Interface stats and monitor-traffic
CLI reference:/tool/traffic-monitor/interface/interface/monitor-traffic
Every RouterOS interface contains various counters, for example the number of received and transmitted packets, Fast Path bytes, the number of link downs on the physical side, and packets dropped by the interface queue. These statistics give real-time visibility into network utilization and hardware performance; the monitor-traffic command shows a live per-second rate view for verifying throughput and troubleshooting bottlenecks.
Inspect the counters
Print cumulative counters per interface with stats (or stats-detail for a per-interface list including link events):
[admin@MikroTik] > /interface/print stats
Flags: X - DISABLED; R - RUNNING; S - SLAVE
Columns: NAME, RX-BYTE, TX-BYTE, RX-PACKET, TX-PACKET, RX-DROP, TX-DROP,
TX-QUEUE-DROP, RX-ERROR, TX-ERROR
# NAME RX-BYTE TX-BYTE RX-PACKET TX-PACKET R T T R T
0 S ether1 0 0 0 0 0
1 RS ether2 28 805 078 8 117 511 221 798 17 287 0
2 S ether3 0 0 0 0 0
3 S ether4 0 0 0 0 0
4 S ether5 0 0 0 0 0
The values starting with fp are Fast Path counters; tx-queue-drop counts the packets dropped by the interface queue (a congestion signal). stats-detail adds the link-up/down timestamps and the link-downs count, which are used to spot a flapping cable (when the number keeps rising, check the cable, SFP, or PoE; the interface-specific error counters live in the Ethernet statistics menu):
[admin@MikroTik] > /interface/print stats-detail
0 S name="ether1" link-downs=0 rx-byte=0 tx-byte=0 rx-packet=0 tx-packet=0
tx-queue-drop=0 fp-rx-byte=0 fp-tx-byte=0 fp-rx-packet=0 fp-tx-packet=0
fp-rps-drop=0
1 RS name="ether2" last-link-up-time=2026-10-09 12:41:25 link-downs=0
rx-byte=28 805 078 tx-byte=8 117 511 rx-packet=221 798 tx-packet=17 287
tx-queue-drop=0 fp-rx-byte=27 917 886 fp-tx-byte=0 fp-rx-packet=221 798
fp-tx-packet=0 fp-rps-drop=0
Watch the live rate
/interface/monitor-traffic shows per-second rates for the chosen interfaces:
[admin@MikroTik] > /interface/monitor-traffic ether2 duration=3
rx-packets-per-second: 26
rx-bits-per-second: 26.4kbps
fp-rx-packets-per-second: 26
fp-rx-bits-per-second: 25.6kbps
tx-packets-per-second: 2
tx-bits-per-second: 12.7kbps
fp-tx-packets-per-second: 0
fp-tx-bits-per-second: 0bps
tx--drops-per-second: 0
The view refreshes continuously until you stop it; use duration to bound it. Use it to verify a newly configured VLAN or bridge member passes traffic or that a WAN port does not pass more than it should. Pass several interfaces to compare them side by side, or aggregate to watch the router as a whole. Use Torch for a per-connection breakdown when a single interface stays busy.
Trigger a script on a rate threshold
The /tool/traffic-monitor menu runs a script when an interface's transmitted or received rate goes above a threshold, below it, or every poll (always):
/system/script/add name=rate-alert \
source=":log info \"ether2 over threshold\""
/tool/traffic-monitor/add name=high-load interface=ether2 \
traffic=received trigger=above threshold=100000000 \
on-event=rate-alert
Technical details
- The values starting with
fpcount the traffic that took the Fast Path (the streamlined CPU forwarding path). When regular counters grow much faster than the fp counters, the traffic instead takes the full CPU path (firewall processing and so on) — useful on busy routers. - Interface drop/error counters (
rx-drop,tx-drop,rx-error,tx-error) count the problems seen by the driver;tx-queue-dropbelongs to the queueing system. link-downscounts only the physical link drops; a rising number with no link-down timestamps on a VLAN member usually points to a physical issue on the member's parent interface.
For all the counters and rate rows, see the /interface and /interface/monitor-traffic CLI references; the Ethernet statistics menu adds hardware-level counters.
