Skip to main content
Version: 7.24
MikroTik mobile app
Summary​
The application is available for both Android and iOS operating systems. It is a good way to configure a new device, as it provides a simple and user-friendly setup screen for the most basic settings of your new router. It also features an advanced menu, for the more experienced user.
Downloading app​
MikroTik application is available to download on the App Store and Google Play, please see our web page Software section for direct download links or scan the QR code.
Use the MikroTik smartphone app to configure your router in the field, or to apply the most basic initial settings for your MikroTik home access point.
Quick start with the application​
  • Scan QR code and choose your preferred OS.
  • Install and connect to your wireless network.
  • Open the application. By default, the IP address and username will be already entered.
  • Click Connect to establish a connection.
  • Choose Quick setup, and the application will guide you through all basic configuration settings in a couple of easy steps.
