IP Scan
IP Scan tool allows a user to scan networks based on some network prefix or by setting an interface to listen on. Either way, the tool collects certain data from the network:
- address - IP address of a network device.
- mac-address - MAC address of a network device.
- time - response time of the seen network device when found.
- DNS - DNS name of a network device.
- SNMP - SNMP name of the device.
- NET-BIOS - NET-BIOS name of the device if advertised by the device.
When using the IP scan tool the user must choose what they want to scan for:
- A certain IPv4 prefix - the tool will attempt to scan all the IP addresses or addresses set.
- The interface of the router - the tool will attempt to listen for packets that are "passing by" and attempt to compile results when something is found.
There is a possibility to set both but then results may be inconclusive!
Quick Example
The /tool/ip-scan utility is an essential diagnostic tool for users to discover active hosts within a specific IP range. It is particularly useful for identifying unauthorized devices, verifying IP address assignments, or mapping out a network segment when documentation is missing. By sending ICMP and ARP requests, it provides a real-time overview of reachable addresses, their associated MAC addresses, and even SNMP identity strings for compatible devices.
This tool is frequently utilized during initial site audits or when troubleshooting connectivity issues in a dynamic DHCP environment. By running a scan across a local subnet, you can quickly correlate physical hardware with logical IP addresses to detect IP conflicts or rogue access points. This visibility is crucial for maintaining network integrity and ensuring that all connected infrastructure matches the intended deployment topology.
In the following example, we will scan the devices on 10.155.126.0/24 network:
[admin@MikroTik] > /tool/ip-scan address-range=10.155.126.1-10.155.126.255
Columns: ADDRESS, MAC-ADDRESS, TIMe, SNMP
ADDRESS MAC-ADDRESS TIM SNMP
10.155.126.1 E4:8D:8C:1C:D3:18 2ms CCR1036-8G-2S+
10.155.126.251 2ms
10.155.126.151 E4:8D:8C:49:49:DB 1ms
10.155.126.153 6C:3B:6B:48:0E:8B 1ms 750Gr3
10.155.126.249 CC:2D:E0:8D:01:88 0ms CRS328-24P-4S+
10.155.126.250 B8:69:F4:B3:1B:D2 0ms
10.155.126.252 6C:3B:6B:ED:83:69 0ms
10.155.126.253 6C:3B:6B:ED:81:83 0ms
