Skip to main content
Version: 7.25
Kid Control
Sub-menu: /ip/kid-control
"Kid control" is a parental control feature to limit internet connectivity for LAN devices.
Property Description​
In this menu, it is possible to create a profile for each kid and restrict internet accessibility.
PropertyDescription
name (string)Name of the Kid's profile
mon,tue,wed,thu,fri,sat,sun (time)Each day of the week. Time of day when internet access should be allowed
disabled (yes | no)Whether the profile is disabled
rate-limit (string)The maximum available data rate for flow
tur-mon,tur-tue,tur-wed,tur-thu,tur-fri,tur-sat,tur-sun (time)Time unlimited rate. Time of day when internet access should be unlimited
Time-unlimited rate parameters have higher priority than rate-limit parameter.
Devices​
Sub-menu: /ip/kid-control/device
This sub-menu contains information about whether there are multiple devices connected to the internet (phone, tablet, gaming console, tv etc.). The device is identified by the MAC address that is retrieved from the ARP table. The appropriate IP address is taken from there.
PropertyDescription
name (string)Name of the device
mac-address (string)Device's mac-address
user (string)Profile to append the device to
reset-counters ([id, name])Reset bytes-up and bytes-down counters.
Application example​
With the following example we will restrict access for Peter's mobile phone:
  • Disables internet access on Monday, Wednesday and Friday
  • Allows unlimited internet access on:
    • Tuesday
    • Thursday from 11:00-22:00
    • Sunday 15:00-21:00
  • Limits bandwidth to 3Mbps for Peter's mobile phone on Saturday from 18:30-22:00
[admin@MikroTik] > /ip/kid-control/add name=Peter mon="" tur-tue="00:00-24h" wed="" tur-thu="11:00-22:00" fri="" sat="18:30-22:00" tur-sun="15h-21h" rate-limit=3M
[admin@MikroTik] > /ip/kid-control/device/add name=Mobile-phone user=Peter mac-address=FF:FF:FF:ED:83:63
Internet access limitation is implemented by adding dynamic firewall filter rules or simple queue rules. Here are example firewall filter rules:
[admin@MikroTik] > /ip/firewall/filter/print
1 D ;;; Mobile-phone, kid-control
chain=forward action=reject src-address=192.168.88.254
2 D ;;; Mobile-phone, kid-control
chain=forward action=reject dst-address=192.168.88.254
Dynamically created simple queue:
[admin@MikroTik] > /queue/simple/print
name="queue1" target=192.168.88.254/32 parent=none packet-marks="" priority=8/8 queue=default-small/default-small limit-at=3M/3M max-limit=3M/3M burst-limit=0/0
burst-threshold=0/0 burst-time=0s/0s bucket-size=0.1/0.1
It is possible to monitor how much data is used by the specific device:
[admin@MikroTik] > /ip/kid-control/device/print stats
Flags: X - disabled, D - dynamic, B - blocked, L - limited, I - inactive
# NAME IDLE-TIME RATE-DOWN RATE-UP BYTES-DOWN BYTES-UP
1 BI Mobile-phone 30s 0bps 0bps 3438.1KiB 8.9KiB
It is also possible to pause Internet access for the created kids; it will restrict all access until resume is used, which will continue with configured settings:
[admin@MikroTik] > /ip/kid-control/pause Peter
[admin@MikroTik] > /ip/kid-control/print
Flags: X - disabled, P - paused, B - blocked, L - rate-limited
# NAME SUN MON TUE WED THU FRI SAT
0 PB Peter 15h-21h 11h-22h 18:30h-22h
