Skip to main content
Version: 7.24
E-mail
The E-mail tool is a built-in RouterOS utility that enables the router to send e-mail messages directly from the device. It can be used to automate delivery of configuration backups and exports to a network administrator on a scheduled basis.
The E-mail tool supports plain authentication and TLS encryption. No other authentication or encryption methods are supported.
Properties​
Sub-menu: /tool/e-mail
This submenu allows setting an SMTP server that will be used.
PropertyDescription
address (IP/IPv6 address; Default: 0.0.0.0)SMTP server's IP address.
certificate-verification(yes | yes-without-crl | no; Default: no)Enables trust chain validation from the local certificate store. yes-without-crl validates a certificate, not performing a CRL check (certificate revocation list).
from (string; Default: <>)Name or email address that will be shown as the sender.
password (string; Default: "") sensitivePassword used for authenticating to an SMTP server.
port (integer[0..65535]; Default: 25)SMTP server's port.
tls (no|yes|starttls; Default: no)Whether to use TLS encryption:
  • yes - sends STARTTLS and drops the session if TLS is not available on the server
  • no - does not send STARTTLS
  • starttls - sends STARTTLS and continues without TLS if a server responds that TLS is not available
user (string; Default: "")The username used for authenticating to an SMTP server.
vrf (VRF name; default value: main)Set VRF on which service is creating outgoing connections.
warning
Note: All server configurations (if specified) can be overridden by send command.
Sending Email​
The Send command takes the following parameters:
PropertyDescription
body (string; Default: )The actual body of the email message
cc (string; Default: )Send a copy to listed recipients. Multiple addresses allowed, use "," to separate entries
certificate-verification(yes | yes-without-crl | no; Default: no)Enables trust chain validation from the local certificate store. yes-without-crl, validates a certificate, not performing a CRL check (certificate revocation list).
file (File[,File]; Default: )List of the file names that will be attached to the mail separated by a comma.
from (string; Default: )Name or email address which will appear as the sender. If not specified, a value from the server's configuration is used.
password (string; Default: ) sensitivePassword used to authenticate to an SMTP server. If not specified, a value from the server's configuration is used.
port (integer[0..65535]; Default: )Port of SMTP server. If not specified, a value from the server's configuration is used.
server (IP/IPv6 address; Default: )IP or IPv6 address of the SMTP server. If not specified, a value from the server's configuration is used.
tls (yes|no|starttls; Default: no)Whether to use TLS encryption:
  • no - do not send STARTTLS
subject (string; Default: )The subject of the message.
to (string; Default: )Destination email address. Single address allowed.
user (string; Default: )The username used to authenticate to an SMTP server. If not specified, a value from the server's configuration is used.
Basic examples​
This example will show how to send an email with configuration export every 24 hours.
  1. Configure SMTP server.
[admin@MikroTik] /tool/e-mail> set server=10.1.1.1 port=25 from="router@mydomain.com"
  1. Add a new script named "export-send":
/export file=export
/tool/e-mail/send to="config@mydomain.com" subject="$[/system/identity/get name] export" \
body="$[/system/clock/get date] configuration file" file=export.rsc
  1. Add scheduler to run our script.
/system/scheduler/add on-event="export-send" start-time=00:00:00 interval=24h
Send e-mail to a server using TLS/SSL encryption.
info
Google Mail does not allow third-party devices to authenticate using a standard Gmail password. An App password must be generated and used instead.
To generate an App password, navigate to Security > How you sign in to Google, enable 2-Step Verification, then generate an App password. Use the generated value in the set password=mypassword setting shown below.
  1. Configure the client to connect to the correct server.
/tool/e-mail
set address=smtp.gmail.com
set port=587
set tls=yes
set from=myuser@gmail.com
set user=myuser
  1. Send an e-mail using the send command.
/tool/e-mail/send to=myuser@anotherdomain.com subject="email test" body="email test"
