Skip to main content
Version: 7.24
Speed Test
The Speed Test is an easy test tool for measuring ping, jitter, TCP and UDP throughput from one MikroTik device to another. The "speed-test" command is based on the Ping Tool and Bandwidth Test. In order to use this command, the Bandwidth test server needs to be accessible.
General interface properties​
The speed-test is based on five configurable properties:
  • address - IP address of the host.
  • connection-count - If a device has more than 20 cores - the core count will be used (default is 20).
  • password - Password for the remote device.
  • test-duration - Duration for each test (By default: 5 tests * 10 sec duration + 1sec pause between each test = 54sec).
  • user - Remote device username.
Configuration Example​
Bandwidth and speed tests should be conducted through the devices, not on them to ensure real-life simulation and not to overload the CPU on the devices under testing, (DUT) due to the traffic generating process.
To run a simple test from device A (192.168.88.1) to device B (192.168.88.2):
[admin@MikroTik] > /tool/speed-test address=192.168.88.2
status: done
time-remaining: 0s
ping-min-avg-max: 541us / 609us / 3.35ms
jitter-min-avg-max: 0s / 76us / 2.76ms
loss: 0% (0/100)
tcp-download: 921Mbps local-cpu-load:30%
tcp-upload: 920Mbps local-cpu-load:30% remote-cpu-load:25%
udp-download: 917Mbps local-cpu-load:6% remote-cpu-load:21%
udp-upload: 916Mbps local-cpu-load:20% remote-cpu-load:6%
If any of the device CPU utilization during the test reaches 100%, a warning message will appear:
[admin@MikroTik]] > /tool/speed-test address=192.168.88.2
;;; results can be limited by cpu, note that traffic generation/termination
performance might not be representative of forwarding performance
status: done
time-remaining: 0s
loss: 0% (0/100)
tcp-download: 721Mbps local-cpu-load:78%
tcp-upload: 820Mbps local-cpu-load:100% remote-cpu-load:84%
udp-download: 906Mbps local-cpu-load:10% remote-cpu-load:54%
udp-upload: 895Mbps local-cpu-load:55% remote-cpu-load:12%
The "test-duration" parameter allows changing the duration of all of the 5 tests:
  1. Ping test with 50ms delay.
  2. TCP receive.
  3. TCP send.
  4. UDP receive.
  5. UDP send.
