Skip to main content
Version: current
Container - mosquitto MQTT server
Introduction
The introduction of the container feature into RouterOS made it possible to run all kinds of servers for all sorts of tasks inside the router. This is especially relevant for people who want to reduce the number of devices in their network. Instead of running a server on a separate device/machine, why not run it inside the router?
In this guide, we will showcase how to install a basic MQTT broker (or in other words, server) called eclipse-mosquitto. The MQTT protocol is a very popular choice, especially in IoT topologies. It is an open OASIS and ISO standard lightweight, publish-subscribe network protocol that transports messages between devices. A typical topology consists of an MQTT publisher (a device that sends information), an MQTT broker (a server where the data is stored), and an MQTT subscriber (a device that listens to the data published on the server).
RouterOS supports the MQTT publish, subscribe feature, and, now, we can also run the MQTT broker as well.
The image that we are going to use can be found by following the hub.docker link.
Summary
Make sure to study our container guide before proceeding with the configuration. Make sure to check the disclaimer and requirements sections to understand all the risks and necessary steps you might be required to take.
You can find supported architectures by following the link.
At the time, when the guide was published, the eclipse-mosquitto image was available for ARM32, ARM64, and AMD64 (CHR and x86) devices. In this example, we will run it on an ARM32 architecture device → RB1100AHx4.
warning
A very basic and quick configuration will be shown. Make sure to check the mosquitto documentation page for more information about additional options and settings you can implement. If you want to use it for production, please make sure to harden the security in any way possible:
  • Firewall, so that access to the container is allowed only from your trusted IP addresses;
  • Increasing security from the mosquitto broker/server-side → use strong passwords, non-standard ports etc.;
  • Use SSL MQTT.
Container configuration
Sub-menu: /container
note: The container package is required.
Container mode
Enable container mode:
/system/device-mode/update container=yes
You will need to confirm the device-mode with a press of the reset button, or a cold reboot, if using containers on X86.
Networking
Add veth interface for the container:
/interface/veth/add name=veth2 address=172.19.0.2/24 gateway=172.19.0.1
Create a bridge for containers and add veth to it:
/interface/bridge/add name=msqt
/ip/address/add address=172.19.0.1/24 interface=msqt
/interface/bridge/port/add bridge=msqt interface=veth2
Forward TCP 1883 for non-SSL MQTT (where 192.168.88.1 is the device's LAN IP address) for testing purposes if NAT is required (optional):
/ip/firewall/nat/add action=dst-nat chain=dstnat dst-address=192.168.88.1 dst-port=1883 protocol=tcp to-addresses=172.19.0.2 to-ports=1883
Environment variables and mounts
Per the eclipse-mosquitto docker hub, define a mount for the configuration file. We will mount not just the configuration file, but the whole folder, because, for SSL MQTT, we will need to upload certificates into the folder as well:
/container/mounts/add src=/mosquitto_mounted dst=/mosquitto/config name=msqt_config
Getting image
To simplify the configuration, we will get the image from an external library, but you can also import it via the .tarimportimagefromPC) file.
In this example, we will use the device's own storage. RB1100AHx4 has 128 MB disk space and a basic mosquitto installation should not take up more than ~15 MB.
Make sure that you have "Registry URL" set accordingly, limit RAM usage (if necessary), and set up a directory for the image:
/container/config/set registry-url=https://registry-1.docker.io tmpdir=pull
Pull image
/container/add remote-image=library/eclipse-mosquitto:latest interface=veth2 root-dir=mosquitto mounts=msqt_config logging=yes
After running the command, RouterOS should start "extracting" the package. Check "File System" for newly created folders and monitor container status with the command /container/print.
Setting up mosquitto configuration file
To get the mosquitto.conf file, we will need to use SFTP (file transfer over SSH) protocol, so make sure that SSH service is enabled. You can also use FTP.
Open your command terminal ("CMD", as Administrator, for Windows users, or "Linux Shell or Command Terminal" for Linux users) and navigate to the directory where you want to download the configuration file. For example, to the "Container" folder on your "Desktop":
C:\WINDOWS\system32>cd C:\Users\Administrator\Desktop\Container
C:\Users\Administrator\Desktop\Container>
Initiate SFTP to the device's IP address:
C:\Users\Administrator\Desktop\Container>sftp admin@192.168.88.1
The authenticity of host '192.168.88.1 (192.168.88.1)' can't be established.
RSA key fingerprint is SHA256:lfxxs+xMrXlvP7hiHi9ZAEZlPi6/c5US+r6J7ljhkaA.
Are you sure you want to continue connecting (yes/no/[fingerprint])?yes
Warning: Permanently added '192.168.88.1' (RSA) to the list of known hosts.
Connected to 192.168.88.1.
sftp>
Go to the mosquitto configuration file folder (use the dir or ls command to see the content of the folder you are in and the cd command to go to the folder of your choice). By default, the configuration is loaded from the "/mosquitto/config/mosquitto.conf", so, navigate there and use the get command to download it:
sftp> cd mosquitto/mosquitto/config
sftp> dir
mosquitto.conf
sftp> get mosquitto.conf
Fetching /mosquitto/mosquitto/config/mosquitto.conf to mosquitto.conf
Open "mosquitto.conf" via your preferred text editor (notepad or any other), and just overwrite it with two lines shown below:
warning
In this section, we will configure a basic non-SSL MQTT setup for testing purposes. Non-SSL MQTT is not secure for a production environment unless you are certain the required security/restrictions are in place.
For a production environment, in topologies where the MQTT traffic can be captured/sniffed and/or in topologies where the MQTT traffic is routed directly via the internet (not locally), use SSL MQTT. Check the SSL MQTT section for more information.
listener 1883
allow_anonymous true
  • The first line, listener 1883, will make the installation listen for incoming network connections on the specified port.
  • The second line, allow_anonymous true, determines whether clients that connect without providing a username are allowed to connect.
Overwrite the file using the same mosquitto.conf name.
After you have created your own custom configuration file, upload it into the mounted directory/folder "mosquitto_mounted". If you have not run the container yet, you will not have the "mosquitto_mounted" folder and you can create it manually. If you did run it (/container/start 0), it should have been created automatically:
sftp> dir
mosquitto mosquitto_mounted pub pull skins
Use SFTP from the directory where the edited mosquitto.conf file is located and put it into the mounted directory:
C:\Users\Administrator\Desktop\Container>dir
Directory of C:\Users\Administrator\Desktop\Container
02/03/2023 12:09 PM <DIR> .
02/03/2023 12:09 PM <DIR> ..
02/03/2023 12:09 PM 40,449 mosquitto.conf
1 File(s) 40,449 bytes
2 Dir(s) 76,166,430,720 bytes free
sftp> dir
sftp> cd mosquitto_mounted
sftp> put mosquitto.conf
Uploading mosquitto.conf to /mosquitto_mounted/mosquitto.conf
mosquitto.conf 100% 162 40.5KB/s 00:00
Restart the container:
[admin@MikroTik] > /container/stop 0
[admin@MikroTik] > /container/start 0
Make sure to wait for the container to stop (status=stopped should be shown after using the /container/print command) before initiating it again.
Starting the container
After you make sure that the container has been added and the status has changed to status=stopped after using /container/print → you can initiate it:
/container/start 0
If you have enabled container logging, you would see something like this in the Logs section:
12:12:46 container,info,debug 1707214366: mosquitto version 2.0.18 starting
12:12:46 container,info,debug 1707214366: Config loaded from /mosquitto/config/mosquitto.conf.
12:12:46 container,info,debug 1707214366: Opening ipv4 listen socket on port 1883.
12:12:46 container,info,debug 1707214366: Opening ipv6 listen socket on port 1883.
12:12:46 container,info,debug 1707214366: mosquitto version 2.0.18 running
MQTT publish and subscribe
Sub-menu: /iot/mqtt
note: The iot package is required.
Add an MQTT broker:
/iot/mqtt/brokers/add name=mosquitto username=test address=172.19.0.2
Subscribe to the MQTT broker and the required topic:
/iot/mqtt/subscribe broker=mosquitto topic=test/topic
Publish a static MQTT message:
/iot/mqtt/publish broker="mosquitto" topic="test/topic" message="{\"test\":\"123\"}"
Check subscriptions for received messages:
/iot/mqtt/subscriptions/recv/print
0 broker=mosquitto topic="test/topic" data="{"test":"123"}"
time=2023-07-12 10:01:40
You can also check the container logs (if enabled), to confirm the mosquitto is operational:
12:47:28 container,info,debug 1675421248: New connection from 172.19.0.1:42240 on port 1883.
12:47:28 container,info,debug 1675421248: New client connected from 172.19.0.1:42240 as MTD8580EC793C4 (p2, c1, k60, u'test').
12:47:38 container,info,debug 1675421258: Client MTD8580EC793C4 disconnected.
SSL MQTT
Using non-SSL MQTT for a production environment is not secure. One can easily capture/sniff the packet exchange between the broker and the publisher and, as a result, will be able to obtain user credentials and other sensitive information.
To increase security, use SSL MQTT.
The first step is to generate the certificates. In this example, we will use a simple Root CA scenario (with no device/client certificate requirement).
Use the official mosquitto-tls user guide for the step-by-step.
Server configuration
You should have generated ca.crt (Certificate Authority file), server.crt (server certificate) and server.key (server's key):
07/12/2023 10:58 AM <DIR> .
07/12/2023 10:58 AM <DIR> ..
07/12/2023 10:56 AM 1,322 ca.crt
07/12/2023 10:56 AM 1,854 ca.key
07/12/2023 09:57 AM 35 mosquitto.conf
07/12/2023 10:58 AM 1,164 server.crt
07/12/2023 10:57 AM 960 server.csr
07/12/2023 10:56 AM 1,704 server.key
6 File(s) 7,039 bytes
2 Dir(s) 52,401,184,768 bytes free
Open the mounted "mosquitto.conf" via your preferred text editor (notepad or any other), and just overwrite it with the lines shown below:
tls_version tlsv1.2
port 8883
cafile /mosquitto/config/ca.crt
keyfile /mosquitto/config/server.key
certfile /mosquitto/config/server.crt
  • tls_version line sets minimal TLS version.
  • listener 8883 will make the installation listen for incoming network connection on the specified port.
  • allow_anonymous true determines whether clients that connect without providing a username are allowed to connect.
warning
We are using a basic SSL configuration for testing purposes. allow_anonymous true is not a secure setting for the production environment.
  • cafile /mosquitto/config/ca.crt line specifies a path to the CA certificate file.
  • keyfile /mosquitto/config/server.key line specifies a path to the server key file.
  • certfile /mosquitto/config/server.crt line specifies a path to the server certificate file.
Upload the certificate files and an updated SSL-ready mosquitto.conf file into the mounted folder "mosquitto_mounted":
sftp> dir
mosquitto.conf
sftp> put ca.crt
Uploading ca.crt to /mosquitto_mounted/ca.crt
ca.crt 100% 1322 323.0KB/s 00:00
sftp> put server.crt
Uploading server.crt to /mosquitto_mounted/server.crt
server.crt 100% 1164 227.3KB/s 00:00
sftp> put server.key
Uploading server.key to /mosquitto_mounted/server.key
server.key 100% 1704 415.7KB/s 00:00
sftp> dir
ca.crt mosquitto.conf server.crt server.key
mosquitto.conf 100% 162 32.2KB/s 00:00
Confirm that the broker listens on port 8883 using the logs:
11:20:41 container,info,debug 1689160841: mosquitto version 2.0.15 starting
11:20:41 container,info,debug 1689160841: Config loaded from /mosquitto/config/mosquitto.conf.
11:20:41 container,info,debug 1689160841: Opening ipv4 listen socket on port 8883.
11:20:41 container,info,debug 1689160841: Opening ipv6 listen socket on port 8883.
11:20:41 container,info,debug 1689160841: mosquitto version 2.0.15 running
11:22:24 system,info,account user admin logged in from 10.5.217.34 via local
Testing the connection
Upload the CA certificate (ca.crt) into RouterOS, into the device's "File List":
/file/print
Columns: NAME, TYPE, SIZE, CREATION-TIME
# NAME TYPE SIZE CREATION-TIME
0 skins directory 1970-01-01 03:00:02
1 pub directory 2023-01-04 11:05:04
2 disk7 disk 2023-07-12 09:52:07
3 mosquitto container store 2023-07-12 09:52:09
4 mosquitto_mounted container store 2023-07-25 16:38:37
5 pull directory 2023-07-12 09:52:09
6 ca.crt .crt file 1322 2023-07-12 11:28:23
Import the certificate:
/certificate/import file-name=ca.crt passphrase=""
Add MQTT broker for SSL connection:
/iot/mqtt/brokers/add name=mosquittoSSL username=test address=172.19.0.2 port=8883 ssl=yes
/iot/mqtt/subscribe broker=mosquittoSSL topic=test/topic
/iot/mqtt/publish broker="mosquittoSSL" topic="test/topic" message="{\"test\":\"123\"}"
0 broker=mosquittoSSL topic="test/topic" data="{"test":"123"}"
time=2023-07-12 10:20:40
