Skip to main content
Version: current
CRS1xx/2xx series switches examples
Basic use cases and configuration examples for Cloud Router Switch features.
info
This article applies to CRS1xx and CRS2xx series switches and not to MikroTik devices with Marvell Prestera switch (e.g. CRS3xx series switches).
Port switching
To set up port switching on CRS1xx/2xx series switches, check the Bridge Hardware Offloading page.
danger
It is possible to create multiple isolated switch groups by using multiple bridges with enabled hardware offloading; this is possible only on CRS1xx/2xx series switches. For more complex setups (for example, VLAN filtering) you should use the port isolation feature instead.
Management access configuration
In general, switches are only supposed to forward packets by using the built-in switch chip, but not allow access to the device itself for security reasons. It is possible to use the device's serial port for management access, but in most cases, such an access method is not desired and access using an IP address is more suitable. In such cases, you will need to configure management access.
In all types of management access, it is assumed that ports must be switched together. Use the following commands to switch together the required ports:
/interface/bridge
add name=bridge1
/interface/bridge/port
add bridge=bridge1 interface=ether2 hw=yes
add bridge=bridge1 interface=ether3 hw=yes
add bridge=bridge1 interface=ether4 hw=yes
add bridge=bridge1 interface=ether5 hw=yes
You should also assign an IP address to the bridge interface so the device is reachable using an IP address (the device is also reachable using a MAC address):
/ip/address
add address=192.168.88.1/24 interface=bridge1
Untagged
If invalid VLAN filtering is not enabled, management access to the device using tagged or untagged (VLAN 0) traffic is already allowed from any port, though this is not a good practice; this can cause security issues and can cause the device's CPU to be overloaded in certain situations (most commonly with a broadcast type of traffic).
If you intend to use invalid VLAN filtering (which you should), then ports from which you are going to access the switch must be added to the VLAN table for untagged (VLAN 0) traffic, for example, in case you want to access the switch from ether2:
/interface/ethernet/switch/vlan
add vlan-id=0 ports=ether2,switch1-cpu
Tagged
Allowing only tagged traffic to have management access to the device through a specific port is a much better practice. For example, to allow only VLAN99 to access the device through ether2, you should first add an entry to the VLAN table, which will allow the selected port and the CPU port (switch1-cpu) to forward the selected VLAN ID, therefore allowing management access:
add ports=ether2,switch1-cpu vlan-id=99
Packets that will be sent out from the CPU, for example, ping replies, will not have a VLAN tag, to solve this you need to specify which ports should always send out packets with a VLAN tag for a specific VLAN ID:
/interface/ethernet/switch/egress-vlan-tag
add tagged-ports=ether2,switch1-cpu vlan-id=99
After a valid VLAN99 configuration has been set up, you can enable unknown/invalid VLAN filtering, which will not allow management access through different ports than specified in the VLAN table:
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether2,ether3,ether4,ether5
In this example VLAN99 will be used to access the device. A VLAN interface on the bridge must be created and an IP address must be assigned to it.
/interface/vlan
add interface=bridge1 name=MGMT vlan-id=99
/ip/address
add address=192.168.99.1/24 interface=MGMT
VLAN
:::danger Risk of Lockout It is highly recommended to have a Serial Console cable tested and ready before configuring VLANs. Misconfigurations can easily lock you out of the CPU or your connected port. :::
:::tip Troubleshooting Cached MAC Addresses Some changes may appear delayed because of already-learned MAC addresses. If traffic isn't flowing as expected after a change, flush the Unicast Forwarding Database: /interface/ethernet/switch/unicast-fdb/flush :::
:::info Architectural Best Practice Using multiple hardware-offloaded bridges is a fast way to achieve simple port isolation, but it limits advanced VLAN functionality on the CRS switch-chip. For advanced setups, use a single bridge for all ports, configure your VLANs, and isolate port groups using port isolation profiles. :::
Port Based VLAN
warning
For CRS3xx series devices, you must use bridge VLAN filtering; you can read more about it in the Bridge VLAN Filtering section.
Example 1 (Trunk and Access ports)
Access Ports
Switch together the required ports:
/interface/bridge
add name=bridge1
add bridge=bridge1 interface=ether6 hw=yes
add bridge=bridge1 interface=ether7 hw=yes
add bridge=bridge1 interface=ether8 hw=yes
Specify the VLAN ID that the switch must set on untagged (VLAN0) traffic for each access port:
/interface/ethernet/switch/ingress-vlan-translation
add ports=ether6 customer-vid=0 new-customer-vid=200
add ports=ether7 customer-vid=0 new-customer-vid=300
add ports=ether8 customer-vid=0 new-customer-vid=400
warning
When an entry is created under /interface/ethernet/switch/ingress-vlan-translation, the switch chip will add a VLAN tag on ingress frames on the specified port. To remove the VLAN tag on the same port for egress frames, an /interface/ethernet/switch/egress-vlan-tag entry should be created for the same VLAN ID where only tagged ports are specified. If a specific VLAN is forwarded only between access ports, the /interface/ethernet/switch/egress-vlan-tag entry should still be created without any tagged ports. Another option is to create extra entries under the /interface/ethernet/switch/egress-vlan-translation menu to set untagged (VLAN0) traffic.
You must also specify which VLANs should be sent out to the trunk port with a VLAN tag. Use the tagged-ports property to set up a trunk port:
add tagged-ports=ether2 vlan-id=200
add tagged-ports=ether2 vlan-id=300
add tagged-ports=ether2 vlan-id=400
Add entries to the VLAN table to specify VLAN memberships for each port and each VLAN ID:
add ports=ether2,ether6 vlan-id=200
add ports=ether2,ether7 vlan-id=300
add ports=ether2,ether8 vlan-id=400
After a valid VLAN configuration has been set up, you can enable unknown/invalid VLAN filtering:
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether2,ether6,ether7,ether8
warning
It is possible to use the built-in switch chip and the CPU at the same time to create a Switch-Router setup, where a device acts as a switch and as a router simultaneously.
Example 2 (Trunk and Hybrid Ports)
Hybrid Ports
/interface/bridge
add name=bridge1
By specifying ports as tagged-ports, the switch will always send out packets as tagged packets with the corresponding VLAN ID. Add appropriate entries according to the diagram above:
add tagged-ports=ether2,ether7,ether8 vlan-id=200
add tagged-ports=ether2,ether6,ether8 vlan-id=300
add tagged-ports=ether2,ether6,ether7 vlan-id=400
add ports=ether2,ether6,ether7,ether8 vlan-id=200 learn=yes
add ports=ether2,ether6,ether7,ether8 vlan-id=300 learn=yes
add ports=ether2,ether6,ether7,ether8 vlan-id=400 learn=yes
Protocol Based VLAN
Protocol Based VLAN
/interface/bridge
add name=bridge1
Set VLAN for IP and ARP protocols:
/interface/ethernet/switch/protocol-based-vlan
add port=ether2 protocol=arp set-customer-vid-for=all new-customer-vid=0
add port=ether6 protocol=arp set-customer-vid-for=all new-customer-vid=200
add port=ether2 protocol=ip set-customer-vid-for=all new-customer-vid=0
add port=ether6 protocol=ip set-customer-vid-for=all new-customer-vid=200
Set VLAN for IPX protocol:
add port=ether2 protocol=ipx set-customer-vid-for=all new-customer-vid=0
add port=ether7 protocol=ipx set-customer-vid-for=all new-customer-vid=300
Set VLAN for AppleTalk AARP and AppleTalk DDP protocols:
add port=ether2 protocol=0x80F3 set-customer-vid-for=all new-customer-vid=0
add port=ether8 protocol=0x80F3 set-customer-vid-for=all new-customer-vid=400
add port=ether2 protocol=0x809B set-customer-vid-for=all new-customer-vid=0
add port=ether8 protocol=0x809B set-customer-vid-for=all new-customer-vid=400
MAC Based VLAN
danger
Internally, all MAC addresses in MAC-based VLANs are hashed. Certain MAC addresses can have the same hash, which will prevent a MAC address from being loaded into the switch chip if the hash matches with a hash from a MAC address that has been already loaded, for this reason, it is recommended to use Port-based VLANs in combination with MAC-based VLANs. This is a hardware limitation.
MAC Based VLAN
/interface/bridge
add name=bridge1
Enable MAC-based VLAN translation on an access port:
/interface/ethernet/switch/port
set ether7 allow-fdb-based-vlan-translate=yes
Add MAC-to-VLAN mapping entries in the MAC-based VLAN table:
/interface/ethernet/switch/mac-based-vlan
add src-mac=A4:12:6D:77:94:43 new-customer-vid=200
add src-mac=84:37:62:DF:04:20 new-customer-vid=300
add src-mac=E7:16:34:A1:CD:18 new-customer-vid=400
Add VLAN200, VLAN300, and VLAN400 tagging on the ether2 port to create it as a VLAN trunk port:
Additionally, add entries to the VLAN table, specify VLAN membership for each port, and enable unknown/invalid VLAN filtering, see an example below - Unknown/Invalid VLAN filtering. This is required for network setups where more interfaces are added to the bridge, as it allows defining VLAN boundaries.
InterVLAN Routing
VLAN Routing
InterVLAN routing configuration consists of two main parts – VLAN tagging in switch-chip and routing in RouterOS. This configuration can be used in many applications by combining it with a DHCP server, Hotspot, PPP, and other features for each VLAN.
/interface/bridge
add name=bridge1
Set VLAN tagging on the CPU port for all VLANs to make packets tagged before they are routed:
add tagged-ports=switch1-cpu vlan-id=200
add tagged-ports=switch1-cpu vlan-id=300
add tagged-ports=switch1-cpu vlan-id=400
Add ingress VLAN translation rules to ensure that the correct VLAN ID assignment is done on access ports:
Create the VLAN interfaces on top of the bridge interface:
/interface/vlan
add name=VLAN200 interface=bridge1 vlan-id=200
add name=VLAN300 interface=bridge1 vlan-id=300
add name=VLAN400 interface=bridge1 vlan-id=400
danger
Make sure the VLAN interfaces are created on top of the bridge interface instead of any of the physical interfaces. If the VLAN interfaces are created on a slave interface, then the packet might not be received correctly, and therefore routing might fail. More detailed information can be found in the VLAN interface on a slave interface manual page.
Add IP addresses on created VLAN interfaces. In this example, three 192.168.x.1 addresses are added to VLAN200, VLAN300, and VLAN400 interfaces:
/ip/address
add address=192.168.20.1/24 interface=VLAN200
add address=192.168.30.1/24 interface=VLAN300
add address=192.168.40.1/24 interface=VLAN400
VLAN membership is defined in the VLAN table. Adding entries with VLAN ID and ports makes that VLAN traffic valid on those ports. After a valid VLAN configuration has been set up, unknown/invalid VLAN filtering can be enabled. This VLAN filtering configuration example applies to the InterVLAN Routing setup.
add ports=switch1-cpu,ether6 vlan-id=200
add ports=switch1-cpu,ether7 vlan-id=300
add ports=switch1-cpu,ether8 vlan-id=400
  • Option 1: disable invalid VLAN forwarding on specific ports (more common).
  • Option 2: disable invalid VLAN forwarding on all ports.
set forward-unknown-vlan=no
danger
Using multiple bridges on a single switch chip with enabled unknown/invalid VLAN filtering can cause unexpected behavior. You should always use a single bridge configuration whenever using VLAN filtering. If port isolation is required, then the port isolation feature should be used instead of using multiple bridges.
VLAN Tunneling (Q-in-Q)
This example covers a typical VLAN tunneling use case where service provider devices add another VLAN tag for independent forwarding while allowing customers to use their own VLANs.
warning
This example contains only the Service VLAN tagging part. It is recommended to additionally set Unknown/Invalid VLAN filtering configuration on ports.
QinQ
CRS-1: The first switch on the edge of the service provider network has to properly identify traffic from the customer VLAN ID on port and assign a new service VLAN ID with ingress VLAN translation rules. VLAN trunk port configuration for service provider VLAN tags is in the same egress-vlan-tag table. The main difference from basic Port-Based VLAN configuration is that the CRS switch-chip has to be set to do forwarding according to service (outer) VLAN ID instead of customer (inner) VLAN ID.
/interface/bridge
add name=bridge1
add bridge=bridge1 interface=ether1 hw=yes
add bridge=bridge1 interface=ether9 hw=yes
add customer-vid=200 new-service-vid=400 ports=ether1
add customer-vid=300 new-service-vid=500 ports=ether2
add tagged-ports=ether9 vlan-id=400
add tagged-ports=ether9 vlan-id=500
set bridge-type=service-vid-used-as-lookup-vid
CRS-2: The second switch in the service provider network requires only switched ports to do forwarding according to the service (outer) VLAN ID instead of the customer (inner) VLAN ID.
/interface/bridge
add name=bridge1
add bridge=bridge1 interface=ether10 hw=yes
CRS-3: The third switch has a similar configuration to CRS-1:
  • Ports in a switch group using a bridge.
  • Ingress VLAN translation rules to define new service VLAN assignments on ports.
  • tagged-ports for service provider VLAN trunks.
  • CRS switch-chip set to use service VLAN ID in switching lookup.
/interface/bridge
add name=bridge1
add customer-vid=200 new-service-vid=400 ports=ether3
add customer-vid=300 new-service-vid=500 ports=ether4
add tagged-ports=ether10 vlan-id=400
add tagged-ports=ether10 vlan-id=500
CVID Stacking
It is possible to use CRS1xx/CRS2xx series switches for CVID Stacking setups. CRS1xx/CRS2xx series switches are capable of VLAN filtering based on the outer tag of tagged packets that have two CVID tags (double CVID tag). These switches are also capable of adding another CVID tag on top of an existing CVID tag (CVID Stacking). For example, in a setup where ether1 is receiving tagged packets with CVID 10, but it is required that ether2 sends out these packets with another tag CVID 20 (VLAN10 inside VLAN20) while filtering out any other VLANs, the following must be configured:
Switch together ether1 and ether2:
/interface/bridge
add name=bridge1
Set the switch to filter VLANs based on the service tag (0x88a8):
Add a service tag SVID 20 to packets that have a CVID 10 tag on ether1:
add customer-vid=10 new-service-vid=20 ports=ether1
Specify ether2 as the tagged/trunk port for SVID 20:
Allow ether1 and ether2 to forward SVID 20:
add ports=ether1,ether2 vlan-id=20
Override the SVID EtherType (0x88a8) to CVID EtherType (0x8100) on ether2:
set ether2 egress-service-tpid-override=0x8100 ingress-service-tpid-override=0x8100
Enable unknown/invalid VLAN filtering:
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1,ether2
warning
Since the switch is set to look up VLAN ID based on the service tag, which is overridden with a different EtherType, VLAN filtering is only done on the outer tag of a packet; the inner tag is not checked.
Mirroring
Mirroring
The Cloud Router Switches support three types of mirroring. Port-based mirroring can be applied to any switch-chip ports, VLAN-based mirroring works for all specified VLANs regardless of switch-chip ports, and MAC-based mirroring copies traffic sent or received from a specific device reachable from the port configured in the Unicast Forwarding Database.
Port-Based Mirroring
The first configuration sets the ether5 port as a mirror0 analyzer port for both ingress and egress mirroring. Mirrored traffic will be sent to this port. Port-based ingress and egress mirroring are enabled from the ether6 port.
set ingress-mirror0=ether5 egress-mirror0=ether5
set ether6 ingress-mirror-to=mirror0 egress-mirror-to=mirror0
VLAN Based Mirroring
The second example requires ports to be switched in a group. Mirroring configuration sets the ether5 port as a mirror0 analyzer port and sets the mirror0 port to be used when mirroring from VLAN occurs. VLAN table entry enables mirroring only for VLAN 300 traffic between ether2 and ether7 ports.
/interface/bridge
add name=bridge1
set ingress-mirror0=ether5 vlan-uses=mirror0
add ports=ether2,ether7 vlan-id=300 learn=yes ingress-mirror=yes
MAC Based Mirroring
The third configuration also requires ports to be switched as a group. Mirroring configuration sets the ether5 port as a mirror0 analyzer port and sets the mirror0 port to be used when mirroring from the Unicast Forwarding database occurs. The entry from the Unicast Forwarding database enables mirroring for packets with source or destination MAC address E7:16:34:A1:CD:18 from ether8 port.
/interface/bridge
add name=bridge1
set ingress-mirror0=ether5 fdb-uses=mirror0
add port=ether8 mirror=yes svl=yes mac-address=E7:16:34:A1:CD:18
Trunking
Trunking 3
Trunking in the Cloud Router Switches provides static link aggregation groups with hardware automatic failover and load balancing. The IEEE802.3ad and IEEE802.1ax compatible Link Aggregation Control Protocol is not supported yet. Up to 8 Trunk groups are supported with up to 8 Trunk member ports per Trunk group.
Configuration requires a group of switched ports and an entry in the Trunk table:
/interface/bridge
add name=bridge1 protocol-mode=none
/interface/ethernet/switch/trunk
add name=trunk1 member-ports=ether6,ether7,ether8
This example also shows proper bonding configuration in RouterOS on the other end:
/interface/bonding
add name=bonding1 slaves=ether2,ether3,ether4 mode=balance-xor transmit-hash-policy=layer-2-and-3
danger
Bridge (R)STP is not aware of the underlying switch trunking configuration and some trunk ports can move to a discarding or blocking state. When trunking member ports are connected to other bridges, you should either disable the (R)STP or filter out any BPDU between trunked devices (e.g. with ACL rules).
Limited MAC Access per Port
Disabling MAC learning and configuring static MAC addresses gives the ability to control what exact devices can communicate with CRS1xx/2xx switches and through them.
Configuration requires a group of switched ports, disabled MAC learning on those ports, and static FDB entries:
/interface/bridge
add name=bridge1
add bridge=bridge1 interface=ether6 hw=yes learn=no unknown-unicast-flood=no
add bridge=bridge1 interface=ether7 hw=yes learn=no unknown-unicast-flood=no
add mac-address=4C:5E:0C:00:00:01 port=ether6 svl=yes
add mac-address=D4:CA:6D:00:00:02 port=ether7 svl=yes
/interface/ethernet/switch/acl
add action=drop src-mac-addr-state=sa-not-found src-ports=ether6,ether7 table=egress
add action=drop src-mac-addr-state=static-station-move src-ports=ether6,ether7 table=egress
CRS1xx/2xx switches also allow learning one dynamic MAC per port to ensure only one end-user device is connected no matter its MAC address:
set ether6 learn-limit=1
set ether7 learn-limit=1
Isolation
Port Level Isolation
Port-level isolation is often used for Private VLAN, where:
  • One or multiple uplink ports are shared among all users for accessing the gateway or router.
  • Port group Isolated Ports is for guest users. Communication is through the uplink ports only.
  • Port group Community 0 is for department A. Communication is allowed between the group members and through uplink ports.
  • Port group Community X is for department X. Communication is allowed between the group members and through uplink ports.
The Cloud Router Switches use port-level isolation profiles for Private VLAN implementation:
  • Uplink ports – port-level isolation profile 0
  • Isolated ports – port-level isolation profile 1
  • Community 0 ports - port-level isolation profile 2
  • Community X (X <= 30) ports - port-level isolation profile X
This example requires a group of switched ports. Assume that all ports used in this example are in one switch group.
/interface/bridge
add name=bridge1
The first part of port isolation configuration is setting the Uplink port – set a port profile to 0 for ether2:
set ether2 isolation-leakage-profile-override=0
Then continue with setting isolation profile 1 on all isolated ports and adding the communication port for port isolation profile 1:
set ether5 isolation-leakage-profile-override=1
set ether6 isolation-leakage-profile-override=1
/interface/ethernet/switch/port-isolation
add port-profile=1 ports=ether2 type=dst
Configuration to set Community 2 and Community 3 ports is similar:
set ether7 isolation-leakage-profile-override=2
set ether8 isolation-leakage-profile-override=2
add port-profile=2 ports=ether2,ether7,ether8 type=dst
set ether9 isolation-leakage-profile-override=3
set ether10 isolation-leakage-profile-override=3
add port-profile=3 ports=ether2,ether9,ether10 type=dst
Protocol Level Isolation
Protocol level isolation on CRS switches can be used to enhance network security. For example, restricting DHCP traffic between the users (ether2, ether3, ether4, ether5) and allowing it only to trusted DHCP server ports (ether1) can prevent security risks like DHCP spoofing attacks. The following example shows how to configure it on CRS.
/interface/bridge
add name=bridge1
Set the same Community port profile for all DHCP client ports. Community port profile numbers are from 2 to 30.
set ether2 isolation-leakage-profile-override=2
set ether3 isolation-leakage-profile-override=2
set ether4 isolation-leakage-profile-override=2
set ether5 isolation-leakage-profile-override=2
And configure port isolation/leakage profile for selected Community (2) to allow DHCP traffic destined only to the port where the trusted DHCP server is located. Registration status and traffic-type properties have to be set empty to apply restrictions only for DHCP protocol.
add port-profile=2 protocol-type=dhcpv4 type=dst forwarding-type=bridged ports=ether1 registration-status="" traffic-type=""
Quality of Service (QoS)
QoS configuration schemes
MAC-based traffic scheduling and shaping: [MAC address in UFDB] -> [QoS Group] -> [Priority] -> [Queue] -> [Shaper]
VLAN based traffic scheduling and shaping: [VLAN id in VLAN table] -> [QoS Group] -> [Priority] -> [Queue] -> [Shaper]
Protocol based traffic scheduling and shaping: [Protocol in Protocol VLAN table] -> [QoS Group] -> [Priority] -> [Queue] -> [Shaper]
PCP/DEI based traffic scheduling and shaping: [Switch port PCP/DEI mapping] -> [Priority] -> [Queue] -> [Shaper]
DSCP based traffic scheduling and shaping: [QoS DSCP mapping] -> [Priority] -> [Queue] -> [Shaper]
MAC-based traffic scheduling using internal Priority
In Strict Priority scheduling mode, the highest priority queue is served first. The queue number represents the priority, and the queue with the highest queue number has the highest priority. Traffic is transmitted from the highest priority queue until the queue is empty, and then moves to the next highest priority queue, and so on. If no congestion is present at the egress port, a packet is transmitted as soon as it is received. If congestion occurs in the port where high-priority traffic keeps coming, the lower-priority queues starve.
On all CRS switches, the scheme where MAC-based egress traffic scheduling is done according to internal Priority would be the following: [MAC address] -> [QoS Group] -> [Priority] -> [Queue];
In this example, host1 (E7:16:34:00:00:01) and host2 (E7:16:34:00:00:02) will have higher priority 1 and the rest of the hosts will have lower priority 0 for transmitted traffic on port ether7. Note that CRS has a maximum of 8 queues per port.
/interface/bridge
add name=bridge1
Create a QoS group for use in UFDB:
/interface/ethernet/switch/qos-group
add name=group1 priority=1
Add UFDB entries to match specific MACs on ether7 and apply the QoS group1:
add mac-address=E7:16:34:00:00:01 port=ether7 qos-group=group1 svl=yes
add mac-address=E7:16:34:00:00:02 port=ether7 qos-group=group1 svl=yes
Configure ether7 port queues to work according to Strict Priority and QoS scheme only for the destination address:
set ether7 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0" priority-to-queue=0:0,1:1 qos-scheme-precedence=da-based
MAC-based traffic shaping using internal Priority
The scheme where MAC-based traffic shaping is done according to internal Priority would be as follows: [MAC address] -> [QoS Group] -> [Priority] -> [Queue] -> [Shaper];
In this example, unlimited traffic will have priority 0 and limited traffic will have priority 1 with a bandwidth limit of 10Mbit. Note that CRS has a maximum of 8 queues per port.
Create a group of ports for switching:
/interface/bridge
add name=bridge1
Add a UFDB entry to match a specific MAC on ether8 and apply QoS group1:
add mac-address=E7:16:34:A1:CD:18 port=ether8 qos-group=group1 svl=yes
Configure ether8 port queues to work according to Strict Priority and QoS scheme only for the destination address:
set ether8 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0" priority-to-queue=0:0,1:1 qos-scheme-precedence=da-based
Apply bandwidth limit for queue1 on ether8:
/interface/ethernet/switch/shaper
add port=ether8 rate=10M target=queue1
If the CRS switch supports Access Control Lists, this configuration is simpler:
/interface/ethernet/switch/acl/policer
add name=policer1 yellow-burst=100k yellow-rate=10M
add mac-dst-address=E7:16:34:A1:CD:18 policer=policer1
VLAN-based traffic scheduling + shaping using internal Priorities
The best practice is to assign lower internal QoS Priority for traffic limited by shaper to also make it less important in the Strict Priority scheduler. (Higher priority should be more important and unlimited)
In this example:
Switch port ether6 is using a shaper to limit the traffic that comes from ether7 and ether8.
When the link has reached its capacity, the traffic with the highest priority will be sent out first.
VLAN10 -> QoS group0 = lowest priority
VLAN20 -> QoS group1 = normal priority
VLAN30 -> QoS group2 = highest priority
/interface/bridge
add name=bridge1
Create QoS groups for use in the VLAN table.
add name=group0 priority=0
add name=group2 priority=2
Add VLAN entries to apply QoS groups for certain VLANs.
add ports=ether6,ether7,ether8 qos-group=group0 vlan-id=10
add ports=ether6,ether7,ether8 qos-group=group1 vlan-id=20
add ports=ether6,ether7,ether8 qos-group=group2 vlan-id=30
Configure ether6, ether7, and ether8 port queues to work according to Strict Priority and QoS schemes only for VLAN-based QoS.
set ether6 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0" priority-to-queue=0:0,1:1,2:2 qos-scheme-precedence=vlan-based
set ether7 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0" priority-to-queue=0:0,1:1,2:2 qos-scheme-precedence=vlan-based
set ether8 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0" priority-to-queue=0:0,1:1,2:2 qos-scheme-precedence=vlan-based
Apply a bandwidth limit on ether6.
add port=ether6 rate=10M
PCP-based traffic scheduling
By default, CRS1xx/CRS2xx series devices will ignore the PCP/CoS/802.1p value and forward packets in a FIFO (First-In-First-Out) manner. When the device's internal queue is not full, then packets are sent in a FIFO manner, but as soon as a queue is filled, then higher-priority traffic can be sent out first. Let us consider a scenario where ether1 and ether2 are forwarding data to ether3, but when ether3 is congested, then packets are going to be scheduled. We can configure the switch to hold the lowest priority packets until all higher priority packets are sent out. This is a very common scenario for VoIP type setups, where some traffic needs to be prioritized.
To achieve such a behavior, switch together ether1, ether2, and ether3 ports:
/interface/bridge
add name=bridge1
Enable Strict Policy for each internal queue on each port:
set ether1,ether2,ether3 per-queue-scheduling="strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0,strict-priority:0"
Map each PCP value to an internal priority value, for convenience reasons, simply map PCP to an internal priority 1-to-1:
set ether1,ether2,ether3 pcp-based-qos-priority-mapping=0:0,1:1,2:2,3:3,4:4,5:5,6:6,7:7
Since the switch will empty the largest queue first and you need the highest priority to be served first, you can assign this internal priority to a queue 1-to-1:
set ether1,ether2,ether3 priority-to-queue=0:0,1:1,2:2,3:3,4:4,5:5,6:6,7:7
Finally, set each switch port to schedule packets based on the PCP value:
set ether1,ether2,ether3 qos-scheme-precedence=pcp-based
Bandwidth Limiting
Both Ingress Port policer and Shaper provide bandwidth-limiting features for CRS switches.
  • Ingress Port Policer sets RX limit on port:
/interface/ethernet/switch/ingress-port-policer
add port=ether5 meter-unit=bit rate=10M
  • Shaper sets TX limit on a port.
Traffic Storm Control
The same Ingress Port policer also can be used for traffic storm control to prevent disruptions on Layer 2 ports caused by broadcast, multicast, or unicast traffic storms.
  • Broadcast storm control example on the ether5 port with a 500 packet limit per second:
add port=ether5 rate=500 meter-unit=packet packet-types=broadcast
  • Example with multiple packet types which include ARP and ND protocols and unregistered multicast traffic. Unregistered multicast is traffic that is not defined in the Multicast Forwarding Database.
add port=ether5 rate=5k meter-unit=packet packet-types=broadcast,arp-or-nd,unregistered-multicast
See also
