause Peter
[admin@MikroTik] > /ip/kid-control/print
Flags: X - disabled, P - paused, B - blocked, L - rate-limited
 #   NAME        SUN      MON      TUE      WED      THU      FRI      SAT
 0 PB Peter        15h-21h                             11h-22h          18:30h-22h
