Skip to main content
Version: 7.24
Dynamic DNS
Sub-menu: /tool/dns-update
Standards: RFC 2136, RFC 3007
Dynamic DNS Update Tool gives a way to keep the domain name pointing to a dynamic IP address. It works by sending domain name system update requests to the name server, which has a zone to be updated. Secure DNS updates are also supported.
The DNS update tool supports only one algorithm - hmac-md5. It's the only proposed algorithm for signing DNS messages.
warning
DNS update tool works only with the BIND server; it will not work with DynDNS, EveryDNS, or any other similar service.
Properties​
PropertyDescription
address (IP; Default: )Defines the IP address associated with the domain name.
dns-server (IP; Default: )DNS server to send updates to.
key (string; Default: )Authorization key to access the server.
key-name (string; Default: )Authorization key name (like a username) to access the server.
name (string; Default: )Name to attach to the IP address.
ttl (integer; Default: )Time to live for the item (in seconds).
zone (string; Default: )DNS zone where to update the domain name.
warning
The system clock time on your router can't differ from the DNS server's time by more than 5 minutes. Otherwise, the DNS server will ignore this request.
Example​
To tell the 23.34.45.56 DNS server to (re)associate the mydomain name in the myzone.com zone with the 68.42.14.4 IP address specifying that the name of the key is dns-update-key and the actual key updates:
[admin@MikroTik] tool> dns-update dns-server=23.34.45.56 name=mydomain \
\... zone=myzone.com address=68.42.14.4 key-name=dns-update-key key=update
