Moving from ROSv6 to ROSv7
By default, all routes are added to the "main" routing table as it was before. From a configuration point of view, the biggest differences are routing table limit increase, routing table monitoring differences, and how routes are added to specific routing tables (see next example).
V7 introduces a new menu /routing/route, which shows all address family routes as well as all filtered routes with all possible route attributes. /ip/route and /ipv6/route menus are used to add static routes and for simplicity show only basic route attributes.
For more in-depth information on routing see this article (IP Routing.
Another new change is that the most common route print requests are processed by the routing process which significantly improves the speed compared to v6.
Use of Routing Tables and Policy Routing
The main difference from v6 is that the routing table must be added to the /routing/table menu before actually referencing it anywhere in the configuration. And the fib parameter should be specified if the routing table is intended to push routes to the FIB.
The routing rule configuration is the same except for the menu location (instead of /ip route rule, now it is /routing/rule).
Let's consider a basic example where we want to resolve 8.8.8.8 only in the routing table named myTable to the gateway 172.16.1.1:
/routing/table/add name=myTable fib
/routing/rule/add dst-address=8.8.8.8 action=lookup-only-in-table table=myTable
/ip/route/add dst-address=8.8.8.8 gateway=172.16.1.1@main routing-table=myTable
Instead of routing rules, you could use mangle to mark packets with routing-mark, the same way as it was in ROSv6.
When you are using mangle to set routing-marks, be careful not to mark "local" traffic. If your rule is also marking local traffic, then the router's ip addresses will not be reachable because, by default, mangle is the first in the list and overrides local lookup:
[admin@CCR2004_2XS_111] /routing/rule> print
Flags: X - disabled, I - inactive; * - default
0 * action=
1 * action=lookup vrf
2 * action=unreachable vrf
3 * action=lookup table=local
4 * action=lookup table=main
For example, a basic multiwan setup:
/ip/address
add address=192.168.1.1/24 interface=LAN
add address=1.1.1.2/24 interface=WAN1
add address=2.2.2.2/24 interface=WAN2
/ip/route
add gateway=1.1.1.1@main routing-table=myTable
add gateway=2.2.2.2
/ip/firewall/mangle/add in-interface=LAN action=mark-routing new-routing-mark=myTable
A packet coming from LAN interface with destination address 192.168.1.1 will be marked by a mangle rule and processed by the "myTable" routing table. In that table the only route to reach 192.168.1.1 is via the default route, which means that the packet will be forwarded to the 1.1.1.1 gateway.
There are two options to fix the problem:
- Exclude local from being marked by adding to mangle rule:
!dst-address-type=local. - In
/routing/rulemenu move first rule (action=mangle) below (action=lookup table=local).
Which approach to use depends on the complexity of the setup.
Nexhop lookup
Consider an example from v6:
/ip/route/add dst-address=10.0.1.0/24 gateway=10.0.0.1
scope=50 target-scope=30 comment=A
/ip/route/add dst-address=10.0.2.0/24 gateway=10.0.0.1
scope=30 target-scope=20 comment=B
/ip/route/add dst-address=10.0.0.0/24 scope=20 gateway=WHATEVER
comment=C
Gateway 10.0.0.1 is recursively resolved through C using the smallest referring scope (scope 20 from route B), and both routes are active. Now we change both A and B at the same time:
/ip/route/set A target-scope=10
Suddenly, applying an update to route A makes the gateway of route B inactive. This is because in v6 there is only one gateway object per address.
v7 keeps multiple gateway objects per address, one for each combination of scope and gateway check.
When target-scope or gateway check of a route is changed, ROS v7 will not affect other routes, as it does in v6. In v7 target-scope and gateway check are properties that are internally attached to the gateway, not to the route.
OSPF Configuration
OSPFv3 and OSPFv2 are now merged into one single menu /routing/ospf. At the time of writing this article, there are no default instances and areas.
To start both OSPFv2 and OSPF v3 instances, first, you need to create an instance for each and then add an area to each instance.
/routing/ospf/instance
add name=v2inst version=2 router-id=1.2.3.4
add name=v3inst version=3 router-id=1.2.3.4
/routing/ospf/area
add name=backbone_v2 area-id=0.0.0.0 instance=v2inst
add name=backbone_v3 area-id=0.0.0.0 instance=v3inst
At this point, you are ready to start OSPF on the network interface. In the case of IPv6, you add either an interface on which you want to run OSPF (the same as ROSv6) or the IPv6 network. In the second case, OSPF will automatically detect the interface. Here are some interface configuration examples:
/routing/ospf/interface-template
add network=192.168.0.0/24 area=backbone_v2
add network=2001:db8::/64 area=backbone_v3
add network=ether1 area=backbone_v3
ROSv7 uses templates to match the interface against the template and apply configuration from the matched template. OSPF menus interface and neighbor contain read-only entries purely for status monitoring.
RouteOS allows to control redistribution of routes directly by routing filters, wthout the need of redistribute parameter. This gives greater flexibility on what routes from which protocols you want to redistribute.
For example, let's say you want to redistribute only static IPv4 routes from the 192.168.0.0/16 network range.
Option 1:
set backbone_v2 out-filter-chain=ospf_out redistribute=static
/routing/filter/rule/add chain=ospf_out rule="if (dst in 192.168.0.0/16) {accept}"
Option 2:
/routing/filter/rule/add chain=ospf_out rule="if (protocol static && dst in 192.168.0.0/16) {accept}"
The default action of the routing filter chain is "reject"
BGP Configuration
There is a complete redesign of the BGP configuration compared to ROSv6. The first and biggest difference is that there are no more instance and peer configuration menus. Instead, we have connection, template and session menus.
The reason for such a structure is to strictly split parameters that are responsible for connection and parameters that are BGP protocol specific.
Let's start with the Template. It contains all BGP protocol-related configuration options. It can be used as a template for dynamic peers and to apply a similar config to a group of peers. Note that this is not the same as peer groups on Cisco devices, where the group is more than just a common configuration.
By default, there is a default template that requires you to set your own AS.
/routing/bgp/template/set default as=65533
Starting from v7.1beta4, template parameters are exposed in the "connection" configuration. This means that the template is not mandatory anymore, allowing for an easier basic BGP connection setup, similar to what it was in ROSv6.
Most of the parameters are similar to ROSv6 except that some are grouped in the output and input sections making the config more readable and easier to understand whether the option is applied on input or output. If you are familiar with CapsMan, then the syntax is the same, for example, to specify the output selection chain you set output.filter-chain=myBgpChain.
You can even inherit template parameters from another template, for example:
add name=myAsTemplate as=65500 output.filter-chain=myAsFilter
set default template=myAsTemplate
Another important aspect of the new routing configuration is the global Router ID, which sets router-id and groups peers in one instance. RouterOS adds a default ID which picks instance-id from any interface's highest IP. The default BGP template by default is set to use the "default" ID.
If for any reason you need to tweak or add new instances, it can be done in the /routing/id menu.
Very interesting parameters are input.``affinity and output.affinity; they allow control over which process input and output of the active session will be processed:
- alone - input and output of each session are processed in its own process, most likely the best option when there are a lot of cores and a lot of peers.
- afi, instance, vrf, remote-as - Try to run input/output of a new session in a process with similar parameters.
- main - Run input/output in the main process (could potentially increase performance on single-core even possibly on multicore devices with a small amount of cores).
- input - Run output in the same process as input (can be set only for output affinity).
Now that we have parameters set for the template we can add BGP connections. A minimal set of parameters is remote.address, template, connect, listen and local.role
Connect and listen parameters specify whether peers will try to connect and listen to a remote address or just connect or just listen. It is possible that in setups where a peer uses the multi-hop connection, local.address must be configured too (as it was with update-source in ROSv6).
It is not mandatory to specify a remote AS number. ROS v7 can determine the remote ASN from an open message. You should specify the remote AS only when you want to accept a connection from that specific AS.
Peer role is now a mandatory parameter. For basic setups, you can just use ibgp, ebgp (more information on available roles can be found in the corresponding RFC draft). Keep in mind that at the moment capabilities, communities, and filtering described in the draft are not implemented.
Very basic iBGP setup to listen on the whole local network for connections:
/routing/bgp/connection
add remote.address=10.155.101.0/24 listen=yes template=default local.role=ibgp
Now you can monitor the status of all connected and disconnected peers from /routing/bgp/session menu.
Other great debugging information on all routing processes can be monitored from the /routing/stats menu
[admin@v7_ccr_bgp] /routing/stats/process> print interval=1
Columns: TASKS, PRIVATE-MEM-BLOCKS, SHARED-MEM-BLOCKS, PSS, RSS, VMS, RETIRED, ID, PID, RPID, PROCESS-TIME, KERNEL-TIME, CUR-B>
# TASKS PRIVATE-M SHARED-ME PSS RSS VMS RET ID PID R PROCESS-TI KERN>
0 routing tables 12.2MiB 20.0MiB 18.7MiB 42.2MiB 83.4MiB 8 main 319 0 19s750ms 8s50>
rib >
connected networks >
1 fib 512.0KiB 0 7.4MiB 30.9MiB 83.4MiB fib 384 1 5s160ms 22s5>
2 ospf 1024.0KiB 1024.0KiB 5.9MiB 25.9MiB 83.4MiB 382 ospf 388 1 1m42s170ms 1m31>
3 fantasy 512.0KiB 0 2061.0KiB 5.9MiB 83.4MiB fantasy 389 1 1s410ms 870m>
4 configuration and reporting 40.0MiB 512.0KiB 45.0MiB 64.8MiB 83.4MiB static 390 1 12s550ms 1s17>
5 rip 768.0KiB 0 5.3MiB 24.7MiB 83.4MiB rip 387 1 1s380ms 1s20>
6 /routing/policy/configuration 512.0KiB 256.0KiB 2189.0KiB 6.0MiB 83.4MiB policy 385 1 1s540ms 1s20>
7 BGP service 768.0KiB 0 2445.0KiB 6.2MiB 83.4MiB bgp 386 1 6s170ms 9s38>
8 BGP Input 10.155.101.217 8.8MiB 6.0MiB 15.6MiB 38.5MiB 83.4MiB 20 21338 1 25s170ms 3s23>
BGP Output 10.155.101.217 >
9 Global memory 256.0KiB global 0 0 >
-- [Q quit|D dump|C-z pause|right]
Route filtering differs a bit from ROSv6. In the BGP template, you can now specify output.filter-chain, output.filter-select, input.filter as well as several input.accept-* options.
Now input.accept-* allows filtering incoming messages directly before they are even parsed and stored in memory, that way significantly reducing memory usage. The regular input filter chain can only reject prefixes, which means that it will still eat memory and will be visible in the /routing/route table as "not active, filtered".
A very basic example of a BGP input filter to accept prefixes from 192.168.0.0/16 subnet without modifying any attributes. For other prefixes subtract 1 from the received local pref value and set IGP metric to value from OSPF ext. Additionally, we will accept only specific prefixes from the address list to reduce memory usage.
/ip/firewall/address-list
add list=bgp_list dst-address=192.168.1.0/24
add list=bgp_list dst-address=192.168.0.0/24
add list=bgp_list dst-address=172.16.0.0/24
set default input.filter=bgp_in .accept-nlri=bgp_list
add chain=bgp_in rule="if (dst in 192.168.0.0/16) {accept}"
add chain=bgp_in rule="set bgp-local-pref -1; set bgp-igp-metric ospf-ext-metric; accept"
If the routing filter chain is not specified, BGP will try to advertise every active route it can find in the routing table
Warning: The default action of the routing filter chain is "drop"
Monitoring Advertisements
RouterOS v7 by default disables monitoring of the BGP output. This allows significantly reducing resource usage on setups with large routing tables.
To be able to see output advertisements several steps should be taken:
- Enable "output.keep-sent-attributes" in the BGP connection configuration.
- Run "dump-saved-advertisements" from the BGP session menu.
- View saved output from the
/routing/stats/pcapmenu.
[admin@arm-bgp] /routing/bgp/connection> set 0 output.keep-sent-attributes=yes
[admin@arm-bgp] /routing/bgp/session> print
Flags: E - established
0 E remote.address=10.155.101.183 .as=444 .id=192.168.44.2 .refused-cap-opt=no .capabilities=mp,rr,gr,as4
.afi=, .messages=4 .bytes=219 .eor=""
local.address=10.155.101.186 .as=456 .id=10.155.255.186 .capabilities=mp,rr,gr,as4 .afi=,
.messages=1 .bytes=19 .eor=""
output.procid=66 .filter-chain=bgp_out .network=bgp-nets .keep-sent-attributes=yes
input.procid=66 ebgp
hold-time=3m keepalive-time=1m uptime=4s30ms
[admin@arm-bgp] /routing/bgp/session> dump-saved-advertisements 0 save-to=test_out.pcap
Networks
Lastly, you might notice that the network menu is missing and are probably wondering how to advertise your own networks. Now networks are added to the firewall address-list and referenced in the BGP configuration.
The following is the ROSv6 network configuration:
/routing bgp add network=192.168.0.0/24 synchronize=yes
/ip add dst-address=192.168.0.0/24 type=blackhole
would translate to v7 as:
add list=bgp-networks address=192.168.0.0/24
/ip/route
add dst-address=192.168.0.0/24 blackhole
set peer_name output.network=bgp-networks
It is also possible to automatically create a blackhole route for each BGP network:
set peer_name output.network-blackhole=yes
There is more configuration to be done when adding just one network, but it offers simplicity when you have to deal with a large number of networks. v7 even allows specifying for each BGP connection its own set of networks.
In v7 it is not possible to turn off synchronization with IGP routes (the network will be advertised only if the corresponding IGP route is present in the routing table).
Routing Filters
Starting from ROSv7.1beta4, the routing filter configuration is changed to a script-like configuration. The rule now can have "if .. then" syntax to set parameters or apply actions based on conditions from the "if" statement.
Multiple rules without action are stacked in a single rule and executed in order like a firewall, the reason is that the "set" parameter order is important and writing one "set" per line allows for an easier understanding from top to bottom on what actions were applied.
For example, matching a static default route and applying action accept can be written in one config rule:
add chain=ospf_in rule="if (dst==0.0.0.0/0 && protocol static) { accept }"
For example, the ROSv6 rule /routing/filter/add chain=ospf_in prefix=172.16.0.0/16 prefix-length=24 protocol=static action=accept converted to ROSv7 would be:
add chain=ospf_in rule="if (dst in 172.16.0.0/16 && dst-len==24 && protocol static) { accept }"
Another example is to match prefixes from the 172.16.0.0/16 range with prefix length equal to 24 and set BGP med and prepend values
add chain=BGP_OUT rule="if (dst-len==24 && dst in 172.16.0.0/16) { \n
set bgp-med 20; set bgp-path-prepend 2; accept }"
It is also possible to match a prefix length range like this
add chain=BGP_OUT rule="if (dst-len>13 && dst-len<31 && dst in 172.16.0.0/16) { accept }"
Filter rules now can be used to match or set communities, large communities, and extended communities from the community list:
add chain=bgp_in rule="set bgp-large-communities 200001:200001:10 "
If there are a lot of community sets that need to be applied in multiple rules, then it is possible to define community sets and use them to match or set:
/routing/filter/large-community-set
add set=myLargeComSet communities=200001:200001:10
add chain=bgp_in rule="append bgp-large-communities myLargeComSet "
Since route-target is encoded in the extended community attribute to change or match RT you need to operate on the extended community attribute, for example:
add chain=bgp_in rule="set bgp-ext-communities rt:327824:20 "
RPKI
RouterOS implements an RTR client. You connect to the server which will send route validity information. This information then can be used to validate routes in route filters against a group with "rpki-validate" and further in filters "match-rpki" can be used to match the exact state.
For more info refer to the RPKI documentation.
RIP Configuration
To start RIP, the instance should be configured. There you should select which routes will be redistributed by RIP and if it will redistribute the default route.
/routing/rip/instance
add name=instance1 originate-default=never redistribute=connected,static
Then the interface-template should be configured. There is no need to define networks in ROS version 7 as it was in version 6.
/routing/rip/interface-template
add interfaces=ether1 instance=instance1
Now the basic configuration is completed on one router. The RIP neighbor router should be configured in a similar way.
In ROS v7 the neighbors will appear only when there are routes to be sent and/or to be received.
Prefix lists from ROSv6 are deprecated, now all the filtering must be done by the routing filters.
