Skip to main content
Version: current
Route Selection and Filtering
Route Filtering
Filter Syntax
Routing filter rules use script-like syntax. The following example matches prefixes from subnet 192.168.1.0/24 with a prefix length greater than 24 and increments the default distance by 1. If there is no match, it subtracts the default distance by one.
/routing/filter/rule
add chain=myChain \
rule="if (dst in 192.168.1.0/24 && dst-len>24) {set distance +1; accept} else {set distance -1; accept}"
A filter rule may consist of multiple matchers and actions:
if ( [matchers] ) { [actions] } else { [actions] }
There are two types of properties:
  • Only readable — properties whose values are read-only and cannot be rewritten. They can be used only by matchers.
  • Readable/writable — properties whose values are readable and writable. They can be used by filter actions and by matchers.
For numeric properties only, readable properties can be matched by other readable properties or by constant values with boolean operators.
[matchers]:
[prop readable] [bool operator] [prop readable]
[actions]:
[action] [prop writeable] [value]
You do not need a boolean operator if the matcher has only one possible operation.
Example without a boolean operator:
if ( protocol connected ) { accept }
Example with boolean operator:
if ( bgp-med < 30 ) { accept }
With readable flag properties, the matcher does not require a boolean operator or a value.
if ( ospf-dn ) { reject }
info
The default action of the routing filter chain is reject.
Only Readable Properties
PropertyTypeDescription
Numeric properties
dst-lenDestination prefix length
bgp-path-lenThe current length of the BGP AS-PATH
bgp-input-local-asAS number of the local peer to which the prefix was sent
bgp-input-remote-asAS number of the remote peer from which the prefix was received
bgp-output-local-asAS number of the peer that will advertise the prefix
bgp-output-remote-asAS number of the peer to which the prefix will be advertised
ospf-metricCurrent OSPF metric
ospf-tagCurrent OSPF tag
rip-metricCurrent RIP metric
rip-tagCurrent RIP tag
Flag properties
activeindicates whether the route is active
bgp-atomic-aggregate
bgp-communities-emptyindicates if the BGP Communities attribute is empty
bgp-ext-communities-emptyindicates if the BGP Extended Communities attribute is empty
bgp-large-communities-emptyindicates if the BGP Large Communities attribute is empty
bgp-networkIndicates if the prefix is originated from BGP networks
ospf-dnIndicates if the OSPF route has the DN bit set.
Prefix properties
dstDestination
ospf-fwdCurrent OSPF forwarding address
bgp-input-local-addrThe IP address of the local peer to which the prefix was sent
bgp-input-remote-addrThe IP address of the remote peer from which the prefix was received
bgp-output-local-addrThe IP address of the peer that will advertise the prefix
bgp-output-remote-addrThe IP address of the peer to which the prefix will be advertised
Other Properties
afiipv4 | ipv6 | l2vpn | l2vpn-cisco | vpnv4 | vpnv6The address family of the route.
bgp-as-pathnumeric_regexpAS path regexp matching
bgp-as-path-slow-legacystring_regexpDeprecated. Extremely slow old-style AS path matching. This parameter should be used only as a temporary matcher while migrating from an old ROS v6 config. Read more>>
chainchain_name
originstringMatch route's origin instance, for example, it can match routes imported from a specific OSPF instance: if (origin <instance_name>) {}
ospf-typeext1 | ext2 | inter | intra | nssa1 | nssa2Type of the OSPF route:
  • ext1 - external (Type 5 LSA) with type1 metric
  • ext2 - external (Type 5 LSA) with type2 metric
  • inter - inter-area-route (Type 3 LSA)
  • intra - intra-area-route (Type 4 LSA)
  • nssa1 - Type 7 LSA with type1 metric
  • nssa2 - Type 7 LSA with type1 metric
protocolbgp | connected | dhcp | fantasy | modem | ospf | rip | static | slaac | vpnProtocol type from which the route was imported.
rpkiinvalid | unknown | valid | unverifiedRPKI validation status of the prefix
rtabrouting_table_nameName of the routing table the route was imported from
vrfvrf_nameName of the VRF the route was imported from
Writeable Properties
Numeric properties
distanceroute distance
scope
scope-targettarget scope
bgp-weightBGP WEIGHT attribute
bgp-medBGP MED attribute is local to the router. It is also used in the output of iBGP peers.
bgp-out-medBGP MED attribute to be sent to a remote peer. Should be used in the output chain of eBGP peers.
bgp-local-prefBGP LOCALPREF attribute
bgp-igp-metricBGP IGP METRIC
bgp-path-peer-prependPrepend last received remote peer's ASN. If the prefix is originated from the router, then this parameter will not do anything on the router's output, because ASN does not exist yet.
If used as a matcher in BGP input, it is possible to filter prefixes exceeding a certain number of prepends. For example, if a remote peer prepends its ASN 5 times, but we want to allow max 4 times prepended ASN, then we can use: if (bgp-path-peer-prepend > 4) {reject}
This parameter also overrides any prepends received from the remote peer, for example, if the remote peer prepended its AS 3 times, we can remove this prepend by setting bgp-path-peer-prepend 1 in BGP input
bgp-path-prependPrepend router's ASN, should be used in BGP output.
ospf-ext-metricOSPF External route metric
ospf-ext-tagOSPF external route tag
rip-ext-metricRIP External route metric
rip-ext-tagRIP External route tag
Flag properties
ospf-ext-dnDN bit for external OSPF routes
blackholeBlackhole route
suppress-hw-offloadWhether to suppress L3 HW offloading
use-te-nexthop
Other properties
gwipv4/6 addressIPv4/IPv6 address or interface name. In the case of BGP output, a gateway can be adjusted in the following setups:
  • is a BGP reflector
  • nexthop-choice is set to propagate
  • is not eBGP and nexthop-choice=force-self is not set.
gw-llipv6 addressipv6 link local nexthop attribute. In the case of BGP output, a gateway can be adjusted in the following setups:
gw-interfaceinterface_nameThe interface part of the gateway. Should be used if it is required to attach a specific interface for next-hop, like (1.2.3.4%ether1)
gw-checknone | arp | icmp | bfd | bfd-mh
pref-srcipv4/6 address
bgp-originigp | egp | incomplete
ospf-ext-fwdipv4/6 addressForwarding address of External OSPF route
ospf-ext-typetype1 | type2OSPF External route type
commentstring
bgp-communitiesinline_community_set | community_list_nameBGP Communities attribute is defined in RFC 1997. Each community is 32-bit in size.
bgp-ext-communitiesinline_ext_community_set | ext_community_list_nameBGP Extended Communities attribute is defined in RFC 4360. RouterOS parses site-of-origin (prefixed with soo:) and route-target (prefixed with rt:) extended communities.
For example,
set bgp-ext-communities rt:1111:2.3.4.5;
It is possible to set/match RAW extended community value in 64-bit hex, for example,
set bgp-ext-community 0x.........;
bgp-large-communitiesinline_large_community_set | large_community_list_nameBGP Large Communities attribute is defined in RFC 8092. Suitable for use with all ASNs including 32-bit ASNs. Each community is 12-bytes in length and consists of 3 parts: global_admin:locap_part_1:local_part_2.
Commands
CommandParamsDescription
acceptaccept matched prefix and stop processing the chain.
rejectreject matched prefix and stop processing the chain, the prefix will be stored in the memory as "filtered" and will not be a candidate to be selected as the best path.
returnreturn to the parent chain
jumpjump chain_namejump to a specified chain
unsetunset prop_nameused to unset the value of the following properties: pref-src, bgp-med, bgp-out-med, bgp-local-pref
appendappend at the end of the list or string. Following property values can be appended: bgp-communities, bgp-ext-communities, bgp-large-communities, comment
filterInverse of the delete action (Delete everything except the specified values). Values of the following properties can be filtered: bgp-communities, bgp-ext-communities, bgp-large-communities
deleteDelete the value of the specified property. Values of the following properties can be deleted: bgp-communities, bgp-ext-communities, bgp-large-communities
setprop_writeable valueThe command is used to set a new value to writeable properties. Value can be set from other readable properties of matching types. For numeric properties, it is possible to prefix the value with +/- which will increment or decrement the current property value by a given amount. For example, set bgp-local-ref +1 will increment the current LOCAL_PREF by one, or extract the value from another readable num property, set distance +ospf-ext-metric
rpki-verifyrpki_group_nameEnable RPKI verification in the current chain from the specified RPKI group.
Operators
Matcher Operators
OperatorDescriptionExample
&&Logical AND operatorif (dst in 192.168.0.0/16 && dst-len in 16-32) {reject;}
||Logical OR operatorif (dst in 192.168.0.0/16 || dst-len in 16-32) {reject;}
notLogical NOT operatorif (not bgp-network) {reject; }
Num Prop Operators
OperatorDescription
inreturns true if the value is in the provided numeric range. Numeric range can be written in the following formats: {int..int}, {int-int}
==returns true if numeric values are equal
!=returns true if numeric values are not equal
>returns true if the left numeric value is greater than the right numeric value
<returns true if the left numeric value is less than the right numeric value
>=returns true if the left numeric value is greater than or equal to the right numeric value
<=returns true if the left numeric value is less than or equal to the right numeric value
Prefix Operators
OperatorDescription
inReturns true if the prefix is the subnet of the provided network. If an operator is used to match prefixes from the address list (e.g dst in list_name), then it will match only the exact prefix.
!=Returns true if the prefix is not equal to the provided value
==Returns true if the prefix is equal to the provided value
info
Address lists by design are matching host addresses which means that it will match also /32 prefix that belongs to any range from the address list. The workaround to exclude /32 prefixes from being advertised is to use dst-len if (dst in list_name && dst-len < 32) {}
BGP Community Operators
equalreturns true if the provided communities are equal to the route's property value
equal-listreturns true if communities from the provided community-list are equal to the route's property value
anyreturns true if the route's property value contains at least one of the provided communities
any-listreturns true if the route's property value contains at least one community from the provided list
includesreturns true if the route's property value includes specified communities
includes-listreturns true if the route's property value includes all communities from the specified communities-list
subsetreturns true if the route's community subset matches communities from the list1:1,3:3 will match 1:1,2:2,3:3
subset-listthe same as subset, but matches communities from the community list.
any-regexpthe same as any, but matched by regexp
subset-regexpthe same as subset, but matched by regexp
String Operators
OperatorDescription
findCheck if the provided substring is part of the property value
regexpMatch the string regexp of the property value
Deleting BGP Communities
Routing filters allow clearing BGP communities by using the delete command. The delete command accepts several parameters based on the type of community:
  • communities:
    • wk - Will match and remove well-known communities.
    • other - Will match and remove other communities that are not well known.
    • regexp - regexp pattern to match communities that should be deleted.
    • <community-list name> - Deletes communities from specified community-list.
  • ext-communities:
    • rt - Will match and remove RouteTarget.
    • soo - Will match and remove Site-of-Origin.
    • other - Will match and remove other ext communities that are not RT or SOO.
    • regexp - regexp pattern to match ext communities that should be deleted.
    • <community-ext-list name> - Deletes communities from specified community-ext-list.
  • large-communities:
    • all - Removes everything.
    • regexp - regexp pattern to match large communities that should be deleted.
    • <community-large-list name> - Deletes large communities from specified community-large-list.
It is possible to specify multiple community types, for example delete all SOOs, other types of ext communities and specific RTs from the community-ext list:
/routing/filter/community-ext-list
add list=myRTList communities="rt:1.1.1.1:222"
add chain=myChain rule="delete bgp-ext-communities sso,other,myRTList;"
AS-PATH Regexp Matching
An AS path is the sequence of autonomous system numbers (ASNs). For example, the AS path 123 456 789 means the route originated from AS 789 and traversed AS 456 before reaching the destination. To apply routing policies, match specific AS numbers or sets of AS numbers in the AS path by using a regular expression (regexp).
There are two common ways to work with AS path data:
  • Convert the whole AS path to a string and let regexp operate on the string (ROS v6 or Cisco style).
  • Let regexp operate on each AS path entry as a number (ROS v7, Juniper style).
The first method matches per character. The second method matches per AS number. The second method is faster and uses fewer resources than the string matching approach.
This change requires administrators to use new regexp strategies. Old regexp patterns from RouterOS v6 cannot be copied and pasted directly because they can cause syntax errors or unexpected results.
Take this basic AS path filter rule:
add chain=myChain rule="if (bgp-as-path .1234.) {accept}"
This regexp pattern matches ASN 1234 anywhere in the middle of the AS path. With old style string matching method, the same pattern matches any AS path that contains an ASN with at least six characters and the substring 1234. An equivalent old style pattern is ._1234_..
For example, the old string style pattern 1234[5-9] matches 12345 through 12349 anywhere in the string. That yields matches such as 12345 3434 and 11 9123467 22. With new style matcher, the same pattern matches an AS path containing the exact ASN 1234 followed by an ASN from 5 to 9, such as 1234 7 111 or 111 1234 5 222. It does not match 12345 3434.
danger
Copying regexp patterns between implementations can produce unexpected or dangerous results.
Do not copy Regex patterns directly from ROS v6 or Cisco configurations, they are not directly compatible. It can lead to unexpected or even dangerous configurations in some scenarios.
info
The AS-Path parameter must exist for the regexp matcher to be applied. This means that it is not possible to match a non-existent (empty) AS-Path with a regular expression, aka ^$. bgp-path-len should be used instead.
Regex Testing Tool
RouterOS has a built-in regexp checking tool to help administrators validate regexps. This tool also supports num-list values so you can test a regexp against any AS path before applying it to routing filters.
/routing/filter/num-list/add list=test range=100-1500
/routing/filter/test-as-path-regexp regexp="[[:test:]]5678\$" as-path="1234,5678"
Supported Operators
OperatorDescriptionExampleExample ExplainedExample Matches
^Represents the beginning of the path^1234will match an AS-path starting with ASN 1234
$Represents the end of the path1234$will match the AS-path of origin ASN 1234
*Zero or more occurrences of the listed ASN^1234*$will match a Null as-path or an as-path where ASN 1234 may or may not appear multiple timesMatch:
1234
1234 1234 1234
Null path
No Match:
1234 5678
+One or more occurrences of the listed ASN1234+will match an AS-path where ASN 1234 appears at least onceMatch:
1234
3 1234 6
No match:
12345 678
?Zero or one occurrence of the listed ASN^1234? 5678will match an AS-path that may or may not start with ASN 1234 appearing once.Match:
5678
1234 5678
No match:
1234 1234 5678
12345 5678
.One occurrence of any ASN^.$will match any AS-path with the length of one.Match:
12345
45678
No match:
1234 5678
|Match one of two ASNs on each side^(1234|5678)will match an AS-path starting with ASN 1234 or 5678Match:
1234
5678
1234 5678
No Match:
91011
Represents the set of AS numbers where one AS number from the list must match.
Use ^ after opening the bracket to negate the set.
It is also possible to reference the pre-defined num-lists from num-list with [[:numset_name:]]
^[1234 5678 1-100]will match the AS-path that starts with 1234 or 5678 or from the range of 1 to 100Match:
1234
99
5678
No Match:
101
()Group of regexp terms to match^(1234$|5678)will match an AS-path that starts and ends with 1234 or an AS-path that starts with 5678Match:
1234
5678 9999
No Match:
1234 5678
warning
Repetition ranges are not supported.
Community and Num Lists
A list of commonly used numbers can be configured from the /routing/filter/num-list menu. These lists of numbers can be used in the filter rules to simplify the filter setup process.
In a similar manner, you are allowed to also define community, extended community, and large community lists. Community sets can be used for matching, appending, and setting.
For example, match communities from the list and clear the attribute:
/routing/filter/community-list
add communities=111:222 list=myCommunityList
add chain=myChain rule="if (bgp-communities equal-list myCommunityList) {delete bgp-communities wk,other; accept;}"
Route Selection
Route selection rules control how output routes are selected from available candidate routes. By default, if no selection rules are set, output selects the best route.
The following routing table shows two candidate routes and one best route. By default, when BGP selects a route to send out, it chooses the active route.
[admin@4] /routing/route> print where dst-address=1.0.0.0/24
Flags: A - ACTIVE; b, y - COPY
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
DST-ADDRESS GATEWAY AFI DISTANCE SCOPE TARGET-SCOPE IMMEDIATE-GW
b 1.0.0.0/24 10.155.101.217 ip4 19 40 30 10.155.109.254%ether1
Ab 1.0.0.0/24 10.155.101.232 ip4 20 40 30 10.155.109.254%ether1
b 1.0.0.0/24 10.155.101.231 ip4 20 40 30 10.155.109.254%ether1
If you need a preference for routes that are not active, use selection rules.
Selection rules in RouterOS are configured from the /routing/filter/select-rule menu.
Select rules can also call routing filters so routes are selected by filter rules. For example, to mimic the default output selection, use this rule set:
add chain=get_active rule="if (active) {accept}"
add chain=my_select_chain do-where=get_active
Select rules can be also used to limit how many additional paths to pick for BGP Add-path, for example max 3 paths:
/routing/filter/select-rule add chain=select-for-addpath do-take=3
Routing Filter Wizard
Because writing filter rules in script-like syntax is more complex, routing filter wizard that generates filter rules with ROSv6-like syntax was introduced.
Quick demonstration:
[admin@CCR2004_2XS_111] /routing/filter> filter-wizard <tab>
action dst ospf-type scope-target set-gw-check use-te-nexthop
afi dst-len protocol set-bgp-... set-scope
bgp-... gateway routing-table set-blackhole set-scope-target
blackhole jump-target-chain rpki set-comment set-suppress-hw-offload
chain match-chain rpki-verify set-distance set-use-te-nexthop
distance ospf-metric scope set-gateway suppress-hw-offload
[admin@CCR2004_2XS_111] /routing/filter> filter-wizard action=accept chain=vpn-in afi=vpnv4 set-bgp-ext-communities=rt:2:2
result: Filter rule 'if (afi vpnv4) { set bgp-ext-communities rt:2:2; accept; }' added
[admin@CCR2004_2XS_111] /routing/filter> /routing/filter/rule/print
Flags: X - disabled, I - inactive
0 ;;; added by filter-wizard
chain=vpn-in rule="if (afi vpnv4) { set bgp-ext-communities rt:2:2; accept; }"
The filter wizard adds rules at the end of the list and gives them the comment added by filter-wizard.
Errors returned when you try to add a filter with unacceptable values are printed in the CLI and logged in the system log with the route,error topic.
[admin@CCR2004_2XS_111] /routing/filter> filter-wizard action=accept chain=vpn-in afi=vpnv4 match-chain=vpn-in
result: Error adding 'if (chain vpn-in && afi vpnv4) { accept; }'match with 'vpn-in' creates chain loop (6)
[admin@CCR2004_2XS_111] /routing/filter> /log/print
2025-05-19 13:05:15 route,error Error adding 'if (chain vpn-in && afi vpnv4) { accept; }'match with 'vpn-in' creates chain loop (6)
