Container - freeradius server
Introduction
The introduction of the container feature into RouterOS made it possible to run all kinds of servers for all sorts of tasks inside the router. This is especially relevant for people who want to reduce the number of devices in their network. Instead of running a server on a separate device/machine, why not run it inside the router?
Radius is short for Remote Authentication Dial-In User Service. RouterOS has a RADIUS client feature that can authenticate for HotSpot, PPP, PPPoE, PPTP, L2TP, and ISDN connections. Basically, this feature allows you to connect RouterOS to a Radius Server, and then, utilize the user database from the server for client authentication.
In our example, we will showcase the freeradius/freeradius-server image installation.
Summary
Sub-menu: /container
Note: The container package is required.
Make sure to study our container guide before proceeding with the configuration. Make sure to check the disclaimer and requirements sections to understand all the risks and necessary steps you might be required to do.
At the time when the guide was published, the image was available for Linux/amd64 OS/architecture only (usable by CHR and x86 devices). For arm64 devices you will need to make your own container from the FreeRADIUS source. For both arm64 and arm32 devices, you can also use freeradius/freeradius-server-dev image at your own risk (as it is an "experimental/development" version of the image).
To help you set up a CHR in a Virtual Box, please check our YouTube tutorial, or Make your own x86 router.
This guide demonstrates a basic example! The tests were performed in a local environment! This guide is meant for basic RADIUS "testing" purposes! Not all "freeradius" feature were tested!
Configuration
Container mode
Enable container mode:
/system/device-mode/update container=yes
You will need to confirm the device-mode with a cold reboot if using the container on X86.
Networking
Add veth interface for the container:
/interface/veth/add name=veth3 address=172.17.0.2/24 gateway=172.17.0.1
Create a bridge for the container, assign an IP network to it, and add veth to the bridge:
/interface/bridge/add name=dockerfreeradius
/ip/address/add address=172.17.0.1/24 interface=dockerfreeradius
/interface/bridge/port/add bridge=dockerfreeradius interface=veth3
Setup NAT for outgoing traffic if required:
/ip/firewall/nat/add chain=srcnat action=masquerade src-address=172.17.0.0/24
Getting image
To simplify the configuration, we will get the image from an external library, but you can also import it via the .tarimportimagefromPC) file.
Make sure that you have "Registry URL" set accordingly, limit RAM usage (if necessary), and set up a directory for the image:
/container/config/set registry-url=https://registry-1.docker.io tmpdir=pull
Pull the image with the help of the command:
/container/add remote-image=freeradius/freeradius-server:latest interface=veth3 root-dir=freeradius logging=yes cmd="-X"
where cmd="-X" enables debug logging (per the "freeradius" documentation).
After running the command, RouterOS should start "extracting" the package. Check "File System" for newly created folders and monitor container status with the command /container/print.
Starting the container
After you make sure that the container has been added and the status has changed to status=stopped after using /container/print, you can initiate it:
/container/start 0
Altering the server's configuration files
To access the server's configuration files (clients.conf and authorize), we will need to use the SFTP (file transfer over SSH) protocol, so make sure that SSH service is enabled.
Open your command terminal ("CMD", as Administrator, for Windows users, or "Linux Shell or Command Terminal" for Linux users) and navigate to the directory where you want to download the configuration files. For example, to the "radius" folder on your "Desktop":
C:\WINDOWS\system32>cd C:\Users\Administrator\Desktop\radius
C:\Users\Administrator\Desktop\radius>
Initiate SFTP to the device's IP address:
C:\Users\DenissPC\Desktop\radius>sftp admin@10.55.8.53
admin@10.55.8.53's password:
Connected to 10.55.8.53.
sftp>
Go to the server's configuration file folder (use the dir or ls command to see the content of the folder you are in and the cd command to go to the folder of our choice).
The first file, "clients.conf", allows you to define RADIUS clients. Per the "freeradius" documentation, it should be under the /etc/freeradius directory...so, navigate there and use the get command to download it:
sftp> dir
freeradius pub pull skins
sftp> cd freeradius/etc/freeradius
sftp> dir
README.rst certs clients.conf dictionary experimental.conf hints
huntgroups mods-available mods-config mods-enabled panic.gdb policy.d
proxy.conf radiusd.conf sites-available sites-enabled templates.conf trigger.conf
users
sftp> get clients.conf
Fetching /freeradius/etc/freeradius/clients.conf to clients.conf
/freeradius/etc/freeradius/clients.conf 100% 8323 1.2MB/s 00:00
Open "clients.conf" via your preferred text editor (Notepad or any other). You can study the file to see all the options that you have (additionally, check freeradius.org). This example shows a basic setup, so we will just overwrite the whole file with the lines shown below:
client new {
ipaddr = 0.0.0.0/0
secret = client_password
where we indicate that our radius client can connect using any possible IP address (ipaddr=0.0.0.0/0 ensures that, but you also can change it to the actual ip address/mask of your radius client if you need to do so) and that our secret is "client_password" (you can change it to any other secret).
Save the file/overwrite it.
The second file, "authorize", allows you to set up users. Per the "freeradius" documentation, it should be under /etc/freeradius/mods-config/files. Go there and get the file:
sftp> dir
sftp> cd freeradius/etc/freeradius/mods-config/files
sftp> dir
accounting authorize dhcp pre-proxy
sftp> get authorize
Fetching /freeradius/etc/freeradius/mods-config/files/authorize to authorize
/freeradius/etc/freeradius/mods-config/files/authorize 100% 6594 1.1MB/s 00:00
Open "authorize" via your preferred text editor (notepad or any other). This example shows a basic setup, so we will just uncomment (remove the "#" symbol from) the line shown below (leave the rest of the configuration/lines as they are):
bob Cleartext-Password := "hello"
which creates a username "bob" and sets the password to "hello" (you can change the username and password).
Upload both files back to overwrite the default files with the help of the put command:
sftp> dir
sftp> dir
users
sftp> put clients.conf
Uploading clients.conf to /freeradius/etc/freeradius/clients.conf
clients.conf 100% 67 22.3KB/s 00:00
sftp> cd mods-config/files
sftp> dir
sftp> put authorize
Uploading authorize to /freeradius/etc/freeradius/mods-config/files/authorize
authorize 100% 6626 1.6MB/s 00:00
Restart the container:
/container/stop 0
/container/start 0
Make sure to wait for the container to stop (status=stopped should be shown after using the /container/print command) before initiating it again.
Result verification
In RouterOS, add a new RADIUS client configuration:
/radius/add service=login address=172.17.0.2 secret="client_password"
, where the address is the IP address of the veth3 interface, secret is the secret that we configured in the clients.conf file and service is the allowed service that you wish to use.
Allow "login" with RADIUS users via the command:
/user/aaa/set use-radius=yes
We have allowed the "login" service for RADIUS and we can test it using an ssh/winbox/webfig connection. For the SSH test, issue the command (where you need to indicate the device's management IP and input bob's password "hello" after):
/system/ssh 10.55.8.53 user=bob
You should be able to verify that the terminal user changed from "admin@MikroTik" to "bob@MikroTik":
[admin@MikroTik] > /system/ssh 10.55.8.53 user=bob
password:hello
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.8alpha173 (c) 1999-2023 https://www.mikrotik.com/
Press F1 for help
[bob@MikroTik] >
If you issue the command /user/active/print:
/user/active/print
Flags: R - RADIUS
Columns: WHEN, NAME, ADDRESS, VIA
# WHEN NAME ADDRESS VIA
0 2023-02-16 16:31:21 admin xx.xx.xx.xx winbox
1 2023-02-16 16:38:46 admin xx.xx.xx.xx console
2 R 2023-02-16 16:38:53 bob 10.55.8.53 ssh
you will be able to verify that a new user "bob" is "active" and has a flag "R" assigned, which indicates it is a RADIUS user.
