Packet Sniffer
CLI reference:/tool/sniffer
A packet sniffer is a tool that can capture and analyze packets that are going to, leaving, or going through the router. Packet sniffing is very useful when you diagnose networks or protect against security attacks over networks.
Unicast traffic between Wireless clients with client-to-client forwarding enabled will not be visible to the sniffer tool.
Warning: Packets that are processed with hardware offloading enabled on the bridge will not be visible (flooded packets like unknown unicast, broadcast, and multicast traffic might be visible).
Tip: Sniffer catches packets before they go into the firewall (direction=rx) or after they leave it (direction=tx).
Packet Sniffer configuration
RouterOS embedded sniffer allows you to capture packets based on various protocols.
In the following example, we will configure the sniffer to match packets going through the ether1 interface:
[admin@MikroTik] > /tool/sniffer/start interface=ether1
[admin@MikroTik] > /tool/sniffer/stop
[admin@MikroTik] > /tool/sniffer/save file-name=/flash/test.pcap
MikroTik] > /file/print where name~"test"
Columns: NAME, TYPE, SIZE, CREATION-TIME
# NAME TYPE SIZE CREATION-TIME
9 flash/test.pcap file 3696 2019-12-04 10:48:16
You can download captured packets from a file section. Then you can use a packet analyzer such as Wireshark to analyze a file:
If you are using packet streaming to a PC and are using Wireshark, to ensure you are only viewing the streamed data, you will need to apply a filter that matches the port the sniffer is using; by default, 37008 is used. In addition, we recommend using filter-stream=yes.
Please note that sniffed packets will be available for 10 minutes. If you need them permanently, set a "file-name" to save them directly or issue a "save" command as described previously.
Important: Starting with RouterOS 7.20, the sniffer tool saves captured packets in PCAPNG format. The traffic-generator inject-pcap feature supports PCAPNG format starting from RouterOS 7.21.
Sub-menu: /tool/sniffer
| Property | Description |
| file-limit (integer 10..4294967295[KiB]; Default: 1000KiB) | File size limit. Sniffer will stop when a limit is reached. |
| file-name (string; Default: ) | Name of the file where sniffed packets will be saved. |
| filter-cpu (integer; Default: ) | CPU core used as a filter. |
| filter-ip-address (ip/mask[,ip/mask] (max 16 items); Default: ) | Up to 16 IP addresses used as a filter. |
| filter-dst-ip-address (ip/mask[,ip/mask] (max 16 items); Default: ) | Up to 16 IP destination addresses used as a filter. |
| filter-src-ip-address (ip/mask[,ip/mask] (max 16 items); Default: ) | Up to 16 IP source addresses used as a filter. |
| filter-ipv6-address (ipv6/mask[,ipv6/mask] (max 16 items); Default: ) | Up to 16 IPv6 addresses used as a filter. |
| filter-dst-ipv6-address (ipv6/mask[,ipv6/mask] (max 16 items); Default: ) | Up to 16 IPv6 destination addresses used as a filter. |
| filter-src-ipv6-address (ipv6/mask[,ipv6/mask] (max 16 items); Default: ) | Up to 16 IPv6 source addresses used as a filter. |
| filter-mac-address (mac/mask[,mac/mask] (max 16 items); Default: ) | Up to 16 MAC addresses and MAC address masks used as a filter. |
| filter-dst-mac-address (mac/mask[,mac/mask] (max 16 items); Default: ) | Up to 16 MAC destination addresses and MAC address masks used as a filter. |
| filter-src-mac-address (mac/mask[,mac/mask] (max 16 items); Default: ) | Up to 16 MAC source addresses and MAC address masks used as a filter. |
| filter-port ([!]port[,port] (max 16 items); Default: ) | Up to 16 comma-separated ports used as a filter. A list of predefined port names is also available, like ssh and telnet. |
| filter-dst-port ([!]port[,port] (max 16 items); Default: ) | Up to 16 comma-separated destination ports used as a filter. A list of predefined port names is also available, like ssh and telnet. |
| filter-src-port ([!]port[,port] (max 16 items); Default: ) | Up to 16 comma-separated source ports used as a filter. A list of predefined port names is also available, like ssh and telnet. |
| filter-ip-protocol ([!]protocol[,protocol] (max 16 items); Default: ) | Up to 16 comma-separated IP/IPv6 protocols used as a filter. IP protocols (instead of protocol names, protocol numbers can be used):
| filter-mac-protocol([!]protocol[,protocol] (max 16 items); Default: ) | Up to 16 comma separated entries used as a filter. Mac protocols (instead of protocol names, protocol numbers can be used):
| filter-stream (yes | no; Default: yes) | Sniffed packets that are destined for the sniffer server are ignored. |
| filter-size (integer[-integer]:0..65535; Default: ) | Filters packets of specified size or size range in bytes. |
| filter-direction(any | rx | tx; Default: ) | Specifies which direction filtering will be applied. |
| filter-interface (all | name; Default: all) | Interface name on which sniffer will be running. all indicates that the sniffer will sniff packets on all interfaces. |
| filter-operator-between-entries (and | or; Default: or) | Changes the logic for filters with multiple entries. |
| filter-vlan (integer[,integer]:0..4095; Default: ) | Up to 16 VLAN IDs used as a filter. |
| memory-limit(integer 10..4294967295[KiB]; Default: 100KiB) | Memory amount used to store sniffed data. |
| memory-scroll (yes | no; Default: yes) | Whether to rewrite older sniffed data when the memory limit is reached. |
| only-headers(yes | no; Default: no) | Save in the memory only the packet's headers, not the whole packet. |
| show-frame (yes | no; Default: no) | Whether to see the content of the frame when running quick sniffer in command line. |
| streaming-enabled (yes | no; Default: no) | Defines whether to send sniffed packets to the streaming server. |
| streaming-server (IP; Default: 0.0.0.0) | Tazmen Sniffer Protocol (TZSP) stream receiver. |
| streaming-port (port; Default: 37008 ) | Port to stream the TZSP packets to. |
The file-size limit should not be configured to more than available free memory!
Packet Sniffer Quick Mode
The quick mode will display results as they are filtered out with a limited-size buffer for packets. There are several attributes that can be set up for filtering. If no attributes are set, the current configuration will be used.
[admin@MikroTik] > /tool/sniffer/quick ip-protocol=icmp
Columns: INTERFace, TIME, NUm, DIr, SRC-MAC, DST-MAC, SRC-ADDRESS, DST-ADDRESS, PROTOCOl, SIze, Cpu, FP
INTERF TIME NU DI SRC-MAC DST-MAC SRC-ADDRESS DST-ADDRESS PROTOCO SI C FP
ether7 35.472 79 <- 6C:3B:6B:ED:83:69 6C:3B:6B:ED:81:83 10.155.126.252 10.155.126.253 :icmp 70 7 no
ether7 35.472 80 -> 6C:3B:6B:ED:81:83 6C:3B:6B:ED:83:69 10.155.126.253 10.155.126.252 :icmp 70 7 no
ether1 35.595 81 <- 6C:3B:6B:ED:83:63 6C:3B:6B:ED:81:7D 172.24.24.2 172.24.24.1 :icmp 70 4 no
ether1 35.595 82 -> 6C:3B:6B:ED:81:7D 6C:3B:6B:ED:83:63 172.24.24.1 172.24.24.2 :icmp 70 4 no
ether7 36.457 83 <- 6C:3B:6B:ED:83:69 6C:3B:6B:ED:81:83 10.155.126.252 10.155.126.253 :icmp 70 7 no
ether7 36.457 84 -> 6C:3B:6B:ED:81:83 6C:3B:6B:ED:83:69 10.155.126.253 10.155.126.252 :icmp 70 7 no
ether1 36.6 85 <- 6C:3B:6B:ED:83:63 6C:3B:6B:ED:81:7D 172.24.24.2 172.24.24.1 :icmp 70 4 no
ether1 36.6 86 -> 6C:3B:6B:ED:81:7D 6C:3B:6B:ED:83:63 172.24.24.1 172.24.24.2 :icmp 70 4 no
Traffic-Generator packets will not be visible using the packet sniffer on the same interface unless the fast-path parameter is set.
Packet Sniffer Protocols
In this submenu, you can see all sniffed protocols and their share of the whole sniffed amount.
[admin@MikroTik] /tool/sniffer/protocol> print
# PROTOCOL IP-PROTOCOL PORT PACKETS BYTES SHARE
0 802.2 1 60 0.05%
1 215 100377 99.04%
2 2 120 0.11%
3 6 788 0.77%
4 tcp 210 99981 98.65%
5 udp 3 228 0.22%
6 ospf 2 168 0.16%
7 tcp 8291 (winbox) 210 99981 98.65%
8 tcp 36771 210 99981 98.65%
9 udp 646 3 228 0.22%
Packet Sniffer Host
The submenu shows the list of hosts that were participating in the data exchange you've sniffed.
[admin@MikroTik] /tool/sniffer/host> print
# ADDRESS RATE PEEK-RATE TOTAL
0 10.5.101.3 0bps/0bps 0bps/720bps 0/90
1 10.5.101.10 0bps/0bps 175.0kbps/19.7kbps 61231/7011
2 10.5.101.13 0bps/0bps 0bps/608bps 0/76
3 10.5.101.14 0bps/0bps 0bps/976bps 0/212
4 10.5.101.15 0bps/0bps 19.7kbps/175.0kbps 7011/61231
5 224.0.0.2 0bps/0bps 608bps/0bps 76/0
6 224.0.0.5 0bps/0bps 1440bps/0bps 302/0
Packet Sniffer Connections
Here you can get a list of the connections that have been watched during the sniffing time.
[admin@MikroTik] /tool/sniffer/connection> print
Flags: A - active
# SRC-ADDRESS DST-ADDRESS BYTES RESENDS MSS
0 A 10.0.0.241:1839 10.0.0.181:23 (telnet) 6/42 60/0 0/0
1 A 10.0.0.144:2265 10.0.0.181:22 (ssh) 504/252 504/0 0/0
