# Traffic Generator
> Traffic Generator is a MikroTik RouterOS tool for evaluating device performance by generating and sending raw packets over ports, collecting latency, jitter, throughput, and packet loss data. It supports advanced...
# Traffic Generator
Traffic Generator is a tool that allows evaluating the performance of a DUT (Device Under Test) or SUT (System Under Test).
The tool can generate and send raw packets over specific ports. It also collects latency and jitter values, TX/RX rates, counts lost packets, and detects Out-of-Order (OOO) packets.
Traffic Generator can be used similarly to the [bandwidth test](./bandwidth-test.md) tool, as well as to generate packets that will be routed back to the packet generator for advanced status collection.
All properties and commands of the traffic generator are described in the [`/tool/traffic-generator` CLI reference](../cli-reference/tool/traffic-generator/).
:::info
On a device that generates packets, packets generated by the traffic generator cannot be captured with a sniffer tool, torch, or firewall on the outgoing interface.
Because this tool can be used maliciously, it is disabled by default in every [device mode](../system-information-and-utilities/device-mode). While `traffic-gen` is disabled, `quick` fails with a `not allowed by device-mode` error. Run `/system/device-mode/print` to check the current value. To enable it, run `/system/device-mode/update traffic-gen=yes` and confirm the change within the activation timeout (5 minutes by default) with physical access to the device: press the reset or mode button, or unplug the power. The device reboots after the confirmation; a regular reboot cancels the change. See [Change device-mode](../system-information-and-utilities/device-mode#change-device-mode).
## General
**Sub-menu:** `/tool/traffic-generator`
This menu holds the overall traffic generator settings: the `test-id` of the current measurement session, whether Out-of-Order (OOO) packets are measured (`measure-out-of-order`), the maximum latency range of the latency distribution (`latency-distribution-max`) and how many statistics samples are kept (`stats-samples-to-keep`). It also shows whether the generator is running (`running`) and the current latency measurement range (`latency-distribution-measure-interval`, `latency-distribution-samples`).
### Commands
| Command | Description |
| **quick** | Starts the packet generator, prints the statistics to the terminal and assembles the latency/jitter report. Accepts parameters that override the packet template and stream settings: **cpu-core, entries-to-show, id, interface, mbps, measure-out-of-order, packet-count, packet-size, port, pps, stream, test-id, tx-template**. Parameters specified when running the quick command override configured values; if a parameter is specified only for one header, the value is multiplied for all the other headers (if required). |
| **start** | Starts the traffic generator in the background. Accepts the same override parameters as **quick**, except `entries-to-show` (there is no terminal output). |
| **stop** | Stops the background traffic generator started with the **start** command. |
| **inject** | Injects raw data into an interface. |
| **inject-pcap** | Replays packets from a PCAP or PCAPNG file on an interface. The [sniffer tool](./packet-sniffer.md) saves captures in PCAPNG format, which the traffic generator supports. |
## Packet Template
**Sub-menu:** `/tool/traffic-generator/packet-template`
This sub-menu builds the packet content of a stream from header parameters. Based on the parameters you can build IP packets with VLAN tags, set UDP or TCP ports, or build IPv6 packets. A raw packet template is generated from the provided parameters. The full parameter list is described in the [packet-template CLI reference](../cli-reference/tool/traffic-generator/packet-template).
If you need more low-level packets or want to take full advantage of the traffic generator, use a raw-packet-template builder to build the packet.
If the same type of header is present in the packet more than once, header field values are passed as a comma-separated list. For example, if there are two IP headers, source addresses are given like `ip-src=1.1.1.1,2.2.2.2`.
For quicker header construction, many header field values are assumed. For example, if the header stack is "mac, ip", the traffic generator assumes that the mac-protocol value is "ip". Or if the "port" or "interface" setting is specified, the traffic generator assumes "mac-src" to be the MAC address of the interface. Assumed values have distinct names that start with "assumed-" and are read-only. Manually specified values override assumed ones.
:::info
Assumed values are not automatically updated. New values are assumed after a template edit — `/tool/traffic-generator/packet-template/set [find]` is enough to trigger new assumed values.
The `header-stack` property defines the sequence of headers in the generated packet. It supports **mac** (Ethernet, 14 bytes), **vlan** (802.1Q tag, 4 bytes), **ip** (IPv4, 20 bytes), **udp** (UDP, 8 bytes), **raw** (arbitrary bytes as a hex string), **ipv6** (IPv6, 40 bytes) and **tcp** (TCP, variable length). Sequence limitations follow protocol rules — for example, a VLAN header can follow only a mac header or another VLAN header; at most two IP headers and one UDP header are allowed per packet. Further limitations (for example, on repeated IPv6 or TCP headers) are validated when the template is created. The traffic generator suggests the first header for a packet template (in the port menu), but the first header is not enforced.
## Port Configuration
**Sub-menu:** `/tool/traffic-generator/port`
This menu configures ports that bind an interface to the traffic generator for transmitting and receiving generated packets. A port entry is created automatically (dynamic) when a packet template specifies only an `interface`. The `disabled` flag (see the CLI reference) stops the port from transmitting and receiving; the examples set it to `disabled=no` to be explicit. The read-only `first-header` property of a port shows the suggested first header for packets sent out of that interface: `mac`, `vlan`, `ip`, `udp`, `raw`, `ipv6` or `tcp`. All properties and flags are described in the [port CLI reference](../cli-reference/tool/traffic-generator/port).
## Stats
**Sub-menu:** `/tool/traffic-generator/stats`
If the traffic generator is not running in **quick** mode, all statistics about the test are stored in this menu without being printed to the terminal.
### Latency Distribution
**Sub-menu:** `/tool/traffic-generator/stats/latency-distribution`
This sub-menu shows how many packets were received in a specific latency range. The latency range can be viewed by streams or by sequences, for example `print stream-id=3` or `print seq=10`.
Here is an example output of the latency graph:
```ros
[admin@test-host] /tool/traffic-generator/stats/latency-distribution> print
 # LATENCY                 COUNT        SHARE GRAPH
 0 0-15.5us                    0           0%
 1 15.5us-31us                 0           0%
 2 31us-46.5us                 0           0%
 3 46.5us-62.1us               0           0%
 4 62.1us-77.6us               0           0%
 5 77.6us-93.1us               0           0%
 6 93.1us-109us                0           0%
 7 109us-124us                 0           0%
 8 124us-140us                 0           0%
 9 140us-155us                 0           0%
10 155us-171us                 0           0%
11 171us-186us                 4           0% *
12 186us-202us                29           0% *
13 202us-217us                90       0.001% *
14 217us-233us               302       0.004% *
15 233us-248us               630       0.009% *
16 248us-264us               789       0.011% *
17 264us-279us             1 384       0.021% -*
18 279us-295us             1 990        0.03% --*
19 295us-310us             2 966       0.045% ---*
20 310us-326us             4 089       0.062% -----*
21 326us-341us             4 958       0.075% ------*
22 341us-357us             6 059       0.091% -------*
23 357us-372us             6 660       0.101% --------*
24 372us-388us             8 320       0.126% ----------*
25 388us-403us             9 988       0.151% -------------*
26 403us-419us            11 781       0.178% ---------------*
27 419us-434us            12 512       0.189% ----------------*
28 434us-450us            13 836        0.21% -----------------*
29 450us-465us            15 681       0.238% --------------------*
30 465us-481us            17 740       0.269% ----------------------*
31 481us-496us            19 913       0.302% --------------------------*
32 496us-512us            21 106        0.32% ---------------------------*
33 512us-528us            22 848       0.346% -----------------------------*
34 528us-543us            25 059        0.38% --------------------------------*
35 543us-559us            26 593       0.403% ----------------------------------*
36 559us-574us            27 663       0.419% -----------------------------------*
37 574us-590us            29 351       0.445% -------------------------------------*
38 590us-605us            31 265       0.474% ----------------------------------------*
39 605us-621us            33 224       0.504% -------------------------------------------*
40 621us-636us            34 464       0.523% --------------------------------------------*
41 636us-652us            35 630        0.54% ----------------------------------------------*
42 652us-667us            37 245       0.565% ------------------------------------------------*
43 667us-683us            38 158       0.579% -------------------------------------------------*
44 683us-698us            38 626       0.586% --------------------------------------------------*
45 698us-714us            38 985       0.591% --------------------------------------------------*
46 714us-729us            39 061       0.592% --------------------------------------------------*
47 729us-745us            39 750       0.603% ---------------------------------------------------*
48 745us-760us            39 145       0.594% --------------------------------------------------*
49 760us-776us            39 162       0.594% --------------------------------------------------*
50 776us-791us            38 197       0.579% -------------------------------------------------*
51 791us-807us            37 811       0.573% -------------------------------------------------*
52 807us-822us            37 364       0.567% ------------------------------------------------*
53 822us-838us            36 770       0.558% -----------------------------------------------*
54 838us-853us            35 831       0.543% ----------------------------------------------*
55 853us-869us            35 380       0.536% ----------------------------------------------*
56 869us-884us            34 472       0.523% --------------------------------------------*
57 884us-900us            33 672       0.511% -------------------------------------------*
58 900us-915us            33 799       0.513% --------------------------------------------*
59 915us-931us            32 754       0.497% ------------------------------------------*
60 931us-946us            32 339        0.49% ------------------------------------------*
61 946us-962us            32 419       0.492% ------------------------------------------*
62 962us-977us            32 107       0.487% -----------------------------------------*
63 977us-993us            31 552       0.478% -----------------------------------------*
64 0-993us             1 221 523       18.54%
The columns are described in the [latency-distribution CLI reference](../cli-reference/tool/traffic-generator/stats/latency-distribution).
### Stream Stats
**Sub-menu:** `/tool/traffic-generator/stats/stream`
This sub-menu stores statistics sorted by streams. The output is the same as in **quick** mode.
```ros
[admin@test-host] /tool/traffic-generator/stats/stream> print
 # SEQ    ID      TX-PACKET   TX-RATE     RX-PACKET   RX-RATE   LOST-PACKET LOST-RATE
 0 1      3          43 064 499.5Mbps        25 180 292.0Mbps        17 884 207.4Mbps
 1 1      4          43 062 499.5Mbps        39 946 463.3Mbps         3 116  36.1Mbps
 2 1      TOT        86 126 999.0Mbps        65 126 755.4Mbps        21 000 243.6Mbps
 3 2      3          43 544 505.1Mbps        30 449 353.2Mbps        13 095 151.9Mbps
 4 2      4          43 543 505.0Mbps        42 982 498.5Mbps           561   6.5Mbps
 5 2      TOT        87 087 1010.2...        73 431 851.7Mbps        13 656 158.4Mbps
59 20     TOT        87 277 1012.4...        73 755 855.5Mbps        13 522 156.8Mbps
60 21     3          43 546 505.1Mbps        30 605 355.0Mbps        12 941 150.1Mbps
61 21     4          43 546 505.1Mbps        42 682 495.1Mbps           864  10.0Mbps
62 21     TOT        87 092 1010.2...        73 287 850.1Mbps        13 805 160.1Mbps
63 TOT    3         913 942 504.8Mbps       629 210 347.5Mbps       284 732 157.2Mbps
64 TOT    4         913 939 504.8Mbps       898 374 496.2Mbps        15 565   8.5Mbps
65 TOT    TOT     1 827 881 1009.6...     1 527 584 843.8Mbps       300 297 165.8Mbps
### Port Stats
**Sub-menu:** `/tool/traffic-generator/stats/port`
This sub-menu stores statistics sorted by rx/tx ports.
```ros
[admin@test-host] /tool/traffic-generator/stats/port> print
 # SEQ    PORT        RX-UNK-PACKET    RX-UNK-BYTE RX-UNK...     TX-PACKET   TX-RATE     RX-PACKET
 0 1      port0:et...             0              0      0bps        43 064 499.5Mbps        39 946
 1 1      port1:et...             0              0      0bps        43 062 499.5Mbps        25 180
 2 1      TOT                     0              0      0bps        86 126 999.0Mbps        65 126
 3 2      port0:et...             0              0      0bps        43 544 505.1Mbps        42 982
 4 2      port1:et...             0              0      0bps        43 543 505.0Mbps        30 449
 5 2      TOT                     0              0      0bps        87 087 1010.2...        73 431
 6 3      port0:et...             0              0      0bps        43 540 505.0Mbps        42 615
 7 3      port1:et...             0              0      0bps        43 540 505.0Mbps        30 191
 8 3      TOT                     0              0      0bps        87 080 1010.1...        72 806
### Raw Stats
**Sub-menu:** `/tool/traffic-generator/stats/raw`
This sub-menu stores raw statistics data.
```ros
[admin@test-host] /tool/traffic-generator/stats/raw> print
 # SEQ    PORT       ID      TX-PACKET   TX-RATE     RX-PACKET   RX-RATE   LOST-PACKET LOST-RATE
 0 1      port0:e... 3          43 064 499.5Mbps             0      0bps        43 064 499.5Mbps
 1 1      port1:e... 3               0      0bps        25 180 292.0Mbps       -25 180 292.0Mbps
 2 1      TOT        3          43 064 499.5Mbps        25 180 292.0Mbps        17 884 207.4Mbps
 3 1      port0:e... 4               0      0bps        39 946 463.3Mbps       -39 946 463.3Mbps
 4 1      port1:e... 4          43 062 499.5Mbps             0      0bps        43 062 499.5Mbps
 5 1      TOT        4          43 062 499.5Mbps        39 946 463.3Mbps         3 116  36.1Mbps
 6 1      port0:e... TOT        43 064 499.5Mbps        39 946 463.3Mbps         3 118  36.1Mbps
 7 1      port1:e... TOT        43 062 499.5Mbps        25 180 292.0Mbps        17 882 207.4Mbps
 8 2      port0:e... 3          43 544 505.1Mbps             0      0bps        43 544 505.1Mbps
 9 2      port1:e... 3               0      0bps        30 449 353.2Mbps       -30 449 353.2Mbps
10 2      TOT        3          43 544 505.1Mbps        30 449 353.2Mbps        13 095 151.9Mbps
All statistics columns (seq, id, tx/rx counters and rates, out-of-order, bad-checksum, lost, latency and jitter) are described in the [stream](../cli-reference/tool/traffic-generator/stats/stream), [port](../cli-reference/tool/traffic-generator/stats/port) and [raw](../cli-reference/tool/traffic-generator/stats/raw) CLI reference pages.
## Streams
**Sub-menu:** `/tool/traffic-generator/stream`
A stream defines the generated traffic: the packet template used (`tx-template`, mandatory) and the port it is transmitted through (`port`, usually taken from the template), the transmission rate (`pps` and/or `mbps`), the L2 packet size (`packet-size`, can be a range for random sizes), how many packets to transmit (`packet-count`) and the CPU core (or core range) the stream is pinned to (`cpu-core`, for multi-core tests). Its read-only `default-port` shows the port the stream transmits on, derived from the template. All properties are described in the [stream CLI reference](../cli-reference/tool/traffic-generator/stream).
Each stream has a unique `id` (the old property name `num` is no longer used) that identifies its packets in the statistics and in the **start** and **quick** commands.
## Configuration Examples
### IPsec tunnel performance test
Consider the following test setup:
![Traffic generator IPsec test setup](./img/traffic-generator-01.webp)
System Under Test (SUT) consists of two routers connected to a traffic generator server. The connection between both SUT routers is IPSec encrypted.
The traffic generator will run two streams:
- In a direction from 1.1.1.0/24 network to 2.2.2.0/24 network.
- In a direction from 2.2.2.0/24 network to 1.1.1.0/24 network.
#### R1 routing and IPsec setup
```ros
/ip/address
add address=192.168.33.1/30 interface=ether1
add address=1.1.1.2/24 interface=ether2
/ip/route
add dst-address=2.2.2.0/24 gateway=192.168.33.2
/ip/ipsec/proposal
set default enc-algorithms=aes-128-cbc
/ip/ipsec/peer
add address=192.168.33.2 secret=123
/ip/ipsec/policy
add sa-src-address=192.168.33.1 sa-dst-address=192.168.33.2 \
    src-address=1.1.1.0/24 dst-address=2.2.2.0/24 tunnel=yes
#### R2 routing and IPsec setup
```ros
/ip/address
add address=192.168.33.2/30 interface=ether1
add address=2.2.2.2/24 interface=ether2
/ip/route
add dst-address=1.1.1.0/24 gateway=192.168.33.1
/ip/ipsec/proposal
/ip/ipsec/peer
add address=192.168.33.1 secret=123
/ip/ipsec/policy
add sa-src-address=192.168.33.2 sa-dst-address=192.168.33.1 \
    src-address=2.2.2.0/24 dst-address=1.1.1.0/24 tunnel=yes
#### Traffic generator server setup
```ros
/ip/address
add address=1.1.1.1/24 interface=ether2
add address=2.2.2.1/24 interface=ether3
First, define which ports will be used as traffic generator TX/RX ports:
```ros
add disabled=no interface=ether2 name=port0
add disabled=no interface=ether3 name=port1
To construct the actual packet that will be generated, the packet-template is used:
```ros
add header-stack=mac,ip,udp ip-dst=2.2.2.1/32 ip-gateway=1.1.1.2 ip-src=1.1.1.1/32 \
    name=routing-1 port=port0
add header-stack=mac,ip,udp ip-dst=1.1.1.1/32 ip-gateway=2.2.2.2 ip-src=2.2.2.1/32 \
    name=routing-2 port=port1
Notice that MAC addresses were not specified, since the template generator can assume the next-hop MAC address automatically by sending ARP messages. Since routing is performed and the destination IP is not directly reachable, the **ip-gateway** parameter is set to determine the next-hop MAC address.
When running **print**, you can see all assumed (detected) values, including MAC addresses:
```ros
[admin@test-host] /tool/traffic-generator/packet-template> print
 0 name="routing-1" header-stack=mac,ip,udp port=port0
   assumed-mac-dst=00:0C:42:00:38:9D assumed-mac-src=00:0C:42:40:94:25
   assumed-mac-protocol=ip assumed-ip-dscp=0 assumed-ip-id=0
   assumed-ip-frag-off=0 assumed-ip-ttl=64 assumed-ip-protocol=udp
   ip-src=1.1.1.1/32 ip-dst=2.2.2.1/32 assumed-udp-src-port=100
   assumed-udp-dst-port=200 ip-gateway=1.1.1.2 data=uninitialized data-byte=0
 1 name="routing-2" header-stack=mac,ip,udp port=port1
   assumed-mac-dst=00:0C:42:00:38:D1 assumed-mac-src=00:0C:42:40:94:26
   ip-src=2.2.2.1/32 ip-dst=1.1.1.1/32 assumed-udp-src-port=100
   assumed-udp-dst-port=200 ip-gateway=2.2.2.2 data=uninitialized data-byte=0
If any router in the SUT were to change, the assumed MAC addresses would not be updated automatically. To update packet templates, issue the command:
```ros
The last part is to configure the streams:
```ros
add disabled=no mbps=500 name=str1 id=3 packet-size=1450 port=port0 pps=0 \
    tx-template=routing-1
add disabled=no mbps=500 name=str3 id=4 packet-size=1450 port=port1 pps=0 \
    tx-template=routing-2
Notice that each stream has a unique **id** value. This value identifies the stream packets; without it, the traffic generator will not work.
Now the test is ready to run. In this case, **quick** mode is used:
```ros
[admin@test-host] /tool/traffic-generator> quick mbps=450
SEQ    ID      TX-PACKET   TX-RATE     RX-PACKET   RX-RATE        RX-OOO   LOST-PACKET LOST-RATE
37     4          39 488 458.0Mbps        39 270 455.5Mbps        15 509           218   2.5Mbps
37     TOT        78 976 916.1Mbps        76 485 887.2Mbps        22 529         2 491  28.8Mbps
38     3          38 957 451.9Mbps        37 657 436.8Mbps         7 078         1 300  15.0Mbps
38     4          38 958 451.9Mbps        38 402 445.4Mbps        14 763           556   6.4Mbps
38     TOT        77 915 903.8Mbps        76 059 882.2Mbps        21 841         1 856  21.5Mbps
39     3          38 816 450.2Mbps        37 893 439.5Mbps         7 307           923  10.7Mbps
39     4          38 815 450.2Mbps        38 642 448.2Mbps        15 110           173   2.0Mbps
39     TOT        77 631 900.5Mbps        76 535 887.8Mbps        22 417         1 096  12.7Mbps
40     3          39 779 461.4Mbps        37 415 434.0Mbps         7 136         2 364  27.4Mbps
40     4          39 780 461.4Mbps        39 567 458.9Mbps        15 908           213   2.4Mbps
40     TOT        79 559 922.8Mbps        76 982 892.9Mbps        23 044         2 577  29.8Mbps
41     3          39 218 454.9Mbps        37 089 430.2Mbps         7 075         2 129  24.6Mbps
41     4          39 218 454.9Mbps        38 663 448.4Mbps        15 752           555   6.4Mbps
41     TOT        78 436 909.8Mbps        75 752 878.7Mbps        22 827         2 684  31.1Mbps
42     3          39 188 454.5Mbps        37 906 439.7Mbps         6 729         1 282  14.8Mbps
42     4          39 187 454.5Mbps        38 954 451.8Mbps        15 565           233   2.7Mbps
42     TOT        78 375 909.1Mbps        76 860 891.5Mbps        22 294         1 515  17.5Mbps
TOT    3       1 645 468 454.4Mbps     1 568 201 433.1Mbps       280 174        77 267  21.3Mbps
TOT    4       1 645 464 454.4Mbps     1 626 896 449.3Mbps       627 480        18 568   5.1Mbps
TOT    TOT     3 290 932 908.9Mbps     3 195 097 882.4Mbps       907 654        95 835  26.4Mbps
The stats show the throughput of each stream and the total throughput of both streams, the Out-of-Order packet count, the loss rate, latency and jitter.
