Skip to main content
Version: current
Container - Postgres
PostgreSQL is a powerful, widely-used SQL database engine that serves as the backbone for numerous applications, ranging from small web projects to enterprise-level systems. This guide will walk you through the essential steps required to get PostgreSQL up and running on RouterOS. Additionally, this guide will provide you with the necessary instructions to set up pgAdmin—a feature-rich, web-based interface that allows you to easily manage your PostgreSQL database.
Configuration
This section provides step-by-step instructions for setting up a PostgreSQL container on your MikroTik RouterOS device. PostgreSQL is a powerful, open-source relational database system that supports SQL standards and offers advanced features such as transactions, subqueries, and user-defined types. Before proceeding, ensure that you have already created a container network as described in the Container network documentation.
Step 1: Create Mount Point for PostgreSQL Container
Before creating the container, you need to create a persistent storage location where PostgreSQL will store its database files. This ensures that your data persists even if the container is recreated or removed, protecting your valuable database information.
/container/mounts/add list=MOUNT_POSTGRES src=disk1/volumes/postgres/data dst=/var/lib/postgresql/data
This mount point maps your local data directory to the container's /var/lib/postgresql/data path, which is where PostgreSQL will store all database files, transaction logs, and system catalogs.
Step 2: Configure Environment Variables for PostgreSQL Container
Environment variables provide configuration parameters that PostgreSQL requires at startup. These variables define the initial database name, user credentials, and data directory location.
/container/envs/add list=ENV_POSTGRES key=POSTGRES_DB value="myapp"
/container/envs/add list=ENV_POSTGRES key=POSTGRES_PASSWORD value="<changeme>"
/container/envs/add list=ENV_POSTGRES key=POSTGRES_USER value="myapp"
/container/envs/add list=ENV_POSTGRES key=PGDATA value="/var/lib/postgresql/data/pgdata"
/container/envs/add list=ENV_POSTGRES key=POSTGRES_INITDB_ARGS value="--encoding='UTF8' --lc-collate='C' --lc-ctype='C'"
The POSTGRES_DB variable specifies the name of the initial database that will be created when PostgreSQL starts for the first time. The POSTGRES_USER and POSTGRES_PASSWORD variables define the superuser account credentials that you'll use to connect to and manage your database. The PGDATA variable indicates the location within the container where PostgreSQL will store its data files. The POSTGRES_INITDB_ARGS variable provides additional initialization parameters that set the database encoding to UTF8 and the locale settings to C for consistent behavior.
Step 3: Create the PostgreSQL Container
Now you're ready to create and configure the PostgreSQL container instance. This command pulls the official PostgreSQL Docker image from the remote registry and configures it with the environment variables and mount point which were established in the previous steps.
/container/add remote-image=postgres:15 interface=veth1 root-dir=disk1/images/postgres mountlists=MOUNT_POSTGRES envlists=ENV_POSTGRES name=postgres start-on-boot=yes logging=yes
warning
You can specify a different version for PostgreSQL by changing the postgres:15 value to any other available PostgreSQL version tag.
Step 4: Start the PostgreSQL Container
With all configuration complete, you're now ready to initiate the PostgreSQL container. Starting the container will launch the PostgreSQL database server, which will become ready to accept connections from your applications.
/container/start [find where name=postgres]
Once started, PostgreSQL will automatically create the initial database and user based on the environment variables you configured. The container will automatically start on system boot if you have configured it to do so.
Advanced: PostgreSQL with pgAdmin
This guide demonstrates how to configure and deploy pgAdmin, the popular web-based administration tool for PostgreSQL databases, as a container on your MikroTik RouterOS device. pgAdmin provides an intuitive graphical interface for managing your PostgreSQL databases servers, allowing you to create databases, execute queries, manage users, and perform various administrative tasks through a web browser.
Step 1: Create Mount Points Directories for pgAdmin Container
Before creating the container, you need to create persistent storage locations where pgAdmin will store its configuration files, session data, and server connection settings. This ensures that your settings and connections remain intact even after container restarts or updates.
/container/mounts/add list=MOUNT_PGADMIN_CONFIG src=disk1/volumes/pgadmin/config dst=/config
/container/mounts/add list=MOUNT_PGADMIN_DATA src=disk1/volumes/pgadmin/data dst=/var/lib/pgadmin
The first mount point maps your local configuration directory to the container's /config path, where pgAdmin will store server definitions and user preferences. The second mount point maps your local data directory to the container's /var/lib/pgadmin path, which houses session information, logs, and runtime data.
Step 2: Configure Environment Variables for pgAdmin Container
Environment variables provide configuration parameters that pgAdmin requires at startup. These variables define the application behavior, default credentials, and network settings.
/container/envs/add list=ENV_PGADMIN key=PGADMIN_LISTEN_PORT value=80
/container/envs/add list=ENV_PGADMIN key=PGADMIN_DEFAULT_EMAIL value="sysadmin@domain.com"
/container/envs/add list=ENV_PGADMIN key=PGADMIN_DEFAULT_PASSWORD value="<changeme>"
/container/envs/add list=ENV_PGADMIN key=PGADMIN_SERVER_JSON_FILE value="/config/servers.json"
/container/envs/add list=ENV_PGADMIN key=PGADMIN_PREFERENCES_JSON_FILE value="/config/preferences.json"
/container/envs/add list=ENV_PGADMIN key=PGPASS_FILE value="/config/pgpass"
/container/envs/add list=ENV_PGADMIN key=PGADMIN_DISABLE_POSTFIX value="True"
The PGADMIN_LISTEN_PORT variable specifies which port pgAdmin will listen on for incoming web connections—port 80 is used by default for standard HTTP access. The PGADMIN_DEFAULT_EMAIL and PGADMIN_DEFAULT_PASSWORD variables define the initial administrator credentials that you'll use to log into the pgAdmin web interface for the first time. The remaining variables specify file paths within the container where pgAdmin will store and retrieve server connection configurations, user preferences, and password files data.
Step 3: Create the pgAdmin Container
Now you're ready to create and configure the pgAdmin container instance. This command pulls the official dpage/pgadmin4 Docker image from the remote registry and configures it with the environment variables and mount points which were established in the previous steps.
/container/add remote-image=dpage/pgadmin4 envlists=ENV_PGADMIN mountlists=MOUNT_PGADMIN_CONFIG,MOUNT_PGADMIN_DATA interface=veth1 logging=yes name=pgadmin root-dir=disk1/images/pgadmin start-on-boot=yes user=0:0
This command specifies the official pgAdmin4 Docker image from Docker Hub, applies your previously defined environment variable list and mount point list, assigns the container to the veth1 virtual ethernet interface, enables logging for troubleshooting purposes, names the container "pgadmin" for easy identification, stores the container image files in the designated disk location, configures the container to start automatically whenever the router boots, and runs the container with root user privileges.
Step 4: Disable the Webfig Service
As pgAdmin operates as a web-based application and by default listens on HTTP port 80, it conflicts with RouterOS's built-in WebFig web interface which also uses port 80. To prevent this port conflict and ensure pgAdmin functions properly, you must disable the WebFig service.
/ip/service
set www disabled=yes
tip
You have an alternative approach if you prefer to keep WebFig accessible: simply modify the PGADMIN_LISTEN_PORT environment variable to use a different port number—such as 8080 or 8888—instead of the default port 80. This allows both services to run simultaneously without conflict.
Step 5: Start the pgAdmin Container
With all configuration complete, you're now ready to initiate the pgAdmin container. Starting the container will launch the pgAdmin web application, which will become accessible through your web browser.
/container/start [find where name=pgadmin]
Once started, you can access the pgAdmin web interface by navigating to your router's IP address in a web browser. Use the email address and password you configured in Step 2 to authenticate and begin managing your PostgreSQL databases servers.
