Netwatch
Netwatch monitors the state of hosts on the network. Monitoring can be done with the following probe types:
- ICMP - pings to a specified IP address - hosts, with an option to adjust threshold values
- Simple - uses ping, without the use of advanced metrics
- TCP conn, to test the TCP connection
- HTTP GET/HTTPS GET, a request against a server you are monitoring
- DNS - sends a DNS query to a DNS server and checks for a response.
For each entry in the Netwatch table, you can specify an IP address, ping interval, and console scripts. The main advantage of Netwatch is its ability to issue arbitrary console commands on host state changes.
Since 7.4, Netwatch functionality has been expanded; prior versions only support simple ICMP probes. While upgrading to the new version, old Netwatch entries will be unchanged, reporting probe type "simple" - preserving the same functionality.
Warning: Default Netwatch values are always used - even if they were not defined by the user. Make sure to check the "status" page of the probe to see if the default thresholds are appropriate for your use case. Default threshold values can be found under the "probe options" section on this page.
Properties
Sub-menu: /tool/netwatch
| Property | Description |
| host (Default:"") | The IP address of the server to be probed. Formats:
| type (icmp | tcp-conn | http-get | http-get | dns | simple; Default: simple) | Type of the probe:
| interval (Default: 10s) | The time interval between probe tests |
| timeout (Default: 3s) | Max time limit to wait for a response |
| src-address (Default: "") | Source IP address which the Netwatch will try to use in order to reach the host. If the address is not present, then the host will be considered as "down". |
| start-delay (Default: 3s) | Time to wait before starting the probe (on add, enable, or system start) |
| startup-delay (Default: 5m) | Time to wait until starting the Netwatch probe after system startup |
| up-script (Default:"") | Script to execute on the event of probe state change 'fail' --> 'OK' |
| down-script (Default:"") | Script to execute on the event of probe state change 'OK' --> 'fail' |
| test-script (Default:"") | Script to execute at the end of every probe test |
| ignore-initial-up (no | yes; Default: no) | Specifies if "Up" script should be run if the probe state change goes from Unknown to 'Up', used to help against false positives after enabling the probe, or after a reboot. "no" means that the change from Unknown to Up will not be ignored. |
| ignore-initial-down (no | yes; Default: no) | Specifies if "Down" script should be run if the probe state change goes from Unknown to 'Down'. "no" means that the change from 'Unknown' to 'Down' will not be ignored. Warning: Should be used with care, as the first "Down" status won't be executed, and Down script will only be run if the probe goes through "Up" > "Down" state. |
Netwatch executes scripts as *sys user, so any defined global variable in the Netwatch script will not be readable by, for example, a scheduler or other users
Netwatch is limited to read,write,test,reboot script policies. If the owner of the script does not have enough permissions to execute a certain command in the script, then the script will not be executed. If the script has greater policies than read,write,test,reboot - then the script will not be executed as well. Make sure your scripts do not exceed the mentioned policies.
It is possible to disable permission checking for RouterOS scripts under the /system/scripts menu. This is useful when Netwatch does not have enough permissions to execute a script, though this decreases overall security. It is recommended to assign proper permissions to a script instead.
Type-specific options
All config options specific to one probe type (e.g. icmp's packet-interval) are ignored for other probe types.
ICMP probe options
| packet-interval (Default: 50ms) | The time between ICMP-request packet sends |
| packet-count (Default: 10) | Total count of ICMP packets to send out within a single test |
| packet-size (Default: 54 (IPv4) or 54 (IPv6)) | The total size of the IP ICMP packet |
| thr-max (Default**: 1s**) | Fail threshold for rtt-max (a value above thr-max is a probe fail) |
| thr-avg (Default: 100ms) | Fail threshold for rtt-avg (round trip time-avg) |
| thr-stdev (Default: 250ms) | Fail threshold for rtt-stdev |
| thr-jitter (Default: 1s) | Fail threshold for rtt-jitter |
| thr-loss-percent (Default: 85.0%) | Fail threshold for loss-percent |
| thr-loss-count (Default: 4294967295(max)) | Fail threshold for loss-count |
| ttl(Default; 255) | Manually sets the time to live value for the ICMP packet |
| accept-icmp-time-exceeded (yes | no; Default no) | If the ICMP "time exceeded" message should be considered a valid response |
| early-failure-detection (no | yes; Default: no) | Netwatch will not wait for all the packets to be processed to change probe status if it is already known that the host will be considered "down". |
| early-success-detection(no | yes; Default:no) | Netwatch will not wait for all the packets to be processed to change probe status if it is already known that the host will be considered "up". |
accept-icmp-time-exceeded=yes can be used together with a manually set low ttl value to monitor Internet connectivity, without relying on a specific endpoint.
For example, you can monitor a public IP address, but that address can filter your ICMP request, or just become unreachable itself, if the Netwatch probe is using this address to monitor Internet connectivity, this would cause a false alarm.
To make sure you can reach the Internet, it's generally enough to make sure you can reach a device a few routing hops away. A low time to live value will expire in transit to the specified host you want to monitor - each router passing the ICMP packet will subtract "1" from the TTL value, upon the TTL reaching 0, an ICMP "time exceeded" packet will be generated, and sent back to the Netwatch probe. If all other fail thresholds are not broken, this response will be considered a success.
Important: When writing Up/Down/Test scripts for Netwatch, use the rtt-* elements instead of the thr-* elements. If the element names differ, their script-specific forms are listed in the description.
Important: Simple, ICMP, HTTP, and TCP-connect probes are sent with the "don't fragment" flag set. With an ICMP probe, you can set packet-size, which in combination with the DF flag, can be used to aid with path MTU discovery.
TCP-CONNECT
| port (Default: 80) | TCP port (for both tcp-conn and http-get probes) |
TCP-CONNECT pass-fail criteria
| thr-tcp-conn-time (Default: 00:05...00:30) | Fail threshold for tcp-connect-time, the configuration uses microseconds, if the time unit is not specified (s/m/h), log and status pages display the same value in milliseconds. |
HTTP-GET probe options
HTTPS-GET probe options
| port (Default: 443) | TCP port (for both tcp-conn and http-get probes) |
| certificate (Default:"") | Certificate from the local store that should be used for host verification. |
| check-certificate (yes | no; Default no) | Enables trust chain validation from the local certificate store. |
HTTP-GET/HTTPS-GET probe pass/fail criteria
| thr-http-time (Default: 10s) | Fail threshold for http-resp-time |
| http-code-min (Default: 100) | OK/fail criteria for the HTTP response code. |
| http-code-max (Default: 299) | Response in the range [http-code-min , http-code-max] is a probe pass/OK; outside is a probe fail. See mozilla-http-status or rfc7231 |
DNS probe options
| host (Default:"") | DNS name that should be resolved. |
| record-type (A | AAAA | MX | NS; Default: A) | Record type that will be used for DNS probe. |
| dns-server | The DNS server that the probe should send its requests to; if not specified, it will use the value from /ip/dns. |
Probe statistics/variables
You can view statistics and use these variables in scripting. Keep in mind that variables containing "-" must be written like this, for example, "done-tests" would be $"done-tests"
Generic:
| name | user added name for the Netwatch entry |
| comment | user added comment |
| host | host that was probed |
| type | probe type |
| interval | interval |
| timeout | timeout |
| since | The last time the status change happened |
| status | The current status of the probe |
| done-tests | total count of probe tests already done so far |
| failed-tests | count of failed probe tests |
ICMP:
| sent-count | ICMP packets sent out |
| response-count | Matching/valid ICMP packet responses received |
| thr-loss-count | number of lost packets |
| thr-loss-percent | number of lost packets in percent |
| thr-avg | mean value of round trip time (rtt-avg) |
| thr-max | max round trip time (rtt-max) |
| thr-jitter | jitter ( = max - min) of round trip time (rtt-jitter) |
| thr-stdev | standard deviation of round trip time (rtt-stdev) |
TCP:
| tcp-connect-time | time taken to establish a TCP connection |
HTTP:
| http-status-code | HTTP response status code (200 OK, 404 Not Found, etc.). See mozilla-http-status or RFC7231 |
HTTPS:
DNS:
| ip | IP address - the result of A record-type probe |
| ip6 | IPv6 address - the result of AAAA record-type probe |
| mail-servers | Mail servers along with their priorities - the result of MX record-type probe |
| name-servers | Name servers - the result of NS record-type probe |
Logs
On each probe's OK/fail state change:
- Probe identification info and OK->fail or fail->OK are printed to info level.
- Detailed probe stats and config are printed to debug level.
Status
Command /tool/netwatch/print will show the current status of Netwatch and read-only properties:
- since - Indicates when a state of the host changed last time.
- status - Shows the current status of the host.
- host - address being monitored.
Quick Example
Here we will use a simple ICMP check to the host with IP 8.8.8.8:
[admin@MikroTik] > /tool/netwatch/add host=8.8.8.8 interval=30s up-script=":log info \"Ping to 8.8.8.8 successful\""
Afterward, in the logging section we can see Netwatch executed script:
[admin@MikroTik] > /log/print where message~"8.8.8.8"
08:03:26 ,info Ping to 8.8.8.8 successful
