Skip to main content
Version: 7.24
caps-man
caps-man/aaa​
Package: wireless-rep
Type: Settings Directory
ArgumentTypeDescription
mac-formatstring
mac-modeenum (as-username | as-username-and-password)
mac-cachingalt { enum (disabled) { disabled:0 } , time }
interim-updatealt { enum (disabled) { disabled:0 } , time }
called-formatenum (mac:ssid | mac | ssid)
caps-man/acl/access-list​
Type: Directory
FlagNameDescription
Xdisabled
mac-address ( unset )macAddr
mac-address-mask ( unset )macAddr
interface ( unset )iface_enum { , any:0 }
signal-range ( unset )composite { , }
allow-signal-out-of-range ( unset )alt { enum (always) { always:0 } , time }
ssid-regexp ( unset )string
time ( unset )super { time [0 .. 86400] , -time [0 .. 86400] , ,ubit (sun, mon, tue, wed, thu, fri, sat) { sun, mon, tue, wed, thu, fri, sat } }
action ( unset )enum (accept | reject | query-radius)
ap-tx-limit ( unset )num
client-tx-limit ( unset )num
private-passphrase ( unset )string
radius-accounting ( unset )bool
client-to-client-forwarding ( unset )bool
vlan-mode ( unset )enum (no-tag | use-tag | use-service-tag)
vlan-id ( unset )num
caps-man/cfg/configuration​
Type: Directory
name ( mandatory )string
security ( unset )enum
datapath ( unset )enum
channel ( unset )enum
rates ( unset )enum
mode ( unset )enum (ap)
ssid ( unset )string
hide-ssid ( unset )bool
max-sta-count ( unset )num
multicast-helper ( unset )enum (default | disabled | full | dhcp)
tx-chains ( unset )ubit (0, 1, 2, 3)
rx-chains ( unset )ubit (0, 1, 2, 3)
guard-interval ( unset )enum (any | long)
country ( unset )enum
installation ( unset )enum (any | indoor | outdoor)
load-balancing-group ( unset )enum
distance ( unset )enum (indoors | dynamic)
hw-retries ( unset )num
hw-protection-mode ( unset )enum (none | rts-cts | cts-to-self)
frame-lifetime ( unset )time
disconnect-timeout ( unset )time
keepalive-frames ( unset )bool
authentication-types ( unset )ubit (wpa-psk, wpa2-psk, wpa-eap, wpa2-eap)
encryption ( unset )ubit (aes-ccm, tkip)
group-encryption ( unset )enum (aes-ccm | tkip)
group-key-updatetime
eap-methods ( unset )multi { array-id, enum (eap-tls | passthrough) { eap-tls:13, passthrough:0xffffffff } }
eap-radius-accounting ( unset )bool
tls-modeenum (verify-certificate | dont-verify-certificate | no-certificates | verify-certificate-with-crl)
tls-certificateenum (none)
disable-pmkid ( unset )bool
mtunum
l2mtunum
arpenum (disabled | enabled | proxy-arp | reply-only | local-proxy-arp)
bridge ( unset )iface_enum
bridge-cost ( unset )num
bridge-horizon ( unset )num
openflow-switch ( unset )enum
local-forwarding ( unset )bool
interface-list ( unset )enum
frequency ( unset )multi { array-id, num }
secondary-frequency ( unset )multi { array-id, alt { enum (disabled) { disabled:wlc::CHANCFG_SECFREQS_DISABLED } , num } { enum (disabled) { disabled:wlc::CHANCFG_SECFREQS_DISABLED } , num } }
control-channel-width ( unset )enum (5mhz | 10mhz | 20mhz | 40mhz-turbo)
band ( unset )enum (2ghz-b | 2ghz-onlyg | 2ghz-b/g | 5ghz-a | 5ghz-onlyn | 5ghz-a/n | 2ghz-onlyn | 2ghz-b/g/n | 2ghz-g/n | 5ghz-a/n/ac | 5ghz-n/ac | 5ghz-onlyac)
extension-channel ( unset )enum (disabled | Ce | eC | Ceee | eCee | eeCe | eeeC | XX | XXXX | Ceeeeeee | eCeeeeee | eeCeeeee | eeeCeeee | eeeeCeee | eeeeeCee | eeeeeeCe | eeeeeeeC | XXXXXXXX)
tx-power ( unset )num
save-selected ( unset )bool
reselect-interval ( unset )super { time [1 .. 60*60*24*300] , ..time [1 .. 60*60*24*300] }
skip-dfs-channels ( unset )bool
basic ( unset )ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps, 6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps)
supported ( unset )ubit (1Mbps, 2Mbps, 5.5Mbps, 11Mbps, 6Mbps, 9Mbps, 12Mbps, 18Mbps, 24Mbps, 36Mbps, 48Mbps, 54Mbps)
ht-basic-mcs ( unset )ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23)
ht-supported-mcs ( unset )ubit (mcs-0, mcs-1, mcs-2, mcs-3, mcs-4, mcs-5, mcs-6, mcs-7, mcs-8, mcs-9, mcs-10, mcs-11, mcs-12, mcs-13, mcs-14, mcs-15, mcs-16, mcs-17, mcs-18, mcs-19, mcs-20, mcs-21, mcs-22, mcs-23)
vht-basic-mcs ( unset )multi { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } }
vht-supported-mcs ( unset )multi { array-id, enum (none | mcs0-7 | mcs0-8 | mcs0-9) { none:0, mcs0-7:1, mcs0-8:2, mcs0-9:3 } }
caps-man/chancfg/channel​
Type: Directory
caps-man/controller/manager​
enabledbool
certificateenum (none | auto)
ca-certificateenum (none | auto)
package-pathstring
upgrade-policyenum (none | suggest-same-version | require-same-version)
require-peer-certificatebool
Read-only ArgumentTypeDescription
generated-certificateenum (none)
generated-ca-certificateenum (none)
caps-man/controller/manager/interface​
Type: Directory
FlagNameDescription
*default
Xdisabled
Ddynamic
interface ( mandatory )iface_enum { all:nv::BADID }
forbidbool
caps-man/dpathcfg/datapath​
Type: Directory
mtunum
l2mtunum
caps-man/ifaceactual/actual-interface-configuration​
Type: Directory
FlagNameDescription
Mmaster
Ddynamic
Bbound
Xdisabled
Iinactive
Rrunning
namestring
mac-addressmacAddr
arp-timeoutalt { enum (auto) { auto:0 } , time }
disable-running-checkbool
radio-macmacAddr
master-interfaceiface_enum { none:nv::BADID }
mtunum
l2mtunum
caps-man/interface​
Type: Directory
FlagNameDescription
Mmaster
Ddynamic
Bbound
Xdisabled
Iinactive
Rrunning
namestring
mac-addressmacAddr
radio-macmacAddr
radio-namestring
configuration ( unset )enum
rates ( unset )enum
mtunum
l2mtunum
current-statestring
current-channelstring
current-rate-setstring
current-basic-rate-setstring
current-registered-clientsnum
current-authorized-clientsnum
caps-man/interface/hw-info​
Type: Command
interfaceiface_enum
rangesmulti { array-id, string }
tx-chainsubit (0, 1, 2, 3)
rx-chainsubit (0, 1, 2, 3)
antenna-gainnum
locked-countriesmulti { array-id, enum }
caps-man/interface/possible-channels​
Type: Command
interfaceiface_enum
channelsmulti { array-id, string }
caps-man/interface/reselect-channel​
Type: Command
interfaceiface_enum
caps-man/interface/scan​
Type: Command
FlagNameDescription
Aactive
Pprivacy
Rrouteros-network
Nnstreme
Ttdma
Wwds
Bbridge
interfaceiface_enum
save-filestring
roundsnum
addressmacAddr
ssidstring
channelstring
signum
nfnum
snrnum
radio-namestring
routeros-versionstring
caps-man/radio​
Type: Directory
FlagNameDescription
Llocal
Pprovisioned
radio-macmacAddr
remote-cap-namestring
remote-cap-identitystring
interfaceiface_enum
caps-man/radio/hw-info​
Type: Command
antenna-gainnum
caps-man/radio/provision​
Type: Command
caps-man/ratescfg/rates​
Type: Directory
caps-man/remoteap/remote-cap​
Type: Directory
statestring
namestring
radiosnum
addresssuper { alt { ip6Addr , macAddr } { ip6Addr , macAddr } , /num }
boardstring
serialstring
base-macstring
versionstring
identitystring
caps-man/remoteap/remote-cap/provision​
Type: Command
caps-man/remoteap/remote-cap/set-identity​
Type: Command
identitystring
caps-man/remoteap/remote-cap/upgrade​
Type: Command
caps-man/rule/provisioning​
Type: Directory
FlagNameDescription
Xdisabled
radio-macmacAddr
hw-supported-modesmulti { array-id, enum (a | a-turbo | an | ac | b | g | g-turbo | gn) { a:1, a-turbo:2, an:3, ac:5, b:0x11, g:0x12, g-turbo:0x13, gn:0x14 } }
identity-regexpstring
common-name-regexpstring
ip-address-rangesmulti { , , ipRange }
actionenum (none | create-enabled | create-disabled | create-dynamic-enabled)
master-configurationenum
slave-configurationsmulti { array-id, enum }
name-formatenum (cap | prefix | identity | prefix-identity)
name-prefixstring
caps-man/seccfg/security​
Type: Directory
caps-man/sta/registration-table​
Type: Directory
interfaceiface_enum
ssidstring
mac-addressmacAddr
radio-namestring
tx-ratestring
rx-ratestring
tx-signalnum
rx-signalnum
uptimetime
packetscomposite { , }
bytescomposite { , }
tx-rate-setstring
eap-identitystring
vlan-idnum
last-ipipAddr
