Scheduler
CLI reference:/system/scheduler
Summary
The scheduler can trigger script execution at a particular time moment, after a specified time interval, or both.
Properties
| Property | Description |
| days (always | sun | mon | tue | wed | thu | fri | sat; Default: always) | Days of the week when the task can run. Separate multiple days with commas (for example, mon,wed,fri). Use always to run every day. |
| interval (time; Default: 0s) | Interval between two script executions. When set to zero, the script runs only once at the start time. |
| name (string; Default: ) | Name of the task. |
| on-event (string; Default: ) | Script to execute. |
| policy (ftp | reboot | read | write | policy | test | password | sniff | sensitive | romon; Default: ) | Policies applied to the scheduled script, controlling permissions during execution. |
| start-date (date; Default: ) | Date of the first script execution. |
| start-time (time | startup; Default: ) | Time of the first script execution. Use startup to execute 3 seconds after system boot. |
| run-count (read-only: integer) | Counter incremented each time the script runs. Resets on reboot. |
Notes
Rebooting the router will reset the run-count counter.
If more than one script has to be executed simultaneously, they are executed in the order they appear in the scheduler configuration. This can be important if one scheduled script is used to disable another one.
If a more complex execution pattern is needed, it can usually be done by scheduling several scripts, and making them enable and disable each other.
When days, a specific start-time, and an interval are all set, the task will start at the specified start time on matching days and repeat at the given interval until the end of the day.
If a scheduler item has start-time set to startup, it behaves as if start-time and start-date were set to a time 3 seconds after console starts up. Scripts with start-time=startup and interval=0 will be executed once each time the router boots. If the interval is set to a value other than 0, the scheduler will not run at startup.
Examples
We will add a task that executes the script log-test every hour:
[admin@MikroTik] /system/script> add name=log-test source=":log info message=test"
[admin@MikroTik] /system/script> print
Flags: I - invalid
0 name="log-test" owner="admin" policy=ftp,reboot,read,write,,test,password,sniff,sensitive,romon dont-require-permissions=no run-count=0
source=:log info message=test
[admin@MikroTik] /system/script> .. /scheduler
[admin@MikroTik] /system/scheduler> add name=run-1h interval=1h
on-event=log-test
[admin@MikroTik] /system/scheduler> print
Flags: X - disabled
# NAME ON-EVENT START-DATE START-TIME INTERVAL RUN-COUNT
0 run-1h log-test 2004-03-30 06:11:35 1h 0
The following example runs a task only on business days:
[admin@MikroTik] /system/script> add name=business-log source=":log info message=workday"
[admin@MikroTik] /system/scheduler> add name=workday-task interval=1d on-event=business-log days=mon,tue,wed,thu,fri start-time=8:00:00
Flags: X - disabled
# NAME ON-EVENT START-DATE START-TIME INTERVAL DAYS RUN-COUNT
0 workday-task business-log 2026-07-16 08:00:00 1d mon,tue,wed,thu,fri 0
In another example, there will be two scripts added that will change the bandwidth setting of a queue rule "Cust0". Every day at 9AM the queue will be set to 64Kb/s and at 5PM the queue will be set to 128Kb/s. The queue rule, the scripts, and the scheduler tasks are below:
[admin@MikroTik] /queue/simple> add name=Cust0 interface=ether1 \
\... dst-address=192.168.0.0/24 limit-at=64000
[admin@MikroTik] /queue/simple> print
Flags: X - disabled, I - invalid 0 name="Cust0" target-address=0.0.0.0/0 dst-address=192.168.0.0/24
interface=ether1 limit-at=64000 queue=default priority=8 bounded=yes
[admin@MikroTik] /queue/simple> /system/script
[admin@MikroTik] /system/script> add name=start_limit source={/queue/simple/set \
\... Cust0 limit-at=64000}
[admin@MikroTik] /system/script> add name=stop_limit source={/queue/simple/set \
\... Cust0 limit-at=128000}
0 name="start_limit" source="/queue/simple/set Cust0 limit-at=64000"
owner=admin run-count=0
1 name="stop_limit" source="/queue/simple/set Cust0 limit-at=128000"
[admin@MikroTik] /system/scheduler> add interval=24h name="set-64k" \
\... start-time=9:00:00 on-event=start_limit
[admin@MikroTik] /system/scheduler> add interval=24h name="set-128k" \
\... start-time=17:00:00 on-event=stop_limit
Flags: X - disabled
0 set-64k start... 2008-10-30 09:00:00 1d 0
1 set-128k stop_... 2008-10-30 17:00:00 1d 0
The following example schedules a script that sends each week a backup of router configuration by e-mail.
[admin@MikroTik] /system/script> add name=e- source={/system/backup
{... save name=email; /tool/e-mail/send to="root@host.com" subject=([/system
{... /identity/get name] . " Backup") file=email.}
0 name="e-backup" source="/system/backup/save name=ema... owner=admin run-count=0
[admin@MikroTik] /system/script> ../scheduler
[admin@MikroTik] /system/scheduler> add interval=7d name="email-backup" \
\... on-event=e-
Flags: X - disabled
0 email-... e- 2008-10-30 15:19:28 7d 1
Do not forget to set the e-mail settings, i.e., the SMTP server and From: address under /tool/e-mail. For example:
[admin@MikroTik] /tool/e-mail> set server=159.148.147.198 from=SysAdmin@host.com
[admin@MikroTik] /tool/e-mail> print
server: 159.148.147.198
The example below will put 'x' in logs each hour from midnight till noon:
[admin@MikroTik] /system/script> add name=enable-x source={/system/scheduler
{... enable x}
[admin@MikroTik] /system/script> add name=disable-x source={/system/scheduler
{... disable x}
[admin@MikroTik] /system/script> add name=log-x source={:log info message=x}
[admin@MikroTik] /system/scheduler> add name=x-up start-time=00:00:00 \
\... interval=24h on-event=enable-x
[admin@MikroTik] /system/scheduler> add name=x-down start-time=12:00:00
\... interval=24h on-event=disable-x
[admin@MikroTik] /system/scheduler> add name=x start-time=00:00:00 interval=1h \
\... on-event=log-x
Flags: X - disabled
0 x-up enable-x 2008-10-30 00:00:00 1d 0
1 x-down disab... 2008-10-30 12:00:00 1d 0
2 x log-x 2008-10-30 00:00:00 1h 0
