Skip to main content
Version: 7.26
actual-interface-configuration
caps-man/actual-interface-configuration​
Package: wireless-rep
Type: Directory
FlagNameDescription
Mmaster
Ddynamic
Bbound
Xdisabled
Iinactive
Rrunning
ArgumentTypeDescription
namestring
mac-addressmacAddr
arp-timeoutalt { arp-timeout: enum (auto) { auto:0 } , arp-timeout: time }
disable-running-checkbool
radio-macmacAddr
master-interfaceiface_enum { none }
configuration.mode ( unset )enum (ap)
configuration.ssid ( unset )string
configuration.hide-ssid ( unset )bool
configuration.max-sta-count ( unset )num
configuration.multicast-helper ( unset )enum (default | disabled | full | dhcp) { default:0, disabled:1, full:2, dhcp:3 }
configuration.tx-chains ( unset )ubit (0, 1, 2, 3)
configuration.rx-chains ( unset )ubit (0, 1, 2, 3)
configuration.guard-interval ( unset )enum (any | long) { any:0, long:1 }
configuration.country ( unset )enum
configuration.installation ( unset )enum (any | indoor | outdoor)
configuration.load-balancing-group ( unset )enum
configuration.distance ( unset )enum (indoors | dynamic) { indoors:0, dynamic:0xffffffff }
configuration.hw-retries ( unset )num
configuration.hw-protection-mode ( unset )enum (none | rts-cts | cts-to-self) { none:0, rts-cts:1, cts-to-self:2 }
configuration.hw-protection-threshold ( unset )num
configuration.frame-lifetime ( unset )time
configuration.disconnect-timeout ( unset )time
configuration.keepalive-frames ( unset )enum (enabled | disabled)
security.authentication-types ( unset )ubit (wpa-psk, wpa2-psk, wpa-eap, wpa2-eap)
security.encryption ( unset )ubit (aes-ccm, tkip)
security.group-encryption ( unset )enum (aes-ccm | tkip)
security.group-key-updatetime
security.passphrase ( unset )string
security.eap-methods ( unset )multi { array-id, method: enum (eap-tls | passthrough) { eap-tls:13, passthrough:0xffffffff } }
security.eap-radius-accounting ( unset )bool
security.tls-modeenum (verify-certificate | dont-verify-certificate | no-certificates | verify-certificate-with-crl)
security.tls-certificateenum (none) { none:0xffffffff }
security.disable-pmkid ( unset )bool
mtunum
l2mtunum
arpenum (disabled | enabled | proxy-arp | reply-only | local-proxy-arp) { disabled:0, enabled:1, proxy-arp:2, reply-only:3, local-proxy-arp:4 }
client-to-client-forwarding ( unset )bool
bridge ( unset )iface_enum
bridge-cost ( unset )num
bridge-horizon ( unset )num
openflow-switch ( unset )enum
local-forwarding ( unset )bool
vlan-mode ( unset )enum (no-tag | use-tag | use-service-tag)
vlan-id ( unset )num
interface-list ( unset )enum
channel.frequency ( unset )multi { array-id, frequency: num }
channel.secondary-frequency ( unset )multi { array-id, secondary-frequency: alt { secondary-frequency-disable: enum (disabled) , secondary-frequency-num: num } }
channel.control-channel-width ( unset )enum (5mhz | 10mhz | 20mhz | 40mhz-turbo) { 5mhz:5000, 10mhz:10000, 20mhz:20000, 40mhz-turbo:40000 }
channel.band ( unset )enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n | 5ghz-a/n/ac | 5ghz-n/ac | 5ghz-onlyac)
channel.extension-channel ( unset )enum (disabled | Ce | eC | Ceee | eCee | eeCe | eeeC | XX | XXXX | Ceeeeeee | eCeeeeee | eeCeeeee | eeeCeeee | eeeeCeee | eeeeeCee | eeeeeeCe | eeeeeeeC | XXXXXXXX)
channel.tx-power ( unset )num
channel.save-selected ( unset )bool
channel.reselect-interval ( unset )super { reselect-interval-min: time [1 .. 60*60*24*300] , [reselect-interval-max] ..time [1 .. 60*60*24*300] }
channel.skip-dfs-channels ( unset )bool
