caps-man
caps-man/sta/registration-table
Type: Directory
| Read-only Argument | Type | Description |
| interface | interface_enum | |
| ssid | string | |
| mac-address | macAddr | |
| radio-name | string | |
| tx-rate | string | |
| rx-rate | string | |
| tx-signal | num | |
| rx-signal | num | |
| uptime | time | |
| packets | composite_arg { , } | |
| bytes | composite_arg { , } | |
| tx-rate-set | string | |
| eap-identity | string | |
| vlan-id | num | |
| last-ip | ipAddr |
caps-man/ratescfg/rates
Type: Directory
| name ( mandatory ) | string | |
| basic ( unset ) | ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps, 6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps) | |
| supported ( unset ) | ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps, 6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps) | |
| ht-basic-mcs ( unset ) | ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23) | |
| ht-supported-mcs ( unset ) | ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23) | |
| vht-basic-mcs ( unset ) | multi_arg { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } } | |
| vht-supported-mcs ( unset ) | multi_arg { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } } |
caps-man/rule/provisioning
Type: Directory
| Flag | Name | Description |
| X | disabled | disabled |
| radio-mac | macAddr | |
| hw-supported-modes | multi_arg { array-id, enum (a | a-turbo | an | ac | b | g | g-turbo | gn) { a:1, a-turbo:2, an:3, ac:5, b:0x11, g:0x12, g-turbo:0x13, gn:0x14 } } | |
| identity-regexp | string | |
| common-name-regexp | string | |
| ip-address-ranges | multi_arg { , , ip_range_arg } | |
| action | enum (none | create-enabled | create-disabled | create-dynamic-enabled) | |
| master-configuration | enum | |
| slave-configurations | multi_arg { array-id, enum } | |
| name-format | enum (cap | prefix | identity | prefix-identity) | |
| name-prefix | string |
caps-man/controller/manager
Type: Settings Directory
| enabled | bool | |
| certificate | enum (none | auto) | |
| ca-certificate | enum (none | auto) | |
| package-path | string | |
| upgrade-policy | enum (none | suggest-same-version | require-same-version) | |
| require-peer-certificate | bool |
| generated-certificate | enum (none) | |
| generated-ca-certificate | enum (none) |
caps-man/controller/manager/interface
Type: Directory
| * | default | default |
| D | dynamic | dynamic |
| interface ( mandatory ) | interface_enum { all:nv::BADID } | |
| forbid | bool |
caps-man/dpathcfg/datapath
Type: Directory
| mtu | num | |
| l2mtu | num | |
| arp | enum (disabled | enabled | proxy-arp | reply-only | local-proxy-arp) | |
| client-to-client-forwarding ( unset ) | bool | |
| bridge ( unset ) | interface_enum | |
| bridge-cost ( unset ) | num | |
| bridge-horizon ( unset ) | num | |
| openflow-switch ( unset ) | enum | |
| local-forwarding ( unset ) | bool | |
| vlan-mode ( unset ) | enum (no-tag | use-tag | use-service-tag) | |
| vlan-id ( unset ) | num | |
| interface-list ( unset ) | enum |
caps-man/acl/access-list
Type: Directory
| mac-address ( unset ) | macAddr | |
| mac-address-mask ( unset ) | macAddr | |
| interface ( unset ) | interface_enum { , any:0 } | |
| signal-range ( unset ) | composite_arg { , } | |
| allow-signal-out-of-range ( unset ) | alt { enum (always) { always:0 } , time } | |
| ssid-regexp ( unset ) | string | |
| time ( unset ) | super { time [0 .. 86400] , -time [0 .. 86400] , ,ubit (sun, mon, tue, wed, thu, fri, sat) { sun, mon, tue, wed, thu, fri, sat } } | |
| action ( unset ) | enum (accept | reject | query-radius) | |
| ap-tx-limit ( unset ) | num | |
| client-tx-limit ( unset ) | num | |
| private-passphrase ( unset ) | string | |
| radius-accounting ( unset ) | bool | |
caps-man/aaa
| mac-format | string | |
| mac-mode | enum (as-username | as-username-and-password) | |
| mac-caching | alt { enum (disabled) { disabled:0 } , time } | |
| interim-update | alt { enum (disabled) { disabled:0 } , time } | |
| called-format | enum (mac:ssid | mac | ssid) |
caps-man/cfg/configuration
Type: Directory
| security ( unset ) | enum | |
| datapath ( unset ) | enum | |
| channel ( unset ) | enum | |
| rates ( unset ) | enum | |
| mode ( unset ) | enum (ap) | |
| ssid ( unset ) | string | |
| hide-ssid ( unset ) | bool | |
| max-sta-count ( unset ) | num | |
| multicast-helper ( unset ) | enum (default | disabled | full | dhcp) | |
| tx-chains ( unset ) | ubit (0, 1, 2, 3) | |
| rx-chains ( unset ) | ubit (0, 1, 2, 3) | |
| guard-interval ( unset ) | enum (any | long) | |
| country ( unset ) | enum | |
| installation ( unset ) | enum (any | indoor | outdoor) | |
| load-balancing-group ( unset ) | enum | |
| distance ( unset ) | enum (indoors | dynamic) | |
| hw-retries ( unset ) | num | |
| hw-protection-mode ( unset ) | enum (none | rts-cts | cts-to-self) | |
| frame-lifetime ( unset ) | time | |
| disconnect-timeout ( unset ) | time | |
| keepalive-frames ( unset ) | bool | |
| authentication-types ( unset ) | ubit (wpa-psk, wpa2-psk, wpa-eap, wpa2-eap) | |
| encryption ( unset ) | ubit (aes-ccm, tkip) | |
| group-encryption ( unset ) | enum (aes-ccm | tkip) | |
| group-key-update | time | |
| eap-methods ( unset ) | multi_arg { array-id, enum (eap-tls | passthrough) { eap-tls:13, passthrough:0xffffffff } } | |
| eap-radius-accounting ( unset ) | bool | |
| tls-mode | enum (verify-certificate | dont-verify-certificate | no-certificates | verify-certificate-with-crl) | |
| tls-certificate | enum (none) | |
| disable-pmkid ( unset ) | bool | |
| mtu | num | |
| l2mtu | num | |
| interface-list ( unset ) | enum | |
| frequency ( unset ) | multi_arg { array-id, num } | |
| secondary-frequency ( unset ) | multi_arg { array-id, alt { enum (disabled) { disabled:wlc::CHANCFG_SECFREQS_DISABLED } , num } { enum (disabled) { disabled:wlc::CHANCFG_SECFREQS_DISABLED } , num } } | |
| control-channel-width ( unset ) | enum (5mhz | 10mhz | 20mhz | 40mhz-turbo) | |
| band ( unset ) | enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n | 5ghz-a/n/ac | 5ghz-n/ac | 5ghz-onlyac) | |
| extension-channel ( unset ) | enum (disabled | Ce | eC | Ceee | eCee | eeCe | eeeC | XX | XXXX | Ceeeeeee | eCeeeeee | eeCeeeee | eeeCeeee | eeeeCeee | eeeeeCee | eeeeeeCe | eeeeeeeC | XXXXXXXX) | |
| tx-power ( unset ) | num | |
| save-selected ( unset ) | bool | |
| reselect-interval ( unset ) | super { time [1 .. 60*60*24*300] , ..time [1 .. 60*60*24*300] } | |
| skip-dfs-channels ( unset ) | bool | |
caps-man/seccfg/security
Type: Directory
caps-man/ifaceactual/actual-interface-configuration
Type: Directory
| M | master | master |
| B | bound | bound |
| I | inactive | inactive |
| R | running | running |
| name | string | |
| arp-timeout | alt { enum (auto) { auto:0 } , time } | |
| disable-running-check | bool | |
| master-interface | interface_enum { none:nv::BADID } | |
| mtu | num | |
| l2mtu | num | |
caps-man/radio
Type: Directory
| L | local | local |
| P | provisioned | provisioned |
| remote-cap-name | string | |
| remote-cap-identity | string | |
caps-man/radio/provision
Type: Command
caps-man/radio/hw-info
Type: Command
| ranges | multi_arg { array-id, string } | |
| tx-chains | ubit (0, 1, 2, 3) | |
| rx-chains | ubit (0, 1, 2, 3) | |
| antenna-gain | num | |
| locked-countries | multi_arg { array-id, enum } |
caps-man/chancfg/channel
Type: Directory
caps-man/remoteap/remote-cap
Type: Directory
| state | string | |
| name | string | |
| radios | num | |
| address | super { alt { ip6Addr , macAddr } { ip6Addr , macAddr } , /num } | |
| board | string | |
| serial | string | |
| base-mac | string | |
| version | string | |
| identity | string |
caps-man/remoteap/remote-cap/provision
Type: Command
caps-man/remoteap/remote-cap/upgrade
Type: Command
caps-man/remoteap/remote-cap/set-identity
Type: Command
| identity | string |
interface/wireless
Type: Directory
| name | string | |
| mtu | num | |
| l2mtu | num | |
| prism-cardtype | enum (200mW | 100mW | 30mW) | |
| master-interface ( mandatory ) | interface_enum | |
| mode | enum (station | station-wds | ap-bridge | bridge | alignment-only | nstreme-dual-slave | wds-slave | station-pseudobridge | station-pseudobridge-clone | station-bridge) | |
| ssid | string | |
| area | string | |
| frequency-mode | enum | |
| country | enum | |
| installation | enum (any | indoor | outdoor) | |
| frequency | alt { num , enum (auto) { auto:0 } } | |
| band | enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n | 5ghz-a/n/ac | 5ghz-n/ac | 5ghz-onlyac) | |
| channel-width | enum (20mhz | 40mhz-turbo | 10mhz | 5mhz | 20/40mhz-Ce | 20/40mhz-eC | 20/40/80mhz-Ceee | 20/40/80mhz-eCee | 20/40/80mhz-eeCe | 20/40/80mhz-eeeC | 20/40/80/160mhz-Ceeeeeee | 20/40/80/160mhz-eCeeeeee | 20/40/80/160mhz-eeCeeeee | 20/40/80/160mhz-eeeCeeee | 20/40/80/160mhz-eeeeCeee | 20/40/80/160mhz-eeeeeCee | 20/40/80/160mhz-eeeeeeCe | 20/40/80/160mhz-eeeeeeeC | 20/40mhz-XX | 20/40/80mhz-XXXX | 20/40/80/160mhz-XXXXXXXX) | |
| secondary-frequency | multi_arg { array-id, enum (auto) { auto:0xffffffff } } | |
| scan-list | obj_arg { alt { enum (default) { default:0 } , super { num , -num , [ :num] } { num , -num , [ :num] } , enum () { , } } { enum (default) { default:0 } , super { num , -num , [ :num] } { num , -num , [ :num] } , enum () { , } } } | |
| wireless-protocol | enum (unspecified | any | 802.11 | nstreme | nv2 | nv2-nstreme-802.11 | nv2-nstreme) | |
| rate-set | enum (default | configured) | |
| supported-rates-b | ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps) | |
| supported-rates-a/g | ubit (6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps) | |
| basic-rates-b | ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps) | |
| basic-rates-a/g | ubit (6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps) | |
| max-station-count | num | |
| distance | enum (indoors | dynamic) | |
| tx-power | num { } | |
| tx-power-mode | enum (default | all-rates-fixed | card-rates | manual-table) | |
| noise-floor-threshold | alt { enum (default) { default:5555 } , num [-128 .. 127] } | |
| nv2-noise-floor-offset | alt { enum (default) { default:5555 } , num [0 .. 20] } | |
| burst-time | enum (disabled) | |
| dfs-test-mode (syscap=dfstest) | ubit (only-detect, duty-cycle, short-search) | |
| antenna-mode | enum (ant-a | ant-b | txa-rxb | rxa-txb) | |
| vlan-mode | enum (no-tag | use-tag | use-service-tag) | |
| vlan-id | num | |
| wds-mode | enum (disabled | static | dynamic | static-mesh | dynamic-mesh) | |
| wds-default-bridge | interface_enum { none:0xffffffff } | |
| wds-default-cost | num | |
| wds-cost-range | range_arg | |
| wds-ignore-ssid | bool | |
| update-stats-interval | alt { enum (disabled) { disabled:0 } , time [10 .. 18000] } | |
| bridge-mode | enum (enabled | disabled) | |
| default-authentication | bool | |
| default-forwarding | bool | |
| default-ap-tx-limit | num | |
| default-client-tx-limit | num | |
| wmm-support | enum (disabled | enabled | required) | |
| hide-ssid | bool | |
| security-profile | enum | |
| interworking-profile | enum (disabled) | |
| wps-mode | enum (disabled | push-button | push-button-virtual-only | push-button-5s) | |
| station-roaming | enum (disabled | enabled) | |
| disconnect-timeout | time | |
| on-fail-retry-time | time | |
| preamble-mode | enum (long | short | both) | |
| compression | bool | |
| allow-sharedkey | bool | |
| station-bridge-clone-mac | macAddr | |
| ampdu-priorities | ubit (0, 1, 2, 3, 4, 5, 6, 7) | |
| guard-interval | enum (any | long) | |
| ht-supported-mcs | ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23, mcs-24, mcs-25, mcs-26, mcs-27, mcs-28, mcs-29, mcs-30, mcs-31) | |
| ht-basic-mcs | ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23, mcs-24, mcs-25, mcs-26, mcs-27, mcs-28, mcs-29, mcs-30, mcs-31) | |
| vht-supported-mcs | multi_arg { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } } | |
| vht-basic-mcs | multi_arg { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } } | |
| amsdu-limit | num | |
| amsdu-threshold | num | |
| tdma-period-size | enum (auto | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10) | |
| nv2-queue-count | num | |
| nv2-qos | enum (default | frame-priority) | |
| nv2-cell-radius | num | |
| nv2-security | enum (disabled | enabled) | |
| nv2-preshared-key | string | |
| nv2-mode | enum (dynamic-downlink | fixed-downlink | sync-master | sync-slave) | |
| nv2-downlink-ratio | num | |
| nv2-sync-secret | string | |
| hw-retries | num | |
| frame-lifetime | num | |
| adaptive-noise-immunity | enum (none | client-mode | ap-and-client-mode) | |
| hw-fragmentation-threshold | num | |
| hw-protection-mode | enum (none | rts-cts | cts-to-self) | |
| hw-protection-threshold | num | |
| frequency-offset | num | |
| rate-selection | enum (advanced) | |
| multicast-helper | enum (default | disabled | full | dhcp) | |
| multicast-buffering | bool | |
| keepalive-frames | bool | |
| skip-dfs-channels | enum (disabled | all | 10min-cac) |
| default-name | string | |
| interface-type | enum (virtual | Atheros AR5212 | Atheros AR5211 | Atheros AR5210 | Prism | Atheros AR5213 | Atheros AR5413 | Atheros 11N | Atheros AR9271 | Atheros AR9300 | Atheros AR92xx | Atheros AR9888 | IPQ4019 | QCA9984 | QCA9888) | |
| pci-info | string |
interface/wireless/nstreme
Type: Directory
| enable-nstreme | bool | |
| enable-polling | bool | |
| disable-csma | bool | |
| framer-policy | enum (none | best-fit | exact-size | dynamic-size) | |
| framer-limit | num |
| name | string |
interface/wireless/manual-tx-power-table
Type: Directory
| manual-tx-powers | multi_arg { array-id, array-id, composite_arg { , } { , } } |
| name | string |
interface/wireless/channels
Type: Directory
| list ( mandatory ) | enum | |
| name | string | |
| frequency ( mandatory ) | num | |
| width ( mandatory ) | num | |
| band ( mandatory ) | enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n | 5ghz-a/n/ac | 5ghz-n/ac | 5ghz-onlyac) | |
| extension-channel | enum (disabled | Ce | eC | Ceee | eCee | eeCe | eeeC) |
interface/wireless/security-profiles
Type: Directory
| mode | enum (none | static-keys-optional | static-keys-required | dynamic-keys) | |
| authentication-types | ubit (wpa-psk, wpa2-psk, wpa-eap, wpa2-eap) | |
| unicast-ciphers | ubit (tkip, aes-ccm) | |
| group-ciphers | ubit (tkip, aes-ccm) | |
| wpa-pre-shared-key | string | |
| wpa2-pre-shared-key | string | |
| supplicant-identity | string | |
| eap-methods | multi_arg { array-id, enum (eap-tls | eap-ttls-mschapv2 | peap | passthrough) { eap-tls:13, eap-ttls-mschapv2:21, peap:25, passthrough:0xffffffff } } | |
| mschapv2-username | string | |
| mschapv2-password | string | |
| disable-pmkid | bool | |
| static-algo-0 | enum () | |
| static-key-0 | string | |
| static-algo-1 | enum () | |
| static-key-1 | string | |
| static-algo-2 | enum () | |
| static-key-2 | string | |
| static-algo-3 | enum () | |
| static-key-3 | string | |
| static-transmit-key | enum (key-0 | key-1 | key-2 | key-3) | |
| static-sta-private-algo | enum () | |
| static-sta-private-key | string | |
| radius-mac-authentication | bool | |
| radius-mac-accounting | bool | |
| radius-eap-accounting | bool | |
| interim-update | time | |
| radius-mac-format | enum (XX:XX:XX:XX:XX:XX | XXXX:XXXX:XXXX | XXXXXX:XXXXXX | XX-XX-XX-XX-XX-XX | XXXXXX-XXXXXX | XXXXXXXXXXXX | XX XX XX XX XX XX | xx:xx:xx:xx:xx:xx | xxxx:xxxx:xxxx | xxxxxx:xxxxxx | xx-xx-xx-xx-xx-xx | xxxxxx-xxxxxx | xxxxxxxxxxxx | xx xx xx xx xx xx) | |
| radius-mac-mode | enum (as-username | as-username-and-password) | |
| radius-called-format | enum (mac:ssid | mac | ssid) | |
| radius-mac-caching | alt { enum (disabled) { disabled:0 } , time } | |
| management-protection | enum (allowed | required | disabled) | |
| management-protection-key | string |
interface/wireless/interworking-profiles
Type: Directory
| network-type | enum (private | private-with-guest | public-chargeable | public-free | personal-device | emergency-only | test | wildcard) | |
| internet | bool | |
| asra | bool | |
| esr | bool | |
| uesa | bool | |
| venue | enum (unspecified | disabled) | |
| hessid | macAddr | |
| hotspot20 | bool | |
| hotspot20-dgaf | bool | |
| roaming-ois | multi_arg { array-id, string } | |
| venue-names | obj_arg { composite_arg { , } { , } } | |
| authentication-types | obj_arg { composite_arg { , } { , } } | |
| ipv4-availability | enum (not-available | public | port-restricted | single-nated | double-nated | port-restricted-single-nated | port-restricted-double-nated | unknown) | |
| ipv6-availability | enum (not-available | available | unknown) | |
| realms | obj_arg { composite_arg { , } { , } } | |
| realms-raw | multi_arg { array-id, string } | |
| 3gpp-raw | string | |
| 3gpp-info | obj_arg { composite_arg { , } { , } } | |
| domain-names | multi_arg { array-id, string } | |
| operator-names | obj_arg { composite_arg { , } { , } } | |
| wan-status | enum (reserved | up | down | test) | |
| wan-symmetric | bool | |
| wan-at-capacity | bool | |
| wan-downlink | num | |
| wan-uplink | num | |
| wan-downlink-load | num | |
| wan-uplink-load | num | |
| wan-measurement-duration | num | |
| connection-capabilities | obj_arg { composite_arg { , } { , } } | |
| operational-classes | multi_arg { array-id, num } |
interface/wireless/nstreme-dual
Type: Directory
| name | string | |
| mtu | num | |
| l2mtu | num | |
| tx-radio | interface_enum | |
| rx-radio | interface_enum | |
| remote-mac | macAddr | |
| tx-band | enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n) | |
| tx-channel-width | enum (20mhz | 40mhz | 10mhz | 5mhz) | |
| tx-frequency | num | |
| rx-band | enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n) | |
| rx-channel-width | enum (20mhz | 40mhz | 10mhz | 5mhz) | |
| rx-frequency | num | |
| ht-rates | ubit (1, 2, 3, 4, 5, 6, 7, 8) | |
| ht-guard-interval | enum (long | short | both) | |
| ht-channel-width | enum (20mhz | 40mhz | 2040mhz) | |
| ht-streams | enum (single | double | both) | |
| framer-policy | enum (none | best-fit | exact-size) | |
interface/wireless/nstreme-dual/reset-counters
Type: Command
interface/wireless/nstreme-dual/monitor
Type: Command
| rx-signal-strength | num | |
| tx-signal-strength | num | |
| connected | bool | |
| frames | composite_arg { , } | |
| frame-bytes | composite_arg { , } | |
| hw-frames | composite_arg { , } | |
| hw-frame-bytes | composite_arg { , } | |
| tx-retries-timeout | num | |
| tx-retries-lost | num | |
| rx-bad-seqs | num | |
| rx-duplicates | num |
interface/wireless/wds
Type: Directory
| name | string | |
| mtu | num | |
| l2mtu | num | |
| master-interface | interface_enum | |
| wds-address | macAddr |
interface/wireless/wds/monitor
Type: Command
| active | bool |
interface/wireless/reset-configuration
Type: Command
interface/wireless/reset-mac-address
Type: Command
interface/wireless/wps-push-button
Type: Command
interface/wireless/scan
Type: Command
| A | active | active |
| P | privacy | privacy |
| R | routeros-network | routeros-network |
| N | nstreme | nstreme |
| T | tdma | tdma |
| W | wds | wds |
| B | bridge | bridge |
| background | bool | |
| save-file | string | |
| rounds | num | |
| passive | bool |
| ssid | string | |
| channel | string | |
| sig | num | |
| nf | num | |
| snr | num | |
| routeros-version | string |
interface/wireless/frequency-monitor
Type: Command
| freq | num | |
| use | num | |
| nf | num |
interface/wireless/info
Type: Directory
interface/wireless/info/country-info
Type: Command
| country | enum |
interface/wireless/info/scan-list
Type: Command
| country | enum | |
| channel-width | enum (20mhz | 40mhz-turbo | 10mhz | 5mhz | 20/40mhz-Ce | 20/40mhz-eC | 20/40/80mhz-Ceee | 20/40/80mhz-eCee | 20/40/80mhz-eeCe | 20/40/80mhz-eeeC) | |
| dfs-mode | enum (none | no-radar-detect | radar-detect) | |
| channels | multi_arg { array-id, string } |
interface/wireless/info/default-scan-list
Type: Command
| country | enum | |
interface/wireless/info/country-list
Type: Command
| countries | multi_arg { array-id, string } |
interface/wireless/info/allowed-channels
Type: Command
| country | enum | |
interface/wireless/info/hw-info
Type: Command
| extra-info | string | |
interface/wireless/align
| frame-size | num | |
| active-mode | bool | |
| receive-all | bool | |
| audio-monitor | macAddr | |
| filter-mac | macAddr | |
| ssid-all | bool | |
| frames-per-second | num | |
| audio-min | num | |
| audio-max | num |
interface/wireless/align/monitor
Type: Command
| A | access-point | access-point |
| ssid | string | |
| rxq | num | |
| avg-rxq | num | |
| last-rx | num | |
| txq | num | |
| last-tx | num | |
| correct | num |
interface/wireless/align/test-audio
Type: Command
| test-value | num |
interface/wireless/connect-list
Type: Directory
| connect | bool | |
| ssid | string | |
| signal-range | composite_arg { , } | |
| allow-signal-out-of-range | alt { enum (always) { always:0 } , time } | |
| area-prefix | string | |
| security-profile | enum (none) | |
| wireless-protocol | enum (any | 802.11 | nstreme | tdma) | |
| interworking | enum () | |
| iw-network-type | enum () | |
| iw-venue | enum (any | assembly | business | educational | industrial | institutional | mercantile | residential | storage | utility | vehicular | outdoor) | |
| iw-hessid | macAddr | |
| iw-internet | enum () | |
| iw-asra | enum () | |
| iw-esr | enum () | |
| iw-uesa | enum () | |
| iw-hotspot20 | enum () | |
| iw-hotspot20-dgaf | enum () | |
| iw-roaming-ois | multi_arg { array-id, string } | |
| iw-authentication-types | obj_arg { enum (terms-and-conditions | online-enrollment | https-redirection | dns-redirection) { terms-and-conditions:0, online-enrollment:1, https-redirection:2, dns-redirection:3 } } | |
| iw-ipv4-availability | enum (any | not-available | public | port-restricted | single-nated | double-nated | port-restricted-single-nated | port-restricted-double-nated | unknown) | |
| iw-ipv6-availability | enum (any | not-available | available | unknown) | |
| iw-realms | obj_arg { composite_arg { , } { , } } | |
| 3gpp | string | |
| iw-connection-capabilities | obj_arg { composite_arg { , } { , } } |
interface/wireless/access-list
Type: Directory
| interface | interface_enum { , any:0 } | |
| private-algo | enum (none | 40bit-wep | 104bit-wep | aes-ccm | tkip) | |
| private-pre-shared-key | string | |
| time | super { time [0 .. 86400] , -time [0 .. 86400] , ,ubit (sun, mon, tue, wed, thu, fri, sat) { sun, mon, tue, wed, thu, fri, sat } } | |
| management-protection-key | string | |
| vlan-mode | enum (default | no-tag | use-tag | use-service-tag) | |
| vlan-id | num |
interface/wireless/registration-table
Type: Directory
| ap | bool | |
| wds | bool | |
| bridge | bool | |
| packed-frames | composite_arg { , } | |
| packed-bytes | composite_arg { , } | |
| tx-frames-timed-out | num | |
| uptime | time | |
| last-activity | time | |
| signal-strength | composite_arg { , } | |
| signal-to-noise | num | |
| signal-strength-ch0 | num | |
| signal-strength-ch1 | num | |
| signal-strength-ch2 | num | |
| signal-strength-ch3 | num | |
| tx-signal-strength-ch0 | num | |
| tx-signal-strength-ch1 | num | |
| tx-signal-strength-ch2 | num | |
| tx-signal-strength-ch3 | num | |
| evm-ch0 | num | |
| evm-ch1 | num | |
| evm-ch2 | num | |
| evm-ch3 | num | |
| tx-evm-ch0 | num | |
| tx-evm-ch1 | num | |
| tx-evm-ch2 | num | |
| tx-evm-ch3 | num | |
| strength-at-rates | multi_arg { , , , super { num , @enum () { } , time } { num , @enum () { } , time } } | |
| tx-ccq | num | |
| rx-ccq | num | |
| p-throughput | num | |
| ack-timeout | num | |
| distance | num | |
| nstreme | bool | |
| nstreme-plus | bool | |
| framing-mode | enum (none | best-fit | exact-size) | |
| framing-limit | num | |
| framing-current-size | num | |
| routeros-version | string | |
| last-ip | ipAddr | |
| 802.1x-port-enabled | bool | |
| authentication-type | enum (wpa-psk | wpa2-psk | wpa-eap | wpa2-eap) | |
| encryption | enum () | |
| group-encryption | enum () | |
| management-protection | bool | |
| wmm-enabled | bool | |
| wmm-ps-enabled | bool | |
| vlan-id | num | |
| tdma-timing-offset | num | |
| tdma-tx-size | num | |
| tdma-rx-size | num | |
| tdma-retx | num | |
| tdma-winfull | num | |
interface/wireless/registration-table/reset-counters
Type: Command
interface/wireless/monitor
Type: Command
| status | enum (disabled | searching-for-network | connected-to-ess | initializing | searching-for-frequency | radar-detecting | running-ap | tkip-countermeasures | nstreme-dual-slave) | |
| status-reason | string | |
| wireless-protocol | enum (802.11 | nstreme | nv2) | |
| nstreme-status | bool | |
| ssid | string | |
| bssid | macAddr | |
| noise-floor | num | |
| tx-ccq | num | |
| rx-ccq | num | |
| overall-tx-ccq | num | |
| registered-clients | num | |
| authenticated-clients | num | |
| current-ack-timeout | num | |
| current-distance | num | |
| wds-link | bool | |
| bridge | bool | |
| nstreme | bool | |
| polling | bool | |
| csma-disabled | bool | |
| nv2-sync-state | enum (searching | syncing | synced) | |
| nv2-sync-master | macAddr | |
| nv2-sync-distance | num | |
| nv2-sync-period-size | num | |
| nv2-sync-downlink-ratio | num | |
| current-tx-powers | multi_arg { , , , , super { enum () { } , :num , (num , num } { enum () { } , :num , (num , num } } | |
| current-ofdm-errors | num | |
| current-cck-errors | num | |
| 1s-frames | composite_arg { , } | |
| 1s-compressed-frames | num | |
| 1s-bytes | composite_arg { , } | |
| 1s-length-of-orig | num | |
| total-frames | composite_arg { , } | |
| total-compressed-frames | num | |
| total-bytes | composite_arg { , } | |
| total-length-of-orig | num | |
| notify-external-fdb | bool | |
| cloned-mac-address | macAddr | |
| searching-for-address-to-clone | bool |
interface/wireless/spectral-scan
Type: Command
| range | alt { range_arg [ .. 7000] , enum (2.4ghz | 5ghz | current-channel) { 2.4ghz:1, 5ghz:2, current-channel:3 } } | |
| show-interference | bool | |
| samples | num | |
| buckets | num | |
| peak-hold-time | time | |
| save-file-name | string |
| freq | num | |
| interference | composite_arg { , } | |
| dbm | num | |
| graph | meter_arg |
interface/wireless/snooper
| multiple-channels | bool | |
| channel-time | time | |
| receive-errors | bool |
interface/wireless/snooper/flat-snoop
Type: Command
| type | enum (frequency | network | station) | |
| use | num | |
| bitrate | alt { num , num , num } | |
| frequency-network-count | num | |
| frequency-station-count | num | |
| active | alt { bool , bool } | |
| frequency-known | bool | |
| beacon-seen | bool | |
| address | alt { macAddr , macAddr } | |
| network-ssid | string | |
| beacon-hides-ssid | bool | |
| beacon-interval | num | |
| beacon-rate | string | |
| last-beacon | time | |
| beacon-strength | num | |
| signal-to-noise | alt { num , num } | |
| ssid-source | enum (none | association-discussion | probe-response | beacon) | |
| supported-rates | multi_arg { array-id, enum () { } } | |
| basic-rates | multi_arg { array-id, enum () { } } | |
| network-capabilities | multi_arg { array-id, enum () { } } | |
| mt-network | bool | |
| mt-info | multi_arg { array-id, enum (nstreme | doing-wds | without-polling | dynamic-packing-size) { nstreme:0, doing-wds:2, without-polling:3, dynamic-packing-size:4 } } | |
| mt-name | alt { string , string } | |
| mt-routeros-version | alt { string , string } | |
| mt-mru | alt { num , num } | |
| mt-framing-mode | enum (none | best-fit | exact-size) | |
| network-station-count | num | |
| use-of-freq | alt { num , num } | |
| use-of-traffic | alt { num , num } | |
| freq-source | enum (seen-frame-on-freq | network-on-freq) | |
| last-seen | time | |
| network-source | enum (none | seen-data-frame | seen-successful-auth | seen-successful-assoc | forms-network) | |
| seen-wep | bool | |
| station-rates | multi_arg { array-id, enum () { } } | |
| station-capabilities | multi_arg { array-id, enum () { } } | |
| mt-station | bool | |
| assoc-capabilities | multi_arg { array-id, enum () { } } | |
| assoc-id | num | |
| assoc-mt-info | multi_arg { array-id, enum (nstreme | doing-wds | without-polling | dynamic-packing-size) { nstreme:0, doing-wds:2, without-polling:3, dynamic-packing-size:4 } } | |
| assoc-mt-ap-tx-limit | num | |
| assoc-mt-client-tx-limit | num | |
| assoc-mt-framing-mode | enum (none | best-fit | exact-size) | |
| assoc-mt-framing-limit | num |
interface/wireless/cap
| enabled | bool | |
| interfaces | multi_arg { array-id, interface_enum } | |
| certificate | enum (request | none) | |
| lock-to-caps-man | bool | |
| discovery-interfaces | multi_arg { array-id, interface_enum } | |
| caps-man-addresses | multi_arg { array-id, ip6Addr } | |
| caps-man-names | multi_arg { array-id, string } | |
| caps-man-certificate-common-names | multi_arg { array-id, string } | |
| static-virtual | bool |
| requested-certificate | enum (none) | |
| locked-caps-man-common-name | string |
interface/wireless/sniffer
| only-headers | bool | |
| receive-errors | bool | |
| memory-limit | num | |
| file-name | string | |
| file-limit | num | |
| streaming-enabled | bool | |
| streaming-server | ipAddr | |
| streaming-max-rate | num |
interface/wireless/sniffer/sniff
Type: Command
| processed-packets | num | |
| file-size | num | |
| file-saved-packets | num | |
| file-over-limit-packets | num | |
| memory-size | num | |
| memory-saved-packets | num | |
| memory-over-limit-packets | num | |
| stream-dropped-packets | num | |
| stream-sent-packets | num | |
| real-file-limit | num | |
| real-memory-limit | num |
interface/wireless/sniffer/save
Type: Command
interface/wireless/sniffer/packet
Type: Directory
| E | crc-error | crc-error |
| time | num | |
| signal-at-rate | composite_arg { , } | |
| dst | macAddr | |
| src | macAddr | |
| type | enum (assoc-req | assoc-resp | reassoc-req | reassoc-resp | probe-req | probe-resp | beacon | atim | disassoc | auth | deauth | ps-poll | rts | cts | ack | cf-end | cf-endack | data | d-cfack | d-cfpoll | d-cfackpoll | data-null | nd-cfack | nd-cfpoll | nd-cfackpoll) |
interface/wireless/wps-client
Type: Command
| ssid | string | |
| create-profile | string |
| status | string | |
| ssid | string | |
| passphrase | string | |
| authentication | string | |
| encryption | string |
interface/wireless/setup-repeater
Type: Command
| ssid | string | |
| country | enum |
| status | string |
caps-man/interface
Type: Directory
| M | master | |
| D | dynamic | |
| B | bound | |
| X | disabled | |
| I | inactive | |
| R | running |
| name | string | |
| configuration ( unset ) | enum | |
| mtu | num | |
| l2mtu | num | |
| current-state | string | |
| current-channel | string | |
| current-rate-set | string | |
| current-basic-rate-set | string | |
| current-registered-clients | num | |
| current-authorized-clients | num |
caps-man/interface/hw-info
Type: Command
caps-man/interface/possible-channels
Type: Command
caps-man/interface/reselect-channel
Type: Command
caps-man/interface/scan
Type: Command
| A | active | |
| P | privacy | |
| R | routeros-network | |
| N | nstreme | |
| T | tdma | |
| W | wds | |
| B | bridge |
| rounds | num |
| ssid | string | |
| sig | num | |
| nf | num | |
| snr | num | |
