tr069-client
tr069-client
Type: Settings Directory
| Argument | Type | Description |
| enabled | bool | |
| acs-url | string | |
| username | string | |
| password | string | |
| periodic-inform-enabled | bool | |
| periodic-inform-interval | time | |
| connection-request-username | string | |
| connection-request-password | string | |
| connection-request-port | num | |
| provisioning-code | string | |
| client-certificate | enum (none) | |
| check-certificate | enum (yes | no) |
| Read-only Argument | Type | Description |
| status | enum (disabled | initializing | error | waiting-url | running) | |
| last-session-error | string | |
| retry-count | num |
tr069-client/reset-tr069-config
Type: Command
