Skip to main content
Version: current
DDoS Protection
A denial-of-service (DoS) or distributed denial-of-service (DDoS) attack is a malicious attempt to disrupt normal traffic of a targeted server, service, or network by overwhelming the target or its surrounding infrastructure with a flood of Internet traffic. There are several types of DDoS attacks, for example, HTTP flood, SYN flood, DNS amplification, etc.
![](../../../attachments/28606540_Untitled Diagram (1).jpg)
Protection against DDoS
Configuration lines
warning
These rules are only an improvement for the firewall, do not forget to properly secure your device.
/ip/firewall/address-list
add list=ddos-attackers
add list=ddos-targets
/ip/firewall/filter
add chain=forward connection-state=new action=jump jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddos-targets address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers address-list-timeout=10m chain=detect-ddos
/ip/firewall/raw
add action=drop chain=prerouting dst-address-list=ddos-targets src-address-list=ddos-attackers
Configuration Explained
First, we will send every new connection to the specific firewall chain where we will detect DDoS:
/ip/firewall/filter/add chain=forward connection-state=new action=jump jump-target=detect-ddos
In the newly created chain, we will add the following rule with the "dst-limit" parameter. This parameter is written in the following format: dst-limit=****count[/time],burst,mode[/expire]. We will match 32 packets with a 32-packet burst based on destination and source address flow, which renews every 10 seconds. The rule will work until a given rate is exceeded.
/ip/firewall/filter/add chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s action=return
So far all the legitimate traffic should go through the "action=return", but in the case of DoS/DDoS the "dst-limit" buffer will be filled and a rule will not "catch" any new traffic. Here come the next rules, which will deal with the attack. Let's start with creating a list for attackers and victims which we will drop:
/ip/firewall/address-list/add list=ddos-attackers
/ip/firewall/address-list/add list=ddos-targets
/ip/firewall/raw/add chain=prerouting action=drop src-address-list=ddos-attackers dst-address-list=ddos-targets
With the firewall filter section, we will add attackers to the "DDoS-attackers" and victims to the "ddos-targets" list:
/ip/firewall/filter
SYN Attack
SYN Flood
A SYN flood is a form of DoS attack in which an attacker sends a succession of SYN requests to a target's system in an attempt to consume enough server resources to make the system unresponsive to legitimate traffic. Fortunately, in RouterOS we have a specific feature for such an attack:
/ip/settings/set tcp-syncookies=yes
The feature works by sending back ACK packets that contain a little cryptographic hash, which the responding client will echo back with as part of its SYN-ACK packet. If the kernel doesn't see this "cookie" in the reply packet, it will assume the connection is bogus and drop it.
SYN-ACK Flood
A SYN-ACK flood is an attack method that involves sending a target server spoofed SYN-ACK packets at a high rate. The server requires significant resources to process such packets out-of-order (not in accordance with the normal SYN, SYN-ACK, ACK TCP three-way handshake mechanism). It can become so busy handling the attack traffic, that it cannot handle legitimate traffic and hence the attackers achieve a DoS/DDoS condition. In RouterOS, we can configure similar rules from the previously mentioned example, but more specifically for SYN-ACK flood:
/ip/firewall/filter/add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s protocol=tcp tcp-flags=syn,ack
