Skip to main content
Version: current
Bandwidth Test
Sub-menu: /tool Packages required: system
The Bandwidth Tester can be used to measure the throughput to another MikroTik router (either wired or wireless) and thereby help to discover network "bottlenecks".
The TCP test uses the standard TCP protocol with acknowledgments and follows the TCP algorithm on how many packets to send according to latency, dropped packets, and other features in the TCP algorithm. Please review the TCP protocol for details on its internal speed settings and how to analyze its behavior. Statistics for throughput are calculated using the entire size of the TCP data stream. As acknowledgments are an internal working of TCP, their size and usage of the link are not included in the throughput statistics. Therefore, this statistic is not as reliable as the UDP statistic when estimating throughput.
The UDP tester sends 110% or more packets than are currently reported as received on the other side of the link. To see the maximum throughput of a link, the packet size should be set to the maximum MTU allowed by the links, which is usually 1500 bytes. There is no acknowledgment required by UDP; this implementation means that the closest approximation of the throughput can be seen.
warning
Bandwidth Test uses all available bandwidth and system resources, and may impact network usability. If you want to test real throughput of a router, you should run bandwidth test through the tested router not from, or to itself. To do this you need at least 3 routers connected in a chain: the Bandwidth Server, the router being tested and the Bandwidth Client.
note
If you use UDP protocol then Bandwidth Test counts IP header+UDP header+UDP data. If you use TCP then Bandwidth Test counts only TCP data (TCP header and IP header are not included).
Bandwidth Test Server
Sub-menu: /tool/bandwidth-server
PropertyDescription
allocate-udp-ports-from (integer 1000..64000; Default: 2000)Beginning of UDP port range
authenticate (yes | no; Default: yes)Communicate only with authenticated clients
enabled (yes | no; Default: yes)Defines whether the bandwidth server is enabled or not
max-sessions (integer 1..1000; Default: 100)Maximal simultaneous test count
Example
Bandwidth Server:
[admin@MikroTik] /tool/bandwidth-server> print
enabled: yes
authenticate: yes
allocate-udp-ports-from: 2000
max-sessions: 100
Active sessions:
[admin@MikroTik] /tool/bandwidth-server/session> print
# CLIENT PROTOCOL DIRECTION USER
0 35.35.35.1 udp send admin
1 25.25.25.1 udp send admin
2 36.36.36.1 udp send admin
To enable the bandwidth-test server without client authentication:
[admin@MikroTik] /tool/bandwidth-server> set enabled=yes authenticate=no
enabled: yes
authenticate: no
max-sessions: 100
Bandwidth Test Client
Sub-menu: /tool/bandwidth-test
PropertyDescription
address (IP address | IPv6 prefix[%interface]; Default:)IP address of host
direction (both | receive | transmit; Default:receive)
Direction of data flow
duration (time; Default:)Duration of the test
interval (time: 20ms..5s; Default:1s)Delay between reports (in seconds)
local-tx-speed (integer 0..18446744073709551615; Default: )Transfer test maximum speed (bits per second)
local-udp-tx-size (integer: 28..64000)Local transmit packet size in bytes
password (string; Default: "")Password for the remote user
protocol (udp | tcp; Default: udp)Protocol to use
random-data (yes | no; Default: no)If random-data is set to yes, the payload of the bandwidth test packets will have an incompressible random data stream so that links that use data compression will not distort the results (this is CPU intensive and random-data should be set to no for low-speed CPUs)
remote-tx-speed (integer 0..18446744073709551615; Default: )Receive test maximum speed (bits per second)
remote-udp-tx-size (integer: 28..64000)Remote transmit packet size in bytes
connection-count (integer 1..255; Default:)Number of TCP connections to use
user (string; Default: "")Remote user
Example
To run a 15-second-long bandwidth-test to the 10.0.0.32 host sending and receiving 1000-byte UDP packets and using username admin to connect:
[admin@MikroTik] /tool> bandwidth-test 10.0.0.32 duration=15s \
\... direction=both local-udp-tx-size=1000 protocol=udp \
\... remote-udp-tx-size=1000 user=admin
status: done testing
duration: 15s
tx-current: 272.8Mbps
tx-10-second-average: 200.3Mbps
tx-total-average: 139.5Mbps
rx-current: 169.6Mbps
rx-10-second-average: 164.8Mbps
rx-total-average: 117.0Mbps
lost-packets: 373
random-data: no
direction: both
tx-size: 1000
rx-size: 1000
[admin@MikroTik] > /tool/bandwidth-test fe80::34:23ff:fe6a:570c%local
status: running
duration: 5s
rx-current: 23.9Mbps
rx-10-second-average: 15.1Mbps
rx-total-average: 15.1Mbps
lost-packets: 0
random-data: no
direction: receive
rx-size: 1500
