DNS update
CLI reference:/tool/dns-update
The /tool/dns-update command sends one dynamic update (RFC 2136) to the authoritative DNS server of a zone and points a name in that zone at an IPv4 address. The update is signed with a TSIG key (RFC 8945), so the server can check that it comes from you, as in a secure dynamic update (RFC 3007). Use it for a zone that you run yourself, for example on a BIND server.
You do not need this command in two common cases:
- For a name that follows the router's own public address without running a DNS server, use the DDNS service of IP Cloud.
- Dynamic DNS services that take updates over HTTP, such as DynDNS, are updated with Fetch instead.
Prerequisites
- A DNS server that is authoritative for the zone and accepts dynamic updates over TCP port 53.
- A TSIG key that the server accepts for updates of the zone, with the algorithm hmac-md5. RouterOS signs with hmac-md5 only; the command has no algorithm setting.
- The name of the key and its secret in base64, as configured on the server. For example on BIND, create the key with
tsig-keygen -a hmac-md5 dns-update-key, because BIND creates keys with another algorithm by default, and allow this key to update only the name it needs (update-policy). - A router clock that differs from the server's clock by less than 5 minutes. The signature allows 300 seconds of difference, so keep the clock synchronized with NTP.
- A firewall on the server side that accepts TCP port 53 from the router.
Point a name at an address
Point office.example.com at 198.51.100.20 on the DNS server 192.0.2.53, with the key dns-update-key. Replace the key with the base64 secret of your key, and keep the quotes, because a base64 value can end in =:
/tool/dns-update dns-server=192.0.2.53 zone=example.com \
name=office address=198.51.100.20 ttl=300 \
key-name=-update-key key="c2VjcmV0LWtleS1mb3ItZXhhbXBsZQ=="
ttl=300 keeps the record for 5 minutes in the caches of other DNS servers, so they pick up a changed address soon. Without ttl, the record gets one day.
When the server accepts the update, the command prints nothing. When it does not, the command stops with a failure: message; the Troubleshoot section lists what each one means.
How the parameters work:
nameis relative tozone:name=officewithzone=example.comupdatesoffice.example.com. A full name is doubled:name=office.example.comupdatesoffice.example.com.example.com. A name with a trailing dot is refused withfailure: bad name.- The update first deletes all A records of the name and then adds the new one, so it replaces the address instead of adding a second one.
ttlsets the time to live of the record in seconds. Withoutttl, the record gets 86400 seconds (one day), which is long for an address that changes.addresstakes one IPv4 address. Two addresses fail withfailure: only one address allowed, and an IPv6 address is refused. The command updates A records only.
Keep the name current
The command sends one update each time it runs. To keep a name pointing at an address that changes, run it from a script when the address changes, for example from the lease script of the DHCP client on the WAN interface, or regularly from a scheduler entry. The script reads the current address, removes the prefix length (see Strip netmask), and passes the address to /tool/dns-update.
Things to keep in mind for such a script:
- Each update changes the zone on the server. Compare the address with the address the name has now (
:resolve), and send the update only when it differs. - At startup, wait until NTP has synchronized the clock, so that the server accepts the signature.
- Behind NAT or carrier-grade NAT, the address on the WAN interface is not the public one. The router's public address is in
public-addressof IP Cloud. - The key is part of the command, so every user who can read the script can read the key.
Troubleshoot
| Message | Meaning |
failure: update send failed | The router could not open a TCP connection to port 53 of the server: the server is down, does not listen on TCP, or a firewall blocks it. |
failure: reply not signed | The server rejected the signature, for example because the key name or the key is wrong. |
failure: refused | The server refuses the update, for example because the key has no permission to update this zone, or because the update was sent without a key. |
failure: name not within zone | The name is not in the zone. Check zone and name. |
failure: bad name | name is not valid, for example because it ends with a dot. |
Technical details
Protocol
The update goes to TCP port 53 of dns-server. The message is a DNS UPDATE for the zone (zone section example.com. IN SOA). Its update section deletes the A records of the name (office.example.com. ANY A) and adds the new record (office.example.com. 86400 IN A 198.51.100.20).
Signature
With key-name and key, the message carries a TSIG record with the algorithm hmac-md5.sig-alg.reg.int and a fudge of 300 seconds, the allowed clock difference. key is the base64 secret of the key. Without key-name and key, the update is sent unsigned, and most servers refuse it.
For all parameters, see the /tool/dns-update CLI reference.
