IP packing
CLI reference:/ip/packing
IP Packing provides a packet packaging service on network links. It allows simple packet aggregation into larger packets and compression of the contents of packets.
Requirements
Packet packing is part of the system package and has to have a discovery protocol enabled on an interface.
Configuration
Sub-menu: /ip/packing
It is required to have a configuration in two places, both routers should be set up symmetrically:
/ip/packing- to enable packet aggregation and/or compression on an interface./ip/neighbor/discovery-settingsto enable discovery protocol on the interface.
Packing configuration
| Property | Description |
| aggregated-size (20 .. 16384 default:1500) | size of an aggregated packet that packing will try to achieve before sending a packet over the network |
| disabled (yes|no) | state of the packing rule, if a value is yes it will be ignored and will not be part of the active configuration |
| interface (interface name) | packing will try to aggregate and/or compress packets from this interface |
| packing (simple|compress-all|compress-headers|none) | the action it should perform when a packet is leaving the interface the packing rule is configured on:
| unpacking (simple|compress-all|compress-headers|none) | the action that should be performed when a packet is received on the interface the packing rule is configured on:
The router should be seen as a neighbor of the router over the interface you want to enable packing on. If in the neighbor list there is no entry indicating packing, packing is not working!
Warning: Packing may increase latency on the link it is configured on.
Example
Router-A and Router-B are connected with a cable with interface ether1 on Router-A and ether3 on Router-B. This example will aggregate packets coming from Router-A, but will leave packets from Router-B intact. On Router-A:
Make sure discovery is enabled:
/ip/neighbor/discovery/set ether1 discover=yes
Add a packing rule for the interface:
/ip/packing/add interface=ether1 aggregated-size=1500 packing=simple unpacking=none
On Router-B:
/ip/neighbor/discovery/set ether3 discover=yes
/ip/packing/add interface=ether3 aggregated-size=1500 packing=none unpacking=simple
