Wake on LAN
Sub-menu: /tool/wol
Wake on LAN (WoL) is a network feature that sends a UDP Magic Packet to the broadcast address. This packet contains the MAC address of the target device. If the target device supports Wake on LAN (meaning it has the required hardware and software configuration), it will power on from a sleep or shutdown state. Note that secure WoL is currently not supported.
Property Description
| Property | Description |
| interface (string; Default: ) | Interface through which the Magic Packet will be sent |
| mac (MAC; Default: ) | MAC address of a target computer |
Wake-on-LAN Command
The /tool/wol command requires a MAC address parameter and an interface to function properly.
warning
If no interface is specified, the Magic Packet is sent as an IP broadcast from the default gateway interface.
/tool/wol mac=FE:4B:71:05:EA:8B interface=ether1
