TR-069
CLI reference:/tr069-client
TR069-client implements CPE WAN Management Protocol (CWMP) for remote device management, which is standardized by the Broadband Forum (BBF). CWMP works over an IP network using HTTP(S) to communicate with an Auto Configuration Server (ACS), which can monitor, configure attributes and update the firmware of a remote device. It is typically used by ISPs to manage CPEs, but also can be used for Network Infrastructure Device management.
Requires the tr069-client package.
Configuration Settings
Sub-menu: /tr069-client
TR069-client menu parameters:
Writable Settings
Client configuration settings.
| Property | Description |
| enabled | enable/disable CWMP protocol |
| acs-url | URL of ACS. Examples: "https://example.com:8080/path/", "https://192.168.1.100/" If ACS is accessed using HTTPS, a Root CA must be imported on the client certificate store to verify the ACS server certificate. |
| username | HTTP authentication username (used by CPE to "log in" to ACS) |
| password sensitive | HTTP authentication password (used by CPE to "log in" to ACS) |
| periodic-inform-enabled | enable/disable CPE periodic session initiation. Timer is started after every successful session. When a session is started by periodic interval then Inform RPC contains "2 PERIODIC" event. Maps to "Device.ManagementServer.PeriodicInformEnable" Parameter |
| periodic-inform-interval | timer interval of periodic inform. Maps to "Device.ManagementServer.PeriodicInformInterval" |
| client-certificate | certificate of client/CPE, which can be used by ACS for extra authentication |
Read-only Settings
Read-only parameters to monitor the state of the client.
| status | informative status of CWMP.
| last-session-error | user-friendly error description indicating why the previous session didn't finish successfully |
| retry-count | consecutive unsuccessful session count. If > 0, then last-session-error should indicate error. Resets to 0 on a successful session, a disabled protocol or reboot |
Commands
| Command | Description |
| reset-tr069-config | Completely resets and forgets tr069-client configuration and state (without affecting other ROS configurations). Use when CWMP goes into unresponsive/hung state and should be restored without re-installation of the RouterOS. |
CWMP Session
The CWMP client usually starts communication(Session) with ACS on different events - first boot, reboot, periodic interval, remote request, value change etc. In each session, CPE and ACS can call RPCs to be "executed" on the other side. CPE always starts with the Inform RPC, which contains connection reason, device info and some Parameter values depending on configuration. When CPE has nothing more to say, then ACS executes its RPCs (which most of the time are Parameter management RPCs).
Parameters and Data Models
Parameters are simple name+value pairs and each vendor can decide which Parameters to support in its devices. A combination of all supported Parameters is called Data Model (DM). BBF defines three root Data Models (TR-098, TR-181:1, TR-181:2) on which vendors should base their supported Parameters. RouterOS Data Model is based on "TR-181 Issue 2 Amendment 11", which is the newest DM and recommended by BBF.
RouterOS TR069 client-supported parameter reference
Download RPC
RouterOS Update (1 Firmware Upgrade Image)
The CWMP standard defines that CPE's firmware can be updated using Download RPC with FileType="1 Firmware Upgrade Image" and a single URL of a downloadable file (HTTP and HTTPS are supported). The standard also states that the downloaded file can be any type and vendor-specific process can be applied to finish firmware update. Because MikroTik's update is package based (and also for extra flexibility), an XML file is used to describe firmware upgrade/downgrade. For now, XML configuration supports providing multiple URLs of files, which will be downloaded and applied similarly to a regular RouterOS update through firmware/package file upload.
An example of a RouterOS bundle package and tr069-client package update (don't forget to also update the tr069-client package). An XML file should be put on some HTTP server, which is accessible from CPE for download. Also, downloadable RouterOS package files should be accessible the same way (can be on any HTTP server). Using ACS, execute Download RPC with the URL pointing to the XML file (e.g. "https://example.com/path/upgrade.xml") with contents:
<upgrade version="1" type="links">
<config/>
<links>
<link>
<url>https://example.com/routeros-mipsbe-X.Y.Z.npk</url>
</link>
<link>
<url>https://example.com/tr069-client-X.Y.Z-mipsbe.npk</url>
</link>
</links>
</upgrade>
CPE will download XML, parse/validate its contents, download files from provided URLs and try to upgrade. The result will be reported with TransferComplete RPC.
Note
Always make firmware updates incremental - first, update a locally tested device and make sure that CWMP communication is resumed with a new version and required ROS functionality works. Secondly, repeat steps by updating groups of CPEs incrementally. We do not recommend updating all remote devices at once.
Warning: Use HTTPS in production for firmware management
Configuration Change (3 Vendor Configuration File)
The same Download RPC can be used to perform complete configuration overwrite (as intended by the standard) OR configuration alteration (when URL's filename extension is ".alter").
Alter configuration
RouterOS has a lot of configuration attributes and not everything can be ported to CWMP Parameters. That's why RouterOS provides a possibility to execute its powerful scripting language to configure any attribute. A configuration alteration (which is really a regular script execution) can be performed using Download RPC FileType="3 Vendor Configuration File" with a downloadable file extension ".alter". This powerful feature can be used to configure any ROS attributes which are not available through CWMP Parameters.
Overwrite all configurations
Full ROS configuration overwrite can be performed using Download RPC FileType="3 Vendor Configuration File" with any URL file name (except with the ".alter" extension).
Warning: The provided configuration file (script) must be "smart" enough to apply configuration correctly right after reboot. This is especially important when using an uploaded configuration file with Upload RPC, because it only contains exported values. Some things that should be added manually:
- Startup delay for interfaces to show up.
- Hidden passwords for users.
- Certificates.
RouterOS default configuration change (X MIKROTIK Factory Configuration File)
This vendor specific FileType allows the change of the RouterOS default configuration script that is executed when the /system/reset-configuration command is executed (or by other means when the router configuration is being reset).
Note
If the default configuration script is changed, it will not be displayed by /system/default-configuration/print as it is the case if that script is altered via the Netinstall tool. That command will always show the default script set up by MikroTik.
Warning: Use this with caution as the failure of the uploaded script may render the device inoperable and/or inaccessible by the ACS
FactoryReset RPC
This is a CWMP standard RPC, which performs RouterOS configuration factory-reset. The reset process is performed in the same way as executing the command:
/system/reset-configuration skip-backup=yes
Note that the default factory configuration can be different for each device (see Default configurations) and execution of this command removes all configurations and executes the internally stored default-configuration script.
Upload RPC
Upload current configuration (1 Vendor Configuration File)
The result of this is a file uploaded to the ACS same as the output of the /export command in RouterOS
Upload log file (2 Vendor Log File)
The result of this is that the file uploaded to the ACS is similar to the output of /log/print command in RouterOS
Upload default configuration (X MIKROTIK Factory Configuration File)
The result of this is file uploaded to the ACS that has contents of the current set default configuration script that will be executed if /system/reset-configuration command is executed. It may differ from one returned using /system/default-configuration/print.
Security
- HTTP should only be used when testing initial setup in the secured/private network because a Man-in-the-middle attacker could read/change configuration parameters. In the production environment, HTTPS is a MUST.
- CWMP's incoming connection validation by design is safe because CPE will not communicate with any other device except the previously configured ACS. Connection Request only signals the CPE to start a new connection + new session with the previously configured ACS.
Get the router ready for use with TR069
This Best Practices Guide shows an example of RouterOS initial setup if it needs a safe/preconfigured factory-reset with custom configuration, especially when TR-069 is used. It can be useful in cases when the user (or provider unknowingly) has misconfigured the device in a non-reversible state. Then the factory-reset configuration can be applied using TR069 FactoryReset RPC or through RouterOS /system/reset-configuration or by using the reset button on the router.
Overriding factory default-configurations on Netinstall
When performing Netinstall, the default-configuration script can be adapted to specific needs and installed by overwriting the MikroTik's default one. It should be done by providers who want to have FactoryReset as a backup which could make the device "reachable" again in case of some unresolvable misconfiguration. In the TR-069 case the default-configuration script should at minimum import certificates, set up the IP layer connectivity, enable and configure tr069-client, configure the firewall. After that other configurations can be performed by the ACS.
On factory-reset all certificates are removed too, so if they are needed after reset, then the default-configuration script must import them
Example script
The example default-configuration script, which assumes that the board is using ether1 as a WAN port for reaching ACS, a dummy CA certificate and the initial IP configuration is received by a DHCP client.
Note: Of course, values of certificate, acs-url, username, password must be replaced and extra configurations will most probably be added. You also might want to define your own interface-list for discovery from LAN side.
# Install certificate
:global acsCaCertTxt "-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----";
/file/print file=tmp_acs_ca_cert.txt;
:delay 2;
/file/set tmp_acs_ca_cert.txt contents=$acsCaCertTxt;
/certificate/import file-name=tmp_acs_ca_cert.txt passphrase="";
/file/remove tmp_acs_ca_cert.txt;
# Wait while ether ifaces show up
:local count 0;
:while ([/interface/ethernet/find] = "") do={
:if ($count = 30) do={
/quit;
:delay 1s; :set count ($count +1);
# Set as secure settings as possible for tr069-client to work
/ip/firewall {
add chain=input action=accept connection-state=established,related \
comment="defconf: accept established,related"
/filter/add chain=input action=drop in-interface=ether1 \
comment="defconf: drop all from WAN"
/ip/neighbor/discovery-settings/set discover-interface-list=none
# Configure IP level, so that tr069-client can work
/ip/dhcp-client/add interface=ether1 disabled=no comment="defconf";
/tr069-client/set acs-url="https://example.com:7777/" enabled=yes \
username=exampleusername password=examplesecurepassword
Tested ACSs
Ordering is alphabetical. MikroTik does not imply any one vendor's superiority over another.
Commercial
We have tested and verified the following commercial ACS solutions:
