Skip to main content
Version: 7.25
Detect Internet
Detect Internet watches the interfaces in detect-interface-list and gives each one a state: whether it has a link, whether the router's route to the internet goes through it, and whether MikroTik's cloud server answers through it. It adds each interface to the LAN, WAN or internet interface list you name, so settings and scripts that use those lists follow the current state of the interfaces.
Detect Internet is off by default (detect-interface-list=none), and the hAP ax² default configuration does not turn it on. While it runs, the router contacts cloud.mikrotik.com on UDP port 30000 to check the internet state, see Communication with MikroTik Cloud Services.
note
Detect Internet changes the members of the interface lists by itself. Rules and settings that use these lists change their effect whenever an interface changes its state.
See which interface has internet​
Create a list for the interfaces with internet, and watch all interfaces:
/interface/list/add name=internet
/interface/detect-internet/set detect-interface-list=all \
internet-interface-list=internet
The state of each interface shows in the state menu:
[admin@MikroTik] > /interface/detect-internet/state/print
Columns: NAME, STATE, STATE-CHANGE-TIME, CLOUD-RTT
# NAME STATE STATE-CHANGE-TIME CLOUD-RTT
0 lo lan 2026-10-01 13:48:56
1 ether1 no-link 2026-10-01 13:48:56
2 ether2 slave 2026-10-01 13:48:56
3 ether3 slave 2026-10-01 13:48:56
4 ether4 slave 2026-10-01 13:48:56
5 ether5 slave 2026-10-01 13:48:56
6 wifi1 slave 2026-10-01 13:48:56
7 wifi2 slave 2026-10-01 13:48:56
8 bridge internet 2026-10-01 13:49:02 12ms
This router gets its internet from another router on its LAN, so its bridge has the internet state. On a typical home router, the internet state goes to the interface with the default route, for example ether1. Ports of the bridge show as slave, and ether1 has no cable here (no-link). lo is the router's loopback interface, shown as lan.
The interface with the internet state is a dynamic member of the internet list:
[admin@MikroTik] > /interface/list/member/print where list=internet
Flags: D - DYNAMIC
Columns: LIST, INTERFACE
# LIST INTERFACE
;;; INTERNET detected
0 D internet bridge
Use the lists with care​
The lists change on their own: an interface leaves the internet or wan list when its state changes, and every interface is lan again after a link change. Do not use these lists for trust decisions, for example in firewall rules that accept traffic, and do not set them to the LAN and WAN lists of the default configuration. They fit informational use, for example in scripts that report which line has the internet.
Set lan-interface-list and wan-interface-list to fill lists for the other states in the same way.
How the states work​
StateMeaning
no-linkThe interface has no link.
slaveThe interface is a port of a bridge or another interface, for example a bridge port or a Wi-Fi interface in a bridge.
lanThe start state of layer 2 interfaces, and the state again after a link change.
unknownThe router is checking the interface. It lasts about 6 seconds.
wanThe router's active route to 8.8.8.8 goes through the interface. Layer 3 tunnels, such as IPIP, become wan when their link comes up.
internetA wan interface through which the router reaches cloud.mikrotik.com on UDP port 30000. The router's route to the cloud server must go through this interface.
The router checks an interface again after a link change, a route change or a change of the Detect Internet settings. These rules decide what can change:
  • An interface that has stayed lan for an hour is locked. It changes only after a link change, also when a route to 8.8.8.8 goes through it later.
  • A wan interface goes back to lan only after a link change.
  • An internet interface falls back to wan when the cloud server stops answering (after about 4 minutes with the default request-interval), or when the route to the cloud server no longer goes through the interface. When the server answers again, the interface gets the internet state back.
  • With two equal-cost routes to 8.8.8.8 through different interfaces, neither interface becomes wan.
A link change means that the link of the interface goes down and comes up again, for example when a cable is unplugged and plugged in, or when the interface is disabled and enabled.
note
Detect Internet shows which interface the router's active route uses, not the health of every line. A backup line whose route is not active stays lan, and after an hour it is locked, so Detect Internet is not a health check for failover. A /32 route to 8.8.8.8 through one line, which some failover setups use, keeps the wan state on that line. To check backup lines, use routes with check-gateway (see Failover (WAN backup)) or Netwatch.
Each state change is logged with the topic interface, for example ether1 detect WAN.
Troubleshoot​
When every interface stays lan:
  • Check that the router's active route to the internet goes through the interface:
    /ip/route/print where active and dst-address=0.0.0.0/0
  • An interface that stayed lan for an hour is locked. Disable and enable it, or unplug and plug in its cable, so that the router checks it again.
  • With two equal-cost routes to 8.8.8.8 through different interfaces, neither becomes wan.
When an interface is wan but never internet, check that the router's route to cloud.mikrotik.com goes through that interface, and that UDP port 30000 to the cloud server is not blocked on the way.
Technical details​
Cloud check​
For a wan interface, the router sends a 32-byte UDP message to cloud.mikrotik.com port 30000, and the server sends it back. The router sends the message at half of request-interval, so about every minute with the default of 2 minutes. request-interval takes values from 1 minute to 1 day. CLOUD-RTT in the state menu shows the round-trip time of the last answer.
Dynamic list members​
Each dynamic member of a list gets a comment with the state that added it: LAN detected, WAN detected or INTERNET detected.
Settings changes​
A change of the Detect Internet settings checks all watched interfaces again. Each interface shows unknown for a few seconds and then its state.
Turn it off​
Stop watching the interfaces:
/interface/detect-internet/set detect-interface-list=none
This also removes the dynamic members from the lists. With no interfaces to watch, Detect Internet no longer contacts the cloud server.
For all parameters, see the CLI reference for /interface/detect-internet and /interface/detect-internet/state.
