Skip to main content
Version: 7.26
L3 Hardware Offloading
Layer 3 Hardware Offloading (L3HW, otherwise known as IP switching or HW routing) allows offloading some router features onto the switch chip. This allows reaching wire speeds when routing packets, which would simply not be possible with the CPU.
Switch Configuration​
To enable Layer 3 Hardware Offloading, set l3-hw-offloading=yes for the switch:
/interface/ethernet/switch/set 0 l3-hw-offloading=yes
Switch Port Configuration​
Layer 3 Hardware Offloading can be configured for each physical switch port. For example:
/interface/ethernet/switch/port/set sfp-sfpplus1 l3-hw-offloading=yes
Note that l3hw settings for switch and ports are different:
  • Setting l3-hw-offloading``=no for the switch completely disables offloading - all packets will be routed by the CPU.
  • However, setting l3-hw-offloading``=no for a switch port only disables hardware routing from/to this particular port. Moreover, the port can still participate in Fasttrack connection offloading.
To enable full hardware routing, enable l3hw on all switch ports:
/interface/ethernet/switch/port/set [find] l3-hw-offloading=yes
To make all packets go through the CPU first, and offload only the Fasttrack connections, disable l3hw on all ports but keep it enabled on the switch chip itself:
/interface/ethernet/switch/port/set [find] l3-hw-offloading=no
info
Packets are routed by hardware when both the ingress and egress ports have l3-hw-offloading=yes.
If both ingress and egress ports have l3-hw-offloading=no, packets will go through the CPU/Firewall while offloading only the Fasttrack connections.
It is possible to direct packets to go through the CPU/Firewall by setting l3-hw-offloading=no on just the egress port. However, setting l3-hw-offloading=no only the ingress port may cause unpredictable behavior, for example, packets might still be routed by hardware and completely bypass the CPU/firewall.
The next example enables hardware routing on all ports but the upstream port (sfp-sfpplus16). Packets going to/from sfp-sfpplus16 will enter the CPU and, therefore, be subject to Firewall/NAT processing.
/interface/ethernet/switch/port/set sfp-sfpplus16 l3-hw-offloading=no
warning
The existing connections may be unaffected by the l3-hw-offloading setting change.
L3HW Settings​
Settings menu /interface/ethernet/switch/l3hw-settings can be used to tweak L3HW behavior according to setup needs.
Interface Lists​
It is impossible to use interface lists directly to control l3-hw-offloading because an interface list may contain virtual interfaces (such as VLAN) while the l3-hw-offloading setting must be applied to physical switch ports only. For example, if there are two VLAN interfaces (vlan20 and vlan30) running on the same switch port (trunk port), it is impossible to enable hardware routing on vlan20 but keep it disabled on vlan30.
However, an interface list may be used as a port selector. The following example demonstrates how to enable hardware routing on LAN ports (ports that belong to the "LAN" interface list) and disable it on WAN ports:
:foreach i in=[/interface/list/member/find where list=LAN] do={
/interface/ethernet/switch/port/set [/interface/list/member/get $i interface] l3-hw-offloading=yes
:foreach i in=[/interface/list/member/find where list=WAN] do={
/interface/ethernet/switch/port/set [/interface/list/member/get $i interface] l3-hw-offloading=no
Please take into account that since interface lists are not directly used in hardware routing control, modifying the interface list also does not automatically reflect in l3hw changes. For instance, adding a switch port to the "LAN" interface list does not automatically enable l3-hw-offloading on it. The user has to rerun the above script to apply the changes.
MTU​
The hardware supports up to 8 MTU profiles, meaning that the user can set up to 8 different MTU values for interfaces: the default 1500 + seven custom ones.
tip
It is recommended to disable l3-hw-offloading while changing the MTU/L2MTU values on the interfaces.
MTU Change Example
/interface/ethernet/switch/set 0 l3-hw-offloading=no
/interface/set sfp-sfpplus1 mtu=9000 l2mtu=9022
/interface/set sfp-sfpplus2 mtu=9000 l2mtu=9022
/interface/set sfp-sfpplus3 mtu=10000 l2mtu=10022
Layer 2 Dependency​
Layer 3 hardware processing lies on top of Layer 2 hardware processing. Therefore, L3HW offloading requires L2HW offloading on the underlying interfaces. The latter is enabled by default, but there are some exceptions. For example, MikroTik devices with Marvell Prestera switch support only one hardware bridge. If there are multiple bridges, others are processed by the CPU and are not subject to L3HW.
Another example is ACL rules. If a rule redirects traffic to the CPU for software processing, then hardware routing (L3HW) is not triggered:
ACL rule to disable hardware processing on a specific port​
/interface/ethernet/switch/rule/add switch=switch1 ports=ether1 redirect-to-cpu=yes
tip
It is recommended to turn off L3HW offloading during L2 configuration.
To make sure that Layer 3 is in sync with Layer 2 on both the software and hardware sides, we recommend disabling L3HW while configuring Layer 2 features. The recommendation applies to the following configuration:
  • Adding/removing/enabling/disabling bridges.
  • Adding/removing switch ports to/from the bridge.
  • Bonding switch ports / removing bonds.
  • Changing VLAN settings.
  • Changing MTU/L2MTU on switch ports.
  • Changing ethernet (MAC) addresses.
In short, disable l3-hw-offloading while making changes under /interface/bridge/ and /interface/vlan/:
Layer 2 Configuration Template​
/interface/bridge
# put bridge configuration changes here
/interface/vlan
# define/change VLAN interfaces
MAC telnet​
There is a limitation for MAC telnet when L3HW offloading is enabled on 98DX8xxx, 98DX4xxx, or 98DX325x switch chips. Packets from MAC Telnet are dropped and do not reach the CPU, thus access to the device will fail.
If MAC telnet is desired in combination with L3HW, a certain ACL rule can be created to force these packets to the CPU.
For example, if MAC telnet access on sfp-sfpplus1 and sfp-sfpplus2 is needed, you will need to add this ACL rule. It is possible to select even more interfaces with the ports setting.
add dst-port=20561 ports=sfp-sfpplus1,sfp-sfpplus2 protocol=udp redirect-to-cpu=yes switch=switch1
Inter-VLAN Routing​
Since L3HW depends on L2HW, and L2HW is the one that does VLAN processing, Inter-VLAN hardware routing typically requires a hardware bridge underneath. Even if a particular VLAN has only one tagged port member, the port must be a bridge member, and the VLAN interface must be assigned to the bridge.
Devices with Marvell 98DX7xxx series switch chips are an exception — they also support hardware routing between VLAN interfaces created directly on Ethernet switch ports, without a bridge:
/interface/vlan/add interface=ether2 name=vlan20 vlan-id=20
On all other L3HW devices, do not assign a VLAN interface directly to a switch port — such an interface does not get offloaded and its traffic is routed by the CPU. Assign the VLAN interface to the bridge instead. This way, VLAN configuration gets offloaded to the hardware, and, with L3HW enabled, the traffic is subject to inter-VLAN hardware routing.
VLAN Configuration Example​
/interface/bridge/port/add bridge=bridge interface=ether2
/interface/bridge/vlan/add bridge=bridge tagged=bridge,ether2 vlan-ids=20
/interface/vlan/add interface=bridge name=vlan20 vlan-id=20
/ip/address/add address=192.0.2.1/24 interface=vlan20
/interface/bridge/set bridge vlan-filtering=yes
info
For Inter-VLAN routing, the bridge interface must be a tagged member of every routable /interface/bridge/vlan/ entry.
Per-VLAN offloading​
It is possible to configure L3HW offloading per individual VLAN interface using the l3-hw-offloading=yes|no setting in the /interface/vlan menu. This provides finer control over which VLANs (and their related routes) are offloaded to the switch chip, and which are processed by the CPU. It is no longer necessary to disable L3HW on a switch port in order to disable L3HW routing for specific VLANs.
VLAN interface gets offloaded (receives the H flag) only when ALL the following conditions are met:
  • VLAN interface has l3-hw-offloading=yes.
  • VLAN interface is created on a hardware-offloaded, vlan-filtering bridge, or, on 98DX7xxx switches, directly on an Ethernet switch port.
  • All involved switch ports have l3-hw-offloading=yes — all member ports of the VLAN for the bridge case, or the parent port for a VLAN interface created directly on a switch port.
For inter-VLAN routing, both ingress and egress VLANs must be hw-offloaded, otherwise, packets are sent to the CPU.
info
If a switch port carries multiple VLANs with different L3HW settings, keep the port's l3-hw-offloading=yes.
L3HW MAC Address Range Limitation (DX2000/DX3000 series only)​
Marvell Prestera DX2000 and DX3000 switch chips have a hardware limitation that allows configuring only the last (least significant) octet of the MAC address for each interface. The other five (most significant) octets are configured globally and, therefore, must be equal for all interfaces (switch ports, bridge, VLANs). In other words, the MAC addresses must be in the format "XX:XX:XX:XX:XX:??", where:
  • "XX:XX:XX:XX:XX" part is common for all interfaces.
  • "??" is a variable part.
This requirement applies only to Layer 3 (routing). Layer 2 (bridging) does not use the switch's ethernet addresses. Moreover, it does not apply to bridge ports because they use the bridge's MAC address.
The requirement for common five octets applies to:
  • Standalone switch ports (not bridge members) with hardware routing enabled (l3-hw-offloading=yes).
  • Bridge itself.
  • VLAN interfaces (those that use the bridge's MAC address by default).
Route Configuration​
Suppressing HW Offload​
By default, all the routes are hardware candidate routes. To further fine-tune which traffic to offload, there is an option for each route to disable/enable suppress-hw-offload.
For example, if we know that the majority of traffic flows to the network where servers are located, we can enable offloading only to that specific destination:
/ip/route/set [find where static && dst-address!="192.168.3.0/24"] suppress-hw-offload=yes
Now only the route to 192.168.3.0/24 has H-flag, indicating that it will be the only one eligible to be selected for HW offloading:
[admin@MikroTik] > /ip/route/print where static
Flags: A - ACTIVE; s - STATIC, y - COPY; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY D
0 As 0.0.0.0/0 172.16.2.1 1
1 As 10.0.0.0/8 10.155.121.254 1
2 AsH 192.168.3.0/24 172.16.2.1 1
danger
H-flag does not indicate that the route is actually HW offloaded; it indicates only that the route can be selected to be HW offloaded.
Routing Filters​
For dynamic routing protocols like OSPF and BGP, it is possible to suppress HW offloading using routing filters. For example, to suppress HW offloading on all OSPF instance routes, use the "suppress-hw-offload yes" property:
/routing/ospf/instance
set [find name=instance1] in-filter-chain=ospf-input
/routing/filter/rule
add chain="ospf-input" rule="set suppress-hw-offload yes; accept"
Offloading Fasttrack Connections​
Firewall filter rules have the hw-offload option for Fasttrack, allowing fine-tuning connection offloading. Since the hardware memory for Fasttrack connections is very limited, we can choose what type of connections to offload and, therefore, benefit from near-the-wire-speed traffic. The next example offloads only TCP connections while UDP packets are routed via the CPU and do not occupy HW memory:
/ip/firewall/filter
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes protocol=tcp
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=no
add action=accept chain=forward connection-state=established,related
Stateless Hardware Firewall​
While connection tracking and stateful firewalling can be performed only by the CPU, the hardware can perform stateless firewalling via switch rules (ACL). The next example prevents (on a hardware level) accessing a MySQL server from ether1, and redirects packets from ether2 and ether3 to the CPU/Firewall:
add switch=switch1 dst-address=10.0.1.2/32 dst-port=3306 ports=ether1 new-dst-ports=""
add switch=switch1 dst-address=10.0.1.2/32 dst-port=3306 ports=ether2,ether3 redirect-to-cpu=yes
Switch Rules (ACL) vs. Fasttrack HW Offloading​
Some firewall rules may be implemented via both switch rules (ACL) and CPU Firewall Filter + Fasttrack HW Offloading. Both options grant near-the-wire-speed performance. So the question is which one to use?
First, not all devices support Fasttrack HW Offloading, and without HW offloading, Firewall Filter uses only software routing, which is dramatically slower than its hardware counterpart. Second, even if Fasttrack HW Offloading is an option, a rule of thumb is:
tip
Always use Switch Rules (ACL), if possible.
Switch rules share the hardware memory with Fasttrack connections. However, hardware resources are allocated for each Fasttrack connection while a single ACL rule can match multiple connections. For example, if you have a guest WiFi network connected to sfp-sfpplus1 VLAN 10 and you don't want it to access your internal network, simply create an ACL rule:
add switch=switch1 ports=sfp-sfpplus1 vlan-id=10 dst-address=10.0.0.0/8 new-dst-ports=""
The matched packets will be dropped on the hardware level. It is much better than letting all guest packets go to the CPU for Firewall filtering.
Of course, ACL rules cannot match everything. For instance, ACL rules cannot filter connection states: accept established, drop others. That is where Fasttrack HW Offloading gets into action - redirect the packets to the CPU by default for firewall filtering, then offload the established Fasttrack connections. However, disabling l3-hw-offloading for the entire switch or port is not the only option.
info
Define ACL rules with redirect-to-cpu=yes instead of setting l3-hw-offloading=no on the switch port for narrowing down the traffic that goes to the CPU.
Hardware-Offloaded VRF​
Hardware-offloaded VRF is supported on 98DX8xxx, 98DX4xxx, 98DX325x, 98CX8410 and 98DX7xxx switch chips. It is not supported on 98DX3xxx and 98DX2xxx series.
If routes are in a VRF and the egress interface is L3HW-capable the switch chip will route the packet. You can associate any L3HW-capable interface (Ethernet, bonding, bridge, VLAN) with a VRF. Always associate the master interface with the VRF, not an interface marked with the S (slave) flag, such as a bridge or bonding port. Fasttrack, NAT, and VXLAN offloading are limited to the main routing table only.
VRFs are configured under /ip/vrf. For more details, see the VRF manual.
98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX3255 support up to 512 VRF tables. All other supported switch chips support up to 1024.
VRF Assignment via ACL​
L3HW supports assigning VRF to ingress traffic using ACL switch rules. The new-vrf option in /interface/ethernet/switch/rule allows directing matched packets into a specific VRF table.
On VRF-unaware switches (98DX3xxx and 98DX2xxx series), setting new-vrf to anything other than main will result in redirect-to-cpu=yes.
For more details on ACL rules, see Switch Rules (ACL).
Configuration Examples​
Inter-VLAN Routing with Upstream Port Behind Firewall/NAT​
This example demonstrates how to benefit from near-to-wire-speed inter-VLAN routing while keeping Firewall and NAT running on the upstream port. Moreover, Fasttrack connections to the upstream port get offloaded to hardware as well, boosting the traffic speed close to wire-level. Inter-VLAN traffic is fully routed by the hardware, not entering the CPU/Firewall, and, therefore, not occupying the hardware memory of Fasttrack connections.
We use the CRS317-1G-16S+ model with the following setup:
  • sfp1-sfp4 - bridged ports, VLAN ID 20, untagged.
  • sfp5-sfp8 - bridged ports, VLAN ID 30, untagged.
  • sfp16 - the upstream port.
  • ether1 - management port.
Set up interface lists for easy access:
Interface Lists​
/interface/list
add name=LAN
add name=WAN
add name=MGMT
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8 list=LAN
add interface=sfp-sfpplus16 list=WAN
add interface=ether1 list=MGMT
Bridge Setup​
/interface/bridge
add name=bridge vlan-filtering=yes
add bridge=bridge interface=sfp-sfpplus1 pvid=20
add bridge=bridge interface=sfp-sfpplus2 pvid=20
add bridge=bridge interface=sfp-sfpplus3 pvid=20
add bridge=bridge interface=sfp-sfpplus4 pvid=20
add bridge=bridge interface=sfp-sfpplus5 pvid=30
add bridge=bridge interface=sfp-sfpplus6 pvid=30
add bridge=bridge interface=sfp-sfpplus7 pvid=30
add bridge=bridge interface=sfp-sfpplus8 pvid=30
add bridge=bridge tagged=bridge untagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=20
add bridge=bridge tagged=bridge untagged=sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8 vlan-ids=30
Routing requires dedicated VLAN interfaces. For standard L2 VLAN bridging (without inter-VLAN routing), the next step can be omitted.
VLAN Interface Setup for Routing​
/interface/vlan
add interface=bridge name=vlan30 vlan-id=30
/ip/address
add address=192.168.20.17/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.17/24 interface=vlan30 network=192.168.30.0
Configure management and upstream ports, a basic firewall, NAT, and enable hardware offloading of Fasttrack connections:
Firewall Setup​
/ip/address
add address=192.168.88.1/24 interface=ether1
add address=10.0.0.17/24 interface=sfp-sfpplus16
/ip/route
add gateway=10.0.0.1
/ip/firewall/filter
/ip/firewall/nat
At this moment, all routing still is performed by the CPU. Enable hardware routing on the switch chip:
Enable Layer 3 Hardware Offloading​
# Enable full hardware routing on LAN ports
# Disable full hardware routing on WAN or Management ports
:foreach i in=[/interface/list/member/find where list=WAN or list=MGMT] do={
# Activate Layer 3 Hardware Offloading on the switch chip
Results:
  • Within the same VLAN (e.g., sfp1-sfp4), traffic is forwarded by the hardware on Layer 2 (L2HW).
  • Inter-VLAN traffic (e.g. sfp1-sfp5) is routed by the hardware on Layer 3 (L3HW).
  • Traffic from/to the WAN port gets processed by the CPU/Firewall first. Then Fasttrack connections get offloaded to the hardware (Hardware-Accelerated L4 Stateful Firewall). NAT applies both on CPU- and HW-processed packets.
  • Traffic to the management port is protected by the Firewall.
Typical Misconfiguration​
Below are typical user errors in configuring Layer 3 Hardware Offloading.
VLAN interface on a switch port or bond​
/interface/vlan
add name=vlan10 vlan-id=10 interface=sfp-sfpplus1
add name=vlan20 vlan-id=20 interface=bond1
Due to Layer 2 dependency, on most devices only VLAN interfaces created on a hardware-offloaded, vlan-filtering bridge are capable of L3HW offloading. The correct configuration is:
add bridge=bridge1 interface=sfp-sfpplus1 frame-types=admit-only-vlan-tagged
add bridge=bridge1 interface=bond1 frame-types=admit-only-vlan-tagged
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1 vlan-ids=10
add bridge=bridge1 tagged=bridge1,bond1 vlan-ids=20
/interface/vlan
add name=vlan10 vlan-id=10 interface=bridge1
add name=vlan20 vlan-id=20 interface=bridge1
warning
If VLAN interfaces are created directly on Ethernet or bonding interfaces on devices that do not support offloading such interfaces (see Inter-VLAN Routing), packets may be offloaded incorrectly - bypassing CPU processing (such as firewall and NAT) and causing undefined behavior.
If this type of configuration is required, L3HW offloading must be disabled on the related switch ports under the /interface/ethernet/switch/port menu by setting l3-hw-offloading=no.
Not adding the bridge interface to /interface/bridge/vlan/​
For Inter-VLAN routing, the bridge interface itself needs to be added to the tagged members of the given VLANs. In the next example, Inter-VLAN routing works between VLAN 10 and 11, but packets are NOT routed to VLAN 20.
add bridge=bridge1 vlan-ids=10 tagged=bridge1,sfp-sfpplus1
add bridge=bridge1 vlan-ids=11 tagged=bridge1 untagged=sfp-sfpplus2,sfp-sfpplus3
add bridge=bridge1 vlan-ids=20 tagged=sfp-sfpplus1 untagged=sfp-sfpplus4,sfp-sfpplus5
The above example does not always mean an error. Sometimes, you may want the device to act as a simple L2 switch in some/all VLANs. Just make sure you set such behavior on purpose, not due to a mistake.
Creating multiple bridges​
The devices support only one hardware bridge. If there are multiple bridges created, only one gets hardware offloading. While for L2 that means software forwarding for other bridges, in the case of L3HW, multiple bridges may lead to undefined behavior.
tip
Instead of creating multiple bridges, create one and segregate L2 networks with VLAN filtering.
Using ports that do not belong to the switch​
Some devices have two switch chips or the management port directly connected to the CPU. For example, CRS312-4C+8XG has an ether9 port connected to a separate switch chip. Trying to add this port to a bridge or involve it in the L3HW setup leads to unexpected results. Leave the management port for management!
[admin@crs312] /interface/ethernet/switch> print
Columns: NAME, TYPE, L3-HW-OFFLOADING
# NAME TYPE L3-HW-OFFLOADING
0 switch1 Marvell-98DX8212 yes
1 switch2 Atheros-8227 no
[admin@crs312] /interface/ethernet/switch> port print
Columns: NAME, SWITCH, L3-HW-OFFLOADING, STORM-RATE
# NAME SWITCH L3-HW-OFFLOADING STORM-RATE
0 ether9 switch2
1 ether1 switch1 yes 100
2 ether2 switch1 yes 100
3 ether3 switch1 yes 100
4 ether4 switch1 yes 100
5 ether5 switch1 yes 100
6 ether6 switch1 yes 100
7 ether7 switch1 yes 100
8 ether8 switch1 yes 100
9 combo1 switch1 yes 100
10 combo2 switch1 yes 100
11 combo3 switch1 yes 100
12 combo4 switch1 yes 100
13 switch1-cpu switch1 100
14 switch2-cpu switch2
Relying on Fasttrack HW Offloading too much​
Since Fasttrack HW Offloading offers near-the-wire-speed performance at zero configuration overhead, users are tempted to use it as the default solution. However, the number of HW Fasttrack connections is very limited, leaving the other traffic for the CPU. Try using the hardware routing as much as possible, reduce the CPU traffic to the minimum via switch ACL rules, and then fine-tune which Fasttrack connections to offload with firewall filter rules.
Trying to offload slow-path connections​
Using certain configurations (e.g. enabling bridge "use-ip-firewall" setting, creating bridge nat/filter rules) or running specific features like sniffer or torch can disable RouterOS FastPath, which will affect the ability to properly FastTrack and HW offload connections. If HW offloaded Fasttrack is required, make sure that there are no settings that disable the FastPath and verify that connections are getting the "H" flag or use the L3HW monitor command to see the number of HW offloaded connections.
L3HW Feature Support​
  • HW - The feature is supported and offloaded to the hardware.
  • CPU - The feature is supported but performed by software (CPU).
  • N/A - The feature is not available together with L3HW. Layer 3 hardware offloading must be completely disabled (switch l3-hw-offloading=no) to make this feature work.
  • FW - The feature requires l3-hw-offloading=no for a given switch port. On the switch level, l3-hw-offloading=yes.
FeatureSupportCommentsRelease
IPv4 Unicast RoutingHW7.1
IPv6 Unicast RoutingHW
/interface/ethernet/switch/l3hw-settings/set ipv6-hw=yes
7.6
IPv4 Multicast RoutingCPU
IPv6 Multicast RoutingCPU
ECMPHWMultipath routing7.1
BlackholesHW
/ip/route/add dst-address=10.0.99.0/24 blackhole
7.1
gateway=<interface_name>CPU/HW
/ip/route/add dst-address=10.0.0.0/24 gateway=ether1
This works only for directly connected networks. Since HW does not know how to send ARP requests, CPU sends an ARP request and waits for a reply to find out the DST MAC address on the first received packet of the connection that matches a DST IP address. After DST MAC is determined, HW entry is added and all further packets will be processed by the switch chip.
7.1
BridgeHWRouting from/to hardware-offloaded bridge interface.7.1
VLANHWRouting between VLAN interfaces that are created on hardware-offloaded bridge interface with vlan-filtering.
On 98DX7xxx switches, also between VLAN interfaces created directly on Ethernet switch ports.
/interface/vlan
7.1
BondingHWRouting between bonding interfaces.
/interface/bonding
Only 802.3ad and balance-xor bonding modes are hardware offloaded.
7.1
IPv4 FirewallFWUsers must choose either HW-accelerated routing or firewall. Firewall rules get processed by the CPU. Fasttrack connections get offloaded to HW.7.1
IPv4 NATFWNAT rules applied to the offloaded Fasttrack connections get processed by HW too.7.1
MLAGN/A
VRFHWHardware-offloaded VRF.
VRRPN/A
Traffic-FlowN/AL3HW offloaded traffic is not reported through Traffic Flow.
VXLANHWSupport for hardware-offloaded VXLAN data plane, VXLAN encapsulation and decapsulation. This allows for static one-to-one VLAN-to-VXLAN mappings within a vlan-filtering bridge. At this point, some known features are not yet implemented.
Underlay (routing encapsulated VXLAN packets):
1. VTEPs are not supported over ECMP
2. VTEPs are not supported over bond, bridge, VLAN interfaces (only stand-alone routed Ethernet interfaces are supported)
3. VTEPs are not supported over multicast
4. VXLAN hardware offloading is limited to the main routing table. VTEPs cannot operate within VRFs.
5. VTEPs are not supported with IPv6
Overlay (forwarding between Ethernet and VXLAN):
1. VLAN tagging over VXLAN is not supported
2. Routing between different VXLAN VNIs is not supported
3. VTEPs are isolated, and there is no mechanism to control "horizon" between them.
4. Bridged VXLAN interfaces do not support IGMP snooping. When snooping is enabled, MDB entries on VXLAN are not offloaded, and multicast traffic gets restricted between Ethernet and VXLAN.
5. Bridged VXLAN interfaces are not supported by MLAG.
/interface/vxlan
7.18
MTUHWThe hardware supports up to 8 MTU profiles.7.1
QinQ RoutingCPUStacked routable VLAN interfaces will lose L3HW offloading, while routable VLAN interfaces created directly on the bridge interface can still use HW offloading.
IPv4 routes with IPv6 nexthops or vice versaN/A
Only the devices listed in the table below support L3 HW Offloading.
L3HW Device Support​
CRS3xx: Switch 98DX3xxx and 98DX2xxx Series​
The devices below are based on Marvell 98DX224S, 98DX226S, 98DX2528, or 98DX3236 switch chip models.
info
The 98DX3255 and 98DX3257 models are exceptions, which have a feature set of the 98DX8xxx rather than the 98DX3xxx series.
Caution: Below are some important features that these devices are missing when compared to other switch models:
  • Fasttrack and NAT connection offloading
  • per-VLAN packet and byte counters
  • VXLAN offloading
  • hardware-offloaded VRF.
Switch ChipModelsIPv4 Route Prefixes 1IPv6 Route Prefixes 2NexthopsECMP paths per prefix 3
98DX3236CRS305-1G-4S+IN
CRS326-24G-2S+ (RM/IN)
CRS328-24P-4S+RM
CRS328-4C-20S-4S+RM
1331233284K8
98DX226SCRS305-1G-4S+OUT (FiberBox Plus)
CRS310-1G-5S-4S+ (netFiber 9/IN)
CRS310-8G+2S+IN
CRS318-16P-2S+OUT (netPower 16P)
CRS320-8P-8B-4S+RM
CRS418-8P-8G-2S+RM
CRS418-8P-8G-2S+5axQ2axQ-RM
1331233284K8
98DX224SCRS318-1Fi-15Fr-2S-OUT (netPower 15FR)1331233284K8
98DX2528CRS304-4XG-IN1331233284K8
1 Since the total number of routes that can be offloaded is limited, prefixes with higher netmask are preferred to be forwarded by hardware (e.g., /32, /30, /29, etc.). Any other prefixes that do not fit in the HW table will be processed by the CPU. Directly connected hosts are offloaded as /32 (IPv4) or /128 (IPv6) route prefixes. The number of hosts is also limited by max-neighbor-entries in IP Settings / IPv6 Settings.
2 IPv4 and IPv6 routing tables share the same hardware memory.
3 If a route has more paths than the hardware ECMP limit (X), only the first X paths get offloaded.
Partial offloading​
In the case of 98DX3xxx, 98DX2xxx switch chip series, it is quite simple: one RouterOS route entry (/ip/route/) reflects into one HW IPv4 route prefix entry. Connected hosts (/32 routes) also occupy the same table. As long as the total number of routes ("/ip/route/print count-only") + connected host count ("/ip/arp/print count-only where status=reachable or status=stale"), does not exceed 13312 (13k), everything gets offloaded. Exceeding the number, routes with shorter prefixes stay on the CPU.
CCR2xxx, CRS3xx, CRS5xx: Switch 98DX8xxx and 98DX4xxx Series​
The devices below are based on Marvell 98DX8xxx, 98DX4xxx switch chips, or 98DX325x model.
Switch ChipModelsIPv4 Routes 1IPv4 Hosts 5IPv6 Routes 1IPv6 Hosts 5NexthopsIPv4 Fasttrack connections 2, 3, 4IPv4 NAT entries 2, 4IPv4 Fasttrack/NAT, VXLAN offloading Per-VLAN packet/byte counters
98DX8208CRS309-1G-8S+INup to 36Kup to 16Kup to 6Kup to 12K8K4.5K3.9K+
98DX8212CRS312-4C+8XG-RMup to 36Kup to 16Kup to 6Kup to 12K8K2.25K2.25K+
98DX8216CRS317-1G-16S+RMup to 240Kup to 64Kup to 40Kup to 48K8K4.5K4K+
98DX8332CRS326-24S+2Q+RM
CRS326-4C+20G+2Q+RM
98DX3257 6CRS354-48G-4S+2Q+RM
CRS354-48P-4S+2Q+RM
98DX4310CRS504-4XQ (IN/OUT)
CRS510-8XS-2XQ-IN
RDS2216-2XG-4S+4XS-2XQ
up to 120Kup to 64Kup to 20Kup to 48K8K4.5K4K+
98CX8410CRS520-4XS-16XQ-RMup to 240Kup to 64Kup to 40Kup to 48K8K4.5K4K+
98DX3255 6CCR2116-12G-4S+up to 36Kup to 16Kup to 6Kup to 12K8K2.25K2.25K+
98DX8525CCR2216-1G-12XS-2XQ
CRS518-16XS-2XQ-RM
1 Depends on the complexity of the routing table. Whole-byte IP prefixes (/8, /16, /24, etc.) occupy less HW space than others (e.g., /22). When the Routing HW table gets full, only routes with longer subnet prefixes are offloaded (/30, /29, /28, etc.) while the CPU processes the shorter prefixes. Users can fine-tune what routes to offload via routing filters (for dynamic routes) or suppressing hardware offload per switch port, static route or VLAN. IPv4 and IPv6 routing tables share the same hardware memory.
2 When the HW limit of Fasttrack or NAT entries is reached, other connections will fall back to the CPU. MikroTik's smart connection offload algorithm ensures that the connections with the most traffic are offloaded to the hardware.
3 Fasttrack connections share the same HW memory with ACL rules. Depending on the complexity, one ACL rule may occupy the memory of 3-6 Fasttrack connections.
4 If a Fasttrack connection requires Network Address Translation, a hardware NAT entry is created. The hardware supports both SRCNAT and DSTNAT.
5 DX4000/DX8000 switch chips store directly connected hosts, IPv4 /32, and IPv6 /128 route entries in the FDB table rather than the routing table. The HW memory is shared between regular FDB L2 entries (MAC), IPv4, and IPv6 addresses. The number of hosts is also limited by max-neighbor-entries in IP Settings / IPv6 Settings.
6 The switch chip has a feature set of the DX8000 series.
Partial offloading​
The 98DX8xxx, 98DX4xxx have entirely different routing tables. Instead of prefixes, we have to offload route indexes. The entire IPv4 address range (same for IPv6) must be indexed, i.e., 0.0.0.0 - 255.255.255.255. Adding new route entries causes an index rebuild, increasing hardware memory by 0-5 entries depending on the complexity of the routing table. That's why no exact numbers are given. For example, some routing tables containing 240K entries can be fully offloaded to CRS317 HW, while others with 160K entries barely fit. And you will never know until you try.
When indexing the entire IP address range (0.0.0.0 - 255.255.255.255), you can offload as many routes as needed, as long as you also have a default route (0.0.0.0/0) using the same next-hop.
For example, on a CCR2216 router around 950k routes with a /30 prefix are created, all using the same next-hop along with a default route. As a result, all routes were offloaded, while the lpm-usage remained minimal.
[admin@MikroTik] > /interface/ethernet/switch/l3hw-settings/advanced/monitor
ipv4-routes-total: 942338
ipv4-routes-hw: 942326
ipv4-routes-cpu: 11
ipv4-shortest-hw-prefix: 0
ipv4-hosts: 1
route-queue-size: 0
route-queue-rate: 0
route-process-rate: 0
nexthop-cap: 8192
nexthop-usage: 85
vxlan-mtu-packet-drop: 0
fasttrack-ipv4-conns: 0
fasttrack-queue-size: 0
fasttrack-queue-rate: 0
fasttrack-process-rate: 0
fasttrack-hw-min-speed: 0
fasttrack-hw-offloaded: 0
fasttrack-hw-unloaded: 0
lpm-cap: 27200
lpm-usage: 11
lpm-bank-cap: 1360
lpm-bank-usage: 1
0
0
0
1
0
0
0
4
0
0
0
5
0
0
0
0
0
0
0
pbr-cap: 8192
pbr-usage: 0
pbr-lpm-bank: 2
nat-usage: 0
However, if there are "gaps" in the address range, such as not using a default route or having multiple next-hops, this consumes HW table. When the routing HW table gets full, only routes with longer subnet prefixes are offloaded (/30, /29, /28, etc.) while the CPU processes the shorter prefixes. Here is what happens when the default route gets disabled or different next-hops are used: only 37k routes with a /30 prefix fit in the HW table. This is the worst-case scenario for the CCR2216.
ipv4-routes-total: 942337
ipv4-routes-hw: 37729
ipv4-routes-cpu: 904608
ipv4-shortest-hw-prefix: 30
ipv4-hosts: 1
route-queue-size: 0
route-queue-rate: 0
nexthop-cap: 8192
nexthop-usage: 85
lpm-cap: 27200
lpm-usage: 22392
lpm-bank-cap: 1360
lpm-bank-usage: 1022
1033
1027
1028
1221
1033
1040
678
1358
1245
1254
1242
1246
1249
1273
1260
1101
1024
1031
1027
pbr-cap: 8192
pbr-usage: 0
pbr-lpm-bank: 2
nat-usage: 0
In many cases, the default behavior "offloading only routes with longer subnet prefixes" is not optimal, especially if the ratio of CPU-handled routes to HW-offloaded routes is too high. When this happens, the chances of a packet being hardware-forwarded drop significantly.
If HW memory is insufficient and partial offloading occurs, a better approach for you as a network administrator would be to offload only the routes that carry the most traffic while keeping less demanding routes on the CPU, and not letting the partial offloading happen.
Fortunately, there are several ways to manage this. There is per-switch-port and static route suppression, and filtering dynamic routes using a wide range of attributes. One example is to use as-path to filter most demanding prefixes (Google, Meta), while all other routes get L3HW suppressed.
CRS8xx: Switch 98DX7xxx Series​
The devices below are based on Marvell 98DX7xxx switch chip models.
danger
The software support for the following features is still in development and not available yet:
  • FastTrack and NAT connection offloading
  • VXLAN offloading
Switch ChipModelsIPv4 Routes 1IPv4 Hosts 2IPv6 Routes 1IPv6 Hosts 2NexthopsIPv4 Fasttrack connectionsIPv4 NAT entriesVXLAN offloadingPer-VLAN packet/byte counters
98DX7335CRS812-8DS-2DQ-2DDQ-RMup to 240Kup to 64Kup to 40Kup to 48K16Kto be announcedto be announcedto be announced+
98DX7335CRS804-4DDQ-hRMup to 240Kup to 64Kup to 40Kup to 48K16Kto be announcedto be announcedto be announced+
1 Depends on the complexity of the routing table. Whole-byte IP prefixes (/8, /16, /24, etc.) occupy less HW space than others (e.g., /22). When the Routing HW table gets full, only routes with longer subnet prefixes are offloaded (/30, /29, /28, etc.) while the CPU processes the shorter prefixes. Users can fine-tune what routes to offload via routing filters (for dynamic routes) or suppressing hardware offload of static routes. IPv4 and IPv6 routing tables share the same hardware memory.
2 98DX7xxx switch chips store directly connected hosts, IPv4 /32 route entries, and IPv6 /128 route entries in the FDB table rather than the routing table. The HW memory is shared between regular FDB L2 entries (MAC), IPv4 addresses, and IPv6 addresses. The number of hosts is also limited by max-neighbor-entries in IP Settings / IPv6 Settings.
