Connection tracking
CLI reference:/ip/firewall/connection/tracking/ip/firewall/connection/ip/firewall/filter
Connection tracking allows the kernel to keep track of all logical network connections or sessions, and thereby relate all of the packets which may make up that connection.
NAT relies on this information to translate all related packets in the same way.
Because of connection tracking you can use stateful firewall functionality even with stateless protocols such as UDP.
Firewall features affected by connection tracking
- NAT
- Firewall:
- connection-bytes
- connection-mark
- connection-type
- connection-state
- connection-limit
- connection-rate
- layer7-protocol
- new-connection-mark
- tarpit
The list of tracked connections can be seen in /ip/firewall/connection for IPv4 and /ipv6/firewall/connection for IPv6.
[admin@3C22-atombumba] /ip/firewall/connection> print
Flags: S - seen-reply, A - assured
# PR.. SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT
0 udp 10.5.8.176:5678 255.255.255.255:5678 0s
1 udp 10.5.101.3:646 224.0.0.2:646 5s
2 ospf 10.5.101.161 224.0.0.5 9m58s
3 udp 10.5.8.140:5678 255.255.255.255:5678 8s
4 SA tcp 10.5.101.147:48984 10.5.101.1:8291 established 4m59s
[admin@3C22-atombumba] /ipv6/firewall/connection> print
Flags: S - seen reply, A - assured
# PRO.. SRC-ADDRESS DST-ADDRESS TCP-STATE
0 udp fe80::d6ca:6dff:fe77:3698 ff02::1
1 udp fe80::d6ca:6dff:fe98:7c28 ff02::1
2 ospf fe80::d6ca:6dff:fe73:9822 ff02::5
Connection states
Based on connection table entries, an arrived packet can get assigned one of the connection states: new, invalid, established, related, or untracked.
There are two different methods when the packet is considered new. The first one is in the case of stateless connections (like UDP) when there is no connection entry in the connection table. The other one is in the case of a stateful protocol (TCP). In this case, a new packet that starts a new connection is always a TCP packet with an SYN flag.
If a packet is not new, it can belong to either an established or related connection or not belong to any connection, making it invalid. A packet with an established state, as most of you already guessed, belongs to an existing connection from the connection tracking table. A related state is very similar, except that the packet belongs to a connection that is related to one of the existing connections, for example, ICMP error packets or FTP data connection packets.
Connection state untracked is a special case when RAW firewall rules are used to exclude the connection from connection tracking. This rule would make all forwarded traffic bypass the connection tracking, improving packet processing speed through the device.
Any other packet is considered invalid and in most cases should be dropped.
Based on this information we can set a basic set of filter rules to speed up packet filtering and reduce the load on the CPU by accepting established/related packets, dropping invalid packets, and working on more detailed filtering only for new packets.
/ip/firewall/filter
add chain=input connection-state=invalid action=drop comment="Drop Invalid connections"
add chain=input connection-state=established,related,untracked action=accept comment="Allow Established/Related/Untracked connections"
Such a rule set must not be applied to routers with asymmetric routing, because asymmetrically routed packets may be considered invalid and dropped.
FastTrack
IPv4 FastTrack is a special handler that bypasses Linux facilities, allowing for faster packet forwarding. The handler is used for TCP and UDP connections marked with the fasttrack-connection action. The IPv4 FastTrack handler supports NAT (SNAT, DNAT, or both).
Note that not all packets of the connection can be FastTracked, so you are likely to see some packets going through a slow path even though the connection is marked for FastTrack. This is the reason why fasttrack-connection is usually followed by an identical action=accept rule.
FastTrack-ed packets are bypassing:
- Firewall.
- Connection tracking.
- Simple queues.
- Queue tree with parent=global.
- IP accounting.
- IPSec.
- Hotspot universal client.
- VRF assignment.
It is up to the administrator to make sure FastTrack does not interfere with other configuration.
Requirements
IPv4 FastTrack is active if the following conditions are met:
- No mesh, metarouter interface configuration.
- Sniffer, torch, or traffic generator is not running.
/tool/mac-scanis not actively used./tool/ip-scanis not actively used.- FastPath and Route cache are enabled under IP/Settings.
Example
For example, for SOHO routers with factory-default configuration, you could FastTrack all LAN traffic with this one rule placed at the top of the Firewall Filter. The same configuration accept rule is required:
/ip/firewall/filter/add chain=forward action=fasttrack- connection-state=established,related
/ip/firewall/filter/add chain=forward action=accept connection-state=established,related
- Connection is FastTracked until the connection is closed, timed out, or the router is rebooted.
- Dummy rules will disappear only after FastTrack firewall rules are deleted/disabled and the router is rebooted.
- While FastPath and FastTrack both are enabled on the device only one can be active at a time.
Warning: Queues (except Queue Trees parented to interfaces), firewall filter, and mangle rules will not be applied to FastTracked traffic.
Connection tracking settings
Connection tracking settings are managed from the /ip/firewall/connection/tracking menu.
Properties
| Property | Description |
| enabled (yes | no | auto; Default: auto) | Allows disabling or enabling connection tracking. With disabled connection tracking firewall features listed above will stop working. If set to "auto" connection tracking is disabled until at least one firewall rule is added. |
| liberal-tcp-tracking (yes | no; Default: no) | Enables or disables liberal TCP connection tracking by toggling the kernel parameter nf_conntrack_tcp_be_liberal. When set to yes, the system marks only out of window RST segments as INVALID. Caution: Enabling this setting may allow malformed packets that would otherwise be considered invalid by the firewall's connection-state matcher. This can increase exposure to certain evasion techniques. This property should be enabled only when troubleshooting or working around known issues. |
| loose-tcp-tracking (*yes | no*; Default: yes) |
| tcp-syn-sent-timeout (time; Default: 5s) | TCP SYN timeout. |
| tcp-syn-received-timeout (time; Default: 5s) | TCP SYN timeout. |
| tcp-established-timeout (time; Default: 1d) | Time after which established TCP connection times out. |
| tcp-fin-wait-timeout (time; Default: 10s) | |
| tcp-close-wait-timeout (time; Default: 10s) | |
| tcp-last-ack-timeout (time; Default: 10s) | |
| tcp-time-wait-timeout (time; Default: 10s) | |
| tcp-close-timeout (time; Default: 10s) | |
| udp-timeout (time; Default: 30s) | Specifies the timeout for UDP connections that have seen packets in one direction |
| udp-stream-timeout (time; Default: 3m) | Specifies the timeout of UDP connections that have seen packets in both directions |
| icmp-timeout (time; Default: 10s) | ICMP connection timeout |
| generic-timeout (time; Default: 10m) | Timeout for all other connection entries |
| tcp-max-retrans-timeout | |
| tcp-unacked-timeout |
Read-only properties
| max-entries (integer) | Max amount of entries that the connection tracking table can hold. This value depends on the installed amount of RAM. Note that the system does not create a maximum-size connection tracking table when it starts; it may increase if the situation demands it and the system still has free RAM, but the size will not exceed 1048576 |
| total-entries (integer) | Amount of connections that the connection table currently holds |
| active-ipv4 | |
| active-ipv6 | |
| total-ip4-entries | |
| total-ip6-entries |
Connection List
Properties
All properties in the connection list are read-only
| assured (yes | no) | Indicates that this connection is assured and that it will not be erased if the maximum possible tracked connection count is reached. |
| confirmed (yes | no) | Connection is confirmed and a packet is sent out from the device |
| connection-mark (string) | Connection mark that was set by the mangle rule. |
| connection-type (pptp | ftp) | Type of connection, the property is empty if connection tracking is unable to determine a predefined connection type. |
| dst-address (ip) | Destination address. |
| dst-port(integer) | Destination port. |
| dstnat (yes | no) | A connection has gone through DST-NAT (for example, port forwarding). |
| dying (yes | no) | The connection is dying due to a connection timeout. |
| expected (yes | no) | Connection is set up using connection helpers (pre-defined service rules). |
| fasttrack (yes | no) | Whether the connection is FastTracked. |
| gre-key (integer) | Contents of the GRE Key field. |
| gre-protocol (string) | Protocol of the encapsulated payload. |
| gre-version (string) | A version of the GRE protocol was used in the connection. |
| hw-offload(yes | no) | Hardware offloaded connection. |
| icmp-code (string) | ICMP Code Field |
| icmp-id (integer) | Contains the ICMP ID |
| icmp-type (integer) | ICMP Type Number |
| orig-bytes (integer) | Number of bytes sent out from the source address using the specific connection. |
| orig-fasttrack-bytes (integer) | Number of FastTracked bytes sent out from the source address using the specific connection. |
| orig-fasttrack-packets (integer) | Number of FastTracked packets sent out from the source address using the specific connection. |
| orig-packets (integer) | Number of packets sent out from the source address using the specific connection. |
| orig-rate (integer) | The data rate at which packets are sent out from the source address using the specific connection. |
| protocol (string) | IP protocol type |
| repl-bytes (integer) | Number of bytes received from the destination address using the specific connection. |
| repl-fasttrack-bytes (integer) | Number of FastTracked bytes received from the destination address using the specific connection. |
| repl-fasttrack-packets (integer) | Number of FastTracked packets received from the destination address using the specific connection. |
| repl-packets (integer) | Number of packets received from the destination address using the specific connection. |
| repl-rate (string) | The data rate at which packets are received from the destination address using the specific connection. |
| reply-dst-address (ip) | Destination address expected for return packets. |
| reply-dst-port(integer) | Destination port expected for return packets. |
| reply-src-address (ip) | Source address expected for return packets. |
| reply-src-port (integer) | Source port expected for return packets. |
| seen-reply (yes | no) | The destination address has replied to the source address. |
| src-address (ip) | The source address. |
| src-port(integer) | The source port. |
| srcnat (yes | no) | Connection is going through SRC-NAT, including packets that were masqueraded through NAT. |
| tcp-state (string) | The current state of the TCP connection:
| timeout (time) | Time after which connection will be removed from the connection list. |
| uses-helper(yes | no) | "IP/Firewall/Service Port" helper has been applied to the particular connection. |
