Neighbor discovery
CLI reference:/ip/neighbor
Neighbor Discovery protocols allow us to find devices compatible with MNDP (MikroTik Neighbor Discovery Protocol), CDP (Cisco Discovery Protocol), or LLDP (Link Layer Discovery Protocol) in the Layer2 broadcast domain. They can be used to map out your network.
Neighbor list
The neighbor list shows all discovered neighbors in the Layer2 broadcast domain. It shows to which interface the neighbor is connected, its IP/MAC addresses, and other related parameters. The list is read-only. An example of a neighbor list is provided below:
[admin@MikroTik] /ip/neighbor/print
# INTERFACE ADDRESS MAC-ADDRESS IDENTITY VERSION BOARD
0 ether13 192.168.33.2 00:0C:42:00:38:9F MikroTik 5.99 RB1100AHx2
1 ether11 1.1.1.4 00:0C:42:40:94:25 test-host 5.8 RB1000
2 Local 10.0.11.203 00:02:B9:3E:AD:E0 c2611-r1 Cisco I...
3 Local 10.0.11.47 00:0C:42:84:25:BA 11.47-750 5.7 RB750
4 Local 10.0.11.254 00:0C:42:70:04:83 tsys-sw1 5.8 RB750G
5 Local 10.0.11.202 00:17:5A:90:66:08 c7200 Cisco I...
Sub-menu: /ip/neighbor
| Property | Description |
| address (IP) | The highest IP address configured on a discovered device |
| address6 (IPv6) | IPv6 address configured on a discovered device |
| add-dns-entries (yes | no) | Specify whether to create dynamic DNS entry for this particular neighbor and use identity as domain name |
| add-dns-entries-suffix (string) | Suffix added to dynamic DNS entries created for each neighbor. |
| age (time) | Time interval since last discovery packet |
| discovered-by (cdp|lldp|mndp) | Shows the list of protocols the neighbor has been discovered by. The property is available since RouterOS version 7.7. |
| board (string) | RouterBoard model. Displayed only for devices with installed RouterOS |
| identity (string) | Configured system identity |
| interface (string) | Interface name to which the discovered device is connected |
| interface-name (string) | Interface name on the neighbor device connected to the L2 broadcast domain. Applies to CDP. |
| ipv6 (yes | no) | Shows whether the device has IPv6 enabled. |
| mac-address (MAC) | MAC address of the remote device. Can be used to connect with mac-telnet. |
| platform (string) | Name of the platform. For example "MikroTik", "cisco", etc. |
| software-id (string) | RouterOS software ID on a remote device. Applies only to devices installed with RouterOS. |
| system-caps (string) | System capabilities reported by the Link-Layer Discovery Protocol (LLDP). |
| system-caps-enabled (string) | Enabled system capabilities reported by the Link-Layer Discovery Protocol (LLDP). |
| unpack (none|simple|uncompressed-headers|uncompressed-all) | Shows the discovery packet compression type. |
| uptime (time) | Uptime of remote device. Shown only for devices installed with RouterOS. |
| version (string) | Version number of installed software on a remote device |
| running (string array) | Reports a list of "features" running on the neighbour device. Currently lists only the "CAPsMAN" feature. |
The number of neighbor entries is limited to (total RAM in megabytes)*16 per interface to avoid memory exhaustion.
LLDP neighbors
LLDP-discovered neighbors are shown in a separate read-only menu under /ip/neighbor/lldp. This menu shows detailed LLDP type-length-values (TLVs) received from neighboring devices.
Unlike the general /ip/neighbor menu which aggregates neighbors from all discovery protocols (MNDP, CDP, and LLDP), /ip/neighbor/lldp shows only LLDP-discovered entries.
Example output:
[admin@Switch] > /ip/neighbor/lldp/print
Columns: INTERFACE, ADDRESS4, ADDRESS6, MAC-ADDRESS, LLDP-CHASSIS-ID, LLDP-PORT-ID, LLDP-PORT-DESCRIPTION, LLDP-SYSTEM-NAME, LLDP-SYSTEM-DESCRIPTION
# INTERFACE ADDRESS4 ADDRESS6 MAC-ADDRESS LLDP-CHASSIS-ID LLDP-PORT-ID LLDP-PORT-DESCRIPTION LLDP-SYSTEM-NAME LLDP-SYSTEM-DESCRIPTION
0 ether2 192.168.88.128 fe80::f61e:57ff:fe13:d794 F4:1E:57:13:D7:94 F4:1E:57:13:D7:94 ether1 ether1 Tested_CRS812 MikroTik RouterOS 7.24rc1 (testing) 2026-07-01 13:53:30 CRS812-8DS-2DQ-2DDQ
bridge1
1 ether3 192.168.88.127 fe80::f61e:57ff:fe47:9255 F4:1E:57:47:92:55 F4:1E:57:47:92:55 ether1 ether1 Tested_CRS520 MikroTik RouterOS 7.24rc1 (testing) 2026-07-01 13:53:30 CRS520-4XS-16XQ
bridge1
2 ether4 192.168.88.9 fe80::1afd:74ff:fe81:9a 18:FD:74:81:00:9A 18:FD:74:81:00:86 ether1 ether1 Tester6 MikroTik RouterOS 7.24rc1 (testing) 2026-07-01 13:53:30 CCR2216-1G-12XS-2XQ
bridge1
3 ether5 192.168.88.132 fe80::d601:c3ff:fe43:c035 D4:01:C3:43:C0:35 D4:01:C3:43:C0:35 ether1 ether1 Tested_L009 MikroTik RouterOS 7.24rc1 (testing) 2026-07-01 13:53:30 L009UiGS
bridge1
4 ether8 192.168.88.129 fe80::f61e:57ff:fec2:8a3d F4:1E:57:C2:8A:3D F4:1E:57:C2:8A:2B ether17 ether17 Tested_CRS418 MikroTik RouterOS 7.24rc1 (testing) 2026-07-01 13:53:30 CRS418-8P-8G-2S+
bridge1
The lldpRemTable SNMP table reports only neighbors discovered through LLDP. Entries discovered exclusively by CDP or MNDP are excluded from the SNMP LLDP-MIB.
Discovery configuration
It is possible to change whether an interface participates in neighbor discovery or not using an Interface list. If the interface is included in the discovery interface list, it will send out basic information about the system and process received discovery packets broadcasted in the Layer2 network. Removing an interface from the interface list will disable both the discovery of neighbors on this interface and the possibility of discovering this device itself on that interface.
Sub-menu: /ip/neighbor/discovery-settings
| discover-interface-list (string; Default: static) | Interface list whose members the discovery protocol will run on. |
| discover-interval (time: 5s..9h6m8s; Default: 30s) | Adjusts the frequency at which neighbor discovery packets are transmitted. It also adjusts the Time-to-Live (TTL) TLV value for CDP and LLDP packets using the formula: (discover-interval * 4) + 1. The setting is available since RouterOS version 7.16. |
| lldp-dcbx (yes | no; Default: no) | Whether to send Data Center Bridging Capabilities Exchange Protocol (DCBX) TLVs, which allows to communicate switch QoS settings and capabilities with other neighboring devices using LLDP. Only applies to MikroTik devices with a Marvell Prestera switch (e.g. CRS3xx). Enabled DCBX includes the following TLVs:
| lldp-mac-phy-config(yes | no; Default: no) | Whether to send MAC/PHY Configuration/Status TLV in LLDP, which indicates the interface capabilities, current setting of the duplex status, bit rate, and auto-negotiation. Only applies to Ethernet interfaces. While the TLV is optional in LLDP, it is mandatory when sending LLDP-MED, meaning this TLV will be included when necessary even though the property is configured as disabled. |
| lldp-max-frame-size (yes | no; Default: no) | Whether to send Maximum Frame Size TLV in LLDP, which indicates the maximum frame size capability of the interface in bytes (l2mtu + 18). Only applies to Ethernet interfaces. |
| lldp-med (yes | no; Default: yes) | Specifies whether to advertise the LLDP-MED Media Capabilities TLV. This option must be enabled when lldp-med-net-policy-vlan is used. The setting is available since RouterOS version 7.23. |
| lldp-poe-power (yes | no; Default: yes) | Two specific TLVs facilitate Power over Ethernet (PoE) management between Power Sourcing Equipment (PSE) and Powered Devices (PD):
lldp-poe-power attribute determines whether to transmit the IEEE 802.3 Organizationally Specific Power Via MDI TLV in LLDP messages. The transmission of LLDP-MED Organizationally Specific Extended Power via MDI TLV is not configurable. It is automatically included in outgoing LLDP-MED packets when the remote device has transmitted the LLDP-MED capability of receiving power. These TLVs are relevant only for Ethernet interfaces that support PoE-Out. The setting is available since RouterOS version 7.15, and it replaces PoE-out port poe-lldp-enabled setting. |
| lldp-med-net-policy-vlan (integer 0..4094; Default: disabled) | Advertised VLAN ID for LLDP-MED Network Policy TLV. This allows assigning a VLAN ID for LLDP-MED capable devices, such as VoIP phones. The TLV will only be added to interfaces where LLDP-MED capable devices are discovered and lldp-med is enabled. Other TLV values are predefined and cannot be changed:
protocol-mode setting. Additionally, other neighbor discovery protocols (e.g. CDP) should be excluded using the protocol setting to avoid LLDP-MED misconfiguration. |
| lldp-vlan-info (yes | no; Default: no) | Whether to send IEEE 802.1 Organizationally Specific TLVs in LLDP related to VLANs. When this setting is enabled, three TLVs are advertised:
| mode (rx-only | tx-only | tx-and-rx; Default: tx-and-rx) | Selects the neighbor discovery packet sending and receiving mode. The setting is available since RouterOS version 7.7. |
| protocol (cdp | lldp | mndp; Default: cdp,lldp,mndp) | List of used discovery protocols. |
Since RouterOS v6.44, neighbor discovery works on individual slave interfaces. Whenever a master interface (e.g. bonding or bridge) is included in the discovery interface list, all its slave interfaces will automatically participate in neighbor discovery. It is possible to allow neighbor discovery only on some slave interfaces. To do that, include the particular slave interface in the list and make sure that the master interface is not included.
/interface/bonding
add name=bond1 slaves=ether5,ether6
/interface/list
add name=only-ether5
/interface/list/member
add interface=ether5 list=only-ether5
set discover-interface-list=only-ether5
Now the neighbor list shows a master interface and an actual slave interface on which a discovery message was received.
[admin@R2] > print
0 ether5 192.168.88.1 CC:2D:E0:11:22:33 R1 6.45.4 ... CCR1036-8G-2S+
bond1
LLDP
Depending on RouterOS configuration, different type-length-values (TLVs) can be sent in the LLDP message. This includes:
- Chassis ID (MAC address).
- Port ID (interface name).
- Time To Live.
- System Name (system identity).
- System Description (platform - MikroTik, software version - RouterOS version, hardware name - RouterBoard name).
- Management Address (all IP addresses configured on the port).
- System Capabilities (enabled system capabilities, e.g. bridge or router).
- Port Description (combined interface name like "bridge/ether1" if the sending interface is part of bridge or bond, or interface name the same as Port ID).
- IEEE 802.1 Port VLAN ID.
- IEEE 802.1 Port And Protocol VLAN ID.
- IEEE 802.1 VLAN Name.
- IEEE 802.3 MAC/PHY Configuration/Status.
- IEEE 802.3 Power Via MDI.
- IEEE 802.3 Maximum Frame Size.
- LLDP-MED Media Capabilities (list of MED capabilities).
- LLDP-MED Network Policy (assigned VLAN ID for voice traffic).
- LLDP-MED Extended Power via MDI.
- Port Extension (Port Extender and Controller Bridge advertisement).
- End of LLDPDU.
