The E-mail tool is a built-in RouterOS utility that enables the router to send e-mail messages directly from the device. It can be used to automate delivery of configuration backups and exports to a network administrator on a scheduled basis.
The E-mail tool supports plain authentication and TLS encryption. No other authentication or encryption methods are supported.
Properties
Sub-menu: /tool/e-mail
This submenu allows setting an SMTP server that will be used.
| Property | Description |
| address (IP/IPv6 address; Default: 0.0.0.0) | SMTP server's IP address. |
| certificate-verification(yes | yes-without-crl | no; Default: no) | Enables trust chain validation from the local certificate store. yes-without-crl validates a certificate, not performing a CRL check (certificate revocation list). |
| from (string; Default: <>) | Name or email address that will be shown as a receiver. |
| password (string; Default: "") sensitive | Password used for authenticating to an SMTP server. |
| port (integer[0..65535]; Default: 25) | SMTP server's port. |
| tls (no|yes|starttls; Default: no) | Whether to use TLS encryption:
| user (string; Default: "") | The username used for authenticating to an SMTP server. |
| vrf (VRF name; default value: main) | Set VRF on which service is creating outgoing connections. |
Note: All server configurations (if specified) can be overridden by send command.
Sending Email
The Send command takes the following parameters:
| body (string; Default: ) | The actual body of the email message |
| cc (string; Default: ) | Send a copy to listed recipients. Multiple addresses allowed, use "," to separate entries |
| certificate-verification(yes | yes-without-crl | no; Default: no) | Enables trust chain validation from the local certificate store. yes-without-crl, validates a certificate, not performing a CRL check (certificate revocation list). |
| file (File[,File]; Default: ) | List of the file names that will be attached to the mail separated by a comma. |
| from (string; Default: ) | Name or email address which will appear as the sender. If not specified, a value from the server's configuration is used. |
| password (string; Default: ) sensitive | Password used to authenticate to an SMTP server. If not specified, a value from the server's configuration is used. |
| port (integer[0..65535]; Default: ) | Port of SMTP server. If not specified, a value from the server's configuration is used. |
| server (IP/IPv6 address; Default: ) | IP or IPv6 address of the SMTP server. If not specified, a value from the server's configuration is used. |
| tls (yes|no|starttls; Default: no) | Whether to use TLS encryption:
| subject (string; Default: ) | The subject of the message. |
| to (string; Default: ) | Destination email address. Single address allowed. |
| user (string; Default: ) | The username used to authenticate to an SMTP server. If not specified, a value from the server's configuration is used. |
Basic examples
This example will show how to send an email with configuration export every 24 hours.
- Configure SMTP server.
[admin@MikroTik] /tool/e-mail> set server=10.1.1.1 port=25 from="router@mydomain.com"
- Add a new script named "export-send":
/export file=
/tool/e-mail/send to="config@mydomain.com" subject="$[/system/identity/get name] export" \
body="$[/system/clock/get date] configuration file" file=.rsc
- Add scheduler to run our script.
/system/scheduler/add on-event="export-send" start-time=00:00:00 interval=24h
Send e-mail to a server using TLS/SSL encryption.
Google Mail does not allow third-party devices to authenticate using a standard Gmail password. An App password must be generated and used instead.
To generate an App password, navigate to Security > How you sign in to Google, enable 2-Step Verification, then generate an App password. Use the generated value in the set password=mypassword setting shown below.
- Configure the client to connect to the correct server.
/tool/e-mail
set address=smtp.gmail.com
set port=465
set tls=yes
set from=myuser@gmail.com
set user=myuser
- Send an e-mail using the send command.
/tool/e-mail/send to=myuser@anotherdomain.com subject="email test" body="email test"
