Traffic Flow
CLI reference:/ip/traffic-flow/ip/traffic-flow/target/ip/traffic-flow/ipfix
MikroTik Traffic-Flow provides statistical information about packets that pass through the router. Besides network monitoring and accounting, system administrators can identify various problems that occur in the network, and analyze and optimize overall network performance. Traffic-Flow is compatible with Cisco NetFlow, so utilities designed for NetFlow work with it.
Traffic Flow only processes traffic that passes through the router's CPU. HW-offloaded traffic (for example, HW-offloaded bridged traffic between switch-chip ports) never shows up in Traffic Flow.
Supported export formats:
- version 1 - The original NetFlow format. Basic information about IP packets flowing through a router, lacking support for different types of protocols and Type of Service (ToS).
- version 5 - An enhancement over version 1, supporting Type of Service (ToS), TCP flags and autonomous-system information. RouterOS does not fill BGP AS numbers.
- version 9 - Template-based export format with support for new record types; exports IPv4 and IPv6 flow information.
- IPFIX - The IETF-standardized protocol based on NetFlow version 9, with more customizable flow records; supports newer fields like multicast.
Enable Traffic Flow and choose interfaces
Enable the service in /ip/traffic-flow:
[admin@MikroTik] > /ip/traffic-flow/set enabled=yes
[admin@MikroTik] > /ip/traffic-flow/print
enabled: yes
interfaces: all
cache-entries: 256k
active-flow-timeout: 30m
inactive-flow-timeout: 15s
packet-sampling: no
sampling-interval: 0
sampling-space: 0
The cache-entries default depends on the device's memory (256k on larger boards, 4k on the smallest). active-flow-timeout and inactive-flow-timeout decide when a flow is expired and exported (see the parameter descriptions).
Packet sampling
Packet sampling only accounts for a selection of packets:
/ip/traffic-flow/set packet-sampling=yes sampling-interval=2222 \
sampling-space=1111
2222 consecutive packets are sampled, then 1111 are omitted, and the cycle repeats.
Add export targets
Add the hosts that receive flow data in /ip/traffic-flow/target:
[admin@MikroTik] > /ip/traffic-flow/target/add dst-address=192.168.0.2 \
port=2055 version=9
[admin@MikroTik] > /ip/traffic-flow/target/print
Columns: SRC-ADDRESS, DST-ADDRESS, PORT, VERSION
# SRC-ADDRESS DST-ADDRESS PORT VERSION
0 0.0.0.0 192.168.0.2 2055 9
src-address=0.0.0.0 means the router picks the source address of the outgoing interface automatically. The export goes out over UDP (default port 2055) in the chosen format, for example NetFlow version 9 here.
Watch the flow counters
The /ip/traffic-flow/monitor command shows the state of the flow cache (live-updating; stops after duration):
[admin@MikroTik] > /ip/traffic-flow/monitor duration=3
finished-flows: 0
active-flows: 8
unmanaged-packets: 0
unmanaged-bytes: 0
If the collector receives nothing, check that the flows appear here: active-flows climbs as the router routes traffic, and finished-flows starts climbing once the flows expire and get exported (default inactive-flow-timeout is 15s after the last packet of the flow). Check the target entry and that the traffic you watch is actually CPU-routed (not hardware-offloaded).
Choose exported fields for IPFIX
The /ip/traffic-flow/ipfix menu selects which fields appear in IPFIX flow records: addresses, ports, protocols, flags, interfaces, timing (for example sys-init-time, first-forwarded, last-forwarded), NAT addresses and ports and more — all rows listed in the CLI reference.
All fields are on by default; drop the ones you do not want with set:
[admin@MikroTik] > /ip/traffic-flow/ipfix/set gateway=no tcp-flags=no
Notes
Traffic flow records flows at the end of the input, forward and output chain stacks of the packet flow diagram, so only traffic that reaches one of those chains is counted.
Because of that, a mirror port on a switch connected to the router cannot be used to count mirrored packets: mirrored frames are dropped before they reach the input chain.
Other interfaces appear in the report if traffic passes through them and the monitoring interface.
Minimal end-to-end example
A setup from scratch on one router, exporting NetFlow v9 to a collector on 192.168.0.2:
/ip/traffic-flow/target/add dst-address=192.168.0.2 port=2055 version=9
The router starts sending export packets with the flow information; watch with /ip/traffic-flow/monitor.
To use ntop-ng with MikroTik you need to use Nprobe, which is paid software.
See more
Related topics
NetFlow analysis with Elasticsearch
This guide explains how to set up NetFlow analysis with Elasticsearch on MikroTik RouterOS by configuring data collection from RouterOS devices to an Elasticsearch server, including Kibana integration and Fleet Server deployment for efficient NetFlow data processing and visualization.
